  4. Kann keine Adapter mehr installieren
    5.9k
30 Beiträge 4 Kommentatoren 3.5k Aufrufe 3 Beobachtet
    @andrebu sagte in Kann keine Adapter mehr installieren:
    This version of npm is compatible with lockfileVersion@1, but package-lock.json was generated for lockfileVersion@2
    hast du mal npm v7 oder größer drauf gehabt?
    andrebu
    @homoran ja aus einem mir nicht nachvollziehbaren Grund war 7 drauf. Ich weiß das die ungraden Entwicklerversionen sind. Echt keine Ahnung wie das passiert ist. Ist aber inzwischen auf 6 geändert.
    Intel NUC
    Proxmox
    Raspberry Pi 4
    Conbee 2 Stick
    Adapter: deConz Zigbee
    • A andrebu
      hier der 2te Teil des Log
      npm ERR! missing: fs-extra@9.1.0, required by @alcalzone/pak@0.7.0
      npm ERR! missing: axios@0.21.4, required by @alcalzone/pak@0.7.0
      npm ERR! missing: execa@5.1.1, required by @alcalzone/pak@0.7.0
      npm ERR! missing: at-least-node@1.0.0, required by fs-extra@9.1.0
      npm ERR! missing: graceful-fs@4.2.6, required by fs-extra@9.1.0
      npm ERR! missing: jsonfile@6.1.0, required by fs-extra@9.1.0
      npm ERR! missing: universalify@2.0.0, required by fs-extra@9.1.0
      npm ERR! missing: debug@4.3.4, required by @iobroker/js-controller-cli@4.0.23
      npm ERR! missing: @iobroker/js-controller-common@4.0.23, required by @iobroker/js-controller-cli@4.0.23
      npm ERR! missing: @iobroker/js-controller-common-db@4.0.23, required by @iobroker/js-controller-cli@4.0.23
      npm ERR! missing: chokidar@3.5.3, required by @iobroker/js-controller-cli@4.0.23
      npm ERR! missing: daemonize2@0.4.2, required by @iobroker/js-controller-cli@4.0.23
      npm ERR! missing: deep-clone@3.0.3, required by @iobroker/js-controller-cli@4.0.23
      npm ERR! missing: event-stream@4.0.1, required by @iobroker/js-controller-cli@4.0.23
      npm ERR! missing: fs-extra@10.0.1, required by @iobroker/js-controller-cli@4.0.23
      npm ERR! missing: readline-sync@1.4.10, required by @iobroker/js-controller-cli@4.0.23
      npm ERR! missing: ms@2.1.2, required by debug@4.3.4
      npm ERR! missing: anymatch@3.1.2, required by chokidar@3.5.3
      npm ERR! missing: braces@3.0.2, required by chokidar@3.5.3
      npm ERR! missing: glob-parent@5.1.2, required by chokidar@3.5.3
      npm ERR! missing: is-binary-path@2.1.0, required by chokidar@3.5.3
      npm ERR! missing: is-glob@4.0.1, required by chokidar@3.5.3
      npm ERR! missing: normalize-path@3.0.0, required by chokidar@3.5.3
      npm ERR! missing: readdirp@3.6.0, required by chokidar@3.5.3
      npm ERR! missing: normalize-path@3.0.0, required by anymatch@3.1.2
      npm ERR! missing: picomatch@2.3.0, required by anymatch@3.1.2
      npm ERR! missing: fill-range@7.0.1, required by braces@3.0.2
      npm ERR! missing: to-regex-range@5.0.1, required by fill-range@7.0.1
      npm ERR! missing: is-number@7.0.0, required by to-regex-range@5.0.1
      npm ERR! missing: is-glob@4.0.1, required by glob-parent@5.1.2
      npm ERR! missing: binary-extensions@2.2.0, required by is-binary-path@2.1.0
      npm ERR! missing: is-extglob@2.1.1, required by is-glob@4.0.1
      npm ERR! missing: picomatch@2.3.0, required by readdirp@3.6.0
      npm ERR! missing: duplexer@0.1.2, required by event-stream@4.0.1
      npm ERR! missing: from@0.1.7, required by event-stream@4.0.1
      npm ERR! missing: map-stream@0.0.7, required by event-stream@4.0.1
      npm ERR! missing: pause-stream@0.0.11, required by event-stream@4.0.1
      npm ERR! missing: split@1.0.1, required by event-stream@4.0.1
      npm ERR! missing: stream-combiner@0.2.2, required by event-stream@4.0.1
      npm ERR! missing: through@2.3.8, required by event-stream@4.0.1
      npm ERR! missing: through@2.3.8, required by pause-stream@0.0.11
      npm ERR! missing: duplexer@0.1.2, required by stream-combiner@0.2.2
      npm ERR! missing: through@2.3.8, required by stream-combiner@0.2.2
      npm ERR! missing: @alcalzone/pak@0.7.0, required by @iobroker/js-controller-common@4.0.23
      npm ERR! missing: axios@0.26.1, required by @iobroker/js-controller-common@4.0.23
      npm ERR! missing: ci-info@3.3.0, required by @iobroker/js-controller-common@4.0.23
      npm ERR! missing: deep-clone@3.0.3, required by @iobroker/js-controller-common@4.0.23
      npm ERR! missing: event-stream@4.0.1, required by @iobroker/js-controller-common@4.0.23
      npm ERR! missing: fs-extra@10.0.1, required by @iobroker/js-controller-common@4.0.23
      npm ERR! missing: jsonwebtoken@8.5.1, required by @iobroker/js-controller-common@4.0.23
      npm ERR! missing: node-forge@1.3.1, required by @iobroker/js-controller-common@4.0.23
      npm ERR! missing: node.extend@2.0.2, required by @iobroker/js-controller-common@4.0.23
      npm ERR! missing: promisify-child-process@4.1.1, required by @iobroker/js-controller-common@4.0.23
      npm ERR! missing: readline@1.3.0, required by @iobroker/js-controller-common@4.0.23
      npm ERR! missing: request@2.88.2, required by @iobroker/js-controller-common@4.0.23
      npm ERR! missing: semver@7.3.5, required by @iobroker/js-controller-common@4.0.23
      npm ERR! missing: winston@3.7.2, required by @iobroker/js-controller-common@4.0.23
      npm ERR! missing: winston-daily-rotate-file@4.6.1, required by @iobroker/js-controller-common@4.0.23
      npm ERR! missing: winston-transport@4.5.0, required by @datalust/winston-seq@1.0.2
      npm ERR! missing: logform@2.4.0, required by winston-transport@4.5.0
      npm ERR! missing: triple-beam@1.3.0, required by winston-transport@4.5.0
      npm ERR! missing: readable-stream@3.6.0, required by winston-transport@4.5.0
      npm ERR! missing: inherits@2.0.4, required by readable-stream@3.6.0
      npm ERR! missing: string_decoder@1.1.1, required by readable-stream@3.6.0
      npm ERR! missing: util-deprecate@1.0.2, required by readable-stream@3.6.0
      npm ERR! missing: follow-redirects@1.14.9, required by axios@0.26.1
      npm ERR! missing: @dabh/diagnostics@2.0.3, required by winston@3.7.2
      npm ERR! missing: is-stream@2.0.0, required by winston@3.7.2
      npm ERR! missing: logform@2.4.0, required by winston@3.7.2
      npm ERR! missing: one-time@1.0.0, required by winston@3.7.2
      npm ERR! missing: safe-stable-stringify@2.3.1, required by winston@3.7.2
      npm ERR! missing: stack-trace@0.0.10, required by winston@3.7.2
      npm ERR! missing: triple-beam@1.3.0, required by winston@3.7.2
      npm ERR! missing: winston-transport@4.5.0, required by winston@3.7.2
      npm ERR! missing: async@3.2.3, required by winston@3.7.2
      npm ERR! missing: readable-stream@3.6.0, required by winston@3.7.2
      npm ERR! missing: colorspace@1.1.4, required by @dabh/diagnostics@2.0.3
      npm ERR! missing: enabled@2.0.0, required by @dabh/diagnostics@2.0.3
      npm ERR! missing: kuler@2.0.0, required by @dabh/diagnostics@2.0.3
      npm ERR! missing: color@3.2.1, required by colorspace@1.1.4
      npm ERR! missing: text-hex@1.0.0, required by colorspace@1.1.4
      npm ERR! missing: @colors/colors@1.5.0, required by logform@2.4.0
      npm ERR! missing: fecha@4.2.3, required by logform@2.4.0
      npm ERR! missing: ms@2.1.3, required by logform@2.4.0
      npm ERR! missing: safe-stable-stringify@2.3.1, required by logform@2.4.0
      npm ERR! missing: triple-beam@1.3.0, required by logform@2.4.0
      npm ERR! missing: fn.name@1.1.0, required by one-time@1.0.0
      npm ERR! missing: file-stream-rotator@0.6.1, required by winston-daily-rotate-file@4.6.1
      npm ERR! missing: object-hash@2.2.0, required by winston-daily-rotate-file@4.6.1
      npm ERR! missing: triple-beam@1.3.0, required by winston-daily-rotate-file@4.6.1
      npm ERR! missing: winston-transport@4.5.0, required by winston-daily-rotate-file@4.6.1
      npm ERR! missing: moment@2.29.1, required by file-stream-rotator@0.6.1
      npm ERR! missing: file-uri-to-path@1.0.0, required by bindings@1.5.0
      npm ERR! missing: @iobroker/db-objects-file@4.0.23, required by @iobroker/js-controller-common-db@4.0.23
      npm ERR! missing: @iobroker/db-objects-jsonl@4.0.23, required by @iobroker/js-controller-common-db@4.0.23
      npm ERR! missing: @iobroker/db-objects-redis@4.0.23, required by @iobroker/js-controller-common-db@4.0.23
      npm ERR! missing: @iobroker/db-states-file@4.0.23, required by @iobroker/js-controller-common-db@4.0.23
      npm ERR! missing: @iobroker/db-states-jsonl@4.0.23, required by @iobroker/js-controller-common-db@4.0.23
      npm ERR! missing: @iobroker/db-states-redis@4.0.23, required by @iobroker/js-controller-common-db@4.0.23
      npm ERR! missing: @iobroker/js-controller-common@4.0.23, required by @iobroker/js-controller-common-db@4.0.23
      npm ERR! missing: fs-extra@10.0.1, required by @iobroker/js-controller-common-db@4.0.23
      npm ERR! missing: winston-transport@4.5.0, required by winston-seq-updated@1.0.4
      npm ERR! missing: @iobroker/plugin-base@1.2.1, required by @iobroker/plugin-sentry@1.2.0
      npm ERR! missing: @sentry/integrations@6.18.2, required by @iobroker/plugin-sentry@1.2.0
      npm ERR! missing: @sentry/node@6.18.2, required by @iobroker/plugin-sentry@1.2.0
      npm ERR! missing: source-map-support@0.5.21, required by @iobroker/plugin-sentry@1.2.0
      npm ERR! missing: callsite@1.0.0, required by decache@4.6.1
      npm ERR! missing: es6-promise@4.2.8, required by diskusage@1.1.3
      npm ERR! missing: escape-html@1.0.3, required by redirect-https@1.3.1
      npm ERR! missing: follow-redirects@1.14.9, required by axios@0.24.0
      npm ERR! missing: ms@2.1.2, required by debug@4.3.3
      npm ERR! missing: ms@2.1.3, required by jsonwebtoken@8.5.1
      npm ERR! missing: semver@5.7.1, required by jsonwebtoken@8.5.1
      npm ERR! missing: jws@3.2.2, required by jsonwebtoken@8.5.1
      npm ERR! missing: lodash.includes@4.3.0, required by jsonwebtoken@8.5.1
      npm ERR! missing: lodash.isboolean@3.0.3, required by jsonwebtoken@8.5.1
      npm ERR! missing: lodash.isinteger@4.0.4, required by jsonwebtoken@8.5.1
      npm ERR! missing: lodash.isnumber@3.0.3, required by jsonwebtoken@8.5.1
      npm ERR! missing: lodash.isplainobject@4.0.6, required by jsonwebtoken@8.5.1
      npm ERR! missing: lodash.isstring@4.0.1, required by jsonwebtoken@8.5.1
      npm ERR! missing: lodash.once@4.1.1, required by jsonwebtoken@8.5.1
      npm ERR! missing: jwa@1.4.1, required by jws@3.2.2
      npm ERR! missing: safe-buffer@5.1.2, required by jws@3.2.2
      npm ERR! missing: buffer-equal-constant-time@1.0.1, required by jwa@1.4.1
      npm ERR! missing: ecdsa-sig-formatter@1.0.11, required by jwa@1.4.1
      npm ERR! missing: safe-buffer@5.1.2, required by jwa@1.4.1
      npm ERR! missing: lie@3.3.0, required by jszip@3.7.1
      npm ERR! missing: pako@1.0.11, required by jszip@3.7.1
      npm ERR! missing: readable-stream@2.3.7, required by jszip@3.7.1
      npm ERR! missing: set-immediate-shim@1.0.1, required by jszip@3.7.1
      npm ERR! missing: immediate@3.0.6, required by lie@3.3.0
      npm ERR! missing: core-util-is@1.0.2, required by readable-stream@2.3.7
      npm ERR! missing: inherits@2.0.4, required by readable-stream@2.3.7
      npm ERR! missing: isarray@1.0.0, required by readable-stream@2.3.7
      npm ERR! missing: process-nextick-args@2.0.1, required by readable-stream@2.3.7
      npm ERR! missing: safe-buffer@5.1.2, required by readable-stream@2.3.7
      npm ERR! missing: string_decoder@1.1.1, required by readable-stream@2.3.7
      npm ERR! missing: util-deprecate@1.0.2, required by readable-stream@2.3.7
      npm ERR! missing: safe-buffer@5.1.2, required by string_decoder@1.1.1
      npm ERR! missing: request@2.88.2, required by le-acme-core@2.1.4
      npm ERR! missing: weak-daemon@1.0.3, required by loadavg-windows@1.1.1
      npm ERR! missing: safe-buffer@5.2.1, required by pidusage@3.0.0
      npm ERR! missing: @colors/colors@1.5.0, required by prompt@1.2.2
      npm ERR! missing: async@0.9.2, required by prompt@1.2.2
      npm ERR! missing: winston@2.4.5, required by prompt@1.2.2
      npm ERR! missing: read@1.0.7, required by prompt@1.2.2
      npm ERR! missing: revalidator@0.1.8, required by prompt@1.2.2
      npm ERR! missing: cycle@1.0.3, required by winston@2.4.5
      npm ERR! missing: eyes@0.1.8, required by winston@2.4.5
      npm ERR! missing: isstream@0.1.2, required by winston@2.4.5
      npm ERR! missing: colors@1.0.3, required by winston@2.4.5
      npm ERR! missing: async@1.0.0, required by winston@2.4.5
      npm ERR! missing: stack-trace@0.0.10, required by winston@2.4.5
      npm ERR! missing: mute-stream@0.0.8, required by read@1.0.7
      npm ERR! missing: chownr@2.0.0, required by tar@6.1.11
      npm ERR! missing: fs-minipass@2.1.0, required by tar@6.1.11
      npm ERR! missing: minipass@3.1.3, required by tar@6.1.11
      npm ERR! missing: minizlib@2.1.2, required by tar@6.1.11
      npm ERR! missing: mkdirp@1.0.4, required by tar@6.1.11
      npm ERR! missing: yallist@4.0.0, required by tar@6.1.11
      npm ERR! missing: minipass@3.1.3, required by fs-minipass@2.1.0
      npm ERR! missing: yallist@4.0.0, required by minipass@3.1.3
      npm ERR! missing: minipass@3.1.3, required by minizlib@2.1.2
      npm ERR! missing: yallist@4.0.0, required by minizlib@2.1.2
      npm ERR! missing: cliui@7.0.4, required by yargs@17.3.1
      npm ERR! missing: escalade@3.1.1, required by yargs@17.3.1
      npm ERR! missing: get-caller-file@2.0.5, required by yargs@17.3.1
      npm ERR! missing: require-directory@2.1.1, required by yargs@17.3.1
      npm ERR! missing: y18n@5.0.8, required by yargs@17.3.1
      npm ERR! missing: string-width@4.2.3, required by yargs@17.3.1
      npm ERR! missing: yargs-parser@21.0.1, required by yargs@17.3.1
      npm ERR! missing: string-width@4.2.3, required by cliui@7.0.4
      npm ERR! missing: strip-ansi@6.0.1, required by cliui@7.0.4
      npm ERR! missing: wrap-ansi@7.0.0, required by cliui@7.0.4
      npm ERR! missing: is-fullwidth-code-point@3.0.0, required by string-width@4.2.3
      npm ERR! missing: strip-ansi@6.0.1, required by string-width@4.2.3
      npm ERR! missing: emoji-regex@8.0.0, required by string-width@4.2.3
      npm ERR! missing: ansi-regex@5.0.1, required by strip-ansi@6.0.1
      npm ERR! missing: ansi-styles@4.3.0, required by wrap-ansi@7.0.0
      npm ERR! missing: string-width@4.2.0, required by wrap-ansi@7.0.0
      npm ERR! missing: strip-ansi@6.0.0, required by wrap-ansi@7.0.0
      npm ERR! missing: emoji-regex@8.0.0, required by string-width@4.2.0
      npm ERR! missing: is-fullwidth-code-point@3.0.0, required by string-width@4.2.0
      npm ERR! missing: strip-ansi@6.0.0, required by string-width@4.2.0
      npm ERR! missing: ansi-regex@5.0.0, required by strip-ansi@6.0.0
      npm ERR! missing: @iobroker/adapter-core@2.6.0, required by iobroker.nina@0.0.25
      npm ERR! missing: request@2.88.2, required by iobroker.nina@0.0.25
      npm ERR! missing: traverse@0.6.6, required by iobroker.nina@0.0.25
      npm ERR! missing: @iobroker/adapter-core@2.6.0, required by iobroker.nut@1.5.1
      npm ERR! missing: node-nut@1.0.3, required by iobroker.nut@1.5.1
      npm ERR! missing: @iobroker/adapter-core@2.6.0, required by iobroker.onvif@0.4.4
      npm ERR! missing: sharp@0.25.4, required by iobroker.onvif@0.4.4
      npm ERR! missing: nimble@0.0.2, required by iobroker.onvif@0.4.4
      npm ERR! missing: onvif@0.6.4, required by iobroker.onvif@0.4.4
      npm ERR! missing: urllib@2.36.1, required by iobroker.onvif@0.4.4
      npm ERR! missing: color@3.2.1, required by sharp@0.25.4
      npm ERR! missing: detect-libc@1.0.3, required by sharp@0.25.4
      npm ERR! missing: prebuild-install@5.3.6, required by sharp@0.25.4
      npm ERR! missing: simple-get@4.0.0, required by sharp@0.25.4
      npm ERR! missing: node-addon-api@3.1.0, required by sharp@0.25.4
      npm ERR! missing: npmlog@4.1.2, required by sharp@0.25.4
      npm ERR! missing: semver@7.3.5, required by sharp@0.25.4
      npm ERR! missing: tar@6.1.11, required by sharp@0.25.4
      npm ERR! missing: tunnel-agent@0.6.0, required by sharp@0.25.4
      npm ERR! missing: detect-libc@1.0.3, required by prebuild-install@5.3.6
      npm ERR! missing: expand-template@2.0.3, required by prebuild-install@5.3.6
      npm ERR! missing: github-from-package@0.0.0, required by prebuild-install@5.3.6
      npm ERR! missing: minimist@1.2.5, required by prebuild-install@5.3.6
      npm ERR! missing: mkdirp-classic@0.5.3, required by prebuild-install@5.3.6
      npm ERR! missing: napi-build-utils@1.0.2, required by prebuild-install@5.3.6
      npm ERR! missing: node-abi@2.26.0, required by prebuild-install@5.3.6
      npm ERR! missing: noop-logger@0.1.1, required by prebuild-install@5.3.6
      npm ERR! missing: npmlog@4.1.2, required by prebuild-install@5.3.6
      npm ERR! missing: pump@3.0.0, required by prebuild-install@5.3.6
      npm ERR! missing: rc@1.2.8, required by prebuild-install@5.3.6
      npm ERR! missing: simple-get@3.1.0, required by prebuild-install@5.3.6
      npm ERR! missing: tar-fs@2.1.1, required by prebuild-install@5.3.6
      npm ERR! missing: tunnel-agent@0.6.0, required by prebuild-install@5.3.6
      npm ERR! missing: which-pm-runs@1.0.0, required by prebuild-install@5.3.6
      npm ERR! missing: decompress-response@6.0.0, required by simple-get@4.0.0
      npm ERR! missing: once@1.4.0, required by simple-get@4.0.0
      npm ERR! missing: simple-concat@1.0.1, required by simple-get@4.0.0
      npm ERR! missing: mimic-response@3.1.0, required by decompress-response@6.0.0
      npm ERR! missing: are-we-there-yet@1.1.5, required by npmlog@4.1.2
      npm ERR! missing: console-control-strings@1.1.0, required by npmlog@4.1.2
      npm ERR! missing: gauge@2.7.4, required by npmlog@4.1.2
      npm ERR! missing: set-blocking@2.0.0, required by npmlog@4.1.2
      npm ERR! missing: delegates@1.0.0, required by are-we-there-yet@1.1.5
      npm ERR! missing: readable-stream@2.3.7, required by are-we-there-yet@1.1.5
      npm ERR! missing: aproba@1.2.0, required by gauge@2.7.4
      npm ERR! missing: console-control-strings@1.1.0, required by gauge@2.7.4
      npm ERR! missing: has-unicode@2.0.1, required by gauge@2.7.4
      npm ERR! missing: object-assign@4.1.1, required by gauge@2.7.4
      npm ERR! missing: signal-exit@3.0.3, required by gauge@2.7.4
      npm ERR! missing: string-width@1.0.2, required by gauge@2.7.4
      npm ERR! missing: strip-ansi@3.0.1, required by gauge@2.7.4
      npm ERR! missing: wide-align@1.1.3, required by gauge@2.7.4
      npm ERR! missing: code-point-at@1.1.0, required by string-width@1.0.2
      npm ERR! missing: is-fullwidth-code-point@1.0.0, required by string-width@1.0.2
      npm ERR! missing: strip-ansi@3.0.1, required by string-width@1.0.2
      npm ERR! missing: number-is-nan@1.0.1, required by is-fullwidth-code-point@1.0.0
      npm ERR! missing: ansi-regex@2.1.1, required by strip-ansi@3.0.1
      npm ERR! missing: string-width@1.0.2, required by wide-align@1.1.3
      npm ERR! missing: lodash.get@4.4.2, required by onvif@0.6.4
      npm ERR! missing: xml2js@0.4.23, required by onvif@0.6.4
      npm ERR! missing: any-promise@1.3.0, required by urllib@2.36.1
      npm ERR! missing: content-type@1.0.4, required by urllib@2.36.1
      npm ERR! missing: debug@2.6.9, required by urllib@2.36.1
      npm ERR! missing: default-user-agent@1.0.0, required by urllib@2.36.1
      npm ERR! missing: digest-header@0.0.1, required by urllib@2.36.1
      npm ERR! missing: ee-first@1.1.1, required by urllib@2.36.1
      npm ERR! missing: formstream@1.1.0, required by urllib@2.36.1
      npm ERR! missing: humanize-ms@1.2.1, required by urllib@2.36.1
      npm ERR! missing: iconv-lite@0.4.24, required by urllib@2.36.1
      npm ERR! missing: ip@1.1.5, required by urllib@2.36.1
      npm ERR! missing: proxy-agent@3.1.1, required by urllib@2.36.1
      npm ERR! missing: pump@3.0.0, required by urllib@2.36.1
      npm ERR! missing: qs@6.9.7, required by urllib@2.36.1
      npm ERR! missing: statuses@1.5.0, required by urllib@2.36.1
      npm ERR! missing: utility@1.17.0, required by urllib@2.36.1
      npm ERR! missing: os-name@1.0.3, required by default-user-agent@1.0.0
      npm ERR! missing: osx-release@1.1.0, required by os-name@1.0.3
      npm ERR! missing: win-release@1.1.1, required by os-name@1.0.3
      npm ERR! missing: minimist@1.2.5, required by osx-release@1.1.0
      npm ERR! missing: semver@5.7.1, required by win-release@1.1.1
      npm ERR! missing: utility@0.1.11, required by digest-header@0.0.1
      npm ERR! missing: address@1.1.2, required by utility@0.1.11
      npm ERR! missing: destroy@1.0.4, required by formstream@1.1.0
      npm ERR! missing: mime@1.6.0, required by formstream@1.1.0
      npm ERR! missing: pause-stream@0.0.11, required by formstream@1.1.0
      npm ERR! missing: ms@2.0.0, required by humanize-ms@1.2.1
      npm ERR! missing: http-proxy-agent@2.1.0, required by proxy-agent@3.1.1
      npm ERR! missing: pac-proxy-agent@3.0.1, required by proxy-agent@3.1.1
      npm ERR! missing: agent-base@4.3.0, required by proxy-agent@3.1.1
      npm ERR! missing: debug@4.3.1, required by proxy-agent@3.1.1
      npm ERR! missing: https-proxy-agent@3.0.1, required by proxy-agent@3.1.1
      npm ERR! missing: lru-cache@5.1.1, required by proxy-agent@3.1.1
      npm ERR! missing: proxy-from-env@1.1.0, required by proxy-agent@3.1.1
      npm ERR! missing: socks-proxy-agent@4.0.2, required by proxy-agent@3.1.1
      npm ERR! missing: agent-base@4.3.0, required by http-proxy-agent@2.1.0
      npm ERR! missing: debug@3.1.0, required by http-proxy-agent@2.1.0
      npm ERR! missing: es6-promisify@5.0.0, required by agent-base@4.3.0
      npm ERR! missing: ms@2.0.0, required by debug@3.1.0
      npm ERR! missing: get-uri@2.0.4, required by pac-proxy-agent@3.0.1
      npm ERR! missing: http-proxy-agent@2.1.0, required by pac-proxy-agent@3.0.1
      npm ERR! missing: agent-base@4.3.0, required by pac-proxy-agent@3.0.1
      npm ERR! missing: debug@4.3.1, required by pac-proxy-agent@3.0.1
      npm ERR! missing: https-proxy-agent@3.0.1, required by pac-proxy-agent@3.0.1
      npm ERR! missing: pac-resolver@3.0.0, required by pac-proxy-agent@3.0.1
      npm ERR! missing: raw-body@2.4.3, required by pac-proxy-agent@3.0.1
      npm ERR! missing: socks-proxy-agent@4.0.2, required by pac-proxy-agent@3.0.1
      npm ERR! missing: data-uri-to-buffer@1.2.0, required by get-uri@2.0.4
      npm ERR! missing: debug@2.6.9, required by get-uri@2.0.4
      npm ERR! missing: extend@3.0.2, required by get-uri@2.0.4
      npm ERR! missing: file-uri-to-path@1.0.0, required by get-uri@2.0.4
      npm ERR! missing: ftp@0.3.10, required by get-uri@2.0.4
      npm ERR! missing: readable-stream@2.3.7, required by get-uri@2.0.4
      npm ERR! missing: ms@2.1.2, required by debug@4.3.1
      npm ERR! missing: agent-base@4.3.0, required by https-proxy-agent@3.0.1
      npm ERR! missing: debug@3.2.7, required by https-proxy-agent@3.0.1
      npm ERR! missing: ms@2.1.2, required by debug@3.2.7
      npm ERR! missing: co@4.6.0, required by pac-resolver@3.0.0
      npm ERR! missing: degenerator@1.0.4, required by pac-resolver@3.0.0
      npm ERR! missing: ip@1.1.5, required by pac-resolver@3.0.0
      npm ERR! missing: netmask@1.0.6, required by pac-resolver@3.0.0
      npm ERR! missing: thunkify@2.1.2, required by pac-resolver@3.0.0
      npm ERR! missing: ast-types@0.14.2, required by degenerator@1.0.4
      npm ERR! missing: esprima@3.1.3, required by degenerator@1.0.4
      npm ERR! missing: escodegen@1.14.3, required by degenerator@1.0.4
      npm ERR! missing: tslib@2.1.0, required by ast-types@0.14.2
      npm ERR! missing: esprima@4.0.1, required by escodegen@1.14.3
      npm ERR! missing: estraverse@4.3.0, required by escodegen@1.14.3
      npm ERR! missing: esutils@2.0.3, required by escodegen@1.14.3
      npm ERR! missing: optionator@0.8.3, required by escodegen@1.14.3
      npm ERR! missing: source-map@0.6.1, required by escodegen@1.14.3
      npm ERR! missing: es6-promise@4.2.8, required by es6-promisify@5.0.0
      npm ERR! missing: yallist@3.1.1, required by lru-cache@5.1.1
      npm ERR! missing: socks@2.3.3, required by socks-proxy-agent@4.0.2
      npm ERR! missing: agent-base@4.2.1, required by socks-proxy-agent@4.0.2
      npm ERR! missing: ip@1.1.5, required by socks@2.3.3
      npm ERR! missing: smart-buffer@4.1.0, required by socks@2.3.3
      npm ERR! missing: es6-promisify@5.0.0, required by agent-base@4.2.1
      npm ERR! missing: copy-to@2.0.1, required by utility@1.17.0
      npm ERR! missing: escape-html@1.0.3, required by utility@1.17.0
      npm ERR! missing: mz@2.7.0, required by utility@1.17.0
      npm ERR! missing: unescape@1.0.1, required by utility@1.17.0
      npm ERR! missing: mkdirp@0.5.5, required by utility@1.17.0
      npm ERR! missing: any-promise@1.3.0, required by mz@2.7.0
      npm ERR! missing: object-assign@4.1.1, required by mz@2.7.0
      npm ERR! missing: thenify-all@1.6.0, required by mz@2.7.0
      npm ERR! missing: thenify@3.3.1, required by thenify-all@1.6.0
      npm ERR! missing: any-promise@1.3.0, required by thenify@3.3.1
      npm ERR! missing: extend-shallow@2.0.1, required by unescape@1.0.1
      npm ERR! missing: is-extendable@0.1.1, required by extend-shallow@2.0.1
      npm ERR! missing: minimist@1.2.5, required by mkdirp@0.5.5
      npm ERR! missing: @iobroker/adapter-core@2.6.0, required by iobroker.plenticore@2.2.0
      npm ERR! missing: @strathcole/iob-lib@0.1.4, required by iobroker.plenticore@2.2.0
      npm ERR! missing: suncalc2@1.8.1, required by iobroker.plenticore@2.2.0
      npm ERR! missing: @iobroker/adapter-core@2.6.0, required by iobroker.pollenflug@1.0.6
      npm ERR! missing: node-schedule@1.3.3, required by iobroker.pollenflug@1.0.6
      npm ERR! missing: xml2js@0.4.19, required by iobroker.pollenflug@1.0.6
      npm ERR! missing: xmlbuilder@15.1.1, required by iobroker.pollenflug@1.0.6
      npm ERR! missing: request@2.88.2, required by iobroker.pollenflug@1.0.6
      npm ERR! missing: request-promise-native@1.0.9, required by iobroker.pollenflug@1.0.6
      npm ERR! missing: semver@7.3.5, required by iobroker.pollenflug@1.0.6
      npm ERR! missing: shelly-iot@1.1.2, required by iobroker.pollenflug@1.0.6
      npm ERR! missing: cron-parser@2.18.0, required by node-schedule@1.3.3
      npm ERR! missing: long-timeout@0.1.1, required by node-schedule@1.3.3
      npm ERR! missing: sorted-array-functions@1.3.0, required by node-schedule@1.3.3
      npm ERR! missing: is-nan@1.3.2, required by cron-parser@2.18.0
      npm ERR! missing: moment-timezone@0.5.34, required by cron-parser@2.18.0
      npm ERR! missing: xmlbuilder@9.0.7, required by xml2js@0.4.19
      npm ERR! missing: sax@1.2.4, required by xml2js@0.4.19
      npm ERR! missing: node-rest-client@3.1.1, required by shelly-iot@1.1.2
      npm ERR! missing: coap@0.26.0, required by shelly-iot@1.1.2
      npm ERR! missing: follow-redirects@1.14.9, required by node-rest-client@3.1.1
      npm ERR! missing: debug@4.3.3, required by node-rest-client@3.1.1
      npm ERR! missing: xml2js@0.4.23, required by node-rest-client@3.1.1
      npm ERR! missing: @types/bl@5.0.2, required by coap@0.26.0
      npm ERR! missing: @types/node@16.11.26, required by coap@0.26.0
      npm ERR! missing: capitalize@2.0.3, required by coap@0.26.0
      npm ERR! missing: fastseries@2.0.0, required by coap@0.26.0
      npm ERR! missing: lru-cache@6.0.0, required by coap@0.26.0
      npm ERR! missing: bl@5.0.0, required by coap@0.26.0
      npm ERR! missing: coap-packet@1.1.1, required by coap@0.26.0
      npm ERR! missing: debug@4.3.3, required by coap@0.26.0
      npm ERR! missing: readable-stream@3.6.0, required by coap@0.26.0
      npm ERR! missing: @types/node@16.11.26, required by @types/bl@5.0.2
      npm ERR! missing: @types/readable-stream@2.3.13, required by @types/bl@5.0.2
      npm ERR! missing: @types/node@16.11.26, required by @types/readable-stream@2.3.13
      npm ERR! missing: safe-buffer@5.1.2, required by @types/readable-stream@2.3.13
      npm ERR! missing: inherits@2.0.4, required by bl@5.0.0
      npm ERR! missing: buffer@6.0.3, required by bl@5.0.0
      npm ERR! missing: readable-stream@3.6.0, required by bl@5.0.0
      npm ERR! missing: base64-js@1.5.1, required by buffer@6.0.3
      npm ERR! missing: ieee754@1.2.1, required by buffer@6.0.3
      npm ERR! missing: @iobroker/adapter-core@2.6.0, required by iobroker.proxmox@1.3.4
      npm ERR! missing: request@2.88.2, required by iobroker.proxmox@1.3.4
      npm ERR! missing: @iobroker/adapter-core@2.6.0, required by iobroker.robonect@0.1.4
      npm ERR! missing: json-logic-js@1.2.3, required by iobroker.robonect@0.1.4
      npm ERR! missing: ping@0.2.3, required by iobroker.robonect@0.1.4
      npm ERR! missing: request@2.88.2, required by iobroker.robonect@0.1.4
      npm ERR! missing: q@1.5.1, required by ping@0.2.3
      npm ERR! missing: underscore@1.13.2, required by ping@0.2.3
      npm ERR! missing: @apollon/iobroker-tools@0.2.0, required by iobroker.shelly@5.3.2
      npm ERR! missing: @iobroker/adapter-core@2.6.0, required by iobroker.shelly@5.3.2
      npm ERR! missing: coiot-coap@1.0.0, required by iobroker.shelly@5.3.2
      npm ERR! missing: crypto@1.0.1, required by iobroker.shelly@5.3.2
      npm ERR! missing: axios@0.26.1, required by iobroker.shelly@5.3.2
      npm ERR! missing: mqtt@4.3.6, required by iobroker.shelly@5.3.2
      npm ERR! missing: xmlbuilder@15.1.1, required by iobroker.shelly@5.3.2
      npm ERR! missing: mqtt-connection@4.1.0, required by iobroker.shelly@5.3.2
      npm ERR! missing: shelly-iot@1.1.2, required by iobroker.shelly@5.3.2
      npm ERR! missing: tcp-ping@0.1.1, required by iobroker.shelly@5.3.2
      npm ERR! missing: xml2js@0.4.23, required by iobroker.shelly@5.3.2
      npm ERR! missing: coap@0.24.0, required by coiot-coap@1.0.0
      npm ERR! missing: commander@6.2.1, required by coiot-coap@1.0.0
      npm ERR! missing: bl@4.1.0, required by coap@0.24.0
      npm ERR! missing: capitalize@2.0.3, required by coap@0.24.0
      npm ERR! missing: coap-packet@0.1.14, required by coap@0.24.0
      npm ERR! missing: debug@4.3.2, required by coap@0.24.0
      npm ERR! missing: lru-cache@5.1.1, required by coap@0.24.0
      npm ERR! missing: readable-stream@3.6.0, required by coap@0.24.0
      npm ERR! missing: fastseries@2.0.0, required by coap@0.24.0
      npm ERR! missing: ms@2.1.2, required by debug@4.3.2
      npm ERR! missing: commist@1.1.0, required by mqtt@4.3.6
      npm ERR! missing: help-me@3.0.0, required by mqtt@4.3.6
      npm ERR! missing: inherits@2.0.4, required by mqtt@4.3.6
      npm ERR! missing: concat-stream@2.0.0, required by mqtt@4.3.6
      npm ERR! missing: debug@4.3.3, required by mqtt@4.3.6
      npm ERR! missing: duplexify@4.1.2, required by mqtt@4.3.6
      npm ERR! missing: readable-stream@3.6.0, required by mqtt@4.3.6
      npm ERR! missing: ws@7.5.7, required by mqtt@4.3.6
      npm ERR! missing: lru-cache@6.0.0, required by mqtt@4.3.6
      npm ERR! missing: minimist@1.2.5, required by mqtt@4.3.6
      npm ERR! missing: mqtt-packet@6.9.1, required by mqtt@4.3.6
      npm ERR! missing: number-allocator@1.0.9, required by mqtt@4.3.6
      npm ERR! missing: pump@3.0.0, required by mqtt@4.3.6
      npm ERR! missing: reinterval@1.1.0, required by mqtt@4.3.6
      npm ERR! missing: rfdc@1.3.0, required by mqtt@4.3.6
      npm ERR! missing: split2@3.2.2, required by mqtt@4.3.6
      npm ERR! missing: xtend@4.0.2, required by mqtt@4.3.6
      npm ERR! missing: leven@2.1.0, required by commist@1.1.0
      npm ERR! missing: minimist@1.2.5, required by commist@1.1.0
      npm ERR! missing: glob@7.1.6, required by help-me@3.0.0
      npm ERR! missing: readable-stream@3.6.0, required by help-me@3.0.0
      npm ERR! missing: fs.realpath@1.0.0, required by glob@7.1.6
      npm ERR! missing: inflight@1.0.6, required by glob@7.1.6
      npm ERR! missing: inherits@2.0.4, required by glob@7.1.6
      npm ERR! missing: minimatch@3.0.4, required by glob@7.1.6
      npm ERR! missing: once@1.4.0, required by glob@7.1.6
      npm ERR! missing: path-is-absolute@1.0.1, required by glob@7.1.6
      npm ERR! missing: once@1.4.0, required by inflight@1.0.6
      npm ERR! missing: wrappy@1.0.2, required by inflight@1.0.6
      npm ERR! missing: buffer-from@1.1.1, required by concat-stream@2.0.0
      npm ERR! missing: inherits@2.0.4, required by concat-stream@2.0.0
      npm ERR! missing: readable-stream@3.6.0, required by concat-stream@2.0.0
      npm ERR! missing: typedarray@0.0.6, required by concat-stream@2.0.0
      npm ERR! missing: end-of-stream@1.4.4, required by duplexify@4.1.2
      npm ERR! missing: inherits@2.0.4, required by duplexify@4.1.2
      npm ERR! missing: readable-stream@3.6.0, required by duplexify@4.1.2
      npm ERR! missing: stream-shift@1.0.1, required by duplexify@4.1.2
      npm ERR! missing: bl@4.1.0, required by mqtt-packet@6.9.1
      npm ERR! missing: debug@4.3.1, required by mqtt-packet@6.9.1
      npm ERR! missing: process-nextick-args@2.0.1, required by mqtt-packet@6.9.1
      npm ERR! missing: js-sdsl@2.1.4, required by number-allocator@1.0.9
      npm ERR! missing: debug@4.3.3, required by number-allocator@1.0.9
      npm ERR! missing: readable-stream@3.6.0, required by split2@3.2.2
      npm ERR! missing: duplexify@3.7.1, required by mqtt-connection@4.1.0
      npm ERR! missing: inherits@2.0.4, required by mqtt-connection@4.1.0
      npm ERR! missing: mqtt-packet@6.9.1, required by mqtt-connection@4.1.0
      npm ERR! missing: safe-buffer@5.1.2, required by mqtt-connection@4.1.0
      npm ERR! missing: through2@2.0.5, required by mqtt-connection@4.1.0
      npm ERR! missing: end-of-stream@1.4.4, required by duplexify@3.7.1
      npm ERR! missing: inherits@2.0.4, required by duplexify@3.7.1
      npm ERR! missing: readable-stream@2.3.7, required by duplexify@3.7.1
      npm ERR! missing: stream-shift@1.0.1, required by duplexify@3.7.1
      npm ERR! missing: readable-stream@2.3.7, required by through2@2.0.5
      npm ERR! missing: xtend@4.0.2, required by through2@2.0.5
      npm ERR! missing: sax@1.2.4, required by xml2js@0.4.23
      npm ERR! missing: xmlbuilder@11.0.1, required by xml2js@0.4.23
      npm ERR! missing: @iobroker/adapter-core@2.6.0, required by iobroker.simple-api@2.6.4
      npm ERR! missing: @iobroker/adapter-core@2.6.0, required by iobroker.smartgarden@1.0.5
      npm ERR! missing: @jpgorganizer/utils@1.2.1, required by iobroker.smartgarden@1.0.5
      npm ERR! missing: request@2.88.2, required by iobroker.smartgarden@1.0.5
      npm ERR! missing: ws@7.4.6, required by iobroker.smartgarden@1.0.5
      npm ERR! missing: @iobroker/adapter-core@2.6.0, required by iobroker.socketio@4.2.0
      npm ERR! missing: cookie-parser@1.4.6, required by iobroker.socketio@4.2.0
      npm ERR! missing: express-session@1.17.2, required by iobroker.socketio@4.2.0
      npm ERR! missing: axios@0.26.1, required by iobroker.socketio@4.2.0
      npm ERR! missing: passport@0.5.2, required by iobroker.socketio@4.2.0
      npm ERR! missing: socket.io@2.4.1, required by iobroker.socketio@4.2.0
      npm ERR! missing: engine.io@3.5.0, required by socket.io@2.4.1
      npm ERR! missing: has-binary2@1.0.3, required by socket.io@2.4.1
      npm ERR! missing: socket.io-adapter@1.1.2, required by socket.io@2.4.1
      npm ERR! missing: socket.io-client@2.4.0, required by socket.io@2.4.1
      npm ERR! missing: socket.io-parser@3.4.1, required by socket.io@2.4.1
      npm ERR! missing: debug@4.1.1, required by socket.io@2.4.1
      npm ERR! missing: accepts@1.3.8, required by engine.io@3.5.0
      npm ERR! missing: base64id@2.0.0, required by engine.io@3.5.0
      npm ERR! missing: cookie@0.4.1, required by engine.io@3.5.0
      npm ERR! missing: engine.io-parser@2.2.1, required by engine.io@3.5.0
      npm ERR! missing: debug@4.1.1, required by engine.io@3.5.0
      npm ERR! missing: ws@7.4.6, required by engine.io@3.5.0
      npm ERR! missing: after@0.8.2, required by engine.io-parser@2.2.1
      npm ERR! missing: arraybuffer.slice@0.0.7, required by engine.io-parser@2.2.1
      npm ERR! missing: base64-arraybuffer@0.1.4, required by engine.io-parser@2.2.1
      npm ERR! missing: blob@0.0.5, required by engine.io-parser@2.2.1
      npm ERR! missing: has-binary2@1.0.3, required by engine.io-parser@2.2.1
      npm ERR! missing: ms@2.1.3, required by debug@4.1.1
      npm ERR! missing: isarray@2.0.1, required by has-binary2@1.0.3
      npm ERR! missing: backo2@1.0.2, required by socket.io-client@2.4.0
      npm ERR! missing: component-bind@1.0.0, required by socket.io-client@2.4.0
      npm ERR! missing: component-emitter@1.3.0, required by socket.io-client@2.4.0
      npm ERR! missing: engine.io-client@3.5.0, required by socket.io-client@2.4.0
      npm ERR! missing: has-binary2@1.0.3, required by socket.io-client@2.4.0
      npm ERR! missing: indexof@0.0.1, required by socket.io-client@2.4.0
      npm ERR! missing: parseqs@0.0.6, required by socket.io-client@2.4.0
      npm ERR! missing: parseuri@0.0.6, required by socket.io-client@2.4.0
      npm ERR! missing: debug@3.1.0, required by socket.io-client@2.4.0
      npm ERR! missing: socket.io-parser@3.3.2, required by socket.io-client@2.4.0
      npm ERR! missing: to-array@0.1.4, required by socket.io-client@2.4.0
      npm ERR! missing: component-emitter@1.3.0, required by engine.io-client@3.5.0
      npm ERR! missing: component-inherit@0.0.3, required by engine.io-client@3.5.0
      npm ERR! missing: debug@3.1.0, required by engine.io-client@3.5.0
      npm ERR! missing: engine.io-parser@2.2.1, required by engine.io-client@3.5.0
      npm ERR! missing: has-cors@1.1.0, required by engine.io-client@3.5.0
      npm ERR! missing: indexof@0.0.1, required by engine.io-client@3.5.0
      npm ERR! missing: parseqs@0.0.6, required by engine.io-client@3.5.0
      npm ERR! missing: parseuri@0.0.6, required by engine.io-client@3.5.0
      npm ERR! missing: ws@7.4.6, required by engine.io-client@3.5.0
      npm ERR! missing: xmlhttprequest-ssl@1.5.5, required by engine.io-client@3.5.0
      npm ERR! missing: yeast@0.1.2, required by engine.io-client@3.5.0
      npm ERR! missing: component-emitter@1.3.0, required by socket.io-parser@3.3.2
      npm ERR! missing: debug@3.1.0, required by socket.io-parser@3.3.2
      npm ERR! missing: isarray@2.0.1, required by socket.io-parser@3.3.2
      npm ERR! missing: component-emitter@1.2.1, required by socket.io-parser@3.4.1
      npm ERR! missing: debug@4.1.1, required by socket.io-parser@3.4.1
      npm ERR! missing: isarray@2.0.1, required by socket.io-parser@3.4.1
      npm ERR! missing: @iobroker/adapter-core@2.6.0, required by iobroker.sonoff@2.5.0
      npm ERR! missing: mqtt-connection@4.1.0, required by iobroker.sonoff@2.5.0
      npm ERR! missing: @iobroker/adapter-core@1.0.1, required by iobroker.spotify-premium@1.0.0
      npm ERR! missing: querystring@0.2.0, required by iobroker.spotify-premium@1.0.0
      npm ERR! missing: request@2.83.0, required by iobroker.spotify-premium@1.0.0
      npm ERR! missing: promise@8.0.1, required by iobroker.spotify-premium@1.0.0
      npm ERR! missing: @types/iobroker@1.4.13, required by @iobroker/adapter-core@1.0.1
      npm ERR! missing: @types/node@16.11.26, required by @types/iobroker@1.4.13
      npm ERR! missing: aws-sign2@0.7.0, required by request@2.83.0
      npm ERR! missing: aws4@1.11.0, required by request@2.83.0
      npm ERR! missing: caseless@0.12.0, required by request@2.83.0
      npm ERR! missing: combined-stream@1.0.8, required by request@2.83.0
      npm ERR! missing: extend@3.0.2, required by request@2.83.0
      npm ERR! missing: forever-agent@0.6.1, required by request@2.83.0
      npm ERR! missing: form-data@2.3.3, required by request@2.83.0
      npm ERR! missing: hawk@6.0.2, required by request@2.83.0
      npm ERR! missing: http-signature@1.2.0, required by request@2.83.0
      npm ERR! missing: har-validator@5.0.3, required by request@2.83.0
      npm ERR! missing: oauth-sign@0.8.2, required by request@2.83.0
      npm ERR! missing: qs@6.5.2, required by request@2.83.0
      npm ERR! missing: tough-cookie@2.3.4, required by request@2.83.0
      npm ERR! missing: is-typedarray@1.0.0, required by request@2.83.0
      npm ERR! missing: isstream@0.1.2, required by request@2.83.0
      npm ERR! missing: json-stringify-safe@5.0.1, required by request@2.83.0
      npm ERR! missing: mime-types@2.1.35, required by request@2.83.0
      npm ERR! missing: performance-now@2.1.0, required by request@2.83.0
      npm ERR! missing: safe-buffer@5.1.2, required by request@2.83.0
      npm ERR! missing: stringstream@0.0.6, required by request@2.83.0
      npm ERR! missing: tunnel-agent@0.6.0, required by request@2.83.0
      npm ERR! missing: uuid@3.4.0, required by request@2.83.0
      npm ERR! missing: boom@4.3.1, required by hawk@6.0.2
      npm ERR! missing: cryptiles@3.1.4, required by hawk@6.0.2
      npm ERR! missing: hoek@4.2.1, required by hawk@6.0.2
      npm ERR! missing: sntp@2.1.0, required by hawk@6.0.2
      npm ERR! missing: hoek@4.2.1, required by boom@4.3.1
      npm ERR! missing: boom@5.2.0, required by cryptiles@3.1.4
      npm ERR! missing: hoek@4.2.1, required by boom@5.2.0
      npm ERR! missing: hoek@4.2.1, required by sntp@2.1.0
      npm ERR! missing: har-schema@2.0.0, required by har-validator@5.0.3
      npm ERR! missing: ajv@5.5.2, required by har-validator@5.0.3
      npm ERR! missing: co@4.6.0, required by ajv@5.5.2
      npm ERR! missing: fast-json-stable-stringify@2.1.0, required by ajv@5.5.2
      npm ERR! missing: fast-deep-equal@1.1.0, required by ajv@5.5.2
      npm ERR! missing: json-schema-traverse@0.3.1, required by ajv@5.5.2
      npm ERR! missing: punycode@1.4.1, required by tough-cookie@2.3.4
      npm ERR! missing: asap@2.0.6, required by promise@8.0.1
      npm ERR! missing: @iobroker/adapter-core@2.6.0, required by iobroker.tankerkoenig@2.1.1
      npm ERR! missing: request@2.88.2, required by iobroker.tankerkoenig@2.1.1
      npm ERR! missing: xml2js@0.4.23, required by iobroker.tankerkoenig@2.1.1
      npm ERR! missing: @iobroker/adapter-core@2.6.0, required by iobroker.telegram@1.12.2
      npm ERR! missing: axios@0.26.1, required by iobroker.telegram@1.12.2
      npm ERR! missing: node-telegram-bot-api@0.56.0, required by iobroker.telegram@1.12.2
      npm ERR! missing: array.prototype.findindex@2.1.0, required by node-telegram-bot-api@0.56.0
      npm ERR! missing: bluebird@3.7.2, required by node-telegram-bot-api@0.56.0
      npm ERR! missing: depd@1.1.2, required by node-telegram-bot-api@0.56.0
      npm ERR! missing: file-type@3.9.0, required by node-telegram-bot-api@0.56.0
      npm ERR! missing: bl@1.2.3, required by node-telegram-bot-api@0.56.0
      npm ERR! missing: debug@3.2.7, required by node-telegram-bot-api@0.56.0
      npm ERR! missing: eventemitter3@3.1.2, required by node-telegram-bot-api@0.56.0
      npm ERR! missing: mime@1.6.0, required by node-telegram-bot-api@0.56.0
      npm ERR! missing: pump@2.0.1, required by node-telegram-bot-api@0.56.0
      npm ERR! missing: request@2.88.2, required by node-telegram-bot-api@0.56.0
      npm ERR! missing: request-promise@4.2.6, required by node-telegram-bot-api@0.56.0
      npm ERR! missing: define-properties@1.1.3, required by array.prototype.findindex@2.1.0
      npm ERR! missing: es-abstract@1.19.1, required by array.prototype.findindex@2.1.0
      npm ERR! missing: object-keys@1.1.1, required by define-properties@1.1.3
      npm ERR! missing: call-bind@1.0.2, required by es-abstract@1.19.1
      npm ERR! missing: es-to-primitive@1.2.1, required by es-abstract@1.19.1
      npm ERR! missing: function-bind@1.1.1, required by es-abstract@1.19.1
      npm ERR! missing: get-intrinsic@1.1.1, required by es-abstract@1.19.1
      npm ERR! missing: get-symbol-description@1.0.0, required by es-abstract@1.19.1
      npm ERR! missing: has@1.0.3, required by es-abstract@1.19.1
      npm ERR! missing: has-symbols@1.0.2, required by es-abstract@1.19.1
      npm ERR! missing: internal-slot@1.0.3, required by es-abstract@1.19.1
      npm ERR! missing: is-callable@1.2.4, required by es-abstract@1.19.1
      npm ERR! missing: is-negative-zero@2.0.2, required by es-abstract@1.19.1
      npm ERR! missing: is-regex@1.1.4, required by es-abstract@1.19.1
      npm ERR! missing: is-shared-array-buffer@1.0.1, required by es-abstract@1.19.1
      npm ERR! missing: is-string@1.0.7, required by es-abstract@1.19.1
      npm ERR! missing: is-weakref@1.0.2, required by es-abstract@1.19.1
      npm ERR! missing: object-inspect@1.12.0, required by es-abstract@1.19.1
      npm ERR! missing: object-keys@1.1.1, required by es-abstract@1.19.1
      npm ERR! missing: object.assign@4.1.2, required by es-abstract@1.19.1
      npm ERR! missing: string.prototype.trimend@1.0.4, required by es-abstract@1.19.1
      npm ERR! missing: string.prototype.trimstart@1.0.4, required by es-abstract@1.19.1
      npm ERR! missing: unbox-primitive@1.0.1, required by es-abstract@1.19.1
      npm ERR! missing: is-callable@1.2.4, required by es-to-primitive@1.2.1
      npm ERR! missing: is-date-object@1.0.4, required by es-to-primitive@1.2.1
      npm ERR! missing: is-symbol@1.0.4, required by es-to-primitive@1.2.1
      npm ERR! missing: has-symbols@1.0.2, required by is-symbol@1.0.4
      npm ERR! missing: function-bind@1.1.1, required by get-intrinsic@1.1.1
      npm ERR! missing: has@1.0.3, required by get-intrinsic@1.1.1
      npm ERR! missing: has-symbols@1.0.2, required by get-intrinsic@1.1.1
      npm ERR! missing: call-bind@1.0.2, required by get-symbol-description@1.0.0
      npm ERR! missing: get-intrinsic@1.1.1, required by get-symbol-description@1.0.0
      npm ERR! missing: get-intrinsic@1.1.1, required by internal-slot@1.0.3
      npm ERR! missing: has@1.0.3, required by internal-slot@1.0.3
      npm ERR! missing: side-channel@1.0.4, required by internal-slot@1.0.3
      npm ERR! missing: call-bind@1.0.2, required by side-channel@1.0.4
      npm ERR! missing: get-intrinsic@1.1.1, required by side-channel@1.0.4
      npm ERR! missing: object-inspect@1.12.0, required by side-channel@1.0.4
      npm ERR! missing: has-tostringtag@1.0.0, required by is-string@1.0.7
      npm ERR! missing: call-bind@1.0.2, required by is-weakref@1.0.2
      npm ERR! missing: call-bind@1.0.2, required by object.assign@4.1.2
      npm ERR! missing: define-properties@1.1.3, required by object.assign@4.1.2
      npm ERR! missing: has-symbols@1.0.2, required by object.assign@4.1.2
      npm ERR! missing: object-keys@1.1.1, required by object.assign@4.1.2
      npm ERR! missing: call-bind@1.0.2, required by string.prototype.trimend@1.0.4
      npm ERR! missing: define-properties@1.1.3, required by string.prototype.trimend@1.0.4
      npm ERR! missing: call-bind@1.0.2, required by string.prototype.trimstart@1.0.4
      npm ERR! missing: define-properties@1.1.3, required by string.prototype.trimstart@1.0.4
      npm ERR! missing: function-bind@1.1.1, required by unbox-primitive@1.0.1
      npm ERR! missing: has-bigints@1.0.1, required by unbox-primitive@1.0.1
      npm ERR! missing: has-symbols@1.0.2, required by unbox-primitive@1.0.1
      npm ERR! missing: which-boxed-primitive@1.0.2, required by unbox-primitive@1.0.1
      npm ERR! missing: is-bigint@1.0.4, required by which-boxed-primitive@1.0.2
      npm ERR! missing: is-boolean-object@1.1.2, required by which-boxed-primitive@1.0.2
      npm ERR! missing: is-number-object@1.0.6, required by which-boxed-primitive@1.0.2
      npm ERR! missing: is-string@1.0.7, required by which-boxed-primitive@1.0.2
      npm ERR! missing: is-symbol@1.0.4, required by which-boxed-primitive@1.0.2
      npm ERR! missing: has-bigints@1.0.1, required by is-bigint@1.0.4
      npm ERR! missing: call-bind@1.0.2, required by is-boolean-object@1.1.2
      npm ERR! missing: has-tostringtag@1.0.0, required by is-boolean-object@1.1.2
      npm ERR! missing: has-tostringtag@1.0.0, required by is-number-object@1.0.6
      npm ERR! missing: readable-stream@2.3.7, required by bl@1.2.3
      npm ERR! missing: safe-buffer@5.1.2, required by bl@1.2.3
      npm ERR! missing: ms@2.1.3, required by debug@3.2.7
      npm ERR! missing: end-of-stream@1.4.4, required by pump@2.0.1
      npm ERR! missing: once@1.4.0, required by pump@2.0.1
      npm ERR! missing: bluebird@3.7.2, required by request-promise@4.2.6
      npm ERR! missing: request-promise-core@1.1.4, required by request-promise@4.2.6
      npm ERR! missing: stealthy-require@1.1.1, required by request-promise@4.2.6
      npm ERR! missing: tough-cookie@2.5.0, required by request-promise@4.2.6
      npm ERR! missing: cli@0.4.x, required by ipv6@3.1.1
      npm ERR! missing: cliff@0.1.x, required by ipv6@3.1.1
      npm ERR! missing: @iobroker/adapter-core@2.6.0, required by iobroker.trashschedule@1.4.5
      npm ERR! missing: @iobroker/adapter-core@2.6.0, required by iobroker.vis@1.4.15
      npm ERR! missing: axios@0.26.1, required by iobroker.vis@1.4.15
      npm ERR! missing: jsonwebtoken@8.5.1, required by iobroker.vis@1.4.15
      npm ERR! missing: @iobroker/adapter-core@2.6.0, required by iobroker.vis-colorpicker@1.2.0
      npm ERR! missing: @iobroker/adapter-core@1.0.3, required by iobroker.vis-history@1.0.0
      npm ERR! missing: @types/iobroker@1.4.13, required by @iobroker/adapter-core@1.0.3
      npm ERR! missing: @iobroker/adapter-core@2.6.0, required by iobroker.vis-icontwo@0.87.0
      npm ERR! missing: minimist@1.2.5, required by iobroker.vis-icontwo@0.87.0
      npm ERR! missing: np@7.5.0, required by iobroker.vis-icontwo@0.87.0
      npm ERR! missing: @samverschueren/stream-to-observable@0.3.1, required by np@7.5.0
      npm ERR! missing: any-observable@0.5.1, required by np@7.5.0
      npm ERR! missing: async-exit-hook@2.0.1, required by np@7.5.0
      npm ERR! missing: chalk@4.1.2, required by np@7.5.0
      npm ERR! missing: cosmiconfig@7.0.1, required by np@7.5.0
      npm ERR! missing: del@6.0.0, required by np@7.5.0
      npm ERR! missing: escape-goat@3.0.0, required by np@7.5.0
      npm ERR! missing: escape-string-regexp@4.0.0, required by np@7.5.0
      npm ERR! missing: execa@5.1.1, required by np@7.5.0
      npm ERR! missing: github-url-from-git@1.5.0, required by np@7.5.0
      npm ERR! missing: has-yarn@2.1.0, required by np@7.5.0
      npm ERR! missing: hosted-git-info@3.0.8, required by np@7.5.0
      npm ERR! missing: ignore-walk@3.0.4, required by np@7.5.0
      npm ERR! missing: import-local@3.0.3, required by np@7.5.0
      npm ERR! missing: inquirer@7.3.3, required by np@7.5.0
      npm ERR! missing: is-installed-globally@0.3.2, required by np@7.5.0
      npm ERR! missing: is-interactive@1.0.0, required by np@7.5.0
      npm ERR! missing: is-scoped@2.1.0, required by np@7.5.0
      npm ERR! missing: issue-regex@3.1.0, required by np@7.5.0
      npm ERR! missing: listr@0.14.3, required by np@7.5.0
      npm ERR! missing: listr-input@0.2.1, required by np@7.5.0
      npm ERR! missing: log-symbols@4.1.0, required by np@7.5.0
      npm ERR! missing: meow@8.1.2, required by np@7.5.0
      npm ERR! missing: minimatch@3.0.4, required by np@7.5.0
      npm ERR! missing: new-github-release-url@1.0.0, required by np@7.5.0
      npm ERR! missing: npm-name@6.0.1, required by np@7.5.0
      npm ERR! missing: onetime@5.1.2, required by np@7.5.0
      npm ERR! missing: open@7.4.2, required by np@7.5.0
      npm ERR! missing: ow@0.21.0, required by np@7.5.0
      npm ERR! missing: p-memoize@4.0.2, required by np@7.5.0
      npm ERR! missing: p-timeout@4.1.0, required by np@7.5.0
      npm ERR! missing: pkg-dir@5.0.0, required by np@7.5.0
      npm ERR! missing: read-pkg-up@7.0.1, required by np@7.5.0
      npm ERR! missing: rxjs@6.6.7, required by np@7.5.0
      npm ERR! missing: semver@7.3.5, required by np@7.5.0
      npm ERR! missing: split@1.0.1, required by np@7.5.0
      npm ERR! missing: symbol-observable@3.0.0, required by np@7.5.0
      npm ERR! missing: terminal-link@2.1.1, required by np@7.5.0
      npm ERR! missing: update-notifier@5.1.0, required by np@7.5.0
      npm ERR! missing: any-observable@0.3.0, required by @samverschueren/stream-to-observable@0.3.1
      npm ERR! missing: ansi-styles@4.3.0, required by chalk@4.1.2
      npm ERR! missing: supports-color@7.2.0, required by chalk@4.1.2
      npm ERR! missing: color-convert@2.0.1, required by ansi-styles@4.3.0
      npm ERR! missing: color-name@1.1.4, required by color-convert@2.0.1
      npm ERR! missing: has-flag@4.0.0, required by supports-color@7.2.0
      npm ERR! missing: @types/parse-json@4.0.0, required by cosmiconfig@7.0.1
      npm ERR! missing: import-fresh@3.3.0, required by cosmiconfig@7.0.1
      npm ERR! missing: parse-json@5.2.0, required by cosmiconfig@7.0.1
      npm ERR! missing: path-type@4.0.0, required by cosmiconfig@7.0.1
      npm ERR! missing: yaml@1.10.2, required by cosmiconfig@7.0.1
      npm ERR! missing: parent-module@1.0.1, required by import-fresh@3.3.0
      npm ERR! missing: resolve-from@4.0.0, required by import-fresh@3.3.0
      npm ERR! missing: callsites@3.1.0, required by parent-module@1.0.1
      npm ERR! missing: @babel/code-frame@7.15.8, required by parse-json@5.2.0
      npm ERR! missing: error-ex@1.3.2, required by parse-json@5.2.0
      npm ERR! missing: json-parse-even-better-errors@2.3.1, required by parse-json@5.2.0
      npm ERR! missing: lines-and-columns@1.1.6, required by parse-json@5.2.0
      npm ERR! missing: @babel/highlight@7.14.5, required by @babel/code-frame@7.15.8
      npm ERR! missing: @babel/helper-validator-identifier@7.15.7, required by @babel/highlight@7.14.5
      npm ERR! missing: chalk@2.4.2, required by @babel/highlight@7.14.5
      npm ERR! missing: js-tokens@4.0.0, required by @babel/highlight@7.14.5
      npm ERR! missing: ansi-styles@3.2.1, required by chalk@2.4.2
      npm ERR! missing: escape-string-regexp@1.0.5, required by chalk@2.4.2
      npm ERR! missing: supports-color@5.5.0, required by chalk@2.4.2
      npm ERR! missing: color-convert@1.9.3, required by ansi-styles@3.2.1
      npm ERR! missing: has-flag@3.0.0, required by supports-color@5.5.0
      npm ERR! missing: is-arrayish@0.2.1, required by error-ex@1.3.2
      npm ERR! missing: p-map@4.0.0, required by del@6.0.0
      npm ERR! missing: rimraf@3.0.2, required by del@6.0.0
      npm ERR! missing: globby@11.0.4, required by del@6.0.0
      npm ERR! missing: graceful-fs@4.2.6, required by del@6.0.0
      npm ERR! missing: is-glob@4.0.1, required by del@6.0.0
      npm ERR! missing: is-path-cwd@2.2.0, required by del@6.0.0
      npm ERR! missing: is-path-inside@3.0.3, required by del@6.0.0
      npm ERR! missing: slash@3.0.0, required by del@6.0.0
      npm ERR! missing: aggregate-error@3.1.0, required by p-map@4.0.0
      npm ERR! missing: indent-string@4.0.0, required by aggregate-error@3.1.0
      npm ERR! missing: clean-stack@2.2.0, required by aggregate-error@3.1.0
      npm ERR! missing: glob@7.1.6, required by rimraf@3.0.2
      npm ERR! missing: array-union@2.1.0, required by globby@11.0.4
      npm ERR! missing: dir-glob@3.0.1, required by globby@11.0.4
      npm ERR! missing: fast-glob@3.2.7, required by globby@11.0.4
      npm ERR! missing: ignore@5.1.8, required by globby@11.0.4
      npm ERR! missing: merge2@1.4.1, required by globby@11.0.4
      npm ERR! missing: slash@3.0.0, required by globby@11.0.4
      npm ERR! missing: path-type@4.0.0, required by dir-glob@3.0.1
      npm ERR! missing: @nodelib/fs.stat@2.0.5, required by fast-glob@3.2.7
      npm ERR! missing: @nodelib/fs.walk@1.2.8, required by fast-glob@3.2.7
      npm ERR! missing: glob-parent@5.1.2, required by fast-glob@3.2.7
      npm ERR! missing: merge2@1.4.1, required by fast-glob@3.2.7
      npm ERR! missing: micromatch@4.0.4, required by fast-glob@3.2.7
      npm ERR! missing: @nodelib/fs.scandir@2.1.5, required by @nodelib/fs.walk@1.2.8
      npm ERR! missing: fastq@1.13.0, required by @nodelib/fs.walk@1.2.8
      npm ERR! missing: @nodelib/fs.stat@2.0.5, required by @nodelib/fs.scandir@2.1.5
      npm ERR! missing: run-parallel@1.2.0, required by @nodelib/fs.scandir@2.1.5
      npm ERR! missing: queue-microtask@1.2.3, required by run-parallel@1.2.0
      npm ERR! missing: reusify@1.0.4, required by fastq@1.13.0
      npm ERR! missing: cross-spawn@7.0.3, required by execa@5.1.1
      npm ERR! missing: get-stream@6.0.1, required by execa@5.1.1
      npm ERR! missing: human-signals@2.1.0, required by execa@5.1.1
      npm ERR! missing: is-stream@2.0.0, required by execa@5.1.1
      npm ERR! missing: merge-stream@2.0.0, required by execa@5.1.1
      npm ERR! missing: npm-run-path@4.0.1, required by execa@5.1.1
      npm ERR! missing: onetime@5.1.2, required by execa@5.1.1
      npm ERR! missing: signal-exit@3.0.3, required by execa@5.1.1
      npm ERR! missing: strip-final-newline@2.0.0, required by execa@5.1.1
      npm ERR! missing: path-key@3.1.1, required by cross-spawn@7.0.3
      npm ERR! missing: shebang-command@2.0.0, required by cross-spawn@7.0.3
      npm ERR! missing: which@2.0.2, required by cross-spawn@7.0.3
      npm ERR! missing: shebang-regex@3.0.0, required by shebang-command@2.0.0
      npm ERR! missing: isexe@2.0.0, required by which@2.0.2
      npm ERR! missing: path-key@3.1.1, required by npm-run-path@4.0.1
      npm ERR! missing: lru-cache@6.0.0, required by hosted-git-info@3.0.8
      npm ERR! missing: minimatch@3.0.4, required by ignore-walk@3.0.4
      npm ERR! missing: pkg-dir@4.2.0, required by import-local@3.0.3
      npm ERR! missing: resolve-cwd@3.0.0, required by import-local@3.0.3
      npm ERR! missing: find-up@4.1.0, required by pkg-dir@4.2.0
      npm ERR! missing: locate-path@5.0.0, required by find-up@4.1.0
      npm ERR! missing: path-exists@4.0.0, required by find-up@4.1.0
      npm ERR! missing: p-locate@4.1.0, required by locate-path@5.0.0
      npm ERR! missing: p-limit@2.3.0, required by p-locate@4.1.0
      npm ERR! missing: p-try@2.2.0, required by p-limit@2.3.0
      npm ERR! missing: resolve-from@5.0.0, required by resolve-cwd@3.0.0
      npm ERR! missing: ansi-escapes@4.3.2, required by inquirer@7.3.3
      npm ERR! missing: chalk@4.1.2, required by inquirer@7.3.3
      npm ERR! missing: cli-cursor@3.1.0, required by inquirer@7.3.3
      npm ERR! missing: cli-width@3.0.0, required by inquirer@7.3.3
      npm ERR! missing: external-editor@3.1.0, required by inquirer@7.3.3
      npm ERR! missing: figures@3.2.0, required by inquirer@7.3.3
      npm ERR! missing: string-width@4.2.3, required by inquirer@7.3.3
      npm ERR! missing: strip-ansi@6.0.1, required by inquirer@7.3.3
      npm ERR! missing: lodash@4.17.20, required by inquirer@7.3.3
      npm ERR! missing: mute-stream@0.0.8, required by inquirer@7.3.3
      npm ERR! missing: run-async@2.4.1, required by inquirer@7.3.3
      npm ERR! missing: rxjs@6.6.7, required by inquirer@7.3.3
      npm ERR! missing: through@2.3.8, required by inquirer@7.3.3
      npm ERR! missing: type-fest@0.21.3, required by ansi-escapes@4.3.2
      npm ERR! missing: restore-cursor@3.1.0, required by cli-cursor@3.1.0
      npm ERR! missing: onetime@5.1.2, required by restore-cursor@3.1.0
      npm ERR! missing: signal-exit@3.0.3, required by restore-cursor@3.1.0
      npm ERR! missing: chardet@0.7.0, required by external-editor@3.1.0
      npm ERR! missing: iconv-lite@0.4.24, required by external-editor@3.1.0
      npm ERR! missing: tmp@0.0.33, required by external-editor@3.1.0
      npm ERR! missing: os-tmpdir@1.0.2, required by tmp@0.0.33
      npm ERR! missing: escape-string-regexp@1.0.5, required by figures@3.2.0
      npm ERR! missing: global-dirs@2.1.0, required by is-installed-globally@0.3.2
      npm ERR! missing: is-path-inside@3.0.3, required by is-installed-globally@0.3.2
      npm ERR! missing: ini@1.3.7, required by global-dirs@2.1.0
      npm ERR! missing: scoped-regex@2.1.0, required by is-scoped@2.1.0
      npm ERR! missing: @samverschueren/stream-to-observable@0.3.1, required by listr@0.14.3
      npm ERR! missing: is-observable@1.1.0, required by listr@0.14.3
      npm ERR! missing: is-promise@2.2.2, required by listr@0.14.3
      npm ERR! missing: listr-silent-renderer@1.1.1, required by listr@0.14.3
      npm ERR! missing: listr-update-renderer@0.5.0, required by listr@0.14.3
      npm ERR! missing: listr-verbose-renderer@0.5.0, required by listr@0.14.3
      npm ERR! missing: is-stream@1.1.0, required by listr@0.14.3
      npm ERR! missing: p-map@2.1.0, required by listr@0.14.3
      npm ERR! missing: rxjs@6.6.7, required by listr@0.14.3
      npm ERR! missing: symbol-observable@1.2.0, required by is-observable@1.1.0
      npm ERR! missing: cli-truncate@0.2.1, required by listr-update-renderer@0.5.0
      npm ERR! missing: elegant-spinner@1.0.1, required by listr-update-renderer@0.5.0
      npm ERR! missing: indent-string@3.2.0, required by listr-update-renderer@0.5.0
      npm ERR! missing: chalk@1.1.3, required by listr-update-renderer@0.5.0
      npm ERR! missing: figures@1.7.0, required by listr-update-renderer@0.5.0
      npm ERR! missing: log-symbols@1.0.2, required by listr-update-renderer@0.5.0
      npm ERR! missing: log-update@2.3.0, required by listr-update-renderer@0.5.0
      npm ERR! missing: strip-ansi@3.0.1, required by listr-update-renderer@0.5.0
      npm ERR! missing: slice-ansi@0.0.4, required by cli-truncate@0.2.1
      npm ERR! missing: string-width@1.0.2, required by cli-truncate@0.2.1
      npm ERR! missing: has-ansi@2.0.0, required by chalk@1.1.3
      npm ERR! missing: ansi-styles@2.2.1, required by chalk@1.1.3
      npm ERR! missing: escape-string-regexp@1.0.5, required by chalk@1.1.3
      npm ERR! missing: supports-color@2.0.0, required by chalk@1.1.3
      npm ERR! missing: strip-ansi@3.0.1, required by chalk@1.1.3
      npm ERR! missing: ansi-regex@2.1.1, required by has-ansi@2.0.0
      npm ERR! missing: escape-string-regexp@1.0.5, required by figures@1.7.0
      npm ERR! missing: object-assign@4.1.1, required by figures@1.7.0
      npm ERR! missing: chalk@1.1.3, required by log-symbols@1.0.2
      npm ERR! missing: ansi-escapes@3.2.0, required by log-update@2.3.0
      npm ERR! missing: cli-cursor@2.1.0, required by log-update@2.3.0
      npm ERR! missing: wrap-ansi@3.0.1, required by log-update@2.3.0
      npm ERR! missing: restore-cursor@2.0.0, required by cli-cursor@2.1.0
      npm ERR! missing: onetime@2.0.1, required by restore-cursor@2.0.0
      npm ERR! missing: signal-exit@3.0.3, required by restore-cursor@2.0.0
      npm ERR! missing: mimic-fn@1.2.0, required by onetime@2.0.1
      npm ERR! missing: string-width@2.1.1, required by wrap-ansi@3.0.1
      npm ERR! missing: strip-ansi@4.0.0, required by wrap-ansi@3.0.1
      npm ERR! missing: is-fullwidth-code-point@2.0.0, required by string-width@2.1.1
      npm ERR! missing: strip-ansi@4.0.0, required by string-width@2.1.1
      npm ERR! missing: ansi-regex@3.0.0, required by strip-ansi@4.0.0
      npm ERR! missing: date-fns@1.30.1, required by listr-verbose-renderer@0.5.0
      npm ERR! missing: chalk@2.4.2, required by listr-verbose-renderer@0.5.0
      npm ERR! missing: cli-cursor@2.1.0, required by listr-verbose-renderer@0.5.0
      npm ERR! missing: figures@2.0.0, required by listr-verbose-renderer@0.5.0
      npm ERR! missing: escape-string-regexp@1.0.5, required by figures@2.0.0
      npm ERR! missing: inquirer@7.3.3, required by listr-input@0.2.1
      npm ERR! missing: inquirer-autosubmit-prompt@0.2.0, required by listr-input@0.2.1
      npm ERR! missing: rxjs@6.6.7, required by listr-input@0.2.1
      npm ERR! missing: through@2.3.8, required by listr-input@0.2.1
      npm ERR! missing: chalk@2.4.2, required by inquirer-autosubmit-prompt@0.2.0
      npm ERR! missing: inquirer@6.5.2, required by inquirer-autosubmit-prompt@0.2.0
      npm ERR! missing: rxjs@6.6.7, required by inquirer-autosubmit-prompt@0.2.0
      npm ERR! missing: external-editor@3.1.0, required by inquirer@6.5.2
      npm ERR! missing: ansi-escapes@3.2.0, required by inquirer@6.5.2
      npm ERR! missing: chalk@2.4.2, required by inquirer@6.5.2
      npm ERR! missing: cli-cursor@2.1.0, required by inquirer@6.5.2
      npm ERR! missing: cli-width@2.2.1, required by inquirer@6.5.2
      npm ERR! missing: figures@2.0.0, required by inquirer@6.5.2
      npm ERR! missing: mute-stream@0.0.7, required by inquirer@6.5.2
      npm ERR! missing: string-width@2.1.1, required by inquirer@6.5.2
      npm ERR! missing: strip-ansi@5.2.0, required by inquirer@6.5.2
      npm ERR! missing: lodash@4.17.20, required by inquirer@6.5.2
      npm ERR! missing: run-async@2.4.1, required by inquirer@6.5.2
      npm ERR! missing: rxjs@6.6.7, required by inquirer@6.5.2
      npm ERR! missing: through@2.3.8, required by inquirer@6.5.2
      npm ERR! missing: ansi-regex@4.1.0, required by strip-ansi@5.2.0
      npm ERR! missing: chalk@4.1.2, required by log-symbols@4.1.0
      npm ERR! missing: is-unicode-supported@0.1.0, required by log-symbols@4.1.0
      npm ERR! missing: @types/minimist@1.2.2, required by meow@8.1.2
      npm ERR! missing: camelcase-keys@6.2.2, required by meow@8.1.2
      npm ERR! missing: decamelize-keys@1.1.0, required by meow@8.1.2
      npm ERR! missing: hard-rejection@2.1.0, required by meow@8.1.2
      npm ERR! missing: type-fest@0.18.1, required by meow@8.1.2
      npm ERR! missing: minimist-options@4.1.0, required by meow@8.1.2
      npm ERR! missing: normalize-package-data@3.0.3, required by meow@8.1.2
      npm ERR! missing: read-pkg-up@7.0.1, required by meow@8.1.2
      npm ERR! missing: redent@3.0.0, required by meow@8.1.2
      npm ERR! missing: trim-newlines@3.0.1, required by meow@8.1.2
      npm ERR! missing: yargs-parser@20.2.5, required by meow@8.1.2
      npm ERR! missing: camelcase@5.3.1, required by camelcase-keys@6.2.2
      npm ERR! missing: map-obj@4.3.0, required by camelcase-keys@6.2.2
      npm ERR! missing: quick-lru@4.0.1, required by camelcase-keys@6.2.2
      npm ERR! missing: decamelize@1.2.0, required by decamelize-keys@1.1.0
      npm ERR! missing: map-obj@1.0.1, required by decamelize-keys@1.1.0
      npm ERR! missing: kind-of@6.0.3, required by minimist-options@4.1.0
      npm ERR! missing: arrify@1.0.1, required by minimist-options@4.1.0
      npm ERR! missing: is-plain-obj@1.1.0, required by minimist-options@4.1.0
      npm ERR! missing: is-core-module@2.7.0, required by normalize-package-data@3.0.3
      npm ERR! missing: hosted-git-info@4.0.2, required by normalize-package-data@3.0.3
      npm ERR! missing: semver@7.3.5, required by normalize-package-data@3.0.3
      npm ERR! missing: validate-npm-package-license@3.0.4, required by normalize-package-data@3.0.3
      npm ERR! missing: has@1.0.3, required by is-core-module@2.7.0
      npm ERR! missing: lru-cache@6.0.0, required by hosted-git-info@4.0.2
      npm ERR! missing: spdx-correct@3.1.1, required by validate-npm-package-license@3.0.4
      npm ERR! missing: spdx-expression-parse@3.0.1, required by validate-npm-package-license@3.0.4
      npm ERR! missing: spdx-expression-parse@3.0.1, required by spdx-correct@3.1.1
      npm ERR! missing: spdx-license-ids@3.0.10, required by spdx-correct@3.1.1
      npm ERR! missing: spdx-exceptions@2.3.0, required by spdx-expression-parse@3.0.1
      npm ERR! missing: spdx-license-ids@3.0.10, required by spdx-expression-parse@3.0.1
      npm ERR! missing: indent-string@4.0.0, required by redent@3.0.0
      npm ERR! missing: strip-indent@3.0.0, required by redent@3.0.0
      npm ERR! missing: min-indent@1.0.1, required by strip-indent@3.0.0
      npm ERR! missing: type-fest@0.4.1, required by new-github-release-url@1.0.0
      npm ERR! missing: got@10.7.0, required by npm-name@6.0.1
      npm ERR! missing: is-scoped@2.1.0, required by npm-name@6.0.1
      npm ERR! missing: is-url-superb@4.0.0, required by npm-name@6.0.1
      npm ERR! missing: lodash.zip@4.2.0, required by npm-name@6.0.1
      npm ERR! missing: p-map@3.0.0, required by npm-name@6.0.1
      npm ERR! missing: org-regex@1.0.0, required by npm-name@6.0.1
      npm ERR! missing: registry-auth-token@4.2.1, required by npm-name@6.0.1
      npm ERR! missing: registry-url@5.1.0, required by npm-name@6.0.1
      npm ERR! missing: validate-npm-package-name@3.0.0, required by npm-name@6.0.1
      npm ERR! missing: @sindresorhus/is@2.1.1, required by got@10.7.0
      npm ERR! missing: @szmarczak/http-timer@4.0.6, required by got@10.7.0
      npm ERR! missing: @types/cacheable-request@6.0.2, required by got@10.7.0
      npm ERR! missing: cacheable-lookup@2.0.1, required by got@10.7.0
      @andrebu
      Da ist der komplette Dependency Tree kaputt.
      Da hab ich aber auch keine gescheite Idee, wie man das wieder gerade zupfen kann.
      • A andrebu
        @homoran ja aus einem mir nicht nachvollziehbaren Grund war 7 drauf. Ich weiß das die ungraden Entwicklerversionen sind. Echt keine Ahnung wie das passiert ist. Ist aber inzwischen auf 6 geändert.
        @andrebu sagte in Kann keine Adapter mehr installieren:
        aber die package-lock.json ist noch für npm v7.
        Dann musst du diese löschen
          @andrebu
          Bitte komplette Ein- und Ausgaben posten, damit man sieht welcher Befehl da wo eingegeben wurde.
          Versuch mal
          iobroker add denon --host ioBkoker202
          cd /opt/iobroker
          npm ls | grep ERR
          (Ist der Hostname richtig mit dem vermeintlichen Schreibfehler?)
          andrebu
          und hier der 3te Teil des LOG
          npm ERR! missing: cacheable-request@7.0.2, required by got@10.7.0
          npm ERR! missing: duplexer3@0.1.4, required by got@10.7.0
          npm ERR! missing: decompress-response@5.0.0, required by got@10.7.0
          npm ERR! missing: get-stream@5.2.0, required by got@10.7.0
          npm ERR! missing: type-fest@0.10.0, required by got@10.7.0
          npm ERR! missing: lowercase-keys@2.0.0, required by got@10.7.0
          npm ERR! missing: mimic-response@2.1.0, required by got@10.7.0
          npm ERR! missing: p-cancelable@2.1.1, required by got@10.7.0
          npm ERR! missing: p-event@4.2.0, required by got@10.7.0
          npm ERR! missing: responselike@2.0.0, required by got@10.7.0
          npm ERR! missing: to-readable-stream@2.1.0, required by got@10.7.0
          npm ERR! missing: defer-to-connect@2.0.1, required by @szmarczak/http-timer@4.0.6
          npm ERR! missing: @types/http-cache-semantics@4.0.1, required by @types/cacheable-request@6.0.2
          npm ERR! missing: @types/keyv@3.1.3, required by @types/cacheable-request@6.0.2
          npm ERR! missing: @types/node@16.11.26, required by @types/cacheable-request@6.0.2
          npm ERR! missing: @types/responselike@1.0.0, required by @types/cacheable-request@6.0.2
          npm ERR! missing: @types/node@16.11.26, required by @types/keyv@3.1.3
          npm ERR! missing: @types/node@16.11.26, required by @types/responselike@1.0.0
          npm ERR! missing: @types/keyv@3.1.3, required by cacheable-lookup@2.0.1
          npm ERR! missing: keyv@4.0.3, required by cacheable-lookup@2.0.1
          npm ERR! missing: json-buffer@3.0.1, required by keyv@4.0.3
          npm ERR! missing: get-stream@5.2.0, required by cacheable-request@7.0.2
          npm ERR! missing: clone-response@1.0.2, required by cacheable-request@7.0.2
          npm ERR! missing: http-cache-semantics@4.1.0, required by cacheable-request@7.0.2
          npm ERR! missing: keyv@4.0.3, required by cacheable-request@7.0.2
          npm ERR! missing: lowercase-keys@2.0.0, required by cacheable-request@7.0.2
          npm ERR! missing: normalize-url@6.1.0, required by cacheable-request@7.0.2
          npm ERR! missing: responselike@2.0.0, required by cacheable-request@7.0.2
          npm ERR! missing: pump@3.0.0, required by get-stream@5.2.0
          npm ERR! missing: mimic-response@1.0.1, required by clone-response@1.0.2
          npm ERR! missing: mimic-response@2.1.0, required by decompress-response@5.0.0
          npm ERR! missing: p-timeout@3.2.0, required by p-event@4.2.0
          npm ERR! missing: p-finally@1.0.0, required by p-timeout@3.2.0
          npm ERR! missing: lowercase-keys@2.0.0, required by responselike@2.0.0
          npm ERR! missing: aggregate-error@3.1.0, required by p-map@3.0.0
          npm ERR! missing: rc@1.2.8, required by registry-auth-token@4.2.1
          npm ERR! missing: rc@1.2.8, required by registry-url@5.1.0
          npm ERR! missing: builtins@1.0.3, required by validate-npm-package-name@3.0.0
          npm ERR! missing: mimic-fn@2.1.0, required by onetime@5.1.2
          npm ERR! missing: is-docker@2.2.1, required by open@7.4.2
          npm ERR! missing: is-wsl@2.2.0, required by open@7.4.2
          npm ERR! missing: is-docker@2.2.1, required by is-wsl@2.2.0
          npm ERR! missing: callsites@3.1.0, required by ow@0.21.0
          npm ERR! missing: dot-prop@6.0.1, required by ow@0.21.0
          npm ERR! missing: lodash.isequal@4.5.0, required by ow@0.21.0
          npm ERR! missing: @sindresorhus/is@4.2.0, required by ow@0.21.0
          npm ERR! missing: type-fest@0.20.2, required by ow@0.21.0
          npm ERR! missing: vali-date@1.0.0, required by ow@0.21.0
          npm ERR! missing: is-obj@2.0.0, required by dot-prop@6.0.1
          npm ERR! missing: map-age-cleaner@0.1.3, required by p-memoize@4.0.2
          npm ERR! missing: mimic-fn@3.1.0, required by p-memoize@4.0.2
          npm ERR! missing: p-defer@1.0.0, required by map-age-cleaner@0.1.3
          npm ERR! missing: find-up@5.0.0, required by pkg-dir@5.0.0
          npm ERR! missing: locate-path@6.0.0, required by find-up@5.0.0
          npm ERR! missing: path-exists@4.0.0, required by find-up@5.0.0
          npm ERR! missing: p-locate@5.0.0, required by locate-path@6.0.0
          npm ERR! missing: p-limit@3.1.0, required by p-locate@5.0.0
          npm ERR! missing: yocto-queue@0.1.0, required by p-limit@3.1.0
          npm ERR! missing: read-pkg@5.2.0, required by read-pkg-up@7.0.1
          npm ERR! missing: find-up@4.1.0, required by read-pkg-up@7.0.1
          npm ERR! missing: type-fest@0.8.1, required by read-pkg-up@7.0.1
          npm ERR! missing: @types/normalize-package-data@2.4.1, required by read-pkg@5.2.0
          npm ERR! missing: parse-json@5.2.0, required by read-pkg@5.2.0
          npm ERR! missing: normalize-package-data@2.5.0, required by read-pkg@5.2.0
          npm ERR! missing: type-fest@0.6.0, required by read-pkg@5.2.0
          npm ERR! missing: hosted-git-info@2.8.9, required by normalize-package-data@2.5.0
          npm ERR! missing: semver@5.7.1, required by normalize-package-data@2.5.0
          npm ERR! missing: resolve@1.20.0, required by normalize-package-data@2.5.0
          npm ERR! missing: validate-npm-package-license@3.0.4, required by normalize-package-data@2.5.0
          npm ERR! missing: is-core-module@2.7.0, required by resolve@1.20.0
          npm ERR! missing: path-parse@1.0.7, required by resolve@1.20.0
          npm ERR! missing: tslib@1.14.1, required by rxjs@6.6.7
          npm ERR! missing: through@2.3.8, required by split@1.0.1
          npm ERR! missing: ansi-escapes@4.3.2, required by terminal-link@2.1.1
          npm ERR! missing: supports-hyperlinks@2.2.0, required by terminal-link@2.1.1
          npm ERR! missing: has-flag@4.0.0, required by supports-hyperlinks@2.2.0
          npm ERR! missing: supports-color@7.2.0, required by supports-hyperlinks@2.2.0
          npm ERR! missing: boxen@5.1.2, required by update-notifier@5.1.0
          npm ERR! missing: chalk@4.1.2, required by update-notifier@5.1.0
          npm ERR! missing: configstore@5.0.1, required by update-notifier@5.1.0
          npm ERR! missing: has-yarn@2.1.0, required by update-notifier@5.1.0
          npm ERR! missing: import-lazy@2.1.0, required by update-notifier@5.1.0
          npm ERR! missing: is-ci@2.0.0, required by update-notifier@5.1.0
          npm ERR! missing: is-npm@5.0.0, required by update-notifier@5.1.0
          npm ERR! missing: is-yarn-global@0.3.0, required by update-notifier@5.1.0
          npm ERR! missing: latest-version@5.1.0, required by update-notifier@5.1.0
          npm ERR! missing: pupa@2.1.1, required by update-notifier@5.1.0
          npm ERR! missing: semver@7.3.5, required by update-notifier@5.1.0
          npm ERR! missing: semver-diff@3.1.1, required by update-notifier@5.1.0
          npm ERR! missing: is-installed-globally@0.4.0, required by update-notifier@5.1.0
          npm ERR! missing: xdg-basedir@4.0.0, required by update-notifier@5.1.0
          npm ERR! missing: ansi-align@3.0.1, required by boxen@5.1.2
          npm ERR! missing: camelcase@6.2.0, required by boxen@5.1.2
          npm ERR! missing: string-width@4.2.3, required by boxen@5.1.2
          npm ERR! missing: type-fest@0.20.2, required by boxen@5.1.2
          npm ERR! missing: chalk@4.1.2, required by boxen@5.1.2
          npm ERR! missing: cli-boxes@2.2.1, required by boxen@5.1.2
          npm ERR! missing: widest-line@3.1.0, required by boxen@5.1.2
          npm ERR! missing: wrap-ansi@7.0.0, required by boxen@5.1.2
          npm ERR! missing: string-width@4.2.3, required by ansi-align@3.0.1
          npm ERR! missing: string-width@4.2.3, required by widest-line@3.1.0
          npm ERR! missing: dot-prop@5.3.0, required by configstore@5.0.1
          npm ERR! missing: graceful-fs@4.2.6, required by configstore@5.0.1
          npm ERR! missing: make-dir@3.1.0, required by configstore@5.0.1
          npm ERR! missing: unique-string@2.0.0, required by configstore@5.0.1
          npm ERR! missing: write-file-atomic@3.0.3, required by configstore@5.0.1
          npm ERR! missing: xdg-basedir@4.0.0, required by configstore@5.0.1
          npm ERR! missing: is-obj@2.0.0, required by dot-prop@5.3.0
          npm ERR! missing: crypto-random-string@2.0.0, required by unique-string@2.0.0
          npm ERR! missing: imurmurhash@0.1.4, required by write-file-atomic@3.0.3
          npm ERR! missing: is-typedarray@1.0.0, required by write-file-atomic@3.0.3
          npm ERR! missing: signal-exit@3.0.3, required by write-file-atomic@3.0.3
          npm ERR! missing: typedarray-to-buffer@3.1.5, required by write-file-atomic@3.0.3
          npm ERR! missing: is-typedarray@1.0.0, required by typedarray-to-buffer@3.1.5
          npm ERR! missing: ci-info@2.0.0, required by is-ci@2.0.0
          npm ERR! missing: package-json@6.5.0, required by latest-version@5.1.0
          npm ERR! missing: got@9.6.0, required by package-json@6.5.0
          npm ERR! missing: semver@6.3.0, required by package-json@6.5.0
          npm ERR! missing: registry-auth-token@4.2.1, required by package-json@6.5.0
          npm ERR! missing: registry-url@5.1.0, required by package-json@6.5.0
          npm ERR! missing: duplexer3@0.1.4, required by got@9.6.0
          npm ERR! missing: @sindresorhus/is@0.14.0, required by got@9.6.0
          npm ERR! missing: @szmarczak/http-timer@1.1.2, required by got@9.6.0
          npm ERR! missing: cacheable-request@6.1.0, required by got@9.6.0
          npm ERR! missing: decompress-response@3.3.0, required by got@9.6.0
          npm ERR! missing: get-stream@4.1.0, required by got@9.6.0
          npm ERR! missing: lowercase-keys@1.0.1, required by got@9.6.0
          npm ERR! missing: mimic-response@1.0.1, required by got@9.6.0
          npm ERR! missing: p-cancelable@1.1.0, required by got@9.6.0
          npm ERR! missing: to-readable-stream@1.0.0, required by got@9.6.0
          npm ERR! missing: url-parse-lax@3.0.0, required by got@9.6.0
          npm ERR! missing: defer-to-connect@1.1.3, required by @szmarczak/http-timer@1.1.2
          npm ERR! missing: clone-response@1.0.2, required by cacheable-request@6.1.0
          npm ERR! missing: http-cache-semantics@4.1.0, required by cacheable-request@6.1.0
          npm ERR! missing: lowercase-keys@2.0.0, required by cacheable-request@6.1.0
          npm ERR! missing: get-stream@5.2.0, required by cacheable-request@6.1.0
          npm ERR! missing: keyv@3.1.0, required by cacheable-request@6.1.0
          npm ERR! missing: normalize-url@4.5.1, required by cacheable-request@6.1.0
          npm ERR! missing: responselike@1.0.2, required by cacheable-request@6.1.0
          npm ERR! missing: json-buffer@3.0.0, required by keyv@3.1.0
          npm ERR! missing: lowercase-keys@1.0.1, required by responselike@1.0.2
          npm ERR! missing: mimic-response@1.0.1, required by decompress-response@3.3.0
          npm ERR! missing: pump@3.0.0, required by get-stream@4.1.0
          npm ERR! missing: prepend-http@2.0.0, required by url-parse-lax@3.0.0
          npm ERR! missing: escape-goat@2.1.1, required by pupa@2.1.1
          npm ERR! missing: semver@6.3.0, required by semver-diff@3.1.1
          npm ERR! missing: is-path-inside@3.0.3, required by is-installed-globally@0.4.0
          npm ERR! missing: global-dirs@3.0.0, required by is-installed-globally@0.4.0
          npm ERR! missing: ini@2.0.0, required by global-dirs@3.0.0
          npm ERR! missing: @iobroker/adapter-core@2.6.0, required by iobroker.vis-inventwo@3.3.1
          npm ERR! missing: minimist@1.2.5, required by iobroker.vis-inventwo@3.3.1
          npm ERR! missing: np@7.5.0, required by iobroker.vis-inventwo@3.3.1
          npm ERR! missing: @material/button@7.0.0, required by iobroker.vis-material-advanced@1.7.2
          npm ERR! missing: @material/card@7.0.0, required by iobroker.vis-material-advanced@1.7.2
          npm ERR! missing: @material/switch@7.0.0, required by iobroker.vis-material-advanced@1.7.2
          npm ERR! missing: @iobroker/adapter-core@1.0.3, required by iobroker.vis-material-advanced@1.7.2
          npm ERR! missing: @material/density@7.0.0, required by @material/button@7.0.0
          npm ERR! missing: @material/elevation@7.0.0, required by @material/button@7.0.0
          npm ERR! missing: @material/feature-targeting@7.0.0, required by @material/button@7.0.0
          npm ERR! missing: @material/ripple@7.0.0, required by @material/button@7.0.0
          npm ERR! missing: @material/rtl@7.0.0, required by @material/button@7.0.0
          npm ERR! missing: @material/shape@7.0.0, required by @material/button@7.0.0
          npm ERR! missing: @material/theme@7.0.0, required by @material/button@7.0.0
          npm ERR! missing: @material/touch-target@7.0.0, required by @material/button@7.0.0
          npm ERR! missing: @material/typography@7.0.0, required by @material/button@7.0.0
          npm ERR! missing: @material/animation@7.0.0, required by @material/elevation@7.0.0
          npm ERR! missing: @material/base@7.0.0, required by @material/elevation@7.0.0
          npm ERR! missing: @material/feature-targeting@7.0.0, required by @material/elevation@7.0.0
          npm ERR! missing: @material/theme@7.0.0, required by @material/elevation@7.0.0
          npm ERR! missing: @material/animation@7.0.0, required by @material/ripple@7.0.0
          npm ERR! missing: @material/base@7.0.0, required by @material/ripple@7.0.0
          npm ERR! missing: @material/dom@7.0.0, required by @material/ripple@7.0.0
          npm ERR! missing: @material/feature-targeting@7.0.0, required by @material/ripple@7.0.0
          npm ERR! missing: @material/theme@7.0.0, required by @material/ripple@7.0.0
          npm ERR! missing: tslib@1.14.1, required by @material/ripple@7.0.0
          npm ERR! missing: @material/theme@7.0.0, required by @material/rtl@7.0.0
          npm ERR! missing: @material/feature-targeting@7.0.0, required by @material/shape@7.0.0
          npm ERR! missing: @material/rtl@7.0.0, required by @material/shape@7.0.0
          npm ERR! missing: @material/theme@7.0.0, required by @material/shape@7.0.0
          npm ERR! missing: @material/feature-targeting@7.0.0, required by @material/theme@7.0.0
          npm ERR! missing: @material/base@7.0.0, required by @material/touch-target@7.0.0
          npm ERR! missing: @material/feature-targeting@7.0.0, required by @material/touch-target@7.0.0
          npm ERR! missing: @material/feature-targeting@7.0.0, required by @material/typography@7.0.0
          npm ERR! missing: @material/theme@7.0.0, required by @material/typography@7.0.0
          npm ERR! missing: @material/elevation@7.0.0, required by @material/card@7.0.0
          npm ERR! missing: @material/feature-targeting@7.0.0, required by @material/card@7.0.0
          npm ERR! missing: @material/ripple@7.0.0, required by @material/card@7.0.0
          npm ERR! missing: @material/rtl@7.0.0, required by @material/card@7.0.0
          npm ERR! missing: @material/shape@7.0.0, required by @material/card@7.0.0
          npm ERR! missing: @material/theme@7.0.0, required by @material/card@7.0.0
          npm ERR! missing: @material/animation@7.0.0, required by @material/switch@7.0.0
          npm ERR! missing: @material/base@7.0.0, required by @material/switch@7.0.0
          npm ERR! missing: @material/density@7.0.0, required by @material/switch@7.0.0
          npm ERR! missing: @material/dom@7.0.0, required by @material/switch@7.0.0
          npm ERR! missing: @material/elevation@7.0.0, required by @material/switch@7.0.0
          npm ERR! missing: @material/feature-targeting@7.0.0, required by @material/switch@7.0.0
          npm ERR! missing: @material/ripple@7.0.0, required by @material/switch@7.0.0
          npm ERR! missing: @material/rtl@7.0.0, required by @material/switch@7.0.0
          npm ERR! missing: @material/theme@7.0.0, required by @material/switch@7.0.0
          npm ERR! missing: tslib@1.14.1, required by @material/switch@7.0.0
          npm ERR! missing: tslib@1.14.1, required by @material/animation@7.0.0
          npm ERR! missing: tslib@1.14.1, required by @material/base@7.0.0
          npm ERR! missing: @material/feature-targeting@7.0.0, required by @material/dom@7.0.0
          npm ERR! missing: tslib@1.14.1, required by @material/dom@7.0.0
          npm ERR! missing: @iobroker/adapter-core@1.0.3, required by iobroker.vis-metro@1.2.0
          npm ERR! missing: @iobroker/adapter-core@1.0.3, required by iobroker.vis-players@0.1.6
          npm ERR! missing: @iobroker/adapter-core@1.0.3, required by iobroker.vis-plumb@1.0.2
          npm ERR! missing: @iobroker/adapter-core@2.6.0, required by iobroker.weatherunderground@3.4.1
          npm ERR! missing: axios@0.26.1, required by iobroker.weatherunderground@3.4.1
          npm ERR! missing: follow-redirects@1.14.9, required by axios@0.26.1
          npm ERR! missing: @iobroker/adapter-core@2.6.0, required by iobroker.web@4.2.3
          npm ERR! missing: body-parser@1.19.2, required by iobroker.web@4.2.3
          npm ERR! missing: compression@1.7.4, required by iobroker.web@4.2.3
          npm ERR! missing: connect-flash@0.1.1, required by iobroker.web@4.2.3
          npm ERR! missing: cookie-parser@1.4.6, required by iobroker.web@4.2.3
          npm ERR! missing: express@4.17.3, required by iobroker.web@4.2.3
          npm ERR! missing: express-session@1.17.2, required by iobroker.web@4.2.3
          npm ERR! missing: iobroker.simple-api@2.6.4, required by iobroker.web@4.2.3
          npm ERR! missing: iobroker.socketio@4.2.0, required by iobroker.web@4.2.3
          npm ERR! missing: iobroker.ws@1.3.0, required by iobroker.web@4.2.3
          npm ERR! missing: mime-types@2.1.35, required by iobroker.web@4.2.3
          npm ERR! missing: passport@0.5.2, required by iobroker.web@4.2.3
          npm ERR! missing: passport-local@1.0.0, required by iobroker.web@4.2.3
          npm ERR! missing: xtend@4.0.2, required by iobroker.web@4.2.3
          npm ERR! missing: @iobroker/adapter-core@2.6.0, required by iobroker.ws@1.3.0
          npm ERR! missing: cookie-parser@1.4.6, required by iobroker.ws@1.3.0
          npm ERR! missing: express-session@1.17.2, required by iobroker.ws@1.3.0
          npm ERR! missing: iobroker.ws.server@1.0.1, required by iobroker.ws@1.3.0
          npm ERR! missing: axios@0.26.1, required by iobroker.ws@1.3.0
          npm ERR! missing: passport@0.5.2, required by iobroker.ws@1.3.0
          npm ERR! missing: ws@8.5.0, required by iobroker.ws.server@1.0.1
          npm ERR! missing: mime-db@1.52.0, required by mime-types@2.1.35
          npm ERR! missing: @iobroker/adapter-core@2.6.0, required by iobroker.whatsapp-cmb@0.2.2
          npm ERR! missing: request@2.88.2, required by iobroker.whatsapp-cmb@0.2.2
          npm ERR! missing: @iobroker/adapter-core@2.6.0, required by iobroker.wled@0.6.3
          npm ERR! missing: axios@0.21.4, required by iobroker.wled@0.6.3
          npm ERR! missing: bonjour@3.5.0, required by iobroker.wled@0.6.3
          npm ERR! missing: hex-rgb@4.3.0, required by iobroker.wled@0.6.3
          npm ERR! missing: ws@8.2.2, required by iobroker.wled@0.6.3
          npm ERR! missing: rgb-hex@3.0.0, required by iobroker.wled@0.6.3
          npm ERR! missing: follow-redirects@1.14.9, required by axios@0.21.4
          npm ERR! missing: array-flatten@2.1.2, required by bonjour@3.5.0
          npm ERR! missing: deep-equal@1.1.1, required by bonjour@3.5.0
          npm ERR! missing: dns-equal@1.0.0, required by bonjour@3.5.0
          npm ERR! missing: dns-txt@2.0.2, required by bonjour@3.5.0
          npm ERR! missing: multicast-dns@6.2.3, required by bonjour@3.5.0
          npm ERR! missing: multicast-dns-service-types@1.1.0, required by bonjour@3.5.0
          npm ERR! missing: is-arguments@1.1.0, required by deep-equal@1.1.1
          npm ERR! missing: is-date-object@1.0.4, required by deep-equal@1.1.1
          npm ERR! missing: is-regex@1.1.4, required by deep-equal@1.1.1
          npm ERR! missing: object-is@1.1.5, required by deep-equal@1.1.1
          npm ERR! missing: object-keys@1.1.1, required by deep-equal@1.1.1
          npm ERR! missing: regexp.prototype.flags@1.3.1, required by deep-equal@1.1.1
          npm ERR! missing: call-bind@1.0.2, required by is-arguments@1.1.0
          npm ERR! missing: call-bind@1.0.2, required by is-regex@1.1.4
          npm ERR! missing: has-tostringtag@1.0.0, required by is-regex@1.1.4
          npm ERR! missing: has-symbols@1.0.2, required by has-tostringtag@1.0.0
          npm ERR! missing: call-bind@1.0.2, required by object-is@1.1.5
          npm ERR! missing: define-properties@1.1.3, required by object-is@1.1.5
          npm ERR! missing: call-bind@1.0.2, required by regexp.prototype.flags@1.3.1
          npm ERR! missing: define-properties@1.1.3, required by regexp.prototype.flags@1.3.1
          npm ERR! missing: buffer-indexof@1.1.1, required by dns-txt@2.0.2
          npm ERR! missing: dns-packet@1.3.1, required by multicast-dns@6.2.3
          npm ERR! missing: thunky@1.1.0, required by multicast-dns@6.2.3
          andre@ioBkoker202:/opt/iobroker$
          Intel NUC
          Proxmox
          Raspberry Pi 4
          Conbee 2 Stick
          Adapter: deConz Zigbee
            andrebu
            @homoran sagte in Kann keine Adapter mehr installieren:
            Kannst du mir die Befehle dazu sagen? Büüütte. Bevor ich als Linux Einsteiger den nächsten Bock schieße.
            Intel NUC
            Proxmox
            Raspberry Pi 4
            Conbee 2 Stick
            • A andrebu
              @andrebu
              rm /pfad/zur/datei
              Schau aber auch mal nach der nodeJS-Installation:
              uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
              A 3 Antworten Letzte Antwort
                @andrebu
                rm /pfad/zur/datei
                andrebu
                @thomas-braun sagte in Kann keine Adapter mehr installieren:
                @andrebu
                rm /pfad/zur/datei
                Hast du zufällig auch den Pfad? :-)
                Intel NUC
                Proxmox
                Raspberry Pi 4
                Conbee 2 Stick
                  @andrebu
                  rm /pfad/zur/datei
                  andrebu
                  Sieht so aus
                  andre@ioBkoker202:/opt/iobroker$ sudo ln -s /usr/bin/node /usr/bin/nodejs
                  [sudo] Passwort für andre:
                  Das hat nicht funktioniert, bitte nochmal probieren.
                  ln: die symbolische Verknüpfung '/usr/bin/nodejs' konnte nicht angelegt werden: Die Datei existiert bereits
                  andre@ioBkoker202:/opt/iobroker$ uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                  x86_64
                  /usr/bin/nodejs
                  /usr/bin/node
                  /usr/bin/npm
                  v14.19.1
                  v14.19.1
                  6.14.16
                  andre
                  /opt/iobroker
                  OK:1 http://security.debian.org/debian-security bullseye-security InRelease
                  OK:2 http://deb.debian.org/debian bullseye InRelease
                  OK:3 http://deb.debian.org/debian bullseye-updates InRelease
                  OK:4 http://ftp.debian.org/debian bullseye-backports InRelease
                  OK:5 http://phoscon.de/apt/deconz buster InRelease
                  OK:6 https://deb.nodesource.com/node_14.x bullseye InRelease
                  Aktualisierung für 1 Paket verfügbar. Führen Sie »apt list --upgradable« aus, um es anzuzeigen.
                  nodejs:
                    Installiert:           14.19.1-deb-1nodesource1
                    Installationskandidat: 14.19.2-deb-1nodesource1
                    Versionstabelle:
                       14.19.2-deb-1nodesource1 500
                          500 https://deb.nodesource.com/node_14.x bullseye/main amd64 Packages
                   *** 14.19.1-deb-1nodesource1 100
                       12.22.5~dfsg-2~11u1 500
                          500 http://deb.debian.org/debian bullseye/main amd64 Packages
                          500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
                  Intel NUC
                  Proxmox
                  Raspberry Pi 4
                  Conbee 2 Stick
                    @andrebu
                    rm /pfad/zur/datei
                    andrebu
                    @thomas-braun @Homoran oder soll ich NPM einfach mal auf Version 8 anheben? Dann sollte das Problem mit der package-lock.json auch behoben sein oder?
                    Intel NUC
                    Proxmox
                    Raspberry Pi 4
                    Conbee 2 Stick
                    • A andrebu
                      keine gute Idee mit node 14
                      Leider habe ich auswendig den Pfad zur package-lock.json nicht parat.
                      Müsste aber hier im Forum zu finden sein. Du bist nicht der erste mit dem Problem
                      EDIT:
                      Die Suche hat ausgespuckt:
                      In /opt/iobroker gibt es eine package-lock.json, die den Dependency-Tree aus Sicht von /opt/iobroker abbildet
                      A 2 Antworten Letzte Antwort
                        EDIT:
                        andrebu
                        @homoran Danke dann lösch ich die mal.
                        Intel NUC
                        Proxmox
                        Raspberry Pi 4
                        Conbee 2 Stick
                          EDIT:
                          andrebu
                          schrieb am zuletzt editiert von andrebu
                          @homoran @Thomas-Braun ist gelöscht
                          nun bleibt die installation ohne Fehlermeldung hängen.
                          andre@ioBkoker202:/opt/iobroker$ iobroker add denon --ioBkoker202
                          NPM version: 6.14.16
                          Installing iobroker.denon@1.13.3... (System call)
                          Soll ich jetzt mal den Fixer drüber laufen lassen?
                          iob stop
                          iob fix
                          iob start
                          EDIT
                          jetzt macht er doch was ich poste gleich das aktuelle LOG.
                          Intel NUC
                          Proxmox
                          Raspberry Pi 4
                          Conbee 2 Stick
                          • A andrebu
                            Sieht so aus
                            x86_64
                            /usr/bin/nodejs
                            /usr/bin/node
                            /usr/bin/npm
                            v14.19.1
                            v14.19.1
                            6.14.16
                            andre
                            /opt/iobroker
                            nodejs:
                              Versionstabelle:
                            Das ist nodejs. Kannste direkt mal aktualisieren.
                              andrebu
                              @Homoran @crunchip
                              der Adapter wurde doch tatsächlich installiert :-) :-)
                              > diskusage@1.1.3 install /opt/iobroker/node_modules/diskusage
                              > node-gyp rebuild
                              make: Verzeichnis „/opt/iobroker/node_modules/diskusage/build“ wird betreten
                                CXX(target) Release/obj.target/diskusage/src/main.o
                                CXX(target) Release/obj.target/diskusage/src/diskusage_posix.o
                                SOLINK_MODULE(target) Release/obj.target/diskusage.node
                                COPY Release/diskusage.node
                              make: Verzeichnis „/opt/iobroker/node_modules/diskusage/build“ wird verlassen
                              > @serialport/bindings-cpp@10.7.0 install /opt/iobroker/node_modules/@serialport/bindings-cpp
                              > node-gyp-build
                              > unix-dgram@2.0.4 install /opt/iobroker/node_modules/unix-dgram
                              > node-gyp rebuild
                              make: Verzeichnis „/opt/iobroker/node_modules/unix-dgram/build“ wird betreten
                                CXX(target) Release/obj.target/unix_dgram/src/unix_dgram.o
                                SOLINK_MODULE(target) Release/obj.target/unix_dgram.node
                                COPY Release/unix_dgram.node
                              make: Verzeichnis „/opt/iobroker/node_modules/unix-dgram/build“ wird verlassen
                              > ursa-optional@0.9.10 install /opt/iobroker/node_modules/ursa-optional
                              > node rebuild.js
                              ursaNative bindings compilation fail. This is not an issue. Modules that depend on it will use fallbacks.
                              > sharp@0.28.1 install /opt/iobroker/node_modules/sharp
                              > (node install/libvips && node install/dll-copy && prebuild-install) || (node-gyp rebuild && node install/dll-copy)
                              sharp: Using cached /home/iobroker/.npm/_libvips/libvips-8.10.6-linux-x64.tar.br
                              > canvas@2.9.1 install /opt/iobroker/node_modules/canvas
                              > node-pre-gyp install --fallback-to-build
                              [canvas] Success: "/opt/iobroker/node_modules/canvas/build/Release/canvas.node" is installed via remote
                              > sharp@0.25.4 install /opt/iobroker/node_modules/iobroker.onvif/node_modules/sharp
                              > (node install/libvips && node install/dll-copy && prebuild-install --runtime=napi) || (node-gyp rebuild && node install/dll-copy)
                              > @root/acme@3.1.0 postinstall /opt/iobroker/node_modules/@root/acme
                              > node scripts/postinstall
                              > esbuild@0.11.23 postinstall /opt/iobroker/node_modules/esbuild
                              > node install.js
                              + iobroker.denon@1.13.3
                              added 93 packages from 55 contributors, removed 49 packages and updated 1342 packages in 357.835s
                              138 packages are looking for funding
                                run `npm fund` for details
                              host.ioBkoker202 install adapter denon
                              upload [12] denon.admin /opt/iobroker/node_modules/iobroker.denon/admin/denon.png denon.png image/png
                              upload [11] denon.admin /opt/iobroker/node_modules/iobroker.denon/admin/i18n/de/translations.json i18n/de/translations.json application/json
                              upload [10] denon.admin /opt/iobroker/node_modules/iobroker.denon/admin/i18n/en/translations.json i18n/en/translations.json application/json
                              upload [9] denon.admin /opt/iobroker/node_modules/iobroker.denon/admin/i18n/es/translations.json i18n/es/translations.json application/json
                              upload [8] denon.admin /opt/iobroker/node_modules/iobroker.denon/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                              upload [7] denon.admin /opt/iobroker/node_modules/iobroker.denon/admin/i18n/it/translations.json i18n/it/translations.json application/json
                              upload [6] denon.admin /opt/iobroker/node_modules/iobroker.denon/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                              upload [5] denon.admin /opt/iobroker/node_modules/iobroker.denon/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                              upload [4] denon.admin /opt/iobroker/node_modules/iobroker.denon/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                              upload [3] denon.admin /opt/iobroker/node_modules/iobroker.denon/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                              upload [2] denon.admin /opt/iobroker/node_modules/iobroker.denon/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                              upload [1] denon.admin /opt/iobroker/node_modules/iobroker.denon/admin/index_m.html index_m.html text/html
                              upload [0] denon.admin /opt/iobroker/node_modules/iobroker.denon/admin/words.js words.js application/javascript
                              host.ioBkoker202 object system.adapter.denon created/updated
                              host.ioBkoker202 create instance denon
                              host.ioBkoker202 object system.adapter.denon.0.alive created
                              host.ioBkoker202 object system.adapter.denon.0.connected created
                              host.ioBkoker202 object system.adapter.denon.0.compactMode created
                              host.ioBkoker202 object system.adapter.denon.0.cpu created
                              host.ioBkoker202 object system.adapter.denon.0.cputime created
                              host.ioBkoker202 object system.adapter.denon.0.memHeapUsed created
                              host.ioBkoker202 object system.adapter.denon.0.memHeapTotal created
                              host.ioBkoker202 object system.adapter.denon.0.memRss created
                              host.ioBkoker202 object system.adapter.denon.0.uptime created
                              host.ioBkoker202 object system.adapter.denon.0.inputCount created
                              host.ioBkoker202 object system.adapter.denon.0.outputCount created
                              host.ioBkoker202 object system.adapter.denon.0.eventLoopLag created
                              host.ioBkoker202 object system.adapter.denon.0.sigKill created
                              host.ioBkoker202 object system.adapter.denon.0.logLevel created
                              host.ioBkoker202 object denon.0.info created
                              host.ioBkoker202 object denon.0.info.connection created
                              host.ioBkoker202 object denon.0.display created
                              host.ioBkoker202 object denon.0.display.brightness created
                              host.ioBkoker202 object denon.0.settings created
                              host.ioBkoker202 object denon.0.settings.powerSystem created
                              host.ioBkoker202 object denon.0.settings.expertCommand created
                              host.ioBkoker202 object denon.0.settings.expertReadingResult created
                              host.ioBkoker202 object denon.0.settings.expertReadingPattern created
                              host.ioBkoker202 Set default value of denon.0.info.connection: false
                              host.ioBkoker202 object system.adapter.denon.0 created
                              Intel NUC
                              Proxmox
                              Raspberry Pi 4
                              Conbee 2 Stick
                              • A andrebu
                                @Homoran @crunchip
                                > node-gyp rebuild
                                > node-gyp-build
                                > node-gyp rebuild
                                > node rebuild.js
                                > node install.js
                                andrebu
                                Danke Danke Danke. Ich die installation über die Admin Oberfläche läuft auch durch.
                                Danke @Homoran @Thomas-Braun @crunchip 🥇 🥇 🥇 🥇 🥇Vielen Dank. ich hab in den letzen Stunden soviel dazu gelernt. Danke.
                                Intel NUC
                                Proxmox
                                Raspberry Pi 4
                                Conbee 2 Stick
                                  andrebu
                                  @Thomas-Braun
                                  Tatsache 14.19.2 ich hab 14.19.1
                                  ich trau mich nicht. ;-)
                                  Sollte ich den Mut fassen, ist es dann so richtig?
                                  iob stop
                                  curl -sL https://deb.nodesource.com/setup_14.x | sudo -E bash -
                                  sudo apt install -y nodejs
                                  node -v
                                  iob fix
                                  iob start
                                  Backup wird 3 mal die Woche automatisch gemacht. Deshalb lasse ich
                                  cd /opt/iobroker
                                  iobroker backup
                                  weg.
                                  Intel NUC
                                  Proxmox
                                  Raspberry Pi 4
                                  Conbee 2 Stick
                                  • A andrebu
                                    @Thomas-Braun
                                    iob stop
                                    node -v
                                    iob fix
                                    iob start
                                    cd /opt/iobroker
                                    iobroker backup
                                    weg.
                                    @andrebu
                                    iobroker stop
                                    sudo apt update
                                    sudo apt full-upgrade
                                    iobroker start
                                      @andrebu
                                      iobroker stop
                                      sudo apt update
                                      iobroker start
                                      andrebu
                                      @thomas-braun super, vielen Dank. Ihr habt mir echt den Tag gerettet.
                                      Intel NUC
                                      Proxmox
                                      Raspberry Pi 4
                                      Conbee 2 Stick
                                      • A andrebu
                                        dann war die Aktion ja erfolgreich
