  4. Sonoff Adapter Helligkeit Steuern
    6.0k
sonofftasmotatasmota gpio
25 Beiträge 4 Kommentatoren 2.4k Aufrufe 1 Beobachtet
  • Basti97B Basti97
    @ralla66 Ja der Zustand (Helligkeit) wird von Tasmota über MQTT geschickt und die Zahl bei Channel ändert sich. Aber andersherum funktioniert es nicht. Und unter Channel 1 lässt sich der Wert auch nicht ändern bzw der Datenpumkt ist nicht Schreibbar.
    Ralla66R Offline
    Ralla66R Offline
    Ralla66
    @basti97
    mal bitte Bild oder besser Text der Tasmota Konsole hochladen.
    Basti97B 1 Antwort Letzte Antwort
    • Ralla66R Ralla66
      @basti97
      Basti97B Offline
      Basti97B Offline
      Basti97
      schrieb am zuletzt editiert von Basti97
      @ralla66
      Das ist ein kurzer Log von Tasmota
      19:10:51.284 MQT: tele/tasmota_E1F8E3/STATE = {"Time":"2022-04-01T19:10:51","Uptime":"15T08:30:27","UptimeSec":1326627,"Heap":22,"SleepMode":"Dynamic","Sleep":10,"LoadAvg":99,"MqttCount":30,"POWER1":"ON","Channel1":72,"POWER2":"ON","Channel2":23,"Color":"B83B","Wifi":{"AP":1,"SSId":"SmartHome System Mira","BSSId":"B0:48:7A:D1:E0:9C","Channel":9,"Mode":"11n","RSSI":72,"Signal":-64,"LinkCount":1,"Downtime":"0T00:00:03"}}
      19:10:51.290 MQT: tele/tasmota_E1F8E3/SENSOR = {"Time":"2022-04-01T19:10:51","DS18B20":{"Id":"3C01B556775D","Temperature":27.1},"TempUnit":"C"}
      19:15:51.283 MQT: tele/tasmota_E1F8E3/STATE = {"Time":"2022-04-01T19:15:51","Uptime":"15T08:35:27","UptimeSec":1326927,"Heap":22,"SleepMode":"Dynamic","Sleep":10,"LoadAvg":99,"MqttCount":30,"POWER1":"ON","Channel1":72,"POWER2":"ON","Channel2":23,"Color":"B83B","Wifi":{"AP":1,"SSId":"SmartHome System Mira","BSSId":"B0:48:7A:D1:E0:9C","Channel":9,"Mode":"11n","RSSI":78,"Signal":-61,"LinkCount":1,"Downtime":"0T00:00:03"}}
      19:15:51.289 MQT: tele/tasmota_E1F8E3/SENSOR = {"Time":"2022-04-01T19:15:51","DS18B20":{"Id":"3C01B556775D","Temperature":27.1},"TempUnit":"C"}
      19:20:51.287 MQT: tele/tasmota_E1F8E3/STATE = {"Time":"2022-04-01T19:20:51","Uptime":"15T08:40:27","UptimeSec":1327227,"Heap":22,"SleepMode":"Dynamic","Sleep":10,"LoadAvg":99,"MqttCount":30,"POWER1":"ON","Channel1":72,"POWER2":"ON","Channel2":23,"Color":"B83B","Wifi":{"AP":1,"SSId":"SmartHome System Mira","BSSId":"B0:48:7A:D1:E0:9C","Channel":9,"Mode":"11n","RSSI":74,"Signal":-63,"LinkCount":1,"Downtime":"0T00:00:03"}}
      19:20:51.292 MQT: tele/tasmota_E1F8E3/SENSOR = {"Time":"2022-04-01T19:20:51","DS18B20":{"Id":"3C01B556775D","Temperature":27.2},"TempUnit":"C"}
      19:25:51.288 MQT: tele/tasmota_E1F8E3/STATE = {"Time":"2022-04-01T19:25:51","Uptime":"15T08:45:27","UptimeSec":1327527,"Heap":22,"SleepMode":"Dynamic","Sleep":10,"LoadAvg":99,"MqttCount":30,"POWER1":"ON","Channel1":72,"POWER2":"ON","Channel2":23,"Color":"B83B","Wifi":{"AP":1,"SSId":"SmartHome System Mira","BSSId":"B0:48:7A:D1:E0:9C","Channel":9,"Mode":"11n","RSSI":76,"Signal":-62,"LinkCount":1,"Downtime":"0T00:00:03"}}
      19:25:51.294 MQT: tele/tasmota_E1F8E3/SENSOR = {"Time":"2022-04-01T19:25:51","DS18B20":{"Id":"3C01B556775D","Temperature":27.3},"TempUnit":"C"}
      19:30:51.286 MQT: tele/tasmota_E1F8E3/STATE = {"Time":"2022-04-01T19:30:51","Uptime":"15T08:50:27","UptimeSec":1327827,"Heap":22,"SleepMode":"Dynamic","Sleep":10,"LoadAvg":99,"MqttCount":30,"POWER1":"ON","Channel1":72,"POWER2":"ON","Channel2":23,"Color":"B83B","Wifi":{"AP":1,"SSId":"SmartHome System Mira","BSSId":"B0:48:7A:D1:E0:9C","Channel":9,"Mode":"11n","RSSI":78,"Signal":-61,"LinkCount":1,"Downtime":"0T00:00:03"}}
      19:30:51.292 MQT: tele/tasmota_E1F8E3/SENSOR = {"Time":"2022-04-01T19:30:51","DS18B20":{"Id":"3C01B556775D","Temperature":27.1},"TempUnit":"C"}
      19:35:51.288 MQT: tele/tasmota_E1F8E3/STATE = {"Time":"2022-04-01T19:35:51","Uptime":"15T08:55:27","UptimeSec":1328127,"Heap":22,"SleepMode":"Dynamic","Sleep":10,"LoadAvg":99,"MqttCount":30,"POWER1":"ON","Channel1":72,"POWER2":"ON","Channel2":23,"Color":"B83B","Wifi":{"AP":1,"SSId":"SmartHome System Mira","BSSId":"B0:48:7A:D1:E0:9C","Channel":9,"Mode":"11n","RSSI":78,"Signal":-61,"LinkCount":1,"Downtime":"0T00:00:03"}}
      19:35:51.294 MQT: tele/tasmota_E1F8E3/SENSOR = {"Time":"2022-04-01T19:35:51","DS18B20":{"Id":"3C01B556775D","Temperature":27.2},"TempUnit":"C"}
      19:40:51.292 MQT: tele/tasmota_E1F8E3/STATE = {"Time":"2022-04-01T19:40:51","Uptime":"15T09:00:27","UptimeSec":1328427,"Heap":22,"SleepMode":"Dynamic","Sleep":10,"LoadAvg":99,"MqttCount":30,"POWER1":"ON","Channel1":72,"POWER2":"ON","Channel2":23,"Color":"B83B","Wifi":{"AP":1,"SSId":"SmartHome System Mira","BSSId":"B0:48:7A:D1:E0:9C","Channel":9,"Mode":"11n","RSSI":76,"Signal":-62,"LinkCount":1,"Downtime":"0T00:00:03"}}
      19:40:51.298 MQT: tele/tasmota_E1F8E3/SENSOR = {"Time":"2022-04-01T19:40:51","DS18B20":{"Id":"3C01B556775D","Temperature":27.1},"TempUnit":"C"}
      19:41:28.501 MQT: stat/tasmota_E1F8E3/RESULT = {"POWER1":"ON","Channel1":72,"POWER2":"ON","Channel2":22,"Color":"B838"}
      a7dd2f76-f3d9-4247-b805-e0718ef08adc-grafik.png Tasmota Oberfläche
      e7fb5a88-f717-499c-9450-ed0091b667c2-grafik.png iobroker Ansicht
      (Auszug Sonoff Adapter)
      Und Channel 1 und 2 ist nicht beschreibar.
      Iobroker läuft als VM auf Proxmoxserver x folgende Hersteller im Einsatz Sonoff, Gosund, Siemens x Aofo über Tasmota x Zigbee x das Smarthome wächst und wächst
      Ralla66R 1 Antwort Letzte Antwort
      • Basti97B Basti97
        @ralla66
        Ralla66R Offline
        Ralla66R Offline
        Ralla66
        @basti97
        Mal davon ausgehend das du Generic 18 und WS2812 an den GPIO eingestellt hast ist es
        fraglich ob überhaupt 2 Stripes steuerbar sind. Dann wäre zu prüfen ob die richtige .bin
        geflasht ist in der die WS2812 aktiv sind, Sollte dies der Fall sein sind die Anschlüsse am ESP
        GPIO zu prüfen. Die Beschaltung der Stripes muss sowie stimmen. Nicht jeder Ausgang am Esp
        kann hier eingestellt werden.
        Da Dimmer nicht in tele auftaucht ist die Einstellung oder die .bin falsch.
        J Basti97B 2 Antworten Letzte Antwort
        • Ralla66R Ralla66
          @basti97
          Jan1
          @ralla66 sagte in Sonoff Adapter Helligkeit Steuern:
          So ist es und solange das ni von Dimmer steht und er weiter auf den DPs Channel rum reitet bin ich hier eh raus.
          • Ralla66R Ralla66
            @basti97
            Basti97B Offline
            Basti97B Offline
            Basti97
            @ralla66 Wiso WS2812? Und was haben meine Ausgänge und config in Tasmota damit zutun.
            Wenn du richtig gelesen hast (hoffentlich) steht das die Bedienung in Tasmota funktioniert aber jedoch nicht über den Adapter dimmen lässt. Schalten funktioniert über den Adapter.
            Und zweitens weiß ich genau welche gpios ich dafür nehmen kann und welche nicht. :)
            • J Jan1
              Basti97B Offline
              Basti97B Offline
              Basti97
              @jan1 Das ist auch besser so weil auf deine sinnlosen Antworten kann ich verzichten die mich außerdem überhaupt nicht weiter gebracht haben. :)
              • mickymM Offline
                mickymM Offline
                mickym
                Der Sonoff Adapter ist kein Ersatz für einen mqtt-Broker. Er kann nur das machen was er weiß. Ich kann nur immer wieder betonen, wenn man Tasmota vollumfänglich nutzen möchte, dann sollte man einen richtigen mqtt Broker nehmen und den direkt oder indirekt über den mqtt-Adapter steuern. Ein Adapter, der mqtt Nachrichten interpretiert, kann nur das zur Verfügung stellen, was er kennt.
                • mickymM mickym
                  Basti97B Offline
                  Basti97B Offline
                  Basti97
                  @mickym Ok das ist doch eine gute Antwort. :) Was aber komisch ist über Chanel 1 und 2 bekommt er die Helligkeit über MQtt geschickt. Aber ich kann den Wert des Datenpunktes nicht ändern. Auch die Angaben von red, blue, green bräuchte ich bei zwei weiß Strips nicht. Ich habe die funktion per SetOption68 1 aktviert. Würde das funktionieren das ich die Helligkeit über Request zum ESP (tasmota schicke) und die tatsächlichen Werte (Channel1 und 2) per Sonoff Adapter zurückbekomme.
                  • Basti97B Basti97
                    mickymM Offline
                    mickymM Offline
                    mickym
                    Ich habe, um ehrlich zu sein, keine Ahnung von dem Sonoff Adapter im Detail, weil ich alle Adapter, die mqtt interpretieren grundsätzlich meide. Wenn Du weißt, wie Du in diesem Adapter Konsolen kommandos verschickst, die nicht interpretiert werden, dann sollte die Rückmeldung kommen.
                    Du kannst natürlich http und mqtt (vom Sonoff Adapter) kombinieren. Dann müsstest Du diese OPtion ggf. so schicken:
                    http://<ip>/cm?cmnd=SetOption68%201
                    Zumindest scheint diese Syntax den Konsolenbefehl zu schlucken:
                    Funktionieren denn die Dimmer Commands nicht?
                    Wie gesagt würde ich halt alles mal über http testen und wenn das tut musst Du halt hybrid fahren oder stellst halt doch auf einen richtigen mqtt Broker um.
                    Das Problem ist wie gesagt - intern hört Tasmota im mqtt nur auf den cmnd Ast, der stat und der tele Ast ist nur Info über den Status. Der Adapter zeigt in den Datenpunkten in meinen Augen nur den Status. Wenn Du den Datenpunkt änderst published er quasi in den cmnd Ast. Wenn das aber nicht vorgesehen ist, dann ist halt Mist.
                    Unter mqtt hast Du eben diese 3 Äste. Wenn man ein Kommando öfter braucht, dann erstellt man einfach einen neuen Datenpunkt ansonsten kannst Du über den backlog Datenpunkt direkt die Konsolenkommandos im Tasmota absetzen:
                    • Basti97B Basti97
                      Ralla66R Offline
                      Ralla66R Offline
                      Ralla66
                      @basti97
                      ja dann, du kannst ja alles, nur komisch das es bei Jan1 und mir läuft, auch mit Sonoff Adapter als Broker. 😀
                      • mickymM mickym
                        Basti97B Offline
                        Basti97B Offline
                        Basti97
                        @mickym Vielen Dank für die Ausführliche Anleitung. Wenn ich am PC bin Probiere ich es aus. Einen eigenen Datenpunkt könnte ich jetzt nicht im Sonoff Ordner erstellen.
                        • Ralla66R Ralla66
                          @basti97
                          Basti97B Offline
                          Basti97B Offline
                          Basti97
                          @ralla66 Ja das ist halt blöde weil ich die Datenpunkte wie Red unso nicht brauche. Ich weiß auch nicht warum der das anlegt weil in der Tasmota Version ist es ja auch nicht als RGB definiert sondern als zwei mal weiß. Wenn ich die Datenpunkte im Sonoff Adapter lösche kommt eine Fehlermeldung im iob Log.😀
