  4. [Frage] Blockly zufällig im Zeitbereich
    6.3k
    1.6k
40 Beiträge 6 Kommentatoren 5.7k Aufrufe 2 Beobachtet
    andyb
    ich würde gerne zur Anwesenheitssimulation im angegebenen Zeitbereich einschalten.
    Ich finde keinen passenden Baustein als Trigger
    so?
    ! <block 1999/xmlns="<URL url=" http:/www.w3.org/xhtml"="">http://www.w3.org/1999/xhtml" type="astro" id="vOdIC2f-cxe3Fw91q4@" x="-462" y="742"> ! <field name="TYPE">night</field> ! <field name="OFFSET">45</field> ! <statement name="STATEMENT"><block type="controls_if" id=")Kfco!pFpTd*{4v=%;L+"><value name="IF0"><block type="logic_compare" id="Obk-^bf7EBKGGQAHspl"><field name="OP">EQ</field>
    ! <value name="A"><block type="get_value" id="vNMQOarn%Jm6f8.DpO{"><field name="ATTR">val</field> ! <field name="OID">javascript.0.Modus.AWS</field></block></value> ! <value name="B"><block type="logic_boolean" id="%_*mxijikz++/8hb=_%T"><field name="BOOL">TRUE</field></block></value></block></value> ! <statement name="DO0"><block type="controls_if" id="VXYk(|jxbDq+Vr+e]1!"><value name="IF0"><block type="logic_compare" id="UZT5.q]hv(zV^q#kkvEW"><field name="OP">EQ</field>
    ! <value name="A"><block type="get_value" id="Flm{x{=Gbqly?Zv=*=-!"><field name="ATTR">val</field>
    ! <field name="OID">javascript.0.Modus.Gastmodus</field></block></value>
    ! <value name="B"><block type="logic_boolean" id="=3tl~@.H.r#^oyX83u(I"><field name="BOOL">FALSE</field></block></value></block></value>
    ! <statement name="DO0"><block type="timeouts_setinterval" id="h!BRd3bN:-?sFaV-+vzj"><field name="NAME">Intervall</field>
    ! <field name="INTERVAL">3600000</field>
    ! <statement name="STATEMENT"><block type="control" id="K+v]dW2Pm}q#!MxHmk2l"><mutation delay_input="false"></mutation>
    ! <field name="OID">hm-rpc.0.LEQ0747868.1.ON_TIME</field>
    ! <field name="WITH_DELAY">FALSE</field>
    ! <value name="VALUE"><block type="math_number" id="KZaXi(n3yuZsCdFt-#5g"><field name="NUM">300</field></block></value>
    ! <next><block type="control" id="by1D,7OwL,QjqnFHl(,R"><mutation delay_input="true"></mutation>
    ! <field name="OID">hm-rpc.0.LEQ0747868.1.STATE</field>
    ! <field name="WITH_DELAY">TRUE</field>
    ! <field name="DELAY_MS">1000</field>
    ! <field name="CLEAR_RUNNING">FALSE</field>
    ! <value name="VALUE"><block type="logic_boolean" id="Dmo(.#MK2Ori~|KGPkuY"><field name="BOOL">TRUE</field></block></value>
    ! <next><block type="controls_if" id="Z.@.EXfbBRlUMlg{!Z!"><value name="IF0"><block type="time_compare_ex" id="e/_G[d|S6NW^{6[qiruD"><mutation end_time="false" actual_time="true"></mutation> ! <field name="USE_ACTUAL_TIME">TRUE</field> ! <field name="OPTION">==</field> ! <value name="START_TIME"><shadow type="text" id="]OME?qyjG70+~d/U2m6"><field name="TEXT">24:00</field></shadow></value></block></value>
    ! <statement name="DO0"><block type="timeouts_clearinterval" id="/h7#aP6_C3AJ.[qH6Vw{"><field name="NAME">Intervall</field></block></statement></block></next></block></next></block></statement></block></statement></block></statement></block></statement></block>
    • rantanplanR Offline
      rantanplanR Offline
      rantanplan
      Hallo andyb
      Sollte funktionieren.
      Ist natürlich schwer zu testen, weil das Script nur einmal am Tag ausgeführt wird.
      Ich nehme dafür gerne den Cron Trigger und frage dann einige Bedingungen ab.
      Wenn Du z.B. die AWS nach dem Zeitpunkt "Nacht + 45" aktivierst, passiert da nichts mehr.
      Die Bedingung für die Intervall-Unterbrechung würde ich auch ändern.
      Das die Abfrage genau um 24:00 Uhr erfolgt ist nicht sicher.
      Bedingungen zum Tageswechsel sind immer etwas heikel.
      Nimm lieber "größer als" oder "gleich oder größer als" 23:30.
      Falls die Abfrage nach 24:00 erfolgt, würde 24:00 >= 00:01 unwahr sein.
      Deshalb 23:30, das passt auf jeden Fall in Dein Intervall.
      Rantanplan
        andyb
        Danke., ändere ich.
        Ich wollte eigentlich da wo ich den festen Intervall hab, was variables haben….
        • lobomauL Offline
          lobomauL Offline
          lobomau
          Gibt es sonst eine Möglichkeit nur mit Blockly einen zufälligen Zeitbereich zu erstellen?
          Ich möchte dass nachts ein Licht 10 mal schaltet, aber jeweils im zufälligen Bereich von 0 bis 5 Minuten.
          Host: NUC8i3 mit Proxmox:
          • Slave: Pi4
            rantanplanR Offline
            rantanplan
            @lobomau:
            Ich möchte dass nachts ein Licht 10 mal schaltet, aber jeweils im zufälligen Bereich von 0 bis 5 Minuten. `
            Hallo lobomau
            Nicht direkt. Leider läßt Blockly in vielen Bausteinen keine Variablen zu.
            Aber vom Rücken, durch die Brust ins Auge könnte es gehen.
            Auf die Schnelle fällt mir dazu folgende Möglichkeit ein.
            Der Export:
            <xml xmlns="http://www.w3.org/1999/xhtml"><block type="schedule" id="#q]X?XA6,T#oVG0~p2-k" x="-137" y="-162"><field name="SCHEDULE">/5 * * * * </field>
            <statement name="STATEMENT"><block type="controls_if" id="SPb@1vaoX%#8}Ztk9|.{"><value name="IF0"><block type="logic_compare" id=")|K
            D~LFn0EfiYM^m@Nn"><field name="OP">NEQ</field>
            <value name="A"><block type="variables_get" id="d71W,pX%pJ72;8{kfdS"><field name="VAR">TimerAktiv</field></block></value> <value name="B"><block type="logic_boolean" id="(%,AB0sDN!#y4ic_{VjS"><field name="BOOL">TRUE</field></block></value></block></value> <statement name="DO0"><block type="variables_set" id="}.-BM_s!1lz.V*hvU@AY"><field name="VAR">valZufall</field> <value name="VALUE"><block type="math_random_int" id="3Q/HHpL~EpbBr^HE~1df"><value name="FROM"><shadow type="math_number" id="A.LJ5W.UeBqK(Tl2GvZ"><field name="NUM">1</field></shadow></value>
            <value name="TO"><shadow type="math_number" id="T{/dDJqQ1%YlMESV9(Nv"><field name="NUM">3</field></shadow></value></block></value>
            <next><block type="controls_if" id="kGg5uFcR8[gxXgSzVl5n"><mutation elseif="2"></mutation>
            <value name="IF0"><block type="logic_compare" id="?nV9axQ.ztUS+?mvR:^v"><field name="OP">EQ</field>
            <value name="A"><block type="variables_get" id="eGQClh}yINaaminM]h@M"><field name="VAR">valZufall</field></block></value>
            <value name="B"><block type="math_number" id="w)p6@Kl(M%rZZC2w[fk^"><field name="NUM">1</field></block></value></block></value>
            <statement name="DO0"><block type="procedures_callnoreturn" id="K0BT]GJP:#6Le6RdwqF8"><mutation name="ZufallEins"></mutation></block></statement>
            <value name="IF1"><block type="logic_compare" id="M0[QB+35R8YTEh=5Xge
            <value name="A"><block type="variables_get" id="(tpMntf[RTlhk6nXF#Xk"><field name="VAR">valZufall</field></block></value>
            <value name="B"><block type="math_number" id="Nc.|J~M;eYEIWS|Q!J;l"><field name="NUM">2</field></block></value></block></value>
            <statement name="DO1"><block type="procedures_callnoreturn" id="W87g2nl8jprwJXB]J[hw"><mutation name="ZufallZwei"></mutation></block></statement>
            <value name="IF2"><block type="logic_compare" id="gj}gnPUy#/5aHdoBnr@"><field name="OP">EQ</field>
            <value name="A"><block type="variables_get" id="leS?FhGaeYN^U_eW=UC@"><field name="VAR">valZufall</field></block></value>
            <value name="B"><block type="math_number" id="L+jsa(J@;}6M8Rr%a}Yd"><field name="NUM">3</field></block></value></block></value>
            <statement name="DO2"><block type="procedures_callnoreturn" id="{;AN3#fKQQ0kBms}=oDy"><mutation name="ZufallDrei"></mutation></block></statement></block></next></block></statement></block></statement></block>
            <block type="procedures_defnoreturn" id="]aih=G55?HS]7lpb
            vSc" x="538" y="-187"><field name="NAME">ZufallEins</field>
            <statement name="STACK"><block type="debug" id="m(8lX4Y:**J%J^9ti)M"><field name="Severity">log</field> <value name="TEXT"><shadow type="text" id="7k{/9%WdRZg%WaMby}Z"><field name="TEXT">5 Min</field></shadow>
            <block type="variables_get" id="y1Q1BFtS+I+?X!T;vdJ|"><field name="VAR">valZufall</field></block></value>
            <next><block type="comment" id="UD8iI_FNE6Pa0}07og*["><field name="COMMENT">Schalte etwas ein</field>
            <next><block type="variables_set" id="gc%||Eu?4a-GR[lV#V+9"><field name="VAR">TimerAktiv</field>
            <value name="VALUE"><block type="logic_boolean" id=".f:;9;bHuW@Q8uTIM7cx"><field name="BOOL">TRUE</field></block></value>
            <next><block type="timeouts_settimeout" id="KUky=Au9Hf42KvRsaZi"><field name="NAME">timeout</field>
            <field name="DELAY">1000</field>
            <statement name="STATEMENT"><block type="comment" id="!/W#E)^phCi/#d:rZ11M"><field name="COMMENT">Schalte etwas wieder aus</field>
            <next><block type="variables_set" id="45qLb@}f0E5vBYwGUs,H"><field name="VAR">TimerAktiv</field>
            <value name="VALUE"><block type="logic_boolean" id="M69l1/uK.(zT^%3mbA|@"><field name="BOOL">FALSE</field></block></value></block></next></block></statement></block></next></block></next></block></next></block></statement></block>
            <block type="procedures_defnoreturn" id="j6lr
            @jITsr]ms8yhUh0" x="538" y="63"><field name="NAME">ZufallZwei</field>
            <statement name="STACK"><block type="debug" id="Yj?[d2mz/jUbw6B@}i^w"><field name="Severity">log</field>
            <value name="TEXT"><shadow type="text" id="7k{/9%WdRZg%WaMby}Z"><field name="TEXT">5 Min</field></shadow> <block type="variables_get" id=")6F1e[,wecN:0#OxtHo5"><field name="VAR">valZufall</field></block></value> <next><block type="comment" id="(K~gPu|WTF3rn%_]Wu|p"><field name="COMMENT">Schalte etwas ein</field> <next><block type="variables_set" id="{(kXy~N;Z.QRt}vr3I"><field name="VAR">TimerAktiv</field>
            <value name="VALUE"><block type="logic_boolean" id="G6@Xxm=)a-dD[j{I=Yfv"><field name="BOOL">TRUE</field></block></value>
            <next><block type="timeouts_settimeout" id="xefMj,DIwtkW
            2@Phw1Q"><field name="NAME">timeout2</field>
            <field name="DELAY">2000</field>
            <statement name="STATEMENT"><block type="comment" id="A[?425Oyazos+*y8;Y2:"><field name="COMMENT">Schalte etwas wieder aus</field>
            <next><block type="variables_set" id="W,)iWjtj;*J19I8rbs8"><field name="VAR">TimerAktiv</field> <value name="VALUE"><block type="logic_boolean" id="P=PZWs~Sdnb/7A_g1IMp"><field name="BOOL">FALSE</field></block></value></block></next></block></statement></block></next></block></next></block></next></block></statement></block> <block type="procedures_defnoreturn" id=",%sXx)neL(hBuOH~l%%9" x="538" y="313"><field name="NAME">ZufallDrei</field> <comment pinned="false" h="80" w="160">Beschreibe diese Funktion …</comment> <statement name="STACK"><block type="debug" id="k}),=oVBLM[qL:1,0K=%"><field name="Severity">log</field> <value name="TEXT"><shadow type="text" id="7k{/9%WdRZg%WaMby}Z"><field name="TEXT">5 Min</field></shadow>
            <block type="variables_get" id="zY3NJB^6bk2C?gA/]Qa9"><field name="VAR">valZufall</field></block></value>
            <next><block type="comment" id="|;jKXPh/w,O.!TE~)5y6"><field name="COMMENT">Schalte etwas ein</field>
            <next><block type="variables_set" id="WDYnD=%[7Ot3b94P*cl"><field name="VAR">TimerAktiv</field> <value name="VALUE"><block type="logic_boolean" id="m{t-glCB~U:?~U6VhWvj"><field name="BOOL">TRUE</field></block></value> <next><block type="timeouts_settimeout" id="TX2ufws26#AES|*Hmty"><field name="NAME">timeout3</field>
            <field name="DELAY">3000</field>
            <statement name="STATEMENT"><block type="comment" id=";6|h5I,9xy=NsXaK6Pv{"><field name="COMMENT">Schalte etwas wieder aus</field>
            <next><block type="variables_set" id="q7GtkJVZ!-R+JVdai^K("><field name="VAR">TimerAktiv</field>
            <value name="VALUE"><block type="logic_boolean" id="p!%n^3t8Q}JFG!y8~NPI"><field name="BOOL">FALSE</field></block></value></block></next></block></statement></block></next></block></next></block></next></block></statement></block></xml>
            EDIT: Die lokalen Variablem müssen vorher initialisiert werden!!! Sonst klappt es nicht.
             ![147_beispiel.png](/assets/uploads/files/147_beispiel.png)
            Ist in dem Export NICHT enthalten.
            Rantanplan
            • lobomauL Offline
              lobomauL Offline
              lobomau
              @rantanplan:
              @lobomau:
              Hallo lobomau
              Der Export:
              Grüße `
              Danke!
              Der wichtige Hinweis war für mich, dass es unter Mathematik zufällige Zahlen gibt. Damit kann man sich dann was basteln.
              EDIT: funktioniert gut dein Test-Script:
              	script.js.common.Übung: 2
              javascript.1	2017-04-23 15:44:10.147	info	script.js.common.Übung: 1
              javascript.1	2017-04-23 15:44:05.146	info	script.js.common.Übung: 3
              javascript.1	2017-04-23 15:44:00.147	info	script.js.common.Übung: 3
              javascript.1	2017-04-23 15:43:55.147	info	script.js.common.Übung: 2
              javascript.1	2017-04-23 15:43:50.150	info	script.js.common.Übung: 2
              javascript.1	2017-04-23 15:43:45.147	info	script.js.common.Übung: 3
              javascript.1	2017-04-23 15:43:40.147	info	script.js.common.Übung: 2
              javascript.1	2017-04-23 15:43:35.146	info	script.js.common.Übung: 2
              javascript.1	2017-04-23 15:43:30.145	info	script.js.common.Übung: 1
              javascript.1	2017-04-23 15:43:25.148	info	script.js.common.Übung: 1
              javascript.1	2017-04-23 15:43:20.152	info	script.js.common.Übung: 1
              Wobei ich dachte dass ganzzahlige Zahl zwischen 1 und 3 immer 2 ist. Ist also eher als "größer gleich" zu verstehen und nicht "größer".
              • Slave: Pi4
                rantanplanR Offline
                rantanplan
                @lobomau:
                Wobei ich dachte dass ganzzahlige Zahl zwischen 1 und 3 immer 2 ist. Ist also eher als "größer gleich" zu verstehen und nicht "größer". `
                Ja, ist eher wie bei den alten Zaubertricks "…sage mir eine Zahl von 1 bis 10..." ;)
                Rantanplan
                • lobomauL Offline
                  lobomauL Offline
                  lobomau
                  @rantanplan:
                  @lobomau:
                  Hallo lobomau
                  Der Export:
                  Grüße `
                  Wozu ist TimerAktiv gut? Kann ich nicht weglassen und beim Trigger gleich mit "setze ValZufall" anfangen?
                  • Slave: Pi4
                    rantanplanR Offline
                    rantanplan
                    @lobomau:
                    Wozu ist TimerAktiv gut? Kann ich nicht weglassen und beim Trigger gleich mit "setze ValZufall" anfangen? `
                    Probiere es doch einfach mal aus TimerAktiv wegzulassen.
                    Rantanplan
                    • lobomauL Offline
                      lobomauL Offline
                      lobomau
                      @rantanplan:
                      @lobomau:
                      Grüße `
                      Ja, geht auch ohne :) Ich verstehe TimerAktiv also als nice-to-have, um z.B. bei längeren Zeitbereichen zu wissen, dass ein Timer aktiv ist.
                      Ich lasse es drin. Stört ja nicht. Oder gibt es noch einen anderen Grund dafür?
                      • Slave: Pi4
                        rantanplanR Offline
                        rantanplan
                        @lobomau:
                        Ich lasse es drin. Stört ja nicht. Oder gibt es noch einen anderen Grund dafür? `
                        Augenscheinlich hast Du nicht richtig getestet.
                        Natürlich läuft das Script. Aber auch richtig?
                        Jedesmal wenn Du einen Timer startest, wird er ausgeführt OHNE den vorherigen zu stoppen.
                        Wenn man einen Timer häufig startest, kannst Du schnell 100derte Timer aktiv haben.
                        Und dann wird irgendwann das Licht 100derte mal ausgeschaltet.
                        Von der verschwendeten Rechnerleistung gar nicht zu reden.
                        TimerAktiv ist also etwas mehr als nice-to-have.
                        Rantanplan
                          Belei
                          @rantanplan:
                          @lobomau:
                          Hallo lobomau
                          Der Export:
                          Grüße `
                          Für noch mehr Schaltungen füge ich einfach noch mehr Zufallszahlen ein.
                          Ich brauche ja für jedes Komado eine Zahl, oder?
                          also Lampe 1 an = Zufall 1
                          und Lampe 1 aus = Zufall 2
                          usw.
                            rantanplanR Offline
                            rantanplan
                            @Belei:
                            usw. `
                            In dem Beispiel wird jeweils ein Timer gestartet. Darin wird das jeweilige Gerät wieder ausgeschaltet (s. Komentare).
                            Man kann es aber so machen wie Du es beschreibst.
                            Rantanplan
                              Belei
                              OK hatte ich auch erst so verstanden aber bei meiner probe, wurde die Lichter nie ausgeschaltet.
                                rantanplanR Offline
                                rantanplan
                                Du hast ja auch den Aufruf der Funktionen "ZufallEins","ZufallZwei"….. raus genommen.
                                Das Ein-,Ausschalten soll in den Funktionen stattfinden.
                                Da wo die Kommentare "Schalte etwas ein" und innerhalb der Timer "Schalte etwas aus".
                                Rantanplan
                                  Belei
                                  ups, da hab ich wohl was flasch verstanden…
                                  Also ist der Timer oben Links für den Interwall der Zufallszahlen und die Timeout in den Funktionen sind für die Auschaltzeit.?
                                    rantanplanR Offline
                                    rantanplan
                                    @Belei:
                                    Also ist der Timer oben Links für den Interwall der Zufallszahlen und die Timeout in den Funktionen sind für die Auschaltzeit.? `
                                    "oben LInks" ist kein Timer.
                                    Oder meinst Du den Trigger?
                                    Rantanplan
                                      Belei
                                      Ja meinte den Trigger muss die Begriffe besser beachten .
                                        Belei
                                        Nur noch mal zum Verständniss:
                                        Ich starte den Script und nach Ablauf des Triggers geht der erste Block los, er guckt kein Timer aktiv also Zufallszahl 1-3 an
                                        z.B. Funktionsblock 1 wird ausgewählt und Licht angeschaltet für Timeout von XX Minuten. Nach dem auschalten wird der Timer wieder auf unwahr gesetzt und der erste Block startet wieder nach Ablauf des Triggers?
                                        Ist es dann nicht so das immer nur 1 Licht leuchtet und nie mal mehrere? Weil es wird ja immer nur nach Ablauf des Timers neugestartet, oder?
                                          rantanplanR Offline
                                          rantanplan
                                          Hallo Belei
                                          Das Blockly ist nur ein Beispiel, wie man so etwas lösen könnte.
                                          Das ist keine fertige Vorlage oder Anwendung!
                                          Wie viele Geräte Du in einer Zufalls-Funktion ein-/ausschaltest liegt in Deinem Ermessen.
                                          Du kannst auch für jede Funktion einen eigenen Flag für "TimerAktiv" anlegen.
                                          TimerAktivEins, TimerAktivZwei usw. usw.
                                          "TimerAktivXXX" soll verhindern, dass ein Timer mehrmals gestartet wird!
                                          Rantanplan
                                          82.7k
