  4. Admin nicht erreichbar
    6.0k
18 Beiträge 3 Kommentatoren 1.5k Aufrufe 2 Beobachtet
  • T tamtaras
    @homoran said in Admin nicht erreichbar:
    was immer das ist
    Das sagt mir auch nichts - kann ich das einfach deaktivieren?
    @tamtaras
    Zuerst mal würde ich dein Betriebssystem pflegen.
    sudo apt update
    sudo apt full-upgrade
    sudo reboot
    Und dann würde ich node14 installieren, nicht node15.
      @tamtaras
      sudo apt update
      sudo reboot
      tamtaras
      @thomas-braun Bitte nicht erschlagen! 😥
      pi@raspberrypi:~ $ iobroker update
      Used repository: default
      /opt/iobroker/node_modules/tough-cookie/lib/cookie.js:865
        if (this.,"lc":1645241342031}
      SyntaxError: Unexpected token ','
          at wrapSafe (node:internal/modules/cjs/loader:999:16)
          at Module._compile (node:internal/modules/cjs/loader:1047:27)
          at Object.Module._extensions..js (node:internal/modules/cjs/loader:1112:10)
          at Module.load (node:internal/modules/cjs/loader:948:32)
          at Function.Module._load (node:internal/modules/cjs/loader:789:14)
          at Module.require (node:internal/modules/cjs/loader:972:19)
          at require (node:internal/modules/cjs/helpers:88:18)
          at Object.<anonymous> (/opt/iobroker/node_modules/request/lib/cookies.js:3:13)
          at Module._compile (node:internal/modules/cjs/loader:1083:30)
      pi@raspberrypi:~ $ sudo apt update
      Get:1 http://archive.raspberrypi.org/debian buster InRelease [32.6 kB]
      Get:2 http://raspbian.raspberrypi.org/raspbian buster InRelease [15.0 kB]
      Hit:3 https://deb.nodesource.com/node_15.x buster InRelease
      E: Repository 'http://archive.raspberrypi.org/debian buster InRelease' changed its 'Suite' value from 'testing' to 'oldstable'
      N: This must be accepted explicitly before updates for this repository can be applied. See apt-secure(8) manpage for details.
      Do you want to accept these changes and continue updating from this repository? [y/N] Y
      Get:4 http://archive.raspberrypi.org/debian buster/main armhf Packages [393 kB]
      E: Repository 'http://raspbian.raspberrypi.org/raspbian buster InRelease' changed its 'Suite' value from 'stable' to 'oldstable'
      Do you want to accept these changes and continue updating from this repository? [y/N] y
      Get:5 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages [13.0 MB]
      Get:6 http://raspbian.raspberrypi.org/raspbian buster/contrib armhf Packages [58.8 kB]
      Get:7 http://raspbian.raspberrypi.org/raspbian buster/non-free armhf Packages [104 kB]
      Fetched 13.6 MB in 26s (524 kB/s)
      Reading package lists... Done
      Building dependency tree
      131 packages can be upgraded. Run 'apt list --upgradable' to see them.
      pi@raspberrypi:~ $ sudo apt full-upgrade
      Calculating upgrade... Done
      The following packages will be upgraded:
        alsa-utils apt apt-utils avahi-daemon base-files bind9-host bluez bluez-firmware ca-certificates curl debconf debconf-i18n debconf-utils device-tree-compiler
        distro-info-data dphys-swapfile file firmware-atheros firmware-brcm80211 firmware-libertas firmware-misc-nonfree firmware-realtek groff-base iproute2
        iputils-ping isc-dhcp-client isc-dhcp-common klibc-utils libapt-inst2.0 libapt-pkg5.0 libasound2 libasound2-data libavahi-client-dev libavahi-client3
        libavahi-common-data libavahi-common-dev libavahi-common3 libavahi-compat-libdnssd-dev libavahi-compat-libdnssd1 libavahi-core7 libbind9-161 libbsd0 libc-bin
        libc-dev-bin libc-l10n libc6 libc6-dbg libc6-dev libcurl3-gnutls libcurl4 libdns-export1104 libdns1104 libexpat1 libexpat1-dev libgcrypt20 libgnutls30
        libgssapi-krb5-2 libhogweed4 libicu63 libisc-export1100 libisc1100 libisccc161 libisccfg163 libjpeg62-turbo libk5crypto3 libklibc libkrb5-3 libkrb5support0
        libldap-2.4-2 libldap-common liblwres161 liblz4-1 libmagic-mgc libmagic1 libnettle6 libnftnl11 libntfs-3g883 libp11-kit0 libpam-systemd libpolkit-agent-1-0
        libpolkit-backend-1-0 libpolkit-gobject-1-0 libpython3.7 libpython3.7-minimal libpython3.7-stdlib libraspberrypi-bin libraspberrypi-dev libraspberrypi-doc
        libraspberrypi0 libsqlite3-0 libssl1.1 libsystemd0 libudev-dev libudev1 libx11-6 libx11-data libxml2 libzstd1 linux-libc-dev locales multiarch-support ntfs-3g
        openssh-client openssh-server openssh-sftp-server openssl pi-bluetooth policykit-1 psmisc python-apt-common python-rpi.gpio python3-apt python3-debconf python3.7
        python3.7-minimal raspberrypi-bootloader raspberrypi-kernel raspberrypi-net-mods raspberrypi-sys-mods raspi-config rpi-eeprom rpi-update rpi.gpio-common ssh sudo
        systemd systemd-sysv tzdata udev unzip wpasupplicant
      131 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
      Need to get 203 MB of archives.
      After this operation, 18.7 MB of additional disk space will be used.
      Do you want to continue? [Y/n] Y
      Err:1 http://archive.raspberrypi.org/debian buster/main armhf libc6-dbg armhf 2.28-10+rpt2+rpi1
        Could not open file /var/cache/apt/archives/partial/libc6-dbg_2.28-10+rpt2+rpi1_armhf.deb - open (30: Read-only file system) [IP: 2a00:1098:88:26::1:1 80]
      Err:2 http://archive.raspberrypi.org/debian buster/main armhf libc6-dev armhf 2.28-10+rpt2+rpi1
        Could not open file /var/cache/apt/archives/partial/libc6-dev_2.28-10+rpt2+rpi1_armhf.deb - open (30: Read-only file system) [IP: 2a00:1098:80:56::3:1 80]
      Err:4 http://archive.raspberrypi.org/debian buster/main armhf libc-dev-bin armhf 2.28-10+rpt2+rpi1
        Could not open file /var/cache/apt/archives/partial/libc-dev-bin_2.28-10+rpt2+rpi1_armhf.deb - open (30: Read-only file system) [IP: 2a00:1098:80:56::2:1 80]
      Err:3 http://mirror.de.leaseweb.net/raspbian/raspbian buster/main armhf base-files armhf 10.3+rpi1+deb10u11
        Could not open file /var/cache/apt/archives/partial/base-files_10.3+rpi1+deb10u11_armhf.deb - open (30: Read-only file system) [IP: 2a00:c98:2030:a034::21 80]
      Err:6 http://archive.raspberrypi.org/debian buster/main armhf linux-libc-dev armhf 1:1.20211201~buster-1
        Could not open file /var/cache/apt/archives/partial/linux-libc-dev_1%3a1.20211201~buster-1_armhf.deb - open (30: Read-only file system) [IP: 2a00:1098:84:1e0::2 80]
      Err:7 http://archive.raspberrypi.org/debian buster/main armhf libc6 armhf 2.28-10+rpt2+rpi1
        Could not open file /var/cache/apt/archives/partial/libc6_2.28-10+rpt2+rpi1_armhf.deb - open (30: Read-only file system) [IP: 2a00:1098:80:56::1:1 80]
      Err:5 http://mirror1.hs-esslingen.de/pub/Mirrors/archive.raspbian.org/raspbian buster/main armhf liblz4-1 armhf 1.8.3-1+deb10u1
        Could not open file /var/cache/apt/archives/partial/liblz4-1_1.8.3-1+deb10u1_armhf.deb - open (30: Read-only file system) [IP: 2001:7c0:700::10 80]
      Err:9 http://archive.raspberrypi.org/debian buster/main armhf libc-bin armhf 2.28-10+rpt2+rpi1
        Could not open file /var/cache/apt/archives/partial/libc-bin_2.28-10+rpt2+rpi1_armhf.deb - open (30: Read-only file system) [IP: 2a00:1098:82:47::1:1 80]
      Err:10 http://archive.raspberrypi.org/debian buster/main armhf bluez armhf 5.50-1.2~deb10u2+rpt1
        Could not open file /var/cache/apt/archives/partial/bluez_5.50-1.2~deb10u2+rpt1_armhf.deb - open (30: Read-only file system) [IP: 2a00:1098:82:47::2:1 80]
      Err:11 http://archive.raspberrypi.org/debian buster/main armhf libasound2 armhf 1.1.8-1+rpt2
        Could not open file /var/cache/apt/archives/partial/libasound2_1.1.8-1+rpt2_armhf.deb - open (30: Read-only file system) [IP: 2a00:1098:82:47::1 80]
      Err:12 http://mirror1.hs-esslingen.de/pub/Mirrors/archive.raspbian.org/raspbian buster/main armhf libpam-systemd armhf 241-7~deb10u8+rpi1
        Could not open file /var/cache/apt/archives/partial/libpam-systemd_241-7~deb10u8+rpi1_armhf.deb - open (30: Read-only file system) [IP: 129.143.116.10 80]
      Err:13 http://archive.raspberrypi.org/debian buster/main armhf libasound2-data all 1.1.8-1+rpt2
        Could not open file /var/cache/apt/archives/partial/libasound2-data_1.1.8-1+rpt2_all.deb - open (30: Read-only file system) [IP: 2a00:1098:84:1e0::1 80]
      Err:14 http://archive.raspberrypi.org/debian buster/main armhf openssh-sftp-server armhf 1:7.9p1-10+deb10u2+rpt1
        Could not open file /var/cache/apt/archives/partial/openssh-sftp-server_1%3a7.9p1-10+deb10u2+rpt1_armhf.deb - open (30: Read-only file system) [IP: 2a00:1098:84:1e0::3 80]
      Err:16 http://archive.raspberrypi.org/debian buster/main armhf openssh-server armhf 1:7.9p1-10+deb10u2+rpt1
        Could not open file /var/cache/apt/archives/partial/openssh-server_1%3a7.9p1-10+deb10u2+rpt1_armhf.deb - open (30: Read-only file system) [IP: 2a00:1098:88:26::1 80]
      Err:15 http://mirror.de.leaseweb.net/raspbian/raspbian buster/main armhf libudev-dev armhf 241-7~deb10u8+rpi1
        Could not open file /var/cache/apt/archives/partial/libudev-dev_241-7~deb10u8+rpi1_armhf.deb - open (30: Read-only file system) [IP: 37.58.58.140 80]
      Err:17 http://archive.raspberrypi.org/debian buster/main armhf openssh-client armhf 1:7.9p1-10+deb10u2+rpt1
        Could not open file /var/cache/apt/archives/partial/openssh-client_1%3a7.9p1-10+deb10u2+rpt1_armhf.deb - open (30: Read-only file system) [IP: 2a00:1098:88:26::2:1 80]
      Err:8 http://ftp.gwdg.de/pub/linux/debian/raspbian/raspbian buster/main armhf systemd-sysv armhf 241-7~deb10u8+rpi1
        Could not open file /var/cache/apt/archives/partial/systemd-sysv_241-7~deb10u8+rpi1_armhf.deb - open (30: Read-only file system) [IP: 2001:638:60f:110::1:2 80]
      Err:19 http://archive.raspberrypi.org/debian buster/main armhf ssh all 1:7.9p1-10+deb10u2+rpt1
        Could not open file /var/cache/apt/archives/partial/ssh_1%3a7.9p1-10+deb10u2+rpt1_all.deb - open (30: Read-only file system) [IP: 46.235.230.122 80]
      Err:18 http://mirror.de.leaseweb.net/raspbian/raspbian buster/main armhf libsystemd0 armhf 241-7~deb10u8+rpi1
        Could not open file /var/cache/apt/archives/partial/libsystemd0_241-7~deb10u8+rpi1_armhf.deb - open (30: Read-only file system) [IP: 2a00:c98:2030:a034::21 80]
      Err:20 http://archive.raspberrypi.org/debian buster/main armhf libc-l10n all 2.28-10+rpt2+rpi1
        Could not open file /var/cache/apt/archives/partial/libc-l10n_2.28-10+rpt2+rpi1_all.deb - open (30: Read-only file system) [IP: 93.93.135.117 80]
      Err:21 http://archive.raspberrypi.org/debian buster/main armhf locales all 2.28-10+rpt2+rpi1
        Could not open file /var/cache/apt/archives/partial/locales_2.28-10+rpt2+rpi1_all.deb - open (30: Read-only file system) [IP: 93.93.130.212 80]
      Err:23 http://archive.raspberrypi.org/debian buster/main armhf alsa-utils armhf 1.1.8-2+rpt1
        Could not open file /var/cache/apt/archives/partial/alsa-utils_1.1.8-2+rpt1_armhf.deb - open (30: Read-only file system) [IP: 93.93.135.118 80]
      Err:24 http://archive.raspberrypi.org/debian buster/main armhf bluez-firmware all 1.2-4+rpt8
        Could not open file /var/cache/apt/archives/partial/bluez-firmware_1.2-4+rpt8_all.deb - open (30: Read-only file system) [IP: 176.126.240.84 80]
      Err:22 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf systemd armhf 241-7~deb10u8+rpi1
        Could not open file /var/cache/apt/archives/partial/systemd_241-7~deb10u8+rpi1_armhf.deb - open (30: Read-only file system) [IP: 2a00:8a60:e012:a00::21 80]
      Err:26 http://archive.raspberrypi.org/debian buster/main armhf dphys-swapfile all 20100506-5+rpt2
        Could not open file /var/cache/apt/archives/partial/dphys-swapfile_20100506-5+rpt2_all.deb - open (30: Read-only file system) [IP: 46.235.231.111 80]
      Err:25 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf udev armhf 241-7~deb10u8+rpi1
        Could not open file /var/cache/apt/archives/partial/udev_241-7~deb10u8+rpi1_armhf.deb - open (30: Read-only file system) [IP: 137.226.34.46 80]
      Err:28 http://archive.raspberrypi.org/debian buster/main armhf firmware-atheros all 1:20190114-2+rpt4
        Could not open file /var/cache/apt/archives/partial/firmware-atheros_1%3a20190114-2+rpt4_all.deb - open (30: Read-only file system) [IP: 46.235.231.145 80]
      Err:27 http://mirror1.hs-esslingen.de/pub/Mirrors/archive.raspbian.org/raspbian buster/main armhf libudev1 armhf 241-7~deb10u8+rpi1
        Could not open file /var/cache/apt/archives/partial/libudev1_241-7~deb10u8+rpi1_armhf.deb - open (30: Read-only file system) [IP: 2001:7c0:700::10 80]
      Err:29 http://archive.raspberrypi.org/debian buster/main armhf firmware-brcm80211 all 1:20190114-2+rpt4
        Could not open file /var/cache/apt/archives/partial/firmware-brcm80211_1%3a20190114-2+rpt4_all.deb - open (30: Read-only file system) [IP: 176.126.240.86 80]
      Err:31 http://archive.raspberrypi.org/debian buster/main armhf firmware-libertas all 1:20190114-2+rpt4
        Could not open file /var/cache/apt/archives/partial/firmware-libertas_1%3a20190114-2+rpt4_all.deb - open (30: Read-only file system) [IP: 46.235.231.151 80]
      Err:32 http://archive.raspberrypi.org/debian buster/main armhf firmware-misc-nonfree all 1:20190114-2+rpt4
        Could not open file /var/cache/apt/archives/partial/firmware-misc-nonfree_1%3a20190114-2+rpt4_all.deb - open (30: Read-only file system) [IP: 46.235.227.39 80]
      Err:30 http://mirror.netcologne.de/raspbian/raspbian buster/main armhf libnettle6 armhf 3.4.1-1+deb10u1
        Could not open file /var/cache/apt/archives/partial/libnettle6_3.4.1-1+deb10u1_armhf.deb - open (30: Read-only file system) [IP: 2001:4dd0:1234:1::deb 80]
      Err:34 http://archive.raspberrypi.org/debian buster/main armhf firmware-realtek all 1:20190114-2+rpt4
        Could not open file /var/cache/apt/archives/partial/firmware-realtek_1%3a20190114-2+rpt4_all.deb - open (30: Read-only file system) [IP: 176.126.240.167 80]
      Err:33 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libhogweed4 armhf 3.4.1-1+deb10u1
        Could not open file /var/cache/apt/archives/partial/libhogweed4_3.4.1-1+deb10u1_armhf.deb - open (30: Read-only file system) [IP: 2a00:8a60:e012:a00::21 80]
      Err:35 http://archive.raspberrypi.org/debian buster/main armhf libnftnl11 armhf 1.1.7-1~bpo10+1~0
        Could not open file /var/cache/apt/archives/partial/libnftnl11_1.1.7-1~bpo10+1~0_armhf.deb - open (30: Read-only file system) [IP: 93.93.135.141 80]
      Err:37 http://archive.raspberrypi.org/debian buster/main armhf policykit-1 armhf 0.105-25+rpt1+deb10u1
        Could not open file /var/cache/apt/archives/partial/policykit-1_0.105-25+rpt1+deb10u1_armhf.deb - open (30: Read-only file system) [IP: 2a00:1098:88:26::1:1 80]
      Err:36 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libp11-kit0 armhf 0.23.15-2+deb10u1
        Could not open file /var/cache/apt/archives/partial/libp11-kit0_0.23.15-2+deb10u1_armhf.deb - open (30: Read-only file system) [IP: 137.226.34.46 80]
      Err:38 http://archive.raspberrypi.org/debian buster/main armhf libpolkit-agent-1-0 armhf 0.105-25+rpt1+deb10u1
        Could not open file /var/cache/apt/archives/partial/libpolkit-agent-1-0_0.105-25+rpt1+deb10u1_armhf.deb - open (30: Read-only file system) [IP: 2a00:1098:80:56::3:1 80]
      Err:39 http://mirror1.hs-esslingen.de/pub/Mirrors/archive.raspbian.org/raspbian buster/main armhf libgnutls30 armhf 3.6.7-4+deb10u7
        Could not open file /var/cache/apt/archives/partial/libgnutls30_3.6.7-4+deb10u7_armhf.deb - open (30: Read-only file system) [IP: 129.143.116.10 80]
      Err:40 http://archive.raspberrypi.org/debian buster/main armhf libpolkit-backend-1-0 armhf 0.105-25+rpt1+deb10u1
        Could not open file /var/cache/apt/archives/partial/libpolkit-backend-1-0_0.105-25+rpt1+deb10u1_armhf.deb - open (30: Read-only file system) [IP: 2a00:1098:80:56::2:1 80]
      Err:41 http://archive.raspberrypi.org/debian buster/main armhf libpolkit-gobject-1-0 armhf 0.105-25+rpt1+deb10u1
        Could not open file /var/cache/apt/archives/partial/libpolkit-gobject-1-0_0.105-25+rpt1+deb10u1_armhf.deb - open (30: Read-only file system) [IP: 2a00:1098:84:1e0::2 80]
      Err:43 http://archive.raspberrypi.org/debian buster/main armhf libraspberrypi-doc armhf 1:1.20211201~buster-1
        Could not open file /var/cache/apt/archives/partial/libraspberrypi-doc_1%3a1.20211201~buster-1_armhf.deb - open (30: Read-only file system) [IP: 2a00:1098:80:56::1:1 80]
      Err:44 http://archive.raspberrypi.org/debian buster/main armhf libraspberrypi-dev armhf 1:1.20211201~buster-1
        Could not open file /var/cache/apt/archives/partial/libraspberrypi-dev_1%3a1.20211201~buster-1_armhf.deb - open (30: Read-only file system) [IP: 2a00:1098:82:47::1:1 80]
      Err:46 http://archive.raspberrypi.org/debian buster/main armhf raspberrypi-kernel armhf 1:1.20211201~buster-1
        Could not open file /var/cache/apt/archives/partial/raspberrypi-kernel_1%3a1.20211201~buster-1_armhf.deb - open (30: Read-only file system) [IP: 2a00:1098:82:47::2:1 80]
      Err:45 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libapt-pkg5.0 armhf 1.8.2.3
        Could not open file /var/cache/apt/archives/partial/libapt-pkg5.0_1.8.2.3_armhf.deb - open (30: Read-only file system) [IP: 2a00:8a60:e012:a00::21 80]
      Err:42 http://mirror.netzwerge.de/raspbian/raspbian buster/main armhf libzstd1 armhf 1.3.8+dfsg-3+rpi1+deb10u2
        Could not open file /var/cache/apt/archives/partial/libzstd1_1.3.8+dfsg-3+rpi1+deb10u2_armhf.deb - open (30: Read-only file system) [IP: 2a01:55e0::a1f 80]
      Err:47 http://archive.raspberrypi.org/debian buster/main armhf libraspberrypi-bin armhf 1:1.20211201~buster-1
        Could not open file /var/cache/apt/archives/partial/libraspberrypi-bin_1%3a1.20211201~buster-1_armhf.deb - open (30: Read-only file system) [IP: 2a00:1098:82:47::1 80]
      Err:49 http://archive.raspberrypi.org/debian buster/main armhf libraspberrypi0 armhf 1:1.20211201~buster-1
        Could not open file /var/cache/apt/archives/partial/libraspberrypi0_1%3a1.20211201~buster-1_armhf.deb - open (30: Read-only file system) [IP: 2a00:1098:84:1e0::1 80]
      Err:50 http://archive.raspberrypi.org/debian buster/main armhf raspberrypi-bootloader armhf 1:1.20211201~buster-1
        Could not open file /var/cache/apt/archives/partial/raspberrypi-bootloader_1%3a1.20211201~buster-1_armhf.deb - open (30: Read-only file system) [IP: 2a00:1098:84:1e0::3 80]
      Err:51 http://archive.raspberrypi.org/debian buster/main armhf multiarch-support armhf 2.28-10+rpt2+rpi1
        Could not open file /var/cache/apt/archives/partial/multiarch-support_2.28-10+rpt2+rpi1_armhf.deb - open (30: Read-only file system) [IP: 2a00:1098:88:26::1 80]
      Err:48 http://ftp.agdsn.de/pub/mirrors/raspbian/raspbian buster/main armhf libapt-inst2.0 armhf 1.8.2.3
        Could not open file /var/cache/apt/archives/partial/libapt-inst2.0_1.8.2.3_armhf.deb - open (30: Read-only file system) [IP: 141.30.235.39 80]
      Err:53 http://archive.raspberrypi.org/debian buster/main armhf raspberrypi-sys-mods armhf 20211005
        Could not open file /var/cache/apt/archives/partial/raspberrypi-sys-mods_20211005_armhf.deb - open (30: Read-only file system) [IP: 2a00:1098:88:26::2:1 80]
      Err:52 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf apt armhf 1.8.2.3
        Could not open file /var/cache/apt/archives/partial/apt_1.8.2.3_armhf.deb - open (30: Read-only file system) [IP: 137.226.34.46 80]
      Err:54 http://archive.raspberrypi.org/debian buster/main armhf pi-bluetooth all 0.1.18
        Could not open file /var/cache/apt/archives/partial/pi-bluetooth_0.1.18_all.deb - open (30: Read-only file system) [IP: 46.235.230.122 80]
      Err:56 http://archive.raspberrypi.org/debian buster/main armhf python-rpi.gpio armhf 0.7.0-0.1~bpo10+4
        Could not open file /var/cache/apt/archives/partial/python-rpi.gpio_0.7.0-0.1~bpo10+4_armhf.deb - open (30: Read-only file system) [IP: 93.93.135.117 80]
      Err:55 http://mirror.de.leaseweb.net/raspbian/raspbian buster/main armhf apt-utils armhf 1.8.2.3
        Could not open file /var/cache/apt/archives/partial/apt-utils_1.8.2.3_armhf.deb - open (30: Read-only file system) [IP: 37.58.58.140 80]
      Err:57 http://archive.raspberrypi.org/debian buster/main armhf rpi.gpio-common armhf 0.7.0-0.1~bpo10+4
        Could not open file /var/cache/apt/archives/partial/rpi.gpio-common_0.7.0-0.1~bpo10+4_armhf.deb - open (30: Read-only file system) [IP: 93.93.130.212 80]
      Err:59 http://archive.raspberrypi.org/debian buster/main armhf raspberrypi-net-mods all 1.3.2
        Could not open file /var/cache/apt/archives/partial/raspberrypi-net-mods_1.3.2_all.deb - open (30: Read-only file system) [IP: 93.93.135.118 80]
      Err:58 http://mirror.de.leaseweb.net/raspbian/raspbian buster/main armhf debconf-i18n all 1.5.71+deb10u1
        Could not open file /var/cache/apt/archives/partial/debconf-i18n_1.5.71+deb10u1_all.deb - open (30: Read-only file system) [IP: 2a00:c98:2030:a034::21 80]
      Err:60 http://archive.raspberrypi.org/debian buster/main armhf raspi-config all 20210212
        Could not open file /var/cache/apt/archives/partial/raspi-config_20210212_all.deb - open (30: Read-only file system) [IP: 176.126.240.84 80]
      Err:61 http://archive.raspberrypi.org/debian buster/main armhf rpi-eeprom armhf 13.9-1~buster
        Could not open file /var/cache/apt/archives/partial/rpi-eeprom_13.9-1~buster_armhf.deb - open (30: Read-only file system) [IP: 46.235.231.111 80]
      Err:62 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf python3-debconf all 1.5.71+deb10u1
        Could not open file /var/cache/apt/archives/partial/python3-debconf_1.5.71+deb10u1_all.deb - open (30: Read-only file system) [IP: 2a00:8a60:e012:a00::21 80]
      Err:63 http://archive.raspberrypi.org/debian buster/main armhf rpi-update all 20210618
        Could not open file /var/cache/apt/archives/partial/rpi-update_20210618_all.deb - open (30: Read-only file system) [IP: 46.235.231.145 80]
      Err:64 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf debconf-utils all 1.5.71+deb10u1
        Could not open file /var/cache/apt/archives/partial/debconf-utils_1.5.71+deb10u1_all.deb - open (30: Read-only file system) [IP: 137.226.34.46 80]
      Err:65 http://ftp.gwdg.de/pub/linux/debian/raspbian/raspbian buster/main armhf debconf all 1.5.71+deb10u1
        Could not open file /var/cache/apt/archives/partial/debconf_1.5.71+deb10u1_all.deb - open (30: Read-only file system) [IP: 134.76.12.6 80]
      Err:66 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libgcrypt20 armhf 1.8.4-5+deb10u1
        Could not open file /var/cache/apt/archives/partial/libgcrypt20_1.8.4-5+deb10u1_armhf.deb - open (30: Read-only file system) [IP: 2a00:8a60:e012:a00::21 80]
      Err:67 http://ftp.gwdg.de/pub/linux/debian/raspbian/raspbian buster/main armhf ntfs-3g armhf 1:2017.3.23AR.3-3+deb10u1
        Could not open file /var/cache/apt/archives/partial/ntfs-3g_1%3a2017.3.23AR.3-3+deb10u1_armhf.deb - open (30: Read-only file system) [IP: 2001:638:60f:110::1:2 80]
      Err:68 http://mirror.de.leaseweb.net/raspbian/raspbian buster/main armhf libntfs-3g883 armhf 1:2017.3.23AR.3-3+deb10u1
        Could not open file /var/cache/apt/archives/partial/libntfs-3g883_1%3a2017.3.23AR.3-3+deb10u1_armhf.deb - open (30: Read-only file system) [IP: 37.58.58.140 80]
      Err:69 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libexpat1-dev armhf 2.2.6-2+deb10u2
        Could not open file /var/cache/apt/archives/partial/libexpat1-dev_2.2.6-2+deb10u2_armhf.deb - open (30: Read-only file system) [IP: 137.226.34.46 80]
      Err:70 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libexpat1 armhf 2.2.6-2+deb10u2
        Could not open file /var/cache/apt/archives/partial/libexpat1_2.2.6-2+deb10u2_armhf.deb - open (30: Read-only file system) [IP: 2a00:8a60:e012:a00::21 80]
      Err:71 http://mirror.de.leaseweb.net/raspbian/raspbian buster/main armhf libpython3.7 armhf 3.7.3-2+deb10u3
        Could not open file /var/cache/apt/archives/partial/libpython3.7_3.7.3-2+deb10u3_armhf.deb - open (30: Read-only file system) [IP: 2a00:c98:2030:a034::21 80]
      Err:72 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libssl1.1 armhf 1.1.1d-0+deb10u7
        Could not open file /var/cache/apt/archives/partial/libssl1.1_1.1.1d-0+deb10u7_armhf.deb - open (30: Read-only file system) [IP: 137.226.34.46 80]
      Err:73 http://mirror.de.leaseweb.net/raspbian/raspbian buster/main armhf python3.7 armhf 3.7.3-2+deb10u3
        Could not open file /var/cache/apt/archives/partial/python3.7_3.7.3-2+deb10u3_armhf.deb - open (30: Read-only file system) [IP: 37.58.58.140 80]
      Err:74 http://mirror.de.leaseweb.net/raspbian/raspbian buster/main armhf libpython3.7-stdlib armhf 3.7.3-2+deb10u3
        Could not open file /var/cache/apt/archives/partial/libpython3.7-stdlib_3.7.3-2+deb10u3_armhf.deb - open (30: Read-only file system) [IP: 2a00:c98:2030:a034::21 80]
      Err:75 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf python3.7-minimal armhf 3.7.3-2+deb10u3
        Could not open file /var/cache/apt/archives/partial/python3.7-minimal_3.7.3-2+deb10u3_armhf.deb - open (30: Read-only file system) [IP: 2a00:8a60:e012:a00::21 80]
      Err:76 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libpython3.7-minimal armhf 3.7.3-2+deb10u3
        Could not open file /var/cache/apt/archives/partial/libpython3.7-minimal_3.7.3-2+deb10u3_armhf.deb - open (30: Read-only file system) [IP: 137.226.34.46 80]
      Err:77 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libsqlite3-0 armhf 3.27.2-3+deb10u1
        Could not open file /var/cache/apt/archives/partial/libsqlite3-0_3.27.2-3+deb10u1_armhf.deb - open (30: Read-only file system) [IP: 2a00:8a60:e012:a00::21 80]
      Err:78 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libgssapi-krb5-2 armhf 1.17-3+deb10u3
        Could not open file /var/cache/apt/archives/partial/libgssapi-krb5-2_1.17-3+deb10u3_armhf.deb - open (30: Read-only file system) [IP: 137.226.34.46 80]
      Err:79 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libkrb5-3 armhf 1.17-3+deb10u3
        Could not open file /var/cache/apt/archives/partial/libkrb5-3_1.17-3+deb10u3_armhf.deb - open (30: Read-only file system) [IP: 2a00:8a60:e012:a00::21 80]
      Err:80 http://mirror1.hs-esslingen.de/pub/Mirrors/archive.raspbian.org/raspbian buster/main armhf libkrb5support0 armhf 1.17-3+deb10u3
        Could not open file /var/cache/apt/archives/partial/libkrb5support0_1.17-3+deb10u3_armhf.deb - open (30: Read-only file system) [IP: 2001:7c0:700::10 80]
      Err:81 http://mirror1.hs-esslingen.de/pub/Mirrors/archive.raspbian.org/raspbian buster/main armhf libk5crypto3 armhf 1.17-3+deb10u3
        Could not open file /var/cache/apt/archives/partial/libk5crypto3_1.17-3+deb10u3_armhf.deb - open (30: Read-only file system) [IP: 129.143.116.10 80]
      Err:82 http://mirror1.hs-esslingen.de/pub/Mirrors/archive.raspbian.org/raspbian buster/main armhf libldap-common all 2.4.47+dfsg-3+rpi1+deb10u6
        Could not open file /var/cache/apt/archives/partial/libldap-common_2.4.47+dfsg-3+rpi1+deb10u6_all.deb - open (30: Read-only file system) [IP: 2001:7c0:700::10 80]
      Err:83 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libldap-2.4-2 armhf 2.4.47+dfsg-3+rpi1+deb10u6
        Could not open file /var/cache/apt/archives/partial/libldap-2.4-2_2.4.47+dfsg-3+rpi1+deb10u6_armhf.deb - open (30: Read-only file system) [IP: 137.226.34.46 80]
      Err:84 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf tzdata all 2021a-0+deb10u3
        Could not open file /var/cache/apt/archives/partial/tzdata_2021a-0+deb10u3_all.deb - open (30: Read-only file system) [IP: 2a00:8a60:e012:a00::21 80]
      Err:85 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf groff-base armhf 1.22.4-3+deb10u1
        Could not open file /var/cache/apt/archives/partial/groff-base_1.22.4-3+deb10u1_armhf.deb - open (30: Read-only file system) [IP: 137.226.34.46 80]
      Err:86 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf iproute2 armhf 4.20.0-2+deb10u1
        Could not open file /var/cache/apt/archives/partial/iproute2_4.20.0-2+deb10u1_armhf.deb - open (30: Read-only file system) [IP: 2a00:8a60:e012:a00::21 80]
      Err:87 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf iputils-ping armhf 3:20180629-2+deb10u2
        Could not open file /var/cache/apt/archives/partial/iputils-ping_3%3a20180629-2+deb10u2_armhf.deb - open (30: Read-only file system) [IP: 137.226.34.46 80]
      Err:88 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libisc-export1100 armhf 1:9.11.5.P4+dfsg-5.1+deb10u6
        Could not open file /var/cache/apt/archives/partial/libisc-export1100_1%3a9.11.5.P4+dfsg-5.1+deb10u6_armhf.deb - open (30: Read-only file system) [IP: 2a00:8a60:e012:a00::21 80]
      Err:89 http://mirror.netcologne.de/raspbian/raspbian buster/main armhf libdns-export1104 armhf 1:9.11.5.P4+dfsg-5.1+deb10u6
        Could not open file /var/cache/apt/archives/partial/libdns-export1104_1%3a9.11.5.P4+dfsg-5.1+deb10u6_armhf.deb - open (30: Read-only file system) [IP: 194.8.197.22 80]
      Err:90 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf isc-dhcp-client armhf 4.4.1-2+deb10u1
        Could not open file /var/cache/apt/archives/partial/isc-dhcp-client_4.4.1-2+deb10u1_armhf.deb - open (30: Read-only file system) [IP: 137.226.34.46 80]
      Err:91 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf isc-dhcp-common armhf 4.4.1-2+deb10u1
        Could not open file /var/cache/apt/archives/partial/isc-dhcp-common_4.4.1-2+deb10u1_armhf.deb - open (30: Read-only file system) [IP: 2a00:8a60:e012:a00::21 80]
      Err:92 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libicu63 armhf 63.1-6+deb10u2
        Could not open file /var/cache/apt/archives/partial/libicu63_63.1-6+deb10u2_armhf.deb - open (30: Read-only file system) [IP: 137.226.34.46 80]
      Err:93 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libxml2 armhf 2.9.4+dfsg1-7+deb10u2
        Could not open file /var/cache/apt/archives/partial/libxml2_2.9.4+dfsg1-7+deb10u2_armhf.deb - open (30: Read-only file system) [IP: 2a00:8a60:e012:a00::21 80]
      Err:94 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf bind9-host armhf 1:9.11.5.P4+dfsg-5.1+deb10u6
        Could not open file /var/cache/apt/archives/partial/bind9-host_1%3a9.11.5.P4+dfsg-5.1+deb10u6_armhf.deb - open (30: Read-only file system) [IP: 137.226.34.46 80]
      Err:95 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libbind9-161 armhf 1:9.11.5.P4+dfsg-5.1+deb10u6
        Could not open file /var/cache/apt/archives/partial/libbind9-161_1%3a9.11.5.P4+dfsg-5.1+deb10u6_armhf.deb - open (30: Read-only file system) [IP: 2a00:8a60:e012:a00::21 80]
      Err:96 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libisccfg163 armhf 1:9.11.5.P4+dfsg-5.1+deb10u6
        Could not open file /var/cache/apt/archives/partial/libisccfg163_1%3a9.11.5.P4+dfsg-5.1+deb10u6_armhf.deb - open (30: Read-only file system) [IP: 137.226.34.46 80]
      Err:97 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libisccc161 armhf 1:9.11.5.P4+dfsg-5.1+deb10u6
        Could not open file /var/cache/apt/archives/partial/libisccc161_1%3a9.11.5.P4+dfsg-5.1+deb10u6_armhf.deb - open (30: Read-only file system) [IP: 2a00:8a60:e012:a00::21 80]
      Err:98 http://mirror.de.leaseweb.net/raspbian/raspbian buster/main armhf libdns1104 armhf 1:9.11.5.P4+dfsg-5.1+deb10u6
        Could not open file /var/cache/apt/archives/partial/libdns1104_1%3a9.11.5.P4+dfsg-5.1+deb10u6_armhf.deb - open (30: Read-only file system) [IP: 37.58.58.140 80]
      Err:99 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libisc1100 armhf 1:9.11.5.P4+dfsg-5.1+deb10u6
        Could not open file /var/cache/apt/archives/partial/libisc1100_1%3a9.11.5.P4+dfsg-5.1+deb10u6_armhf.deb - open (30: Read-only file system) [IP: 137.226.34.46 80]
      Err:100 http://mirror1.hs-esslingen.de/pub/Mirrors/archive.raspbian.org/raspbian buster/main armhf liblwres161 armhf 1:9.11.5.P4+dfsg-5.1+deb10u6
        Could not open file /var/cache/apt/archives/partial/liblwres161_1%3a9.11.5.P4+dfsg-5.1+deb10u6_armhf.deb - open (30: Read-only file system) [IP: 129.143.116.10 80]
      Err:101 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf file armhf 1:5.35-4+deb10u2
        Could not open file /var/cache/apt/archives/partial/file_1%3a5.35-4+deb10u2_armhf.deb - open (30: Read-only file system) [IP: 2a00:8a60:e012:a00::21 80]
      Err:102 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libmagic1 armhf 1:5.35-4+deb10u2
        Could not open file /var/cache/apt/archives/partial/libmagic1_1%3a5.35-4+deb10u2_armhf.deb - open (30: Read-only file system) [IP: 137.226.34.46 80]
      Err:103 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libmagic-mgc armhf 1:5.35-4+deb10u2
        Could not open file /var/cache/apt/archives/partial/libmagic-mgc_1%3a5.35-4+deb10u2_armhf.deb - open (30: Read-only file system) [IP: 2a00:8a60:e012:a00::21 80]
      Err:104 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libavahi-common-dev armhf 0.7-4+deb10u1
        Could not open file /var/cache/apt/archives/partial/libavahi-common-dev_0.7-4+deb10u1_armhf.deb - open (30: Read-only file system) [IP: 137.226.34.46 80]
      Err:105 http://mirror.de.leaseweb.net/raspbian/raspbian buster/main armhf libavahi-common-data armhf 0.7-4+deb10u1
        Could not open file /var/cache/apt/archives/partial/libavahi-common-data_0.7-4+deb10u1_armhf.deb - open (30: Read-only file system) [IP: 2a00:c98:2030:a034::21 80]
      Err:106 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libavahi-common3 armhf 0.7-4+deb10u1
        Could not open file /var/cache/apt/archives/partial/libavahi-common3_0.7-4+deb10u1_armhf.deb - open (30: Read-only file system) [IP: 2a00:8a60:e012:a00::21 80]
      Err:107 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libavahi-core7 armhf 0.7-4+deb10u1
        Could not open file /var/cache/apt/archives/partial/libavahi-core7_0.7-4+deb10u1_armhf.deb - open (30: Read-only file system) [IP: 137.226.34.46 80]
      Err:108 http://mirror1.hs-esslingen.de/pub/Mirrors/archive.raspbian.org/raspbian buster/main armhf avahi-daemon armhf 0.7-4+deb10u1
        Could not open file /var/cache/apt/archives/partial/avahi-daemon_0.7-4+deb10u1_armhf.deb - open (30: Read-only file system) [IP: 2001:7c0:700::10 80]
      Err:109 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf openssl armhf 1.1.1d-0+deb10u7
        Could not open file /var/cache/apt/archives/partial/openssl_1.1.1d-0+deb10u7_armhf.deb - open (30: Read-only file system) [IP: 2a00:8a60:e012:a00::21 80]
      Err:110 http://mirror1.hs-esslingen.de/pub/Mirrors/archive.raspbian.org/raspbian buster/main armhf ca-certificates all 20200601~deb10u2
        Could not open file /var/cache/apt/archives/partial/ca-certificates_20200601~deb10u2_all.deb - open (30: Read-only file system) [IP: 129.143.116.10 80]
      Err:111 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf curl armhf 7.64.0-4+deb10u2
        Could not open file /var/cache/apt/archives/partial/curl_7.64.0-4+deb10u2_armhf.deb - open (30: Read-only file system) [IP: 137.226.34.46 80]
      Err:112 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libcurl4 armhf 7.64.0-4+deb10u2
        Could not open file /var/cache/apt/archives/partial/libcurl4_7.64.0-4+deb10u2_armhf.deb - open (30: Read-only file system) [IP: 2a00:8a60:e012:a00::21 80]
      Err:113 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf device-tree-compiler armhf 1.4.7-4
        Could not open file /var/cache/apt/archives/partial/device-tree-compiler_1.4.7-4_armhf.deb - open (30: Read-only file system) [IP: 137.226.34.46 80]
      Err:114 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf distro-info-data all 0.41+deb10u4
        Could not open file /var/cache/apt/archives/partial/distro-info-data_0.41+deb10u4_all.deb - open (30: Read-only file system) [IP: 2a00:8a60:e012:a00::21 80]
      Err:115 http://ftp.gwdg.de/pub/linux/debian/raspbian/raspbian buster/main armhf klibc-utils armhf 2.0.6-1+rpi1+deb10u1
        Could not open file /var/cache/apt/archives/partial/klibc-utils_2.0.6-1+rpi1+deb10u1_armhf.deb - open (30: Read-only file system) [IP: 134.76.12.6 80]
      Err:116 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libklibc armhf 2.0.6-1+rpi1+deb10u1
        Could not open file /var/cache/apt/archives/partial/libklibc_2.0.6-1+rpi1+deb10u1_armhf.deb - open (30: Read-only file system) [IP: 137.226.34.46 80]
      Err:117 http://mirror1.hs-esslingen.de/pub/Mirrors/archive.raspbian.org/raspbian buster/main armhf libavahi-client-dev armhf 0.7-4+deb10u1
        Could not open file /var/cache/apt/archives/partial/libavahi-client-dev_0.7-4+deb10u1_armhf.deb - open (30: Read-only file system) [IP: 2001:7c0:700::10 80]
      Err:118 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libavahi-client3 armhf 0.7-4+deb10u1
        Could not open file /var/cache/apt/archives/partial/libavahi-client3_0.7-4+deb10u1_armhf.deb - open (30: Read-only file system) [IP: 2a00:8a60:e012:a00::21 80]
      Err:119 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libavahi-compat-libdnssd-dev armhf 0.7-4+deb10u1
        Could not open file /var/cache/apt/archives/partial/libavahi-compat-libdnssd-dev_0.7-4+deb10u1_armhf.deb - open (30: Read-only file system) [IP: 137.226.34.46 80]
      Err:120 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libavahi-compat-libdnssd1 armhf 0.7-4+deb10u1
        Could not open file /var/cache/apt/archives/partial/libavahi-compat-libdnssd1_0.7-4+deb10u1_armhf.deb - open (30: Read-only file system) [IP: 2a00:8a60:e012:a00::21 80]
      Err:121 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libbsd0 armhf 0.9.1-2+deb10u1
        Could not open file /var/cache/apt/archives/partial/libbsd0_0.9.1-2+deb10u1_armhf.deb - open (30: Read-only file system) [IP: 137.226.34.46 80]
      Err:122 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libcurl3-gnutls armhf 7.64.0-4+deb10u2
        Could not open file /var/cache/apt/archives/partial/libcurl3-gnutls_7.64.0-4+deb10u2_armhf.deb - open (30: Read-only file system) [IP: 2a00:8a60:e012:a00::21 80]
      Err:123 http://mirror.de.leaseweb.net/raspbian/raspbian buster/main armhf libjpeg62-turbo armhf 1:1.5.2-2+deb10u1
        Could not open file /var/cache/apt/archives/partial/libjpeg62-turbo_1%3a1.5.2-2+deb10u1_armhf.deb - open (30: Read-only file system) [IP: 37.58.58.140 80]
      Err:124 http://mirror1.hs-esslingen.de/pub/Mirrors/archive.raspbian.org/raspbian buster/main armhf libx11-data all 2:1.6.7-1+deb10u2
        Could not open file /var/cache/apt/archives/partial/libx11-data_2%3a1.6.7-1+deb10u2_all.deb - open (30: Read-only file system) [IP: 129.143.116.10 80]
      Err:125 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libx11-6 armhf 2:1.6.7-1+deb10u2
        Could not open file /var/cache/apt/archives/partial/libx11-6_2%3a1.6.7-1+deb10u2_armhf.deb - open (30: Read-only file system) [IP: 137.226.34.46 80]
      Err:126 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf psmisc armhf 23.2-1+deb10u1
        Could not open file /var/cache/apt/archives/partial/psmisc_23.2-1+deb10u1_armhf.deb - open (30: Read-only file system) [IP: 2a00:8a60:e012:a00::21 80]
      Err:127 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf python-apt-common all 1.8.4.3
        Could not open file /var/cache/apt/archives/partial/python-apt-common_1.8.4.3_all.deb - open (30: Read-only file system) [IP: 137.226.34.46 80]
      Err:128 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf python3-apt armhf 1.8.4.3
        Could not open file /var/cache/apt/archives/partial/python3-apt_1.8.4.3_armhf.deb - open (30: Read-only file system) [IP: 2a00:8a60:e012:a00::21 80]
      Err:129 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf sudo armhf 1.8.27-1+deb10u3
        Could not open file /var/cache/apt/archives/partial/sudo_1.8.27-1+deb10u3_armhf.deb - open (30: Read-only file system) [IP: 137.226.34.46 80]
      Err:130 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf unzip armhf 6.0-23+deb10u2
        Could not open file /var/cache/apt/archives/partial/unzip_6.0-23+deb10u2_armhf.deb - open (30: Read-only file system) [IP: 2a00:8a60:e012:a00::21 80]
      Err:131 http://mirror.de.leaseweb.net/raspbian/raspbian buster/main armhf wpasupplicant armhf 2:2.7+git20190128+0c1e29f-6+deb10u3
        Could not open file /var/cache/apt/archives/partial/wpasupplicant_2%3a2.7+git20190128+0c1e29f-6+deb10u3_armhf.deb - open (30: Read-only file system) [IP: 2a00:c98:2030:a034::21 80]
      W: Problem unlinking the file /var/cache/apt/archives/partial/.apt-acquire-privs-test.MRUIcY - IsAccessibleBySandboxUser (30: Read-only file system)
      W: Problem unlinking the file /var/cache/apt/archives/partial/.apt-acquire-privs-test.KiHLN2 - IsAccessibleBySandboxUser (30: Read-only file system)
      W: Problem unlinking the file /var/cache/apt/archives/partial/.apt-acquire-privs-test.EFY4o7 - IsAccessibleBySandboxUser (30: Read-only file system)
      W: Problem unlinking the file /var/cache/apt/archives/partial/.apt-acquire-privs-test.MTHy0b - IsAccessibleBySandboxUser (30: Read-only file system)
      musste kuerzen sonst Post zu lang
      W: Problem unlinking the file /var/cache/apt/archives/partial/libx11-data_2%3a1.6.7-1+deb10u2_all.deb - PrepareFiles (30: Read-only file system)
      W: Problem unlinking the file /var/cache/apt/archives/partial/libx11-6_2%3a1.6.7-1+deb10u2_armhf.deb - PrepareFiles (30: Read-only file system)
      W: Problem unlinking the file /var/cache/apt/archives/partial/psmisc_23.2-1+deb10u1_armhf.deb - PrepareFiles (30: Read-only file system)
      W: Problem unlinking the file /var/cache/apt/archives/partial/python-apt-common_1.8.4.3_all.deb - PrepareFiles (30: Read-only file system)
      W: Problem unlinking the file /var/cache/apt/archives/partial/python3-apt_1.8.4.3_armhf.deb - PrepareFiles (30: Read-only file system)
      W: Problem unlinking the file /var/cache/apt/archives/partial/sudo_1.8.27-1+deb10u3_armhf.deb - PrepareFiles (30: Read-only file system)
      W: Problem unlinking the file /var/cache/apt/archives/partial/unzip_6.0-23+deb10u2_armhf.deb - PrepareFiles (30: Read-only file system)
      W: Problem unlinking the file /var/cache/apt/archives/partial/wpasupplicant_2%3a2.7+git20190128+0c1e29f-6+deb10u3_armhf.deb - PrepareFiles (30: Read-only file system)
      E: Failed to fetch http://mirror.de.leaseweb.net/raspbian/raspbian/pool/main/b/base-files/base-files_10.3+rpi1+deb10u11_armhf.deb  Could not open file /var/cache/apt/archives/partial/base-files_10.3+rpi1+deb10u11_armhf.deb - open (30: Read-only file system) [IP: 2a00:c98:2030:a034::21 80]
      E: Failed to fetch http://archive.raspberrypi.org/debian/pool/main/g/glibc/libc6-dbg_2.28-10+rpt2+rpi1_armhf.deb  Could not open file /var/cache/apt/archives/partial/libc6-dbg_2.28-10+rpt2+rpi1_armhf.deb - open (30: Read-only file system) [IP: 2a00:1098:88:26::1:1 80]
      E: Failed to fetch http://archive.raspberrypi.org/debian/pool/main/g/glibc/libc6-dev_2.28-10+rpt2+rpi1_armhf.deb  Could not open file /var/cache/apt/archives/partial/libc6-dev_2.28-10+rpt2+rpi1_armhf.deb - open (30: Read-only file system) [IP: 2a00:1098:80:56::3:1 80]
      E: Failed to fetch http://archive.raspberrypi.org/debian/pool/main/g/glibc/libc-dev-bin_2.28-10+rpt2+rpi1_armhf.deb  Could not open file /var/cache/apt/archives/partial/libc-dev-bin_2.28-10+rpt2+rpi1_armhf.deb - open (30: Read-only file system) [IP: 2a00:1098:80:56::2:1 80]
      E: Failed to fetch http://archive.raspberrypi.org/debian/pool/main/r/raspberrypi-firmware/linux-libc-dev_1.20211201~buster-1_armhf.deb  Could not open file /var/cache/apt/archives/partial/linux-libc-dev_1%3a1.20211201~buster-1_armhf.deb - open (30: Read-only file system) [IP: 2a00:1098:84:1e0::2 80]
      E: Failed to fetch http://archive.raspberrypi.org/debian/pool/main/g/glibc/libc6_2.28-10+rpt2+rpi1_armhf.deb  Could not open file /var/cache/apt/archives/partial/libc6_2.28-10+rpt2+rpi1_armhf.deb - open (30: Read-only file system) [IP: 2a00:1098:80:56::1:1 80]
      E: Failed to fetch http://archive.raspberrypi.org/debian/pool/main/g/glibc/libc-bin_2.28-10+rpt2+rpi1_armhf.deb  Could not open file /var/cache/apt/archives/partial/libc-bin_2.28-10+rpt2+rpi1_armhf.deb - open (30: Read-only file system) [IP: 2a00:1098:82:47::1:1 80]
      E: Failed to fetch http://mirror1.hs-esslingen.de/pub/Mirrors/archive.raspbian.org/raspbian/pool/main/l/lz4/liblz4-1_1.8.3-1+deb10u1_armhf.deb  Could not open file /var/cache/apt/archives/partial/liblz4-1_1.8.3-1+deb10u1_armhf.deb - open (30: Read-only file system) [IP: 2001:7c0:700::10 80]
      E: Failed to fetch http://ftp.gwdg.de/pub/linux/debian/raspbian/raspbian/pool/main/s/systemd/systemd-sysv_241-7~deb10u8+rpi1_armhf.deb  Could not open file /var/cache/apt/archives/partial/systemd-sysv_241-7~deb10u8+rpi1_armhf.deb - open (30: Read-only file system) [IP: 2001:638:60f:110::1:2 80]
      E: Failed to fetch http://archive.raspberrypi.org/debian/pool/main/o/openssh/openssh-sftp-server_7.9p1-10+deb10u2+rpt1_armhf.deb  Could not open file /var/cache/apt/archives/partial/openssh-sftp-server_1%3a7.9p1-10+deb10u2+rpt1_armhf.deb - open (30: Read-only file system) [IP: 2a00:1098:84:1e0::3 80]
      E: Failed to fetch http://ftp.halifax.rwth-aachen.de/raspbian/raspbian/pool/main/k/krb5/libgssapi-krb5-2_1.17-3+deb10u3_armhf.deb  Could not open file /var/cache/apt/archives/partial/libgssapi-krb5-2_1.17-3+deb10u3_armhf.deb - open (30: Read-only file system) [IP: 137.226.34.46 80]
      E: Failed to fetch http://ftp.halifax.rwth-aachen.de/raspbian/raspbian/pool/main/k/krb5/libkrb5-3_1.17-3+deb10u3_armhf.deb  Could not open file /var/cache/apt/archives/partial/libkrb5-3_1.17-3+deb10u3_armhf.deb - open (30: Read-only file system) [IP: 2a00:8a60:e012:a00::21 80]
      E: Failed to fetch http://mirror1.hs-esslingen.de/pub/Mirrors/archive.raspbian.org/raspbian/pool/main/k/krb5/libkrb5support0_1.17-3+deb10u3_armhf.deb  Could not open file /var/cache/apt/archives/partial/libkrb5support0_1.17-3+deb10u3_armhf.deb - open (30: Read-only file system) [IP: 2001:7c0:700::10 80]
      E: Failed to fetch http://mirror1.hs-esslingen.de/pub/Mirrors/archive.raspbian.org/raspbian/pool/main/k/krb5/libk5crypto3_1.17-3+deb10u3_armhf.deb  Could not open file /var/cache/apt/archives/partial/libk5crypto3_1.17-3+deb10u3_armhf.deb - open (30: Read-only file system) [IP: 129.143.116.10 80]
      E: Failed to fetch http://archive.raspberrypi.org/debian/pool/main/o/openssh/openssh-server_7.9p1-10+deb10u2+rpt1_armhf.deb  Could not open file /var/cache/apt/archives/partial/openssh-server_1%3a7.9p1-10+deb10u2+rpt1_armhf.deb - open (30: Read-only file system) [IP: 2a00:1098:88:26::1 80]
      E: Failed to fetch http://archive.raspberrypi.org/debian/pool/main/o/openssh/openssh-client_7.9p1-10+deb10u2+rpt1_armhf.deb  Could not open file /var/cache/apt/archives/partial/openssh-client_1%3a7.9p1-10+deb10u2+rpt1_armhf.deb - open (30: Read-only file system) [IP: 2a00:1098:88:26::2:1 80]
      E: Failed to fetch http://archive.raspberrypi.org/debian/pool/main/o/openssh/ssh_7.9p1-10+deb10u2+rpt1_all.deb  Could not open file /var/cache/apt/archives/partial/ssh_1%3a7.9p1-10+deb10u2+rpt1_all.deb - open (30: Read-only file system) [IP: 46.235.230.122 80]
      E: Failed to fetch http://mirror1.hs-esslingen.de/pub/Mirrors/archive.raspbian.org/raspbian/pool/main/o/openldap/libldap-common_2.4.47+dfsg-3+rpi1+deb10u6_all.deb  Could not open file /var/cache/apt/archives/partial/libldap-common_2.4.47+dfsg-3+rpi1+deb10u6_all.deb - open (30: Read-only file system) [IP: 2001:7c0:700::10 80]
      E: Failed to fetch http://ftp.halifax.rwth-aachen.de/raspbian/raspbian/pool/main/o/openldap/libldap-2.4-2_2.4.47+dfsg-3+rpi1+deb10u6_armhf.deb  Could not open file /var/cache/apt/archives/partial/libldap-2.4-2_2.4.47+dfsg-3+rpi1+deb10u6_armhf.deb - open (30: Read-only file system) [IP: 137.226.34.46 80]
      E: Failed to fetch http://ftp.halifax.rwth-aachen.de/raspbian/raspbian/pool/main/t/tzdata/tzdata_2021a-0+deb10u3_all.deb  Could not open file /var/cache/apt/archives/partial/tzdata_2021a-0+deb10u3_all.deb - open (30: Read-only file system) [IP: 2a00:8a60:e012:a00::21 80]
      E: Failed to fetch http://ftp.halifax.rwth-aachen.de/raspbian/raspbian/pool/main/g/groff/groff-base_1.22.4-3+deb10u1_armhf.deb  Could not open file /var/cache/apt/archives/partial/groff-base_1.22.4-3+deb10u1_armhf.deb - open (30: Read-only file system) [IP: 137.226.34.46 80]
      E: Failed to fetch http://ftp.halifax.rwth-aachen.de/raspbian/raspbian/pool/main/i/iproute2/iproute2_4.20.0-2+deb10u1_armhf.deb  Could not open file /var/cache/apt/archives/partial/iproute2_4.20.0-2+deb10u1_armhf.deb - open (30: Read-only file system) [IP: 2a00:8a60:e012:a00::21 80]
      E: Failed to fetch http://ftp.halifax.rwth-aachen.de/raspbian/raspbian/pool/main/i/iputils/iputils-ping_20180629-2+deb10u2_armhf.deb  Could not open file /var/cache/apt/archives/partial/iputils-ping_3%3a20180629-2+deb10u2_armhf.deb - open (30: Read-only file system) [IP: 137.226.34.46 80]
      E: Failed to fetch http://ftp.halifax.rwth-aachen.de/raspbian/raspbian/pool/main/b/bind9/libisc-export1100_9.11.5.P4+dfsg-5.1+deb10u6_armhf.deb  Could not open file /var/cache/apt/archives/partial/libisc-export1100_1%3a9.11.5.P4+dfsg-5.1+deb10u6_armhf.deb - open (30: Read-only file system) [IP: 2a00:8a60:e012:a00::21 80]
      E: Failed to fetch http://mirror.netcologne.de/raspbian/raspbian/pool/main/b/bind9/libdns-export1104_9.11.5.P4+dfsg-5.1+deb10u6_armhf.deb  Could not open file /var/cache/apt/archives/partial/libdns-export1104_1%3a9.11.5.P4+dfsg-5.1+deb10u6_armhf.deb - open (30: Read-only file system) [IP: 194.8.197.22 80]
      E: Failed to fetch http://ftp.halifax.rwth-aachen.de/raspbian/raspbian/pool/main/i/isc-dhcp/isc-dhcp-client_4.4.1-2+deb10u1_armhf.deb  Could not open file /var/cache/apt/archives/partial/isc-dhcp-client_4.4.1-2+deb10u1_armhf.deb - open (30: Read-only file system) [IP: 137.226.34.46 80]
      E: Failed to fetch http://ftp.halifax.rwth-aachen.de/raspbian/raspbian/pool/main/i/isc-dhcp/isc-dhcp-common_4.4.1-2+deb10u1_armhf.deb  Could not open file /var/cache/apt/archives/partial/isc-dhcp-common_4.4.1-2+deb10u1_armhf.deb - open (30: Read-only file system) [IP: 2a00:8a60:e012:a00::21 80]
      E: Failed to fetch http://ftp.halifax.rwth-aachen.de/raspbian/raspbian/pool/main/i/icu/libicu63_63.1-6+deb10u2_armhf.deb  Could not open file /var/cache/apt/archives/partial/libicu63_63.1-6+deb10u2_armhf.deb - open (30: Read-only file system) [IP: 137.226.34.46 80]
      E: Failed to fetch http://ftp.halifax.rwth-aachen.de/raspbian/raspbian/pool/main/libx/libxml2/libxml2_2.9.4+dfsg1-7+deb10u2_armhf.deb  Could not open file /var/cache/apt/archives/partial/libxml2_2.9.4+dfsg1-7+deb10u2_armhf.deb - open (30: Read-only file system) [IP: 2a00:8a60:e012:a00::21 80]
      E: Failed to fetch http://ftp.halifax.rwth-aachen.de/raspbian/raspbian/pool/main/b/bind9/bind9-host_9.11.5.P4+dfsg-5.1+deb10u6_armhf.deb  Could not open file /var/cache/apt/archives/partial/bind9-host_1%3a9.11.5.P4+dfsg-5.1+deb10u6_armhf.deb - open (30: Read-only file system) [IP: 137.226.34.46 80]
      E: Failed to fetch http://ftp.halifax.rwth-aachen.de/raspbian/raspbian/pool/main/b/bind9/libbind9-161_9.11.5.P4+dfsg-5.1+deb10u6_armhf.deb  Could not open file /var/cache/apt/archives/partial/libbind9-161_1%3a9.11.5.P4+dfsg-5.1+deb10u6_armhf.deb - open (30: Read-only file system) [IP: 2a00:8a60:e012:a00::21 80]
      E: Failed to fetch http://ftp.halifax.rwth-aachen.de/raspbian/raspbian/pool/main/b/bind9/libisccfg163_9.11.5.P4+dfsg-5.1+deb10u6_armhf.deb  Could not open file /var/cache/apt/archives/partial/libisccfg163_1%3a9.11.5.P4+dfsg-5.1+deb10u6_armhf.deb - open (30: Read-only file system) [IP: 137.226.34.46 80]
      E: Failed to fetch http://ftp.halifax.rwth-aachen.de/raspbian/raspbian/pool/main/b/bind9/libisccc161_9.11.5.P4+dfsg-5.1+deb10u6_armhf.deb  Could not open file /var/cache/apt/archives/partial/libisccc161_1%3a9.11.5.P4+dfsg-5.1+deb10u6_armhf.deb - open (30: Read-only file system) [IP: 2a00:8a60:e012:a00::21 80]
      E: Failed to fetch http://mirror.de.leaseweb.net/raspbian/raspbian/pool/main/b/bind9/libdns1104_9.11.5.P4+dfsg-5.1+deb10u6_armhf.deb  Could not open file /var/cache/apt/archives/partial/libdns1104_1%3a9.11.5.P4+dfsg-5.1+deb10u6_armhf.deb - open (30: Read-only file system) [IP: 37.58.58.140 80]
      E: Failed to fetch http://ftp.halifax.rwth-aachen.de/raspbian/raspbian/pool/main/b/bind9/libisc1100_9.11.5.P4+dfsg-5.1+deb10u6_armhf.deb  Could not open file /var/cache/apt/archives/partial/libisc1100_1%3a9.11.5.P4+dfsg-5.1+deb10u6_armhf.deb - open (30: Read-only file system) [IP: 137.226.34.46 80]
      E: Failed to fetch http://mirror1.hs-esslingen.de/pub/Mirrors/archive.raspbian.org/raspbian/pool/main/b/bind9/liblwres161_9.11.5.P4+dfsg-5.1+deb10u6_armhf.deb  Could not open file /var/cache/apt/archives/partial/liblwres161_1%3a9.11.5.P4+dfsg-5.1+deb10u6_armhf.deb - open (30: Read-only file system) [IP: 129.143.116.10 80]
      E: Failed to fetch http://ftp.halifax.rwth-aachen.de/raspbian/raspbian/pool/main/f/file/file_5.35-4+deb10u2_armhf.deb  Could not open file /var/cache/apt/archives/partial/file_1%3a5.35-4+deb10u2_armhf.deb - open (30: Read-only file system) [IP: 2a00:8a60:e012:a00::21 80]
      E: Failed to fetch http://ftp.halifax.rwth-aachen.de/raspbian/raspbian/pool/main/f/file/libmagic1_5.35-4+deb10u2_armhf.deb  Could not open file /var/cache/apt/archives/partial/libmagic1_1%3a5.35-4+deb10u2_armhf.deb - open (30: Read-only file system) [IP: 137.226.34.46 80]
      E: Failed to fetch http://ftp.halifax.rwth-aachen.de/raspbian/raspbian/pool/main/f/file/libmagic-mgc_5.35-4+deb10u2_armhf.deb  Could not open file /var/cache/apt/archives/partial/libmagic-mgc_1%3a5.35-4+deb10u2_armhf.deb - open (30: Read-only file system) [IP: 2a00:8a60:e012:a00::21 80]
      E: Failed to fetch http://archive.raspberrypi.org/debian/pool/main/g/glibc/libc-l10n_2.28-10+rpt2+rpi1_all.deb  Could not open file /var/cache/apt/archives/partial/libc-l10n_2.28-10+rpt2+rpi1_all.deb - open (30: Read-only file system) [IP: 93.93.135.117 80]
      E: Failed to fetch http://archive.raspberrypi.org/debian/pool/main/g/glibc/locales_2.28-10+rpt2+rpi1_all.deb  Could not open file /var/cache/apt/archives/partial/locales_2.28-10+rpt2+rpi1_all.deb - open (30: Read-only file system) [IP: 93.93.130.212 80]
      E: Failed to fetch http://archive.raspberrypi.org/debian/pool/main/a/alsa-utils/alsa-utils_1.1.8-2+rpt1_armhf.deb  Could not open file /var/cache/apt/archives/partial/alsa-utils_1.1.8-2+rpt1_armhf.deb - open (30: Read-only file system) [IP: 93.93.135.118 80]
      E: Failed to fetch http://ftp.halifax.rwth-aachen.de/raspbian/raspbian/pool/main/a/avahi/libavahi-common-dev_0.7-4+deb10u1_armhf.deb  Could not open file /var/cache/apt/archives/partial/libavahi-common-dev_0.7-4+deb10u1_armhf.deb - open (30: Read-only file system) [IP: 137.226.34.46 80]
      E: Failed to fetch http://mirror.de.leaseweb.net/raspbian/raspbian/pool/main/a/avahi/libavahi-common-data_0.7-4+deb10u1_armhf.deb  Could not open file /var/cache/apt/archives/partial/libavahi-common-data_0.7-4+deb10u1_armhf.deb - open (30: Read-only file system) [IP: 2a00:c98:2030:a034::21 80]
      E: Failed to fetch http://ftp.halifax.rwth-aachen.de/raspbian/raspbian/pool/main/a/avahi/libavahi-common3_0.7-4+deb10u1_armhf.deb  Could not open file /var/cache/apt/archives/partial/libavahi-common3_0.7-4+deb10u1_armhf.deb - open (30: Read-only file system) [IP: 2a00:8a60:e012:a00::21 80]
      E: Failed to fetch http://ftp.halifax.rwth-aachen.de/raspbian/raspbian/pool/main/a/avahi/libavahi-core7_0.7-4+deb10u1_armhf.deb  Could not open file /var/cache/apt/archives/partial/libavahi-core7_0.7-4+deb10u1_armhf.deb - open (30: Read-only file system) [IP: 137.226.34.46 80]
      E: Failed to fetch http://mirror1.hs-esslingen.de/pub/Mirrors/archive.raspbian.org/raspbian/pool/main/a/avahi/avahi-daemon_0.7-4+deb10u1_armhf.deb  Could not open file /var/cache/apt/archives/partial/avahi-daemon_0.7-4+deb10u1_armhf.deb - open (30: Read-only file system) [IP: 2001:7c0:700::10 80]
      E: Failed to fetch http://archive.raspberrypi.org/debian/pool/main/b/bluez-firmware/bluez-firmware_1.2-4+rpt8_all.deb  Could not open file /var/cache/apt/archives/partial/bluez-firmware_1.2-4+rpt8_all.deb - open (30: Read-only file system) [IP: 176.126.240.84 80]
      E: Failed to fetch http://ftp.halifax.rwth-aachen.de/raspbian/raspbian/pool/main/o/openssl/openssl_1.1.1d-0+deb10u7_armhf.deb  Could not open file /var/cache/apt/archives/partial/openssl_1.1.1d-0+deb10u7_armhf.deb - open (30: Read-only file system) [IP: 2a00:8a60:e012:a00::21 80]
      E: Failed to fetch http://mirror1.hs-esslingen.de/pub/Mirrors/archive.raspbian.org/raspbian/pool/main/c/ca-certificates/ca-certificates_20200601~deb10u2_all.deb  Could not open file /var/cache/apt/archives/partial/ca-certificates_20200601~deb10u2_all.deb - open (30: Read-only file system) [IP: 129.143.116.10 80]
      E: Failed to fetch http://ftp.halifax.rwth-aachen.de/raspbian/raspbian/pool/main/c/curl/curl_7.64.0-4+deb10u2_armhf.deb  Could not open file /var/cache/apt/archives/partial/curl_7.64.0-4+deb10u2_armhf.deb - open (30: Read-only file system) [IP: 137.226.34.46 80]
      E: Failed to fetch http://ftp.halifax.rwth-aachen.de/raspbian/raspbian/pool/main/c/curl/libcurl4_7.64.0-4+deb10u2_armhf.deb  Could not open file /var/cache/apt/archives/partial/libcurl4_7.64.0-4+deb10u2_armhf.deb - open (30: Read-only file system) [IP: 2a00:8a60:e012:a00::21 80]
      E: Failed to fetch http://ftp.halifax.rwth-aachen.de/raspbian/raspbian/pool/main/d/device-tree-compiler/device-tree-compiler_1.4.7-4_armhf.deb  Could not open file /var/cache/apt/archives/partial/device-tree-compiler_1.4.7-4_armhf.deb - open (30: Read-only file system) [IP: 137.226.34.46 80]
      E: Failed to fetch http://ftp.halifax.rwth-aachen.de/raspbian/raspbian/pool/main/d/distro-info-data/distro-info-data_0.41+deb10u4_all.deb  Could not open file /var/cache/apt/archives/partial/distro-info-data_0.41+deb10u4_all.deb - open (30: Read-only file system) [IP: 2a00:8a60:e012:a00::21 80]
      E: Failed to fetch http://archive.raspberrypi.org/debian/pool/main/d/dphys-swapfile/dphys-swapfile_20100506-5+rpt2_all.deb  Could not open file /var/cache/apt/archives/partial/dphys-swapfile_20100506-5+rpt2_all.deb - open (30: Read-only file system) [IP: 46.235.231.111 80]
      E: Failed to fetch http://archive.raspberrypi.org/debian/pool/main/f/firmware-nonfree/firmware-atheros_20190114-2+rpt4_all.deb  Could not open file /var/cache/apt/archives/partial/firmware-atheros_1%3a20190114-2+rpt4_all.deb - open (30: Read-only file system) [IP: 46.235.231.145 80]
      E: Failed to fetch http://archive.raspberrypi.org/debian/pool/main/f/firmware-nonfree/firmware-brcm80211_20190114-2+rpt4_all.deb  Could not open file /var/cache/apt/archives/partial/firmware-brcm80211_1%3a20190114-2+rpt4_all.deb - open (30: Read-only file system) [IP: 176.126.240.86 80]
      E: Failed to fetch http://archive.raspberrypi.org/debian/pool/main/f/firmware-nonfree/firmware-libertas_20190114-2+rpt4_all.deb  Could not open file /var/cache/apt/archives/partial/firmware-libertas_1%3a20190114-2+rpt4_all.deb - open (30: Read-only file system) [IP: 46.235.231.151 80]
      E: Failed to fetch http://archive.raspberrypi.org/debian/pool/main/f/firmware-nonfree/firmware-misc-nonfree_20190114-2+rpt4_all.deb  Could not open file /var/cache/apt/archives/partial/firmware-misc-nonfree_1%3a20190114-2+rpt4_all.deb - open (30: Read-only file system) [IP: 46.235.227.39 80]
      E: Failed to fetch http://archive.raspberrypi.org/debian/pool/main/f/firmware-nonfree/firmware-realtek_20190114-2+rpt4_all.deb  Could not open file /var/cache/apt/archives/partial/firmware-realtek_1%3a20190114-2+rpt4_all.deb - open (30: Read-only file system) [IP: 176.126.240.167 80]
      E: Failed to fetch http://ftp.gwdg.de/pub/linux/debian/raspbian/raspbian/pool/main/k/klibc/klibc-utils_2.0.6-1+rpi1+deb10u1_armhf.deb  Could not open file /var/cache/apt/archives/partial/klibc-utils_2.0.6-1+rpi1+deb10u1_armhf.deb - open (30: Read-only file system) [IP: 134.76.12.6 80]
      E: Failed to fetch http://ftp.halifax.rwth-aachen.de/raspbian/raspbian/pool/main/k/klibc/libklibc_2.0.6-1+rpi1+deb10u1_armhf.deb  Could not open file /var/cache/apt/archives/partial/libklibc_2.0.6-1+rpi1+deb10u1_armhf.deb - open (30: Read-only file system) [IP: 137.226.34.46 80]
      E: Failed to fetch http://mirror1.hs-esslingen.de/pub/Mirrors/archive.raspbian.org/raspbian/pool/main/a/avahi/libavahi-client-dev_0.7-4+deb10u1_armhf.deb  Could not open file /var/cache/apt/archives/partial/libavahi-client-dev_0.7-4+deb10u1_armhf.deb - open (30: Read-only file system) [IP: 2001:7c0:700::10 80]
      E: Failed to fetch http://ftp.halifax.rwth-aachen.de/raspbian/raspbian/pool/main/a/avahi/libavahi-client3_0.7-4+deb10u1_armhf.deb  Could not open file /var/cache/apt/archives/partial/libavahi-client3_0.7-4+deb10u1_armhf.deb - open (30: Read-only file system) [IP: 2a00:8a60:e012:a00::21 80]
      E: Failed to fetch http://ftp.halifax.rwth-aachen.de/raspbian/raspbian/pool/main/a/avahi/libavahi-compat-libdnssd-dev_0.7-4+deb10u1_armhf.deb  Could not open file /var/cache/apt/archives/partial/libavahi-compat-libdnssd-dev_0.7-4+deb10u1_armhf.deb - open (30: Read-only file system) [IP: 137.226.34.46 80]
      E: Failed to fetch http://ftp.halifax.rwth-aachen.de/raspbian/raspbian/pool/main/a/avahi/libavahi-compat-libdnssd1_0.7-4+deb10u1_armhf.deb  Could not open file /var/cache/apt/archives/partial/libavahi-compat-libdnssd1_0.7-4+deb10u1_armhf.deb - open (30: Read-only file system) [IP: 2a00:8a60:e012:a00::21 80]
      E: Failed to fetch http://ftp.halifax.rwth-aachen.de/raspbian/raspbian/pool/main/libb/libbsd/libbsd0_0.9.1-2+deb10u1_armhf.deb  Could not open file /var/cache/apt/archives/partial/libbsd0_0.9.1-2+deb10u1_armhf.deb - open (30: Read-only file system) [IP: 137.226.34.46 80]
      E: Failed to fetch http://ftp.halifax.rwth-aachen.de/raspbian/raspbian/pool/main/c/curl/libcurl3-gnutls_7.64.0-4+deb10u2_armhf.deb  Could not open file /var/cache/apt/archives/partial/libcurl3-gnutls_7.64.0-4+deb10u2_armhf.deb - open (30: Read-only file system) [IP: 2a00:8a60:e012:a00::21 80]
      E: Failed to fetch http://mirror.de.leaseweb.net/raspbian/raspbian/pool/main/libj/libjpeg-turbo/libjpeg62-turbo_1.5.2-2+deb10u1_armhf.deb  Could not open file /var/cache/apt/archives/partial/libjpeg62-turbo_1%3a1.5.2-2+deb10u1_armhf.deb - open (30: Read-only file system) [IP: 37.58.58.140 80]
      E: Failed to fetch http://archive.raspberrypi.org/debian/pool/main/libn/libnftnl/libnftnl11_1.1.7-1~bpo10+1~0_armhf.deb  Could not open file /var/cache/apt/archives/partial/libnftnl11_1.1.7-1~bpo10+1~0_armhf.deb - open (30: Read-only file system) [IP: 93.93.135.141 80]
      E: Failed to fetch http://archive.raspberrypi.org/debian/pool/main/p/policykit-1/policykit-1_0.105-25+rpt1+deb10u1_armhf.deb  Could not open file /var/cache/apt/archives/partial/policykit-1_0.105-25+rpt1+deb10u1_armhf.deb - open (30: Read-only file system) [IP: 2a00:1098:88:26::1:1 80]
      E: Failed to fetch http://archive.raspberrypi.org/debian/pool/main/p/policykit-1/libpolkit-agent-1-0_0.105-25+rpt1+deb10u1_armhf.deb  Could not open file /var/cache/apt/archives/partial/libpolkit-agent-1-0_0.105-25+rpt1+deb10u1_armhf.deb - open (30: Read-only file system) [IP: 2a00:1098:80:56::3:1 80]
      E: Failed to fetch http://archive.raspberrypi.org/debian/pool/main/p/policykit-1/libpolkit-backend-1-0_0.105-25+rpt1+deb10u1_armhf.deb  Could not open file /var/cache/apt/archives/partial/libpolkit-backend-1-0_0.105-25+rpt1+deb10u1_armhf.deb - open (30: Read-only file system) [IP: 2a00:1098:80:56::2:1 80]
      E: Failed to fetch http://archive.raspberrypi.org/debian/pool/main/p/policykit-1/libpolkit-gobject-1-0_0.105-25+rpt1+deb10u1_armhf.deb  Could not open file /var/cache/apt/archives/partial/libpolkit-gobject-1-0_0.105-25+rpt1+deb10u1_armhf.deb - open (30: Read-only file system) [IP: 2a00:1098:84:1e0::2 80]
      E: Failed to fetch http://archive.raspberrypi.org/debian/pool/main/r/raspberrypi-firmware/libraspberrypi-doc_1.20211201~buster-1_armhf.deb  Could not open file /var/cache/apt/archives/partial/libraspberrypi-doc_1%3a1.20211201~buster-1_armhf.deb - open (30: Read-only file system) [IP: 2a00:1098:80:56::1:1 80]
      E: Failed to fetch http://archive.raspberrypi.org/debian/pool/main/r/raspberrypi-firmware/libraspberrypi-dev_1.20211201~buster-1_armhf.deb  Could not open file /var/cache/apt/archives/partial/libraspberrypi-dev_1%3a1.20211201~buster-1_armhf.deb - open (30: Read-only file system) [IP: 2a00:1098:82:47::1:1 80]
      E: Failed to fetch http://archive.raspberrypi.org/debian/pool/main/r/raspberrypi-firmware/raspberrypi-kernel_1.20211201~buster-1_armhf.deb  Could not open file /var/cache/apt/archives/partial/raspberrypi-kernel_1%3a1.20211201~buster-1_armhf.deb - open (30: Read-only file system) [IP: 2a00:1098:82:47::2:1 80]
      E: Failed to fetch http://archive.raspberrypi.org/debian/pool/main/r/raspberrypi-firmware/libraspberrypi-bin_1.20211201~buster-1_armhf.deb  Could not open file /var/cache/apt/archives/partial/libraspberrypi-bin_1%3a1.20211201~buster-1_armhf.deb - open (30: Read-only file system) [IP: 2a00:1098:82:47::1 80]
      E: Failed to fetch http://archive.raspberrypi.org/debian/pool/main/r/raspberrypi-firmware/libraspberrypi0_1.20211201~buster-1_armhf.deb  Could not open file /var/cache/apt/archives/partial/libraspberrypi0_1%3a1.20211201~buster-1_armhf.deb - open (30: Read-only file system) [IP: 2a00:1098:84:1e0::1 80]
      E: Failed to fetch http://archive.raspberrypi.org/debian/pool/main/r/raspberrypi-firmware/raspberrypi-bootloader_1.20211201~buster-1_armhf.deb  Could not open file /var/cache/apt/archives/partial/raspberrypi-bootloader_1%3a1.20211201~buster-1_armhf.deb - open (30: Read-only file system) [IP: 2a00:1098:84:1e0::3 80]
      E: Failed to fetch http://mirror1.hs-esslingen.de/pub/Mirrors/archive.raspbian.org/raspbian/pool/main/libx/libx11/libx11-data_1.6.7-1+deb10u2_all.deb  Could not open file /var/cache/apt/archives/partial/libx11-data_2%3a1.6.7-1+deb10u2_all.deb - open (30: Read-only file system) [IP: 129.143.116.10 80]
      E: Failed to fetch http://ftp.halifax.rwth-aachen.de/raspbian/raspbian/pool/main/libx/libx11/libx11-6_1.6.7-1+deb10u2_armhf.deb  Could not open file /var/cache/apt/archives/partial/libx11-6_2%3a1.6.7-1+deb10u2_armhf.deb - open (30: Read-only file system) [IP: 137.226.34.46 80]
      E: Failed to fetch http://archive.raspberrypi.org/debian/pool/main/g/glibc/multiarch-support_2.28-10+rpt2+rpi1_armhf.deb  Could not open file /var/cache/apt/archives/partial/multiarch-support_2.28-10+rpt2+rpi1_armhf.deb - open (30: Read-only file system) [IP: 2a00:1098:88:26::1 80]
      E: Failed to fetch http://archive.raspberrypi.org/debian/pool/main/r/raspberrypi-sys-mods/raspberrypi-sys-mods_20211005_armhf.deb  Could not open file /var/cache/apt/archives/partial/raspberrypi-sys-mods_20211005_armhf.deb - open (30: Read-only file system) [IP: 2a00:1098:88:26::2:1 80]
      E: Failed to fetch http://archive.raspberrypi.org/debian/pool/main/p/pi-bluetooth/pi-bluetooth_0.1.18_all.deb  Could not open file /var/cache/apt/archives/partial/pi-bluetooth_0.1.18_all.deb - open (30: Read-only file system) [IP: 46.235.230.122 80]
      E: Failed to fetch http://ftp.halifax.rwth-aachen.de/raspbian/raspbian/pool/main/p/psmisc/psmisc_23.2-1+deb10u1_armhf.deb  Could not open file /var/cache/apt/archives/partial/psmisc_23.2-1+deb10u1_armhf.deb - open (30: Read-only file system) [IP: 2a00:8a60:e012:a00::21 80]
      E: Failed to fetch http://ftp.halifax.rwth-aachen.de/raspbian/raspbian/pool/main/p/python-apt/python-apt-common_1.8.4.3_all.deb  Could not open file /var/cache/apt/archives/partial/python-apt-common_1.8.4.3_all.deb - open (30: Read-only file system) [IP: 137.226.34.46 80]
      E: Failed to fetch http://archive.raspberrypi.org/debian/pool/main/r/rpi.gpio/python-rpi.gpio_0.7.0-0.1~bpo10+4_armhf.deb  Could not open file /var/cache/apt/archives/partial/python-rpi.gpio_0.7.0-0.1~bpo10+4_armhf.deb - open (30: Read-only file system) [IP: 93.93.135.117 80]
      E: Failed to fetch http://archive.raspberrypi.org/debian/pool/main/r/rpi.gpio/rpi.gpio-common_0.7.0-0.1~bpo10+4_armhf.deb  Could not open file /var/cache/apt/archives/partial/rpi.gpio-common_0.7.0-0.1~bpo10+4_armhf.deb - open (30: Read-only file system) [IP: 93.93.130.212 80]
      E: Failed to fetch http://ftp.halifax.rwth-aachen.de/raspbian/raspbian/pool/main/p/python-apt/python3-apt_1.8.4.3_armhf.deb  Could not open file /var/cache/apt/archives/partial/python3-apt_1.8.4.3_armhf.deb - open (30: Read-only file system) [IP: 2a00:8a60:e012:a00::21 80]
      E: Failed to fetch http://archive.raspberrypi.org/debian/pool/main/r/raspberrypi-net-mods/raspberrypi-net-mods_1.3.2_all.deb  Could not open file /var/cache/apt/archives/partial/raspberrypi-net-mods_1.3.2_all.deb - open (30: Read-only file system) [IP: 93.93.135.118 80]
      E: Failed to fetch http://archive.raspberrypi.org/debian/pool/main/r/raspi-config/raspi-config_20210212_all.deb  Could not open file /var/cache/apt/archives/partial/raspi-config_20210212_all.deb - open (30: Read-only file system) [IP: 176.126.240.84 80]
      E: Failed to fetch http://archive.raspberrypi.org/debian/pool/main/r/rpi-eeprom/rpi-eeprom_13.9-1~buster_armhf.deb  Could not open file /var/cache/apt/archives/partial/rpi-eeprom_13.9-1~buster_armhf.deb - open (30: Read-only file system) [IP: 46.235.231.111 80]
      E: Failed to fetch http://archive.raspberrypi.org/debian/pool/main/r/rpi-update/rpi-update_20210618_all.deb  Could not open file /var/cache/apt/archives/partial/rpi-update_20210618_all.deb - open (30: Read-only file system) [IP: 46.235.231.145 80]
      E: Failed to fetch http://ftp.halifax.rwth-aachen.de/raspbian/raspbian/pool/main/s/sudo/sudo_1.8.27-1+deb10u3_armhf.deb  Could not open file /var/cache/apt/archives/partial/sudo_1.8.27-1+deb10u3_armhf.deb - open (30: Read-only file system) [IP: 137.226.34.46 80]
      E: Failed to fetch http://ftp.halifax.rwth-aachen.de/raspbian/raspbian/pool/main/u/unzip/unzip_6.0-23+deb10u2_armhf.deb  Could not open file /var/cache/apt/archives/partial/unzip_6.0-23+deb10u2_armhf.deb - open (30: Read-only file system) [IP: 2a00:8a60:e012:a00::21 80]
      E: Failed to fetch http://mirror.de.leaseweb.net/raspbian/raspbian/pool/main/w/wpa/wpasupplicant_2.7+git20190128+0c1e29f-6+deb10u3_armhf.deb  Could not open file /var/cache/apt/archives/partial/wpasupplicant_2%3a2.7+git20190128+0c1e29f-6+deb10u3_armhf.deb - open (30: Read-only file system) [IP: 2a00:c98:2030:a034::21 80]
      E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
      pi@raspberrypi:~ $
      • T tamtaras
        @thomas-braun Bitte nicht erschlagen! 😥
        pi@raspberrypi:~ $ iobroker update
        Used repository: default
        /opt/iobroker/node_modules/tough-cookie/lib/cookie.js:865
          if (this.,"lc":1645241342031}
        SyntaxError: Unexpected token ','
            at wrapSafe (node:internal/modules/cjs/loader:999:16)
            at Module._compile (node:internal/modules/cjs/loader:1047:27)
            at Object.Module._extensions..js (node:internal/modules/cjs/loader:1112:10)
            at Module.load (node:internal/modules/cjs/loader:948:32)
            at Function.Module._load (node:internal/modules/cjs/loader:789:14)
            at Module.require (node:internal/modules/cjs/loader:972:19)
            at require (node:internal/modules/cjs/helpers:88:18)
            at Object.<anonymous> (/opt/iobroker/node_modules/request/lib/cookies.js:3:13)
            at Module._compile (node:internal/modules/cjs/loader:1083:30)
        pi@raspberrypi:~ $ sudo apt update
        Get:1 http://archive.raspberrypi.org/debian buster InRelease [32.6 kB]
        Get:2 http://raspbian.raspberrypi.org/raspbian buster InRelease [15.0 kB]
        Hit:3 https://deb.nodesource.com/node_15.x buster InRelease
        E: Repository 'http://archive.raspberrypi.org/debian buster InRelease' changed its 'Suite' value from 'testing' to 'oldstable'
        N: This must be accepted explicitly before updates for this repository can be applied. See apt-secure(8) manpage for details.
        Do you want to accept these changes and continue updating from this repository? [y/N] Y
        Get:4 http://archive.raspberrypi.org/debian buster/main armhf Packages [393 kB]
        E: Repository 'http://raspbian.raspberrypi.org/raspbian buster InRelease' changed its 'Suite' value from 'stable' to 'oldstable'
        Do you want to accept these changes and continue updating from this repository? [y/N] y
        Get:5 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages [13.0 MB]
        Get:6 http://raspbian.raspberrypi.org/raspbian buster/contrib armhf Packages [58.8 kB]
        Get:7 http://raspbian.raspberrypi.org/raspbian buster/non-free armhf Packages [104 kB]
        Fetched 13.6 MB in 26s (524 kB/s)
        Reading package lists... Done
        Building dependency tree
        131 packages can be upgraded. Run 'apt list --upgradable' to see them.
        pi@raspberrypi:~ $ sudo apt full-upgrade
        Calculating upgrade... Done
        The following packages will be upgraded:
          alsa-utils apt apt-utils avahi-daemon base-files bind9-host bluez bluez-firmware ca-certificates curl debconf debconf-i18n debconf-utils device-tree-compiler
          distro-info-data dphys-swapfile file firmware-atheros firmware-brcm80211 firmware-libertas firmware-misc-nonfree firmware-realtek groff-base iproute2
          iputils-ping isc-dhcp-client isc-dhcp-common klibc-utils libapt-inst2.0 libapt-pkg5.0 libasound2 libasound2-data libavahi-client-dev libavahi-client3
          libavahi-common-data libavahi-common-dev libavahi-common3 libavahi-compat-libdnssd-dev libavahi-compat-libdnssd1 libavahi-core7 libbind9-161 libbsd0 libc-bin
          libc-dev-bin libc-l10n libc6 libc6-dbg libc6-dev libcurl3-gnutls libcurl4 libdns-export1104 libdns1104 libexpat1 libexpat1-dev libgcrypt20 libgnutls30
          libgssapi-krb5-2 libhogweed4 libicu63 libisc-export1100 libisc1100 libisccc161 libisccfg163 libjpeg62-turbo libk5crypto3 libklibc libkrb5-3 libkrb5support0
          libldap-2.4-2 libldap-common liblwres161 liblz4-1 libmagic-mgc libmagic1 libnettle6 libnftnl11 libntfs-3g883 libp11-kit0 libpam-systemd libpolkit-agent-1-0
          libpolkit-backend-1-0 libpolkit-gobject-1-0 libpython3.7 libpython3.7-minimal libpython3.7-stdlib libraspberrypi-bin libraspberrypi-dev libraspberrypi-doc
          libraspberrypi0 libsqlite3-0 libssl1.1 libsystemd0 libudev-dev libudev1 libx11-6 libx11-data libxml2 libzstd1 linux-libc-dev locales multiarch-support ntfs-3g
          openssh-client openssh-server openssh-sftp-server openssl pi-bluetooth policykit-1 psmisc python-apt-common python-rpi.gpio python3-apt python3-debconf python3.7
          python3.7-minimal raspberrypi-bootloader raspberrypi-kernel raspberrypi-net-mods raspberrypi-sys-mods raspi-config rpi-eeprom rpi-update rpi.gpio-common ssh sudo
          systemd systemd-sysv tzdata udev unzip wpasupplicant
        131 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
        Need to get 203 MB of archives.
        After this operation, 18.7 MB of additional disk space will be used.
        Do you want to continue? [Y/n] Y
        Err:1 http://archive.raspberrypi.org/debian buster/main armhf libc6-dbg armhf 2.28-10+rpt2+rpi1
        Err:2 http://archive.raspberrypi.org/debian buster/main armhf libc6-dev armhf 2.28-10+rpt2+rpi1
        Err:4 http://archive.raspberrypi.org/debian buster/main armhf libc-dev-bin armhf 2.28-10+rpt2+rpi1
        Err:3 http://mirror.de.leaseweb.net/raspbian/raspbian buster/main armhf base-files armhf 10.3+rpi1+deb10u11
        Err:6 http://archive.raspberrypi.org/debian buster/main armhf linux-libc-dev armhf 1:1.20211201~buster-1
        Err:7 http://archive.raspberrypi.org/debian buster/main armhf libc6 armhf 2.28-10+rpt2+rpi1
        Err:5 http://mirror1.hs-esslingen.de/pub/Mirrors/archive.raspbian.org/raspbian buster/main armhf liblz4-1 armhf 1.8.3-1+deb10u1
        Err:9 http://archive.raspberrypi.org/debian buster/main armhf libc-bin armhf 2.28-10+rpt2+rpi1
        Err:10 http://archive.raspberrypi.org/debian buster/main armhf bluez armhf 5.50-1.2~deb10u2+rpt1
          Could not open file /var/cache/apt/archives/partial/bluez_5.50-1.2~deb10u2+rpt1_armhf.deb - open (30: Read-only file system) [IP: 2a00:1098:82:47::2:1 80]
        Err:11 http://archive.raspberrypi.org/debian buster/main armhf libasound2 armhf 1.1.8-1+rpt2
          Could not open file /var/cache/apt/archives/partial/libasound2_1.1.8-1+rpt2_armhf.deb - open (30: Read-only file system) [IP: 2a00:1098:82:47::1 80]
        Err:12 http://mirror1.hs-esslingen.de/pub/Mirrors/archive.raspbian.org/raspbian buster/main armhf libpam-systemd armhf 241-7~deb10u8+rpi1
          Could not open file /var/cache/apt/archives/partial/libpam-systemd_241-7~deb10u8+rpi1_armhf.deb - open (30: Read-only file system) [IP: 129.143.116.10 80]
        Err:13 http://archive.raspberrypi.org/debian buster/main armhf libasound2-data all 1.1.8-1+rpt2
          Could not open file /var/cache/apt/archives/partial/libasound2-data_1.1.8-1+rpt2_all.deb - open (30: Read-only file system) [IP: 2a00:1098:84:1e0::1 80]
        Err:14 http://archive.raspberrypi.org/debian buster/main armhf openssh-sftp-server armhf 1:7.9p1-10+deb10u2+rpt1
        Err:16 http://archive.raspberrypi.org/debian buster/main armhf openssh-server armhf 1:7.9p1-10+deb10u2+rpt1
        Err:15 http://mirror.de.leaseweb.net/raspbian/raspbian buster/main armhf libudev-dev armhf 241-7~deb10u8+rpi1
          Could not open file /var/cache/apt/archives/partial/libudev-dev_241-7~deb10u8+rpi1_armhf.deb - open (30: Read-only file system) [IP: 37.58.58.140 80]
        Err:17 http://archive.raspberrypi.org/debian buster/main armhf openssh-client armhf 1:7.9p1-10+deb10u2+rpt1
        Err:8 http://ftp.gwdg.de/pub/linux/debian/raspbian/raspbian buster/main armhf systemd-sysv armhf 241-7~deb10u8+rpi1
        Err:19 http://archive.raspberrypi.org/debian buster/main armhf ssh all 1:7.9p1-10+deb10u2+rpt1
        Err:18 http://mirror.de.leaseweb.net/raspbian/raspbian buster/main armhf libsystemd0 armhf 241-7~deb10u8+rpi1
          Could not open file /var/cache/apt/archives/partial/libsystemd0_241-7~deb10u8+rpi1_armhf.deb - open (30: Read-only file system) [IP: 2a00:c98:2030:a034::21 80]
        Err:20 http://archive.raspberrypi.org/debian buster/main armhf libc-l10n all 2.28-10+rpt2+rpi1
        Err:21 http://archive.raspberrypi.org/debian buster/main armhf locales all 2.28-10+rpt2+rpi1
        Err:23 http://archive.raspberrypi.org/debian buster/main armhf alsa-utils armhf 1.1.8-2+rpt1
        Err:24 http://archive.raspberrypi.org/debian buster/main armhf bluez-firmware all 1.2-4+rpt8
        Err:22 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf systemd armhf 241-7~deb10u8+rpi1
          Could not open file /var/cache/apt/archives/partial/systemd_241-7~deb10u8+rpi1_armhf.deb - open (30: Read-only file system) [IP: 2a00:8a60:e012:a00::21 80]
        Err:26 http://archive.raspberrypi.org/debian buster/main armhf dphys-swapfile all 20100506-5+rpt2
        Err:25 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf udev armhf 241-7~deb10u8+rpi1
          Could not open file /var/cache/apt/archives/partial/udev_241-7~deb10u8+rpi1_armhf.deb - open (30: Read-only file system) [IP: 137.226.34.46 80]
        Err:28 http://archive.raspberrypi.org/debian buster/main armhf firmware-atheros all 1:20190114-2+rpt4
        Err:27 http://mirror1.hs-esslingen.de/pub/Mirrors/archive.raspbian.org/raspbian buster/main armhf libudev1 armhf 241-7~deb10u8+rpi1
          Could not open file /var/cache/apt/archives/partial/libudev1_241-7~deb10u8+rpi1_armhf.deb - open (30: Read-only file system) [IP: 2001:7c0:700::10 80]
        Err:29 http://archive.raspberrypi.org/debian buster/main armhf firmware-brcm80211 all 1:20190114-2+rpt4
        Err:31 http://archive.raspberrypi.org/debian buster/main armhf firmware-libertas all 1:20190114-2+rpt4
        Err:32 http://archive.raspberrypi.org/debian buster/main armhf firmware-misc-nonfree all 1:20190114-2+rpt4
        Err:30 http://mirror.netcologne.de/raspbian/raspbian buster/main armhf libnettle6 armhf 3.4.1-1+deb10u1
          Could not open file /var/cache/apt/archives/partial/libnettle6_3.4.1-1+deb10u1_armhf.deb - open (30: Read-only file system) [IP: 2001:4dd0:1234:1::deb 80]
        Err:34 http://archive.raspberrypi.org/debian buster/main armhf firmware-realtek all 1:20190114-2+rpt4
        Err:33 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libhogweed4 armhf 3.4.1-1+deb10u1
          Could not open file /var/cache/apt/archives/partial/libhogweed4_3.4.1-1+deb10u1_armhf.deb - open (30: Read-only file system) [IP: 2a00:8a60:e012:a00::21 80]
        Err:35 http://archive.raspberrypi.org/debian buster/main armhf libnftnl11 armhf 1.1.7-1~bpo10+1~0
        Err:37 http://archive.raspberrypi.org/debian buster/main armhf policykit-1 armhf 0.105-25+rpt1+deb10u1
        Err:36 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libp11-kit0 armhf 0.23.15-2+deb10u1
          Could not open file /var/cache/apt/archives/partial/libp11-kit0_0.23.15-2+deb10u1_armhf.deb - open (30: Read-only file system) [IP: 137.226.34.46 80]
        Err:38 http://archive.raspberrypi.org/debian buster/main armhf libpolkit-agent-1-0 armhf 0.105-25+rpt1+deb10u1
        Err:39 http://mirror1.hs-esslingen.de/pub/Mirrors/archive.raspbian.org/raspbian buster/main armhf libgnutls30 armhf 3.6.7-4+deb10u7
          Could not open file /var/cache/apt/archives/partial/libgnutls30_3.6.7-4+deb10u7_armhf.deb - open (30: Read-only file system) [IP: 129.143.116.10 80]
        Err:40 http://archive.raspberrypi.org/debian buster/main armhf libpolkit-backend-1-0 armhf 0.105-25+rpt1+deb10u1
        Err:41 http://archive.raspberrypi.org/debian buster/main armhf libpolkit-gobject-1-0 armhf 0.105-25+rpt1+deb10u1
        Err:43 http://archive.raspberrypi.org/debian buster/main armhf libraspberrypi-doc armhf 1:1.20211201~buster-1
        Err:44 http://archive.raspberrypi.org/debian buster/main armhf libraspberrypi-dev armhf 1:1.20211201~buster-1
        Err:46 http://archive.raspberrypi.org/debian buster/main armhf raspberrypi-kernel armhf 1:1.20211201~buster-1
        Err:45 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libapt-pkg5.0 armhf 1.8.2.3
          Could not open file /var/cache/apt/archives/partial/libapt-pkg5.0_1.8.2.3_armhf.deb - open (30: Read-only file system) [IP: 2a00:8a60:e012:a00::21 80]
        Err:42 http://mirror.netzwerge.de/raspbian/raspbian buster/main armhf libzstd1 armhf 1.3.8+dfsg-3+rpi1+deb10u2
          Could not open file /var/cache/apt/archives/partial/libzstd1_1.3.8+dfsg-3+rpi1+deb10u2_armhf.deb - open (30: Read-only file system) [IP: 2a01:55e0::a1f 80]
        Err:47 http://archive.raspberrypi.org/debian buster/main armhf libraspberrypi-bin armhf 1:1.20211201~buster-1
        Err:49 http://archive.raspberrypi.org/debian buster/main armhf libraspberrypi0 armhf 1:1.20211201~buster-1
        Err:50 http://archive.raspberrypi.org/debian buster/main armhf raspberrypi-bootloader armhf 1:1.20211201~buster-1
        Err:51 http://archive.raspberrypi.org/debian buster/main armhf multiarch-support armhf 2.28-10+rpt2+rpi1
        Err:48 http://ftp.agdsn.de/pub/mirrors/raspbian/raspbian buster/main armhf libapt-inst2.0 armhf 1.8.2.3
          Could not open file /var/cache/apt/archives/partial/libapt-inst2.0_1.8.2.3_armhf.deb - open (30: Read-only file system) [IP: 141.30.235.39 80]
        Err:53 http://archive.raspberrypi.org/debian buster/main armhf raspberrypi-sys-mods armhf 20211005
        Err:52 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf apt armhf 1.8.2.3
          Could not open file /var/cache/apt/archives/partial/apt_1.8.2.3_armhf.deb - open (30: Read-only file system) [IP: 137.226.34.46 80]
        Err:54 http://archive.raspberrypi.org/debian buster/main armhf pi-bluetooth all 0.1.18
        Err:56 http://archive.raspberrypi.org/debian buster/main armhf python-rpi.gpio armhf 0.7.0-0.1~bpo10+4
        Err:55 http://mirror.de.leaseweb.net/raspbian/raspbian buster/main armhf apt-utils armhf 1.8.2.3
          Could not open file /var/cache/apt/archives/partial/apt-utils_1.8.2.3_armhf.deb - open (30: Read-only file system) [IP: 37.58.58.140 80]
        Err:57 http://archive.raspberrypi.org/debian buster/main armhf rpi.gpio-common armhf 0.7.0-0.1~bpo10+4
        Err:59 http://archive.raspberrypi.org/debian buster/main armhf raspberrypi-net-mods all 1.3.2
        Err:58 http://mirror.de.leaseweb.net/raspbian/raspbian buster/main armhf debconf-i18n all 1.5.71+deb10u1
          Could not open file /var/cache/apt/archives/partial/debconf-i18n_1.5.71+deb10u1_all.deb - open (30: Read-only file system) [IP: 2a00:c98:2030:a034::21 80]
        Err:60 http://archive.raspberrypi.org/debian buster/main armhf raspi-config all 20210212
        Err:61 http://archive.raspberrypi.org/debian buster/main armhf rpi-eeprom armhf 13.9-1~buster
        Err:62 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf python3-debconf all 1.5.71+deb10u1
          Could not open file /var/cache/apt/archives/partial/python3-debconf_1.5.71+deb10u1_all.deb - open (30: Read-only file system) [IP: 2a00:8a60:e012:a00::21 80]
        Err:63 http://archive.raspberrypi.org/debian buster/main armhf rpi-update all 20210618
        Err:64 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf debconf-utils all 1.5.71+deb10u1
          Could not open file /var/cache/apt/archives/partial/debconf-utils_1.5.71+deb10u1_all.deb - open (30: Read-only file system) [IP: 137.226.34.46 80]
        Err:65 http://ftp.gwdg.de/pub/linux/debian/raspbian/raspbian buster/main armhf debconf all 1.5.71+deb10u1
          Could not open file /var/cache/apt/archives/partial/debconf_1.5.71+deb10u1_all.deb - open (30: Read-only file system) [IP: 134.76.12.6 80]
        Err:66 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libgcrypt20 armhf 1.8.4-5+deb10u1
          Could not open file /var/cache/apt/archives/partial/libgcrypt20_1.8.4-5+deb10u1_armhf.deb - open (30: Read-only file system) [IP: 2a00:8a60:e012:a00::21 80]
        Err:67 http://ftp.gwdg.de/pub/linux/debian/raspbian/raspbian buster/main armhf ntfs-3g armhf 1:2017.3.23AR.3-3+deb10u1
          Could not open file /var/cache/apt/archives/partial/ntfs-3g_1%3a2017.3.23AR.3-3+deb10u1_armhf.deb - open (30: Read-only file system) [IP: 2001:638:60f:110::1:2 80]
        Err:68 http://mirror.de.leaseweb.net/raspbian/raspbian buster/main armhf libntfs-3g883 armhf 1:2017.3.23AR.3-3+deb10u1
          Could not open file /var/cache/apt/archives/partial/libntfs-3g883_1%3a2017.3.23AR.3-3+deb10u1_armhf.deb - open (30: Read-only file system) [IP: 37.58.58.140 80]
        Err:69 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libexpat1-dev armhf 2.2.6-2+deb10u2
          Could not open file /var/cache/apt/archives/partial/libexpat1-dev_2.2.6-2+deb10u2_armhf.deb - open (30: Read-only file system) [IP: 137.226.34.46 80]
        Err:70 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libexpat1 armhf 2.2.6-2+deb10u2
          Could not open file /var/cache/apt/archives/partial/libexpat1_2.2.6-2+deb10u2_armhf.deb - open (30: Read-only file system) [IP: 2a00:8a60:e012:a00::21 80]
        Err:71 http://mirror.de.leaseweb.net/raspbian/raspbian buster/main armhf libpython3.7 armhf 3.7.3-2+deb10u3
          Could not open file /var/cache/apt/archives/partial/libpython3.7_3.7.3-2+deb10u3_armhf.deb - open (30: Read-only file system) [IP: 2a00:c98:2030:a034::21 80]
        Err:72 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libssl1.1 armhf 1.1.1d-0+deb10u7
          Could not open file /var/cache/apt/archives/partial/libssl1.1_1.1.1d-0+deb10u7_armhf.deb - open (30: Read-only file system) [IP: 137.226.34.46 80]
        Err:73 http://mirror.de.leaseweb.net/raspbian/raspbian buster/main armhf python3.7 armhf 3.7.3-2+deb10u3
          Could not open file /var/cache/apt/archives/partial/python3.7_3.7.3-2+deb10u3_armhf.deb - open (30: Read-only file system) [IP: 37.58.58.140 80]
        Err:74 http://mirror.de.leaseweb.net/raspbian/raspbian buster/main armhf libpython3.7-stdlib armhf 3.7.3-2+deb10u3
          Could not open file /var/cache/apt/archives/partial/libpython3.7-stdlib_3.7.3-2+deb10u3_armhf.deb - open (30: Read-only file system) [IP: 2a00:c98:2030:a034::21 80]
        Err:75 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf python3.7-minimal armhf 3.7.3-2+deb10u3
          Could not open file /var/cache/apt/archives/partial/python3.7-minimal_3.7.3-2+deb10u3_armhf.deb - open (30: Read-only file system) [IP: 2a00:8a60:e012:a00::21 80]
        Err:76 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libpython3.7-minimal armhf 3.7.3-2+deb10u3
          Could not open file /var/cache/apt/archives/partial/libpython3.7-minimal_3.7.3-2+deb10u3_armhf.deb - open (30: Read-only file system) [IP: 137.226.34.46 80]
        Err:77 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libsqlite3-0 armhf 3.27.2-3+deb10u1
          Could not open file /var/cache/apt/archives/partial/libsqlite3-0_3.27.2-3+deb10u1_armhf.deb - open (30: Read-only file system) [IP: 2a00:8a60:e012:a00::21 80]
        Err:78 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libgssapi-krb5-2 armhf 1.17-3+deb10u3
        Err:79 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libkrb5-3 armhf 1.17-3+deb10u3
        Err:80 http://mirror1.hs-esslingen.de/pub/Mirrors/archive.raspbian.org/raspbian buster/main armhf libkrb5support0 armhf 1.17-3+deb10u3
        Err:81 http://mirror1.hs-esslingen.de/pub/Mirrors/archive.raspbian.org/raspbian buster/main armhf libk5crypto3 armhf 1.17-3+deb10u3
        Err:82 http://mirror1.hs-esslingen.de/pub/Mirrors/archive.raspbian.org/raspbian buster/main armhf libldap-common all 2.4.47+dfsg-3+rpi1+deb10u6
        Err:83 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libldap-2.4-2 armhf 2.4.47+dfsg-3+rpi1+deb10u6
        Err:84 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf tzdata all 2021a-0+deb10u3
        Err:85 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf groff-base armhf 1.22.4-3+deb10u1
        Err:86 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf iproute2 armhf 4.20.0-2+deb10u1
        Err:87 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf iputils-ping armhf 3:20180629-2+deb10u2
        Err:88 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libisc-export1100 armhf 1:9.11.5.P4+dfsg-5.1+deb10u6
        Err:89 http://mirror.netcologne.de/raspbian/raspbian buster/main armhf libdns-export1104 armhf 1:9.11.5.P4+dfsg-5.1+deb10u6
        Err:90 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf isc-dhcp-client armhf 4.4.1-2+deb10u1
        Err:91 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf isc-dhcp-common armhf 4.4.1-2+deb10u1
        pi@raspberrypi:~ $
        @tamtaras sagte in Admin nicht erreichbar:
        Das ist schon mal ein Zeichen dafür, dass dein Speichermedium 'nen Schuß hat.
        Von dem Update-Stau mal ganz abgesehen.
        dmesg -T | grep ext4
        T 2 Antworten Letzte Antwort
          tamtaras
          @thomas-braun said in Admin nicht erreichbar:
          pi@raspberrypi:~ $ dmesg -T | grep ext4
          [Tue Feb 22 07:32:58 2022] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_headphones=1  smsc95xx.macaddr=DC:A6:32:1A:9E:22 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=0d3c229f-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
          [Tue Feb 22 07:33:01 2022] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
          [Tue Feb 22 10:54:58 2022] EXT4-fs error (device mmcblk0p2) in ext4_reserve_inode_write:5946: Journal has aborted
          [Tue Feb 22 10:54:58 2022] EXT4-fs error (device mmcblk0p2): ext4_journal_check_start:61: Detected aborted journal
          [Tue Feb 22 10:54:59 2022] EXT4-fs error (device mmcblk0p2) in ext4_reserve_inode_write:5946: Journal has aborted
          [Tue Feb 22 10:54:59 2022] EXT4-fs error (device mmcblk0p2) in ext4_orphan_del:3067: Journal has aborted
          pi@raspberrypi:~ $
          Also letztes Backup auf eine neue Speicherkarte spielen? Und dann läuft das Update vielleicht?
            tamtaras
            @thomas-braun Meinst Du ich kann von dieser SD-Karte noch ein Backup machen? Wohl eher nicht...
            • T tamtaras
              @tamtaras
              Ich würde die Karte entsorgen.
                @tamtaras
                tamtaras
                schrieb am zuletzt editiert von tamtaras
                @thomas-braun Danke für Eure Hilfe - das dauert jetzt ne Weile...
                Nur damit ich hier keinen verärgere: Gebe ich Euch ein ' ^ ' als Dank für Eure Bemühungen? Oder nur für die Lösung des Threadproblems? Dankbar für die Analyse meiner Terminalschnipsel bin ich allemal!
                T Thomas BraunT 2 Antworten Letzte Antwort
                • T tamtaras
                  tamtaras
                  gelöscht
                  • T tamtaras
                    Ich trinke Pils. 🍺
                      Ich trinke Pils. 🍺
                      tamtaras
                      Ich habe nun ein Backup von Ende 2021 auf eine neue Karte aufgespielt und auf den neusten Stand gebracht. Nun läuft alles wieder. Ob der Fehler jetzt von der defekten SD-Karte kam, kann ich nicht mehr beurteilen. Ist aber wahrscheinlich, da das alles stabil lief und dann ohne jegliches Antasten des Systems diese Fehler auftraten. Vielen Dank für die Infos!
