  3. Einsteigerfragen
  4. iobroker läuft nicht mehr
    2.7k
    4.7k
    4.0k
87 Beiträge 4 Kommentatoren 8.8k Aufrufe 3 Beobachtet
  • E Emi 0
    micros02@smartmeter:~ $ sudo kill 2963
    kill: (2963): No such process
    @emi-0
    systemctl status iobroker.service
    E 1 Antwort Letzte Antwort
      @emi-0
      Emi 0
      @thomas-braun said in iobroker läuft nicht mehr:
      micros02@smartmeter:~ $ systemctl status iobroker.service
      ● iobroker.service - ioBroker Server
           Loaded: loaded (/lib/systemd/system/iobroker.service; enabled; vendor preset: enabled)
           Active: activating (auto-restart) (Result: exit-code) since Wed 2022-04-27 12:44:50 CEST; 1s ago
             Docs: http://iobroker.net
          Process: 3329 ExecStart=/usr/bin/bash -c ${NODE} /opt/iobroker/node_modules/iobroker.js-controller/controller.j>
         Main PID: 3329 (code=exited, status=1/FAILURE)
              CPU: 44.948s
      Apr 27 12:44:53 smartmeter systemd[1]: iobroker.service: Scheduled restart job, restart counter is at 82.
      Apr 27 12:44:53 smartmeter systemd[1]: Stopped ioBroker Server.
      Apr 27 12:44:53 smartmeter systemd[1]: iobroker.service: Consumed 44.948s CPU time.
      Apr 27 12:44:53 smartmeter systemd[1]: Started ioBroker Server.
      lines 1-12/12 (END)
      • E Emi 0
                CPU: 44.948s
        lines 1-12/12 (END)
        @emi-0
        sudo systemctl stop iobroker
          @emi-0
          Emi 0
          micros02@smartmeter:~ $ sudo systemctl stop iobroker
          • E Emi 0
            @emi-0
            Dann schau nochmal, was da läuft:
            ps auxww|grep io
            Wenn da keine iobroker-Prozesse mehr zu sehen sind:
            iobroker update
            iobroker upgrade
              @emi-0
              ps auxww|grep io
              iobroker update
              iobroker upgrade
              Emi 0
              Das funktioniert irgendwie nicht 😢
              micros02@smartmeter:~ $ ps auxww|grep io
              root        34  0.0  0.0      0     0 ?        I<   11:06   0:00 [blkcg_punt_bio]
              root        36  0.0  0.0      0     0 ?        I<   11:06   0:00 [rpciod]
              root        38  0.0  0.0      0     0 ?        I<   11:06   0:00 [xprtiod]
              root        40  0.0  0.0      0     0 ?        I<   11:06   0:00 [nfsiod]
              root        44  0.0  0.0      0     0 ?        I<   11:06   0:00 [DWC Notificatio]
              message+   249  0.0  0.7   7688  3324 ?        Ss   11:07   0:05 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation --syslog-only
              micros02  4485  0.0  0.4   7436  1944 pts/0    S+   13:39   0:00 grep --color=auto io
              micros02@smartmeter:~ $ iobroker update
              No connection to databases possible ...
                @emi-0 sagte in iobroker läuft nicht mehr:
                ist das ein Multihost-System?
                @Emi-0
                Du hast die Frage noch nicht beantwortet:
                @homoran sagte in iobroker läuft nicht mehr:
                  @Emi-0
                  Emi 0
                  sorry, die Frage ist bei mir untergegangen.
                  Nein, es ist nur ein raspi, der den Stromverbrauch misst.
                  • E Emi 0
                    @emi-0
                    Prüf mal die nodeJS-Installation:
                    which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                    • E Emi 0
                      @emi-0
                      Wenn nodejs in Version 14 sauber installiert ist:
                      cd /opt/iobroker
                      sudo -H -u iobroker npm install iobroker.js-controller
                        @emi-0
                        cd /opt/iobroker
                        Emi 0
                        schrieb am zuletzt editiert von Emi 0
                        micros02@smartmeter:~ $ cd /opt/iobroker
                        micros02@smartmeter:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
                        removed 82 packages in 1m
                        38 packages are looking for funding
                          run `npm fund` for details
                        soll ich iobroker nochmal starten?
                          @emi-0
                          Emi 0
                          ich interpretiere das so, dass die nodeJS-Installatiion i.O ist:
                          micros02@smartmeter:~ $ which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                          /usr/bin/nodejs
                          /usr/bin/node
                          /usr/bin/npm
                          v12.22.5
                          v12.22.5
                          7.5.2
                          micros02
                          /home/micros02
                          Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
                          Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                          Reading package lists... Done
                          54 packages can be upgraded. Run 'apt list --upgradable' to see them.
                          nodejs:
                            Installed: 12.22.5~dfsg-2~11u1
                            Candidate: 12.22.5~dfsg-2~11u1
                            Version table:
                           *** 12.22.5~dfsg-2~11u1 500
                          aber ich sehe gerade, dass es die 12.22.5 ist
                          • E Emi 0
                            /usr/bin/nodejs
                            /usr/bin/node
                            /usr/bin/npm
                            v12.22.5
                            v12.22.5
                            7.5.2
                            micros02
                            /home/micros02
                            nodejs:
                              Version table:
                            mit:
                            v12.22.5
                            7.5.2
                            npm v7 eher nicht
                              mit:
                              v12.22.5
                              7.5.2
                              npm v7 eher nicht
                              Emi 0
                              was kann ich tun?
                              • E Emi 0
                                was kann ich tun?
                                @emi-0
                                Und es ist auch die dfsg-Version, nicht die von nodesource gepackte.
                                Installier sauber node14, Anleitung in meiner Signatur.
                                  @emi-0
                                  Emi 0
                                  Habe es nach Deiner Anleitung mehrfach versucht.
                                  micros02@smartmeter:~ $ sudo apt update
                                  Get:1 http://archive.raspberrypi.org/debian bullseye InRelease [23.7 kB]
                                  Get:3 http://archive.raspberrypi.org/debian bullseye/main armhf Packages [282 kB]
                                  Fetched 306 kB in 6s (48.4 kB/s)
                                  1 package can be upgraded. Run 'apt list --upgradable' to see it.
                                  N: Ignoring file 'nodesource.list.save.1' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extension
                                  N: Ignoring file 'nodesource.list.save.2' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extension
                                  micros02@smartmeter:~ $ sudo apt upgrade
                                  Calculating upgrade... Done
                                  The following packages will be upgraded:
                                    rpi-eeprom
                                  1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                                  Need to get 2,037 kB of archives.
                                  After this operation, 1,574 kB of additional disk space will be used.
                                  Do you want to continue? [Y/n] Y
                                  Get:1 http://archive.raspberrypi.org/debian bullseye/main armhf rpi-eeprom armhf 13.13-1 [2,037 kB]
                                  Fetched 2,037 kB in 1s (1,540 kB/s)
                                  Reading changelogs... Done
                                  (Reading database ... 53199 files and directories currently installed.)
                                  Preparing to unpack .../rpi-eeprom_13.13-1_armhf.deb ...
                                  Unpacking rpi-eeprom (13.13-1) over (13.12-1) ...
                                  Setting up rpi-eeprom (13.13-1) ...
                                  Processing triggers for man-db (2.9.4-2) ...
                                  micros02@smartmeter:~ $ uname -a
                                  Linux smartmeter 5.15.32+ #1538 Thu Mar 31 19:37:58 BST 2022 armv6l GNU/Linux
                                  micros02@smartmeter:~ $ lsb_release -a
                                  No LSB modules are available.
                                  Distributor ID: Raspbian
                                  Description:    Raspbian GNU/Linux 11 (bullseye)
                                  Release:        11
                                  Codename:       bullseye
                                  micros02@smartmeter:~ $ nodejs -v
                                  v12.22.5
                                  Bleibt aber bei v12.22.5
                                  • E Emi 0
                                      rpi-eeprom
                                    Release:        11
                                    Codename:       bullseye
                                    v12.22.5
                                    Da fehlt die Datei nodesource.list
                                    Dafür hast du da nodesource.list.save.xy drin. Die werden nicht eingelesen, nur Dateiendungen .list werden berücksichtigt.
                                      sudo rm /etc/apt/sources.list.d/nodesource.li*
                                      sudo apt remove nodejs*
                                      curl -sL https://deb.nodesource.com/setup_14.x | sudo -E bash
                                      sudo apt update
                                      sudo apt install nodejs
                                        sudo apt update
                                        Emi 0
                                        habe alle Schritte wie beschrieben ausgeführt.
                                        Bleibt bei v12.22.5.
                                        Kann iobroker nicht starten.
                                        Kann es darab liegen, dass ich einen raspi zero verwende?
                                        micros02@smartmeter:~ $ iobroker start
                                        micros02@smartmeter:~ $ iob status
                                        Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
                                        micros02@smartmeter:~ $ which nodejs node npm && nodejs -v && node -v && npm -v && apt policy nodejs
                                        /usr/bin/nodejs
                                        /usr/bin/node
                                        v12.22.5
                                        /usr/bin/nodejs
                                        /usr/bin/node
                                        Release:        11
                                        Codename:       bullseye
                                        • E Emi 0
                                          /usr/bin/nodejs
                                          /usr/bin/node
                                          v12.22.5
                                          /usr/bin/nodejs
                                          /usr/bin/node
                                          Release:        11
                                          Codename:       bullseye
                                          @emi-0
                                          Das ist ein alter Raspberry.
                                          Der muss bezüglich nodejs besonders/anders angepackt werden. In meinem nodejs-HowTo wird das aber auch erwähnt. Schau mal rein
                                          Der hat 512MB RAM, oder? Das dürfte kaum für eine
                                          sinnvollen Betrieb ausreichen. Das Doppelte ist schon schwierig.
                                          E 2 Antworten Letzte Antwort
