  4. Backitup Error bei automatischem Start
    6.0k
7 Beiträge 2 Kommentatoren 445 Aufrufe 2 Beobachtet
    BigChris
    Mein Backitup Adapter hat ein Problem beim automatischen Start.
    Ich erhalte diese Meldungen im Log:
    2022-03-06 02:40:21.984 - error: backitup.0 (419942) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2022-03-06 02:40:21.985 - error: backitup.0 (419942) unhandled promise rejection: Rate Limit Exceeded
    2022-03-06 02:40:22.081 - error: backitup.0 (419942) Error: Rate Limit Exceeded
    at Gaxios._request (/opt/iobroker/node_modules/gaxios/src/gaxios.ts:158:15)
    at runMicrotasks ()
    at processTicksAndRejections (internal/process/task_queues.js:95:5)
    at OAuth2Client.requestAsync (/opt/iobroker/node_modules/google-auth-library/build/src/auth/oauth2client.js:368:18)
    2022-03-06 02:40:22.082 - error: backitup.0 (419942) Exception-Code: 403: Rate Limit Exceeded
    2022-03-06 02:40:22.097 - info: backitup.0 (419942) cleaned everything up...
    2022-03-06 02:40:22.098 - info: backitup.0 (419942) terminating
    2022-03-06 02:40:22.098 - warn: backitup.0 (419942) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2022-03-06 02:40:22.684 - error: host.iobroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2022-03-06 02:40:22.687 - error: host.iobroker Caught by controller[0]: Error: Rate Limit Exceeded
    2022-03-06 02:40:22.688 - error: host.iobroker Caught by controller[0]: at Gaxios._request (/opt/iobroker/node_modules/gaxios/src/gaxios.ts:158:15)
    2022-03-06 02:40:22.688 - error: host.iobroker Caught by controller[0]: at runMicrotasks ()
    2022-03-06 02:40:22.688 - error: host.iobroker Caught by controller[0]: at processTicksAndRejections (internal/process/task_queues.js:95:5)
    2022-03-06 02:40:22.688 - error: host.iobroker Caught by controller[0]: at OAuth2Client.requestAsync (/opt/iobroker/node_modules/google-auth-library/build/src/auth/oauth2client.js:368:18)
    2022-03-06 02:40:22.688 - error: host.iobroker instance system.adapter.backitup.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2022-03-06 02:40:22.688 - info: host.iobroker Restart adapter system.adapter.backitup.0 because enabled
    Wenn ich das Backup manuell ausführe, läuft es einwandfrei durch.
    Was ist bei der automatischen Ausführung denn anders?
    • B BigChris
      at runMicrotasks ()
      @bigchris
      Leg den Zeitpunkt mal
      a) außerhalb der Stunde von 2-3 Uhr
      b) auf krumme Minuten. 03:34 oder 04:18 sowas.
      B 2 Antworten Letzte Antwort
        @bigchris
        BigChris
        Ok, ich habe es mal auf 3:23 gestellt und schaue was passiert heute nacht.
          @bigchris
          BigChris
          Heute Nacht hat es funktioniert 🤔
          • B BigChris
            @bigchris
            Natürlich.
              @bigchris
              Natürlich.
              BigChris
              Warum es jetzt geht, habe ich aber nicht verstanden.
              • B BigChris
                @bigchris
                Weil die Cloud zu den 'geraden' Uhrzeiten aus der Standardeinstellung proppenvoll ist.
