  4. [erledigt] Backup Fehler
    6.3k
59 Beiträge 8 Kommentatoren 5.7k Aufrufe 6 Beobachtet
  • H Offline
    hm_krause
    beim Backup kommt folgender Fehler.
    Started iobroker ...
    [DEBUG] [iobroker] - host.iobroker 190162 states saved
    [DEBUG] [iobroker] - host.iobroker 234950 objects saved
    [ERROR] [iobroker] -
    <--- Last few GCs --->
    [192216:0x2cb4bad0]   415581 ms: Mark-sweep (reduce) 2050.3 (2051.6) -> 2050.3 (2053.6) MB, 939.2 / 0.0 ms  (average mu = 0.335, current mu = 0.015) allocation failure scavenge might not succeed
    <--- JS stacktrace --->
    FATAL ERROR: MarkCompactCollector: young object promotion failed Allocation failed - JavaScript heap out of memory
    [ERROR] [iobroker] -  1: 0xa2f1a8 node::Abort() [/usr/bin/node]
     2: 0x975a58 node::FatalError(char const*, char const*) [/usr/bin/node]
    [ERROR] [iobroker] -  3: 0xb947e0 v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, bool) [/usr/bin/node]
    [ERROR] [iobroker] -  4: 0xb9496c v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, bool) [/usr/bin/node]
    [ERROR] [iobroker] -  5: 0xd3d088 v8::internal::Heap::EnsureFromSpaceIsCommitted() [/usr/bin/node]
    [ERROR] [iobroker] -  6: 0xd6aae0 v8::internal::EvacuateNewSpaceVisitor::Visit(v8::internal::HeapObject, int) [/usr/bin/node]
    [ERROR] [iobroker] -  7: 0xd758fc v8::internal::FullEvacuator::RawEvacuatePage(v8::internal::MemoryChunk*, long*) [/usr/bin/node]
    [ERROR] [iobroker] -  8: 0xd63688 v8::internal::Evacuator::EvacuatePage(v8::internal::MemoryChunk*) [/usr/bin/node]
     9: 0xd63920 v8::internal::PageEvacuationTask::RunInParallel(v8::internal::ItemParallelJob::Task::Runner) [/usr/bin/node]
    [ERROR] [iobroker] - 10: 0xd56fc0 v8::internal::ItemParallelJob::Run() [/usr/bin/node]
    11: 0xd773a8 void v8::internal::MarkCompactCollectorBase::CreateAndExecuteEvacuationTasks<v8::internal::FullEvacuator, v8::internal::MarkCompactCollector>(v8::internal::MarkCompactCollector*, v8::internal::ItemParallelJob*, v8::internal::MigrationObserver*, long) [/usr/bin/node]
    [ERROR] [iobroker] - 12: 0xd77b20 v8::internal::MarkCompactCollector::EvacuatePagesInParallel() [/usr/bin/node]
    13: 0xd77cb4 v8::internal::MarkCompactCollector::Evacuate() [/usr/bin/node]
    [ERROR] [iobroker] - 14: 0xd88a28 v8::internal::MarkCompactCollector::CollectGarbage() [/usr/bin/node]
    [ERROR] [iobroker] - 15: 0xd4a80c v8::internal::Heap::MarkCompact() [/usr/bin/node]
    [ERROR] [iobroker] - 16: 0xd4bd88 v8::internal::Heap::CollectGarbage(v8::internal::AllocationSpace, v8::internal::GarbageCollectionReason, v8::GCCallbackFlags) [/usr/bin/node]
    17: 0xd4ec84 v8::internal::Heap::AllocateRawWithRetryOrFailSlowPath(int, v8::internal::AllocationType, v8::internal::AllocationOrigin, v8::internal::AllocationAlignment) [/usr/bin/node]
    [ERROR] [iobroker] - 18: 0xd17c28 v8::internal::Factory::AllocateRaw(int, v8::internal::AllocationType, v8::internal::AllocationAlignment) [/usr/bin/node]
    [ERROR] [iobroker] - 19: 0xd117a0 v8::internal::FactoryBase<v8::internal::Factory>::AllocateRawWithImmortalMap(int, v8::internal::AllocationType, v8::internal::Map, v8::internal::AllocationAlignment) [/usr/bin/node]
    [ERROR] [iobroker] - 20: 0xd137fc v8::internal::FactoryBase<v8::internal::Factory>::NewRawOneByteString(int, v8::internal::AllocationType) [/usr/bin/node]
    [ERROR] [iobroker] - 21: 0xe24514 v8::internal::JsonParser<unsigned short>::MakeString(v8::internal::JsonString const&, v8::internal::Handle<v8::internal::String>) [/usr/bin/node]
    22: 0xe25c4c v8::internal::JsonParser<unsigned short>::ParseJsonValue() [/usr/bin/node]
    [ERROR] [iobroker] - 23: 0xe26a8c v8::internal::JsonParser<unsigned short>::ParseJson() [/usr/bin/node]
    24: 0xc38c64  [/usr/bin/node]
    [ERROR] [iobroker] - 25: 0xc392b8 v8::internal::Builtin_JsonParse(int, unsigned long*, v8::internal::Isolate*) [/usr/bin/node]
    [ERROR] [iobroker] - 26: 0x139eacc  [/usr/bin/node]
    [DEBUG] [iobroker] - done
    [DEBUG] [cifs] - Copy iobroker_2022_03_20-09_41_12_backupiobroker.tar.gz...
    [ERROR] [cifs] - Error: ENOENT: no such file or directory, open '/opt/iobroker/backups/iobroker_2022_03_20-09_41_12_backupiobroker.tar.gz'
    [DEBUG] [cifs] - done
    [ERROR] [clean] - Backup files not deleted from /opt/iobroker/backups because some errors.
    [DEBUG] [clean] - done
    [DEBUG] [historyHTML] - new history html values created
    [DEBUG] [historyHTML] - done
    [DEBUG] [historyJSON] - new history json values created
    [DEBUG] [historyJSON] - done
    [EXIT] 0
    • H hm_krause
      [EXIT] 0
      Jan1
      @hm_krause sagte in Backitup Fehler:
      Da geht wohl der RAM aus.
      Edit:
      Wobei das bei 8GB nie und nimmer passieren sollte.
      H Thomas BraunT 2 Antworten Letzte Antwort
      • H Offline
        hm_krause
        folgender Hergang:
        am 17.03. System neu aufgesetzt wegen Backup Fehler
        am 18.03 Backup komplett i.O. (alles so wie eingestellt, Influxdb, Iobroker, History...)
        gestern und heute Iobroker Fehler (nur dieser)
        Könnt Ihr mir bitte helfen?
        • J Jan1
          Edit:
          hm_krause
          @jan1
          pi@iobroker:~ $ df -h
          Dateisystem    Größe Benutzt Verf. Verw% Eingehängt auf
          /dev/root       235G    7,2G  218G    4% /
          devtmpfs        3,7G       0  3,7G    0% /dev
          tmpfs           3,9G       0  3,9G    0% /dev/shm
          tmpfs           1,6G    884K  1,6G    1% /run
          tmpfs           5,0M    4,0K  5,0M    1% /run/lock
          /dev/sda1       253M     30M  223M   12% /boot
          /dev/sdb1        30G    3,7G   26G   13% /media/usbstick
          tmpfs           782M       0  782M    0% /run/user/1000
          Thomas BraunT J 2 Antworten Letzte Antwort
          • H hm_krause
            @jan1
            @hm_krause
            Das ist der Festplattenplatz, nicht der Arbeitsspeicher.
            Ich vermute, das die Zahl der Objekte / States zu hoch ist.
            • H hm_krause
              @jan1
              Jan1
              df -h
              Damit zeigst ja auch nur die Festplatte an. Ich denke der RAM wird beim Backup erstellen voll laufen. Ich habe "nur" 4GB und damit keine Probleme. Ist eben die Fehlermeldung, die mir als erstes ins Auge sticht.
              • H Offline
                hm_krause
                ...hilft Euch das weiter?
                J apollon77A 2 Antworten Letzte Antwort
                • H hm_krause
                  Jan1
                  @hm_krause
                  Das würde wohl Thomas Verdacht bestätigen, da das ja wirklich extrem viel ist.
                  • H Offline
                    hm_krause
                    Hier mal die Ausgabe bei wechsel von "Instanzen" auf "Backitup" Button
                    pi@iobroker:~ $ top
                    top - 10:17:50 up 2 days, 15:38,  1 user,  load average: 2,44, 2,01, 1,57
                    Tasks: 167 total,   3 running, 164 sleeping,   0 stopped,   0 zombie
                    %CPU(s): 47,7 us,  2,0 sy,  0,0 ni, 50,0 id,  0,0 wa,  0,0 hi,  0,2 si,  0,0 st
                    MiB Spch:   7812,0 total,   3478,3 free,   3065,3 used,   1268,4 buff/cache
                    MiB Swap:    100,0 total,     98,5 free,      1,5 used.   4683,3 avail Spch
                        PID USER      PR  NI    VIRT    RES    SHR S  %CPU  %MEM     ZEIT+ BEFEHL
                       2251 iobroker  20   0 2145980   1,3g  34684 R 181,8  16,8   2133:56 iobroker.js-con
                        663 influxdb  20   0  329108 119796  28244 S   7,3   1,5  23:24.98 influxd
                       2376 iobroker  20   0  939160  84032  34604 S   3,6   1,1  30:33.46 io.tr-064.0
                       2382 iobroker  20   0  943500 110396  31032 S   3,6   1,4 167:25.32 io.zigbee.0
                       2332 iobroker  20   0  884284  93652  29516 S   0,7   1,2  28:00.90 io.mqtt.1
                     194075 pi        20   0    9964   3444   2824 R   0,7   0,0   0:00.19 top
                         89 root     -51   0       0      0      0 S   0,3   0,0   7:20.66 irq/51-mmc0
                        659 grafana   20   0 1746392  86648  54060 S   0,3   1,1   6:13.63 grafana-server
                       2317 iobroker  20   0  678692  74192  29600 S   0,3   0,9   4:20.01 io.mqtt.0
                       2464 iobroker  20   0  670668  74604  34388 S   0,3   0,9   3:01.61 io.shuttercontr
                     193495 root      20   0       0      0      0 I   0,3   0,0   0:02.04 kworker/1:1-events_freezable
                          1 root      20   0  165944  10164   7224 S   0,0   0,1   0:05.95 systemd
                          2 root      20   0       0      0      0 S   0,0   0,0   0:00.27 kthreadd
                          3 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 rcu_gp
                          4 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 rcu_par_gp
                          6 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 kworker/0:0H-events_highpri
                          8 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 mm_percpu_wq
                    • H hm_krause
                      pi@iobroker:~ $ top
                      HomoranH Offline
                      HomoranH Offline
                      jepp, da hängt es
                      Wie groß ist dein Backup?
                      H 1 Antwort Letzte Antwort
                        jepp, da hängt es
                        hm_krause
                        ...da lief noch kein Backup, das war nur ein Wechsel von Instanzen auf Backup.
                        Backupgröße von Iobroker= 23091KB
                        • H hm_krause
                          HomoranH Offline
                          HomoranH Offline
                          Meinst du einen "Reiter"-Wechsel?
                          dann sieh mal in der Browserkonsole nach, was da soviel Ressourcen frisst
                            hm_krause
                            -Ja-
                            • mache ich wie?
                            • H hm_krause
                              -Ja-
                              • mache ich wie?
                              HomoranH Offline
                              HomoranH Offline
                              mache ich wie?
                              F12
                                mache ich wie?
                                F12
                                hm_krause
                                ? so ?
                                • J Jan1
                                  Edit:
                                  @jan1 sagte in Backitup Fehler:
                                  Edit:
                                  Der Heap hat nicht (viel) mit dem verbauten Ram zu tun.
                                    Edit:
                                    Jan1
                                    Das bezog sich auf meine Vermutung, dass der RAM voll läuft, da das der einzige Hinweis im Log war mit dem ich was anfangen konnte ;)
                                    Und das 8GB voll laufen mit IOBroker ist nun mal sehr unwahrscheinlich.
                                    • H hm_krause
                                      ? so ?
                                      HomoranH Offline
                                      HomoranH Offline
                                      ? so ?
                                      ja!
                                      aber da bist du doch während eines backups
                                      • H Offline
                                        hm_krause
                                        Sorry, mein Hund hat sein Recht eingefordert.
                                        Hatte zwischendurch ein :
                                        sudo apt update && sudo apt full-upgrade
                                        durchgeführt.
                                        Hier wurde node auf v14.19.1 angehoben, jetzt warte ich nach einem reboot auf den Iobroker
                                        • H hm_krause
                                          durchgeführt.
                                          HomoranH Offline
                                          HomoranH Offline
                                          @hm_krause auf deinem Screenshot läuft doch gerade ein Backup, oder was ist das?
                                          nur ein Reiterwechsel scheint das nicht zu sein
