  4. Probleme von 4.0.21 auf 4.0.23
91 Beiträge 7 Kommentatoren 15.3k Aufrufe 5 Beobachtet
  • SMSS SMS
    @apollon77
    May  6 00:01:27 homee rsyslogd:  [origin software="rsyslogd" swVersion="8.1901.0" x-pid="398" x-info="https://www.rsyslog.com"] rsyslogd was HUPed
    May  6 00:01:31 homee influxd-systemd-start.sh[496]: [httpd] 192.168.178.58 - admin [06/May/2022:00:01:28 +0200] "POST /write?database=iobroker&db=iobroker&p=%5BREDACTED%5D&precision=ms&u=admin HTTP/1.1 " 204 0 "-" "-" e9efdcae-ccbe-11e$
    May  6 00:01:31 homee systemd[1]: logrotate.service: Succeeded.
    May  6 00:01:31 homee systemd[1]: Started Rotate log files.
    May  6 00:01:37 homee kernel: [ 6910.425923] w1_master_driver w1_bus_master1: Attaching one wire slave 00.210000000000 crc 7d
    May  6 00:01:37 homee kernel: [ 6910.434104] w1_master_driver w1_bus_master1: Family 0 for 00.210000000000.7d is not registered.
    May  6 00:01:58 homee bash[2230]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
    May  6 00:06:42 homee rngd[387]: stats: bits received from HRNG source: 120064
    May  6 00:06:42 homee rngd[387]: stats: bits sent to kernel pool: 63072
    May  6 00:06:42 homee rngd[387]: stats: entropy added to kernel pool: 63072
    May  6 00:06:42 homee rngd[387]: stats: FIPS 140-2 successes: 6
    May  6 00:06:42 homee rngd[387]: stats: FIPS 140-2 failures: 0
    May  6 00:06:42 homee rngd[387]: stats: FIPS 140-2(2001-10-10) Monobit: 0
    May  6 00:06:42 homee rngd[387]: stats: FIPS 140-2(2001-10-10) Poker: 0
    May  6 00:06:42 homee rngd[387]: stats: FIPS 140-2(2001-10-10) Runs: 0
    May  6 00:06:42 homee rngd[387]: stats: FIPS 140-2(2001-10-10) Long run: 0
    May  6 00:06:42 homee rngd[387]: stats: FIPS 140-2(2001-10-10) Continuous run: 0
    May  6 00:06:42 homee rngd[387]: stats: HRNG source speed: (min=372.542; avg=481.926; max=560.309)Kibits/s
    May  6 00:06:42 homee rngd[387]: stats: FIPS tests speed: (min=11.387; avg=14.422; max=31.268)Mibits/s
    May  6 00:06:42 homee rngd[387]: stats: Lowest ready-buffers level: 2
    May  6 00:06:42 homee rngd[387]: stats: Entropy starvations: 0
    May  6 00:06:42 homee rngd[387]: stats: Time spent starving for entropy: (min=0; avg=0.000; max=0)us
    May  6 00:17:01 homee CRON[8999]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
    May  6 01:17:01 homee CRON[12322]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
    May  6 01:17:09 homee kernel: [11442.408152] w1_master_driver w1_bus_master1: Attaching one wire slave 00.db0000000000 crc 77
    May  6 01:17:09 homee kernel: [11442.415445] w1_master_driver w1_bus_master1: Family 0 for 00.db0000000000.77 is not registered.
    Das wiederholt sich alles ...
    @sms Da musst du schon mehr liefern. Das sind ja nur die paar Minuten nach Mitternacht.
    SMSS 1 Antwort Letzte Antwort
    • SMSS SMS
      @apollon77
      @sms Es ging zB um den Zeitraum von gestern 22:xx Uhr wie oben das Log
        SMSS Offline
        SMSS Offline
        SMS
        schrieb am zuletzt editiert von SMS
        @thomas-braun wie gesagt, es wiederholt sich.
        hier z.B. ändert sich nur die Endung bzw. der letzte Teil
        May  6 00:02:17 homee kernel: [ 6949.673493] w1_master_driver w1_bus_master1: Attaching one wire slave 00.a10000000000 crc f1
        May  6 00:02:17 homee kernel: [ 6949.681792] w1_master_driver w1_bus_master1: Family 0 for 00.a10000000000.f1 is not registered.
        May  6 03:53:57 homee kernel: [20850.448190] w1_master_driver w1_bus_master1: Attaching one wire slave 00.098000000000 crc b3
        May  6 03:53:57 homee kernel: [20850.465035] w1_master_driver w1_bus_master1: Family 0 for 00.098000000000.b3 is not registered.
        May  6 04:41:06 homee kernel: [23678.807903] w1_master_driver w1_bus_master1: Attaching one wire slave 00.e38000000000 crc 24
        May  6 04:41:06 homee kernel: [23678.817614] w1_master_driver w1_bus_master1: Family 0 for 00.e38000000000.24 is not registered.
        • SMSS SMS
          @sms Dann ist es nicht relevant ... Bitte schau An den Zeotpunkten wo ioBroker ECONNREFUSED meldet!!
          • apollon77A apollon77
            SMSS Offline
            SMSS Offline
            SMS
            #66
            @apollon77 kann ich das wie suchen?
            Wie markiere ich denn alles? Was bedeutet M-A (Text markieren)?
              SMSS Offline
              SMSS Offline
              SMS
              #67
              @apollon77 sagte in Probleme von 4.0.21 auf 4.0.23:
              Das hatte ich aber aus dem LOG vom iobroker
              • SMSS SMS
                #68
                @sms Ja und du solltest schauen ob zum gleichen zeitraum auch was im anderen Log ist
                  SMSS Offline
                  SMSS Offline
                  SMS
                  #69
                  @apollon77
                  der LOG beginnt doch erst heute um 00:01:27. Das im iobroker war ja gestern.
                  Thomas BraunT apollon77A 2 Antworten Letzte Antwort
                  • SMSS SMS
                    @apollon77
                    #70
                    @sms
                    Dann schau im log von gestern.
                    zless -R /opt/iobroker/log/iobroker.2022-05-05.log.gz
                    syslog liegt woanders, falls du das anschauen willst.
                    • SMSS SMS
                      @apollon77
                      #71
                      @sms Bzw bei Syslog heisst das syslog.1 bzw syslog.X.gz
                      Thomas BraunT SMSS 3 Antworten Letzte Antwort
                        #72
                        Und ist nicht per Datum eindeutig gekennzeichnet. Das syslog läuft permanent seit boot.
                          SMSS Offline
                          SMSS Offline
                          SMS
                          #73
                          2022-05-05 22:21:58.771  - info: host.homee instance system.adapter.mqtt.0 terminated with code null ()
                          2022-05-05 22:21:58.870  - info: host.homee instance system.adapter.influxdb.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                          2022-05-05 22:21:58.870  - info: host.homee All instances are stopped.
                          2022-05-05 22:22:07.702  - info: host.homee terminated
                          2022-05-05 22:25:17.286  - info: host.homee iobroker.js-controller version 4.0.23 js-controller starting
                          2022-05-05 22:25:17.293  - info: host.homee Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                          2022-05-05 22:25:17.294  - info: host.homee hostname: homee, node: v14.19.1
                          2022-05-05 22:25:17.294  - info: host.homee ip addresses: 192.168.178.58 2001:16b8:24be:ce00:35fc:e4dd:2647:ec17 fe80::f3d:d27f:ef47:279
                          2022-05-05 22:25:21.569  - info: host.homee connected to Objects and States
                          2022-05-05 22:25:21.634  - info: host.homee added notifications configuration of host
                          2022-05-05 22:25:22.777  - info: host.homee 55 instances found
                          2022-05-05 22:25:22.874  - info: host.homee starting 23 instances
                          2022-05-05 22:25:22.892  - warn: host.homee startInstance cannot find adapter "ds18b20@1.5.4". Try to install it... 1 attempt
                          2022-05-05 22:25:22.893  - info: host.homee iobroker install ds18b20@1.5.4 using installedFrom
                          2022-05-05 22:25:23.266  - info: host.homee instance system.adapter.admin.0 started with pid 2255
                          2022-05-05 22:25:26.754  - info: host.homee iobroker npm-install: NPM version: 6.14.16
                          2022-05-05 22:25:26.756  - info: host.homee iobroker npm-install: Installing iobroker.ds18b20@1.5.4... (System call)
                          2022-05-05 22:25:26.924  - info: host.homee instance system.adapter.email.0 started with pid 2287
                          2022-05-05 22:25:27.120  - info: admin.0 (2255) starting. Version 5.3.8 in /opt/iobroker/node_modules/iobroker.admin, node: v14.19.1, js-controller: 4.0.23
                          2022-05-05 22:25:27.210  - info: admin.0 (2255) requesting all states
                          2022-05-05 22:25:27.211  - info: admin.0 (2255) requesting all objects
                          2022-05-05 22:25:29.417  - info: admin.0 (2255) received all objects
                          2022-05-05 22:25:29.654  - info: admin.0 (2255) Request actual repository...
                          2022-05-05 22:25:29.773  - info: admin.0 (2255) http server listening on port 7777
                          2022-05-05 22:25:29.774  - info: admin.0 (2255) Use link "http://localhost:7777" to configure.
                          2022-05-05 22:25:32.269  - info: host.homee instance system.adapter.influxdb.0 started with pid 2306
                          2022-05-05 22:25:37.582  - info: host.homee instance system.adapter.javascript.0 started with pid 2317
                          2022-05-05 22:25:39.354  - info: host.homee Updating repository "Stable (default)" under "http://download.iobroker.net/sources-dist.json"
                          2022-05-05 22:25:41.855  - info: host.homee instance scheduled system.adapter.ical.0 0 */12 * * *
                          2022-05-05 22:25:43.416  - info: admin.0 (2255) Repository received successfully.
                          2022-05-05 22:25:41.898  - info: host.homee instance system.adapter.ical.0 started with pid 2336
                          2022-05-05 22:25:46.687  - info: email.0 (2287) starting. Version 1.0.10 in /opt/iobroker/node_modules/iobroker.email, node: v14.19.1, js-controller: 4.0.23
                          2022-05-05 22:25:46.945  - info: host.homee instance system.adapter.mqtt.0 started with pid 2351
                          2022-05-05 22:25:47.568  - info: host.homee instance system.adapter.rpi2.0 started with pid 2358
                          2022-05-05 22:25:50.630  - info: influxdb.0 (2306) starting. Version 2.6.3 in /opt/iobroker/node_modules/iobroker.influxdb, node: v14.19.1, js-controller: 4.0.23
                          2022-05-05 22:25:50.697  - info: influxdb.0 (2306) No stored data from last exit found
                          2022-05-05 22:25:50.699  - info: influxdb.0 (2306) Connecting http://192.168.178.58:8086 ...
                          2022-05-05 22:25:50.700  - info: influxdb.0 (2306) Influx DB Version used: 1.x
                          nix zu sehen
                            SMSS Offline
                            SMSS Offline
                            SMS
                            #74
                            May  5 22:25:16 homee systemd[1]: Started ioBroker Server.
                            May  5 22:25:16 homee influxd-systemd-start.sh[496]: ts=2022-05-05T20:25:16.815776Z lvl=info msg="TSM compaction (end)" log_id=0aHT8Fol000 engine=tsm1 tsm1_strategy=full tsm1_optimize=false trace_id=0aHUD9fG000 op_name=tsm1_compact_grou$
                            May  5 22:25:17 homee influxd-systemd-start.sh[496]: ts=2022-05-05T20:25:17.385721Z lvl=info msg="TSM compaction (start)" log_id=0aHT8Fol000 engine=tsm1 tsm1_strategy=full tsm1_optimize=false trace_id=0aHUDPIG000 op_name=tsm1_compact_gr$
                            May  5 22:25:17 homee influxd-systemd-start.sh[496]: ts=2022-05-05T20:25:17.385781Z lvl=info msg="Beginning compaction" log_id=0aHT8Fol000 engine=tsm1 tsm1_strategy=full tsm1_optimize=false trace_id=0aHUDPIG000 op_name=tsm1_compact_grou$
                            May  5 22:25:17 homee influxd-systemd-start.sh[496]: ts=2022-05-05T20:25:17.385803Z lvl=info msg="Compacting file" log_id=0aHT8Fol000 engine=tsm1 tsm1_strategy=full tsm1_optimize=false trace_id=0aHUDPIG000 op_name=tsm1_compact_group db_$
                            May  5 22:25:17 homee influxd-systemd-start.sh[496]: ts=2022-05-05T20:25:17.385824Z lvl=info msg="Compacting file" log_id=0aHT8Fol000 engine=tsm1 tsm1_strategy=full tsm1_optimize=false trace_id=0aHUDPIG000 op_name=tsm1_compact_group db_$
                            May  5 22:25:19 homee influxd-systemd-start.sh[496]: ts=2022-05-05T20:25:19.698975Z lvl=warn msg="Error compacting TSM files" log_id=0aHT8Fol000 engine=tsm1 tsm1_strategy=full tsm1_optimize=false trace_id=0aHUDPIG000 op_name=tsm1_compac$
                            May  5 22:25:20 homee influxd-systemd-start.sh[496]: ts=2022-05-05T20:25:20.699205Z lvl=info msg="TSM compaction (end)" log_id=0aHT8Fol000 engine=tsm1 tsm1_strategy=full tsm1_optimize=false trace_id=0aHUDPIG000 op_name=tsm1_compact_grou$
                            May  5 22:25:21 homee influxd-systemd-start.sh[496]: ts=2022-05-05T20:25:21.385843Z lvl=info msg="TSM compaction (start)" log_id=0aHT8Fol000 engine=tsm1 tsm1_strategy=full tsm1_optimize=false trace_id=0aHUDdvG000 op_name=tsm1_compact_gr$
                            May  5 22:25:21 homee influxd-systemd-start.sh[496]: ts=2022-05-05T20:25:21.385901Z lvl=info msg="Beginning compaction" log_id=0aHT8Fol000 engine=tsm1 tsm1_strategy=full tsm1_optimize=false trace_id=0aHUDdvG000 op_name=tsm1_compact_grou$
                            May  5 22:25:21 homee influxd-systemd-start.sh[496]: ts=2022-05-05T20:25:21.385922Z lvl=info msg="Compacting file" log_id=0aHT8Fol000 engine=tsm1 tsm1_strategy=full tsm1_optimize=false trace_id=0aHUDdvG000 op_name=tsm1_compact_group db_$
                            May  5 22:25:21 homee influxd-systemd-start.sh[496]: ts=2022-05-05T20:25:21.385946Z lvl=info msg="Compacting file" log_id=0aHT8Fol000 engine=tsm1 tsm1_strategy=full tsm1_optimize=false trace_id=0aHUDdvG000 op_name=tsm1_compact_group db_$
                            May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.admin.0" for host "homee"
                            May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.admin.1" for host "homee"
                            May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.email.0" for host "homee"
                            May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.influxdb.0" for host "homee"
                            May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.javascript.0" for host "homee"
                            May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.whatsapp-cmb.0" for host "Gartenklo"
                            May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.ical.0" for host "homee"
                            May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.modbus.1" for host "kellerkind4GB"
                            May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.modbus.2" for host "kellerkind4GB"
                            May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.mqtt.0" for host "homee"
                            May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.rpi2.0" for host "homee"
                            May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.rpi2.1" for host "kellerkind4GB"
                            May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.rpi2.4" for host "Gartenklo"
                            May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.smartmeter.0" for host "homee"
                            May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.sonoff.0" for host "homee"
                            May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.rpi2.2" for host "homee"
                            May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.rpi2.3" for host "PapaHuette"
                            May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.backitup.0" for host "homee"
                            May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.binance.0" for host "homee"
                            May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.coronavirus-statistics.0" for host "homee"
                            May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.daswetter.0" for host "homee"
                            May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.ds18b20.1" for host "kellerkind4GB"
                            May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.ds18b20.2" for host "homee"
                            May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.dwd.0" for host "homee"
                            May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.ecovacs-deebot.0" for host "homee"
                            May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.fritzbox.0" for host "homee"
                            May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.growatt.0" for host "homee"
                            May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.nina.0" for host "homee"
                            May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.parser.0" for host "homee"
                            May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.pegelalarm.0" for host "homee"
                            May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.pollenflug.0" for host "homee"
                            May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.systeminfo.0" for host "homee"
                            May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.systeminfo.1" for host "kellerkind4GB"
                            May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.systeminfo.4" for host "Gartenklo"
                            May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.tankerkoenig.0" for host "homee"
                            May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.vis-bars.0" for host "homee"
                            May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.vis-canvas-gauges.0" for host "homee"
                            May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.vis-history.0" for host "homee"
                            May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.vis-hqwidgets.0" for host "homee"
                            May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.vis-jqui-mfd.0" for host "homee"
                            May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.vis-justgage.0" for host "homee"
                            May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.vis-metro.0" for host "homee"
                            May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.vis-plumb.0" for host "homee"
                            May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.vis-rgraph.0" for host "homee"
                            May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.vis-timeandweather.0" for host "homee"
                            May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.vis.0" for host "homee"
                            May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.web.0" for host "homee"
                            May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.worx.2" for host "PapaHuette"
                            May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.systeminfo.2" for host "homee"
                            May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.discovery.0" for host "homee"
                            May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.systeminfo.3" for host "PapaHuette"
                            May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.ds18b20.3" for host "PapaHuette"
                            May  5 22:25:22 homee bash[2230]: host.homee check instance "system.adapter.pegelalarm.1" for host "homee"
                            May  5 22:25:24 homee influxd-systemd-start.sh[496]: ts=2022-05-05T20:25:24.111574Z lvl=warn msg="Error compacting TSM files" log_id=0aHT8Fol000 engine=tsm1 tsm1_strategy=full tsm1_optimize=false trace_id=0aHUDdvG000 op_name=tsm1_compac$
                            May  5 22:25:24 homee kernel: [ 1137.087409] w1_master_driver w1_bus_master1: Attaching one wire slave 00.a80000000000 crc 6d
                            May  5 22:25:24 homee kernel: [ 1137.094042] w1_master_driver w1_bus_master1: Family 0 for 00.a80000000000.6d is not registered.
                            May  5 22:25:30 homee bash[2230]: ================================== > LOG REDIRECT system.adapter.admin.0 => true [system.adapter.admin.0.logging]
                            May  5 22:25:38 homee bash[2230]: Send diag info: {"uuid":"552ef446-e4c5-844c-fb5b-c3c1844dd251","language":"de","country":"Germany","hosts":[{"version":"4.0.23","platform":"Javascript/Node.js","type":"linux"},{"version":"4.0.23","platf$
                            May  5 22:26:55 homee bash[2230]: Send diag info: {"uuid":"552ef446-e4c5-844c-fb5b-c3c1844dd251","language":"de","country":"Germany","hosts":[{"version":"4.0.23","platform":"Javascript/Node.js","type":"linux"},{"version":"4.0.23","platf$
                            • SMSS SMS
                              #75
                              @sms was steht da früher?im log sieht man klar das 22:22 iobroker gestoppt wurde und 22:25 gestartet. Also was steht so gegen 22:22 bis 25 im syslog???
                                SMSS Offline
                                SMSS Offline
                                SMS
                                #76
                                @apollon77
                                Leider nicht mehr rausfindbar. In den Dateien stehen nur Hyroglyphen.
                                • SMSS SMS
                                  @apollon77
                                  #77
                                  @sms Wenn das so ist ............. SD Karte defekt?
                                    #78
                                    @apollon77
                                    Oder es wurde das gz-Archiv mir einem Editor geöffnet.
                                    apollon77A SMSS 2 Antworten Letzte Antwort
                                      @apollon77
                                      #79
                                      @thomas-braun lol ... ja right .. Auch ne Option gg
                                        @apollon77
                                        SMSS Offline
                                        SMSS Offline
                                        SMS
                                        #80
                                        so:
                                        nano /var/log/syslog.6.gz
                                        Denke das wird dann wohl falsch sein ...
                                        • SMSS SMS
                                          so:
                                          #81
                                          @sms sagte in Probleme von 4.0.21 auf 4.0.23:
                                          Ich würde mir das in einem pager anschauen.
                                          less bzw. in Falle von gezippten Dateien zless
                                          zless /var/log/syslog.6.gz
