  4. LaMetric oder JSON-POST per IOBroker Javascript
69 Beiträge 19 Kommentatoren 18.8k Aufrufe 8 Beobachtet
  • ruhr70R Offline
    ruhr70R Offline
    ruhr70
    Und eine zweite Variante, falls das oben so nicht funktioniert:
    var apikey = '<your api/key/here="">';
    var auth = 'Basic ' + new Buffer('dev:' + apikey).toString('base64');
    var options = {
        host: deviceIpAdress,
        port: 4343,
        path: cmd,
        method: 'POST',
        headers: {
            'User-Agent' : 'Mozilla/5.0 (Macintosh; Intel Mac OS X 10_12_4) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/57.0.2987.133 Safari/537.36',
            'Content-Type': 'application/json',
            'Authorization': 'Basic <'+auth+'>',
            'Accept': 'applciation/json',
            'Content-Length': data.length
    };</your>
    Ich würde auf diese zweite Variante tippen… wg. der Beschreibung Authorization: Basic<base64(dev:api_key)></base64(dev:api_key)>
      mdsv
      Feedback Var. 1
      Leider nicht … habe sogar mit <> und ohne probiert.
      ` > 21:50:06.426 [info] javascript.0 Start javascript script.js.LeMetric.notification
      21:50:06.426 [info] javascript.0 script.js.LeMetric.notification: Data to request body: {"priority":"warning","model":{"cycles":1,"frames":[{"icon":"data:image/png;base64,iVBORw0KGgoAAAANGRkUFBQZ0…....................<snip>...","text":"HELLO!"}],"sound":{"category":"notifications","id":"cat"}}}
      21:50:06.426 [info] javascript.0 script.js.LeMetric.notification: registered 0 subscriptions and 0 schedules
      21:50:06.441 [info] javascript.0 script.js.LeMetric.notification: http Status: 401
      21:50:06.441 [warn] javascript.0 script.js.LeMetric.notification: HEADERS: {"www-authenticate":"Basic realm="global"","content-type":"application/json;charset=UTF8","content-length":"96","connection":"close","date":"Tue, 02 May 2017 19:50:05 GMT","server":"lighttpd/1.4.35"}
      21:50:06.441 [info] javascript.0 script.js.LeMetric.notification: body: { "errors":[ { "message":"Authorization is required" } ] }</snip> `
      Feedback Var.2
      OK, habe den Unterschied gefunden :D
      'Authorization': 'Basic <'+auth+'>' im Header
      -> gleiche Fehlermeldung.
      • ruhr70R Offline
        ruhr70R Offline
        ruhr70
        @mdsv:
        Feedback Var.2
        -> gleiche Fehlermeldung. `
        Und das auth: über den Header weg.
        Ich glaube die < > gehören auch nicht dazu…
        Also:
        'Authorization': 'Basic '+auth,
        • ruhr70R Offline
          ruhr70R Offline
          ruhr70
          Poste mal bitte, wie dieser Bereich jetzt bei Dir aussieht:
          var options = {
              port: 4343,
              path: cmd,
              method: 'POST',
              headers: {
          };</your>
            mdsv
            ungefähr so ….
            var https = require('http');
            var apikey = '08cc1947<snip>.....</snip>4a28cb900457b9bd';
            var options = {
                port: 8080,
                auth: auth,
                path: cmd,
                method: 'POST',
                headers: {
                    'Accept': 'application/json',
                    'Content-Length': data.length,
            Meldung kommt immer noch.
            • ruhr70R Offline
              ruhr70R Offline
              ruhr70
              Da sind jetzt ein paar Punkte…
              Du nutzt http (8080).
              Wir verwenden aber das Module https
              Das muss geändert werden.
              Dann ist das auth in den Options noch drin.
              [EDIT]: OK, habe ich übersehen… Du hast es in http oben geändert ;-) sorry... ;-)
              • ruhr70R Offline
                ruhr70R Offline
                ruhr70
                @mdsv ich änder das Skript eben und poste es noch einmal.
                • ruhr70R Offline
                  ruhr70R Offline
                  ruhr70
                  mhh… wenn es nicht das überflüssige auth: auth, in den Options ist, bin ich mit meinem Latein fast am Ende.
                  Muss mir das Teil wohl doch mal bestellen ;-)
                    mdsv
                    Danke für die Mühe … vielleicht solltest dir eine holen ;) ... man kann Notification einblenden (Tür öffnet), aber auch durch li/re Klick den Status anzeigen lassen (Wetter, ....).
                    Durch lokale Update wird die Info dann übermittelt. Den Action-Modus habe ich noch nicht probiert und das ganze unscheinbar als nette Uhr.
                    Per CURL bekomme ich es schon direkt hin, allerdings wäre Javascript besser, um die Parameter zu übermitteln.
                    PS: die überflüssige auth war es auch nicht ....schade.
                    • R Offline
                      ronnyw
                      Meine Programmierkenntnisse sind leider recht rudimentär und ich kann auch gerade nicht helfen. Aber als ioBroker Neuling mit einer LaMetric interessiert mich das Thema sehr (auch wenn ich später Richtung Button-App hinaus möchte und schon überlege, wie man wohl einen LaMetric Adapter hinbekommt, der das ermöglicht). Ich hoffe das Thema LaMetric findet hier noch breiteren Anklang :-)
                        Ben
                        Hier ist meine funktionierende Lösung. :geek:
                        Dabei habe ich auch ein cooles ioBroker-Icon gebaut.
                        Hier eine Vorschau:
                        https://youtu.be/iDtKofIqIh8
                        Einfach den API-Key und die IP ersetzen. ;)
                        var http = require('http');
                        var apikey = '1234567891011121314'; // der API-Key von developer.lametric.com
                        var deviceIpAdress = '192.168.178.??'; // IP vom LaMetric
                        var port = '8080';
                        var cmd = '/api/v2/device/notifications';
                        var dataTemplate = {
                            model: {
                                cycles: 1,
                                frames: [{
                                    icon: 'i10462',
                                    text: null
                                sound: {
                                    category: 'notifications',
                        var optionsTemplate = {
                            port: port,
                            path: cmd,
                            method: 'POST',
                            headers: {
                                'Content-Length': null,
                                'Authorization': 'Basic ' + new Buffer('dev' + ':' + apikey).toString('base64')
                        function lametricNotification(notificationText) {
                            var data = dataTemplate;
                            data.model.frames[0].text = notificationText;
                            var dataString = JSON.stringify(data);
                            var options = optionsTemplate;
                            options.headers['Content-Length'] = dataString.length;
                            var req = http.request(options, function(res) {
                                log('http Status: ' + res.statusCode);
                                log('HEADERS: ' + JSON.stringify(res.headers), (res.statusCode != 200 ? 'warn' : 'info'));
                                var bodyChunks  = [];
                                res.on('data', function(chunk) {
                                    bodyChunks.push(chunk);
                                }).on('end', function() {
                                    var body = Buffer.concat(bodyChunks);
                                    log('body: ' + body);
                            req.on('error', function(e) {
                                log('ERROR: ' + e.message, 'warn');
                            (dataString ? req.write(dataString) : log('Daten: keine Daten im Body angegeben'));
                            req.end();
                        https://www.alefo.de
                        • ruhr70R Offline
                          ruhr70R Offline
                          ruhr70
                          Na das ist ja mal ein Einstieg :-)
                          • R Offline
                            ronnyw
                            Super, danke für die Hilfestellung.
                            Ich habe derweil den umgekehrten Weg probiert: eine Button-App auf der LaMetric schaltet ioBroker. Nachdem ich ein paar Grundlagen lernen musste, war das am Ende eigentlich ziemlich simpel zu realisieren über den Node-Red Adapter.
                            • ldittmarL Offline
                              ldittmarL Offline
                              ldittmar
                              Nur ein kurze Info zu LaMetric: LaMetric kann mit IFTTT kommunizieren und die neueste Version vom Cloud-Adapter (ab Version 1.0.2) wird IFTTT unterstützen. ;)
                              Grüße,
                              ldittmar
                                mdsv
                                Ergänzend von den Möglichkeiten:
                                Es gibt Notification … per Script steuerbar als einmalig eingeblendete Nachrichten, z.B. "Fenster auf".
                                Es gibt (Indication) Apps. Durch linke / rechte Taste kann auf seine eigene Apps umschalten, die dann Statusmeldungen anzeigen (folgende Fenster sind offen ...., Benzinpreis ist ...). Per Script erfolgt im Hintergrund eine Aktualisierung. Bei Interesse kann man sich informieren.
                                Und natürlich die Button Apps... z.B. Anzeige einer Mülltonne -> wenn man sie rausgebracht hat und in der Mitte drückt, dann wird per Http-Request die Systemvariable wieder false gesetzt. Durch ein Script wird zum Zeitpunkt auf diese Apps komplett umgeschaltet und es wird dann das gewünschte Symbol angezeigt, statt der Uhr.
                                Das beste finde ich inzwischen:
                                Es zeigt unscheinbar eine Uhr an, aber wenn die Alarmanlage scharf ist, dann eben ein Symbol und eine Warnung. Falls manchmal Geofency nicht richtig die Deaktivierung vornimmt. Das Umschalten auf diese habe ich über das Umschalten auf diese Apps per Script gelöst. Finde ich sogar besser, als irgendwelche große Bildschirme, wo jeder Besucher die Augen verdreht.
                                Die Geschwindigkeit ist auch beeindruckend, wenn dies über Script erfolgt.
                                Was habt Ihr so?
                                • R Offline
                                  ronnyw
                                  Dank der Vorarbeit hier bin ich schon relativ weit gekommen.
                                  Das Script, das Ben angepasst hat, funktioniert erstmal ganz gut, ich bekomme alle möglichen Arten von Notifications hin.
                                  Darauf aufbauend wollte ich jetzt den Inhalt von Indicator-Apps verändern.
                                  Ich hab dafür das gleiche Script genutzt, den Pfad angepasst, so wie es in dem Developerbereich vorgeschlagen wird. Also für die var cmd habe ich z.B. "api/v1/dev/widget/update/com.lametric.<id>/1" gesetzt.
                                  Das Dataformat hab ich auch angepasst.
                                  Nun habe ich wahlweise zwei Fehler.
                                  Wenn ich das per http auf Port 8080 probiere, bekomme ich von der LaMatric den Error "Wrong API Key". Versteh ich nicht. Es gibt ja nur einen, der in dem gleichen Script mit der normalen Notification funktioniert.
                                  Wenn ich wie im Developerbereich von LaMetric vorgeschlagen lokal https nutze und den Port auf 4343 setze bekomme ich im Log "unable to very the first certificate" - kenne mich aber mit der Zertifikatskette nicht aus. Per CURL mit dem Beispielaufruf aus dem Developerbereich funktioniert alles (auch per https).
                                  Ich weiß also weder, ob ich eigentlich SSL nutzen MUSS (und wie ich aus dem Zertifikatsfehler rauskomme) oder warum ich den "wrong API key" zurückbekomme.
                                  @mdsv, wie steuerst Du die Infos Indicator-Apps von ioBroker aus?!</id>
                                    mdsv
                                    http://xx.xx.xx.xx:8080 mit lokaler IP Adresse geht … siehe auch https://developer.lametric.com .. dort sind die Beispiele.
                                    Bei mir ging SSL mit lokaler IP auch nicht, aber ist lokal auch nicht notwendig
                                    Oder SSL über Internet … aber warum drüber schleusen?
                                    • R Offline
                                      ronnyw
                                      @mdsv:
                                      Oder SSL über Internet … aber warum drüber schleusen? `
                                      Genau, über den LaMetric Server wollte ich auch nicht gehen, nur lokal. Danke, dass Du bestätigst, dass es auch ohne SSL geht (ich hatte in irgendeinem Forenbeitrag bei LaMetric aufgeschnappt, dass bestimmte Funktionen nur über SSL gehen - vielleicht ist das aber auch schon wieder überholt). Allerdings bleibt dann das Problem, dass ich einen "wrong API key" zurückbekomme.
                                      Hier mal meine angepasste Funktion:
                                      var apikey = '1234'; // API-Key von developer.lametric.com
                                      var deviceIpAddress = getState("javascript.0.LaMetric.Device.IPAddress").val; // LaMetric IP
                                      var port = '8080';
                                          host: deviceIpAddress,
                                          port: port,
                                          path: null,
                                          method: 'POST',
                                          headers: {
                                      function LaMetricIndicator(options,data) {
                                              log('HEADERS: ' + JSON.stringify(res.headers), (res.statusCode != 201 ? 'warn' : 'info'));
                                          req.end();
                                      // Indicator Fensterstatus setzen
                                      optionsTemplate.path = '/api/v1/dev/widget/update/com.lametric.<hier-ein-schlüssel-dessen-vertraulichkeit-ich-nicht-einschätzen-kann>/1';
                                          frames:[{
                                              text: 'Alle zu.',
                                              icon: 'a135',
                                              index: 0,
                                      // Notification
                                      optionsTemplate.path = '/api/v2/device/notifications';
                                          model: {
                                              cycles: 0,
                                              frames: [{
                                                  icon: 'i10462',
                                                  text: 'Hallo Welt.'
                                              sound: {
                                      LaMetricIndicator(optionsTemplate,dataTemplate);</hier-ein-schlüssel-dessen-vertraulichkeit-ich-nicht-einschätzen-kann>
                                      Indicator geht nicht ("wrong api key"), Notification geht :roll:
                                      (der Sample-Push-Request mit CURL, der einem auf der Developer-Seite mitgegeben wird, funktioniert. (EDIT: Diese Annahme war wohl falsch, zumindest ist es nicht das gleiche! >) Dort wird der API Key ja in den Token encoded (< Ende falsch ;-) ), das Data-Schema sieht gleich aus… ich finde den Unterschied nicht)
                                      • R Offline
                                        ronnyw
                                        Mit einem Tipp vom LaMetric-Support funktioniert es jetzt doch. Ich dachte zwar, dass ich die Kombination auch ausprobiert hätte, aber anscheinend nicht: die Indicator Apps brauchen als Authentifizierung immer den generierten Token (von dem ich erst dachte er wäre das gleiche wie der in dem Script base64 encodete API Key - ist er aber nicht) in den Headern ("X-Access-Token"), die Notification braucht als Authentifizierung wie in dem Beispiel den API-Key ("Authorization"). (Als Fehlermeldung bei der Indicator App wäre vielleicht statt "Wrong API Key" hilfreicher gewesen "Wrong/missing Token" - das hätte mich eher drauf gebracht ;-) )
                                        Nun habe ich verschiedene Anzeigebereiche in der LaMetric:
                                        Fensterstatus
                                        Aktuelle gespielte Liedtitel (Chromecast)
                                        Status von Waschmaschine und Trockner mit Benachrichtigung wenn eins fertig ist (steht in der Waschküche im Keller)
                                        Wetterdaten (die nicht von einer eigenen Wetterstation kommen sondern von einer Station der nahegelegenen Uni geparsed werden)
                                        Als nächstes möchte ich ein paar Komfortfunktionen umsetzen:
                                        "Aufstehen"
                                        "Zu Bett gehen"
                                        "Wohnung verlassen"
                                        "Anwesend"
                                        Wie von mdsv schon erwähnt, können dann die jeweiligen Apps (jede Funktion ist eine eigene kleine App) zu bestimmten Zeiten in den Vordergrund geholt werden, so dass man nicht durchschalten muss (was dann zumindest bei einem festen Tagesrhythmus funktioniert).
                                        Ich denke ich werde alles über Indicator-Apps lösen, die können alles, was eine Button-App kann, zusätzlich kann ich aber die Anzeigeinhalte flexibler gestalten.
                                        Wenn ich ein besserer Programmierer (mit mehr Zeit ;-) ) wäre, würde ein LaMetric-Adapter ja ziemlich naheliegen. In Gedanken habe ich schon den kompletten Status- und App-Objekte-Baum in ioBroker liegen, einfaches Ändern der angezeigten Inhalte über die Objekte. Die LaMetric-API ist - soweit ich das beurteilen kann - auch recht simpel. Wäre echt super, wenn diese "Uhr" mehr Anklang finden würde :-)
                                        Ach ja, ich habe noch ein Problem wenn ich Sonderzeichen in meinen Daten habe (z.B. würden einfache Umlaute im Text in dem Beispielscript derzeit nicht gehen). Hat das schon jemand gelöst? Wie muss ich das encoden?
                                          mdsv
                                          Wie es scheint, kann LaMetric keine Umlaute und unterdrückt Notification mit Umlauten sogar.
                                          Bei Unwetterwarnung filtere ich diese dann vorher raus.
                                          var txt2=txt.replace(/ä/, "ae");
                                          Geht bestimmt besser.
