  4. Iobroker Windows Installation aktualisieren
    6.0k
35 Beiträge 6 Kommentatoren 1.7k Aufrufe 4 Beobachtet
    @ben1983 node@14 ist die empfohlene Version.
    Warum der admin nicht startet steht evtl. im log drin.
    Unter Linux so:
    iobroker logs --watch
    Ob das unter Windows auch funktioniert musst du mal ausprobieren.
    Ben1983B Offline
    Ben1983B Offline
    Ben1983
    @thomas-braun sagte in Iobroker Windows Installation aktualisieren:
    C:\Program Files\iobroker\SmartHome>iobroker logs --watch
    2022-02-28 16:26:32.675  - info: host.Server(SmartHome) instance system.adapter.info.0 started with pid 7420
    2022-02-28 16:26:39.195  - error: host.Server(SmartHome) Caught by controller[0]: TypeError: Class extends value undefined is not a constructor or null
    2022-02-28 16:26:39.196  - error: host.Server(SmartHome) Caught by controller[0]:     at Object.<anonymous> (C:\Program Files\iobroker\SmartHome\nodejs\node_modules\npm\node_modules\socks-proxy-agent\dist\agent.js:114:44)
    2022-02-28 16:26:39.196  - error: host.Server(SmartHome) Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1103:14)
    2022-02-28 16:26:39.196  - error: host.Server(SmartHome) Caught by controller[0]:     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1155:10)
    2022-02-28 16:26:39.197  - error: host.Server(SmartHome) Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:981:32)
    2022-02-28 16:26:39.197  - error: host.Server(SmartHome) Caught by controller[0]:     at Function.Module._load (node:internal/modules/cjs/loader:822:12)
    2022-02-28 16:26:39.197  - error: host.Server(SmartHome) Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1005:19)
    2022-02-28 16:26:39.197  - error: host.Server(SmartHome) Caught by controller[0]:     at require (node:internal/modules/cjs/helpers:102:18)
    2022-02-28 16:26:39.198  - error: host.Server(SmartHome) Caught by controller[0]:     at Object.<anonymous> (C:\Program Files\iobroker\SmartHome\nodejs\node_modules\npm\node_modules\socks-proxy-agent\dist\index.js:5:33)
    2022-02-28 16:26:39.198  - error: host.Server(SmartHome) Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1103:14)
    2022-02-28 16:26:39.198  - error: host.Server(SmartHome) Caught by controller[0]:     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1155:10)
    2022-02-28 16:26:39.199  - error: host.Server(SmartHome) Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:981:32)
    2022-02-28 16:26:39.199  - error: host.Server(SmartHome) Caught by controller[0]:     at Function.Module._load (node:internal/modules/cjs/loader:822:12)
    2022-02-28 16:26:39.199  - error: host.Server(SmartHome) Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1005:19)
    2022-02-28 16:26:39.199  - error: host.Server(SmartHome) Caught by controller[0]:     at require (node:internal/modules/cjs/helpers:102:18)
    2022-02-28 16:26:39.200  - error: host.Server(SmartHome) Caught by controller[0]:     at Object.<anonymous> (C:\Program Files\iobroker\SmartHome\nodejs\node_modules\npm\node_modules\make-fetch-happen\lib\agent.js:161:25)
    2022-02-28 16:26:39.200  - error: host.Server(SmartHome) Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1103:14)
    2022-02-28 16:26:39.200  - error: host.Server(SmartHome) Caught by controller[0]: TypeError: Class extends value undefined is not a constructor or null
    2022-02-28 16:26:39.200  - error: host.Server(SmartHome) Caught by controller[0]:     at Object.<anonymous> (C:\Program Files\iobroker\SmartHome\nodejs\node_modules\npm\node_modules\socks-proxy-agent\dist\agent.js:114:44)
    2022-02-28 16:26:39.201  - error: host.Server(SmartHome) Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1103:14)
    2022-02-28 16:26:39.201  - error: host.Server(SmartHome) Caught by controller[0]:     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1155:10)
    2022-02-28 16:26:39.201  - error: host.Server(SmartHome) Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:981:32)
    2022-02-28 16:26:39.201  - error: host.Server(SmartHome) Caught by controller[0]:     at Function.Module._load (node:internal/modules/cjs/loader:822:12)
    2022-02-28 16:26:39.202  - error: host.Server(SmartHome) Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1005:19)
    2022-02-28 16:26:39.202  - error: host.Server(SmartHome) Caught by controller[0]:     at require (node:internal/modules/cjs/helpers:102:18)
    2022-02-28 16:26:39.202  - error: host.Server(SmartHome) Caught by controller[0]:     at Object.<anonymous> (C:\Program Files\iobroker\SmartHome\nodejs\node_modules\npm\node_modules\socks-proxy-agent\dist\index.js:5:33)
    2022-02-28 16:26:39.202  - error: host.Server(SmartHome) Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1103:14)
    2022-02-28 16:26:39.203  - error: host.Server(SmartHome) Caught by controller[0]:     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1155:10)
    2022-02-28 16:26:39.203  - error: host.Server(SmartHome) Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:981:32)
    2022-02-28 16:26:39.203  - error: host.Server(SmartHome) Caught by controller[0]:     at Function.Module._load (node:internal/modules/cjs/loader:822:12)
    2022-02-28 16:26:39.204  - error: host.Server(SmartHome) Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1005:19)
    2022-02-28 16:26:39.204  - error: host.Server(SmartHome) Caught by controller[0]:     at require (node:internal/modules/cjs/helpers:102:18)
    2022-02-28 16:26:39.204  - error: host.Server(SmartHome) Caught by controller[0]:     at Object.<anonymous> (C:\Program Files\iobroker\SmartHome\nodejs\node_modules\npm\node_modules\make-fetch-happen\lib\agent.js:161:25)
    geht nochellen lang
    • Ben1983B Ben1983
      geht nochellen lang
      Ben1983B Offline
      Ben1983B Offline
      Ben1983
      @ben1983 auf dem rechner ist nodejs 14.7 noch installiert.
      muss das runter?
      • Ben1983B Ben1983
        muss das runter?
        @ben1983
        Your environment has been set up for using Node.js 16.14.0 (x64) and npm.
        Ob da was krumm ist kann ich für Windooze nicht sagen, hab ich keine Ahnung von.
        • Ben1983B Ben1983
          @thomas-braun Aber node.js 16.4 ist ok?
          sigi234S Online
          sigi234S Online
          @ben1983 sagte in Iobroker Windows Installation aktualisieren:
          Nein, 14........
          Startet der Host unter Services?
            @ben1983
            Ben1983B Offline
            Ben1983B Offline
            Ben1983
            @thomas-braun ich schmeis es nochmal runter.
            Wo bekomme ich denn die 14er Version her?beinode.js finde ich nur di latest?
            • Ben1983B Ben1983
              @ben1983
              https://nodejs.org/en/download/releases/
              Aber ich bin hier raus. Von dem komischen Windows hab ich keinen Plan.
                @ben1983
                Ben1983B Offline
                Ben1983B Offline
                Ben1983
                @thomas-braun Danke.
                Was ist denn für iobroker frei gegeben?
                Thomas BraunT S 2 Antworten Letzte Antwort
                • Ben1983B Ben1983
                  @ben1983
                  Der 14er-Zweig.
                  • Ben1983B Ben1983
                    habe das problem beim updaten.
                    iobroker ist irgendwie zerschossen
                    SSW-mcor
                    @ben1983 Du hast schon ein Problem mit der Installation selbst, derartige Meldungen können bei einem Update, was du in der Konsole machst gar nicht kommen.
                    Ich habe die JS v14.90.0 drauf.
                    Vielleicht hast du aber einfach ein Firewallproblem ?
                    • S SSW-mcor
                      bahnuhrB Online
                      bahnuhrB Online
                      bahnuhr
                      @ssw-mcor sagte in Iobroker Windows Installation aktualisieren:
                      JS v14.90.0
                      Ist das richtig ??
                      aktuell ist doch 14.19.0, oder ?
                      Danke.
                      • bahnuhrB bahnuhr
                        JS v14.90.0
                        Ist das richtig ??
                        SSW-mcor
                        @bahnuhr sagte in Iobroker Windows Installation aktualisieren:
                        JS v14.90.0
                        Ist das richtig ??
                        Ja, meinte ich auch 14.19.0 😊
                        • Ben1983B Ben1983
                          SSW-mcor
                          @ben1983 Du kannst ja mehrere ioB mit dem Installer installieren, mach halt mal einen ohne ioB Daten, also nen ganz leeren.
                          Vielleicht klappt das dann.
                          Ben1983B 3 Antworten Letzte Antwort
                          • S SSW-mcor
                            Ben1983B Offline
                            Ben1983B Offline
                            Ben1983
                            @ssw-mcor versuche ich gerade
                            • S SSW-mcor
                              Ben1983B Offline
                              Ben1983B Offline
                              Ben1983
                              @ssw-mcor selbst das führt dazu, dass kein admin erreichbar ist
                              nach dem upgrade self startet er nicht mehr
                              • S SSW-mcor
                                Ben1983B Offline
                                Ben1983B Offline
                                Ben1983
                                @ssw-mcor ich habe auf dem windows nodejs V14.7 installiert.
                                dieses Archiv habe ich nun auch für die neue version gezogen, oder muss das vorher komplett runter von windows?
                                ich versuche jetzt nochmal eine installation ohne den js.controller up zu daten
                                • Ben1983B Ben1983
                                  SSW-mcor
                                  Vor dem upgrade self läuft der ioB aber oder wie?
                                  Mit jeder weiteren Installation ändert sich der Port, kann also sein dass du nicht mehr :8081 am Ende hast, sondern z.B. :8091 oder :9091 oder so was.
                                  • S SSW-mcor
                                    Ben1983B Offline
                                    Ben1983B Offline
                                    Ben1983
                                    @ssw-mcor da läuft er, genau.
                                    echt seltsam. Danach kann man auch keinen iobroker stop mehr durchführen.
                                    • Ben1983B Ben1983
                                      SSW-mcor
                                      schrieb am zuletzt editiert von SSW-mcor
                                      Dann is die Konsole wohl weg.
                                      Dann einfach mal Schritt 2 der Anleitung machen, danach sollte die Konsole wieder funktionieren.
                                      Das mit dem ioB stop funktioniert natürlich nicht, den Rest einfach machen.
                                      Hier noch der JS Link... Der in der Beschreibung ist der Allgemeine.
                                      • S SSW-mcor
                                        Ben1983B Offline
                                        Ben1983B Offline
                                        Ben1983
                                        @ssw-mcor habe ich schon versucht.hat alles nichts gebracht. ich bekomme keine instanz mehr installiert.
                                        Irgendwie hat es da was komplett zerschossen.
                                        Kann kein js-controller updaten, danach geht nichts mehr.
                                        • Ben1983B Ben1983
                                          SSW-mcor
                                          @ben1983 Sorry, das ich erst jetzt Antworte, war mit nem Hilfstransport an die ukrainische Grenze beschäftigt.
                                          Hast du denn mal versucht per Installer alles zu deinstallieren und dann noch mal zu installieren?
