  3. Off Topic
  4. Welche SSD?
Welche SSD?
ssd
16 Beiträge 3 Kommentatoren 1.5k Aufrufe 4 Beobachtet
  • H homecineplexx
    @wendy2702 also dmesg ist sicher super, wenn man weiß wonach man sucht, aber davon hab ich so überhaupt keine Ahnung 👼
    wendy2702W Offline
    wendy2702W Offline
    @homecineplexx Dann zeig es uns mal als Text in Code Tags </>
    H 1 Antwort Letzte Antwort
    • wendy2702W wendy2702
      homecineplexx
      @wendy2702 ja bitteschön, wäre echt super, wenn man da was findet, denn das Teil schneckt so extrem herum wahnsinn
      chris@ioBroker:/var/log$ sudo dmesg
      [    0.000000] Linux version 4.19.0-18-amd64 (debian-kernel@lists.debian.org) (gcc version 8.3.0 (Debian 8.3.0-6)) #1 SMP Debian 4.19.208-1 (2021-09-29)
      [    0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-4.19.0-18-amd64 root=UUID=c93c9c7b-3b52-46be-a5cf-82d77370dff5 ro quiet
      [    0.000000] x86/fpu: x87 FPU will use FXSAVE
      [    0.000000] BIOS-provided physical RAM map:
      [    0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009fbff] usable
      [    0.000000] BIOS-e820: [mem 0x000000000009fc00-0x000000000009ffff] reserved
      [    0.000000] BIOS-e820: [mem 0x00000000000f0000-0x00000000000fffff] reserved
      [    0.000000] BIOS-e820: [mem 0x0000000000100000-0x00000000bffd5fff] usable
      [    0.000000] BIOS-e820: [mem 0x00000000bffd6000-0x00000000bfffffff] reserved
      [    0.000000] BIOS-e820: [mem 0x00000000feffc000-0x00000000feffffff] reserved
      [    0.000000] BIOS-e820: [mem 0x00000000fffc0000-0x00000000ffffffff] reserved
      [    0.000000] BIOS-e820: [mem 0x0000000100000000-0x00000001bfffffff] usable
      [    0.000000] NX (Execute Disable) protection: active
      [    0.000000] SMBIOS 2.8 present.
      [    0.000000] DMI: QEMU Standard PC (i440FX + PIIX, 1996), BIOS rel-1.14.0-0-g155821a1990b-prebuilt.qemu.org 04/01/2014
      [    0.000000] Hypervisor detected: KVM
      [    0.000000] kvm-clock: Using msrs 4b564d01 and 4b564d00
      [    0.000001] kvm-clock: cpu 0, msr 415ec001, primary cpu clock
      [    0.000001] kvm-clock: using sched offset of 11875537074 cycles
      [    0.000004] clocksource: kvm-clock: mask: 0xffffffffffffffff max_cycles: 0x1cd42e4dffb, max_idle_ns: 881590591483 ns
      [    0.000007] tsc: Detected 1497.600 MHz processor
      [    0.002717] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
      [    0.002719] e820: remove [mem 0x000a0000-0x000fffff] usable
      [    0.089685] AGP: No AGP bridge found
      [    0.090457] last_pfn = 0x1c0000 max_arch_pfn = 0x400000000
      [    0.090502] MTRR default type: write-back
      [    0.090503] MTRR fixed ranges enabled:
      [    0.090505]   00000-9FFFF write-back
      [    0.090506]   A0000-BFFFF uncachable
      [    0.090508]   C0000-FFFFF write-protect
      [    0.090509] MTRR variable ranges enabled:
      [    0.090511]   0 base 00C0000000 mask FFC0000000 uncachable
      [    0.090512]   1 disabled
      [    0.090513]   2 disabled
      [    0.090514]   3 disabled
      [    0.090515]   4 disabled
      [    0.090515]   5 disabled
      [    0.090516]   6 disabled
      [    0.090517]   7 disabled
      [    0.090534] x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WC  UC- UC
      [    0.090546] last_pfn = 0xbffd6 max_arch_pfn = 0x400000000
      [    0.094989] found SMP MP-table at [mem 0x000f5a50-0x000f5a5f]
      [    0.096308] RAMDISK: [mem 0x33ae9000-0x35d6bfff]
      [    0.096327] ACPI: Early table checksum verification disabled
      [    0.096409] ACPI: RSDP 0x00000000000F5810 000014 (v00 BOCHS )
      [    0.096421] ACPI: RSDT 0x00000000BFFE1F03 000038 (v01 BOCHS  BXPC     00000001 BXPC 00000001)
      [    0.096430] ACPI: FACP 0x00000000BFFE1CD5 000074 (v01 BOCHS  BXPC     00000001 BXPC 00000001)
      [    0.096436] ACPI: DSDT 0x00000000BFFDF040 002C95 (v01 BOCHS  BXPC     00000001 BXPC 00000001)
      [    0.096440] ACPI: FACS 0x00000000BFFDF000 000040
      [    0.096444] ACPI: APIC 0x00000000BFFE1D49 000090 (v01 BOCHS  BXPC     00000001 BXPC 00000001)
      [    0.096448] ACPI: SSDT 0x00000000BFFE1DD9 0000CA (v01 BOCHS  VMGENID  00000001 BXPC 00000001)
      [    0.096451] ACPI: HPET 0x00000000BFFE1EA3 000038 (v01 BOCHS  BXPC     00000001 BXPC 00000001)
      [    0.096455] ACPI: WAET 0x00000000BFFE1EDB 000028 (v01 BOCHS  BXPC     00000001 BXPC 00000001)
      [    0.096459] ACPI: Reserving FACP table memory at [mem 0xbffe1cd5-0xbffe1d48]
      [    0.096461] ACPI: Reserving DSDT table memory at [mem 0xbffdf040-0xbffe1cd4]
      [    0.096462] ACPI: Reserving FACS table memory at [mem 0xbffdf000-0xbffdf03f]
      [    0.096463] ACPI: Reserving APIC table memory at [mem 0xbffe1d49-0xbffe1dd8]
      [    0.096464] ACPI: Reserving SSDT table memory at [mem 0xbffe1dd9-0xbffe1ea2]
      [    0.096465] ACPI: Reserving HPET table memory at [mem 0xbffe1ea3-0xbffe1eda]
      [    0.096466] ACPI: Reserving WAET table memory at [mem 0xbffe1edb-0xbffe1f02]
      [    0.096529] ACPI: Local APIC address 0xfee00000
      [    0.097013] No NUMA configuration found
      [    0.097015] Faking a node at [mem 0x0000000000000000-0x00000001bfffffff]
      [    0.097021] NODE_DATA(0) allocated [mem 0x1bfff8000-0x1bfffcfff]
      [    0.097845] Zone ranges:
      [    0.097849]   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
      [    0.097852]   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
      [    0.097853]   Normal   [mem 0x0000000100000000-0x00000001bfffffff]
      [    0.097854]   Device   empty
      [    0.097855] Movable zone start for each node
      [    0.097856] Early memory node ranges
      [    0.097858]   node   0: [mem 0x0000000000001000-0x000000000009efff]
      [    0.097859]   node   0: [mem 0x0000000000100000-0x00000000bffd5fff]
      [    0.097860]   node   0: [mem 0x0000000100000000-0x00000001bfffffff]
      [    0.099358] Zeroed struct page in unavailable ranges: 140 pages
      [    0.099362] Initmem setup node 0 [mem 0x0000000000001000-0x00000001bfffffff]
      [    0.099366] On node 0 totalpages: 1572724
      [    0.099368]   DMA zone: 64 pages used for memmap
      [    0.099369]   DMA zone: 21 pages reserved
      [    0.099371]   DMA zone: 3998 pages, LIFO batch:0
      [    0.099524]   DMA32 zone: 12224 pages used for memmap
      [    0.099525]   DMA32 zone: 782294 pages, LIFO batch:63
      [    0.145464]   Normal zone: 12288 pages used for memmap
      [    0.145468]   Normal zone: 786432 pages, LIFO batch:63
      [    0.192686] ACPI: PM-Timer IO Port: 0x608
      [    0.192691] ACPI: Local APIC address 0xfee00000
      [    0.192708] ACPI: LAPIC_NMI (acpi_id[0xff] dfl dfl lint[0x1])
      [    0.192786] IOAPIC[0]: apic_id 0, version 17, address 0xfec00000, GSI 0-23
      [    0.192790] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
      [    0.192793] ACPI: INT_SRC_OVR (bus 0 bus_irq 5 global_irq 5 high level)
      [    0.192794] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
      [    0.192796] ACPI: INT_SRC_OVR (bus 0 bus_irq 10 global_irq 10 high level)
      [    0.192797] ACPI: INT_SRC_OVR (bus 0 bus_irq 11 global_irq 11 high level)
      [    0.192798] ACPI: IRQ0 used by override.
      [    0.192800] ACPI: IRQ5 used by override.
      [    0.192801] ACPI: IRQ9 used by override.
      [    0.192801] ACPI: IRQ10 used by override.
      [    0.192802] ACPI: IRQ11 used by override.
      [    0.192804] Using ACPI (MADT) for SMP configuration information
      [    0.192806] ACPI: HPET id: 0x8086a201 base: 0xfed00000
      [    0.192815] smpboot: Allowing 4 CPUs, 0 hotplug CPUs
      [    0.192843] PM: Registered nosave memory: [mem 0x00000000-0x00000fff]
      [    0.192845] PM: Registered nosave memory: [mem 0x0009f000-0x0009ffff]
      [    0.192846] PM: Registered nosave memory: [mem 0x000a0000-0x000effff]
      [    0.192847] PM: Registered nosave memory: [mem 0x000f0000-0x000fffff]
      [    0.192849] PM: Registered nosave memory: [mem 0xbffd6000-0xbfffffff]
      [    0.192850] PM: Registered nosave memory: [mem 0xc0000000-0xfeffbfff]
      [    0.192851] PM: Registered nosave memory: [mem 0xfeffc000-0xfeffffff]
      [    0.192852] PM: Registered nosave memory: [mem 0xff000000-0xfffbffff]
      [    0.192853] PM: Registered nosave memory: [mem 0xfffc0000-0xffffffff]
      [    0.192855] [mem 0xc0000000-0xfeffbfff] available for PCI devices
      [    0.192857] Booting paravirtualized kernel on KVM
      [    0.192861] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645519600211568 ns
      [    0.372287] random: get_random_bytes called from start_kernel+0x93/0x52a with crng_init=0
      [    0.372301] setup_percpu: NR_CPUS:512 nr_cpumask_bits:512 nr_cpu_ids:4 nr_node_ids:1
      [    0.373427] percpu: Embedded 45 pages/cpu s144536 r8192 d31592 u524288
      [    0.373441] pcpu-alloc: s144536 r8192 d31592 u524288 alloc=1*2097152
      [    0.373442] pcpu-alloc: [0] 0 1 2 3
      [    0.373488] KVM setup async PF for cpu 0
      [    0.373501] kvm-stealtime: cpu 0, msr 1b9a161c0
      [    0.373510] PV qspinlock hash table entries: 256 (order: 0, 4096 bytes)
      [    0.373519] Built 1 zonelists, mobility grouping on.  Total pages: 1548127
      [    0.373520] Policy zone: Normal
      [    0.373523] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.19.0-18-amd64 root=UUID=c93c9c7b-3b52-46be-a5cf-82d77370dff5 ro quiet
      [    0.394820] AGP: Checking aperture...
      [    0.488536] AGP: No AGP bridge found
      [    0.489366] Calgary: detecting Calgary via BIOS EBDA area
      [    0.489368] Calgary: Unable to locate Rio Grande table in EBDA - bailing!
      [    0.517208] Memory: 6065696K/6290896K available (10252K kernel code, 1242K rwdata, 3332K rodata, 1596K init, 2260K bss, 225200K reserved, 0K cma-reserved)
      [    0.518094] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
      [    0.518103] Kernel/User page tables isolation: enabled
      [    0.518173] ftrace: allocating 32002 entries in 126 pages
      [    0.535119] rcu: Hierarchical RCU implementation.
      [    0.535124] rcu: 	RCU restricting CPUs from NR_CPUS=512 to nr_cpu_ids=4.
      [    0.535126] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
      [    0.539987] NR_IRQS: 33024, nr_irqs: 456, preallocated irqs: 16
      [    0.571387] Console: colour VGA+ 80x25
      [    0.571392] console [tty0] enabled
      [    0.571429] ACPI: Core revision 20180810
      [    0.571856] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604467 ns
      [    0.572049] hpet clockevent registered
      [    0.572090] APIC: Switch to symmetric I/O mode setup
      [    0.572487] x2apic enabled
      [    0.572964] Switched APIC routing to physical x2apic.
      [    0.574730] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
      [    0.574781] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x159647815e3, max_idle_ns: 440795269835 ns
      [    0.574803] Calibrating delay loop (skipped) preset value.. 2995.20 BogoMIPS (lpj=5990400)
      [    0.574807] pid_max: default: 32768 minimum: 301
      [    0.574857] Security Framework initialized
      [    0.574859] Yama: disabled by default; enable with sysctl kernel.yama.*
      [    0.574888] AppArmor: AppArmor initialized
      [    0.582317] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
      [    0.584251] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
      [    0.584315] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
      [    0.584351] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
      [    0.584799] Last level iTLB entries: 4KB 0, 2MB 0, 4MB 0
      [    0.584800] Last level dTLB entries: 4KB 0, 2MB 0, 4MB 0, 1GB 0
      [    0.584803] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
      [    0.584805] Spectre V2 : Mitigation: Full generic retpoline
      [    0.584806] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
      [    0.584807] Speculative Store Bypass: Vulnerable
      [    0.584852] MDS: Vulnerable: Clear CPU buffers attempted, no microcode
      [    0.585028] Freeing SMP alternatives memory: 24K
      [    0.695869] smpboot: CPU0: Intel Common KVM processor (family: 0xf, model: 0x6, stepping: 0x1)
      [    0.696091] Performance Events: unsupported Netburst CPU model 6 no PMU driver, software events only.
      [    0.696156] rcu: Hierarchical SRCU implementation.
      [    0.696610] NMI watchdog: Perf NMI watchdog permanently disabled
      [    0.697508] smp: Bringing up secondary CPUs ...
      [    0.697704] x86: Booting SMP configuration:
      [    0.697706] .... node  #0, CPUs:      #1
      [    0.034617] kvm-clock: cpu 1, msr 415ec041, secondary cpu clock
      [    0.709870] KVM setup async PF for cpu 1
      [    0.709870] kvm-stealtime: cpu 1, msr 1b9a961c0
      [    0.709870]  #2
      [    0.034617] kvm-clock: cpu 2, msr 415ec081, secondary cpu clock
      [    0.722817] KVM setup async PF for cpu 2
      [    0.722826] kvm-stealtime: cpu 2, msr 1b9b161c0
      [    0.723002]  #3
      [    0.034617] kvm-clock: cpu 3, msr 415ec0c1, secondary cpu clock
      [    0.738820] KVM setup async PF for cpu 3
      [    0.738829] kvm-stealtime: cpu 3, msr 1b9b961c0
      [    0.738838] smp: Brought up 1 node, 4 CPUs
      [    0.738838] smpboot: Max logical packages: 2
      [    0.738838] smpboot: Total of 4 processors activated (11980.80 BogoMIPS)
      [    0.739696] devtmpfs: initialized
      [    0.739696] x86/mm: Memory block size: 128MB
      [    0.739774] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
      [    0.739774] futex hash table entries: 1024 (order: 4, 65536 bytes)
      [    0.739774] pinctrl core: initialized pinctrl subsystem
      [    0.739774] NET: Registered protocol family 16
      [    0.739774] audit: initializing netlink subsys (disabled)
      [    0.739774] audit: type=2000 audit(1646121855.339:1): state=initialized audit_enabled=0 res=1
      [    0.739774] cpuidle: using governor ladder
      [    0.739774] cpuidle: using governor menu
      [    0.739774] ACPI: bus type PCI registered
      [    0.739774] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
      [    0.739774] PCI: Using configuration type 1 for base access
      [    0.743818] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
      [    0.743818] ACPI: Added _OSI(Module Device)
      [    0.743818] ACPI: Added _OSI(Processor Device)
      [    0.743818] ACPI: Added _OSI(3.0 _SCP Extensions)
      [    0.743818] ACPI: Added _OSI(Processor Aggregator Device)
      [    0.743818] ACPI: Added _OSI(Linux-Dell-Video)
      [    0.743818] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
      [    0.747270] ACPI: 2 ACPI AML tables successfully acquired and loaded
      [    0.749998] ACPI: Interpreter enabled
      [    0.750026] ACPI: (supports S0 S3 S4 S5)
      [    0.750029] ACPI: Using IOAPIC for interrupt routing
      [    0.750056] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
      [    0.750341] ACPI: Enabled 3 GPEs in block 00 to 0F
      [    0.758203] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
      [    0.758211] acpi PNP0A03:00: _OSC: OS supports [ASPM ClockPM Segments MSI]
      [    0.758218] acpi PNP0A03:00: _OSC failed (AE_NOT_FOUND); disabling ASPM
      [    0.758228] acpi PNP0A03:00: fail to add MMCONFIG information, can't access extended PCI configuration space under this bridge.
      [    0.758705] acpiphp: Slot [3] registered
      [    0.758765] acpiphp: Slot [4] registered
      [    0.758841] acpiphp: Slot [5] registered
      [    0.758906] acpiphp: Slot [6] registered
      [    0.758966] acpiphp: Slot [7] registered
      [    0.759026] acpiphp: Slot [8] registered
      [    0.759086] acpiphp: Slot [9] registered
      [    0.759148] acpiphp: Slot [10] registered
      [    0.759207] acpiphp: Slot [11] registered
      [    0.759274] acpiphp: Slot [12] registered
      [    0.759335] acpiphp: Slot [13] registered
      [    0.759395] acpiphp: Slot [14] registered
      [    0.759454] acpiphp: Slot [15] registered
      [    0.759516] acpiphp: Slot [16] registered
      [    0.759576] acpiphp: Slot [17] registered
      [    0.759640] acpiphp: Slot [18] registered
      [    0.759701] acpiphp: Slot [19] registered
      [    0.759760] acpiphp: Slot [20] registered
      [    0.759821] acpiphp: Slot [21] registered
      [    0.759881] acpiphp: Slot [22] registered
      [    0.759941] acpiphp: Slot [23] registered
      [    0.760004] acpiphp: Slot [24] registered
      [    0.760065] acpiphp: Slot [25] registered
      [    0.760126] acpiphp: Slot [26] registered
      [    0.760186] acpiphp: Slot [27] registered
      [    0.760247] acpiphp: Slot [28] registered
      [    0.760338] PCI host bridge to bus 0000:00
      [    0.760342] pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7 window]
      [    0.760344] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
      [    0.760345] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
      [    0.760347] pci_bus 0000:00: root bus resource [mem 0xc0000000-0xfebfffff window]
      [    0.760348] pci_bus 0000:00: root bus resource [mem 0x1c0000000-0x23fffffff window]
      [    0.760351] pci_bus 0000:00: root bus resource [bus 00-ff]
      [    0.760418] pci 0000:00:00.0: [8086:1237] type 00 class 0x060000
      [    0.761324] pci 0000:00:01.0: [8086:7000] type 00 class 0x060100
      [    0.762330] pci 0000:00:01.1: [8086:7010] type 00 class 0x010180
      [    0.767332] pci 0000:00:01.1: reg 0x20: [io  0xe120-0xe12f]
      [    0.769945] pci 0000:00:01.1: legacy IDE quirk: reg 0x10: [io  0x01f0-0x01f7]
      [    0.769949] pci 0000:00:01.1: legacy IDE quirk: reg 0x14: [io  0x03f6]
      [    0.769950] pci 0000:00:01.1: legacy IDE quirk: reg 0x18: [io  0x0170-0x0177]
      [    0.769951] pci 0000:00:01.1: legacy IDE quirk: reg 0x1c: [io  0x0376]
      [    0.770307] pci 0000:00:01.2: [8086:7020] type 00 class 0x0c0300
      [    0.774383] pci 0000:00:01.2: reg 0x20: [io  0xe080-0xe09f]
      [    0.776978] pci 0000:00:01.3: [8086:7113] type 00 class 0x068000
      [    0.777784] pci 0000:00:01.3: quirk: [io  0x0600-0x063f] claimed by PIIX4 ACPI
      [    0.777801] pci 0000:00:01.3: quirk: [io  0x0700-0x070f] claimed by PIIX4 SMB
      [    0.778180] pci 0000:00:02.0: [1234:1111] type 00 class 0x030000
      [    0.783807] pci 0000:00:02.0: reg 0x10: [mem 0xfd000000-0xfdffffff pref]
      [    0.787751] pci 0000:00:02.0: reg 0x18: [mem 0xfea50000-0xfea50fff]
      [    0.797735] pci 0000:00:02.0: reg 0x30: [mem 0xfea40000-0xfea4ffff pref]
      [    0.799032] pci 0000:00:03.0: [1af4:1002] type 00 class 0x00ff00
      [    0.800713] pci 0000:00:03.0: reg 0x10: [io  0xe000-0xe03f]
      [    0.808256] pci 0000:00:03.0: reg 0x20: [mem 0xfe400000-0xfe403fff 64bit pref]
      [    0.811412] pci 0000:00:05.0: [1af4:1004] type 00 class 0x010000
      [    0.813972] pci 0000:00:05.0: reg 0x10: [io  0xe040-0xe07f]
      [    0.815908] pci 0000:00:05.0: reg 0x14: [mem 0xfea51000-0xfea51fff]
      [    0.823977] pci 0000:00:05.0: reg 0x20: [mem 0xfe404000-0xfe407fff 64bit pref]
      [    0.828232] pci 0000:00:12.0: [1af4:1000] type 00 class 0x020000
      [    0.831809] pci 0000:00:12.0: reg 0x10: [io  0xe0a0-0xe0bf]
      [    0.834802] pci 0000:00:12.0: reg 0x14: [mem 0xfea52000-0xfea52fff]
      [    0.840697] pci 0000:00:12.0: reg 0x20: [mem 0xfe408000-0xfe40bfff 64bit pref]
      [    0.842801] pci 0000:00:12.0: reg 0x30: [mem 0xfea00000-0xfea3ffff pref]
      [    0.846919] pci 0000:00:1d.0: [8086:2934] type 00 class 0x0c0300
      [    0.850705] pci 0000:00:1d.0: reg 0x20: [io  0xe0c0-0xe0df]
      [    0.852361] pci 0000:00:1d.1: [8086:2935] type 00 class 0x0c0300
      [    0.857326] pci 0000:00:1d.1: reg 0x20: [io  0xe0e0-0xe0ff]
      [    0.859180] pci 0000:00:1d.2: [8086:2936] type 00 class 0x0c0300
      [    0.862714] pci 0000:00:1d.2: reg 0x20: [io  0xe100-0xe11f]
      [    0.864256] pci 0000:00:1d.7: [8086:293a] type 00 class 0x0c0320
      [    0.865089] pci 0000:00:1d.7: reg 0x10: [mem 0xfea53000-0xfea53fff]
      [    0.871614] pci 0000:00:1e.0: [1b36:0001] type 01 class 0x060400
      [    0.874034] pci 0000:00:1e.0: reg 0x10: [mem 0xfea54000-0xfea540ff 64bit]
      [    0.877368] pci 0000:00:1f.0: [1b36:0001] type 01 class 0x060400
      [    0.881253] pci 0000:00:1f.0: reg 0x10: [mem 0xfea55000-0xfea550ff 64bit]
      [    0.885216] pci_bus 0000:01: extended config space not accessible
      [    0.885711] acpiphp: Slot [0] registered
      [    0.885770] acpiphp: Slot [1] registered
      [    0.885829] acpiphp: Slot [2] registered
      [    0.885896] acpiphp: Slot [3-2] registered
      [    0.885963] acpiphp: Slot [4-2] registered
      [    0.886026] acpiphp: Slot [5-2] registered
      [    0.886089] acpiphp: Slot [6-2] registered
      [    0.886155] acpiphp: Slot [7-2] registered
      [    0.886221] acpiphp: Slot [8-2] registered
      [    0.886289] acpiphp: Slot [9-2] registered
      [    0.886353] acpiphp: Slot [10-2] registered
      [    0.886418] acpiphp: Slot [11-2] registered
      [    0.886839] acpiphp: Slot [12-2] registered
      [    0.886903] acpiphp: Slot [13-2] registered
      [    0.886967] acpiphp: Slot [14-2] registered
      [    0.887035] acpiphp: Slot [15-2] registered
      [    0.887102] acpiphp: Slot [16-2] registered
      [    0.887168] acpiphp: Slot [17-2] registered
      [    0.887235] acpiphp: Slot [18-2] registered
      [    0.887298] acpiphp: Slot [19-2] registered
      [    0.887362] acpiphp: Slot [20-2] registered
      [    0.887430] acpiphp: Slot [21-2] registered
      [    0.887495] acpiphp: Slot [22-2] registered
      [    0.887561] acpiphp: Slot [23-2] registered
      [    0.887628] acpiphp: Slot [24-2] registered
      [    0.887693] acpiphp: Slot [25-2] registered
      [    0.887757] acpiphp: Slot [26-2] registered
      [    0.887826] acpiphp: Slot [27-2] registered
      [    0.887891] acpiphp: Slot [28-2] registered
      [    0.887955] acpiphp: Slot [29] registered
      [    0.888015] acpiphp: Slot [30] registered
      [    0.888075] acpiphp: Slot [31] registered
      [    0.888485] pci 0000:00:1e.0: PCI bridge to [bus 01]
      [    0.888516] pci 0000:00:1e.0:   bridge window [io  0xd000-0xdfff]
      [    0.888544] pci 0000:00:1e.0:   bridge window [mem 0xfe800000-0xfe9fffff]
      [    0.888597] pci 0000:00:1e.0:   bridge window [mem 0xfe200000-0xfe3fffff 64bit pref]
      [    0.889739] pci_bus 0000:02: extended config space not accessible
      [    0.890248] acpiphp: Slot [0-2] registered
      [    0.890314] acpiphp: Slot [1-2] registered
      [    0.890381] acpiphp: Slot [2-2] registered
      [    0.890446] acpiphp: Slot [3-3] registered
      [    0.890511] acpiphp: Slot [4-3] registered
      [    0.890578] acpiphp: Slot [5-3] registered
      [    0.890644] acpiphp: Slot [6-3] registered
      [    0.890708] acpiphp: Slot [7-3] registered
      [    0.890797] acpiphp: Slot [8-3] registered
      [    0.892050] acpiphp: Slot [9-3] registered
      [    0.892120] acpiphp: Slot [10-3] registered
      [    0.892187] acpiphp: Slot [11-3] registered
      [    0.892263] acpiphp: Slot [12-3] registered
      [    0.892330] acpiphp: Slot [13-3] registered
      [    0.892399] acpiphp: Slot [14-3] registered
      [    0.892467] acpiphp: Slot [15-3] registered
      [    0.892534] acpiphp: Slot [16-3] registered
      [    0.892599] acpiphp: Slot [17-3] registered
      [    0.892666] acpiphp: Slot [18-3] registered
      [    0.892730] acpiphp: Slot [19-3] registered
      [    0.892798] acpiphp: Slot [20-3] registered
      [    0.892865] acpiphp: Slot [21-3] registered
      [    0.892931] acpiphp: Slot [22-3] registered
      [    0.892998] acpiphp: Slot [23-3] registered
      [    0.893063] acpiphp: Slot [24-3] registered
      [    0.893128] acpiphp: Slot [25-3] registered
      [    0.893195] acpiphp: Slot [26-3] registered
      [    0.893262] acpiphp: Slot [27-3] registered
      [    0.893329] acpiphp: Slot [28-3] registered
      [    0.893397] acpiphp: Slot [29-2] registered
      [    0.893463] acpiphp: Slot [30-2] registered
      [    0.893528] acpiphp: Slot [31-2] registered
      [    0.893964] pci 0000:00:1f.0: PCI bridge to [bus 02]
      [    0.893996] pci 0000:00:1f.0:   bridge window [io  0xc000-0xcfff]
      [    0.894025] pci 0000:00:1f.0:   bridge window [mem 0xfe600000-0xfe7fffff]
      [    0.894079] pci 0000:00:1f.0:   bridge window [mem 0xfe000000-0xfe1fffff 64bit pref]
      [    0.896729] ACPI: PCI Interrupt Link [LNKA] (IRQs 5 *10 11)
      [    0.896920] ACPI: PCI Interrupt Link [LNKB] (IRQs 5 *10 11)
      [    0.897088] ACPI: PCI Interrupt Link [LNKC] (IRQs 5 10 *11)
      [    0.897261] ACPI: PCI Interrupt Link [LNKD] (IRQs 5 10 *11)
      [    0.897378] ACPI: PCI Interrupt Link [LNKS] (IRQs *9)
      [    0.897992] pci 0000:00:02.0: vgaarb: setting as boot VGA device
      [    0.897992] pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
      [    0.897992] pci 0000:00:02.0: vgaarb: bridge control possible
      [    0.897992] vgaarb: loaded
      [    0.897992] pps_core: LinuxPPS API ver. 1 registered
      [    0.897992] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
      [    0.897992] PTP clock support registered
      [    0.897992] EDAC MC: Ver: 3.0.0
      [    0.899070] PCI: Using ACPI for IRQ routing
      [    0.899070] PCI: pci_cache_line_size set to 64 bytes
      [    0.899234] e820: reserve RAM buffer [mem 0x0009fc00-0x0009ffff]
      [    0.899236] e820: reserve RAM buffer [mem 0xbffd6000-0xbfffffff]
      [    0.899427] HPET: 3 timers in total, 0 timers will be used for per-cpu timer
      [    0.899427] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
      [    0.899427] hpet0: 3 comparators, 64-bit 100.000000 MHz counter
      [    0.908843] clocksource: Switched to clocksource kvm-clock
      [    0.925114] VFS: Disk quotas dquot_6.6.0
      [    0.925137] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
      [    0.925310] AppArmor: AppArmor Filesystem Enabled
      [    0.925342] pnp: PnP ACPI init
      [    0.925443] pnp 00:00: Plug and Play ACPI device, IDs PNP0303 (active)
      [    0.925481] pnp 00:01: Plug and Play ACPI device, IDs PNP0f13 (active)
      [    0.925498] pnp 00:02: [dma 2]
      [    0.925519] pnp 00:02: Plug and Play ACPI device, IDs PNP0700 (active)
      [    0.925551] pnp 00:03: Plug and Play ACPI device, IDs PNP0b00 (active)
      [    0.926082] pnp: PnP ACPI: found 4 devices
      [    0.938003] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
      [    0.938030] pci 0000:00:1e.0: PCI bridge to [bus 01]
      [    0.938058] pci 0000:00:1e.0:   bridge window [io  0xd000-0xdfff]
      [    0.939402] pci 0000:00:1e.0:   bridge window [mem 0xfe800000-0xfe9fffff]
      [    0.940157] pci 0000:00:1e.0:   bridge window [mem 0xfe200000-0xfe3fffff 64bit pref]
      [    0.942510] pci 0000:00:1f.0: PCI bridge to [bus 02]
      [    0.942538] pci 0000:00:1f.0:   bridge window [io  0xc000-0xcfff]
      [    0.943805] pci 0000:00:1f.0:   bridge window [mem 0xfe600000-0xfe7fffff]
      [    0.944526] pci 0000:00:1f.0:   bridge window [mem 0xfe000000-0xfe1fffff 64bit pref]
      [    0.945970] pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7 window]
      [    0.945974] pci_bus 0000:00: resource 5 [io  0x0d00-0xffff window]
      [    0.945976] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
      [    0.945978] pci_bus 0000:00: resource 7 [mem 0xc0000000-0xfebfffff window]
      [    0.945980] pci_bus 0000:00: resource 8 [mem 0x1c0000000-0x23fffffff window]
      [    0.945984] pci_bus 0000:01: resource 0 [io  0xd000-0xdfff]
      [    0.945985] pci_bus 0000:01: resource 1 [mem 0xfe800000-0xfe9fffff]
      [    0.945987] pci_bus 0000:01: resource 2 [mem 0xfe200000-0xfe3fffff 64bit pref]
      [    0.945989] pci_bus 0000:02: resource 0 [io  0xc000-0xcfff]
      [    0.945991] pci_bus 0000:02: resource 1 [mem 0xfe600000-0xfe7fffff]
      [    0.945992] pci_bus 0000:02: resource 2 [mem 0xfe000000-0xfe1fffff 64bit pref]
      [    0.946178] NET: Registered protocol family 2
      [    0.946485] IP idents hash table entries: 131072 (order: 8, 1048576 bytes)
      [    0.948177] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes)
      [    0.948244] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
      [    0.949246] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
      [    0.949599] TCP: Hash tables configured (established 65536 bind 65536)
      [    0.949707] UDP hash table entries: 4096 (order: 5, 131072 bytes)
      [    0.949779] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
      [    0.949923] NET: Registered protocol family 1
      [    0.949933] NET: Registered protocol family 44
      [    0.950017] pci 0000:00:01.0: PIIX3: Enabling Passive Release
      [    0.950041] pci 0000:00:00.0: Limiting direct PCI/PCI transfers
      [    0.950062] pci 0000:00:01.0: Activating ISA DMA hang workarounds
      [    0.987366] PCI Interrupt Link [LNKD] enabled at IRQ 11
      [    1.024975] pci 0000:00:01.2: quirk_usb_early_handoff+0x0/0x6d0 took 73109 usecs
      [    1.025093] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
      [    1.062110] PCI Interrupt Link [LNKA] enabled at IRQ 10
      [    1.099463] pci 0000:00:1d.0: quirk_usb_early_handoff+0x0/0x6d0 took 72548 usecs
      [    1.136393] PCI Interrupt Link [LNKB] enabled at IRQ 10
      [    1.173694] pci 0000:00:1d.1: quirk_usb_early_handoff+0x0/0x6d0 took 72436 usecs
      [    1.210875] PCI Interrupt Link [LNKC] enabled at IRQ 11
      [    1.249471] pci 0000:00:1d.2: quirk_usb_early_handoff+0x0/0x6d0 took 73942 usecs
      [    1.324259] pci 0000:00:1d.7: quirk_usb_early_handoff+0x0/0x6d0 took 72979 usecs
      [    1.324334] PCI: CLS 0 bytes, default 64
      [    1.324420] Unpacking initramfs...
      [    2.188190] Freeing initrd memory: 35340K
      [    2.188197] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
      [    2.188199] software IO TLB: mapped [mem 0xbbfd6000-0xbffd6000] (64MB)
      [    2.188255] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x159647815e3, max_idle_ns: 440795269835 ns
      [    2.189185] Initialise system trusted keyrings
      [    2.189199] Key type blacklist registered
      [    2.189392] workingset: timestamp_bits=40 max_order=21 bucket_order=0
      [    2.191068] zbud: loaded
      [    2.455722] Key type asymmetric registered
      [    2.455726] Asymmetric key parser 'x509' registered
      [    2.455769] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
      [    2.455901] io scheduler noop registered
      [    2.455902] io scheduler deadline registered
      [    2.455961] io scheduler cfq registered (default)
      [    2.455963] io scheduler mq-deadline registered
      [    2.456425] shpchp 0000:00:1e.0: Requesting control of SHPC hotplug via OSHP (\_SB_.PCI0.SF0_)
      [    2.456436] shpchp 0000:00:1e.0: Requesting control of SHPC hotplug via OSHP (\_SB_.PCI0)
      [    2.456443] shpchp 0000:00:1e.0: Cannot get control of SHPC hotplug
      [    2.456522] shpchp 0000:00:1f.0: Requesting control of SHPC hotplug via OSHP (\_SB_.PCI0.SF8_)
      [    2.456528] shpchp 0000:00:1f.0: Requesting control of SHPC hotplug via OSHP (\_SB_.PCI0)
      [    2.456531] shpchp 0000:00:1f.0: Cannot get control of SHPC hotplug
      [    2.456547] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
      [    2.456963] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
      [    2.457838] Linux agpgart interface v0.103
      [    2.458014] AMD IOMMUv2 driver by Joerg Roedel <jroedel@suse.de>
      [    2.458015] AMD IOMMUv2 functionality not available on this system
      [    2.458623] i8042: PNP: PS/2 Controller [PNP0303:KBD,PNP0f13:MOU] at 0x60,0x64 irq 1,12
      [    2.459829] serio: i8042 KBD port at 0x60,0x64 irq 1
      [    2.459840] serio: i8042 AUX port at 0x60,0x64 irq 12
      [    2.460098] mousedev: PS/2 mouse device common for all mice
      [    2.460346] rtc_cmos 00:03: RTC can wake from S4
      [    2.461196] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input0
      [    2.461555] rtc_cmos 00:03: registered as rtc0
      [    2.461581] rtc_cmos 00:03: alarms up to one day, y3k, 242 bytes nvram, hpet irqs
      [    2.461748] ledtrig-cpu: registered to indicate activity on CPUs
      [    2.462129] NET: Registered protocol family 10
      [    2.475497] Segment Routing with IPv6
      [    2.475534] mip6: Mobile IPv6
      [    2.475539] NET: Registered protocol family 17
      [    2.475628] mpls_gso: MPLS GSO support
      [    2.476062] mce: Using 10 MCE banks
      [    2.476097] sched_clock: Marking stable (2445417942, 30617699)->(2492629875, -16594234)
      [    2.477058] registered taskstats version 1
      [    2.477059] Loading compiled-in X.509 certificates
      [    2.534449] Loaded X.509 cert 'Debian Secure Boot CA: 6ccece7e4c6c0d1f6149f3dd27dfcc5cbb419ea1'
      [    2.534477] Loaded X.509 cert 'Debian Secure Boot Signer 2021 - linux: 4b6ef5abca669825178e052c84667ccbc0531f8c'
      [    2.534525] zswap: loaded using pool lzo/zbud
      [    2.534847] AppArmor: AppArmor sha1 policy hashing enabled
      [    2.536445] rtc_cmos 00:03: setting system clock to 2022-03-01 08:04:16 UTC (1646121856)
      [    2.538873] Freeing unused kernel image memory: 1596K
      [    2.566823] Write protecting the kernel read-only data: 16384k
      [    2.567716] Freeing unused kernel image memory: 2028K
      [    2.568091] Freeing unused kernel image memory: 764K
      [    2.581594] x86/mm: Checked W+X mappings: passed, no W+X pages found.
      [    2.581706] x86/mm: Checking user space page tables
      [    2.594997] x86/mm: Checked W+X mappings: passed, no W+X pages found.
      [    2.595001] Run /init as init process
      [    2.724849] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
      [    2.724886] ACPI: Power Button [PWRF]
      [    2.754206] piix4_smbus 0000:00:01.3: SMBus Host Controller at 0x700, revision 0
      [    2.783126] FDC 0 is a S82078B
      [    2.793254] ACPI: bus type USB registered
      [    2.793296] usbcore: registered new interface driver usbfs
      [    2.793309] usbcore: registered new interface driver hub
      [    2.793330] usbcore: registered new device driver usb
      [    2.798110] input: VirtualPS/2 VMware VMMouse as /devices/platform/i8042/serio1/input/input4
      [    2.798603] input: VirtualPS/2 VMware VMMouse as /devices/platform/i8042/serio1/input/input3
      [    2.799474] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
      [    2.805697] uhci_hcd: USB Universal Host Controller Interface driver
      [    2.814165] SCSI subsystem initialized
      [    2.830609] ehci-pci: EHCI PCI platform driver
      [    2.831642] libata version 3.00 loaded.
      [    2.834902] ata_piix 0000:00:01.1: version 2.13
      [    2.841978] scsi host0: ata_piix
      [    2.845888] scsi host1: ata_piix
      [    2.845986] ata1: PATA max MWDMA2 cmd 0x1f0 ctl 0x3f6 bmdma 0xe120 irq 14
      [    2.845988] ata2: PATA max MWDMA2 cmd 0x170 ctl 0x376 bmdma 0xe128 irq 15
      [    2.863499] [drm] Found bochs VGA, ID 0xb0c5.
      [    2.863502] [drm] Framebuffer size 16384 kB @ 0xfd000000, mmio @ 0xfea50000.
      [    2.863675] [TTM] Zone  kernel: Available graphics memory: 3052724 kiB
      [    2.863676] [TTM] Zone   dma32: Available graphics memory: 2097152 kiB
      [    2.863677] [TTM] Initializing pool allocator
      [    2.863682] [TTM] Initializing DMA pool allocator
      [    2.866396] fbcon: bochsdrmfb (fb0) is primary device
      [    2.876619] Console: switching to colour frame buffer device 128x48
      [    2.879783] bochs-drm 0000:00:02.0: fb0: bochsdrmfb frame buffer device
      [    2.885512] uhci_hcd 0000:00:01.2: UHCI Host Controller
      [    2.885529] uhci_hcd 0000:00:01.2: new USB bus registered, assigned bus number 1
      [    2.885560] uhci_hcd 0000:00:01.2: detected 2 ports
      [    2.885761] uhci_hcd 0000:00:01.2: irq 11, io base 0x0000e080
      [    2.885968] usb usb1: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
      [    2.885970] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
      [    2.885972] usb usb1: Product: UHCI Host Controller
      [    2.885973] usb usb1: Manufacturer: Linux 4.19.0-18-amd64 uhci_hcd
      [    2.885975] usb usb1: SerialNumber: 0000:00:01.2
      [    2.886235] hub 1-0:1.0: USB hub found
      [    2.886247] hub 1-0:1.0: 2 ports detected
      [    2.924226] ehci-pci 0000:00:1d.7: EHCI Host Controller
      [    2.924247] ehci-pci 0000:00:1d.7: new USB bus registered, assigned bus number 2
      [    2.930847] [drm] Initialized bochs-drm 1.0.0 20130925 for 0000:00:02.0 on minor 0
      [    3.200382] ehci-pci 0000:00:1d.7: irq 11, io mem 0xfea53000
      [    3.201226] ata2.01: NODEV after polling detection
      [    3.201625] ata2.00: ATAPI: QEMU DVD-ROM, 2.5+, max UDMA/100
      [    3.203498] scsi 1:0:0:0: CD-ROM            QEMU     QEMU DVD-ROM     2.5+ PQ: 0 ANSI: 5
      [    3.216265] sr 1:0:0:0: [sr0] scsi3-mmc drive: 4x/4x cd/rw xa/form2 tray
      [    3.216269] cdrom: Uniform CD-ROM driver Revision: 3.20
      [    3.217187] sr 1:0:0:0: Attached scsi CD-ROM sr0
      [    3.256587] scsi host2: Virtio SCSI HBA
      [    3.261549] scsi 2:0:0:0: Direct-Access     QEMU     QEMU HARDDISK    2.5+ PQ: 0 ANSI: 5
      [    3.269967] virtio_net virtio2 ens18: renamed from eth0
      [    3.293252] random: fast init done
      [    3.303334] sd 2:0:0:0: Power-on or device reset occurred
      [    3.304218] sd 2:0:0:0: [sda] 67108864 512-byte logical blocks: (34.4 GB/32.0 GiB)
      [    3.304279] sd 2:0:0:0: [sda] Write Protect is off
      [    3.304281] sd 2:0:0:0: [sda] Mode Sense: 63 00 00 08
      [    3.304391] sd 2:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
      [    3.311408]  sda: sda1 sda2 < sda5 >
      [    3.312848] sd 2:0:0:0: [sda] Attached SCSI disk
      [    3.331872] usb 1-1: new full-speed USB device number 2 using uhci_hcd
      [    3.346918] ehci-pci 0000:00:1d.7: USB 2.0 started, EHCI 1.00
      [    3.347041] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
      [    3.347043] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
      [    3.347045] usb usb2: Product: EHCI Host Controller
      [    3.347046] usb usb2: Manufacturer: Linux 4.19.0-18-amd64 ehci_hcd
      [    3.347048] usb usb2: SerialNumber: 0000:00:1d.7
      [    3.347239] hub 2-0:1.0: USB hub found
      [    3.347251] hub 2-0:1.0: 6 ports detected
      [    3.347976] uhci_hcd 0000:00:1d.0: UHCI Host Controller
      [    3.347990] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 3
      [    3.348063] uhci_hcd 0000:00:1d.0: detected 2 ports
      [    3.348339] uhci_hcd 0000:00:1d.0: irq 10, io base 0x0000e0c0
      [    3.348517] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
      [    3.348519] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
      [    3.348521] usb usb3: Product: UHCI Host Controller
      [    3.348523] usb usb3: Manufacturer: Linux 4.19.0-18-amd64 uhci_hcd
      [    3.348524] usb usb3: SerialNumber: 0000:00:1d.0
      [    3.348738] hub 3-0:1.0: USB hub found
      [    3.348750] hub 3-0:1.0: 2 ports detected
      [    3.387920] uhci_hcd 0000:00:1d.1: UHCI Host Controller
      [    3.387940] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 4
      [    3.387973] uhci_hcd 0000:00:1d.1: detected 2 ports
      [    3.388072] uhci_hcd 0000:00:1d.1: irq 10, io base 0x0000e0e0
      [    3.388229] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
      [    3.388231] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
      [    3.388233] usb usb4: Product: UHCI Host Controller
      [    3.388234] usb usb4: Manufacturer: Linux 4.19.0-18-amd64 uhci_hcd
      [    3.388236] usb usb4: SerialNumber: 0000:00:1d.1
      [    3.388433] hub 4-0:1.0: USB hub found
      [    3.388443] hub 4-0:1.0: 2 ports detected
      [    3.426600] uhci_hcd 0000:00:1d.2: UHCI Host Controller
      [    3.426620] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 5
      [    3.426651] uhci_hcd 0000:00:1d.2: detected 2 ports
      [    3.426757] uhci_hcd 0000:00:1d.2: irq 11, io base 0x0000e100
      [    3.426942] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
      [    3.426945] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
      [    3.426946] usb usb5: Product: UHCI Host Controller
      [    3.426948] usb usb5: Manufacturer: Linux 4.19.0-18-amd64 uhci_hcd
      [    3.426949] usb usb5: SerialNumber: 0000:00:1d.2
      [    3.427144] hub 5-0:1.0: USB hub found
      [    3.427154] hub 5-0:1.0: 2 ports detected
      [    3.503334] usb 1-1: not running at top speed; connect to a high speed hub
      [    3.536901] usb 1-1: New USB device found, idVendor=0627, idProduct=0001, bcdDevice= 0.00
      [    3.536904] usb 1-1: New USB device strings: Mfr=1, Product=3, SerialNumber=10
      [    3.536906] usb 1-1: Product: QEMU USB Tablet
      [    3.536908] usb 1-1: Manufacturer: QEMU
      [    3.536909] usb 1-1: SerialNumber: 28754-0000:00:01.2-1
      [    3.553645] hidraw: raw HID events driver (C) Jiri Kosina
      [    3.561776] usbcore: registered new interface driver usbhid
      [    3.561779] usbhid: USB HID core driver
      [    3.564733] input: QEMU QEMU USB Tablet as /devices/pci0000:00/0000:00:01.2/usb1/1-1/1-1:1.0/0003:0627:0001.0001/input/input5
      [    3.564896] hid-generic 0003:0627:0001.0001: input,hidraw0: USB HID v0.01 Mouse [QEMU QEMU USB Tablet] on usb-0000:00:01.2-1/input0
      [    3.606834] usb 2-1: new high-speed USB device number 2 using ehci-pci
      [    3.637768] PM: Image not found (code -22)
      [    3.716345] cryptd: max_cpu_qlen set to 1000
      [    3.773530] usb 2-1: New USB device found, idVendor=0451, idProduct=bef3, bcdDevice= 1.00
      [    3.773534] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
      [    3.773536] usb 2-1: Product: XDS110 (03.00.00.16) Embed with CMSIS-DAP
      [    3.773538] usb 2-1: Manufacturer: Texas Instruments
      [    3.773539] usb 2-1: SerialNumber: L1100LEH
      [    3.782431] hid-generic 0003:0451:BEF3.0002: hiddev0,hidraw1: USB HID v1.11 Device [Texas Instruments XDS110 (03.00.00.16) Embed with CMSIS-DAP] on usb-0000:00:1d.7-1/input5
      [    3.938848] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
      [    4.153724] systemd[1]: Inserted module 'autofs4'
      [    4.184756] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
      [    4.184851] systemd[1]: Detected virtualization kvm.
      [    4.184861] systemd[1]: Detected architecture x86-64.
      [    4.193370] systemd[1]: Set hostname to <ioBroker>.
      [    4.414019] random: systemd: uninitialized urandom read (16 bytes read)
      [    4.416828] random: systemd: uninitialized urandom read (16 bytes read)
      [    4.421144] systemd[1]: Created slice User and Session Slice.
      [    4.421279] random: systemd: uninitialized urandom read (16 bytes read)
      [    4.421521] systemd[1]: Listening on fsck to fsckd communication Socket.
      [    4.421799] systemd[1]: Listening on Journal Socket.
      [    4.425396] systemd[1]: Starting Set the console keyboard layout...
      [    4.425490] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
      [    4.435806] systemd[1]: Listening on RPCbind Server Activation Socket.
      [    4.479241] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
      [    4.531098] RPC: Registered named UNIX socket transport module.
      [    4.531102] RPC: Registered udp transport module.
      [    4.531102] RPC: Registered tcp transport module.
      [    4.531103] RPC: Registered tcp NFSv4.1 backchannel transport module.
      [    4.702615] systemd-journald[225]: Received request to flush runtime journal from PID 1
      [    4.920083] audit: type=1400 audit(1646121858.880:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libreoffice-xpdfimport" pid=296 comm="apparmor_parser"
      [    4.920865] audit: type=1400 audit(1646121858.880:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libreoffice-senddoc" pid=301 comm="apparmor_parser"
      [    4.925124] audit: type=1400 audit(1646121858.884:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libreoffice-oopslash" pid=298 comm="apparmor_parser"
      [    4.932533] audit: type=1400 audit(1646121858.892:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=308 comm="apparmor_parser"
      [    4.932541] audit: type=1400 audit(1646121858.892:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=308 comm="apparmor_parser"
      [    4.935352] audit: type=1400 audit(1646121858.896:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/man" pid=309 comm="apparmor_parser"
      [    4.935359] audit: type=1400 audit(1646121858.896:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_filter" pid=309 comm="apparmor_parser"
      [    4.935362] audit: type=1400 audit(1646121858.896:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_groff" pid=309 comm="apparmor_parser"
      [    4.973306] audit: type=1400 audit(1646121858.932:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/telepathy/mission-control-5" pid=300 comm="apparmor_parser"
      [    5.019820] input: PC Speaker as /devices/platform/pcspkr/input/input6
      [    5.104334] cdc_acm 2-1:1.0: ttyACM0: USB ACM device
      [    5.105931] sr 1:0:0:0: Attached scsi generic sg0 type 5
      [    5.109136] sd 2:0:0:0: Attached scsi generic sg1 type 0
      [    5.112553] cdc_acm 2-1:1.3: ttyACM1: USB ACM device
      [    5.117668] usbcore: registered new interface driver cdc_acm
      [    5.117671] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
      [    5.476265] Adding 6288380k swap on /dev/sda5.  Priority:-2 extents:1 across:6288380k FS
      [    6.127316] IPv6: ADDRCONF(NETDEV_UP): ens18: link is not ready
      [    7.194821] random: crng init done
      [    7.194825] random: 7 urandom warning(s) missed due to ratelimiting
      [  227.777964] alg: No test for fips(ansi_cprng) (fips_ansi_cprng)
      [  227.846331] Bluetooth: Core ver 2.22
      [  227.846396] NET: Registered protocol family 31
      [  227.846398] Bluetooth: HCI device and connection manager initialized
      [  227.846404] Bluetooth: HCI socket layer initialized
      [  227.846407] Bluetooth: L2CAP socket layer initialized
      [  227.846415] Bluetooth: SCO socket layer initialized
      • H homecineplexx
        [    0.709870]  #2
        [    0.723002]  #3
        wendy2702W Offline
        wendy2702W Offline
        @homecineplexx
        Kannst du das "dmesg" auch mal vom Proxmox absetzen, das hier war ja scheinbar aus der VM für iobroker, oder?
        Kannst du auch mal das posten:
        df -h
        free -m
        Und auch mal mit top oder htop beobachten wie die Auslastung ist
        H 2 Antworten Letzte Antwort
        • H homecineplexx
          Hallo
          Ich betreibe seit ca 2-3 Jahren einen Intel Nuc (Proxmox) mit einer ganz billigen herkömmlichen SSD und ich glaub mit 16GB RAM.
          hab diesen hier:
          NUC
          Irgendwie wird das Teil einfach immer langsamer und ich muss ständig restarten. Stellt sich für mich die Frage, liegts an einer eingehenden Festplatte? Wenn ja, welche nimmt man sich?
          SSD1
          SSD2
          oder liegts an einem anderen Problem?
          Immerhin sind in den Jahren die (Anzahl) Javascripts gewachsen und auch die Devices die dran gekoppelt sind.
          oder sollte man überhaupt auf einen anderen Server umsteigen?
          BananaJoeB Offline
          BananaJoeB Offline
          BananaJoe
          @homecineplexx mal unabhängig davon das die anderen dir helfen die Probleme zu lösen:
          Ich würde beim nächsten mal eine NVMe nehmen. Ich habe meine ESXi-Hosts von SSD auf NVMe umgebaut (müssen richtige PCIe M.2 NVMe sein), da hat sich beim lesen nicht soviel geändert, Schreibtests laufen nun aber mit 450MByte/s statt 50MByte/s.
            @homecineplexx
            df -h
            free -m
            homecineplexx
            @wendy2702 said in Welche SSD?:
            @homecineplexx
            df -h
            free -m
            richtig, das war aus der VM raus!
            und das hier ist vom Proxmox:
            root@pve:~# dmesg
            [    0.000000] Linux version 5.13.19-2-pve (build@proxmox) (gcc (Debian 10.2.1-6) 10.2.1 20210110, GNU ld (GNU Binutils for Debian) 2.35.2) #1 SMP PVE 5.13.19-4 (Mon, 29 Nov 2021 12:10:09 +0100) ()
            [    0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-5.13.19-2-pve root=/dev/mapper/pve-root ro quiet
            [    0.000000] KERNEL supported cpus:
            [    0.000000]   Intel GenuineIntel
            [    0.000000]   AMD AuthenticAMD
            [    0.000000]   Hygon HygonGenuine
            [    0.000000]   Centaur CentaurHauls
            [    0.000000]   zhaoxin   Shanghai
            [    0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
            [    0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
            [    0.000000] x86/fpu: Supporting XSAVE feature 0x008: 'MPX bounds registers'
            [    0.000000] x86/fpu: Supporting XSAVE feature 0x010: 'MPX CSR'
            [    0.000000] x86/fpu: xstate_offset[3]:  576, xstate_sizes[3]:   64
            [    0.000000] x86/fpu: xstate_offset[4]:  640, xstate_sizes[4]:   64
            [    0.000000] x86/fpu: Enabled xstate features 0x1b, context size is 704 bytes, using 'compacted' format.
            [    0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000003efff] usable
            [    0.000000] BIOS-e820: [mem 0x000000000003f000-0x000000000003ffff] reserved
            [    0.000000] BIOS-e820: [mem 0x0000000000040000-0x000000000009dfff] usable
            [    0.000000] BIOS-e820: [mem 0x000000000009e000-0x00000000000fffff] reserved
            [    0.000000] BIOS-e820: [mem 0x0000000000100000-0x000000000fffffff] usable
            [    0.000000] BIOS-e820: [mem 0x0000000010000000-0x0000000012150fff] reserved
            [    0.000000] BIOS-e820: [mem 0x0000000012151000-0x0000000077367fff] usable
            [    0.000000] BIOS-e820: [mem 0x0000000077368000-0x0000000079489fff] reserved
            [    0.000000] BIOS-e820: [mem 0x000000007948a000-0x00000000794a4fff] ACPI data
            [    0.000000] BIOS-e820: [mem 0x00000000794a5000-0x00000000798a7fff] ACPI NVS
            [    0.000000] BIOS-e820: [mem 0x00000000798a8000-0x0000000079bd1fff] reserved
            [    0.000000] BIOS-e820: [mem 0x0000000079bd2000-0x0000000079c36fff] type 20
            [    0.000000] BIOS-e820: [mem 0x0000000079c37000-0x0000000079fb9fff] usable
            [    0.000000] BIOS-e820: [mem 0x0000000079fba000-0x0000000079fbafff] ACPI NVS
            [    0.000000] BIOS-e820: [mem 0x0000000079fbb000-0x0000000079fe4fff] reserved
            [    0.000000] BIOS-e820: [mem 0x0000000079fe5000-0x000000007a9defff] usable
            [    0.000000] BIOS-e820: [mem 0x000000007a9df000-0x000000007a9e0fff] reserved
            [    0.000000] BIOS-e820: [mem 0x000000007a9e1000-0x000000007affffff] usable
            [    0.000000] BIOS-e820: [mem 0x000000007b000000-0x000000007fffffff] reserved
            [    0.000000] BIOS-e820: [mem 0x00000000d0000000-0x00000000d0ffffff] reserved
            [    0.000000] BIOS-e820: [mem 0x00000000e0000000-0x00000000efffffff] reserved
            [    0.000000] BIOS-e820: [mem 0x00000000fe042000-0x00000000fe044fff] reserved
            [    0.000000] BIOS-e820: [mem 0x00000000fe900000-0x00000000fe902fff] reserved
            [    0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
            [    0.000000] BIOS-e820: [mem 0x00000000fed01000-0x00000000fed01fff] reserved
            [    0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
            [    0.000000] BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
            [    0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000047fffffff] usable
            [    0.000000] efi: EFI v2.50 by American Megatrends
            [    0.000000] efi: TPMFinalLog=0x79878000 ACPI=0x79497000 ACPI 2.0=0x79497000 SMBIOS=0x79a9d000 SMBIOS 3.0=0x79a9c000 ESRT=0x79a97a58
            [    0.000000] secureboot: Secure boot could not be determined (mode 0)
            [    0.000000] SMBIOS 3.0.0 present.
            [    0.000000] DMI: Intel(R) Client Systems NUC6CAYH/NUC6CAYB, BIOS AYAPLCEL.86A.0055.2018.0821.1152 08/21/2018
            [    0.000000] tsc: Detected 1497.600 MHz processor
            [    0.000023] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
            [    0.000031] e820: remove [mem 0x000a0000-0x000fffff] usable
            [    0.000051] last_pfn = 0x480000 max_arch_pfn = 0x400000000
            [    0.000103] x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WP  UC- WT
            [    0.000331] last_pfn = 0x7b000 max_arch_pfn = 0x400000000
            [    0.007830] esrt: Reserving ESRT space from 0x0000000079a97a58 to 0x0000000079a97a90.
            [    0.007847] Using GB pages for direct mapping
            [    0.008762] secureboot: Secure boot could not be determined (mode 0)
            [    0.008764] RAMDISK: [mem 0x30e5d000-0x34725fff]
            [    0.008771] ACPI: Early table checksum verification disabled
            [    0.008779] ACPI: RSDP 0x0000000079497000 000024 (v02 INTEL )
            [    0.008789] ACPI: XSDT 0x00000000794970C0 0000E4 (v01 INTEL  NUC6CAYB 01072009 AMI  00010013)
            [    0.008802] ACPI: FACP 0x000000007949FF40 000114 (v06 INTEL  NUC6CAYB 01072009 AMI  00010013)
            [    0.008815] ACPI: DSDT 0x0000000079497240 008CF8 (v02 INTEL  NUC6CAYB 01072009 INTL 20120913)
            [    0.008824] ACPI: FACS 0x0000000079877080 000040
            [    0.008830] ACPI: FPDT 0x00000000794A0060 000044 (v01 INTEL  NUC6CAYB 01072009 AMI  00010013)
            [    0.008838] ACPI: FIDT 0x00000000794A00B0 00009C (v01 INTEL  NUC6CAYB 01072009 AMI  00010013)
            [    0.008846] ACPI: MCFG 0x00000000794A0150 00003C (v01 INTEL  NUC6CAYB 01072009 MSFT 00000097)
            [    0.008853] ACPI: DBG2 0x00000000794A0190 000072 (v00 INTEL  NUC6CAYB 00000003 BRXT 0100000D)
            [    0.008861] ACPI: DBGP 0x00000000794A0210 000034 (v01 INTEL  NUC6CAYB 00000003 BRXT 0100000D)
            [    0.008869] ACPI: HPET 0x00000000794A0250 000038 (v01 INTEL  NUC6CAYB 00000003 BRXT 0100000D)
            [    0.008876] ACPI: LPIT 0x00000000794A0290 00005C (v01 INTEL  NUC6CAYB 00000003 BRXT 0100000D)
            [    0.008884] ACPI: APIC 0x00000000794A02F0 000084 (v03 INTEL  NUC6CAYB 00000003 BRXT 0100000D)
            [    0.008892] ACPI: NPKT 0x00000000794A0380 000065 (v01 INTEL  NUC6CAYB 00000003 BRXT 0100000D)
            [    0.008899] ACPI: PRAM 0x00000000794A03F0 000030 (v01 INTEL  NUC6CAYB 00000003 BRXT 0100000D)
            [    0.008907] ACPI: WSMT 0x00000000794A0420 000028 (v01 INTEL  NUC6CAYB 00000003 BRXT 0100000D)
            [    0.008914] ACPI: SSDT 0x00000000794A0450 00002B (v02 INTEL  NUC6CAYB 00000003 BRXT 0100000D)
            [    0.008922] ACPI: SSDT 0x00000000794A0480 000A19 (v01 INTEL  NUC6CAYB 00001000 INTL 20120913)
            [    0.008930] ACPI: SSDT 0x00000000794A0EA0 000442 (v02 INTEL  NUC6CAYB 00003000 INTL 20120913)
            [    0.008938] ACPI: SSDT 0x00000000794A12F0 00072B (v02 INTEL  NUC6CAYB 00003000 INTL 20120913)
            [    0.008946] ACPI: SSDT 0x00000000794A1A20 00032D (v02 INTEL  NUC6CAYB 00003000 INTL 20120913)
            [    0.008954] ACPI: SSDT 0x00000000794A1D50 00017C (v02 INTEL  NUC6CAYB 00003000 INTL 20120913)
            [    0.008961] ACPI: SSDT 0x00000000794A1ED0 002740 (v02 INTEL  NUC6CAYB 00003000 INTL 20120913)
            [    0.008969] ACPI: UEFI 0x00000000794A4610 000042 (v01 INTEL  NUC6CAYB 00000000      00000000)
            [    0.008977] ACPI: TPM2 0x00000000794A4660 000034 (v03 INTEL  NUC6CAYB 00000001 AMI  00000000)
            [    0.008984] ACPI: DMAR 0x00000000794A46A0 0000A8 (v01 INTEL  NUC6CAYB 00000003 BRXT 0100000D)
            [    0.008992] ACPI: WDAT 0x00000000794A4750 000104 (v01 INTEL  NUC6CAYB 00000000      00000000)
            [    0.009000] ACPI: NHLT 0x00000000794A4860 00002D (v00 INTEL  NUC6CAYB 00000002      01000013)
            [    0.009006] ACPI: Reserving FACP table memory at [mem 0x7949ff40-0x794a0053]
            [    0.009010] ACPI: Reserving DSDT table memory at [mem 0x79497240-0x7949ff37]
            [    0.009013] ACPI: Reserving FACS table memory at [mem 0x79877080-0x798770bf]
            [    0.009016] ACPI: Reserving FPDT table memory at [mem 0x794a0060-0x794a00a3]
            [    0.009019] ACPI: Reserving FIDT table memory at [mem 0x794a00b0-0x794a014b]
            [    0.009021] ACPI: Reserving MCFG table memory at [mem 0x794a0150-0x794a018b]
            [    0.009024] ACPI: Reserving DBG2 table memory at [mem 0x794a0190-0x794a0201]
            [    0.009027] ACPI: Reserving DBGP table memory at [mem 0x794a0210-0x794a0243]
            [    0.009029] ACPI: Reserving HPET table memory at [mem 0x794a0250-0x794a0287]
            [    0.009032] ACPI: Reserving LPIT table memory at [mem 0x794a0290-0x794a02eb]
            [    0.009035] ACPI: Reserving APIC table memory at [mem 0x794a02f0-0x794a0373]
            [    0.009037] ACPI: Reserving NPKT table memory at [mem 0x794a0380-0x794a03e4]
            [    0.009040] ACPI: Reserving PRAM table memory at [mem 0x794a03f0-0x794a041f]
            [    0.009043] ACPI: Reserving WSMT table memory at [mem 0x794a0420-0x794a0447]
            [    0.009045] ACPI: Reserving SSDT table memory at [mem 0x794a0450-0x794a047a]
            [    0.009048] ACPI: Reserving SSDT table memory at [mem 0x794a0480-0x794a0e98]
            [    0.009051] ACPI: Reserving SSDT table memory at [mem 0x794a0ea0-0x794a12e1]
            [    0.009054] ACPI: Reserving SSDT table memory at [mem 0x794a12f0-0x794a1a1a]
            [    0.009056] ACPI: Reserving SSDT table memory at [mem 0x794a1a20-0x794a1d4c]
            [    0.009059] ACPI: Reserving SSDT table memory at [mem 0x794a1d50-0x794a1ecb]
            [    0.009062] ACPI: Reserving SSDT table memory at [mem 0x794a1ed0-0x794a460f]
            [    0.009065] ACPI: Reserving UEFI table memory at [mem 0x794a4610-0x794a4651]
            [    0.009068] ACPI: Reserving TPM2 table memory at [mem 0x794a4660-0x794a4693]
            [    0.009070] ACPI: Reserving DMAR table memory at [mem 0x794a46a0-0x794a4747]
            [    0.009073] ACPI: Reserving WDAT table memory at [mem 0x794a4750-0x794a4853]
            [    0.009076] ACPI: Reserving NHLT table memory at [mem 0x794a4860-0x794a488c]
            [    0.009098] ACPI: Local APIC address 0xfee00000
            [    0.009236] No NUMA configuration found
            [    0.009239] Faking a node at [mem 0x0000000000000000-0x000000047fffffff]
            [    0.009262] NODE_DATA(0) allocated [mem 0x47ffd6000-0x47fffffff]
            [    0.010262] Zone ranges:
            [    0.010265]   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
            [    0.010269]   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
            [    0.010273]   Normal   [mem 0x0000000100000000-0x000000047fffffff]
            [    0.010277]   Device   empty
            [    0.010280] Movable zone start for each node
            [    0.010286] Early memory node ranges
            [    0.010288]   node   0: [mem 0x0000000000001000-0x000000000003efff]
            [    0.010291]   node   0: [mem 0x0000000000040000-0x000000000009dfff]
            [    0.010293]   node   0: [mem 0x0000000000100000-0x000000000fffffff]
            [    0.010296]   node   0: [mem 0x0000000012151000-0x0000000077367fff]
            [    0.010299]   node   0: [mem 0x0000000079c37000-0x0000000079fb9fff]
            [    0.010301]   node   0: [mem 0x0000000079fe5000-0x000000007a9defff]
            [    0.010304]   node   0: [mem 0x000000007a9e1000-0x000000007affffff]
            [    0.010306]   node   0: [mem 0x0000000100000000-0x000000047fffffff]
            [    0.010312] Initmem setup node 0 [mem 0x0000000000001000-0x000000047fffffff]
            [    0.010317] On node 0 totalpages: 4154703
            [    0.010321]   DMA zone: 64 pages used for memmap
            [    0.010323]   DMA zone: 156 pages reserved
            [    0.010325]   DMA zone: 3996 pages, LIFO batch:0
            [    0.010328]   DMA32 zone: 7511 pages used for memmap
            [    0.010330]   DMA32 zone: 480691 pages, LIFO batch:63
            [    0.010333]   Normal zone: 57344 pages used for memmap
            [    0.010335]   Normal zone: 3670016 pages, LIFO batch:63
            [    0.010340] On node 0, zone DMA: 1 pages in unavailable ranges
            [    0.010344] On node 0, zone DMA: 1 pages in unavailable ranges
            [    0.010398] On node 0, zone DMA: 98 pages in unavailable ranges
            [    0.017108] On node 0, zone DMA32: 8529 pages in unavailable ranges
            [    0.017359] On node 0, zone DMA32: 10447 pages in unavailable ranges
            [    0.017399] On node 0, zone DMA32: 43 pages in unavailable ranges
            [    0.017423] On node 0, zone DMA32: 2 pages in unavailable ranges
            [    0.068275] On node 0, zone Normal: 20480 pages in unavailable ranges
            [    0.068299] Reserving Intel graphics memory at [mem 0x7c000000-0x7fffffff]
            [    0.068537] ACPI: PM-Timer IO Port: 0x408
            [    0.068545] ACPI: Local APIC address 0xfee00000
            [    0.068560] ACPI: LAPIC_NMI (acpi_id[0x01] high level lint[0x1])
            [    0.068566] ACPI: LAPIC_NMI (acpi_id[0x02] high level lint[0x1])
            [    0.068569] ACPI: LAPIC_NMI (acpi_id[0x03] high level lint[0x1])
            [    0.068571] ACPI: LAPIC_NMI (acpi_id[0x04] high level lint[0x1])
            [    0.068608] IOAPIC[0]: apic_id 1, version 32, address 0xfec00000, GSI 0-119
            [    0.068616] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
            [    0.068620] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 low level)
            [    0.068625] ACPI: IRQ0 used by override.
            [    0.068628] ACPI: IRQ9 used by override.
            [    0.068632] Using ACPI (MADT) for SMP configuration information
            [    0.068634] ACPI: HPET id: 0x8086a701 base: 0xfed00000
            [    0.068645] TSC deadline timer available
            [    0.068648] smpboot: Allowing 4 CPUs, 0 hotplug CPUs
            [    0.068720] PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
            [    0.068727] PM: hibernation: Registered nosave memory: [mem 0x0003f000-0x0003ffff]
            [    0.068732] PM: hibernation: Registered nosave memory: [mem 0x0009e000-0x000fffff]
            [    0.068737] PM: hibernation: Registered nosave memory: [mem 0x10000000-0x12150fff]
            [    0.068743] PM: hibernation: Registered nosave memory: [mem 0x77368000-0x79489fff]
            [    0.068745] PM: hibernation: Registered nosave memory: [mem 0x7948a000-0x794a4fff]
            [    0.068747] PM: hibernation: Registered nosave memory: [mem 0x794a5000-0x798a7fff]
            [    0.068749] PM: hibernation: Registered nosave memory: [mem 0x798a8000-0x79bd1fff]
            [    0.068751] PM: hibernation: Registered nosave memory: [mem 0x79bd2000-0x79c36fff]
            [    0.068758] PM: hibernation: Registered nosave memory: [mem 0x79fba000-0x79fbafff]
            [    0.068760] PM: hibernation: Registered nosave memory: [mem 0x79fbb000-0x79fe4fff]
            [    0.068765] PM: hibernation: Registered nosave memory: [mem 0x7a9df000-0x7a9e0fff]
            [    0.068770] PM: hibernation: Registered nosave memory: [mem 0x7b000000-0x7fffffff]
            [    0.068773] PM: hibernation: Registered nosave memory: [mem 0x80000000-0xcfffffff]
            [    0.068775] PM: hibernation: Registered nosave memory: [mem 0xd0000000-0xd0ffffff]
            [    0.068777] PM: hibernation: Registered nosave memory: [mem 0xd1000000-0xdfffffff]
            [    0.068779] PM: hibernation: Registered nosave memory: [mem 0xe0000000-0xefffffff]
            [    0.068781] PM: hibernation: Registered nosave memory: [mem 0xf0000000-0xfe041fff]
            [    0.068783] PM: hibernation: Registered nosave memory: [mem 0xfe042000-0xfe044fff]
            [    0.068785] PM: hibernation: Registered nosave memory: [mem 0xfe045000-0xfe8fffff]
            [    0.068787] PM: hibernation: Registered nosave memory: [mem 0xfe900000-0xfe902fff]
            [    0.068789] PM: hibernation: Registered nosave memory: [mem 0xfe903000-0xfebfffff]
            [    0.068791] PM: hibernation: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
            [    0.068794] PM: hibernation: Registered nosave memory: [mem 0xfec01000-0xfed00fff]
            [    0.068796] PM: hibernation: Registered nosave memory: [mem 0xfed01000-0xfed01fff]
            [    0.068798] PM: hibernation: Registered nosave memory: [mem 0xfed02000-0xfedfffff]
            [    0.068800] PM: hibernation: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
            [    0.068802] PM: hibernation: Registered nosave memory: [mem 0xfee01000-0xfeffffff]
            [    0.068804] PM: hibernation: Registered nosave memory: [mem 0xff000000-0xffffffff]
            [    0.068808] [mem 0x80000000-0xcfffffff] available for PCI devices
            [    0.068811] Booting paravirtualized kernel on bare hardware
            [    0.068817] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645519600211568 ns
            [    0.068835] setup_percpu: NR_CPUS:8192 nr_cpumask_bits:4 nr_cpu_ids:4 nr_node_ids:1
            [    0.069454] percpu: Embedded 57 pages/cpu s196608 r8192 d28672 u524288
            [    0.069475] pcpu-alloc: s196608 r8192 d28672 u524288 alloc=1*2097152
            [    0.069482] pcpu-alloc: [0] 0 1 2 3
            [    0.069567] Built 1 zonelists, mobility grouping on.  Total pages: 4089628
            [    0.069575] Policy zone: Normal
            [    0.069579] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.13.19-2-pve root=/dev/mapper/pve-root ro quiet
            [    0.072908] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
            [    0.074521] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
            [    0.074610] mem auto-init: stack:off, heap alloc:on, heap free:off
            [    0.184336] Memory: 16074656K/16618812K available (16393K kernel code, 3487K rwdata, 10016K rodata, 2848K init, 5800K bss, 543896K reserved, 0K cma-reserved)
            [    0.184353] random: get_random_u64 called from __kmem_cache_create+0x2d/0x4e0 with crng_init=0
            [    0.184661] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
            [    0.184692] ftrace: allocating 47502 entries in 186 pages
            [    0.215513] ftrace: allocated 186 pages with 5 groups
            [    0.215779] rcu: Hierarchical RCU implementation.
            [    0.215785] rcu: 	RCU restricting CPUs from NR_CPUS=8192 to nr_cpu_ids=4.
            [    0.215788] 	Rude variant of Tasks RCU enabled.
            [    0.215790] 	Tracing variant of Tasks RCU enabled.
            [    0.215791] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
            [    0.215794] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
            [    0.226586] NR_IRQS: 524544, nr_irqs: 1024, preallocated irqs: 16
            [    0.227191] random: crng done (trusting CPU's manufacturer)
            [    0.227263] Console: colour dummy device 80x25
            [    0.227306] printk: console [tty0] enabled
            [    0.227353] ACPI: Core revision 20210331
            [    0.227662] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 99544814920 ns
            [    0.227759] APIC: Switch to symmetric I/O mode setup
            [    0.227764] DMAR: Host address width 39
            [    0.227766] DMAR: DRHD base: 0x000000fed64000 flags: 0x0
            [    0.227779] DMAR: dmar0: reg_base_addr fed64000 ver 1:0 cap 1c0000c40660462 ecap 7e3ff0505e
            [    0.227784] DMAR: DRHD base: 0x000000fed65000 flags: 0x1
            [    0.227794] DMAR: dmar1: reg_base_addr fed65000 ver 1:0 cap d2008c40660462 ecap f050da
            [    0.227800] DMAR: RMRR base: 0x00000079425000 end: 0x00000079444fff
            [    0.227804] DMAR: RMRR base: 0x0000007b800000 end: 0x0000007fffffff
            [    0.227810] DMAR-IR: IOAPIC id 1 under DRHD base  0xfed65000 IOMMU 1
            [    0.227813] DMAR-IR: HPET id 0 under DRHD base 0xfed65000
            [    0.227816] DMAR-IR: Queued invalidation will be enabled to support x2apic and Intr-remapping.
            [    0.229850] DMAR-IR: Enabled IRQ remapping in x2apic mode
            [    0.229858] x2apic enabled
            [    0.229882] Switched APIC routing to cluster x2apic.
            [    0.234469] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
            [    0.251716] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x159647815e3, max_idle_ns: 440795269835 ns
            [    0.251731] Calibrating delay loop (skipped), value calculated using timer frequency.. 2995.20 BogoMIPS (lpj=5990400)
            [    0.251738] pid_max: default: 32768 minimum: 301
            [    0.257850] LSM: Security Framework initializing
            [    0.257880] Yama: becoming mindful.
            [    0.257945] AppArmor: AppArmor initialized
            [    0.258054] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
            [    0.258117] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
            [    0.258692] CPU0: Thermal monitoring enabled (TM1)
            [    0.258844] Last level iTLB entries: 4KB 48, 2MB 0, 4MB 0
            [    0.258849] Last level dTLB entries: 4KB 0, 2MB 0, 4MB 0, 1GB 0
            [    0.258857] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
            [    0.258861] Spectre V2 : Mitigation: Full generic retpoline
            [    0.258862] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
            [    0.258864] Spectre V2 : Enabling Restricted Speculation for firmware calls
            [    0.258867] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
            [    0.267986] Freeing SMP alternatives memory: 40K
            [    0.268225] smpboot: Estimated ratio of average max frequency by base frequency (times 1024): 1570
            [    0.268247] smpboot: CPU0: Intel(R) Celeron(R) CPU J3455 @ 1.50GHz (family: 0x6, model: 0x5c, stepping: 0x9)
            [    0.268731] Performance Events: PEBS fmt3+, Goldmont events, 32-deep LBR, full-width counters, Intel PMU driver.
            [    0.268768] ... version:                4
            [    0.268770] ... bit width:              48
            [    0.268772] ... generic registers:      4
            [    0.268773] ... value mask:             0000ffffffffffff
            [    0.268775] ... max period:             00007fffffffffff
            [    0.268777] ... fixed-purpose events:   3
            [    0.268779] ... event mask:             000000070000000f
            [    0.268969] rcu: Hierarchical SRCU implementation.
            [    0.270250] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
            [    0.270463] smp: Bringing up secondary CPUs ...
            [    0.270794] x86: Booting SMP configuration:
            [    0.270797] .... node  #0, CPUs:      #1 #2 #3
            [    0.272510] smp: Brought up 1 node, 4 CPUs
            [    0.272510] smpboot: Max logical packages: 1
            [    0.272510] smpboot: Total of 4 processors activated (11980.80 BogoMIPS)
            [    0.273675] devtmpfs: initialized
            [    0.273675] x86/mm: Memory block size: 128MB
            [    0.278207] PM: Registering ACPI NVS region [mem 0x794a5000-0x798a7fff] (4206592 bytes)
            [    0.278207] PM: Registering ACPI NVS region [mem 0x79fba000-0x79fbafff] (4096 bytes)
            [    0.278207] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
            [    0.278207] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
            [    0.278207] pinctrl core: initialized pinctrl subsystem
            [    0.278207] PM: RTC time: 08:13:16, date: 2022-02-28
            [    0.278207] NET: Registered protocol family 16
            [    0.280062] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
            [    0.280492] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
            [    0.280928] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
            [    0.280965] audit: initializing netlink subsys (disabled)
            [    0.281012] audit: type=2000 audit(1646035996.052:1): state=initialized audit_enabled=0 res=1
            [    0.281012] thermal_sys: Registered thermal governor 'fair_share'
            [    0.281012] thermal_sys: Registered thermal governor 'bang_bang'
            [    0.281012] thermal_sys: Registered thermal governor 'step_wise'
            [    0.281012] thermal_sys: Registered thermal governor 'user_space'
            [    0.281012] thermal_sys: Registered thermal governor 'power_allocator'
            [    0.281012] EISA bus registered
            [    0.281012] cpuidle: using governor ladder
            [    0.281012] cpuidle: using governor menu
            [    0.281012] ACPI: bus type PCI registered
            [    0.281012] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
            [    0.281012] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
            [    0.281012] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in E820
            [    0.281012] PCI: Using configuration type 1 for base access
            [    0.285444] Kprobes globally optimized
            [    0.285460] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
            [    0.285460] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
            [    0.287956] ACPI: Added _OSI(Module Device)
            [    0.287962] ACPI: Added _OSI(Processor Device)
            [    0.287964] ACPI: Added _OSI(3.0 _SCP Extensions)
            [    0.287966] ACPI: Added _OSI(Processor Aggregator Device)
            [    0.287968] ACPI: Added _OSI(Linux-Dell-Video)
            [    0.287971] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
            [    0.287973] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
            [    0.311806] ACPI: 8 ACPI AML tables successfully acquired and loaded
            [    0.318189] ACPI: Dynamic OEM Table Load:
            [    0.318206] ACPI: SSDT 0xFFFF8B6841105200 00015F (v02 PmRef  ApIst    00003000 INTL 20120913)
            [    0.322220] ACPI: EC: EC started
            [    0.322223] ACPI: EC: interrupt blocked
            [    0.322308] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
            [    0.322313] ACPI: \_SB_.PCI0.SBRG.H_EC: Boot DSDT EC used to handle transactions
            [    0.322317] ACPI: Interpreter enabled
            [    0.322376] ACPI: (supports S0 S3 S4 S5)
            [    0.322380] ACPI: Using IOAPIC for interrupt routing
            [    0.322469] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
            [    0.323284] ACPI: Enabled 1 GPEs in block 00 to 7F
            [    0.346679] ACPI: PM: Power Resource [FN00] (on)
            [    0.349073] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
            [    0.349091] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI HPX-Type3]
            [    0.351586] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug SHPCHotplug PME AER PCIeCapability LTR]
            [    0.353790] PCI host bridge to bus 0000:00
            [    0.353796] pci_bus 0000:00: root bus resource [io  0x0070-0x0077]
            [    0.353801] pci_bus 0000:00: root bus resource [io  0x0000-0x006f window]
            [    0.353805] pci_bus 0000:00: root bus resource [io  0x0078-0x0cf7 window]
            [    0.353808] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
            [    0.353811] pci_bus 0000:00: root bus resource [mem 0x7c000001-0x7fffffff window]
            [    0.353815] pci_bus 0000:00: root bus resource [mem 0x7b800001-0x7bffffff window]
            [    0.353819] pci_bus 0000:00: root bus resource [mem 0x80000000-0xcfffffff window]
            [    0.353822] pci_bus 0000:00: root bus resource [mem 0xe0000000-0xefffffff window]
            [    0.353826] pci_bus 0000:00: root bus resource [bus 00-ff]
            [    0.353862] pci 0000:00:00.0: [8086:5af0] type 00 class 0x060000
            [    0.354659] pci 0000:00:02.0: [8086:5a85] type 00 class 0x030000
            [    0.354680] pci 0000:00:02.0: reg 0x10: [mem 0x90000000-0x90ffffff 64bit]
            [    0.354694] pci 0000:00:02.0: reg 0x18: [mem 0x80000000-0x8fffffff 64bit pref]
            [    0.354704] pci 0000:00:02.0: reg 0x20: [io  0xf000-0xf03f]
            [    0.355752] pci 0000:00:0e.0: [8086:5a98] type 00 class 0x040380
            [    0.355778] pci 0000:00:0e.0: reg 0x10: [mem 0x91410000-0x91413fff 64bit]
            [    0.355807] pci 0000:00:0e.0: reg 0x20: [mem 0x91000000-0x910fffff 64bit]
            [    0.355877] pci 0000:00:0e.0: PME# supported from D0 D3hot D3cold
            [    0.357274] pci 0000:00:0f.0: [8086:5a9a] type 00 class 0x078000
            [    0.357309] pci 0000:00:0f.0: reg 0x10: [mem 0x91427000-0x91427fff 64bit]
            [    0.357440] pci 0000:00:0f.0: PME# supported from D3hot
            [    0.358152] pci 0000:00:12.0: [8086:5ae3] type 00 class 0x010601
            [    0.358172] pci 0000:00:12.0: reg 0x10: [mem 0x91414000-0x91415fff]
            [    0.358183] pci 0000:00:12.0: reg 0x14: [mem 0x91424000-0x914240ff]
            [    0.358194] pci 0000:00:12.0: reg 0x18: [io  0xf090-0xf097]
            [    0.358204] pci 0000:00:12.0: reg 0x1c: [io  0xf080-0xf083]
            [    0.358214] pci 0000:00:12.0: reg 0x20: [io  0xf060-0xf07f]
            [    0.358225] pci 0000:00:12.0: reg 0x24: [mem 0x91423000-0x914237ff]
            [    0.358278] pci 0000:00:12.0: PME# supported from D3hot
            [    0.358957] pci 0000:00:13.0: [8086:5ad8] type 01 class 0x060400
            [    0.359072] pci 0000:00:13.0: PME# supported from D0 D3hot D3cold
            [    0.359807] pci 0000:00:13.1: [8086:5ad9] type 01 class 0x060400
            [    0.359917] pci 0000:00:13.1: PME# supported from D0 D3hot D3cold
            [    0.360644] pci 0000:00:13.2: [8086:5ada] type 01 class 0x060400
            [    0.360751] pci 0000:00:13.2: PME# supported from D0 D3hot D3cold
            [    0.361508] pci 0000:00:15.0: [8086:5aa8] type 00 class 0x0c0330
            [    0.361537] pci 0000:00:15.0: reg 0x10: [mem 0x91400000-0x9140ffff 64bit]
            [    0.361628] pci 0000:00:15.0: PME# supported from D3hot D3cold
            [    0.362344] pci 0000:00:16.0: [8086:5aac] type 00 class 0x118000
            [    0.362369] pci 0000:00:16.0: reg 0x10: [mem 0x91422000-0x91422fff 64bit]
            [    0.362388] pci 0000:00:16.0: reg 0x18: [mem 0x91421000-0x91421fff 64bit]
            [    0.363182] pci 0000:00:18.0: [8086:5abc] type 00 class 0x118000
            [    0.363209] pci 0000:00:18.0: reg 0x10: [mem 0x91420000-0x91420fff 64bit]
            [    0.363226] pci 0000:00:18.0: reg 0x18: [mem 0x9141f000-0x9141ffff 64bit]
            [    0.363994] pci 0000:00:19.0: [8086:5ac2] type 00 class 0x118000
            [    0.364019] pci 0000:00:19.0: reg 0x10: [mem 0x9141e000-0x9141efff 64bit]
            [    0.364035] pci 0000:00:19.0: reg 0x18: [mem 0x9141d000-0x9141dfff 64bit]
            [    0.364783] pci 0000:00:19.1: [8086:5ac4] type 00 class 0x118000
            [    0.364811] pci 0000:00:19.1: reg 0x10: [mem 0x9141c000-0x9141cfff 64bit]
            [    0.364831] pci 0000:00:19.1: reg 0x18: [mem 0x9141b000-0x9141bfff 64bit]
            [    0.365569] pci 0000:00:19.2: [8086:5ac6] type 00 class 0x118000
            [    0.365595] pci 0000:00:19.2: reg 0x10: [mem 0x9141a000-0x9141afff 64bit]
            [    0.365612] pci 0000:00:19.2: reg 0x18: [mem 0x91419000-0x91419fff 64bit]
            [    0.366373] pci 0000:00:1a.0: [8086:5ac8] type 00 class 0x0c8000
            [    0.366403] pci 0000:00:1a.0: reg 0x10: [mem 0x91418000-0x91418fff 64bit]
            [    0.366421] pci 0000:00:1a.0: reg 0x18: [mem 0x91417000-0x91417fff 64bit]
            [    0.366495] pci 0000:00:1a.0: PME# supported from D0 D3hot
            [    0.367209] pci 0000:00:1f.0: [8086:5ae8] type 00 class 0x060100
            [    0.368024] pci 0000:00:1f.1: [8086:5ad4] type 00 class 0x0c0500
            [    0.368092] pci 0000:00:1f.1: reg 0x10: [mem 0x91416000-0x914160ff 64bit]
            [    0.368173] pci 0000:00:1f.1: reg 0x20: [io  0xf040-0xf05f]
            [    0.369007] pci 0000:01:00.0: [10ec:5229] type 00 class 0xff0000
            [    0.369040] pci 0000:01:00.0: reg 0x10: [mem 0x91300000-0x91300fff]
            [    0.369141] pci 0000:01:00.0: Upstream bridge's Max Payload Size set to 128 (was 256, max 256)
            [    0.369149] pci 0000:01:00.0: Max Payload Size set to 128 (was 128, max 128)
            [    0.369245] pci 0000:01:00.0: supports D1 D2
            [    0.369248] pci 0000:01:00.0: PME# supported from D1 D2 D3hot
            [    0.369474] pci 0000:00:13.0: PCI bridge to [bus 01]
            [    0.369485] pci 0000:00:13.0:   bridge window [mem 0x91300000-0x913fffff]
            [    0.369621] pci 0000:02:00.0: [8086:24fb] type 00 class 0x028000
            [    0.369663] pci 0000:02:00.0: reg 0x10: [mem 0x91200000-0x91201fff 64bit]
            [    0.369732] pci 0000:02:00.0: Upstream bridge's Max Payload Size set to 128 (was 256, max 256)
            [    0.369742] pci 0000:02:00.0: Max Payload Size set to 128 (was 128, max 128)
            [    0.369879] pci 0000:02:00.0: PME# supported from D0 D3hot D3cold
            [    0.370127] pci 0000:00:13.1: PCI bridge to [bus 02]
            [    0.370135] pci 0000:00:13.1:   bridge window [mem 0x91200000-0x912fffff]
            [    0.370277] pci 0000:03:00.0: [10ec:8168] type 00 class 0x020000
            [    0.370310] pci 0000:03:00.0: reg 0x10: [io  0xe000-0xe0ff]
            [    0.370345] pci 0000:03:00.0: reg 0x18: [mem 0x91104000-0x91104fff 64bit]
            [    0.370367] pci 0000:03:00.0: reg 0x20: [mem 0x91100000-0x91103fff 64bit]
            [    0.370391] pci 0000:03:00.0: Upstream bridge's Max Payload Size set to 128 (was 256, max 256)
            [    0.370400] pci 0000:03:00.0: Max Payload Size set to 128 (was 128, max 128)
            [    0.370514] pci 0000:03:00.0: supports D1 D2
            [    0.370517] pci 0000:03:00.0: PME# supported from D0 D1 D2 D3hot D3cold
            [    0.370749] pci 0000:00:13.2: PCI bridge to [bus 03]
            [    0.370756] pci 0000:00:13.2:   bridge window [io  0xe000-0xefff]
            [    0.370762] pci 0000:00:13.2:   bridge window [mem 0x91100000-0x911fffff]
            [    0.372673] ACPI: PCI: Interrupt link LNKA configured for IRQ 15
            [    0.372679] ACPI: PCI: Interrupt link LNKA disabled
            [    0.372894] ACPI: PCI: Interrupt link LNKB configured for IRQ 15
            [    0.372898] ACPI: PCI: Interrupt link LNKB disabled
            [    0.373106] ACPI: PCI: Interrupt link LNKC configured for IRQ 15
            [    0.373110] ACPI: PCI: Interrupt link LNKC disabled
            [    0.373320] ACPI: PCI: Interrupt link LNKD configured for IRQ 15
            [    0.373324] ACPI: PCI: Interrupt link LNKD disabled
            [    0.373528] ACPI: PCI: Interrupt link LNKE configured for IRQ 15
            [    0.373532] ACPI: PCI: Interrupt link LNKE disabled
            [    0.373736] ACPI: PCI: Interrupt link LNKF configured for IRQ 15
            [    0.373740] ACPI: PCI: Interrupt link LNKF disabled
            [    0.373946] ACPI: PCI: Interrupt link LNKG configured for IRQ 15
            [    0.373950] ACPI: PCI: Interrupt link LNKG disabled
            [    0.374154] ACPI: PCI: Interrupt link LNKH configured for IRQ 15
            [    0.374158] ACPI: PCI: Interrupt link LNKH disabled
            [    0.376347] ACPI: EC: interrupt unblocked
            [    0.376350] ACPI: EC: event unblocked
            [    0.376375] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
            [    0.376378] ACPI: EC: GPE=0x40
            [    0.376382] ACPI: \_SB_.PCI0.SBRG.H_EC: Boot DSDT EC initialization complete
            [    0.376387] ACPI: \_SB_.PCI0.SBRG.H_EC: EC: Used to handle transactions and events
            [    0.376568] iommu: Default domain type: Translated
            [    0.376568] SCSI subsystem initialized
            [    0.376568] libata version 3.00 loaded.
            [    0.376568] pci 0000:00:02.0: vgaarb: setting as boot VGA device
            [    0.376568] pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
            [    0.376568] pci 0000:00:02.0: vgaarb: bridge control possible
            [    0.376568] vgaarb: loaded
            [    0.376568] ACPI: bus type USB registered
            [    0.376568] usbcore: registered new interface driver usbfs
            [    0.376568] usbcore: registered new interface driver hub
            [    0.376568] usbcore: registered new device driver usb
            [    0.376568] pps_core: LinuxPPS API ver. 1 registered
            [    0.376568] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
            [    0.376568] PTP clock support registered
            [    0.376568] EDAC MC: Ver: 3.0.0
            [    0.376568] Registered efivars operations
            [    0.376568] NetLabel: Initializing
            [    0.376568] NetLabel:  domain hash size = 128
            [    0.376568] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
            [    0.376568] NetLabel:  unlabeled traffic allowed by default
            [    0.376568] PCI: Using ACPI for IRQ routing
            [    0.406798] PCI: pci_cache_line_size set to 64 bytes
            [    0.406911] e820: reserve RAM buffer [mem 0x0003f000-0x0003ffff]
            [    0.406916] e820: reserve RAM buffer [mem 0x0009e000-0x0009ffff]
            [    0.406919] e820: reserve RAM buffer [mem 0x77368000-0x77ffffff]
            [    0.406922] e820: reserve RAM buffer [mem 0x79fba000-0x7bffffff]
            [    0.406925] e820: reserve RAM buffer [mem 0x7a9df000-0x7bffffff]
            [    0.406927] e820: reserve RAM buffer [mem 0x7b000000-0x7bffffff]
            [    0.406941] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
            [    0.406941] hpet0: 8 comparators, 64-bit 19.200000 MHz counter
            [    0.408821] clocksource: Switched to clocksource tsc-early
            [    0.429767] VFS: Disk quotas dquot_6.6.0
            [    0.429804] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
            [    0.430060] AppArmor: AppArmor Filesystem Enabled
            [    0.430172] pnp: PnP ACPI init
            [    0.431270] system 00:00: [io  0x0a00-0x0a1f] has been reserved
            [    0.431277] system 00:00: [io  0x0a20-0x0a2f] has been reserved
            [    0.431281] system 00:00: [io  0x0a30-0x0a3f] has been reserved
            [    0.431285] system 00:00: [io  0x0a40-0x0a4f] has been reserved
            [    0.431289] system 00:00: [io  0x0a50-0x0a5f] has been reserved
            [    0.431292] system 00:00: [io  0x0a60-0x0a6f] has been reserved
            [    0.431312] system 00:00: Plug and Play ACPI device, IDs PNP0c02 (active)
            [    0.431770] system 00:01: [io  0x0680-0x069f] has been reserved
            [    0.431777] system 00:01: [io  0x0400-0x047f] could not be reserved
            [    0.431781] system 00:01: [io  0x0500-0x05fe] has been reserved
            [    0.431785] system 00:01: [io  0x0600-0x061f] has been reserved
            [    0.431789] system 00:01: [io  0x164e-0x164f] has been reserved
            [    0.431802] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
            [    0.432759] system 00:02: [mem 0xe0000000-0xefffffff] has been reserved
            [    0.432766] system 00:02: [mem 0xfea00000-0xfeafffff] has been reserved
            [    0.432770] system 00:02: [mem 0xfed01000-0xfed01fff] has been reserved
            [    0.432774] system 00:02: [mem 0xfed03000-0xfed03fff] has been reserved
            [    0.432778] system 00:02: [mem 0xfed06000-0xfed06fff] has been reserved
            [    0.432781] system 00:02: [mem 0xfed08000-0xfed09fff] has been reserved
            [    0.432785] system 00:02: [mem 0xfed80000-0xfedbffff] has been reserved
            [    0.432789] system 00:02: [mem 0xfed1c000-0xfed1cfff] has been reserved
            [    0.432793] system 00:02: [mem 0xfee00000-0xfeefffff] could not be reserved
            [    0.432807] system 00:02: Plug and Play ACPI device, IDs PNP0c02 (active)
            [    0.433223] pnp 00:03: Plug and Play ACPI device, IDs PNP0b00 (active)
            [    0.433703] pnp: PnP ACPI: found 4 devices
            [    0.442276] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
            [    0.442422] NET: Registered protocol family 2
            [    0.442877] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
            [    0.447892] tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes, linear)
            [    0.448225] TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear)
            [    0.449062] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
            [    0.449580] TCP: Hash tables configured (established 131072 bind 65536)
            [    0.449831] MPTCP token hash table entries: 16384 (order: 6, 393216 bytes, linear)
            [    0.450004] UDP hash table entries: 8192 (order: 6, 262144 bytes, linear)
            [    0.450244] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes, linear)
            [    0.450535] NET: Registered protocol family 1
            [    0.450555] NET: Registered protocol family 44
            [    0.450586] pci 0000:00:13.0: PCI bridge to [bus 01]
            [    0.450600] pci 0000:00:13.0:   bridge window [mem 0x91300000-0x913fffff]
            [    0.450610] pci 0000:00:13.1: PCI bridge to [bus 02]
            [    0.450617] pci 0000:00:13.1:   bridge window [mem 0x91200000-0x912fffff]
            [    0.450627] pci 0000:00:13.2: PCI bridge to [bus 03]
            [    0.450632] pci 0000:00:13.2:   bridge window [io  0xe000-0xefff]
            [    0.450637] pci 0000:00:13.2:   bridge window [mem 0x91100000-0x911fffff]
            [    0.450649] pci_bus 0000:00: resource 4 [io  0x0070-0x0077]
            [    0.450653] pci_bus 0000:00: resource 5 [io  0x0000-0x006f window]
            [    0.450657] pci_bus 0000:00: resource 6 [io  0x0078-0x0cf7 window]
            [    0.450660] pci_bus 0000:00: resource 7 [io  0x0d00-0xffff window]
            [    0.450664] pci_bus 0000:00: resource 8 [mem 0x7c000001-0x7fffffff window]
            [    0.450668] pci_bus 0000:00: resource 9 [mem 0x7b800001-0x7bffffff window]
            [    0.450671] pci_bus 0000:00: resource 10 [mem 0x80000000-0xcfffffff window]
            [    0.450675] pci_bus 0000:00: resource 11 [mem 0xe0000000-0xefffffff window]
            [    0.450679] pci_bus 0000:01: resource 1 [mem 0x91300000-0x913fffff]
            [    0.450683] pci_bus 0000:02: resource 1 [mem 0x91200000-0x912fffff]
            [    0.450687] pci_bus 0000:03: resource 0 [io  0xe000-0xefff]
            [    0.450690] pci_bus 0000:03: resource 1 [mem 0x91100000-0x911fffff]
            [    0.450914] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
            [    0.451511] PCI: CLS 0 bytes, default 64
            [    0.451588] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
            [    0.451591] software IO TLB: mapped [mem 0x000000006ed83000-0x0000000072d83000] (64MB)
            [    0.451671] Trying to unpack rootfs image as initramfs...
            [    0.451696] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x159647815e3, max_idle_ns: 440795269835 ns
            [    0.451867] clocksource: Switched to clocksource tsc
            [    0.452818] Initialise system trusted keyrings
            [    0.452852] Key type blacklist registered
            [    0.452982] workingset: timestamp_bits=36 max_order=22 bucket_order=0
            [    0.455581] zbud: loaded
            [    0.456284] squashfs: version 4.0 (2009/01/31) Phillip Lougher
            [    0.456934] fuse: init (API version 7.34)
            [    0.457266] integrity: Platform Keyring initialized
            [    0.473464] Key type asymmetric registered
            [    0.473473] Asymmetric key parser 'x509' registered
            [    0.473502] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
            [    0.473693] io scheduler mq-deadline registered
            [    0.474589] pwm-lpss 0000:00:1a.0: can't derive routing for PCI INT A
            [    0.474596] pwm-lpss 0000:00:1a.0: PCI INT A: not connected
            [    0.475175] pcieport 0000:00:13.0: PME: Signaling with IRQ 122
            [    0.475591] pcieport 0000:00:13.1: PME: Signaling with IRQ 123
            [    0.476071] pcieport 0000:00:13.2: PME: Signaling with IRQ 124
            [    0.476262] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
            [    0.476607] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
            [    0.476938] ACPI: button: Power Button [PWRB]
            [    0.477021] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input1
            [    0.477067] ACPI: button: Sleep Button [SLPB]
            [    0.477138] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
            [    0.477198] ACPI: button: Power Button [PWRF]
            [    0.484553] thermal LNXTHERM:00: registered as thermal_zone0
            [    0.484563] ACPI: thermal: Thermal Zone [TZ01] (55 C)
            [    0.484987] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
            [    0.489278] Linux agpgart interface v0.103
            [    0.711820] loop: module loaded
            [    0.712510] libphy: Fixed MDIO Bus: probed
            [    0.712517] tun: Universal TUN/TAP device driver, 1.6
            [    0.712601] PPP generic driver version 2.4.2
            [    0.712748] i8042: PNP: No PS/2 controller found.
            [    0.712751] i8042: Probing ports directly.
            [    0.726984] serio: i8042 KBD port at 0x60,0x64 irq 1
            [    0.727015] serio: i8042 AUX port at 0x60,0x64 irq 12
            [    0.727319] mousedev: PS/2 mouse device common for all mice
            [    0.727681] rtc_cmos 00:03: RTC can wake from S4
            [    0.728534] rtc_cmos 00:03: registered as rtc0
            [    0.728695] rtc_cmos 00:03: setting system clock to 2022-02-28T08:13:16 UTC (1646035996)
            [    0.728739] rtc_cmos 00:03: alarms up to one month, y3k, 242 bytes nvram, hpet irqs
            [    0.728762] i2c /dev entries driver
            [    0.729037] device-mapper: uevent: version 1.0.3
            [    0.729153] device-mapper: ioctl: 4.45.0-ioctl (2021-03-22) initialised: dm-devel@redhat.com
            [    0.729203] platform eisa.0: Probing EISA bus 0
            [    0.729209] platform eisa.0: EISA: Cannot allocate resource for mainboard
            [    0.729213] platform eisa.0: Cannot allocate resource for EISA slot 1
            [    0.729216] platform eisa.0: Cannot allocate resource for EISA slot 2
            [    0.729219] platform eisa.0: Cannot allocate resource for EISA slot 3
            [    0.729221] platform eisa.0: Cannot allocate resource for EISA slot 4
            [    0.729224] platform eisa.0: Cannot allocate resource for EISA slot 5
            [    0.729227] platform eisa.0: Cannot allocate resource for EISA slot 6
            [    0.729230] platform eisa.0: Cannot allocate resource for EISA slot 7
            [    0.729233] platform eisa.0: Cannot allocate resource for EISA slot 8
            [    0.729235] platform eisa.0: EISA: Detected 0 cards
            [    0.729248] intel_pstate: Intel P-state driver initializing
            [    0.729773] ledtrig-cpu: registered to indicate activity on CPUs
            [    0.729779] EFI Variables Facility v0.08 2004-May-17
            [    0.742025] input: AT Raw Set 2 keyboard as /devices/platform/i8042/serio0/input/input3
            [    0.759392] drop_monitor: Initializing network drop monitor service
            [    0.759638] NET: Registered protocol family 10
            [    1.824439] Freeing initrd memory: 58148K
            [    1.835867] Segment Routing with IPv6
            [    1.835913] NET: Registered protocol family 17
            [    1.835955] Bridge firewalling registered
            [    1.836024] Key type dns_resolver registered
            [    1.836592] microcode: sig=0x506c9, pf=0x1, revision=0x32
            [    1.836671] microcode: Microcode Update Driver: v2.2.
            [    1.836751] resctrl: L2 allocation detected
            [    1.836758] IPI shorthand broadcast: enabled
            [    1.836774] sched_clock: Marking stable (1836022192, 712165)->(1839056669, -2322312)
            [    1.837012] registered taskstats version 1
            [    1.837031] Loading compiled-in X.509 certificates
            [    1.837336] zswap: loaded using pool lzo/zbud
            [    1.837628] Key type ._fscrypt registered
            [    1.837632] Key type .fscrypt registered
            [    1.837633] Key type fscrypt-provisioning registered
            [    1.837872] Key type trusted registered
            [    1.843563] Key type encrypted registered
            [    1.843575] AppArmor: AppArmor sha1 policy hashing enabled
            [    1.844670] integrity: Loading X.509 certificate: UEFI:db
            [    1.844745] integrity: Loaded X.509 cert 'Microsoft Corporation UEFI CA 2011: 13adbf4309bd82709c8cd54f316ed522988a1bd4'
            [    1.844748] integrity: Loading X.509 certificate: UEFI:db
            [    1.844785] integrity: Loaded X.509 cert 'Microsoft Windows Production PCA 2011: a92902398e16c49778cd90f99e4f9ae17c55af53'
            [    1.846776] Loading compiled-in module X.509 certificates
            [    1.848094] Loaded X.509 cert 'Build time autogenerated kernel key: da6277a2f83d64c41e13b2887fc2e2072c1de73b'
            [    1.848099] ima: Allocated hash algorithm: sha1
            [    1.876075] ima: No architecture policies found
            [    1.876111] evm: Initialising EVM extended attributes:
            [    1.876112] evm: security.selinux
            [    1.876114] evm: security.SMACK64
            [    1.876115] evm: security.SMACK64EXEC
            [    1.876116] evm: security.SMACK64TRANSMUTE
            [    1.876117] evm: security.SMACK64MMAP
            [    1.876118] evm: security.apparmor
            [    1.876119] evm: security.ima
            [    1.876120] evm: security.capability
            [    1.876121] evm: HMAC attrs: 0x1
            [    1.876561] PM:   Magic number: 10:95:221
            [    1.876624] pci 0000:00:19.0: hash matches
            [    1.876639] acpi device:3f: hash matches
            [    1.876673] memory memory103: hash matches
            [    1.876940] RAS: Correctable Errors collector initialized.
            [    1.878756] Freeing unused decrypted memory: 2036K
            [    1.879499] Freeing unused kernel image (initmem) memory: 2848K
            [    1.895740] Write protecting the kernel read-only data: 28672k
            [    1.896573] Freeing unused kernel image (text/rodata gap) memory: 2036K
            [    1.896687] Freeing unused kernel image (rodata/data gap) memory: 224K
            [    1.959709] x86/mm: Checked W+X mappings: passed, no W+X pages found.
            [    1.959722] Run /init as init process
            [    1.959724]   with arguments:
            [    1.959730]     /init
            [    1.959732]   with environment:
            [    1.959733]     HOME=/
            [    1.959734]     TERM=linux
            [    1.959736]     BOOT_IMAGE=/boot/vmlinuz-5.13.19-2-pve
            [    2.233772] ahci 0000:00:12.0: version 3.0
            [    2.239992] idma64 idma64.0: Found Intel integrated DMA 64-bit
            [    2.244920] ahci 0000:00:12.0: AHCI 0001.0301 32 slots 2 ports 6 Gbps 0x3 impl SATA mode
            [    2.244932] ahci 0000:00:12.0: flags: 64bit ncq sntf pm clo only pmp pio slum part deso sadm sds apst
            [    2.245119] xhci_hcd 0000:00:15.0: xHCI Host Controller
            [    2.245135] xhci_hcd 0000:00:15.0: new USB bus registered, assigned bus number 1
            [    2.245608] i801_smbus 0000:00:1f.1: can't derive routing for PCI INT A
            [    2.245616] i801_smbus 0000:00:1f.1: PCI INT A: not connected
            [    2.245642] i801_smbus 0000:00:1f.1: SPD Write Disable is set
            [    2.245662] i801_smbus 0000:00:1f.1: SMBus using polling
            [    2.245800] i2c i2c-0: 2/2 memory slots populated (from DMI)
            [    2.246392] scsi host0: ahci
            [    2.246393] xhci_hcd 0000:00:15.0: hcc params 0x200077c1 hci version 0x100 quirks 0x0000000081109810
            [    2.246664] i2c i2c-0: Successfully instantiated SPD at 0x50
            [    2.246801] scsi host1: ahci
            [    2.246889] ata1: SATA max UDMA/133 abar m2048@0x91423000 port 0x91423100 irq 125
            [    2.246895] ata2: SATA max UDMA/133 abar m2048@0x91423000 port 0x91423180 irq 125
            [    2.246971] xhci_hcd 0000:00:15.0: xHCI Host Controller
            [    2.246981] xhci_hcd 0000:00:15.0: new USB bus registered, assigned bus number 2
            [    2.246988] xhci_hcd 0000:00:15.0: Host supports USB 3.0 SuperSpeed
            [    2.247058] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.13
            [    2.247063] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
            [    2.247066] usb usb1: Product: xHCI Host Controller
            [    2.247068] usb usb1: Manufacturer: Linux 5.13.19-2-pve xhci-hcd
            [    2.247070] usb usb1: SerialNumber: 0000:00:15.0
            [    2.247892] hub 1-0:1.0: USB hub found
            [    2.247919] hub 1-0:1.0: 8 ports detected
            [    2.255598] idma64 idma64.1: Found Intel integrated DMA 64-bit
            [    2.256292] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.13
            [    2.256301] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
            [    2.256308] usb usb2: Product: xHCI Host Controller
            [    2.256310] usb usb2: Manufacturer: Linux 5.13.19-2-pve xhci-hcd
            [    2.256312] usb usb2: SerialNumber: 0000:00:15.0
            [    2.256910] idma64 idma64.2: Found Intel integrated DMA 64-bit
            [    2.257739] idma64 idma64.3: Found Intel integrated DMA 64-bit
            [    2.258400] idma64 idma64.4: Found Intel integrated DMA 64-bit
            [    2.259419] libphy: r8169: probed
            [    2.259628] hub 2-0:1.0: USB hub found
            [    2.259653] hub 2-0:1.0: 7 ports detected
            [    2.259702] r8169 0000:03:00.0 eth0: RTL8168h/8111h, 1c:69:7a:01:1c:27, XID 541, IRQ 128
            [    2.259711] r8169 0000:03:00.0 eth0: jumbo features [frames: 9194 bytes, tx checksumming: ko]
            [    2.314267] r8169 0000:03:00.0 enp3s0: renamed from eth0
            [    2.561977] ata2: SATA link down (SStatus 4 SControl 300)
            [    2.591740] usb 1-4: new high-speed USB device number 2 using xhci_hcd
            [    2.723744] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
            [    2.724935] ata1.00: ATA-11: SanDisk SDSSDH3 500G, 415000RL, max UDMA/133
            [    2.724939] ata1.00: 976773168 sectors, multi 1: LBA48 NCQ (depth 32), AA
            [    2.727117] ata1.00: configured for UDMA/133
            [    2.737184] ahci 0000:00:12.0: port does not support device sleep
            [    2.737406] scsi 0:0:0:0: Direct-Access     ATA      SanDisk SDSSDH3  00RL PQ: 0 ANSI: 5
            [    2.737817] sd 0:0:0:0: [sda] 976773168 512-byte logical blocks: (500 GB/466 GiB)
            [    2.737839] sd 0:0:0:0: [sda] Write Protect is off
            [    2.737843] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
            [    2.737872] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
            [    2.737928] sd 0:0:0:0: Attached scsi generic sg0 type 0
            [    2.740210] usb 1-4: New USB device found, idVendor=0451, idProduct=bef3, bcdDevice= 1.00
            [    2.740216] usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
            [    2.740219] usb 1-4: Product: XDS110 (03.00.00.16) Embed with CMSIS-DAP
            [    2.740221] usb 1-4: Manufacturer: Texas Instruments
            [    2.740223] usb 1-4: SerialNumber: L1100LEH
            [    2.745178] hid: raw HID events driver (C) Jiri Kosina
            [    2.746460] usbcore: registered new interface driver usbhid
            [    2.746467] usbhid: USB HID core driver
            [    2.748320] hid-generic 0003:0451:BEF3.0001: hiddev0,hidraw0: USB HID v1.11 Device [Texas Instruments XDS110 (03.00.00.16) Embed with CMSIS-DAP] on usb-0000:00:15.0-4/input5
            [    2.757716]  sda: sda1 sda2 sda3
            [    2.795813] sd 0:0:0:0: [sda] Attached SCSI disk
            [    6.430449] fbcon: Taking over console
            [    6.715730] raid6: sse2x4   gen() 112044 MB/s
            [    6.763732] raid6: sse2x4   xor() 21612 MB/s
            [    6.811732] raid6: sse2x2   gen() 115838 MB/s
            [    6.859731] raid6: sse2x2   xor() 68354 MB/s
            [    6.907729] raid6: sse2x1   gen() 100932 MB/s
            [    6.955731] raid6: sse2x1   xor() 60951 MB/s
            [    6.955733] raid6: using algorithm sse2x2 gen() 5119 MB/s
            [    6.955734] raid6: .... xor() 68354 MB/s, rmw enabled
            [    6.955736] raid6: using ssse3x2 recovery algorithm
            [    6.956951] xor: measuring software checksum speed
            [    6.957815]    prefetch64-sse  : 11480 MB/sec
            [    6.958810]    generic_sse     :  9922 MB/sec
            [    6.958812] xor: using function: prefetch64-sse (11480 MB/sec)
            [    6.984780] Btrfs loaded, crc32c=crc32c-intel, zoned=yes
            [    8.037502] EXT4-fs (dm-1): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
            [    8.204174] systemd[1]: Inserted module 'autofs4'
            [    8.286689] systemd[1]: systemd 247.3-6 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=unified)
            [    8.303826] systemd[1]: Detected architecture x86-64.
            [    8.304253] systemd[1]: Set hostname to <pve>.
            [    8.523378] systemd[1]: Queued start job for default target Graphical Interface.
            [    8.541310] systemd[1]: Created slice system-getty.slice.
            [    8.542236] systemd[1]: Created slice system-modprobe.slice.
            [    8.543044] systemd[1]: Created slice system-postfix.slice.
            [    8.543799] systemd[1]: Created slice system-systemd\x2dfsck.slice.
            [    8.544434] systemd[1]: Created slice User and Session Slice.
            [    8.544718] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
            [    8.544838] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
            [    8.545166] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
            [    8.545247] systemd[1]: Reached target ceph target allowing to start/stop all ceph-fuse@.service instances at once.
            [    8.545279] systemd[1]: Reached target ceph target allowing to start/stop all ceph*@.service instances at once.
            [    8.545312] systemd[1]: Reached target Local Encrypted Volumes.
            [    8.545401] systemd[1]: Reached target Paths.
            [    8.545467] systemd[1]: Reached target Slices.
            [    8.545662] systemd[1]: Listening on Device-mapper event daemon FIFOs.
            [    8.545874] systemd[1]: Listening on LVM2 poll daemon socket.
            [    8.552605] systemd[1]: Listening on RPCbind Server Activation Socket.
            [    8.552931] systemd[1]: Listening on Syslog Socket.
            [    8.553131] systemd[1]: Listening on fsck to fsckd communication Socket.
            [    8.553251] systemd[1]: Listening on initctl Compatibility Named Pipe.
            [    8.553533] systemd[1]: Listening on Journal Audit Socket.
            [    8.553706] systemd[1]: Listening on Journal Socket (/dev/log).
            [    8.553938] systemd[1]: Listening on Journal Socket.
            [    8.554461] systemd[1]: Listening on udev Control Socket.
            [    8.554662] systemd[1]: Listening on udev Kernel Socket.
            [    8.556368] systemd[1]: Mounting Huge Pages File System...
            [    8.558133] systemd[1]: Mounting POSIX Message Queue File System...
            [    8.560183] systemd[1]: Mounting RPC Pipe File System...
            [    8.562112] systemd[1]: Mounting Kernel Debug File System...
            [    8.564118] systemd[1]: Mounting Kernel Trace File System...
            [    8.564270] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
            [    8.566283] systemd[1]: Starting Set the console keyboard layout...
            [    8.568412] systemd[1]: Starting Create list of static device nodes for the current kernel...
            [    8.570320] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
            [    8.572198] systemd[1]: Starting Load Kernel Module configfs...
            [    8.574937] systemd[1]: Starting Load Kernel Module drm...
            [    8.577437] systemd[1]: Starting Load Kernel Module fuse...
            [    8.578874] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
            [    8.579003] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
            [    8.583354] systemd[1]: Starting Journal Service...
            [    8.589707] systemd[1]: Starting Load Kernel Modules...
            [    8.591501] systemd[1]: Starting Remount Root and Kernel File Systems...
            [    8.593595] systemd[1]: Starting Coldplug All udev Devices...
            [    8.597155] systemd[1]: Mounted Huge Pages File System.
            [    8.597409] systemd[1]: Mounted POSIX Message Queue File System.
            [    8.597596] systemd[1]: Mounted Kernel Debug File System.
            [    8.597774] systemd[1]: Mounted Kernel Trace File System.
            [    8.598367] systemd[1]: Finished Set the console keyboard layout.
            [    8.599187] systemd[1]: Finished Create list of static device nodes for the current kernel.
            [    8.600051] RPC: Registered named UNIX socket transport module.
            [    8.600058] RPC: Registered udp transport module.
            [    8.600059] RPC: Registered tcp transport module.
            [    8.600060] RPC: Registered tcp NFSv4.1 backchannel transport module.
            [    8.600336] systemd[1]: modprobe@configfs.service: Succeeded.
            [    8.600764] systemd[1]: Finished Load Kernel Module configfs.
            [    8.602266] systemd[1]: Mounted RPC Pipe File System.
            [    8.602714] systemd[1]: modprobe@fuse.service: Succeeded.
            [    8.603099] systemd[1]: Finished Load Kernel Module fuse.
            [    8.607172] systemd[1]: Mounting FUSE Control File System...
            [    8.609874] systemd[1]: Mounting Kernel Configuration File System...
            [    8.611719] systemd[1]: Mounted FUSE Control File System.
            [    8.615677] Loading iSCSI transport class v2.0-870.
            [    8.622832] systemd[1]: Mounted Kernel Configuration File System.
            [    8.624802] iscsi: registered transport (tcp)
            [    8.625228] systemd[1]: modprobe@drm.service: Succeeded.
            [    8.625606] systemd[1]: Finished Load Kernel Module drm.
            [    8.625882] EXT4-fs (dm-1): re-mounted. Opts: errors=remount-ro. Quota mode: none.
            [    8.629315] systemd[1]: Finished Remount Root and Kernel File Systems.
            [    8.630290] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
            [    8.630403] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
            [    8.632196] systemd[1]: Starting Load/Save Random Seed...
            [    8.634125] systemd[1]: Starting Create System Users...
            [    8.654909] systemd[1]: Finished Load/Save Random Seed.
            [    8.655502] systemd[1]: Condition check resulted in First Boot Complete being skipped.
            [    8.657615] systemd[1]: Finished Create System Users.
            [    8.659557] systemd[1]: Starting Create Static Device Nodes in /dev...
            [    8.664082] systemd[1]: Started Device-mapper event daemon.
            [    8.684810] iscsi: registered transport (iser)
            [    8.695336] spl: loading out-of-tree module taints kernel.
            [    8.698715] systemd[1]: Finished Create Static Device Nodes in /dev.
            [    8.701623] systemd[1]: Starting Rule-based Manager for Device Events and Files...
            [    8.709307] znvpair: module license 'CDDL' taints kernel.
            [    8.709315] Disabling lock debugging due to kernel taint
            [    8.742800] systemd[1]: Started Journal Service.
            [    8.757877] systemd-journald[521]: Received client request to flush runtime journal.
            [    8.766951] systemd-journald[521]: File /var/log/journal/549f75853edc40d885427cb68bc3018c/system.journal corrupted or uncleanly shut down, renaming and replacing.
            [    8.894644] ZFS: Loaded module v2.1.1-pve1, ZFS pool version 5000, ZFS filesystem version 5
            [    8.962236] input: PC Speaker as /devices/platform/pcspkr/input/input6
            [    8.968091] at24 0-0050: supply vcc not found, using dummy regulator
            [    8.972600] at24 0-0050: 256 byte spd EEPROM, read-only
            [    8.993697] dw-apb-uart.1: ttyS4 at MMIO 0x91420000 (irq = 4, base_baud = 115200) is a 16550A
            [    9.055898] pstore: Using crash dump compression: deflate
            [    9.055924] pstore: Registered efi as persistent store backend
            [    9.061855] cfg80211: Loading compiled-in X.509 certificates for regulatory database
            [    9.063994] RAPL PMU: API unit is 2^-32 Joules, 4 fixed counters, 655360 ms ovfl timer
            [    9.064001] RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
            [    9.064003] RAPL PMU: hw unit of domain package 2^-14 Joules
            [    9.064004] RAPL PMU: hw unit of domain dram 2^-14 Joules
            [    9.064005] RAPL PMU: hw unit of domain pp1-gpu 2^-14 Joules
            [    9.067275] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
            [    9.068802] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
            [    9.068817] cfg80211: failed to load regulatory.db
            [    9.074005] cdc_acm 1-4:1.0: ttyACM0: USB ACM device
            [    9.085990] Intel(R) Wireless WiFi driver for Linux
            [    9.086091] iwlwifi 0000:02:00.0: enabling device (0000 -> 0002)
            [    9.091887] cryptd: max_cpu_qlen set to 1000
            [    9.094204] iwlwifi 0000:02:00.0: loaded firmware version 29.198743027.0 3168-29.ucode op_mode iwlmvm
            [    9.134770] SSE version of gcm_enc/dec engaged.
            [    9.145920] iwlwifi 0000:02:00.0: Detected Intel(R) Dual Band Wireless AC 3168, REV=0x220
            [    9.152034] thermal thermal_zone1: failed to read out thermal zone (-61)
            [    9.163922] i915 0000:00:02.0: vgaarb: deactivate vga console
            [    9.163942] iwlwifi 0000:02:00.0: base HW address: 20:79:18:3d:72:96
            [    9.171406] snd_hda_intel 0000:00:0e.0: DSP detected with PCI class/subclass/prog-if info 0x040380
            [    9.182110] cdc_acm 1-4:1.3: ttyACM1: USB ACM device
            [    9.182159] usbcore: registered new interface driver cdc_acm
            [    9.182162] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
            [    9.194062] ieee80211 phy0: Selected rate control algorithm 'iwl-mvm-rs'
            [    9.206275] i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=io+mem:owns=io+mem
            [    9.211338] i915 0000:00:02.0: [drm] Finished loading DMC firmware i915/bxt_dmc_ver1_07.bin (v1.7)
            [    9.277234] [drm] Initialized i915 1.6.0 20201103 for 0000:00:02.0 on minor 0
            [    9.283818] ACPI: video: Video Device [GFX0] (multi-head: yes  rom: no  post: no)
            [    9.284376] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input7
            [    9.284635] snd_hda_intel 0000:00:0e.0: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
            [    9.289048] EDAC pnd2: b_cr_tolud_pci=080000001 ret=0
            [    9.289098] EDAC pnd2: b_cr_touud_lo_pci=080000000 ret=0
            [    9.289140] EDAC pnd2: b_cr_touud_hi_pci=000000004 ret=0
            [    9.289182] EDAC pnd2: b_cr_asym_mem_region0_mchbar=000000000 ret=0
            [    9.289224] EDAC pnd2: b_cr_asym_mem_region1_mchbar=000000000 ret=0
            [    9.289266] EDAC pnd2: b_cr_mot_out_base_mchbar=000000000 ret=0
            [    9.289308] EDAC pnd2: b_cr_mot_out_mask_mchbar=000000000 ret=0
            [    9.289389] EDAC pnd2: b_cr_slice_channel_hash=80000d9480001248 ret=0
            [    9.289432] EDAC pnd2: b_cr_asym_2way_mem_region_mchbar=000000000 ret=0
            [    9.289488] EDAC pnd2: d_cr_drp0=0e000c007 ret=0
            [    9.289530] EDAC pnd2: d_cr_drp0=000000000 ret=2
            [    9.289573] EDAC pnd2: d_cr_drp0=0e000c007 ret=0
            [    9.289614] EDAC pnd2: d_cr_drp0=000000000 ret=2
            [    9.289616] EDAC pnd2: ECC disabled on channel 0
            [    9.289617] EDAC pnd2: ECC disabled on channel 2
            [    9.289618] EDAC pnd2: Failed to register device with error -22.
            [    9.301037] i915 0000:00:02.0: [drm] Cannot find any crtc or sizes
            [    9.308714] i915 0000:00:02.0: [drm] Cannot find any crtc or sizes
            [    9.311843] Adding 8388604k swap on /dev/mapper/pve-swap.  Priority:-2 extents:1 across:8388604k SSFS
            [    9.348880] EDAC pnd2: b_cr_tolud_pci=080000001 ret=0
            [    9.348930] EDAC pnd2: b_cr_touud_lo_pci=080000000 ret=0
            [    9.348972] EDAC pnd2: b_cr_touud_hi_pci=000000004 ret=0
            [    9.349014] EDAC pnd2: b_cr_asym_mem_region0_mchbar=000000000 ret=0
            [    9.349056] EDAC pnd2: b_cr_asym_mem_region1_mchbar=000000000 ret=0
            [    9.349098] EDAC pnd2: b_cr_mot_out_base_mchbar=000000000 ret=0
            [    9.349139] EDAC pnd2: b_cr_mot_out_mask_mchbar=000000000 ret=0
            [    9.349221] EDAC pnd2: b_cr_slice_channel_hash=80000d9480001248 ret=0
            [    9.349263] EDAC pnd2: b_cr_asym_2way_mem_region_mchbar=000000000 ret=0
            [    9.349304] EDAC pnd2: d_cr_drp0=0e000c007 ret=0
            [    9.349346] EDAC pnd2: d_cr_drp0=000000000 ret=2
            [    9.349388] EDAC pnd2: d_cr_drp0=0e000c007 ret=0
            [    9.349429] EDAC pnd2: d_cr_drp0=000000000 ret=2
            [    9.349431] EDAC pnd2: ECC disabled on channel 0
            [    9.349432] EDAC pnd2: ECC disabled on channel 2
            [    9.349433] EDAC pnd2: Failed to register device with error -22.
            [    9.354380] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC283: line_outs=2 (0x1b/0x21/0x0/0x0/0x0) type:hp
            [    9.354393] snd_hda_codec_realtek hdaudioC0D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
            [    9.354396] snd_hda_codec_realtek hdaudioC0D0:    hp_outs=0 (0x0/0x0/0x0/0x0/0x0)
            [    9.354399] snd_hda_codec_realtek hdaudioC0D0:    mono: mono_out=0x0
            [    9.354401] snd_hda_codec_realtek hdaudioC0D0:    dig-out=0x1e/0x0
            [    9.354403] snd_hda_codec_realtek hdaudioC0D0:    inputs:
            [    9.354405] snd_hda_codec_realtek hdaudioC0D0:      Mic=0x19
            [    9.354407] snd_hda_codec_realtek hdaudioC0D0:      Internal Mic=0x12
            [    9.377827] intel_telemetry_core Init
            [    9.412631] EDAC pnd2: b_cr_tolud_pci=080000001 ret=0
            [    9.412681] EDAC pnd2: b_cr_touud_lo_pci=080000000 ret=0
            [    9.412724] EDAC pnd2: b_cr_touud_hi_pci=000000004 ret=0
            [    9.412766] EDAC pnd2: b_cr_asym_mem_region0_mchbar=000000000 ret=0
            [    9.412809] EDAC pnd2: b_cr_asym_mem_region1_mchbar=000000000 ret=0
            [    9.412851] EDAC pnd2: b_cr_mot_out_base_mchbar=000000000 ret=0
            [    9.412894] EDAC pnd2: b_cr_mot_out_mask_mchbar=000000000 ret=0
            [    9.412978] EDAC pnd2: b_cr_slice_channel_hash=80000d9480001248 ret=0
            [    9.413021] EDAC pnd2: b_cr_asym_2way_mem_region_mchbar=000000000 ret=0
            [    9.413063] EDAC pnd2: d_cr_drp0=0e000c007 ret=0
            [    9.413105] EDAC pnd2: d_cr_drp0=000000000 ret=2
            [    9.413147] EDAC pnd2: d_cr_drp0=0e000c007 ret=0
            [    9.413190] EDAC pnd2: d_cr_drp0=000000000 ret=2
            [    9.413193] EDAC pnd2: ECC disabled on channel 0
            [    9.413194] EDAC pnd2: ECC disabled on channel 2
            [    9.413195] EDAC pnd2: Failed to register device with error -22.
            [    9.444636] EDAC pnd2: b_cr_tolud_pci=080000001 ret=0
            [    9.444700] EDAC pnd2: b_cr_touud_lo_pci=080000000 ret=0
            [    9.444743] EDAC pnd2: b_cr_touud_hi_pci=000000004 ret=0
            [    9.444785] EDAC pnd2: b_cr_asym_mem_region0_mchbar=000000000 ret=0
            [    9.444827] EDAC pnd2: b_cr_asym_mem_region1_mchbar=000000000 ret=0
            [    9.444868] EDAC pnd2: b_cr_mot_out_base_mchbar=000000000 ret=0
            [    9.444910] EDAC pnd2: b_cr_mot_out_mask_mchbar=000000000 ret=0
            [    9.444992] EDAC pnd2: b_cr_slice_channel_hash=80000d9480001248 ret=0
            [    9.445034] EDAC pnd2: b_cr_asym_2way_mem_region_mchbar=000000000 ret=0
            [    9.445076] EDAC pnd2: d_cr_drp0=0e000c007 ret=0
            [    9.445117] EDAC pnd2: d_cr_drp0=000000000 ret=2
            [    9.445158] EDAC pnd2: d_cr_drp0=0e000c007 ret=0
            [    9.445199] EDAC pnd2: d_cr_drp0=000000000 ret=2
            [    9.445201] EDAC pnd2: ECC disabled on channel 0
            [    9.445203] EDAC pnd2: ECC disabled on channel 2
            [    9.445204] EDAC pnd2: Failed to register device with error -22.
            [    9.446808] Invalid pltconfig, ensure IPC1 device is enabled in BIOS
            [    9.456412] input: HDA Intel PCH Mic as /devices/pci0000:00/0000:00:0e.0/sound/card0/input8
            [    9.456510] input: HDA Intel PCH Headphone Front as /devices/pci0000:00/0000:00:0e.0/sound/card0/input9
            [    9.456584] input: HDA Intel PCH Front Headphone Surround as /devices/pci0000:00/0000:00:0e.0/sound/card0/input10
            [    9.456653] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:0e.0/sound/card0/input11
            [    9.456725] input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:0e.0/sound/card0/input12
            [    9.456808] input: HDA Intel PCH HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:0e.0/sound/card0/input13
            [    9.456879] input: HDA Intel PCH HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:0e.0/sound/card0/input14
            [    9.456973] input: HDA Intel PCH HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:0e.0/sound/card0/input15
            [    9.464738] iwlwifi 0000:02:00.0 wlp2s0: renamed from wlan0
            [    9.512217] Invalid pltconfig, ensure IPC1 device is enabled in BIOS
            [    9.514982] intel_rapl_common: Found RAPL domain package
            [    9.514991] intel_rapl_common: Found RAPL domain core
            [    9.514994] intel_rapl_common: Found RAPL domain uncore
            [    9.514997] intel_rapl_common: Found RAPL domain dram
            [    9.548455] Invalid pltconfig, ensure IPC1 device is enabled in BIOS
            [    9.596265] Invalid pltconfig, ensure IPC1 device is enabled in BIOS
            [    9.740230] audit: type=1400 audit(1646036005.507:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=795 comm="apparmor_parser"
            [    9.740242] audit: type=1400 audit(1646036005.507:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=795 comm="apparmor_parser"
            [    9.744282] audit: type=1400 audit(1646036005.511:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lsb_release" pid=793 comm="apparmor_parser"
            [    9.746812] audit: type=1400 audit(1646036005.511:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/lxc-start" pid=800 comm="apparmor_parser"
            [    9.752377] audit: type=1400 audit(1646036005.519:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="tcpdump" pid=796 comm="apparmor_parser"
            [    9.756142] audit: type=1400 audit(1646036005.523:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/man" pid=801 comm="apparmor_parser"
            [    9.756157] audit: type=1400 audit(1646036005.523:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_filter" pid=801 comm="apparmor_parser"
            [    9.756162] audit: type=1400 audit(1646036005.523:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_groff" pid=801 comm="apparmor_parser"
            [    9.762860] audit: type=1400 audit(1646036005.527:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lxc-container-default" pid=794 comm="apparmor_parser"
            [    9.762876] audit: type=1400 audit(1646036005.527:11): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lxc-container-default-cgns" pid=794 comm="apparmor_parser"
            [    9.814244] vmbr0: port 1(enp3s0) entered blocking state
            [    9.814254] vmbr0: port 1(enp3s0) entered disabled state
            [    9.814454] device enp3s0 entered promiscuous mode
            [    9.851790] Generic FE-GE Realtek PHY r8169-0-300:00: attached PHY driver (mii_bus:phy_addr=r8169-0-300:00, irq=MAC)
            [    9.879943] softdog: initialized. soft_noboot=0 soft_margin=60 sec soft_panic=0 (nowayout=0)
            [    9.879951] softdog:              soft_reboot_cmd=<not set> soft_active_on_boot=0
            [   10.055970] r8169 0000:03:00.0 enp3s0: Link is Down
            [   10.060417] vmbr0: port 1(enp3s0) entered blocking state
            [   10.060429] vmbr0: port 1(enp3s0) entered forwarding state
            [   10.386749] bpfilter: Loaded bpfilter_umh pid 949
            [   10.387231] Started bpfilter
            [   10.815823] vmbr0: port 1(enp3s0) entered disabled state
            [   13.137871] r8169 0000:03:00.0 enp3s0: Link is Up - 1Gbps/Full - flow control off
            [   13.137907] vmbr0: port 1(enp3s0) entered blocking state
            [   13.137913] vmbr0: port 1(enp3s0) entered forwarding state
            [   13.138015] IPv6: ADDRCONF(NETDEV_CHANGE): vmbr0: link becomes ready
            [   23.792755] EXT4-fs warning (device dm-8): ext4_multi_mount_protect:326: MMP interval 42 higher than expected, please wait.
            [   68.616597] EXT4-fs (dm-8): recovery complete
            [   68.617073] EXT4-fs (dm-8): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
            [   68.698271] kauditd_printk_skb: 7 callbacks suppressed
            [   68.698278] audit: type=1400 audit(1646036064.662:19): apparmor="STATUS" operation="profile_load" profile="/usr/bin/lxc-start" name="lxc-102_</var/lib/lxc>" pid=1348 comm="apparmor_parser"
            [   70.095651] fwbr102i0: port 1(fwln102i0) entered blocking state
            [   70.095662] fwbr102i0: port 1(fwln102i0) entered disabled state
            [   70.095807] device fwln102i0 entered promiscuous mode
            [   70.095870] fwbr102i0: port 1(fwln102i0) entered blocking state
            [   70.095874] fwbr102i0: port 1(fwln102i0) entered forwarding state
            [   70.103690] vmbr0: port 2(fwpr102p0) entered blocking state
            [   70.103701] vmbr0: port 2(fwpr102p0) entered disabled state
            [   70.103833] device fwpr102p0 entered promiscuous mode
            [   70.103896] vmbr0: port 2(fwpr102p0) entered blocking state
            [   70.103900] vmbr0: port 2(fwpr102p0) entered forwarding state
            [   70.111639] fwbr102i0: port 2(veth102i0) entered blocking state
            [   70.111651] fwbr102i0: port 2(veth102i0) entered disabled state
            [   70.111778] device veth102i0 entered promiscuous mode
            [   70.175802] eth0: renamed from vethRtUokb
            [   71.140815] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
            [   71.140873] fwbr102i0: port 2(veth102i0) entered blocking state
            [   71.140877] fwbr102i0: port 2(veth102i0) entered forwarding state
            [  109.640417] device tap500i0 entered promiscuous mode
            [  109.701320] fwbr500i0: port 1(fwln500i0) entered blocking state
            [  109.701332] fwbr500i0: port 1(fwln500i0) entered disabled state
            [  109.701460] device fwln500i0 entered promiscuous mode
            [  109.701528] fwbr500i0: port 1(fwln500i0) entered blocking state
            [  109.701532] fwbr500i0: port 1(fwln500i0) entered forwarding state
            [  109.709229] vmbr0: port 3(fwpr500p0) entered blocking state
            [  109.709240] vmbr0: port 3(fwpr500p0) entered disabled state
            [  109.709365] device fwpr500p0 entered promiscuous mode
            [  109.709412] vmbr0: port 3(fwpr500p0) entered blocking state
            [  109.709416] vmbr0: port 3(fwpr500p0) entered forwarding state
            [  109.717127] fwbr500i0: port 2(tap500i0) entered blocking state
            [  109.717139] fwbr500i0: port 2(tap500i0) entered disabled state
            [  109.717299] fwbr500i0: port 2(tap500i0) entered blocking state
            [  109.717303] fwbr500i0: port 2(tap500i0) entered forwarding state
            [  123.162907] usb 1-4: reset high-speed USB device number 2 using xhci_hcd
            [  607.546737] perf: interrupt took too long (2514 > 2500), lowering kernel.perf_event_max_sample_rate to 79500
            [  790.536688] perf: interrupt took too long (3149 > 3142), lowering kernel.perf_event_max_sample_rate to 63500
            [ 1071.991281] perf: interrupt took too long (3946 > 3936), lowering kernel.perf_event_max_sample_rate to 50500
            [ 1570.604883] perf: interrupt took too long (4935 > 4932), lowering kernel.perf_event_max_sample_rate to 40500
            [ 2963.540580] perf: interrupt took too long (6169 > 6168), lowering kernel.perf_event_max_sample_rate to 32250
            [34744.612800] device tap400i0 entered promiscuous mode
            [34744.706479] fwbr400i0: port 1(fwln400i0) entered blocking state
            [34744.706489] fwbr400i0: port 1(fwln400i0) entered disabled state
            [34744.706659] device fwln400i0 entered promiscuous mode
            [34744.706830] fwbr400i0: port 1(fwln400i0) entered blocking state
            [34744.706834] fwbr400i0: port 1(fwln400i0) entered forwarding state
            [34744.720073] vmbr0: port 4(fwpr400p0) entered blocking state
            [34744.720085] vmbr0: port 4(fwpr400p0) entered disabled state
            [34744.720273] device fwpr400p0 entered promiscuous mode
            [34744.720356] vmbr0: port 4(fwpr400p0) entered blocking state
            [34744.720361] vmbr0: port 4(fwpr400p0) entered forwarding state
            [34744.731273] fwbr400i0: port 2(tap400i0) entered blocking state
            [34744.731285] fwbr400i0: port 2(tap400i0) entered disabled state
            [34744.731541] fwbr400i0: port 2(tap400i0) entered blocking state
            [34744.731551] fwbr400i0: port 2(tap400i0) entered forwarding state
            [34872.578666] fwbr500i0: port 2(tap500i0) entered disabled state
            [34872.604468] fwbr500i0: port 1(fwln500i0) entered disabled state
            [34872.604820] vmbr0: port 3(fwpr500p0) entered disabled state
            [34872.605031] device fwln500i0 left promiscuous mode
            [34872.605038] fwbr500i0: port 1(fwln500i0) entered disabled state
            [34872.626392] device fwpr500p0 left promiscuous mode
            [34872.626402] vmbr0: port 3(fwpr500p0) entered disabled state
            [34872.950234] usb 1-4: reset high-speed USB device number 2 using xhci_hcd
            [34873.204866] cdc_acm 1-4:1.0: ttyACM0: USB ACM device
            [34873.305568] cdc_acm 1-4:1.3: ttyACM1: USB ACM device
            [34873.308368] hid-generic 0003:0451:BEF3.0002: hiddev0,hidraw0: USB HID v1.11 Device [Texas Instruments XDS110 (03.00.00.16) Embed with CMSIS-DAP] on usb-0000:00:15.0-4/input5
            [75032.045199] device tap500i0 entered promiscuous mode
            [75032.178145] fwbr500i0: port 1(fwln500i0) entered blocking state
            [75032.178156] fwbr500i0: port 1(fwln500i0) entered disabled state
            [75032.178338] device fwln500i0 entered promiscuous mode
            [75032.178470] fwbr500i0: port 1(fwln500i0) entered blocking state
            [75032.178474] fwbr500i0: port 1(fwln500i0) entered forwarding state
            [75032.191529] vmbr0: port 3(fwpr500p0) entered blocking state
            [75032.191541] vmbr0: port 3(fwpr500p0) entered disabled state
            [75032.192123] device fwpr500p0 entered promiscuous mode
            [75032.192227] vmbr0: port 3(fwpr500p0) entered blocking state
            [75032.192233] vmbr0: port 3(fwpr500p0) entered forwarding state
            [75032.205969] fwbr500i0: port 2(tap500i0) entered blocking state
            [75032.205981] fwbr500i0: port 2(tap500i0) entered disabled state
            [75032.206240] fwbr500i0: port 2(tap500i0) entered blocking state
            [75032.206248] fwbr500i0: port 2(tap500i0) entered forwarding state
            [75047.407701] usb 1-4: reset high-speed USB device number 2 using xhci_hcd
            [75286.277739] fwbr400i0: port 2(tap400i0) entered disabled state
            [75286.306125] fwbr400i0: port 1(fwln400i0) entered disabled state
            [75286.308346] vmbr0: port 4(fwpr400p0) entered disabled state
            [75286.308575] device fwln400i0 left promiscuous mode
            [75286.308583] fwbr400i0: port 1(fwln400i0) entered disabled state
            [75286.330730] device fwpr400p0 left promiscuous mode
            [75286.330739] vmbr0: port 4(fwpr400p0) entered disabled state
            [83641.568506] fwbr500i0: port 2(tap500i0) entered disabled state
            [83641.613816] fwbr500i0: port 1(fwln500i0) entered disabled state
            [83641.614098] vmbr0: port 3(fwpr500p0) entered disabled state
            [83641.614220] device fwln500i0 left promiscuous mode
            [83641.614224] fwbr500i0: port 1(fwln500i0) entered disabled state
            [83641.632097] device fwpr500p0 left promiscuous mode
            [83641.632101] vmbr0: port 3(fwpr500p0) entered disabled state
            [83641.880104] usb 1-4: reset high-speed USB device number 2 using xhci_hcd
            [83642.128896] cdc_acm 1-4:1.0: ttyACM0: USB ACM device
            [83642.229332] cdc_acm 1-4:1.3: ttyACM1: USB ACM device
            [83642.229973] hid-generic 0003:0451:BEF3.0003: hiddev0,hidraw0: USB HID v1.11 Device [Texas Instruments XDS110 (03.00.00.16) Embed with CMSIS-DAP] on usb-0000:00:15.0-4/input5
            [85846.287289] device tap500i0 entered promiscuous mode
            [85846.383731] fwbr500i0: port 1(fwln500i0) entered blocking state
            [85846.383743] fwbr500i0: port 1(fwln500i0) entered disabled state
            [85846.383865] device fwln500i0 entered promiscuous mode
            [85846.383992] fwbr500i0: port 1(fwln500i0) entered blocking state
            [85846.383999] fwbr500i0: port 1(fwln500i0) entered forwarding state
            [85846.395923] vmbr0: port 3(fwpr500p0) entered blocking state
            [85846.395935] vmbr0: port 3(fwpr500p0) entered disabled state
            [85846.396056] device fwpr500p0 entered promiscuous mode
            [85846.396105] vmbr0: port 3(fwpr500p0) entered blocking state
            [85846.396109] vmbr0: port 3(fwpr500p0) entered forwarding state
            [85846.408001] fwbr500i0: port 2(tap500i0) entered blocking state
            [85846.408012] fwbr500i0: port 2(tap500i0) entered disabled state
            [85846.408178] fwbr500i0: port 2(tap500i0) entered blocking state
            [85846.408182] fwbr500i0: port 2(tap500i0) entered forwarding state
            [85859.905932] usb 1-4: reset high-speed USB device number 2 using xhci_hcd
            [87887.041899] fwbr500i0: port 2(tap500i0) entered disabled state
            [87887.061194] fwbr500i0: port 1(fwln500i0) entered disabled state
            [87887.061431] vmbr0: port 3(fwpr500p0) entered disabled state
            [87887.061558] device fwln500i0 left promiscuous mode
            [87887.061562] fwbr500i0: port 1(fwln500i0) entered disabled state
            [87887.082319] device fwpr500p0 left promiscuous mode
            [87887.082327] vmbr0: port 3(fwpr500p0) entered disabled state
            [87887.358318] usb 1-4: reset high-speed USB device number 2 using xhci_hcd
            [87887.607458] cdc_acm 1-4:1.0: ttyACM0: USB ACM device
            [87887.707950] cdc_acm 1-4:1.3: ttyACM1: USB ACM device
            [87887.708617] hid-generic 0003:0451:BEF3.0004: hiddev0,hidraw0: USB HID v1.11 Device [Texas Instruments XDS110 (03.00.00.16) Embed with CMSIS-DAP] on usb-0000:00:15.0-4/input5
            [87890.939091] device tap500i0 entered promiscuous mode
            [87891.001149] fwbr500i0: port 1(fwln500i0) entered blocking state
            [87891.001160] fwbr500i0: port 1(fwln500i0) entered disabled state
            [87891.001301] device fwln500i0 entered promiscuous mode
            [87891.001367] fwbr500i0: port 1(fwln500i0) entered blocking state
            [87891.001371] fwbr500i0: port 1(fwln500i0) entered forwarding state
            [87891.009436] vmbr0: port 3(fwpr500p0) entered blocking state
            [87891.009448] vmbr0: port 3(fwpr500p0) entered disabled state
            [87891.009577] device fwpr500p0 entered promiscuous mode
            [87891.009625] vmbr0: port 3(fwpr500p0) entered blocking state
            [87891.009629] vmbr0: port 3(fwpr500p0) entered forwarding state
            [87891.017598] fwbr500i0: port 2(tap500i0) entered blocking state
            [87891.017610] fwbr500i0: port 2(tap500i0) entered disabled state
            [87891.017776] fwbr500i0: port 2(tap500i0) entered blocking state
            [87891.017781] fwbr500i0: port 2(tap500i0) entered forwarding state
            [87904.473924] usb 1-4: reset high-speed USB device number 2 using xhci_hcd
            • wendy2702W wendy2702
              @homecineplexx
              Kannst du das "dmesg" auch mal vom Proxmox absetzen, das hier war ja scheinbar aus der VM für iobroker, oder?
              Kannst du auch mal das posten:
              df -h
              free -m
              Und auch mal mit top oder htop beobachten wie die Auslastung ist
              homecineplexx
              @wendy2702 said in Welche SSD?:
              @homecineplexx
              df -h
              free -m
              das ist vom df -h von der VM:
              chris@ioBroker:~$ df -h
              Dateisystem    Größe Benutzt Verf. Verw% Eingehängt auf
              udev            2,9G       0  2,9G    0% /dev
              tmpfs           597M    8,3M  588M    2% /run
              /dev/sda1        26G    7,7G   17G   32% /
              tmpfs           3,0G       0  3,0G    0% /dev/shm
              tmpfs           5,0M       0  5,0M    0% /run/lock
              tmpfs           3,0G       0  3,0G    0% /sys/fs/cgroup
              tmpfs           597M       0  597M    0% /run/user/1000
              free -m von der VM:
              chris@ioBroker:~$ free -m
              Mem:           5962        2453        3073           8         434        3272
              Swap:          6140           0        6140
              htop von der VM:
              top - 20:19:28 up 10:41,  2 users,  load average: 3,78, 3,65, 3,41
              Tasks: 127 total,   5 running, 122 sleeping,   0 stopped,   0 zombie
              %Cpu(s): 67,0 us,  5,2 sy,  0,0 ni, 23,4 id,  0,0 wa,  0,0 hi,  2,2 si,  2,2 st
              MiB Mem :   5962,4 total,   3075,1 free,   2465,8 used,    421,5 buff/cache
              MiB Swap:   6141,0 total,   6141,0 free,      0,0 used.   3260,1 avail Mem
                PID USER      PR  NI    VIRT    RES    SHR S  %CPU  %MEM     TIME+ COMMAND
                464 iobroker  20   0 1166644 351112  36020 R  97,3   5,8 601:48.08 iobroker.js-con
                791 iobroker  20   0 1096576 361340  35868 R  97,3   5,9 562:06.80 io.javascript.0
                802 iobroker  20   0  902840 290188  31040 R  29,6   4,8 170:12.87 io.javascript.1
               1061 iobroker  20   0  700988 133412  31160 S  28,2   2,2 179:31.41 io.influxdb.0
                821 iobroker  20   0   10,9g 304888  37452 S  26,2   5,0 164:53.05 io.javascript.2
                989 iobroker  20   0  701124 134832  31308 R  19,9   2,2 122:16.85 io.homepilot20.
                876 iobroker  20   0  711632 114520  30924 S   3,0   1,9  32:27.23 io.mqtt.0
               1775 iobroker  20   0  954524  93104  32760 S   2,0   1,5   1:17.64 io.zigbee.0
                776 iobroker  20   0  997652 151628  36576 S   0,7   2,5  12:18.58 io.admin.0
               1146 iobroker  20   0  682116  89296  31672 S   0,7   1,5  42:40.05 io.unifi.0
                 10 root      20   0       0      0      0 I   0,3   0,0   0:44.28 rcu_sched
                865 iobroker  20   0  946004  83736  31772 S   0,3   1,4   1:33.46 io.telegram.2
               1046 iobroker  20   0  679212  82792  31272 S   0,3   1,4   1:48.92 io.fronius.0
               5288 chris     20   0   11376   3872   3196 R   0,3   0,1   0:00.64 top
                  1 root      20   0  104060  10104   7744 S   0,0   0,2   0:02.88 systemd
                  2 root      20   0       0      0      0 S   0,0   0,0   0:00.01 kthreadd
                  3 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 rcu_gp
                  4 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 rcu_par_gp
                  6 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 kworker/0:0H-kblockd
                  8 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 mm_percpu_wq
                  9 root      20   0       0      0      0 S   0,0   0,0   0:05.85 ksoftirqd/0
                 11 root      20   0       0      0      0 I   0,0   0,0   0:00.00 rcu_bh
                 12 root      rt   0       0      0      0 S   0,0   0,0   0:00.28 migration/0
                 14 root      20   0       0      0      0 S   0,0   0,0   0:00.00 cpuhp/0
                 15 root      20   0       0      0      0 S   0,0   0,0   0:00.00 cpuhp/1
                 16 root      rt   0       0      0      0 S   0,0   0,0   0:00.95 migration/1
                 17 root      20   0       0      0      0 S   0,0   0,0   0:05.55 ksoftirqd/1
                 19 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 kworker/1:0H-kblockd
                 20 root      20   0       0      0      0 S   0,0   0,0   0:00.00 cpuhp/2
                 21 root      rt   0       0      0      0 S   0,0   0,0   0:00.98 migration/2
                 22 root      20   0       0      0      0 S   0,0   0,0   0:05.89 ksoftirqd/2
                 24 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 kworker/2:0H-kblockd
                 25 root      20   0       0      0      0 S   0,0   0,0   0:00.00 cpuhp/3
                 26 root      rt   0       0      0      0 S   0,0   0,0   0:01.00 migration/3
                 27 root      20   0       0      0      0 S   0,0   0,0   0:33.19 ksoftirqd/3
                 29 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 kworker/3:0H-kblockd
                 30 root      20   0       0      0      0 S   0,0   0,0   0:00.00 kdevtmpfs
              • H homecineplexx
                @homecineplexx
                df -h
                free -m
                free -m von der VM:
                Swap:          6140           0        6140
                htop von der VM:
                wendy2702W Offline
                wendy2702W Offline
                @homecineplexx sagte in Welche SSD?:
                Das ist auf die schnelle das Einzige was mir auffällt.
                Laufen bei dir viele Scripte?
                H 1 Antwort Letzte Antwort
                  homecineplexx
                  schrieb am zuletzt editiert von homecineplexx
                  Was bedeutet dieses R?
                  Naja auf der javascript.0 Instanz hab ich meine quasi Alias-Skripte (sind um die 170 Stück) laufen, die von den originalen Devices quasi in virtuelle Devices wegklont und das sind schon einige (vielleicht kann man diese auch vereinfachen oder effektiver gestalten)
                  Wäre da der Alias-Adapter besser geeignet? ich mein die Umstellung wäre eine Monsterarbeit
                  const isWrong = 'AllOwnCreated.0.shelly.isWrongState';
                  doCreateStatesShelly(isWrong, {'name': 'isWrongState', 'role': '','type': 'boolean','read': true,'write': true,'desc': 'Manuell erzeugt','def': false}, false);
                  function doCreateStatesShelly(newObject, commonType, value) {
                      doCreateStates(newObject, null, value, commonType);
                  var preNameSpace = 'VirtualDevice.0.';
                  //generic virtual device
                  function VirtualDevice(config) {
                      //sanity check
                      if (typeof config !== 'object' || typeof config.namespace !== 'string' || typeof config.name !== 'string' || typeof config.states !== 'object') {
                          log('sanity check failed, no device created', 'warn');
                          return;
                      this.config = config;
                      this.namespace = preNameSpace + config.namespace + '.' + config.name;
                      this.name = config.name;
                      //create virtual device
                      log('creating virtual device ' + this.namespace);
                      this.createDevice(function () {
                          this.createStates(function () {
                              log('created virtual device ' + this.namespace);
                          }.bind(this));
                      }.bind(this));
                  VirtualDevice.prototype.createDevice = function (callback) {
                      log('creating object for device ' + this.namespace, 'debug');
                      //create device object
                      var obj = this.config.copy ? getObject(this.config.copy) : {common: {}, native: {}};
                      delete obj.common.custom;
                      if (typeof this.config.common === 'object') {
                          obj.common = Object.assign(obj.common, this.config.common);
                      if (typeof this.config.native === 'object') {
                          obj.native = Object.assign(obj.native, this.config.native);
                      extendObject(this.namespace, {
                          //type: "device",
                          type: "channel",
                          common: obj.common,
                          native: obj.native
                      }, function (err) {
                          if (err) {
                              log('could not create virtual device: ' + this.namespace, 'warn');
                              return;
                          log('created object for device ' + this.namespace, 'debug');
                          if (typeof this.config.onCreate === 'function') {
                              this.config.onCreate(this, callback);
                          } else {
                              callback();
                      }.bind(this));
                  VirtualDevice.prototype.createStates = function (callback) {
                      "use strict";
                      log('creating states for device ' + this.namespace, 'debug');
                      var stateIds = Object.keys(this.config.states);
                      log('creating states ' + JSON.stringify(stateIds), 'debug');
                      var countCreated = 0;
                      for (var i = 0; i < stateIds.length; i++) {
                          let stateId = stateIds[i];
                          this.normalizeState(stateId);
                          var id = this.namespace + '.' + stateId;
                          log('creating state ' + id, 'debug');
                          var obj = this.config.states[stateId].copy ? getObject(this.config.states[stateId].copy) : {
                              type: "state",
                              common: {},
                              native: {}
                          if (typeof this.config.states[stateId].common === 'object') {
                              obj.common = Object.assign(obj.common, this.config.states[stateId].common);
                          if (typeof this.config.states[stateId].native === 'object') {
                              obj.native = Object.assign(obj.native, this.config.states[stateId].native);
                         // var checkObj = getObject(id);
                      	//if (!checkObj) {
                      		setObject(id, obj, function(err, checkObj) {
                      			if (err) {
                                      log('skipping creation of state ' + id, 'debug');
                                  } else {
                                      log('created state ' + id, 'debug');
                                  if (!err && checkObj) {
                                      //setTimeout(function(){
                                          this.connectState(stateId);
                                          countCreated++;
                                          if (countCreated >= stateIds.length) {
                                              log('created ' + countCreated + ' states for device ' + this.namespace, 'debug');
                                              callback();
                                          var newId = checkObj.id;
                                          var helper = newId.substr(newId.lastIndexOf('.') + 1, newId.length);
                                          var stateValueNew = this.config.states[helper].stateValue;
                                          if (stateValueNew !== undefined) {
                                              setStateDelayed(newId, stateValueNew, true, 1000);
                                              log('set default: ' + stateValueNew + ' for ' + newId);
                                      //}.bind(this), 500);
                      		}.bind(this));
                  VirtualDevice.prototype.normalizeState = function (state) {
                      log('normalizing state ' + state, 'debug');
                      if (typeof this.config.states[state].read !== 'object') {
                          this.config.states[state].read = {};
                      if (typeof this.config.states[state].write !== 'object') {
                          this.config.states[state].write = {};
                      var readIds = Object.keys(this.config.states[state].read);
                      for (var i = 0; i < readIds.length; i++) {
                          var readId = this.config.states[state].read[readIds[i]];
                          if (typeof readId.before !== 'function') {
                              this.config.states[state].read[readIds[i]].before = function (device, value, callback) {
                                  callback();
                          if (typeof readId.after !== 'function') {
                              this.config.states[state].read[readIds[i]].after = function (device, value) {
                      var writeIds = Object.keys(this.config.states[state].write);
                      for (i = 0; i < writeIds.length; i++) {
                          var writeId = this.config.states[state].write[writeIds[i]];
                          if (typeof writeId.before !== 'function') {
                              this.config.states[state].write[writeIds[i]].before = function (device, value, callback) {
                                  callback()
                          if (typeof writeId.after !== 'function') {
                              this.config.states[state].write[writeIds[i]].after = function (device, value) {
                      log('normalized state ' + state, 'debug');
                  VirtualDevice.prototype.connectState = function (state) {
                          log('connecting state ' + state, 'debug');
                          var id = this.namespace + '.' + state;
                          //subscribe to read ids
                              if (readIds[i] === null || readIds[i] === undefined || readIds[i] === '') {
                                  continue;
                              if (getState(readIds[i]).notExist === true) { //check if state exists
                                  log('cannot connect to not existing state: ' + readIds[i], 'warn');
                                  continue;
                              var readObj = this.config.states[state].read[readIds[i]];
                              var trigger = readObj.trigger || {change: 'any'};
                              trigger.ack = true;
                              trigger.id = readIds[i];
                              //log('fuck trigger: ' + JSON.stringify(trigger), 'error');
                              //log('fuck this: ' + JSON.stringify(this), 'error');
                              this.subRead(trigger, readObj, state);
                              //log('fuck thisnew: ' + JSON.stringify(this), 'error');
                              log('connected ' + readIds[i] + ' to ' + id, 'debug');
                          //subscribe to this state and write to write ids
                          var trigger = {id: this.namespace + '.' + state, change: 'any', ack: false};
                          //original var trigger = {id: 'javascript.' + instance + '.' + this.namespace + '.' + state, change: 'any', ack: false};
                          on(trigger, function (obj) {
                              "use strict";
                              log('detected change of ' + state, 'debug');
                              for (var i = 0; i < writeIds.length; i++) {
                                  let writeObj = this.config.states[state].write[writeIds[i]];
                                  let val = this.convertValue(obj.state.val, writeObj.convert);
                                  let writeId = writeIds[i];
                                  log('executing function before for ' + writeId, 'debug');
                                  writeObj.before(this, val, function (newVal, newDelay) {
                                      if (newVal !== undefined && newVal !== null) val = newVal;
                                      var delay = writeObj.delay;
                                      if (newDelay !== undefined && newDelay !== null) delay = newDelay;
                                      log(newVal + 'writing value ' + val + ' to ' + writeId + ' with delay ' + delay, 'debug');
                                      setStateDelayed(writeId, val, false, delay || 0, true, function () {
                                          log('executing function after for ' + writeId, 'debug');
                                          writeObj.after(this, val);
                                      }.bind(this));
                                  }.bind(this));
                          }.bind(this));
                          log('connected ' + state + ' to ' + JSON.stringify(writeIds), 'debug');
                      }.bind(this), 500);
                  VirtualDevice.prototype.subRead = function (trigger, readObj, state) {
                      var func = function (obj) {
                          var val = this.convertValue(obj.state.val, readObj.convert);
                          //@todo aggregations
                          log('executing function before for ' + trigger.id, 'debug');
                          readObj.before(this, val, function (newVal, newDelay) {
                              if (newDelay !== undefined && newDelay !== null) writeObj.delay = newDelay;
                              log('reading value ' + val + ' to ' + this.namespace + '.' + state, 'debug');
                              setStateDelayed(this.namespace + '.' + state, val, true, readObj.delay || 0, true, function () {
                                  log('executing function after for ' + trigger.id, 'debug');
                                  readObj.after(this, val);
                              }.bind(this));
                          }.bind(this));
                      }.bind(this);
                      func({state: getState(trigger.id)});
                      on(trigger, func);
                  VirtualDevice.prototype.convertValue = function (val, func) {
                      if (typeof func !== 'function') {
                          return val;
                      return func(val);
                  var deviceId = 'Deckenlicht';
                  var namespace = 'Ankleide';
                  var path = preNameSpace + namespace + '.' + deviceId;
                  new VirtualDevice({
                      namespace: namespace,
                      states: {
                          'name': {
                              common: {name: 'name', role: 'text', type: 'string', desc: 'name', read: true, write: false, def: namespace + ' - ' + deviceId},
                              stateValue: namespace + ' - ' + deviceId
                          'isTelegramInfo': {
                              common: {name: 'TelegramInfo wird durch JavaScript gesetzt', role: 'state', type: 'boolean', desc: 'TelegramInfo', read: true, write: true, def: true},
                              stateValue: true
                          'isTelegramInfoSwitch': {
                              stateValue: true
                          'switch': {
                              common: {name: 'switch', role: 'switch', type: 'boolean', desc: 'switch', def: false, read: true, write: true,
                                  custom: {
                                      'influxdb.0': {
                                          'enabled': true,
                                          'changesOnly': true,
                                          'debounce': 500,
                                          'maxLength': 10,
                                          'retention': 0,
                                          'changesRelogInterval': 30,
                                          'changesMinDelta': 0,
                                          'storageType': '',
                                          'aliasId': ''
                              read: {
                                  'mqtt.0.shellies.shelly1-555EDB.relay.0': {
                                      convert: function (val) {
                                          if (val == 'on') {
                                              val = true;
                                          } else {
                                              val = false;
                                          return val;
                                      trigger: setTimeout(function(){
                                                  on({id:path + '.switch', change: 'ne'}, function (obj) {
                                                      if (getState(path + '.isTelegramInfoSwitch').val === true) {
                                                          var value = obj.state.val;
                                                          var name = getState(path + '.name').val;
                                                          _sendLogToTelegram(_findCorrectEmoji(name + ' wurde ' + (value === true ? 'eingeschaltet.' : 'ausgeschaltet.')));
                                              }, 500)
                              write: {
                                  'mqtt.0.shellies.shelly1-555EDB.relay.0.command': {
                                          if (val === true) {
                                              val ='on';
                                          } else {
                                              val = 'off';
                                          return val;
                          'online': {
                              common: {name: 'online', role: 'variable', type: 'boolean', desc: 'online', read: true, write: false, def: false,
                                  custom: {
                                      'influxdb.0': {
                                          'enabled': true,
                                          'debounce': 500,
                                          'maxLength': 10,
                                          'retention': 0,
                                          'storageType': '',
                                          'aliasId': ''
                              read: {
                                  'mqtt.0.shellies.shelly1-555EDB.online': {
                                              on({id:path + '.online', change: 'ne'}, function (obj) {
                                                  if (value === false) {
                                                      setState(isWrong, true);
                                                  if (getState(path + '.isTelegramInfo').val === true) {
                                                      _sendLogToTelegram(_findCorrectEmoji('OnlineStatus: ' + name + ' ist ' + (value === true ? 'wieder' : 'nicht') + ' erreichbar.'));
                                          }, 500)
                              write: {}
                          'command': {
                              common: {name: 'command', role: 'variable',  type: 'string', desc: 'command', read: true, write: true, def: ''},
                              read: {
                                  'mqtt.0.shellies.shelly1-555EDB.command': {},
                              write: {
                          'announce': {
                              common: {name: 'announce', role: 'variable',  type: 'string', desc: 'announce', read: true, write: false, def: ''},
                              read: {
                                  'mqtt.0.shellies.shelly1-555EDB.announce': {
                                         var jsonValue = JSON.parse(val);
                                          calculateJson(jsonValue, 'Info');
                                          return val;
                          'info': {
                              common: {name: 'info', role: 'variable',  type: 'string', desc: 'info', read: true, write: false, def: ''},
                              read: {
                                  'mqtt.0.shellies.shelly1-555EDB.info': {},
                  function calculateJson(jsonValue, subFolder) {
                      for (var key in jsonValue) {
                          if (jsonValue.hasOwnProperty(key)) {
                              try {
                                  var jsonNewValue = JSON.parse(jsonValue[key]);
                                  calculateJson(jsonNewValue)
                              } catch (e) {
                                  if (typeof jsonValue[key] == 'object') {
                                      for (var item in jsonValue[key]) {
                                          //var commonType = getCommonType(item);
                                          var commonType = null;
                                          doCreateStates(path + '.' + subFolder +'.' + item, item, jsonValue[key][item], commonType)
                                  } else {
                                      doCreateStates(path + '.' + subFolder + '.' + key, key, jsonValue[key])
                  function doCreateStates(newObject, name, value, commonType) {
                      var obj = getObject(newObject);
                      if (commonType == undefined) {
                          commonType = {'name': name, 'role': 'state', 'type': 'string', desc: name, read: true, write: false, def: ''};
                      if (commonType['type'] == 'number' || commonType['type'] == 'boolean') {
                      } else {
                          value = '' + value;
                  	if (!obj) {
                  		setObject(newObject, {
                  			type: 'state',
                  			common: commonType,
                  			native: {}
                  		}, function(err, obj) {
                  			if (!err && obj) {
                  				console.log('Object for ' + obj.id + ' created');
                                  setState(newObject, value, true);
                  	} else {
                      if (name == 'LWT') {
                          setTimeout(function() {
                              on({id:newObject, change: 'ne'}, function (obj) {
                                      _sendLogToTelegram(_findCorrectEmoji(name + ' wurde neu gestartet. Grund: ' + value));
                          }, 500)
                  • H homecineplexx
                        //sanity check
                            return;
                            }.bind(this));
                        }.bind(this));
                            //type: "device",
                            type: "channel",
                            common: obj.common,
                            native: obj.native
                        }, function (err) {
                            if (err) {
                                return;
                            } else {
                                callback();
                        }.bind(this));
                        "use strict";
                                type: "state",
                                common: {},
                                native: {}
                        	//if (!checkObj) {
                        			if (err) {
                                    } else {
                                            countCreated++;
                                                callback();
                        		}.bind(this));
                                    callback();
                                    callback()
                                    continue;
                                    continue;
                                trigger.ack = true;
                                "use strict";
                                        }.bind(this));
                                    }.bind(this));
                            }.bind(this));
                        }.bind(this), 500);
                                }.bind(this));
                            }.bind(this));
                        }.bind(this);
                        on(trigger, func);
                            return val;
                        return func(val);
                    new VirtualDevice({
                        states: {
                            'name': {
                            'isTelegramInfo': {
                                stateValue: true
                                stateValue: true
                            'switch': {
                                    custom: {
                                        'influxdb.0': {
                                            'enabled': true,
                                            'debounce': 500,
                                            'maxLength': 10,
                                            'retention': 0,
                                            'storageType': '',
                                            'aliasId': ''
                                read: {
                                            if (val == 'on') {
                                                val = true;
                                            } else {
                                                val = false;
                                            return val;
                                                }, 500)
                                write: {
                                            if (val === true) {
                                                val ='on';
                                            } else {
                                                val = 'off';
                                            return val;
                            'online': {
                                    custom: {
                                        'influxdb.0': {
                                            'enabled': true,
                                            'debounce': 500,
                                            'maxLength': 10,
                                            'retention': 0,
                                            'storageType': '',
                                            'aliasId': ''
                                read: {
                                            }, 500)
                                write: {}
                            'command': {
                                read: {
                                write: {
                            'announce': {
                                read: {
                                            return val;
                            'info': {
                                read: {
                                try {
                                } catch (e) {
                                    } else {
                        } else {
                            value = '' + value;
                    	if (!obj) {
                    			type: 'state',
                    			common: commonType,
                    			native: {}
                    			if (!err && obj) {
                    	} else {
                            }, 500)
                    wendy2702W Offline
                    wendy2702W Offline
                    Welches meinst du?
                    Denke 170 Stück können das System schon ordentlich langsam machen wenn die permanent etwas machen. Denke in der Tat der der Alias Adapter da eventuell besser geeignet ist
                      Welches meinst du?
                      homecineplexx
                      Welches meinst du?
                      dann werde ich auch wirklich versuch das umzustellen, aber gibts da vielleicht irgendetwas, das mir das viele Klicken erleichtern könnte? Ein Skript mit dem ich meine Datenpunkte verknüpfen könnte, welches ich einmalig laufen lasse?
                      • H homecineplexx
                        Welches meinst du?
                        wendy2702W Offline
                        wendy2702W Offline
                        @homecineplexx Script ist mir nicht bekannt. Da musst du mal die Suche bemühen.
