<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Backitup Error bei automatischem Start]]></title><description><![CDATA[<p dir="auto">Mein Backitup Adapter hat ein Problem beim automatischen Start.<br />
Ich erhalte diese Meldungen im Log:</p>
<pre><code>2022-03-06 02:40:21.984 - error: backitup.0 (419942) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
2022-03-06 02:40:21.985 - error: backitup.0 (419942) unhandled promise rejection: Rate Limit Exceeded
2022-03-06 02:40:22.081 - error: backitup.0 (419942) Error: Rate Limit Exceeded
at Gaxios._request (/opt/iobroker/node_modules/gaxios/src/gaxios.ts:158:15)
at runMicrotasks ()
at processTicksAndRejections (internal/process/task_queues.js:95:5)
at OAuth2Client.requestAsync (/opt/iobroker/node_modules/google-auth-library/build/src/auth/oauth2client.js:368:18)
2022-03-06 02:40:22.082 - error: backitup.0 (419942) Exception-Code: 403: Rate Limit Exceeded
2022-03-06 02:40:22.097 - info: backitup.0 (419942) cleaned everything up...
2022-03-06 02:40:22.098 - info: backitup.0 (419942) terminating
2022-03-06 02:40:22.098 - warn: backitup.0 (419942) Terminated (UNCAUGHT_EXCEPTION): Without reason
2022-03-06 02:40:22.684 - error: host.iobroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
2022-03-06 02:40:22.687 - error: host.iobroker Caught by controller[0]: Error: Rate Limit Exceeded
2022-03-06 02:40:22.688 - error: host.iobroker Caught by controller[0]: at Gaxios._request (/opt/iobroker/node_modules/gaxios/src/gaxios.ts:158:15)
2022-03-06 02:40:22.688 - error: host.iobroker Caught by controller[0]: at runMicrotasks ()
2022-03-06 02:40:22.688 - error: host.iobroker Caught by controller[0]: at processTicksAndRejections (internal/process/task_queues.js:95:5)
2022-03-06 02:40:22.688 - error: host.iobroker Caught by controller[0]: at OAuth2Client.requestAsync (/opt/iobroker/node_modules/google-auth-library/build/src/auth/oauth2client.js:368:18)
2022-03-06 02:40:22.688 - error: host.iobroker instance system.adapter.backitup.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
2022-03-06 02:40:22.688 - info: host.iobroker Restart adapter system.adapter.backitup.0 because enabled
</code></pre>
<p dir="auto">Wenn ich das Backup manuell ausführe, läuft es einwandfrei durch.<br />
Was ist bei der automatischen Ausführung denn anders?</p>
]]></description><link>https://forum.iobroker.net/topic/53134/backitup-error-bei-automatischem-start</link><generator>RSS for Node</generator><lastBuildDate>Sat, 23 May 2026 00:28:46 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/53134.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 06 Mar 2022 17:18:30 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Backitup Error bei automatischem Start on Mon, 07 Mar 2022 08:12:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bigchris" aria-label="Profile: bigchris">@<bdi>bigchris</bdi></a><br />
Weil die Cloud zu den 'geraden' Uhrzeiten aus der Standardeinstellung proppenvoll ist.</p>
]]></description><link>https://forum.iobroker.net/post/773252</link><guid isPermaLink="true">https://forum.iobroker.net/post/773252</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Mon, 07 Mar 2022 08:12:44 GMT</pubDate></item><item><title><![CDATA[Reply to Backitup Error bei automatischem Start on Mon, 07 Mar 2022 08:04:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a><br />
Warum es jetzt geht, habe ich aber nicht verstanden.</p>
]]></description><link>https://forum.iobroker.net/post/773247</link><guid isPermaLink="true">https://forum.iobroker.net/post/773247</guid><dc:creator><![CDATA[BigChris]]></dc:creator><pubDate>Mon, 07 Mar 2022 08:04:42 GMT</pubDate></item><item><title><![CDATA[Reply to Backitup Error bei automatischem Start on Mon, 07 Mar 2022 08:03:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bigchris" aria-label="Profile: bigchris">@<bdi>bigchris</bdi></a><br />
Natürlich.</p>
]]></description><link>https://forum.iobroker.net/post/773244</link><guid isPermaLink="true">https://forum.iobroker.net/post/773244</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Mon, 07 Mar 2022 08:03:00 GMT</pubDate></item><item><title><![CDATA[Reply to Backitup Error bei automatischem Start on Mon, 07 Mar 2022 07:59:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a><br />
Heute Nacht hat es funktioniert 🤔</p>
]]></description><link>https://forum.iobroker.net/post/773239</link><guid isPermaLink="true">https://forum.iobroker.net/post/773239</guid><dc:creator><![CDATA[BigChris]]></dc:creator><pubDate>Mon, 07 Mar 2022 07:59:18 GMT</pubDate></item><item><title><![CDATA[Reply to Backitup Error bei automatischem Start on Sun, 06 Mar 2022 17:57:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a><br />
Ok, ich habe es mal auf 3:23 gestellt und schaue was passiert heute nacht.</p>
]]></description><link>https://forum.iobroker.net/post/773007</link><guid isPermaLink="true">https://forum.iobroker.net/post/773007</guid><dc:creator><![CDATA[BigChris]]></dc:creator><pubDate>Sun, 06 Mar 2022 17:57:53 GMT</pubDate></item><item><title><![CDATA[Reply to Backitup Error bei automatischem Start on Sun, 06 Mar 2022 17:24:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bigchris" aria-label="Profile: bigchris">@<bdi>bigchris</bdi></a></p>
<p dir="auto">Leg den Zeitpunkt mal<br />
a) außerhalb der Stunde von 2-3 Uhr<br />
b) auf krumme Minuten. 03:34 oder 04:18 sowas.</p>
]]></description><link>https://forum.iobroker.net/post/772993</link><guid isPermaLink="true">https://forum.iobroker.net/post/772993</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Sun, 06 Mar 2022 17:24:12 GMT</pubDate></item></channel></rss>
