  4. Zigbee Update
    5.9k
Zigbee Update
zigbee-adapter
35 Beiträge 6 Kommentatoren 2.7k Aufrufe 8 Beobachtet
  • AsgothianA Asgothian
    @michihorn
    So einfach war das dann doch nicht. Da ich den Fehler nicht reproduzieren kann würde ich dich bitten das folgende zu tun:
    • Adapter im Debug starten
    • Im Debug Log nach "getDevices result" suchen
    • das JSON was als Ergebnis ausgegeben wird hier posten.
    A.
    M Online
    M Online
    michihorn
    @asgothian Hallöchen anbei mein aktuelles Debug-Log:
    zigbee.0	2022-05-17 19:27:40.298	debug	(10400) Publish {"voltage":3025,"battery":100,"temperature":27.64,"humidity":47.86,"pressure":1019.4} to "00158d0001e0821b"
    zigbee.0	2022-05-17 19:27:40.297	debug	(10400) lumi.weather: Processed data into payload {"voltage":3025,"battery":100,"temperature":27.64,"humidity":47.86,"pressure":1019.4}
    zigbee.0	2022-05-17 19:27:40.296	debug	(10400) lumi.weather: Processed data into payload {"voltage":3025,"battery":100,"temperature":27.64,"humidity":47.86,"pressure":1019.4}
    zigbee.0	2022-05-17 19:27:40.295	debug	(10400) lumi.weather: unknown key 6 with value 0,1
    zigbee.0	2022-05-17 19:27:40.275	debug	(10400) Type attributeReport device {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":14,"_type":"EndDevice","_ieeeAddr":"0x00158d0001e0821b","_networkAddress":60095,"_
    zigbee.0	2022-05-17 19:27:40.273	debug	(10400) Received Zigbee message from '0x00158d0001e0821b', type 'attributeReport', cluster 'genBasic', data '{"65281":{"1":3025,"4":17320,"5":12,"6":[0,1],"10":0,"100":2764,"101":4786,"102":101941}}'
    zigbee.0	2022-05-17 19:27:40.263	debug	(10400) handleMessage. {"type":"attributeReport","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":14,"_type":"EndDevice","_ieeeAddr":"0x00158d0001e0821b","_networkAddress":60095,"_manu
    zigbee.0	2022-05-17 19:27:18.654	debug	(10400) DeviceAvailability:Non-pingable device 0x00158d000549dc7f lumi.sensor_ht was last seen '1429.172' seconds ago.
    zigbee.0	2022-05-17 19:27:18.654	debug	(10400) DeviceAvailability:Non-pingable device 0x0c4314fffe84e6d8 TS0042 was last seen '842.132' seconds ago.
    zigbee.0	2022-05-17 19:27:18.653	debug	(10400) DeviceAvailability:Non-pingable device 0x00158d000253e897 lumi.sensor_motion.aq2 was last seen '1970.227' seconds ago.
    zigbee.0	2022-05-17 19:27:18.652	debug	(10400) DeviceAvailability:Non-pingable device 0x00158d0001e09c1a lumi.weather was last seen '845.908' seconds ago.
    zigbee.0	2022-05-17 19:27:18.652	debug	(10400) DeviceAvailability:Non-pingable device 0x00158d000444cb23 lumi.weather was last seen '2804.276' seconds ago.
    zigbee.0	2022-05-17 19:27:18.651	debug	(10400) DeviceAvailability:Non-pingable device 0x00158d00028d6fc4 lumi.sensor_magnet.aq2 was last seen '4232.566' seconds ago.
    zigbee.0	2022-05-17 19:27:18.651	debug	(10400) DeviceAvailability:Non-pingable device 0x00158d0001e0821b lumi.weather was last seen '2384.747' seconds ago.
    zigbee.0	2022-05-17 19:27:18.650	debug	(10400) DeviceAvailability:Non-pingable device 0x00158d0001e13db7 lumi.weather was last seen '2225.688' seconds ago.
    zigbee.0	2022-05-17 19:27:18.650	debug	(10400) DeviceAvailability:Non-pingable device 0x00158d0007b6e4bd lumi.sensor_magnet.aq2 was last seen '7805.876' seconds ago.
    zigbee.0	2022-05-17 19:27:18.649	debug	(10400) DeviceAvailability:Non-pingable device 0x00158d0007f851b6 lumi.sensor_magnet.aq2 was last seen '1108.094' seconds ago.
    zigbee.0	2022-05-17 19:27:18.648	debug	(10400) onDeviceStatusUpdate: 00158d0007e0590a: false
    zigbee.0	2022-05-17 19:27:18.645	debug	(10400) DeviceAvailability:Publish LQ for 0x00158d0007e0590a = 0
    zigbee.0	2022-05-17 19:27:18.641	debug	(10400) DeviceAvailability:Publish available for 0x00158d0007e0590a = false
    zigbee.0	2022-05-17 19:27:18.641	debug	(10400) DeviceAvailability:Non-pingable device 0x00158d0007e0590a lumi.sensor_magnet.aq2 was last seen '6514082.173' seconds ago.
    zigbee.0	2022-05-17 19:27:18.640	debug	(10400) DeviceAvailability:Non-pingable device 0x00158d0007e033e1 lumi.sensor_magnet.aq2 was last seen '2201.405' seconds ago.
    zigbee.0	2022-05-17 19:27:18.639	debug	(10400) DeviceAvailability:Non-pingable device 0x00158d0007b7cdce lumi.sensor_magnet.aq2 was last seen '1716.683' seconds ago.
    zigbee.0	2022-05-17 19:27:18.638	debug	(10400) DeviceAvailability:Non-pingable device 0x00158d000476bd65 lumi.sensor_magnet.aq2 was last seen '601.914' seconds ago.
    zigbee.0	2022-05-17 19:27:18.637	debug	(10400) DeviceAvailability:Non-pingable device 0x00158d00069ac702 lumi.sensor_magnet.aq2 was last seen '106.695' seconds ago.
    zigbee.0	2022-05-17 19:27:18.636	debug	(10400) onDeviceStatusUpdate: 00158d0006becb12: false
    zigbee.0	2022-05-17 19:27:18.633	debug	(10400) DeviceAvailability:Publish LQ for 0x00158d0006becb12 = 0
    zigbee.0	2022-05-17 19:27:18.630	debug	(10400) DeviceAvailability:Publish available for 0x00158d0006becb12 = false
    zigbee.0	2022-05-17 19:27:18.629	debug	(10400) DeviceAvailability:Non-pingable device 0x00158d0006becb12 lumi.sensor_magnet.aq2 was last seen '6513860.368' seconds ago.
    zigbee.0	2022-05-17 19:27:18.629	debug	(10400) DeviceAvailability:Non-pingable device 0x00158d000423bfd0 lumi.sensor_motion.aq2 was last seen '718.624' seconds ago.
    zigbee.0	2022-05-17 19:27:18.628	debug	(10400) DeviceAvailability:Non-pingable device 0x00158d0007e3ac5e lumi.weather was last seen '2481.471' seconds ago.
    zigbee.0	2022-05-17 19:27:18.626	debug	(10400) DeviceAvailability:Non-pingable device 0x00158d0007e20084 lumi.weather was last seen '18.887' seconds ago.
    zigbee.0	2022-05-17 19:26:59.783	debug	(10400) Publish {"voltage":3025,"battery":100,"temperature":28.38,"humidity":46.32,"pressure":1018.4} to "00158d0007e20084"
    zigbee.0	2022-05-17 19:26:59.783	debug	(10400) lumi.weather: Processed data into payload {"voltage":3025,"battery":100,"temperature":28.38,"humidity":46.32,"pressure":1018.4}
    zigbee.0	2022-05-17 19:26:59.782	debug	(10400) lumi.weather: Processed data into payload {"voltage":3025,"battery":100,"temperature":28.38,"humidity":46.32,"pressure":1018.4}
    zigbee.0	2022-05-17 19:26:59.781	debug	(10400) lumi.weather: unknown key 6 with value 0,1
    zigbee.0	2022-05-17 19:26:59.757	debug	(10400) Type attributeReport device {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":2,"_type":"EndDevice","_ieeeAddr":"0x00158d0007e20084","_networkAddress":16818,"_m
    zigbee.0	2022-05-17 19:26:59.754	debug	(10400) Received Zigbee message from '0x00158d0007e20084', type 'attributeReport', cluster 'genBasic', data '{"65281":{"1":3025,"4":5032,"5":23,"6":[0,1],"10":0,"100":2838,"101":4632,"102":101837}}' f
    zigbee.0	2022-05-17 19:26:59.743	debug	(10400) handleMessage. {"type":"attributeReport","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":2,"_type":"EndDevice","_ieeeAddr":"0x00158d0007e20084","_networkAddress":16818,"_manuf
    zigbee.0	2022-05-17 19:26:19.954	debug	(10400) onDeviceStatusUpdate: 00158d000549dc7f: true
    zigbee.0	2022-05-17 19:26:19.951	debug	(10400) DeviceAvailability:Publish LQ for 0x00158d000549dc7f = 10
    zigbee.0	2022-05-17 19:26:19.949	debug	(10400) DeviceAvailability:Publish available for 0x00158d000549dc7f = true
    zigbee.0	2022-05-17 19:26:19.948	debug	(10400) onDeviceStatusUpdate: 0c4314fffe84e6d8: true
    zigbee.0	2022-05-17 19:26:19.945	debug	(10400) DeviceAvailability:Publish LQ for 0x0c4314fffe84e6d8 = 10
    zigbee.0	2022-05-17 19:26:19.940	debug	(10400) DeviceAvailability:Publish available for 0x0c4314fffe84e6d8 = true
    zigbee.0	2022-05-17 19:26:19.939	debug	(10400) onDeviceStatusUpdate: 00158d000253e897: true
    zigbee.0	2022-05-17 19:26:19.933	debug	(10400) DeviceAvailability:Publish LQ for 0x00158d000253e897 = 10
    zigbee.0	2022-05-17 19:26:19.931	debug	(10400) DeviceAvailability:Publish available for 0x00158d000253e897 = true
    zigbee.0	2022-05-17 19:26:19.929	debug	(10400) onDeviceStatusUpdate: 00158d0001e09c1a: true
    zigbee.0	2022-05-17 19:26:19.926	debug	(10400) DeviceAvailability:Publish LQ for 0x00158d0001e09c1a = 10
    zigbee.0	2022-05-17 19:26:19.923	debug	(10400) DeviceAvailability:Publish available for 0x00158d0001e09c1a = true
    zigbee.0	2022-05-17 19:26:19.922	debug	(10400) onDeviceStatusUpdate: 00158d000444cb23: true
    zigbee.0	2022-05-17 19:26:19.919	debug	(10400) DeviceAvailability:Publish LQ for 0x00158d000444cb23 = 10
    zigbee.0	2022-05-17 19:26:19.916	debug	(10400) DeviceAvailability:Publish available for 0x00158d000444cb23 = true
    zigbee.0	2022-05-17 19:26:19.915	debug	(10400) onDeviceStatusUpdate: 00158d00028d6fc4: true
    zigbee.0	2022-05-17 19:26:19.912	debug	(10400) DeviceAvailability:Publish LQ for 0x00158d00028d6fc4 = 10
    zigbee.0	2022-05-17 19:26:19.910	debug	(10400) DeviceAvailability:Publish available for 0x00158d00028d6fc4 = true
    zigbee.0	2022-05-17 19:26:19.908	debug	(10400) onDeviceStatusUpdate: 00158d0001e0821b: true
    zigbee.0	2022-05-17 19:26:19.905	debug	(10400) DeviceAvailability:Publish LQ for 0x00158d0001e0821b = 10
    zigbee.0	2022-05-17 19:26:19.903	debug	(10400) DeviceAvailability:Publish available for 0x00158d0001e0821b = true
    zigbee.0	2022-05-17 19:26:19.900	debug	(10400) onDeviceStatusUpdate: 00158d0001e13db7: true
    zigbee.0	2022-05-17 19:26:19.893	debug	(10400) DeviceAvailability:Publish LQ for 0x00158d0001e13db7 = 10
    zigbee.0	2022-05-17 19:26:19.891	debug	(10400) DeviceAvailability:Publish available for 0x00158d0001e13db7 = true
    zigbee.0	2022-05-17 19:26:19.889	debug	(10400) onDeviceStatusUpdate: 00158d0007b6e4bd: true
    zigbee.0	2022-05-17 19:26:19.886	debug	(10400) DeviceAvailability:Publish LQ for 0x00158d0007b6e4bd = 10
    zigbee.0	2022-05-17 19:26:19.880	debug	(10400) DeviceAvailability:Publish available for 0x00158d0007b6e4bd = true
    zigbee.0	2022-05-17 19:26:19.876	debug	(10400) onDeviceStatusUpdate: 00158d0007f851b6: true
    zigbee.0	2022-05-17 19:26:19.873	debug	(10400) DeviceAvailability:Publish LQ for 0x00158d0007f851b6 = 10
    zigbee.0	2022-05-17 19:26:19.869	debug	(10400) DeviceAvailability:Publish available for 0x00158d0007f851b6 = true
    zigbee.0	2022-05-17 19:26:19.866	debug	(10400) onDeviceStatusUpdate: 00158d0007e0590a: true
    zigbee.0	2022-05-17 19:26:19.861	debug	(10400) DeviceAvailability:Publish LQ for 0x00158d0007e0590a = 10
    zigbee.0	2022-05-17 19:26:19.859	debug	(10400) DeviceAvailability:Publish available for 0x00158d0007e0590a = true
    zigbee.0	2022-05-17 19:26:19.857	debug	(10400) onDeviceStatusUpdate: 00158d0007e033e1: true
    zigbee.0	2022-05-17 19:26:19.855	debug	(10400) DeviceAvailability:Publish LQ for 0x00158d0007e033e1 = 10
    zigbee.0	2022-05-17 19:26:19.852	debug	(10400) DeviceAvailability:Publish available for 0x00158d0007e033e1 = true
    zigbee.0	2022-05-17 19:26:19.851	debug	(10400) onDeviceStatusUpdate: 00158d0007b7cdce: true
    zigbee.0	2022-05-17 19:26:19.848	debug	(10400) DeviceAvailability:Publish LQ for 0x00158d0007b7cdce = 10
    zigbee.0	2022-05-17 19:26:19.846	debug	(10400) DeviceAvailability:Publish available for 0x00158d0007b7cdce = true
    zigbee.0	2022-05-17 19:26:19.834	debug	(10400) onDeviceStatusUpdate: 00158d000476bd65: true
    zigbee.0	2022-05-17 19:26:19.831	debug	(10400) DeviceAvailability:Publish LQ for 0x00158d000476bd65 = 10
    zigbee.0	2022-05-17 19:26:19.827	debug	(10400) DeviceAvailability:Publish available for 0x00158d000476bd65 = true
    zigbee.0	2022-05-17 19:26:19.826	debug	(10400) onDeviceStatusUpdate: 00158d00069ac702: true
    zigbee.0	2022-05-17 19:26:19.823	debug	(10400) DeviceAvailability:Publish LQ for 0x00158d00069ac702 = 10
    zigbee.0	2022-05-17 19:26:19.820	debug	(10400) DeviceAvailability:Publish available for 0x00158d00069ac702 = true
    zigbee.0	2022-05-17 19:26:19.819	debug	(10400) onDeviceStatusUpdate: 00158d0006becb12: true
    zigbee.0	2022-05-17 19:26:19.815	debug	(10400) DeviceAvailability:Publish LQ for 0x00158d0006becb12 = 10
    zigbee.0	2022-05-17 19:26:19.812	debug	(10400) DeviceAvailability:Publish available for 0x00158d0006becb12 = true
    zigbee.0	2022-05-17 19:26:19.811	debug	(10400) onDeviceStatusUpdate: 00158d000423bfd0: true
    zigbee.0	2022-05-17 19:26:19.808	debug	(10400) DeviceAvailability:Publish LQ for 0x00158d000423bfd0 = 10
    zigbee.0	2022-05-17 19:26:19.805	debug	(10400) DeviceAvailability:Publish available for 0x00158d000423bfd0 = true
    zigbee.0	2022-05-17 19:26:19.802	debug	(10400) onDeviceStatusUpdate: 00158d0007e3ac5e: true
    zigbee.0	2022-05-17 19:26:19.798	debug	(10400) DeviceAvailability:Publish LQ for 0x00158d0007e3ac5e = 10
    zigbee.0	2022-05-17 19:26:19.796	debug	(10400) DeviceAvailability:Publish available for 0x00158d0007e3ac5e = true
    zigbee.0	2022-05-17 19:26:19.789	debug	(10400) onDeviceStatusUpdate: 00158d0007e20084: true
    zigbee.0	2022-05-17 19:26:19.786	debug	(10400) DeviceAvailability:Publish LQ for 0x00158d0007e20084 = 10
    zigbee.0	2022-05-17 19:26:19.783	debug	(10400) DeviceAvailability:Publish available for 0x00158d0007e20084 = true
    zigbee.0	2022-05-17 19:26:19.103	debug	(10400) DeviceAvailability:register device Ping for "0x00158d000549dc7f"
    zigbee.0	2022-05-17 19:26:19.102	debug	(10400) DeviceAvailability:register device Ping for "0x0c4314fffe84e6d8"
    zigbee.0	2022-05-17 19:26:19.101	debug	(10400) DeviceAvailability:register device Ping for "0x00158d000253e897"
    zigbee.0	2022-05-17 19:26:19.101	debug	(10400) DeviceAvailability:register device Ping for "0x00158d0001e09c1a"
    zigbee.0	2022-05-17 19:26:19.100	debug	(10400) DeviceAvailability:register device Ping for "0x00158d000444cb23"
    zigbee.0	2022-05-17 19:26:19.099	debug	(10400) DeviceAvailability:register device Ping for "0x00158d00028d6fc4"
    zigbee.0	2022-05-17 19:26:19.098	debug	(10400) DeviceAvailability:register device Ping for "0x00158d0001e0821b"
    zigbee.0	2022-05-17 19:26:19.097	debug	(10400) DeviceAvailability:register device Ping for "0x00158d0001e13db7"
    zigbee.0	2022-05-17 19:26:19.096	debug	(10400) DeviceAvailability:register device Ping for "0x00158d0007b6e4bd"
    zigbee.0	2022-05-17 19:26:19.095	debug	(10400) DeviceAvailability:register device Ping for "0x00158d0007f851b6"
    zigbee.0	2022-05-17 19:26:19.095	debug	(10400) DeviceAvailability:register device Ping for "0x00158d0007e0590a"
    zigbee.0	2022-05-17 19:26:19.094	debug	(10400) DeviceAvailability:register device Ping for "0x00158d0007e033e1"
    zigbee.0	2022-05-17 19:26:19.093	debug	(10400) DeviceAvailability:register device Ping for "0x00158d0007b7cdce"
    zigbee.0	2022-05-17 19:26:19.092	debug	(10400) DeviceAvailability:register device Ping for "0x00158d000476bd65"
    zigbee.0	2022-05-17 19:26:19.092	debug	(10400) DeviceAvailability:register device Ping for "0x00158d00069ac702"
    zigbee.0	2022-05-17 19:26:19.091	debug	(10400) DeviceAvailability:register device Ping for "0x00158d0006becb12"
    zigbee.0	2022-05-17 19:26:19.090	debug	(10400) DeviceAvailability:register device Ping for "0x00158d000423bfd0"
    zigbee.0	2022-05-17 19:26:19.089	debug	(10400) DeviceAvailability:register device Ping for "0x00158d0007e3ac5e"
    zigbee.0	2022-05-17 19:26:19.083	debug	(10400) DeviceAvailability:register device Ping for "0x00158d0007e20084"
    zigbee.0	2022-05-17 19:26:18.975	debug	(10400) getGroups result: {}
    zigbee.0	2022-05-17 19:26:18.843	info	(10400) Zigbee started
    zigbee.0	2022-05-17 19:26:18.841	info	(10400) 0x00158d000549dc7f (addr 44107): WSDCGQ01LM - Xiaomi MiJia temperature & humidity sensor (EndDevice)
    zigbee.0	2022-05-17 19:26:18.840	debug	(10400) New device event: {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":20,"_type":"EndDevice","_ieeeAddr":"0x00158d000549dc7f","_networkAddress":44107,"_manufactur
    zigbee.0	2022-05-17 19:26:18.839	info	(10400) 0x0c4314fffe84e6d8 (addr 47520): TS0042 - TuYa Wireless switch with 2 buttons (EndDevice)
    zigbee.0	2022-05-17 19:26:18.838	debug	(10400) New device event: {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":19,"_type":"EndDevice","_ieeeAddr":"0x0c4314fffe84e6d8","_networkAddress":47520,"_manufactur
    zigbee.0	2022-05-17 19:26:18.836	info	(10400) 0x00158d000253e897 (addr 9982): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
    zigbee.0	2022-05-17 19:26:18.835	debug	(10400) New device event: {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":18,"_type":"EndDevice","_ieeeAddr":"0x00158d000253e897","_networkAddress":9982,"_manufacture
    zigbee.0	2022-05-17 19:26:18.833	info	(10400) 0x00158d0001e09c1a (addr 40367): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
    zigbee.0	2022-05-17 19:26:18.832	debug	(10400) New device event: {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":17,"_type":"EndDevice","_ieeeAddr":"0x00158d0001e09c1a","_networkAddress":40367,"_manufactur
    zigbee.0	2022-05-17 19:26:18.831	info	(10400) 0x00158d000444cb23 (addr 31810): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
    zigbee.0	2022-05-17 19:26:18.828	debug	(10400) New device event: {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":16,"_type":"EndDevice","_ieeeAddr":"0x00158d000444cb23","_networkAddress":31810,"_manufactur
    zigbee.0	2022-05-17 19:26:18.827	info	(10400) 0x00158d00028d6fc4 (addr 28105): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
    zigbee.0	2022-05-17 19:26:18.826	debug	(10400) New device event: {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":15,"_type":"EndDevice","_ieeeAddr":"0x00158d00028d6fc4","_networkAddress":28105,"_manufactur
    zigbee.0	2022-05-17 19:26:18.825	info	(10400) 0x00158d0001e0821b (addr 60095): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
    zigbee.0	2022-05-17 19:26:18.824	debug	(10400) New device event: {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":14,"_type":"EndDevice","_ieeeAddr":"0x00158d0001e0821b","_networkAddress":60095,"_manufactur
    zigbee.0	2022-05-17 19:26:18.823	info	(10400) 0x00158d0001e13db7 (addr 17859): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
    zigbee.0	2022-05-17 19:26:18.821	debug	(10400) New device event: {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":13,"_type":"EndDevice","_ieeeAddr":"0x00158d0001e13db7","_networkAddress":17859,"_manufactur
    zigbee.0	2022-05-17 19:26:18.820	info	(10400) 0x00158d0007b6e4bd (addr 10048): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
    zigbee.0	2022-05-17 19:26:18.819	debug	(10400) New device event: {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":12,"_type":"EndDevice","_ieeeAddr":"0x00158d0007b6e4bd","_networkAddress":10048,"_manufactur
    zigbee.0	2022-05-17 19:26:18.817	info	(10400) 0x00158d0007f851b6 (addr 54317): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
    zigbee.0	2022-05-17 19:26:18.816	debug	(10400) New device event: {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":11,"_type":"EndDevice","_ieeeAddr":"0x00158d0007f851b6","_networkAddress":54317,"_manufactur
    zigbee.0	2022-05-17 19:26:18.815	info	(10400) 0x00158d0007e0590a (addr 32469): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
    zigbee.0	2022-05-17 19:26:18.814	debug	(10400) New device event: {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":10,"_type":"EndDevice","_ieeeAddr":"0x00158d0007e0590a","_networkAddress":32469,"_manufactur
    zigbee.0	2022-05-17 19:26:18.812	info	(10400) 0x00158d0007e033e1 (addr 22928): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
    zigbee.0	2022-05-17 19:26:18.811	debug	(10400) New device event: {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":9,"_type":"EndDevice","_ieeeAddr":"0x00158d0007e033e1","_networkAddress":22928,"_manufacture
    zigbee.0	2022-05-17 19:26:18.810	info	(10400) 0x00158d0007b7cdce (addr 62083): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
    zigbee.0	2022-05-17 19:26:18.809	debug	(10400) New device event: {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":8,"_type":"EndDevice","_ieeeAddr":"0x00158d0007b7cdce","_networkAddress":62083,"_manufacture
    zigbee.0	2022-05-17 19:26:18.807	info	(10400) 0x00158d000476bd65 (addr 60884): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
    zigbee.0	2022-05-17 19:26:18.806	debug	(10400) New device event: {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":7,"_type":"EndDevice","_ieeeAddr":"0x00158d000476bd65","_networkAddress":60884,"_manufacture
    zigbee.0	2022-05-17 19:26:18.805	info	(10400) 0x00158d00069ac702 (addr 4598): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
    zigbee.0	2022-05-17 19:26:18.803	debug	(10400) New device event: {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":6,"_type":"EndDevice","_ieeeAddr":"0x00158d00069ac702","_networkAddress":4598,"_manufacturer
    zigbee.0	2022-05-17 19:26:18.802	info	(10400) 0x00158d0006becb12 (addr 5228): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
    zigbee.0	2022-05-17 19:26:18.801	debug	(10400) New device event: {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":5,"_type":"EndDevice","_ieeeAddr":"0x00158d0006becb12","_networkAddress":5228,"_manufacturer
    zigbee.0	2022-05-17 19:26:18.799	info	(10400) 0x00158d000423bfd0 (addr 47946): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
    zigbee.0	2022-05-17 19:26:18.798	debug	(10400) New device event: {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":4,"_type":"EndDevice","_ieeeAddr":"0x00158d000423bfd0","_networkAddress":47946,"_manufacture
    zigbee.0	2022-05-17 19:26:18.796	info	(10400) 0x00158d0007e3ac5e (addr 48933): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
    zigbee.0	2022-05-17 19:26:18.795	debug	(10400) New device event: {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":3,"_type":"EndDevice","_ieeeAddr":"0x00158d0007e3ac5e","_networkAddress":48933,"_manufacture
    zigbee.0	2022-05-17 19:26:18.779	info	(10400) 0x00158d0007e20084 (addr 16818): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
    zigbee.0	2022-05-17 19:26:18.777	debug	(10400) New device event: {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":2,"_type":"EndDevice","_ieeeAddr":"0x00158d0007e20084","_networkAddress":16818,"_manufacture
    zigbee.0	2022-05-17 19:26:18.774	debug	(10400) DeviceConfigure:DeviceConfigure 0x00158d000549dc7f lumi.sensor_ht not needed
    zigbee.0	2022-05-17 19:26:18.774	debug	(10400) DeviceConfigure:DeviceConfigure 0x0c4314fffe84e6d8 TS0042 not needed
    zigbee.0	2022-05-17 19:26:18.773	debug	(10400) DeviceConfigure:DeviceConfigure 0x00158d000253e897 lumi.sensor_motion.aq2 not needed
    zigbee.0	2022-05-17 19:26:18.772	debug	(10400) DeviceConfigure:DeviceConfigure 0x00158d0001e09c1a lumi.weather not needed
    zigbee.0	2022-05-17 19:26:18.772	debug	(10400) DeviceConfigure:DeviceConfigure 0x00158d000444cb23 lumi.weather not needed
    zigbee.0	2022-05-17 19:26:18.772	debug	(10400) DeviceConfigure:DeviceConfigure 0x00158d00028d6fc4 lumi.sensor_magnet.aq2 not needed
    zigbee.0	2022-05-17 19:26:18.771	debug	(10400) DeviceConfigure:DeviceConfigure 0x00158d0001e0821b lumi.weather not needed
    zigbee.0	2022-05-17 19:26:18.771	debug	(10400) DeviceConfigure:DeviceConfigure 0x00158d0001e13db7 lumi.weather not needed
    zigbee.0	2022-05-17 19:26:18.770	debug	(10400) DeviceConfigure:DeviceConfigure 0x00158d0007b6e4bd lumi.sensor_magnet.aq2 not needed
    zigbee.0	2022-05-17 19:26:18.770	debug	(10400) DeviceConfigure:DeviceConfigure 0x00158d0007f851b6 lumi.sensor_magnet.aq2 not needed
    zigbee.0	2022-05-17 19:26:18.769	debug	(10400) DeviceConfigure:DeviceConfigure 0x00158d0007e0590a lumi.sensor_magnet.aq2 not needed
    zigbee.0	2022-05-17 19:26:18.769	debug	(10400) DeviceConfigure:DeviceConfigure 0x00158d0007e033e1 lumi.sensor_magnet.aq2 not needed
    zigbee.0	2022-05-17 19:26:18.768	debug	(10400) DeviceConfigure:DeviceConfigure 0x00158d0007b7cdce lumi.sensor_magnet.aq2 not needed
    zigbee.0	2022-05-17 19:26:18.768	debug	(10400) DeviceConfigure:DeviceConfigure 0x00158d000476bd65 lumi.sensor_magnet.aq2 not needed
    zigbee.0	2022-05-17 19:26:18.768	debug	(10400) DeviceConfigure:DeviceConfigure 0x00158d00069ac702 lumi.sensor_magnet.aq2 not needed
    zigbee.0	2022-05-17 19:26:18.767	debug	(10400) DeviceConfigure:DeviceConfigure 0x00158d0006becb12 lumi.sensor_magnet.aq2 not needed
    zigbee.0	2022-05-17 19:26:18.767	debug	(10400) DeviceConfigure:DeviceConfigure 0x00158d000423bfd0 lumi.sensor_motion.aq2 not needed
    zigbee.0	2022-05-17 19:26:18.766	debug	(10400) DeviceConfigure:DeviceConfigure 0x00158d0007e3ac5e lumi.weather not needed
    zigbee.0	2022-05-17 19:26:18.766	debug	(10400) DeviceConfigure:DeviceConfigure 0x00158d0007e20084 lumi.weather not needed
    zigbee.0	2022-05-17 19:26:18.762	debug	(10400) onDeviceStatusUpdate: 00158d000549dc7f: true
    zigbee.0	2022-05-17 19:26:18.760	debug	(10400) DeviceAvailability:Publish LQ for 0x00158d000549dc7f = 10
    zigbee.0	2022-05-17 19:26:18.758	debug	(10400) DeviceAvailability:Publish available for 0x00158d000549dc7f = true
    zigbee.0	2022-05-17 19:26:18.757	debug	(10400) onDeviceStatusUpdate: 0c4314fffe84e6d8: true
    zigbee.0	2022-05-17 19:26:18.754	debug	(10400) DeviceAvailability:Publish LQ for 0x0c4314fffe84e6d8 = 10
    zigbee.0	2022-05-17 19:26:18.752	debug	(10400) DeviceAvailability:Publish available for 0x0c4314fffe84e6d8 = true
    zigbee.0	2022-05-17 19:26:18.751	debug	(10400) onDeviceStatusUpdate: 00158d000253e897: true
    zigbee.0	2022-05-17 19:26:18.748	debug	(10400) DeviceAvailability:Publish LQ for 0x00158d000253e897 = 10
    zigbee.0	2022-05-17 19:26:18.746	debug	(10400) DeviceAvailability:Publish available for 0x00158d000253e897 = true
    zigbee.0	2022-05-17 19:26:18.745	debug	(10400) onDeviceStatusUpdate: 00158d0001e09c1a: true
    zigbee.0	2022-05-17 19:26:18.742	debug	(10400) DeviceAvailability:Publish LQ for 0x00158d0001e09c1a = 10
    zigbee.0	2022-05-17 19:26:18.740	debug	(10400) DeviceAvailability:Publish available for 0x00158d0001e09c1a = true
    zigbee.0	2022-05-17 19:26:18.739	debug	(10400) onDeviceStatusUpdate: 00158d000444cb23: true
    zigbee.0	2022-05-17 19:26:18.736	debug	(10400) DeviceAvailability:Publish LQ for 0x00158d000444cb23 = 10
    zigbee.0	2022-05-17 19:26:18.734	debug	(10400) DeviceAvailability:Publish available for 0x00158d000444cb23 = true
    zigbee.0	2022-05-17 19:26:18.733	debug	(10400) onDeviceStatusUpdate: 00158d00028d6fc4: true
    zigbee.0	2022-05-17 19:26:18.731	debug	(10400) DeviceAvailability:Publish LQ for 0x00158d00028d6fc4 = 10
    zigbee.0	2022-05-17 19:26:18.728	debug	(10400) DeviceAvailability:Publish available for 0x00158d00028d6fc4 = true
    zigbee.0	2022-05-17 19:26:18.728	debug	(10400) onDeviceStatusUpdate: 00158d0001e0821b: true
    zigbee.0	2022-05-17 19:26:18.725	debug	(10400) DeviceAvailability:Publish LQ for 0x00158d0001e0821b = 10
    zigbee.0	2022-05-17 19:26:18.723	debug	(10400) DeviceAvailability:Publish available for 0x00158d0001e0821b = true
    zigbee.0	2022-05-17 19:26:18.722	debug	(10400) onDeviceStatusUpdate: 00158d0001e13db7: true
    zigbee.0	2022-05-17 19:26:18.720	debug	(10400) DeviceAvailability:Publish LQ for 0x00158d0001e13db7 = 10
    zigbee.0	2022-05-17 19:26:18.718	debug	(10400) DeviceAvailability:Publish available for 0x00158d0001e13db7 = true
    zigbee.0	2022-05-17 19:26:18.717	debug	(10400) onDeviceStatusUpdate: 00158d0007b6e4bd: true
    zigbee.0	2022-05-17 19:26:18.714	debug	(10400) DeviceAvailability:Publish LQ for 0x00158d0007b6e4bd = 10
    zigbee.0	2022-05-17 19:26:18.712	debug	(10400) DeviceAvailability:Publish available for 0x00158d0007b6e4bd = true
    zigbee.0	2022-05-17 19:26:18.711	debug	(10400) onDeviceStatusUpdate: 00158d0007f851b6: true
    zigbee.0	2022-05-17 19:26:18.708	debug	(10400) DeviceAvailability:Publish LQ for 0x00158d0007f851b6 = 10
    zigbee.0	2022-05-17 19:26:18.706	debug	(10400) DeviceAvailability:Publish available for 0x00158d0007f851b6 = true
    zigbee.0	2022-05-17 19:26:18.705	debug	(10400) onDeviceStatusUpdate: 00158d0007e0590a: true
    zigbee.0	2022-05-17 19:26:18.702	debug	(10400) DeviceAvailability:Publish LQ for 0x00158d0007e0590a = 10
    zigbee.0	2022-05-17 19:26:18.699	debug	(10400) DeviceAvailability:Publish available for 0x00158d0007e0590a = true
    zigbee.0	2022-05-17 19:26:18.698	debug	(10400) onDeviceStatusUpdate: 00158d0007e033e1: true
    zigbee.0	2022-05-17 19:26:18.696	debug	(10400) DeviceAvailability:Publish LQ for 0x00158d0007e033e1 = 10
    zigbee.0	2022-05-17 19:26:18.693	debug	(10400) DeviceAvailability:Publish available for 0x00158d0007e033e1 = true
    zigbee.0	2022-05-17 19:26:18.692	debug	(10400) onDeviceStatusUpdate: 00158d0007b7cdce: true
    zigbee.0	2022-05-17 19:26:18.690	debug	(10400) DeviceAvailability:Publish LQ for 0x00158d0007b7cdce = 10
    zigbee.0	2022-05-17 19:26:18.687	debug	(10400) DeviceAvailability:Publish available for 0x00158d0007b7cdce = true
    zigbee.0	2022-05-17 19:26:18.686	debug	(10400) onDeviceStatusUpdate: 00158d000476bd65: true
    zigbee.0	2022-05-17 19:26:18.683	debug	(10400) DeviceAvailability:Publish LQ for 0x00158d000476bd65 = 10
    zigbee.0	2022-05-17 19:26:18.680	debug	(10400) DeviceAvailability:Publish available for 0x00158d000476bd65 = true
    zigbee.0	2022-05-17 19:26:18.679	debug	(10400) onDeviceStatusUpdate: 00158d00069ac702: true
    zigbee.0	2022-05-17 19:26:18.677	debug	(10400) DeviceAvailability:Publish LQ for 0x00158d00069ac702 = 10
    zigbee.0	2022-05-17 19:26:18.674	debug	(10400) DeviceAvailability:Publish available for 0x00158d00069ac702 = true
    zigbee.0	2022-05-17 19:26:18.673	debug	(10400) onDeviceStatusUpdate: 00158d0006becb12: true
    zigbee.0	2022-05-17 19:26:18.671	debug	(10400) DeviceAvailability:Publish LQ for 0x00158d0006becb12 = 10
    zigbee.0	2022-05-17 19:26:18.669	debug	(10400) DeviceAvailability:Publish available for 0x00158d0006becb12 = true
    zigbee.0	2022-05-17 19:26:18.668	debug	(10400) onDeviceStatusUpdate: 00158d000423bfd0: true
    zigbee.0	2022-05-17 19:26:18.666	debug	(10400) DeviceAvailability:Publish LQ for 0x00158d000423bfd0 = 10
    zigbee.0	2022-05-17 19:26:18.664	debug	(10400) DeviceAvailability:Publish available for 0x00158d000423bfd0 = true
    zigbee.0	2022-05-17 19:26:18.663	debug	(10400) onDeviceStatusUpdate: 00158d0007e3ac5e: true
    zigbee.0	2022-05-17 19:26:18.660	debug	(10400) DeviceAvailability:Publish LQ for 0x00158d0007e3ac5e = 10
    zigbee.0	2022-05-17 19:26:18.654	debug	(10400) DeviceAvailability:Publish available for 0x00158d0007e3ac5e = true
    zigbee.0	2022-05-17 19:26:18.651	debug	(10400) onDeviceStatusUpdate: 00158d0007e20084: true
    zigbee.0	2022-05-17 19:26:18.642	debug	(10400) DeviceAvailability:Publish LQ for 0x00158d0007e20084 = 10
    zigbee.0	2022-05-17 19:26:18.635	debug	(10400) DeviceAvailability:Publish available for 0x00158d0007e20084 = true
    zigbee.0	2022-05-17 19:26:18.634	info	(10400) Currently 19 devices are joined:
    zigbee.0	2022-05-17 19:26:18.618	info	(10400) --> transmitPower : normal
    zigbee.0	2022-05-17 19:26:18.590	info	(10400) Unable to disable LED, unsupported function.
    zigbee.0	2022-05-17 19:26:18.588	debug	(10400) Zigbee network parameters: panID=6754 channel=11 extendedPanID=2779d41c004b1200
    zigbee.0	2022-05-17 19:26:18.578	info	(10400) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20210708}}
    zigbee.0	2022-05-17 19:26:18.576	debug	(10400) zigbee-herdsman started
    zigbee.0	2022-05-17 19:26:17.158	debug	(10400) Backup C:\iobroker\SmartHome\iobroker-data\zigbee_0\backup_2022_05_17-19_26_15.tar.gz success
    zigbee.0	2022-05-17 19:26:17.140	info	(10400) Installed Version: iobroker.zigbee@1.6.18
    zigbee.0	2022-05-17 19:26:16.102	debug	(10400) Starting zigbee-herdsman...
    zigbee.0	2022-05-17 19:26:16.099	info	(10400) Starting Zigbee npm ...
    zigbee.0	2022-05-17 19:26:15.871	debug	(10400) Using zigbee-herdsman with settings: {"network":{"panID":6754,"extendedPanID":[221,221,221,221,221,221,221,221],"channelList":[11],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13]},"databa
    zigbee.0	2022-05-17 19:26:15.831	info	(10400) starting. Version 1.6.18 in C:/iobroker/SmartHome/node_modules/iobroker.zigbee, node: v14.18.2, js-controller: 4.0.23
    zigbee.0	2022-05-17 19:26:14.684	debug	(10400) Plugin sentry Initialize Plugin (enabled=true)
    zigbee.0	2022-05-17 19:26:02.872	info	(12824) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    zigbee.0	2022-05-17 19:26:02.868	info	(12824) terminating
    zigbee.0	2022-05-17 19:26:02.494	info	(12824) Zigbee: disabling joining new devices.
    zigbee.0	2022-05-17 19:26:02.365	info	(12824) cleaned everything up...
    zigbee.0	2022-05-17 19:26:02.362	info	(12824) Got terminate signal TERMINATE_YOURSELF
    zigbee.0	2022-05-17 19:13:12.544	warn	(12824) Device '0x0c4314fffe84e6d8' announced itself
    zigbee.0	2022-05-17 18:11:27.711	warn	(12824) Device '0x0c4314fffe84e6d8' announced itself
    • M michihorn
      AsgothianA Offline
      AsgothianA Offline
      Asgothian
      @michihorn Leider ist das was ich suche da nicht enthalten.
      Kannst du bitte den Zigbee-Tab öffnen damit die Funktion aufgerufen wird und dann noch einmal posten ?
      A.
        A.
        M Online
        M Online
        michihorn
        @asgothian Guten Morgen,
        zigbee.0	2022-05-18 09:49:27.243	debug	(984) Publish {"pressure":1021} to "00158d0001e09c1a"
        zigbee.0	2022-05-18 09:49:27.228	debug	(984) Publish {"humidity":51.11} to "00158d0001e09c1a"
        zigbee.0	2022-05-18 09:49:27.212	debug	(984) Publish {"temperature":33.88} to "00158d0001e09c1a"
        zigbee.0	2022-05-18 09:49:27.182	debug	(984) Type attributeReport device {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":17,"_type":"EndDevice","_ieeeAddr":"0x00158d0001e09c1a","_networkAddress":40367,"_ma
        zigbee.0	2022-05-18 09:49:27.180	debug	(984) Received Zigbee message from '0x00158d0001e09c1a', type 'attributeReport', cluster 'msPressureMeasurement', data '{"measuredValue":1021,"scale":-1,"scaledValue":10210}' from endpoint 1 with grou
        zigbee.0	2022-05-18 09:49:27.179	debug	(984) Type attributeReport device {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":17,"_type":"EndDevice","_ieeeAddr":"0x00158d0001e09c1a","_networkAddress":40367,"_ma
        zigbee.0	2022-05-18 09:49:27.177	debug	(984) Received Zigbee message from '0x00158d0001e09c1a', type 'attributeReport', cluster 'msRelativeHumidity', data '{"measuredValue":5111}' from endpoint 1 with groupID 0
        zigbee.0	2022-05-18 09:49:27.175	debug	(984) handleMessage. {"type":"attributeReport","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":17,"_type":"EndDevice","_ieeeAddr":"0x00158d0001e09c1a","_networkAddress":40367,"_manufa
        zigbee.0	2022-05-18 09:49:27.168	debug	(984) handleMessage. {"type":"attributeReport","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":17,"_type":"EndDevice","_ieeeAddr":"0x00158d0001e09c1a","_networkAddress":40367,"_manufa
        zigbee.0	2022-05-18 09:49:27.161	debug	(984) Type attributeReport device {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":17,"_type":"EndDevice","_ieeeAddr":"0x00158d0001e09c1a","_networkAddress":40367,"_ma
        zigbee.0	2022-05-18 09:49:27.158	debug	(984) Received Zigbee message from '0x00158d0001e09c1a', type 'attributeReport', cluster 'msTemperatureMeasurement', data '{"measuredValue":3388}' from endpoint 1 with groupID 0
        zigbee.0	2022-05-18 09:49:27.156	debug	(984) handleMessage. {"type":"attributeReport","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":17,"_type":"EndDevice","_ieeeAddr":"0x00158d0001e09c1a","_networkAddress":40367,"_manufa
        zigbee.0	2022-05-18 09:49:12.978	debug	(984) Publish {"pressure":1019.3} to "00158d0007e20084"
        zigbee.0	2022-05-18 09:49:12.969	debug	(984) Publish {"humidity":50.37} to "00158d0007e20084"
        zigbee.0	2022-05-18 09:49:12.960	debug	(984) Publish {"temperature":24.67} to "00158d0007e20084"
        zigbee.0	2022-05-18 09:49:12.924	debug	(984) Type attributeReport device {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":2,"_type":"EndDevice","_ieeeAddr":"0x00158d0007e20084","_networkAddress":16818,"_man
        zigbee.0	2022-05-18 09:49:12.916	debug	(984) Received Zigbee message from '0x00158d0007e20084', type 'attributeReport', cluster 'msPressureMeasurement', data '{"measuredValue":1019,"scale":-1,"scaledValue":10193}' from endpoint 1 with grou
        zigbee.0	2022-05-18 09:49:12.914	debug	(984) Type attributeReport device {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":2,"_type":"EndDevice","_ieeeAddr":"0x00158d0007e20084","_networkAddress":16818,"_man
        zigbee.0	2022-05-18 09:49:12.912	debug	(984) Received Zigbee message from '0x00158d0007e20084', type 'attributeReport', cluster 'msRelativeHumidity', data '{"measuredValue":5037}' from endpoint 1 with groupID 0
        zigbee.0	2022-05-18 09:49:12.911	debug	(984) handleMessage. {"type":"attributeReport","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":2,"_type":"EndDevice","_ieeeAddr":"0x00158d0007e20084","_networkAddress":16818,"_manufac
        zigbee.0	2022-05-18 09:49:12.907	debug	(984) handleMessage. {"type":"attributeReport","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":2,"_type":"EndDevice","_ieeeAddr":"0x00158d0007e20084","_networkAddress":16818,"_manufac
        zigbee.0	2022-05-18 09:49:12.899	debug	(984) Type attributeReport device {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":2,"_type":"EndDevice","_ieeeAddr":"0x00158d0007e20084","_networkAddress":16818,"_man
        zigbee.0	2022-05-18 09:49:12.896	debug	(984) Received Zigbee message from '0x00158d0007e20084', type 'attributeReport', cluster 'msTemperatureMeasurement', data '{"measuredValue":2467}' from endpoint 1 with groupID 0
        zigbee.0	2022-05-18 09:49:12.894	debug	(984) handleMessage. {"type":"attributeReport","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":2,"_type":"EndDevice","_ieeeAddr":"0x00158d0007e20084","_networkAddress":16818,"_manufac
        zigbee.0	2022-05-18 09:48:48.265	debug	(984) onDeviceStatusUpdate: 00158d000549dc7f: true
        zigbee.0	2022-05-18 09:48:48.262	debug	(984) DeviceAvailability:Publish LQ for 0x00158d000549dc7f = 10
        zigbee.0	2022-05-18 09:48:48.260	debug	(984) DeviceAvailability:Publish available for 0x00158d000549dc7f = true
        zigbee.0	2022-05-18 09:48:48.259	debug	(984) onDeviceStatusUpdate: 0c4314fffe84e6d8: true
        zigbee.0	2022-05-18 09:48:48.257	debug	(984) DeviceAvailability:Publish LQ for 0x0c4314fffe84e6d8 = 10
        zigbee.0	2022-05-18 09:48:48.254	debug	(984) DeviceAvailability:Publish available for 0x0c4314fffe84e6d8 = true
        zigbee.0	2022-05-18 09:48:48.253	debug	(984) onDeviceStatusUpdate: 00158d000253e897: true
        zigbee.0	2022-05-18 09:48:48.250	debug	(984) DeviceAvailability:Publish LQ for 0x00158d000253e897 = 10
        zigbee.0	2022-05-18 09:48:48.247	debug	(984) DeviceAvailability:Publish available for 0x00158d000253e897 = true
        zigbee.0	2022-05-18 09:48:48.246	debug	(984) onDeviceStatusUpdate: 00158d0001e09c1a: true
        zigbee.0	2022-05-18 09:48:48.243	debug	(984) DeviceAvailability:Publish LQ for 0x00158d0001e09c1a = 10
        zigbee.0	2022-05-18 09:48:48.241	debug	(984) DeviceAvailability:Publish available for 0x00158d0001e09c1a = true
        zigbee.0	2022-05-18 09:48:48.240	debug	(984) onDeviceStatusUpdate: 00158d000444cb23: true
        zigbee.0	2022-05-18 09:48:48.237	debug	(984) DeviceAvailability:Publish LQ for 0x00158d000444cb23 = 10
        zigbee.0	2022-05-18 09:48:48.234	debug	(984) DeviceAvailability:Publish available for 0x00158d000444cb23 = true
        zigbee.0	2022-05-18 09:48:48.233	debug	(984) onDeviceStatusUpdate: 00158d00028d6fc4: true
        zigbee.0	2022-05-18 09:48:48.231	debug	(984) DeviceAvailability:Publish LQ for 0x00158d00028d6fc4 = 10
        zigbee.0	2022-05-18 09:48:48.228	debug	(984) DeviceAvailability:Publish available for 0x00158d00028d6fc4 = true
        zigbee.0	2022-05-18 09:48:48.227	debug	(984) onDeviceStatusUpdate: 00158d0001e0821b: true
        zigbee.0	2022-05-18 09:48:48.224	debug	(984) DeviceAvailability:Publish LQ for 0x00158d0001e0821b = 10
        zigbee.0	2022-05-18 09:48:48.222	debug	(984) DeviceAvailability:Publish available for 0x00158d0001e0821b = true
        zigbee.0	2022-05-18 09:48:48.157	debug	(984) onDeviceStatusUpdate: 00158d0001e13db7: true
        zigbee.0	2022-05-18 09:48:48.155	debug	(984) DeviceAvailability:Publish LQ for 0x00158d0001e13db7 = 10
        zigbee.0	2022-05-18 09:48:48.152	debug	(984) DeviceAvailability:Publish available for 0x00158d0001e13db7 = true
        zigbee.0	2022-05-18 09:48:48.151	debug	(984) onDeviceStatusUpdate: 00158d0007b6e4bd: true
        zigbee.0	2022-05-18 09:48:48.148	debug	(984) DeviceAvailability:Publish LQ for 0x00158d0007b6e4bd = 10
        zigbee.0	2022-05-18 09:48:48.146	debug	(984) DeviceAvailability:Publish available for 0x00158d0007b6e4bd = true
        zigbee.0	2022-05-18 09:48:48.145	debug	(984) onDeviceStatusUpdate: 00158d0007f851b6: true
        zigbee.0	2022-05-18 09:48:48.142	debug	(984) DeviceAvailability:Publish LQ for 0x00158d0007f851b6 = 10
        zigbee.0	2022-05-18 09:48:48.140	debug	(984) DeviceAvailability:Publish available for 0x00158d0007f851b6 = true
        zigbee.0	2022-05-18 09:48:48.138	debug	(984) onDeviceStatusUpdate: 00158d0007e0590a: true
        zigbee.0	2022-05-18 09:48:48.136	debug	(984) DeviceAvailability:Publish LQ for 0x00158d0007e0590a = 10
        zigbee.0	2022-05-18 09:48:48.133	debug	(984) DeviceAvailability:Publish available for 0x00158d0007e0590a = true
        zigbee.0	2022-05-18 09:48:48.131	debug	(984) onDeviceStatusUpdate: 00158d0007e033e1: true
        zigbee.0	2022-05-18 09:48:48.128	debug	(984) DeviceAvailability:Publish LQ for 0x00158d0007e033e1 = 10
        zigbee.0	2022-05-18 09:48:48.125	debug	(984) DeviceAvailability:Publish available for 0x00158d0007e033e1 = true
        zigbee.0	2022-05-18 09:48:48.123	debug	(984) onDeviceStatusUpdate: 00158d0007b7cdce: true
        zigbee.0	2022-05-18 09:48:48.120	debug	(984) DeviceAvailability:Publish LQ for 0x00158d0007b7cdce = 10
        zigbee.0	2022-05-18 09:48:48.117	debug	(984) DeviceAvailability:Publish available for 0x00158d0007b7cdce = true
        zigbee.0	2022-05-18 09:48:48.116	debug	(984) onDeviceStatusUpdate: 00158d000476bd65: true
        zigbee.0	2022-05-18 09:48:48.113	debug	(984) DeviceAvailability:Publish LQ for 0x00158d000476bd65 = 10
        zigbee.0	2022-05-18 09:48:48.105	debug	(984) DeviceAvailability:Publish available for 0x00158d000476bd65 = true
        zigbee.0	2022-05-18 09:48:48.104	debug	(984) onDeviceStatusUpdate: 00158d00069ac702: true
        zigbee.0	2022-05-18 09:48:48.100	debug	(984) DeviceAvailability:Publish LQ for 0x00158d00069ac702 = 10
        zigbee.0	2022-05-18 09:48:48.097	debug	(984) DeviceAvailability:Publish available for 0x00158d00069ac702 = true
        zigbee.0	2022-05-18 09:48:48.096	debug	(984) onDeviceStatusUpdate: 00158d0006becb12: true
        zigbee.0	2022-05-18 09:48:48.093	debug	(984) DeviceAvailability:Publish LQ for 0x00158d0006becb12 = 10
        zigbee.0	2022-05-18 09:48:48.088	debug	(984) DeviceAvailability:Publish available for 0x00158d0006becb12 = true
        zigbee.0	2022-05-18 09:48:48.087	debug	(984) onDeviceStatusUpdate: 00158d000423bfd0: true
        zigbee.0	2022-05-18 09:48:48.084	debug	(984) DeviceAvailability:Publish LQ for 0x00158d000423bfd0 = 10
        zigbee.0	2022-05-18 09:48:48.076	debug	(984) DeviceAvailability:Publish available for 0x00158d000423bfd0 = true
        zigbee.0	2022-05-18 09:48:48.074	debug	(984) onDeviceStatusUpdate: 00158d0007e3ac5e: true
        zigbee.0	2022-05-18 09:48:48.071	debug	(984) DeviceAvailability:Publish LQ for 0x00158d0007e3ac5e = 10
        zigbee.0	2022-05-18 09:48:48.066	debug	(984) DeviceAvailability:Publish available for 0x00158d0007e3ac5e = true
        zigbee.0	2022-05-18 09:48:48.031	debug	(984) onDeviceStatusUpdate: 00158d0007e20084: true
        zigbee.0	2022-05-18 09:48:48.028	debug	(984) DeviceAvailability:Publish LQ for 0x00158d0007e20084 = 10
        zigbee.0	2022-05-18 09:48:48.023	debug	(984) DeviceAvailability:Publish available for 0x00158d0007e20084 = true
        zigbee.0	2022-05-18 09:48:47.481	debug	(984) DeviceAvailability:register device Ping for "0x00158d000549dc7f"
        zigbee.0	2022-05-18 09:48:47.480	debug	(984) DeviceAvailability:register device Ping for "0x0c4314fffe84e6d8"
        zigbee.0	2022-05-18 09:48:47.479	debug	(984) DeviceAvailability:register device Ping for "0x00158d000253e897"
        zigbee.0	2022-05-18 09:48:47.478	debug	(984) DeviceAvailability:register device Ping for "0x00158d0001e09c1a"
        zigbee.0	2022-05-18 09:48:47.477	debug	(984) DeviceAvailability:register device Ping for "0x00158d000444cb23"
        zigbee.0	2022-05-18 09:48:47.476	debug	(984) DeviceAvailability:register device Ping for "0x00158d00028d6fc4"
        zigbee.0	2022-05-18 09:48:47.475	debug	(984) DeviceAvailability:register device Ping for "0x00158d0001e0821b"
        zigbee.0	2022-05-18 09:48:47.474	debug	(984) DeviceAvailability:register device Ping for "0x00158d0001e13db7"
        zigbee.0	2022-05-18 09:48:47.473	debug	(984) DeviceAvailability:register device Ping for "0x00158d0007b6e4bd"
        zigbee.0	2022-05-18 09:48:47.302	debug	(984) DeviceAvailability:register device Ping for "0x00158d0007f851b6"
        zigbee.0	2022-05-18 09:48:47.301	debug	(984) DeviceAvailability:register device Ping for "0x00158d0007e0590a"
        zigbee.0	2022-05-18 09:48:47.300	debug	(984) DeviceAvailability:register device Ping for "0x00158d0007e033e1"
        zigbee.0	2022-05-18 09:48:47.299	debug	(984) DeviceAvailability:register device Ping for "0x00158d0007b7cdce"
        zigbee.0	2022-05-18 09:48:47.298	debug	(984) DeviceAvailability:register device Ping for "0x00158d000476bd65"
        zigbee.0	2022-05-18 09:48:47.297	debug	(984) DeviceAvailability:register device Ping for "0x00158d00069ac702"
        zigbee.0	2022-05-18 09:48:47.296	debug	(984) DeviceAvailability:register device Ping for "0x00158d0006becb12"
        zigbee.0	2022-05-18 09:48:47.295	debug	(984) DeviceAvailability:register device Ping for "0x00158d000423bfd0"
        zigbee.0	2022-05-18 09:48:47.293	debug	(984) DeviceAvailability:register device Ping for "0x00158d0007e3ac5e"
        zigbee.0	2022-05-18 09:48:47.282	debug	(984) DeviceAvailability:register device Ping for "0x00158d0007e20084"
        zigbee.0	2022-05-18 09:48:47.250	debug	(984) getGroups result: {}
        zigbee.0	2022-05-18 09:48:47.092	info	(984) Zigbee started
        zigbee.0	2022-05-18 09:48:47.090	info	(984) 0x00158d000549dc7f (addr 44107): WSDCGQ01LM - Xiaomi MiJia temperature & humidity sensor (EndDevice)
        zigbee.0	2022-05-18 09:48:47.089	debug	(984) New device event: {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":20,"_type":"EndDevice","_ieeeAddr":"0x00158d000549dc7f","_networkAddress":44107,"_manufacturer
        zigbee.0	2022-05-18 09:48:47.088	info	(984) 0x0c4314fffe84e6d8 (addr 47520): TS0042 - TuYa Wireless switch with 2 buttons (EndDevice)
        zigbee.0	2022-05-18 09:48:47.087	debug	(984) New device event: {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":19,"_type":"EndDevice","_ieeeAddr":"0x0c4314fffe84e6d8","_networkAddress":47520,"_manufacturer
        zigbee.0	2022-05-18 09:48:47.085	info	(984) 0x00158d000253e897 (addr 9982): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
        zigbee.0	2022-05-18 09:48:47.084	debug	(984) New device event: {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":18,"_type":"EndDevice","_ieeeAddr":"0x00158d000253e897","_networkAddress":9982,"_manufacturerI
        zigbee.0	2022-05-18 09:48:47.083	info	(984) 0x00158d0001e09c1a (addr 40367): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
        zigbee.0	2022-05-18 09:48:47.082	debug	(984) New device event: {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":17,"_type":"EndDevice","_ieeeAddr":"0x00158d0001e09c1a","_networkAddress":40367,"_manufacturer
        zigbee.0	2022-05-18 09:48:47.080	info	(984) 0x00158d000444cb23 (addr 31810): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
        zigbee.0	2022-05-18 09:48:47.077	debug	(984) New device event: {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":16,"_type":"EndDevice","_ieeeAddr":"0x00158d000444cb23","_networkAddress":31810,"_manufacturer
        zigbee.0	2022-05-18 09:48:47.075	info	(984) 0x00158d00028d6fc4 (addr 28105): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
        zigbee.0	2022-05-18 09:48:47.072	debug	(984) New device event: {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":15,"_type":"EndDevice","_ieeeAddr":"0x00158d00028d6fc4","_networkAddress":28105,"_manufacturer
        zigbee.0	2022-05-18 09:48:47.070	info	(984) 0x00158d0001e0821b (addr 60095): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
        zigbee.0	2022-05-18 09:48:47.069	debug	(984) New device event: {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":14,"_type":"EndDevice","_ieeeAddr":"0x00158d0001e0821b","_networkAddress":60095,"_manufacturer
        zigbee.0	2022-05-18 09:48:47.067	info	(984) 0x00158d0001e13db7 (addr 17859): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
        zigbee.0	2022-05-18 09:48:47.066	debug	(984) New device event: {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":13,"_type":"EndDevice","_ieeeAddr":"0x00158d0001e13db7","_networkAddress":17859,"_manufacturer
        zigbee.0	2022-05-18 09:48:47.065	info	(984) 0x00158d0007b6e4bd (addr 10048): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
        zigbee.0	2022-05-18 09:48:47.064	debug	(984) New device event: {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":12,"_type":"EndDevice","_ieeeAddr":"0x00158d0007b6e4bd","_networkAddress":10048,"_manufacturer
        zigbee.0	2022-05-18 09:48:47.062	info	(984) 0x00158d0007f851b6 (addr 54317): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
        zigbee.0	2022-05-18 09:48:47.061	debug	(984) New device event: {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":11,"_type":"EndDevice","_ieeeAddr":"0x00158d0007f851b6","_networkAddress":54317,"_manufacturer
        zigbee.0	2022-05-18 09:48:47.060	info	(984) 0x00158d0007e0590a (addr 32469): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
        zigbee.0	2022-05-18 09:48:47.059	debug	(984) New device event: {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":10,"_type":"EndDevice","_ieeeAddr":"0x00158d0007e0590a","_networkAddress":32469,"_manufacturer
        zigbee.0	2022-05-18 09:48:47.057	info	(984) 0x00158d0007e033e1 (addr 22928): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
        zigbee.0	2022-05-18 09:48:47.056	debug	(984) New device event: {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":9,"_type":"EndDevice","_ieeeAddr":"0x00158d0007e033e1","_networkAddress":22928,"_manufacturerI
        zigbee.0	2022-05-18 09:48:47.055	info	(984) 0x00158d0007b7cdce (addr 62083): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
        zigbee.0	2022-05-18 09:48:47.054	debug	(984) New device event: {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":8,"_type":"EndDevice","_ieeeAddr":"0x00158d0007b7cdce","_networkAddress":62083,"_manufacturerI
        zigbee.0	2022-05-18 09:48:47.053	info	(984) 0x00158d000476bd65 (addr 60884): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
        zigbee.0	2022-05-18 09:48:47.052	debug	(984) New device event: {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":7,"_type":"EndDevice","_ieeeAddr":"0x00158d000476bd65","_networkAddress":60884,"_manufacturerI
        zigbee.0	2022-05-18 09:48:47.050	info	(984) 0x00158d00069ac702 (addr 4598): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
        zigbee.0	2022-05-18 09:48:47.049	debug	(984) New device event: {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":6,"_type":"EndDevice","_ieeeAddr":"0x00158d00069ac702","_networkAddress":4598,"_manufacturerID
        zigbee.0	2022-05-18 09:48:47.048	info	(984) 0x00158d0006becb12 (addr 5228): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
        zigbee.0	2022-05-18 09:48:47.047	debug	(984) New device event: {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":5,"_type":"EndDevice","_ieeeAddr":"0x00158d0006becb12","_networkAddress":5228,"_manufacturerID
        zigbee.0	2022-05-18 09:48:47.046	info	(984) 0x00158d000423bfd0 (addr 47946): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
        zigbee.0	2022-05-18 09:48:47.044	debug	(984) New device event: {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":4,"_type":"EndDevice","_ieeeAddr":"0x00158d000423bfd0","_networkAddress":47946,"_manufacturerI
        zigbee.0	2022-05-18 09:48:47.042	info	(984) 0x00158d0007e3ac5e (addr 48933): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
        zigbee.0	2022-05-18 09:48:47.040	debug	(984) New device event: {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":3,"_type":"EndDevice","_ieeeAddr":"0x00158d0007e3ac5e","_networkAddress":48933,"_manufacturerI
        zigbee.0	2022-05-18 09:48:47.026	info	(984) 0x00158d0007e20084 (addr 16818): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
        zigbee.0	2022-05-18 09:48:47.024	debug	(984) New device event: {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":2,"_type":"EndDevice","_ieeeAddr":"0x00158d0007e20084","_networkAddress":16818,"_manufacturerI
        zigbee.0	2022-05-18 09:48:47.021	debug	(984) DeviceConfigure:DeviceConfigure 0x00158d000549dc7f lumi.sensor_ht not needed
        zigbee.0	2022-05-18 09:48:47.021	debug	(984) DeviceConfigure:DeviceConfigure 0x0c4314fffe84e6d8 TS0042 not needed
        zigbee.0	2022-05-18 09:48:47.020	debug	(984) DeviceConfigure:DeviceConfigure 0x00158d000253e897 lumi.sensor_motion.aq2 not needed
        zigbee.0	2022-05-18 09:48:47.019	debug	(984) DeviceConfigure:DeviceConfigure 0x00158d0001e09c1a lumi.weather not needed
        zigbee.0	2022-05-18 09:48:47.019	debug	(984) DeviceConfigure:DeviceConfigure 0x00158d000444cb23 lumi.weather not needed
        zigbee.0	2022-05-18 09:48:47.019	debug	(984) DeviceConfigure:DeviceConfigure 0x00158d00028d6fc4 lumi.sensor_magnet.aq2 not needed
        zigbee.0	2022-05-18 09:48:47.018	debug	(984) DeviceConfigure:DeviceConfigure 0x00158d0001e0821b lumi.weather not needed
        zigbee.0	2022-05-18 09:48:47.018	debug	(984) DeviceConfigure:DeviceConfigure 0x00158d0001e13db7 lumi.weather not needed
        zigbee.0	2022-05-18 09:48:47.017	debug	(984) DeviceConfigure:DeviceConfigure 0x00158d0007b6e4bd lumi.sensor_magnet.aq2 not needed
        zigbee.0	2022-05-18 09:48:47.017	debug	(984) DeviceConfigure:DeviceConfigure 0x00158d0007f851b6 lumi.sensor_magnet.aq2 not needed
        zigbee.0	2022-05-18 09:48:47.017	debug	(984) DeviceConfigure:DeviceConfigure 0x00158d0007e0590a lumi.sensor_magnet.aq2 not needed
        zigbee.0	2022-05-18 09:48:47.016	debug	(984) DeviceConfigure:DeviceConfigure 0x00158d0007e033e1 lumi.sensor_magnet.aq2 not needed
        zigbee.0	2022-05-18 09:48:47.016	debug	(984) DeviceConfigure:DeviceConfigure 0x00158d0007b7cdce lumi.sensor_magnet.aq2 not needed
        zigbee.0	2022-05-18 09:48:47.015	debug	(984) DeviceConfigure:DeviceConfigure 0x00158d000476bd65 lumi.sensor_magnet.aq2 not needed
        zigbee.0	2022-05-18 09:48:47.014	debug	(984) DeviceConfigure:DeviceConfigure 0x00158d00069ac702 lumi.sensor_magnet.aq2 not needed
        zigbee.0	2022-05-18 09:48:47.014	debug	(984) DeviceConfigure:DeviceConfigure 0x00158d0006becb12 lumi.sensor_magnet.aq2 not needed
        zigbee.0	2022-05-18 09:48:47.013	debug	(984) DeviceConfigure:DeviceConfigure 0x00158d000423bfd0 lumi.sensor_motion.aq2 not needed
        zigbee.0	2022-05-18 09:48:47.013	debug	(984) DeviceConfigure:DeviceConfigure 0x00158d0007e3ac5e lumi.weather not needed
        zigbee.0	2022-05-18 09:48:47.012	debug	(984) DeviceConfigure:DeviceConfigure 0x00158d0007e20084 lumi.weather not needed
        zigbee.0	2022-05-18 09:48:47.010	debug	(984) onDeviceStatusUpdate: 00158d000549dc7f: true
        zigbee.0	2022-05-18 09:48:47.008	debug	(984) DeviceAvailability:Publish LQ for 0x00158d000549dc7f = 10
        zigbee.0	2022-05-18 09:48:47.006	debug	(984) DeviceAvailability:Publish available for 0x00158d000549dc7f = true
        zigbee.0	2022-05-18 09:48:47.005	debug	(984) onDeviceStatusUpdate: 0c4314fffe84e6d8: true
        zigbee.0	2022-05-18 09:48:47.003	debug	(984) DeviceAvailability:Publish LQ for 0x0c4314fffe84e6d8 = 10
        zigbee.0	2022-05-18 09:48:47.001	debug	(984) DeviceAvailability:Publish available for 0x0c4314fffe84e6d8 = true
        zigbee.0	2022-05-18 09:48:47.000	debug	(984) onDeviceStatusUpdate: 00158d000253e897: true
        zigbee.0	2022-05-18 09:48:46.998	debug	(984) DeviceAvailability:Publish LQ for 0x00158d000253e897 = 10
        zigbee.0	2022-05-18 09:48:46.996	debug	(984) DeviceAvailability:Publish available for 0x00158d000253e897 = true
        zigbee.0	2022-05-18 09:48:46.995	debug	(984) onDeviceStatusUpdate: 00158d0001e09c1a: true
        zigbee.0	2022-05-18 09:48:46.993	debug	(984) DeviceAvailability:Publish LQ for 0x00158d0001e09c1a = 10
        zigbee.0	2022-05-18 09:48:46.991	debug	(984) DeviceAvailability:Publish available for 0x00158d0001e09c1a = true
        zigbee.0	2022-05-18 09:48:46.990	debug	(984) onDeviceStatusUpdate: 00158d000444cb23: true
        zigbee.0	2022-05-18 09:48:46.988	debug	(984) DeviceAvailability:Publish LQ for 0x00158d000444cb23 = 10
        zigbee.0	2022-05-18 09:48:46.986	debug	(984) DeviceAvailability:Publish available for 0x00158d000444cb23 = true
        zigbee.0	2022-05-18 09:48:46.985	debug	(984) onDeviceStatusUpdate: 00158d00028d6fc4: true
        zigbee.0	2022-05-18 09:48:46.983	debug	(984) DeviceAvailability:Publish LQ for 0x00158d00028d6fc4 = 10
        zigbee.0	2022-05-18 09:48:46.981	debug	(984) DeviceAvailability:Publish available for 0x00158d00028d6fc4 = true
        zigbee.0	2022-05-18 09:48:46.980	debug	(984) onDeviceStatusUpdate: 00158d0001e0821b: true
        zigbee.0	2022-05-18 09:48:46.978	debug	(984) DeviceAvailability:Publish LQ for 0x00158d0001e0821b = 10
        zigbee.0	2022-05-18 09:48:46.976	debug	(984) DeviceAvailability:Publish available for 0x00158d0001e0821b = true
        zigbee.0	2022-05-18 09:48:46.975	debug	(984) onDeviceStatusUpdate: 00158d0001e13db7: true
        zigbee.0	2022-05-18 09:48:46.973	debug	(984) DeviceAvailability:Publish LQ for 0x00158d0001e13db7 = 10
        zigbee.0	2022-05-18 09:48:46.971	debug	(984) DeviceAvailability:Publish available for 0x00158d0001e13db7 = true
        zigbee.0	2022-05-18 09:48:46.970	debug	(984) onDeviceStatusUpdate: 00158d0007b6e4bd: true
        zigbee.0	2022-05-18 09:48:46.968	debug	(984) DeviceAvailability:Publish LQ for 0x00158d0007b6e4bd = 10
        zigbee.0	2022-05-18 09:48:46.966	debug	(984) DeviceAvailability:Publish available for 0x00158d0007b6e4bd = true
        zigbee.0	2022-05-18 09:48:46.965	debug	(984) onDeviceStatusUpdate: 00158d0007f851b6: true
        zigbee.0	2022-05-18 09:48:46.963	debug	(984) DeviceAvailability:Publish LQ for 0x00158d0007f851b6 = 10
        zigbee.0	2022-05-18 09:48:46.961	debug	(984) DeviceAvailability:Publish available for 0x00158d0007f851b6 = true
        zigbee.0	2022-05-18 09:48:46.960	debug	(984) onDeviceStatusUpdate: 00158d0007e0590a: true
        zigbee.0	2022-05-18 09:48:46.958	debug	(984) DeviceAvailability:Publish LQ for 0x00158d0007e0590a = 10
        zigbee.0	2022-05-18 09:48:46.956	debug	(984) DeviceAvailability:Publish available for 0x00158d0007e0590a = true
        zigbee.0	2022-05-18 09:48:46.955	debug	(984) onDeviceStatusUpdate: 00158d0007e033e1: true
        zigbee.0	2022-05-18 09:48:46.953	debug	(984) DeviceAvailability:Publish LQ for 0x00158d0007e033e1 = 10
        zigbee.0	2022-05-18 09:48:46.951	debug	(984) DeviceAvailability:Publish available for 0x00158d0007e033e1 = true
        zigbee.0	2022-05-18 09:48:46.950	debug	(984) onDeviceStatusUpdate: 00158d0007b7cdce: true
        zigbee.0	2022-05-18 09:48:46.948	debug	(984) DeviceAvailability:Publish LQ for 0x00158d0007b7cdce = 10
        zigbee.0	2022-05-18 09:48:46.946	debug	(984) DeviceAvailability:Publish available for 0x00158d0007b7cdce = true
        zigbee.0	2022-05-18 09:48:46.945	debug	(984) onDeviceStatusUpdate: 00158d000476bd65: true
        zigbee.0	2022-05-18 09:48:46.943	debug	(984) DeviceAvailability:Publish LQ for 0x00158d000476bd65 = 10
        zigbee.0	2022-05-18 09:48:46.941	debug	(984) DeviceAvailability:Publish available for 0x00158d000476bd65 = true
        zigbee.0	2022-05-18 09:48:46.940	debug	(984) onDeviceStatusUpdate: 00158d00069ac702: true
        zigbee.0	2022-05-18 09:48:46.938	debug	(984) DeviceAvailability:Publish LQ for 0x00158d00069ac702 = 10
        zigbee.0	2022-05-18 09:48:46.935	debug	(984) DeviceAvailability:Publish available for 0x00158d00069ac702 = true
        zigbee.0	2022-05-18 09:48:46.934	debug	(984) onDeviceStatusUpdate: 00158d0006becb12: true
        zigbee.0	2022-05-18 09:48:46.932	debug	(984) DeviceAvailability:Publish LQ for 0x00158d0006becb12 = 10
        zigbee.0	2022-05-18 09:48:46.930	debug	(984) DeviceAvailability:Publish available for 0x00158d0006becb12 = true
        zigbee.0	2022-05-18 09:48:46.929	debug	(984) onDeviceStatusUpdate: 00158d000423bfd0: true
        zigbee.0	2022-05-18 09:48:46.927	debug	(984) DeviceAvailability:Publish LQ for 0x00158d000423bfd0 = 10
        zigbee.0	2022-05-18 09:48:46.925	debug	(984) DeviceAvailability:Publish available for 0x00158d000423bfd0 = true
        zigbee.0	2022-05-18 09:48:46.924	debug	(984) onDeviceStatusUpdate: 00158d0007e3ac5e: true
        zigbee.0	2022-05-18 09:48:46.922	debug	(984) DeviceAvailability:Publish LQ for 0x00158d0007e3ac5e = 10
        zigbee.0	2022-05-18 09:48:46.916	debug	(984) DeviceAvailability:Publish available for 0x00158d0007e3ac5e = true
        zigbee.0	2022-05-18 09:48:46.914	debug	(984) onDeviceStatusUpdate: 00158d0007e20084: true
        zigbee.0	2022-05-18 09:48:46.906	debug	(984) DeviceAvailability:Publish LQ for 0x00158d0007e20084 = 10
        zigbee.0	2022-05-18 09:48:46.899	debug	(984) DeviceAvailability:Publish available for 0x00158d0007e20084 = true
        zigbee.0	2022-05-18 09:48:46.898	info	(984) Currently 19 devices are joined:
        zigbee.0	2022-05-18 09:48:46.884	info	(984) --> transmitPower : normal
        zigbee.0	2022-05-18 09:48:46.862	info	(984) Unable to disable LED, unsupported function.
        zigbee.0	2022-05-18 09:48:46.861	debug	(984) Zigbee network parameters: panID=6754 channel=11 extendedPanID=2779d41c004b1200
        zigbee.0	2022-05-18 09:48:46.851	info	(984) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20210708}}
        zigbee.0	2022-05-18 09:48:46.850	debug	(984) zigbee-herdsman started
        zigbee.0	2022-05-18 09:48:46.437	debug	(984) Backup C:\iobroker\SmartHome\iobroker-data\zigbee_0\backup_2022_05_18-09_48_45.tar.gz success
        zigbee.0	2022-05-18 09:48:46.381	info	(984) Installed Version: iobroker.zigbee@1.6.18
        zigbee.0	2022-05-18 09:48:45.429	debug	(984) Starting zigbee-herdsman...
        zigbee.0	2022-05-18 09:48:45.427	info	(984) Starting Zigbee npm ...
        zigbee.0	2022-05-18 09:48:45.198	debug	(984) Using zigbee-herdsman with settings: {"network":{"panID":6754,"extendedPanID":[221,221,221,221,221,221,221,221],"channelList":[11],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13]},"database
        zigbee.0	2022-05-18 09:48:45.155	info	(984) starting. Version 1.6.18 in C:/iobroker/SmartHome/node_modules/iobroker.zigbee, node: v14.18.2, js-controller: 4.0.23
        zigbee.0	2022-05-18 09:48:44.020	debug	(984) Plugin sentry Initialize Plugin (enabled=true)
        zigbee.0	2022-05-18 09:48:31.767	info	(10400) Got terminate signal TERMINATE_YOURSELF
        zigbee.0	2022-05-18 09:48:31.414	info	(10400) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        zigbee.0	2022-05-18 09:48:31.413	debug	(10400) Plugin sentry destroyed
        zigbee.0	2022-05-18 09:48:31.405	info	(10400) terminating
        zigbee.0	2022-05-18 09:48:31.016	info	(10400) Zigbee: disabling joining new devices.
        zigbee.0	2022-05-18 09:48:31.012	debug	(10400) onDeviceStatusUpdate: 00158d000549dc7f: false
        zigbee.0	2022-05-18 09:48:31.010	debug	(10400) DeviceAvailability:Publish LQ for 0x00158d000549dc7f = 0
        zigbee.0	2022-05-18 09:48:31.007	debug	(10400) DeviceAvailability:Publish available for 0x00158d000549dc7f = false
        zigbee.0	2022-05-18 09:48:31.007	debug	(10400) onDeviceStatusUpdate: 0c4314fffe84e6d8: false
        zigbee.0	2022-05-18 09:48:31.005	debug	(10400) DeviceAvailability:Publish LQ for 0x0c4314fffe84e6d8 = 0
        zigbee.0	2022-05-18 09:48:31.002	debug	(10400) DeviceAvailability:Publish available for 0x0c4314fffe84e6d8 = false
        zigbee.0	2022-05-18 09:48:31.001	debug	(10400) onDeviceStatusUpdate: 00158d000253e897: false
        zigbee.0	2022-05-18 09:48:30.999	debug	(10400) DeviceAvailability:Publish LQ for 0x00158d000253e897 = 0
        zigbee.0	2022-05-18 09:48:30.997	debug	(10400) DeviceAvailability:Publish available for 0x00158d000253e897 = false
        zigbee.0	2022-05-18 09:48:30.996	debug	(10400) onDeviceStatusUpdate: 00158d0001e09c1a: false
        zigbee.0	2022-05-18 09:48:30.994	debug	(10400) DeviceAvailability:Publish LQ for 0x00158d0001e09c1a = 0
        zigbee.0	2022-05-18 09:48:30.991	debug	(10400) DeviceAvailability:Publish available for 0x00158d0001e09c1a = false
        zigbee.0	2022-05-18 09:48:30.990	debug	(10400) onDeviceStatusUpdate: 00158d000444cb23: false
        zigbee.0	2022-05-18 09:48:30.988	debug	(10400) DeviceAvailability:Publish LQ for 0x00158d000444cb23 = 0
        zigbee.0	2022-05-18 09:48:30.985	debug	(10400) DeviceAvailability:Publish available for 0x00158d000444cb23 = false
        zigbee.0	2022-05-18 09:48:30.984	debug	(10400) onDeviceStatusUpdate: 00158d00028d6fc4: false
        zigbee.0	2022-05-18 09:48:30.981	debug	(10400) DeviceAvailability:Publish LQ for 0x00158d00028d6fc4 = 0
        zigbee.0	2022-05-18 09:48:30.977	debug	(10400) DeviceAvailability:Publish available for 0x00158d00028d6fc4 = false
        zigbee.0	2022-05-18 09:48:30.977	debug	(10400) onDeviceStatusUpdate: 00158d0001e0821b: false
        zigbee.0	2022-05-18 09:48:30.974	debug	(10400) DeviceAvailability:Publish LQ for 0x00158d0001e0821b = 0
        zigbee.0	2022-05-18 09:48:30.972	debug	(10400) DeviceAvailability:Publish available for 0x00158d0001e0821b = false
        zigbee.0	2022-05-18 09:48:30.971	debug	(10400) onDeviceStatusUpdate: 00158d0001e13db7: false
        zigbee.0	2022-05-18 09:48:30.968	debug	(10400) DeviceAvailability:Publish LQ for 0x00158d0001e13db7 = 0
        zigbee.0	2022-05-18 09:48:30.964	debug	(10400) DeviceAvailability:Publish available for 0x00158d0001e13db7 = false
        zigbee.0	2022-05-18 09:48:30.963	debug	(10400) onDeviceStatusUpdate: 00158d0007b6e4bd: false
        zigbee.0	2022-05-18 09:48:30.960	debug	(10400) DeviceAvailability:Publish LQ for 0x00158d0007b6e4bd = 0
        zigbee.0	2022-05-18 09:48:30.957	debug	(10400) DeviceAvailability:Publish available for 0x00158d0007b6e4bd = false
        zigbee.0	2022-05-18 09:48:30.957	debug	(10400) onDeviceStatusUpdate: 00158d0007f851b6: false
        zigbee.0	2022-05-18 09:48:30.954	debug	(10400) DeviceAvailability:Publish LQ for 0x00158d0007f851b6 = 0
        zigbee.0	2022-05-18 09:48:30.951	debug	(10400) DeviceAvailability:Publish available for 0x00158d0007f851b6 = false
        zigbee.0	2022-05-18 09:48:30.950	debug	(10400) onDeviceStatusUpdate: 00158d0007e033e1: false
        zigbee.0	2022-05-18 09:48:30.948	debug	(10400) DeviceAvailability:Publish LQ for 0x00158d0007e033e1 = 0
        zigbee.0	2022-05-18 09:48:30.945	debug	(10400) DeviceAvailability:Publish available for 0x00158d0007e033e1 = false
        zigbee.0	2022-05-18 09:48:30.945	debug	(10400) onDeviceStatusUpdate: 00158d0007b7cdce: false
        zigbee.0	2022-05-18 09:48:30.942	debug	(10400) DeviceAvailability:Publish LQ for 0x00158d0007b7cdce = 0
        zigbee.0	2022-05-18 09:48:30.938	debug	(10400) DeviceAvailability:Publish available for 0x00158d0007b7cdce = false
        zigbee.0	2022-05-18 09:48:30.937	debug	(10400) onDeviceStatusUpdate: 00158d000476bd65: false
        zigbee.0	2022-05-18 09:48:30.934	debug	(10400) DeviceAvailability:Publish LQ for 0x00158d000476bd65 = 0
        zigbee.0	2022-05-18 09:48:30.931	debug	(10400) DeviceAvailability:Publish available for 0x00158d000476bd65 = false
        zigbee.0	2022-05-18 09:48:30.930	debug	(10400) onDeviceStatusUpdate: 00158d00069ac702: false
        zigbee.0	2022-05-18 09:48:30.927	debug	(10400) DeviceAvailability:Publish LQ for 0x00158d00069ac702 = 0
        zigbee.0	2022-05-18 09:48:30.923	debug	(10400) DeviceAvailability:Publish available for 0x00158d00069ac702 = false
        zigbee.0	2022-05-18 09:48:30.922	debug	(10400) onDeviceStatusUpdate: 00158d000423bfd0: false
        zigbee.0	2022-05-18 09:48:30.919	debug	(10400) DeviceAvailability:Publish LQ for 0x00158d000423bfd0 = 0
        zigbee.0	2022-05-18 09:48:30.916	debug	(10400) DeviceAvailability:Publish available for 0x00158d000423bfd0 = false
        zigbee.0	2022-05-18 09:48:30.916	debug	(10400) onDeviceStatusUpdate: 00158d0007e3ac5e: false
        zigbee.0	2022-05-18 09:48:30.913	debug	(10400) DeviceAvailability:Publish LQ for 0x00158d0007e3ac5e = 0
        zigbee.0	2022-05-18 09:48:30.908	debug	(10400) DeviceAvailability:Publish available for 0x00158d0007e3ac5e = false
        zigbee.0	2022-05-18 09:48:30.908	debug	(10400) onDeviceStatusUpdate: 00158d0007e20084: false
        zigbee.0	2022-05-18 09:48:30.905	debug	(10400) DeviceAvailability:Publish LQ for 0x00158d0007e20084 = 0
        zigbee.0	2022-05-18 09:48:30.902	debug	(10400) DeviceAvailability:Publish available for 0x00158d0007e20084 = false
        zigbee.0	2022-05-18 09:48:30.899	info	(10400) cleaned everything up...
        zigbee.0	2022-05-18 09:48:30.892	info	(10400) Got terminate signal TERMINATE_YOURSELF
        zigbee.0	2022-05-18 09:48:25.552	debug	(10400) DeviceAvailability:Non-pingable device 0x00158d000549dc7f lumi.sensor_ht was last seen '114.738' seconds ago.
        zigbee.0	2022-05-18 09:48:25.552	debug	(10400) DeviceAvailability:Non-pingable device 0x0c4314fffe84e6d8 TS0042 was last seen '659.753' seconds ago.
        zigbee.0	2022-05-18 09:48:25.551	debug	(10400) DeviceAvailability:Non-pingable device 0x00158d000253e897 lumi.sensor_motion.aq2 was last seen '7425.877' seconds ago.
        zigbee.0	2022-05-18 09:48:25.551	debug	(10400) DeviceAvailability:Non-pingable device 0x00158d0001e09c1a lumi.weather was last seen '139.568' seconds ago.
        zigbee.0	2022-05-18 09:48:25.551	debug	(10400) DeviceAvailability:Non-pingable device 0x00158d000444cb23 lumi.weather was last seen '441.391' seconds ago.
        zigbee.0	2022-05-18 09:48:25.550	debug	(10400) DeviceAvailability:Non-pingable device 0x00158d00028d6fc4 lumi.sensor_magnet.aq2 was last seen '1728.727' seconds ago.
        zigbee.0	2022-05-18 09:48:25.549	debug	(10400) DeviceAvailability:Non-pingable device 0x00158d0001e0821b lumi.weather was last seen '344.68' seconds ago.
        zigbee.0	2022-05-18 09:48:25.523	debug	(10400) DeviceAvailability:Non-pingable device 0x00158d0001e13db7 lumi.weather was last seen '323.592' seconds ago.
        zigbee.0	2022-05-18 09:48:25.523	debug	(10400) DeviceAvailability:Non-pingable device 0x00158d0007b6e4bd lumi.sensor_magnet.aq2 was last seen '2195.698' seconds ago.
        zigbee.0	2022-05-18 09:48:25.519	debug	(10400) DeviceAvailability:Non-pingable device 0x00158d0007f851b6 lumi.sensor_magnet.aq2 was last seen '1621.685' seconds ago.
        zigbee.0	2022-05-18 09:48:25.519	debug	(10400) DeviceAvailability:Non-pingable device 0x00158d0007e0590a lumi.sensor_magnet.aq2 was last seen '6565749.051' seconds ago.
        zigbee.0	2022-05-18 09:48:25.518	debug	(10400) DeviceAvailability:Non-pingable device 0x00158d0007e033e1 lumi.sensor_magnet.aq2 was last seen '2632.524' seconds ago.
        zigbee.0	2022-05-18 09:48:25.518	debug	(10400) DeviceAvailability:Non-pingable device 0x00158d0007b7cdce lumi.sensor_magnet.aq2 was last seen '2248.97' seconds ago.
        zigbee.0	2022-05-18 09:48:25.517	debug	(10400) DeviceAvailability:Non-pingable device 0x00158d000476bd65 lumi.sensor_magnet.aq2 was last seen '930.727' seconds ago.
        zigbee.0	2022-05-18 09:48:25.517	debug	(10400) DeviceAvailability:Non-pingable device 0x00158d00069ac702 lumi.sensor_magnet.aq2 was last seen '574.142' seconds ago.
        zigbee.0	2022-05-18 09:48:25.516	debug	(10400) DeviceAvailability:Non-pingable device 0x00158d0006becb12 lumi.sensor_magnet.aq2 was last seen '6565527.255' seconds ago.
        zigbee.0	2022-05-18 09:48:25.516	debug	(10400) DeviceAvailability:Non-pingable device 0x00158d000423bfd0 lumi.sensor_motion.aq2 was last seen '2892.825' seconds ago.
        zigbee.0	2022-05-18 09:48:25.515	debug	(10400) DeviceAvailability:Non-pingable device 0x00158d0007e3ac5e lumi.weather was last seen '798.981' seconds ago.
        zigbee.0	2022-05-18 09:48:25.512	debug	(10400) DeviceAvailability:Non-pingable device 0x00158d0007e20084 lumi.weather was last seen '1147.364' seconds ago.
        zigbee.0	2022-05-18 09:48:23.590	debug	(10400) getExclude result: []
        zigbee.0	2022-05-18 09:48:23.588	debug	(10400) getBinding result: []
        • M michihorn
          AsgothianA Offline
          AsgothianA Offline
          Asgothian
          @michihorn
          die gewünschten Meldungen sind auch in diesem Log ausschnitt nicht enthalten.
          Bitte lass den Adapter etwas laufen, Wechsel auf die Zigbee Tab Darstellung und schau danach ob es im Log Einträge mit den folgenden Schlüsselworten gibt:
          getDevices result:
          getDevices error:
          • AsgothianA Asgothian
            Bitte auch die Rückseite von den Kascheln anschauen ob die IEEE korrekt (0xdeadbeef01234567) oder falsch (0x0xdeadbeef01234567) angegeben ist.
            Ergebnis posten.
            A.
            TT-Tom
            @asgothian sagte in Zigbee Update:
            ich klinke mich hier mal ein, du schreibst das 0x0x...... falsch ist. auf der Kachel die @michihorn postet ist sehen das sie mit 0x0x beginnt. vielleicht da noch mal anfangen.
            Gruß tom
            Gruß Tom
            Public Transport
            NSPanel Adapter Wiki
            • T TT-Tom
              Gruß tom
              AsgothianA Offline
              AsgothianA Offline
              Asgothian
              @tt-tom sagte in Zigbee Update:
              Gruß tom
              Danke für den Hinweis. Da sind wir schon - es ist heraus zu bekommen woher der fasche Eintrag kommt. Er tritt nur unter bestimmten Randbedingungen auf, die ich bei mir auf keinem der (4) Testsysteme habe.
              Daher die Anfrage nach den expliziten Log Dateien.
              A.
                Gruß tom
                A.
                M Online
                M Online
                michihorn
                @asgothian
                zigbee.0	2022-05-18 18:17:16.738	debug	(10732) DeviceAvailability:Non-pingable device 0x00158d000549dc7f lumi.sensor_ht was last seen '108.675' seconds ago.
                zigbee.0	2022-05-18 18:17:16.733	debug	(10732) DeviceAvailability:Non-pingable device 0x0c4314fffe84e6d8 TS0042 was last seen '1558.648' seconds ago.
                zigbee.0	2022-05-18 18:17:16.732	debug	(10732) DeviceAvailability:Non-pingable device 0x00158d000253e897 lumi.sensor_motion.aq2 was last seen '1629.568' seconds ago.
                zigbee.0	2022-05-18 18:17:16.725	debug	(10732) DeviceAvailability:Non-pingable device 0x00158d0001e09c1a lumi.weather was last seen '611.589' seconds ago.
                zigbee.0	2022-05-18 18:17:16.724	debug	(10732) DeviceAvailability:Non-pingable device 0x00158d000444cb23 lumi.weather was last seen '1097.467' seconds ago.
                zigbee.0	2022-05-18 18:17:16.722	debug	(10732) DeviceAvailability:Non-pingable device 0x00158d00028d6fc4 lumi.sensor_magnet.aq2 was last seen '8184.111' seconds ago.
                zigbee.0	2022-05-18 18:17:16.717	debug	(10732) DeviceAvailability:Non-pingable device 0x00158d0001e0821b lumi.weather was last seen '852.308' seconds ago.
                zigbee.0	2022-05-18 18:17:16.716	debug	(10732) DeviceAvailability:Non-pingable device 0x00158d0001e13db7 lumi.weather was last seen '371.398' seconds ago.
                zigbee.0	2022-05-18 18:17:16.715	debug	(10732) DeviceAvailability:Non-pingable device 0x00158d0007b6e4bd lumi.sensor_magnet.aq2 was last seen '8624.259' seconds ago.
                zigbee.0	2022-05-18 18:17:16.713	debug	(10732) DeviceAvailability:Non-pingable device 0x00158d0007f851b6 lumi.sensor_magnet.aq2 was last seen '2066.38' seconds ago.
                zigbee.0	2022-05-18 18:17:16.712	debug	(10732) DeviceAvailability:Non-pingable device 0x00158d0007e0590a lumi.sensor_magnet.aq2 was last seen '6596280.244' seconds ago.
                zigbee.0	2022-05-18 18:17:16.707	debug	(10732) DeviceAvailability:Non-pingable device 0x00158d0007e033e1 lumi.sensor_magnet.aq2 was last seen '10.732' seconds ago.
                zigbee.0	2022-05-18 18:17:16.706	debug	(10732) DeviceAvailability:Non-pingable device 0x00158d0007b7cdce lumi.sensor_magnet.aq2 was last seen '2705.38' seconds ago.
                zigbee.0	2022-05-18 18:17:16.705	debug	(10732) DeviceAvailability:Non-pingable device 0x00158d000476bd65 lumi.sensor_magnet.aq2 was last seen '10347.419' seconds ago.
                zigbee.0	2022-05-18 18:17:16.704	debug	(10732) DeviceAvailability:Non-pingable device 0x00158d00069ac702 lumi.sensor_magnet.aq2 was last seen '988.482' seconds ago.
                zigbee.0	2022-05-18 18:17:16.703	debug	(10732) DeviceAvailability:Non-pingable device 0x00158d0006becb12 lumi.sensor_magnet.aq2 was last seen '6596058.442' seconds ago.
                zigbee.0	2022-05-18 18:17:16.702	debug	(10732) DeviceAvailability:Non-pingable device 0x00158d000423bfd0 lumi.sensor_motion.aq2 was last seen '426.302' seconds ago.
                zigbee.0	2022-05-18 18:17:16.700	debug	(10732) DeviceAvailability:Non-pingable device 0x00158d0007e3ac5e lumi.weather was last seen '938.824' seconds ago.
                zigbee.0	2022-05-18 18:17:16.699	debug	(10732) DeviceAvailability:Non-pingable device 0x00158d0007e20084 lumi.weather was last seen '1195.555' seconds ago.
                zigbee.0	2022-05-18 18:17:06.006	debug	(10732) Publish {"voltage":3025,"battery":100,"temperature":35,"contact":true} to "00158d0007e033e1"
                zigbee.0	2022-05-18 18:17:06.006	debug	(10732) lumi.sensor_magnet.aq2: Processed data into payload {"voltage":3025,"battery":100,"temperature":35,"contact":true}
                zigbee.0	2022-05-18 18:17:06.005	debug	(10732) lumi.sensor_magnet.aq2: Processed data into payload {"voltage":3025,"battery":100,"temperature":35,"contact":true}
                zigbee.0	2022-05-18 18:17:06.005	debug	(10732) lumi.sensor_magnet.aq2: unknown key 6 with value 0,1
                zigbee.0	2022-05-18 18:17:05.988	debug	(10732) Type attributeReport device {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":9,"_type":"EndDevice","_ieeeAddr":"0x00158d0007e033e1","_networkAddress":22928,"_
                zigbee.0	2022-05-18 18:17:05.987	debug	(10732) Received Zigbee message from '0x00158d0007e033e1', type 'attributeReport', cluster 'genBasic', data '{"65281":{"1":3025,"3":35,"4":17320,"5":15,"6":[0,1],"10":0,"100":0}}' from endpoint 1 wit
                zigbee.0	2022-05-18 18:17:05.976	debug	(10732) handleMessage. {"type":"attributeReport","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":9,"_type":"EndDevice","_ieeeAddr":"0x00158d0007e033e1","_networkAddress":22928,"_manu
                zigbee.0	2022-05-18 18:16:16.723	debug	(10732) DeviceAvailability:Non-pingable device 0x00158d000549dc7f lumi.sensor_ht was last seen '48.66' seconds ago.
                zigbee.0	2022-05-18 18:16:16.722	debug	(10732) DeviceAvailability:Non-pingable device 0x0c4314fffe84e6d8 TS0042 was last seen '1498.637' seconds ago.
                zigbee.0	2022-05-18 18:16:16.721	debug	(10732) DeviceAvailability:Non-pingable device 0x00158d000253e897 lumi.sensor_motion.aq2 was last seen '1569.557' seconds ago.
                zigbee.0	2022-05-18 18:16:16.720	debug	(10732) DeviceAvailability:Non-pingable device 0x00158d0001e09c1a lumi.weather was last seen '551.583' seconds ago.
                zigbee.0	2022-05-18 18:16:16.718	debug	(10732) DeviceAvailability:Non-pingable device 0x00158d000444cb23 lumi.weather was last seen '1037.462' seconds ago.
                zigbee.0	2022-05-18 18:16:16.717	debug	(10732) DeviceAvailability:Non-pingable device 0x00158d00028d6fc4 lumi.sensor_magnet.aq2 was last seen '8124.106' seconds ago.
                zigbee.0	2022-05-18 18:16:16.712	debug	(10732) DeviceAvailability:Non-pingable device 0x00158d0001e0821b lumi.weather was last seen '792.303' seconds ago.
                zigbee.0	2022-05-18 18:16:16.711	debug	(10732) DeviceAvailability:Non-pingable device 0x00158d0001e13db7 lumi.weather was last seen '311.393' seconds ago.
                zigbee.0	2022-05-18 18:16:16.710	debug	(10732) DeviceAvailability:Non-pingable device 0x00158d0007b6e4bd lumi.sensor_magnet.aq2 was last seen '8564.254' seconds ago.
                zigbee.0	2022-05-18 18:16:16.709	debug	(10732) DeviceAvailability:Non-pingable device 0x00158d0007f851b6 lumi.sensor_magnet.aq2 was last seen '2006.375' seconds ago.
                zigbee.0	2022-05-18 18:16:16.703	debug	(10732) DeviceAvailability:Non-pingable device 0x00158d0007e0590a lumi.sensor_magnet.aq2 was last seen '6596220.235' seconds ago.
                zigbee.0	2022-05-18 18:16:16.698	debug	(10732) DeviceAvailability:Non-pingable device 0x00158d0007e033e1 lumi.sensor_magnet.aq2 was last seen '15015.937' seconds ago.
                zigbee.0	2022-05-18 18:16:16.697	debug	(10732) DeviceAvailability:Non-pingable device 0x00158d0007b7cdce lumi.sensor_magnet.aq2 was last seen '2645.371' seconds ago.
                zigbee.0	2022-05-18 18:16:16.696	debug	(10732) DeviceAvailability:Non-pingable device 0x00158d000476bd65 lumi.sensor_magnet.aq2 was last seen '10287.41' seconds ago.
                zigbee.0	2022-05-18 18:16:16.692	debug	(10732) DeviceAvailability:Non-pingable device 0x00158d00069ac702 lumi.sensor_magnet.aq2 was last seen '928.47' seconds ago.
                zigbee.0	2022-05-18 18:16:16.691	debug	(10732) DeviceAvailability:Non-pingable device 0x00158d0006becb12 lumi.sensor_magnet.aq2 was last seen '6595998.43' seconds ago.
                zigbee.0	2022-05-18 18:16:16.690	debug	(10732) DeviceAvailability:Non-pingable device 0x00158d000423bfd0 lumi.sensor_motion.aq2 was last seen '366.29' seconds ago.
                zigbee.0	2022-05-18 18:16:16.689	debug	(10732) DeviceAvailability:Non-pingable device 0x00158d0007e3ac5e lumi.weather was last seen '878.813' seconds ago.
                zigbee.0	2022-05-18 18:16:16.687	debug	(10732) DeviceAvailability:Non-pingable device 0x00158d0007e20084 lumi.weather was last seen '1135.543' seconds ago.
                zigbee.0	2022-05-18 18:15:28.112	debug	(10732) Publish {"voltage":3005,"battery":100,"temperature":23.51,"humidity":62.58} to "00158d000549dc7f"
                zigbee.0	2022-05-18 18:15:28.111	debug	(10732) lumi.sens,lumi.sensor_ht: Processed data into payload {"voltage":3005,"battery":100,"temperature":23.51,"humidity":62.58}
                zigbee.0	2022-05-18 18:15:28.110	debug	(10732) lumi.sens,lumi.sensor_ht: unknown key 6 with value 0,2
                zigbee.0	2022-05-18 18:15:28.090	debug	(10732) Type attributeReport device {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":20,"_type":"EndDevice","_ieeeAddr":"0x00158d000549dc7f","_networkAddress":44107,"
                zigbee.0	2022-05-18 18:15:28.088	debug	(10732) Received Zigbee message from '0x00158d000549dc7f', type 'attributeReport', cluster 'genBasic', data '{"65281":{"1":3005,"4":5032,"5":57,"6":[0,2],"10":0,"100":2351,"101":6258}}' from endpoint
                zigbee.0	2022-05-18 18:15:28.067	debug	(10732) handleMessage. {"type":"attributeReport","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":20,"_type":"EndDevice","_ieeeAddr":"0x00158d000549dc7f","_networkAddress":44107,"_man
                zigbee.0	2022-05-18 18:15:16.716	debug	(10732) DeviceAvailability:Non-pingable device 0x00158d000549dc7f lumi.sensor_ht was last seen '3127.611' seconds ago.
                zigbee.0	2022-05-18 18:15:16.715	debug	(10732) DeviceAvailability:Non-pingable device 0x0c4314fffe84e6d8 TS0042 was last seen '1438.63' seconds ago.
                zigbee.0	2022-05-18 18:15:16.715	debug	(10732) DeviceAvailability:Non-pingable device 0x00158d000253e897 lumi.sensor_motion.aq2 was last seen '1509.551' seconds ago.
                zigbee.0	2022-05-18 18:15:16.714	debug	(10732) DeviceAvailability:Non-pingable device 0x00158d0001e09c1a lumi.weather was last seen '491.578' seconds ago.
                zigbee.0	2022-05-18 18:15:16.714	debug	(10732) DeviceAvailability:Non-pingable device 0x00158d000444cb23 lumi.weather was last seen '977.458' seconds ago.
                zigbee.0	2022-05-18 18:15:16.714	debug	(10732) DeviceAvailability:Non-pingable device 0x00158d00028d6fc4 lumi.sensor_magnet.aq2 was last seen '8064.102' seconds ago.
                zigbee.0	2022-05-18 18:15:16.701	debug	(10732) DeviceAvailability:Non-pingable device 0x00158d0001e0821b lumi.weather was last seen '732.292' seconds ago.
                zigbee.0	2022-05-18 18:15:16.700	debug	(10732) DeviceAvailability:Non-pingable device 0x00158d0001e13db7 lumi.weather was last seen '251.382' seconds ago.
                zigbee.0	2022-05-18 18:15:16.699	debug	(10732) DeviceAvailability:Non-pingable device 0x00158d0007b6e4bd lumi.sensor_magnet.aq2 was last seen '8504.243' seconds ago.
                zigbee.0	2022-05-18 18:15:16.698	debug	(10732) DeviceAvailability:Non-pingable device 0x00158d0007f851b6 lumi.sensor_magnet.aq2 was last seen '1946.365' seconds ago.
                zigbee.0	2022-05-18 18:15:16.691	debug	(10732) DeviceAvailability:Non-pingable device 0x00158d0007e0590a lumi.sensor_magnet.aq2 was last seen '6596160.223' seconds ago.
                zigbee.0	2022-05-18 18:15:16.690	debug	(10732) DeviceAvailability:Non-pingable device 0x00158d0007e033e1 lumi.sensor_magnet.aq2 was last seen '14955.929' seconds ago.
                zigbee.0	2022-05-18 18:15:16.689	debug	(10732) DeviceAvailability:Non-pingable device 0x00158d0007b7cdce lumi.sensor_magnet.aq2 was last seen '2585.363' seconds ago.
                zigbee.0	2022-05-18 18:15:16.688	debug	(10732) DeviceAvailability:Non-pingable device 0x00158d000476bd65 lumi.sensor_magnet.aq2 was last seen '10227.402' seconds ago.
                zigbee.0	2022-05-18 18:15:16.685	debug	(10732) DeviceAvailability:Non-pingable device 0x00158d00069ac702 lumi.sensor_magnet.aq2 was last seen '868.463' seconds ago.
                zigbee.0	2022-05-18 18:15:16.684	debug	(10732) DeviceAvailability:Non-pingable device 0x00158d0006becb12 lumi.sensor_magnet.aq2 was last seen '6595938.423' seconds ago.
                zigbee.0	2022-05-18 18:15:16.683	debug	(10732) DeviceAvailability:Non-pingable device 0x00158d000423bfd0 lumi.sensor_motion.aq2 was last seen '306.283' seconds ago.
                zigbee.0	2022-05-18 18:15:16.683	debug	(10732) DeviceAvailability:Non-pingable device 0x00158d0007e3ac5e lumi.weather was last seen '818.807' seconds ago.
                zigbee.0	2022-05-18 18:15:16.682	debug	(10732) DeviceAvailability:Non-pingable device 0x00158d0007e20084 lumi.weather was last seen '1075.538' seconds ago.
                zigbee.0	2022-05-18 18:14:16.713	debug	(10732) DeviceAvailability:Non-pingable device 0x00158d000549dc7f lumi.sensor_ht was last seen '3067.609' seconds ago.
                zigbee.0	2022-05-18 18:14:16.711	debug	(10732) DeviceAvailability:Non-pingable device 0x0c4314fffe84e6d8 TS0042 was last seen '1378.626' seconds ago.
                zigbee.0	2022-05-18 18:14:16.710	debug	(10732) DeviceAvailability:Non-pingable device 0x00158d000253e897 lumi.sensor_motion.aq2 was last seen '1449.546' seconds ago.
                zigbee.0	2022-05-18 18:14:16.708	debug	(10732) DeviceAvailability:Non-pingable device 0x00158d0001e09c1a lumi.weather was last seen '431.572' seconds ago.
                zigbee.0	2022-05-18 18:14:16.707	debug	(10732) DeviceAvailability:Non-pingable device 0x00158d000444cb23 lumi.weather was last seen '917.451' seconds ago.
                zigbee.0	2022-05-18 18:14:16.706	debug	(10732) DeviceAvailability:Non-pingable device 0x00158d00028d6fc4 lumi.sensor_magnet.aq2 was last seen '8004.095' seconds ago.
                zigbee.0	2022-05-18 18:14:16.700	debug	(10732) DeviceAvailability:Non-pingable device 0x00158d0001e0821b lumi.weather was last seen '672.291' seconds ago.
                zigbee.0	2022-05-18 18:14:16.699	debug	(10732) DeviceAvailability:Non-pingable device 0x00158d0001e13db7 lumi.weather was last seen '191.381' seconds ago.
                zigbee.0	2022-05-18 18:14:16.698	debug	(10732) DeviceAvailability:Non-pingable device 0x00158d0007b6e4bd lumi.sensor_magnet.aq2 was last seen '8444.242' seconds ago.
                Mehr tut sich nicht
                • M michihorn
                  @asgothian
                  Mehr tut sich nicht
                  AsgothianA Offline
                  AsgothianA Offline
                  Asgothian
                  @michihorn da muss sich was tun in dem moment wo du auf die Zigbee Tab Ansicht wechselst.
                  A.
                    A.
                    M Online
                    M Online
                    michihorn
                    schrieb am zuletzt editiert von michihorn
                    @asgothian Was genau meinst Du mit Tab Ansicht?
                    Mir fällt gerade mal auf das der Tab Einstellungen fehlt
                    arteckA AsgothianA 2 Antworten Letzte Antwort
                    • M michihorn
                      arteckA Offline
                      arteckA Offline
                      arteck
                      @michihorn quack...klicke und staune
                      • M michihorn
                        AsgothianA Offline
                        AsgothianA Offline
                        Asgothian
                        @michihorn in der Ansicht die du da offen hast den Tab "Geräte" öffnen, abwarten
                        A.
                        • arteckA arteck
                          M Online
                          M Online
                          michihorn
                          @arteck sagte in Zigbee Update:
                          Ach ja, das hatte ich schon richtig gemacht, ich wunderte mich nur, dass die von Asgothian gewünschten Resultate nicht im LOG erschienen sind.
                            A.
                            M Online
                            M Online
                            michihorn
                            @asgothian Hallo Asgothian, ich habe soeben noch einmal den Log kopiert
                            zigbee.0	2022-05-19 16:13:28.137	debug	(10732) DeviceAvailability:Non-pingable device 0x00158d000549dc7f lumi.sensor_ht was last seen '2923.336' seconds ago.
                            zigbee.0	2022-05-19 16:13:28.133	debug	(10732) DeviceAvailability:Non-pingable device 0x0c4314fffe84e6d8 TS0042 was last seen '2750.699' seconds ago.
                            zigbee.0	2022-05-19 16:13:28.132	debug	(10732) DeviceAvailability:Non-pingable device 0x00158d000253e897 lumi.sensor_motion.aq2 was last seen '1361.011' seconds ago.
                            zigbee.0	2022-05-19 16:13:28.131	debug	(10732) DeviceAvailability:Non-pingable device 0x00158d0001e09c1a lumi.weather was last seen '286.45' seconds ago.
                            zigbee.0	2022-05-19 16:13:28.130	debug	(10732) DeviceAvailability:Non-pingable device 0x00158d000444cb23 lumi.weather was last seen '715.348' seconds ago.
                            zigbee.0	2022-05-19 16:13:28.129	debug	(10732) DeviceAvailability:Non-pingable device 0x00158d00028d6fc4 lumi.sensor_magnet.aq2 was last seen '2892.854' seconds ago.
                            zigbee.0	2022-05-19 16:13:28.127	debug	(10732) DeviceAvailability:Non-pingable device 0x00158d0001e0821b lumi.weather was last seen '198.681' seconds ago.
                            zigbee.0	2022-05-19 16:13:28.126	debug	(10732) DeviceAvailability:Non-pingable device 0x00158d0001e13db7 lumi.weather was last seen '377.39' seconds ago.
                            zigbee.0	2022-05-19 16:13:28.126	debug	(10732) DeviceAvailability:Non-pingable device 0x00158d0007b6e4bd lumi.sensor_magnet.aq2 was last seen '3203.55' seconds ago.
                            zigbee.0	2022-05-19 16:13:28.125	debug	(10732) DeviceAvailability:Non-pingable device 0x00158d0007f851b6 lumi.sensor_magnet.aq2 was last seen '2805.106' seconds ago.
                            zigbee.0	2022-05-19 16:13:28.124	debug	(10732) DeviceAvailability:Non-pingable device 0x00158d0007e0590a lumi.sensor_magnet.aq2 was last seen '6675251.656' seconds ago.
                            zigbee.0	2022-05-19 16:13:28.124	debug	(10732) DeviceAvailability:Non-pingable device 0x00158d0007e033e1 lumi.sensor_magnet.aq2 was last seen '3610.205' seconds ago.
                            zigbee.0	2022-05-19 16:13:28.114	debug	(10732) DeviceAvailability:Non-pingable device 0x00158d0007b7cdce lumi.sensor_magnet.aq2 was last seen '467.92' seconds ago.
                            zigbee.0	2022-05-19 16:13:28.112	debug	(10732) DeviceAvailability:Non-pingable device 0x00158d000476bd65 lumi.sensor_magnet.aq2 was last seen '1787.034' seconds ago.
                            zigbee.0	2022-05-19 16:13:28.112	debug	(10732) DeviceAvailability:Non-pingable device 0x00158d00069ac702 lumi.sensor_magnet.aq2 was last seen '13714.272' seconds ago.
                            zigbee.0	2022-05-19 16:13:28.112	debug	(10732) DeviceAvailability:Non-pingable device 0x00158d0006becb12 lumi.sensor_magnet.aq2 was last seen '6675029.851' seconds ago.
                            zigbee.0	2022-05-19 16:13:28.112	debug	(10732) DeviceAvailability:Non-pingable device 0x00158d000423bfd0 lumi.sensor_motion.aq2 was last seen '3552.448' seconds ago.
                            zigbee.0	2022-05-19 16:13:28.111	debug	(10732) DeviceAvailability:Non-pingable device 0x00158d0007e3ac5e lumi.weather was last seen '2046.879' seconds ago.
                            zigbee.0	2022-05-19 16:13:28.111	debug	(10732) DeviceAvailability:Non-pingable device 0x00158d0007e20084 lumi.weather was last seen '219.109' seconds ago.
                            zigbee.0	2022-05-19 16:12:58.777	debug	2
                            zigbee.0	2022-05-19 16:12:58.777	debug	(10732) getBinding result: []
                            zigbee.0	2022-05-19 16:12:58.807	debug	(10732) getExclude result: []
                            zigbee.0	2022-05-19 16:12:58.362	debug	(10732) getDevices result: [{"_id":"0x00124b001cd47927","icon":"img/unknown.png","paired":true,"info":{"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"_type":"Coord
                            zigbee.0	2022-05-19 16:12:58.160	debug	(10732) getMap result: {"lqis":[{"parent":"0x00124b001cd47927","networkAddress":47520,"ieeeAddr":"0x0c4314fffe84e6d8","lqi":78,"relationship":1,"depth":1,"status":"online"},{"parent":"0x00124b001cd479
                            zigbee.0	2022-05-19 16:12:58.160	debug	(10732) Get map succeeded [{"parent":"0x00124b001cd47927","networkAddress":47520,"ieeeAddr":"0x0c4314fffe84e6d8","lqi":78,"relationship":1,"depth":1,"status":"online"},{"parent":"0x00124b001cd47927","
                            zigbee.0	2022-05-19 16:12:58.160	debug	(10732) Routing table succeeded for 'Coordinator'
                            zigbee.0	2022-05-19 16:12:58.159	debug	(10732) Routing for 'Coordinator': {"table":[]}
                            zigbee.0	2022-05-19 16:12:58.150	debug	(10732) LQI succeeded for 'Coordinator'
                            zigbee.0	2022-05-19 16:12:58.086	debug	(10732) getGroups result: {}
                            zigbee.0	2022-05-19 16:12:58.080	debug	(10732) getCoorinatorInfo result: {"installSource":"iobroker.zigbee@1.6.18","channel":"11","port":"COM3","type":"zStack3x0","revision":20210708,"version":"2-1.2.7.1."}
                            zigbee.0	2022-05-19 16:12:58.078	debug	(10732) List of ports: [{"comName":"COM3"},{"comName":"COM4"}]
                            Mehr kann ich nicht bieten
                            M.
                            • M michihorn
                              M.
                              AsgothianA Offline
                              AsgothianA Offline
                              Asgothian
                              @michihorn Der text ist drin, aber unvollständig. Du kannst den Text nicht aus der Oberfläche kopieren sondern musst das Log über "log herunterladen" als Text laden und die entscheidenden Zeilen kopieren.
                              Das was ich suche ist nach geschätzt 120 Zeichen abgeschnitten:
                              A.
                              • M Online
                                M Online
                                michihorn
                                @asgothian Ich würde dir super gerne das LOG runterladen, ich habe aber keinen Button mehr
                                • M michihorn
                                  AsgothianA Offline
                                  AsgothianA Offline
                                  Asgothian
                                  @michihorn du kannst auch die Datei direkt öffnen
                                  /opt/iobroker/log/iobroker.current.log
                                  A.
                                  T M 2 Antworten Letzte Antwort
                                    A.
                                    TT-Tom
                                    @asgothian
                                    Ich nochmal, könnte es auch an der Admin-Oberfläche liegen. Er nutzt noch die alte Oberfläche. Ist bei einigen Adapter jetzt schon Probleme aufgetreten, wenn noch die alte Ansicht aktiv war.
                                    Gruß Tom
                                    Public Transport
                                    • T TT-Tom
                                      @asgothian
                                      Ja.
                                        A.
                                        M Online
                                        M Online
                                        michihorn
                                        @asgothian
                                        iobroker.2022-05-20.log.zip
                                        Der LOG Download ist tatsächlich in dem neuen UI sichtbar.
                                        M.
