  3. Einsteigerfragen
  4. Installation
  5. Raspi4 4GB --> Installation --> Cannot find module ...
    6.3k
29 Beiträge 3 Kommentatoren 3.6k Aufrufe 2 Beobachtet
  • H Hape1
    naja, ich habe von der iobroker-Seite die Kommandozeile kopiert und ausgeführt:
    curl -sLf https://iobroker.net/install.sh | bash -
    Dann kam es zu Fehlermeldungen:
    e -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
    /usr/bin/nodejs
    /usr/bin/node
    /usr/bin/npm
    v14.19.0
    v14.19.0
    8.5.2
    pi
    /home/pi
    OK:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    OK:2 http://archive.raspberrypi.org/debian bullseye InRelease
    OK:3 https://download.docker.com/linux/raspbian bullseye InRelease
    OK:4 https://repos.influxdata.com/debian bullseye InRelease
    OK:5 https://deb.nodesource.com/node_14.x bullseye InRelease
    Alle Pakete sind aktuell.
    nodejs:
      Installiert:           14.19.0-deb-1nodesource1
      Installationskandidat: 14.19.0-deb-1nodesource1
      Versionstabelle:
     *** 14.19.0-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_14.x bullseye/main armhf Packages
         12.22.5~dfsg-2~11u1 500
    pi@raspberrypi4:~ $ cd /opt/iobroker
    pi@raspberrypi4:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
    npm ERR! code 24
    npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
    npm ERR! command failed
    npm ERR! command sh -c node iobroker.js setup first
    npm ERR! Could not connect to states database at 127.0.0.1:9000 (invalid protocol). Please make sure the configured IP and port points to a host running JS-Controller >= 2.0. and that the port is not occupied by other software!
    npm ERR!  Cannot read system.config: null (OK when migrating or restoring)
    npm ERR! Server Cannot start inMem-states on port 9000: Failed to lock DB file "/opt/iobroker/iobroker-data/states.jsonl"!
    npm ERR!     /home/iobroker/.npm/_logs/2022-02-27T12_21_20_675Z-debug-0.log
    pi@raspberrypi4:/opt/iobroker $ iobroker stop
    pi@raspberrypi4:/opt/iobroker $ iobroker fix
    library: loaded
    Library version=2022-02-10
    ioBroker is not installed in /opt/iobroker! Cannot fix anything...
    Es wäre mir auch egal alles auf dem System installierte wieder runterzuholen und neu zu installieren --> es ist ja noch gar nix in iobroker installiert --> wie auch, das Programm ist ja nicht über die ip:8081 erreichbar ...
    Es wäre nett, wenn ihr mir sagt, wie alles wieder komplett deinstalliert und dann neu aufgesetzt wird.
    Kann es vllt. auch damit zusammenhängen, das ja bereits auf der gleichen ip die Apps Portainer (Ports 9000 und 9443), AdGuard und Grafana mit telegraf auf dem Pi laufen ... ?
    @hape1 sagte in Raspi4 4GB --> Installation --> Cannot find module ...:
    Auf dem Port 9000 läuft auch die Datenbank, die du da natürlich nicht erreichen kannst, weil da schon der Portainer läuft.
    Warum man auf den kleinen Pi auch noch einen Docker-Container knallt erschließt sich mir allerdings auch nicht.
    H 1 Antwort Letzte Antwort
      Hape1
      also, in meinem Eingangspost steht, welche Apps auf dem Pi laufen ... Kann man den Port für die Datenbank von iobroker denn ändern?
      • H Hape1
        Hab ich zwar auch gelesen, aber nicht realisiert was eine "App Portainer" sein sollte . Vom Port stand da aber schon mal gar nichts
        Jetzt müsste ich den Thread aus den Einsteigerfragen verschieben, da so eine Konstellation nu wirklich keine Einsdeiger-Konfiguration ist.
        • H Hape1
          @hape1 Ja, geht soweit ich weiß natürlich irgendwie.
          Hab den Befehl aber nicht im Kopf.
          Weil ich neugierig bin: Was veranlasst einen auf dem Pi mit Docker herumzukutschieren?
          • H Offline
            Hape1
            Das sollte auch nicht als Vorwurf rüberkommen, ich habe auch nicht realisiert, das iobroker auf Port 9000 horcht. Also, alles gut! Bliebe also die Frage, ob man den Port der ioBroker Datenbank ändern kann.
              Hape1
              schrieb am zuletzt editiert von Hape1
              Ok, ich konnte den Port 9000 vom Portainer ausschalten. iobroker ist nun auch installiert, aber es fehlt etwas:
              Linux raspberrypi4 5.10.92-v7l+ #1514 SMP Mon Jan 17 17:38:03 GMT 2022 armv7l
              permitted by applicable law.
              Last login: Sun Feb 27 18:26:27 2022 from 192.168.1.161
              pi@raspberrypi4:~ $ iobroker start
              pi@raspberrypi4:/opt/iobroker $ cd /opt/iobroker
              pi@raspberrypi4:/opt/iobroker $ sudo iobroker stop
              pi@raspberrypi4:/opt/iobroker $ sudo iobroker update
              internal/modules/cjs/loader.js:905
                throw err;
              Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                  at Function.Module._resolveFilename (internal/modules/cjs/loader.js:902:15)
                  at Function.Module._load (internal/modules/cjs/loader.js:746:27)
                  at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:75:12)
                  at internal/main/run_main_module.js:17:47 {
                code: 'MODULE_NOT_FOUND',
                requireStack: []
              Habe nun versucht, den fehlenden js-Controller nachzuinstallieren. Es wird aber immer noch angemeckert, das der Port 9000 von einem anderen Server (was wohl der 9000er-Port von Portainer ist) verwendet wird:
               The DB port  9000 is occupied by something that is not a Redis protocol server. Please check other software running on this port or, if you use iobroker, make sure to update to js-controller 2.0 or higher!
              • H Offline
                Hape1
                Vielen Dank für Eure Hilfe --> ich habe mich entschlossen das Thema iobroker auf dem Pi erstmal zurückzustellen. Sollte ich das Thema wieder aufgreifen, melde ich mich wieder.
                • H Hape1
                  @hape1
                  Was läuft denn da eigentlich in dem Docker?
                    @hape1
                    Hape1
                    Um auf Deine Frage zu antworten: Zunächst Portainer, als umfangreiches Deployment-Tool für Container auf dem Docker, dann Grafana mit telegraf als Monitoring für den Pi und AdGuard als Nameserver um unerwünnschte Werbung zu blocken ... dat is et. 😊
                    • H Hape1
                      @hape1
                      Würde ich alles direkt auf dem Pi ausführen und mir die Zwischenebene Docker sparen.
