  4. [gelöst] Samsung Internet Browser Problem mit ioBroker
    6.3k
internetsamsungwebgui
22 Beiträge 6 Kommentatoren 1.7k Aufrufe 6 Beobachtet
  • R Rushmed
    @sigi234 ja
    iobroker.admin@5.1.28
    socket.io.js:59 [2021-12-04T12:10:21.256Z] Try to connect
    socket.io.js:91 WebSocket connection to 'ws://192.168.178.20:8081/?sid=1638619821257&name=admin' failed: Error in connection establishment: net::ERR_SSL_PROTOCOL_ERROR
    SocketClient.connect @ socket.io.js:91
    (anonymous) @ Connection.ts:239
    u @ runtime.js:63
    (anonymous) @ runtime.js:294
    (anonymous) @ runtime.js:119
    n @ asyncToGenerator.js:3
    i @ asyncToGenerator.js:25
    (anonymous) @ asyncToGenerator.js:32
    (anonymous) @ asyncToGenerator.js:21
    (anonymous) @ 5.fdbcba88.chunk.js:2
    (anonymous) @ Connection.ts:99
    socket.io.js:59 [2021-12-04T12:10:21.344Z] Start reconnect 0
    socket.io.js:61 [2021-12-04T12:10:21.345Z] ws connection error: CLOSE_ABNORMAL
    error @ socket.io.js:61
    socket.onclose @ socket.io.js:128
    socket.io.js:59 [2021-12-04T12:10:21.345Z] Reconnect is already running 0
    socket.io.js:59 [2021-12-04T12:10:21.368Z] Try to connect
    socket.io.js:91 WebSocket connection to 'ws://192.168.178.20:8081/?sid=1638619821370&name=admin' failed: Error in connection establishment: net::ERR_SSL_PROTOCOL_ERROR
    (anonymous) @ socket.io.js:372
    socket.io.js:59 [2021-12-04T12:10:21.429Z] Start reconnect 1
    socket.io.js:61 [2021-12-04T12:10:21.430Z] ws connection error: CLOSE_ABNORMAL
    socket.io.js:59 [2021-12-04T12:10:21.430Z] Reconnect is already running 1
    socket.io.js:59 [2021-12-04T12:10:22.430Z] Try to connect
    socket.io.js:91 WebSocket connection to 'ws://192.168.178.20:8081/?sid=1638619822432&name=admin' failed: Error in connection establishment: net::ERR_SSL_PROTOCOL_ERROR
    socket.io.js:59 [2021-12-04T12:10:22.520Z] Start reconnect 2
    socket.io.js:61 [2021-12-04T12:10:22.521Z] ws connection error: CLOSE_ABNORMAL
    socket.io.js:59 [2021-12-04T12:10:22.521Z] Reconnect is already running 2
    socket.io.js:59 [2021-12-04T12:10:24.521Z] Try to connect
    socket.io.js:91 WebSocket connection to 'ws://192.168.178.20:8081/?sid=1638619824521&name=admin' failed: Error in connection establishment: net::ERR_SSL_PROTOCOL_ERROR
    socket.io.js:59 [2021-12-04T12:10:24.582Z] Start reconnect 3
    socket.io.js:61 [2021-12-04T12:10:24.583Z] ws connection error: CLOSE_ABNORMAL
    socket.io.js:59 [2021-12-04T12:10:24.583Z] Reconnect is already running 3
    socket.io.js:59 [2021-12-04T12:10:27.583Z] Try to connect
    socket.io.js:91 WebSocket connection to 'ws://192.168.178.20:8081/?sid=1638619827584&name=admin' failed: Error in connection establishment: net::ERR_SSL_PROTOCOL_ERROR
    socket.io.js:59 [2021-12-04T12:10:27.674Z] Start reconnect 4
    socket.io.js:61 [2021-12-04T12:10:27.674Z] ws connection error: CLOSE_ABNORMAL
    socket.io.js:59 [2021-12-04T12:10:27.675Z] Reconnect is already running 4
    socket.io.js:59 [2021-12-04T12:10:31.675Z] Try to connect
    socket.io.js:91 WebSocket connection to 'ws://192.168.178.20:8081/?sid=1638619831676&name=admin' failed: Error in connection establishment: net::ERR_SSL_PROTOCOL_ERROR
    socket.io.js:59 [2021-12-04T12:10:31.764Z] Start reconnect 5
    socket.io.js:61 [2021-12-04T12:10:31.767Z] ws connection error: CLOSE_ABNORMAL
    socket.io.js:59 [2021-12-04T12:10:31.775Z] Reconnect is already running 5
    socket.io.js:59 [2021-12-04T12:10:36.767Z] Try to connect
    socket.io.js:91 WebSocket connection to 'ws://192.168.178.20:8081/?sid=1638619836768&name=admin' failed: Error in connection establishment: net::ERR_SSL_PROTOCOL_ERROR
    socket.io.js:59 [2021-12-04T12:10:36.857Z] Start reconnect 5
    socket.io.js:61 [2021-12-04T12:10:36.858Z] ws connection error: CLOSE_ABNORMAL
    socket.io.js:59 [2021-12-04T12:10:36.859Z] Reconnect is already running 5
    sigi234S Online
    sigi234S Online
    @rushmed
    Zeig mal Instanzeinstellungen: socketio.0
    • R Offline
      Rushmed
      schrieb am zuletzt editiert von Rushmed
      Ich habe weder HTTPS noch eine socketio. Instanz.
      Ich leg mal eine an.
      Edit:
      Authentifizierung habe ich aktiv.
      Mit dem alten Admin UI komme ich schonmal zum Login Screen und bleibe danach hängen.
      • R Rushmed
        Ok, habe jetzt debug Zugriff auf den Samsung Browser. Wo kann ich da nach Problemen suchen?
        Fehlt der App etwa Javascript?
        FeuersturmF Offline
        FeuersturmF Offline
        Feuersturm
        @rushmed sagte in Samsung Internet Browser Problem mit ioBroker Web UI:
        Wie hast du das gemacht?
        • GlasfaserG Offline
          GlasfaserG Offline
          Samsung (Android) Internet Browsern
          Ohmm .. das ist aber Google laut deinem Screenshot
          • R Offline
            Rushmed
            @Feuersturm Link
            @Glasfaser siehe Link der Debugging Zugang aufs Telefon wird über Chrome gestartet.
            SeffeS 1 Antwort Letzte Antwort
            • R Rushmed
              @Feuersturm Link
              SeffeS Offline
              SeffeS Offline
              Seffe
              schrieb am zuletzt editiert von Seffe
              @rushmed Konntest du das Problem lösen?
              Hätte noch den Vorschlag den Hacken beim erzwingen der Websockets in der Instanz Web.0 zu deaktivieren.
              Hiermit geht zumindest wieder der Zugriff auf die ViS mit dem neuen Samsung Internet Browser.Websocket.jpg
              M R 2 Antworten Letzte Antwort
              • SeffeS Seffe
                MK-66
                @seffe @Rushmed
                Was aber beim neuen Samsung Internet Browser 16.0.2.19 trotzdem nicht mehr geht, ist der Zugriff auf Flot Diagramme, zumindest bei mir nicht (Websockets erzwingen ist deaktiviert). Sobald mehrere Flots geladen werden sollen, passiert außer einem derhenden Kreis einfach gar nichts und irgendwann stürzt der Browser dann auch noch ab. Wenn nur ein einzelnes Flot geladen werden soll, geht es. Mit Chrome und FF gibt es da keine Probleme.
                • SeffeS Seffe
                  Rushmed
                  @seffe Nein, es funktionier immernoch nicht. Das Erzwingen der Websockets war bereits deaktiviert.
                  Ich sehe aber Licht am Ende des Tunnels. In der aktuellen Samsung Internet beta 16.2.1.25 komme ich wieder in die Admin Oberfläche. 👍
                  Flot und Vis habe ich nicht getestet, ich visualisiere alles mit einer Kombi aus Grafana und HabPanel und das ging beides immer.
                  • R Offline
                    Rushmed
                    Mit der aktuellen Version 16.2.1.56 von Samsung Internet besteht das Problem nichtmehr.
                    • R Rushmed
                      FeuersturmF Offline
                      FeuersturmF Offline
                      Feuersturm
                      @rushmed Dankeschön. Funktioniert bei mir jetzt auch wieder.
