  4. admin.0, influxdb, hosts error, sowie MieleCloud warn
    6.3k
16 Beiträge 3 Kommentatoren 404 Aufrufe 3 Beobachtet
  • W Offline
    W Offline
    woupi
    schrieb am zuletzt editiert von woupi
    Systemdata Bitte Ausfüllen
    Hardwaresystem: NUC
    Arbeitsspeicher: 16GB
    Festplattenart: SSD
    Betriebssystem: Proxmox 7 VM Ubuntu
    Node-Version: ---
    Nodejs-Version: v14.18.3
    NPM-Version: 6.14.15
    Installationsart: Skript
    Image genutzt: Nein
    Ort/Name der Imagedatei: Link
    Ich habe leider jede Menge errors und warns und hoffe , dass mir hier einer Helfen kann:
    Die Infludb habe ich in einem separat erstellten LXC Container mit Ubuntu erstellt.
    2022-02-20 14:41:51.203 - error: admin.0 (38718) error
    2022-02-20 05:07:11.242 - error: influxdb.0 (900) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2022-02-20 05:07:11.242 - error: influxdb.0 (900) unhandled promise rejection: hosts.some is not a function
    2022-02-20 05:07:11.243 - error: influxdb.0 (900) TypeError: hosts.some is not a function
    2022-02-20 05:07:58.028 - error: host.iobroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2022-02-20 05:07:58.028 - error: host.iobroker Caught by controller[1]: TypeError: hosts.some is not a function
    2022-02-20 05:07:58.028 - error: host.iobroker Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.influxdb/main.js:234:28
    2022-02-20 05:07:58.029 - error: host.iobroker Caught by controller[1]: at processTicksAndRejections (internal/process/task_queues.js:95:5)
    2022-02-20 05:07:58.029 - error: host.iobroker instance system.adapter.influxdb.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2022-02-20 09:46:46.532 - warn: mielecloudservice.0 (960) State "mielecloudservice.0.000150288351.signalFailure" has no existing object, this might lead to an error in future versions
    2022-02-20 09:46:46.658 - warn: mielecloudservice.0 (960) State "mielecloudservice.0.000150288351.signalInfo" has no existing object, this might lead to an error in future versions
    2022-02-20 09:46:46.660 - warn: mielecloudservice.0 (960) State "mielecloudservice.0.000150288351.targetTemperature_0" has no existing object, this might lead to an error in future versions
    2022-02-20 09:46:46.660 - warn: mielecloudservice.0 (960) State "mielecloudservice.0.000150288351.targetTemperature_1" has no existing object, this might lead to an error in future versions
    2022-02-20 09:46:46.660 - warn: mielecloudservice.0 (960) State "mielecloudservice.0.000150288351.targetTemperature_2" has no existing object, this might lead to an error in future versions
    Ich wusste nicht ob ich besser ein Thema erstelle oder für jedes Problem eins.
    Da aber die Fehler ja eventuell auch zusammen hängen habe ich jetzt erstmal eins erstellt.
    Falls das so nicht erwünscht ist, erstelle ich aber auch für jedes Problem gerne noch ein eigenes Thema.
    Vielen Dank
    NUC10i3, Proxmox, VM Ubuntu iobroker, lxc ubuntu influxdb, grafana, lxc ubuntu SAE, lxc ubuntu MotionEye, WP Panasonic Jeisha 5kW mit Heishamon, Shelly 2.5 und 2pm Rolladensteuerung, OpenWB Wallbox
    • wendy2702W Offline
      wendy2702W Offline
      @woupi Welche Version JS Controller?
      Sind die Fehler nach Updates gekommen?
      Zum Miele Problem. Instanz stoppen, alle Objekte der Instanz löschen, Instanz starten.
      W 1 Antwort Letzte Antwort
      • wendy2702W wendy2702
        W Offline
        W Offline
        woupi
        @wendy2702
        Danke erstmal für die Bereitschaft zu Helfen.
        Wo oder wie finde ich das heraus?
        Auf die schnelle habe ich gerade leider nichts gefunden, außer bei einem der allerdings einen Windows Rechner hatte.
        Das kann ich nicht sagen. Ich bin erst seit ein paar Wochen in der ganzen Geschichte drin und habe immer immer wieder Adapter installiert und auch wieder gelöscht. Updates habe ich offensichtlich nicht gemacht.
        Aufgefallen ist das alles erst, nachdem ich versucht habe influxdb 2.2.1 mit dem Adapter ans laufen zu bekommen.
        Den Adapter habe ich mitlerweile aber auch schon wieder gelöscht.
        Werde ich jetzt mal probieren.
        • W woupi
          @wendy2702
          wendy2702W Offline
          wendy2702W Offline
          @woupi
          Unter dem Reiter „Hosts“ oder mit
          iob v
          • W Offline
            W Offline
            woupi
            @wendy2702
            Da hatte ich nachgesehen, da steht nichts von JS Controller.
            iob v
            3.3.22
            PS.:
            Miele habe ich so gemacht und jetzt sind erstmal keine warn Hinweise mehr gekommen.
            • W woupi
              @wendy2702
              iob v
              3.3.22
              PS.:
              wendy2702W Offline
              wendy2702W Offline
              @woupi sagte in admin.0, influxdb, hosts error, sowie MieleCloud warn:
              Doch, steht da und ist Version 3.3.22
              Kannst du mal einen Screenshot der EInstellungen von der InfluxDB zeigen.
              Sieht für mich aber nach einem Problem in einem Query aus.
                W Offline
                W Offline
                woupi
                @wendy2702
                Sorry, war mir nicht bewusst iobroker der js-controller ist.
                Den lxc mit der influxdb habe ich gerade wieder gestartet, mir ist nur gerade nicht klar welche Einstellungen Du genau meinst, oder meintest Du eventuell den Adapter?
                • W woupi
                  @wendy2702
                  wendy2702W Offline
                  wendy2702W Offline
                  @woupi Ich meine die iobroker Instanz "influx".
                  Da mal das loggen auf "Debug" stellen
                  Oben auf experten modus stellen und dann in der Instanz auf den Stift hinter "info" und im drop down "debug" auswählen.
                    W Offline
                    W Offline
                    woupi
                    @wendy2702
                    2022-02-20 17:37:10.927 - error: host.iobroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                    2022-02-20 17:37:10.928 - error: host.iobroker Caught by controller[1]: TypeError: hosts.some is not a function
                    2022-02-20 17:37:10.928 - error: host.iobroker Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.influxdb/main.js:234:28
                    2022-02-20 17:37:10.928 - error: host.iobroker Caught by controller[1]: at processTicksAndRejections (internal/process/task_queues.js:95:5)
                    2022-02-20 17:37:10.928 - error: host.iobroker instance system.adapter.influxdb.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                    Ich hoffe, dass ist das was Du meinst.
                    Den Adapter hatte ich bereits wieder gelöscht und in jetzt nochmal neu installiert.
                      wendy2702W Offline
                      @woupi Deine InfluxDB ist Version 2.x ?
                        W Offline
                        W Offline
                        woupi
                        @wendy2702
                        Ja, 2.2.1, sorry habe ich vergessen zu schreiben.
                        • W woupi
                          @wendy2702
                          wendy2702W Offline
                          wendy2702W Offline
                          @woupi OK.
                          Dann habe ich aktuell leider keine Idee mehr.
                          Mach am besten auf Github beim Adapter ein Issue auf
                            @woupi OK.
                            W Offline
                            W Offline
                            woupi
                            @wendy2702
                            Danke Trotzdem.
                            AlphaCentauriA 1 Antwort Letzte Antwort
                            • W woupi
                              @wendy2702
                              Danke Trotzdem.
                              AlphaCentauriA Offline
                              AlphaCentauri
                              @woupi Hast du es einmal mit einem Downgrade des InfluxDB-Adapters von Version 2.xxx auf 1.xxx ausprobiert? Experteneinstellung aktivieren und eine neue Instanz des Adpaters nunmehr mit der letzten Version 1.xxx (das weitere Auswahlfeld mit Auswahlmöglichkeit der Adapterversion beachten) installieren. Vorab die InfluxDB mit Versionsnummer 1.xxx in einem weiteren LXC-Container installieren. Dann einmal prüfen, ob mit dem neuen Container und den neuen Adapter mit der Versionnummer 1.xxx dieser Fehler immer noch auftaucht. Falls noch nicht geschehen, muss du auch eine Portfreigabe des Port 8086 (tcp) vornehmen. Denn in Proxmox muss explizit jeder Port der genutzt werden soll, in der Firewall freigeschaltet werden. Ich empfehle dir hierzu das YoutubeVideo https://www.youtube.com/watch?v=YnqHbiEocVE. Viel Erfolg ! ☘
                              • AlphaCentauriA AlphaCentauri
                                W Offline
                                W Offline
                                woupi
                                @alphacentauri
                                Ich habe jetzt einen neuen LXC Container incl influxdb 1.6.7 aufgesetzt.
                                Anschließend den Adapter auf die Version 1.9.5 upgegradet.
                                Es läuft zur Zeit alles.
                                Keine Fehler mehr.
                                Firewall ist übrigens abgeschaltet.
                                Jetzt frage ich mich nur, ob ich es so lassen soll.
                                • W woupi
                                  @alphacentauri
                                  Keine Fehler mehr.
                                  W Offline
                                  W Offline
                                  woupi
                                  Seit gestern gibt es die Version 2.5.2 vom influxdb Adapter.
                                  Ich habe zum testen den Adapter installiert und die Datenbank wieder umgestellt.
                                  Die ganze Nacht keine Fehler.
                                  Also influxdb 2.1.1 und iobroker Adapter 2.5.2 laufen.
                                  Danke nochmal für die Unterstützung.
                                  mfg
