  4. nach NodeJS update 16.x startet zigbee nicht mehr
    6.3k
10 Beiträge 5 Kommentatoren 1.3k Aufrufe 5 Beobachtet
  • ChrisNettC Offline
    ChrisNettC Offline
    ChrisNett
    Systemdata Bitte Ausfüllen
    Hardwaresystem: Pi4.
    Arbeitsspeicher: 4GB
    Festplattenart: SD-Karte&
    Betriebssystem: Ubuntu/Windows/Mac
    Node-Version:
    Nodejs-Version: v16.14.2
    NPM-Version: 8.5.0
    Installationsart: Manuell
    Image genutzt: JNein
    huhu ich wollte JS auf 4.0 updaten scheitere aber schon bei NodeJS 16... den fix für den Klf habe ich noch hinbekommen aber der zigbee adatper starte trotz
    iobroker rebuild zigbee.0
    nicht mehr
    hier noch der log nach einem neustart des adapters
    host.PI4	2022-03-31 11:18:06.907	info	Rebuild for adapter system.adapter.zigbee.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
    host.PI4	2022-03-31 11:18:06.907	error	instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.PI4	2022-03-31 11:18:06.907	error	Caught by controller[0]: }
    host.PI4	2022-03-31 11:18:06.906	error	Caught by controller[0]: code: 'ERR_DLOPEN_FAILED'
    host.PI4	2022-03-31 11:18:06.906	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:981:32) {
    host.PI4	2022-03-31 11:18:06.906	error	Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1157:10)
    host.PI4	2022-03-31 11:18:06.906	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1103:14)
    host.PI4	2022-03-31 11:18:06.906	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/lib/linux.js:2:36)
    host.PI4	2022-03-31 11:18:06.906	error	Caught by controller[0]: at bindings (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/bindings/bindings.js:112:48)
    host.PI4	2022-03-31 11:18:06.905	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:102:18)
    host.PI4	2022-03-31 11:18:06.905	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1005:19)
    host.PI4	2022-03-31 11:18:06.905	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:822:12)
    host.PI4	2022-03-31 11:18:06.905	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:981:32)
    host.PI4	2022-03-31 11:18:06.904	error	Caught by controller[0]: at Object.Module._extensions..node (node:internal/modules/cjs/loader:1187:18)
    host.PI4	2022-03-31 11:18:06.904	error	Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
    host.PI4	2022-03-31 11:18:06.904	error	Caught by controller[0]: NODE_MODULE_VERSION 93. Please try re-compiling or re-installing
    host.PI4	2022-03-31 11:18:06.904	error	Caught by controller[0]: NODE_MODULE_VERSION 72. This version of Node.js requires
    host.PI4	2022-03-31 11:18:06.904	error	Caught by controller[0]: was compiled against a different Node.js version using
    host.PI4	2022-03-31 11:18:06.903	error	Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build/Release/bindings.node'
    host.PI4	2022-03-31 11:18:06.903	error	Caught by controller[0]: ^
    host.PI4	2022-03-31 11:18:06.903	error	Caught by controller[0]: throw e;
    host.PI4	2022-03-31 11:18:06.902	error	Caught by controller[0]: /opt/iobroker/node_modules/zigbee-herdsman/node_modules/bindings/bindings.js:121
    host.PI4	2022-03-31 11:18:05.003	info	instance system.adapter.zigbee.0 started with pid 10673
    host.PI4	2022-03-31 11:18:04.798	info	"system.adapter.zigbee.0" enabled
    host.PI4	2022-03-31 11:18:02.262	info	"system.adapter.zigbee.0" disabled
    an was könnte es liegen?
    • ChrisNettC ChrisNett
      Node-Version:
      NPM-Version: 8.5.0
      nicht mehr
      AsgothianA Offline
      AsgothianA Offline
      Asgothian
      @christian-sandkaulen
      Log lesen. Da steht
      • woran es liegt
      • was zu tun ist
      Wichtig: Log einträge müssen in der richtigen Reihenfolge gelesen werden, in diesem Fall "von unten" :
      Klartext: Das hardwarenahe Modul /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build/Release/bindings.node (übersetzt für NODE_MODULE_VERSION 72) passt nicht zur aktuell installierten Node.JS version (NODE_MODULE_VERSION 93).
      Um das Problem zu beheben:
      Auf die Konsole gehen, in das Verzeichnis /opt/iobroker, npm rebuild ausführen.
      A.
      ChrisNettC OliverIOO 2 Antworten Letzte Antwort
      • AsgothianA Asgothian
        Log lesen. Da steht
        • woran es liegt
        • was zu tun ist
        A.
        ChrisNettC Offline
        ChrisNettC Offline
        ChrisNett
        @asgothian
        danke dann kann ich jetzt den JS Cont updaten
        zigbee.0	2022-03-31 11:41:20.634	info	(18523) Zigbee started
          Log lesen. Da steht
          • woran es liegt
          • was zu tun ist
          A.
          OliverIOO Offline
          OliverIOO Offline
          OliverIO
          Ist evtl etwas verwirrend. ganz oben steht was anderes
          Und geht wahrscheinlich schneller, weil nicht alles neu compiliert wird.
          Meine Adapter und Widgets
          Links im Profil
          • OliverIOO OliverIO
            AsgothianA Offline
            AsgothianA Offline
            Asgothian
            @oliverio sagte in nach NodeJS update 16.x startet zigbee nicht mehr:
            Geht ggf. schneller weil nicht alles neu kompiliert wird - geht aber auch in die Hose, weil nicht alles neu kompiliert wird.
            Das "Wurde nicht neu kompiliert" ist genau die Ursache des Fehlers.
            A.
            ChrisNettC 1 Antwort Letzte Antwort
              A.
              ChrisNettC Offline
              ChrisNettC Offline
              ChrisNett
              hat aber echt auch lange gedauert, ist aber ja nicht weiter schlimm.
                toki1973
                @christian-sandkaulen @Asgothian
                Danke für den Post. Ich habe genau den gleichen Fehler nach node.js Update von 12 auf 14.
                Habe nun npm rebuild ausgeführt. Kann man da den Status verfolgen? Nach 30 Minuten ist die Putty Verbindung unterbrochen worden. Nun weiß ich nicht ob sich noch etwas tut oder es schief gegangen ist.
                NUC, PROXMOX, Grafana, Influx, Unify
                • T toki1973
                  @toki1973
                  Wieder anmelden. Und nochmal schauen. Wenn das rebuild unterbrochen wurde sieht man das im Log.
                    @toki1973
                    toki1973
                    Anmelden über Putty funktioniert nicht mehr :(
                    Über die Proxmoxkonsole Konsole komme ich soweit
                    • T toki1973
                      @toki1973
                      Mach einen eigenen Thread auf. Da ist vielleicht im Proxmurks was kaputt. Hab ich aber nix mit am Hut.
