  4. Hilfe: Neuling - Fehlerhafte ioBroker Installation?
    5.7k
47 Beiträge 6 Kommentatoren 9.9k Aufrufe
    @southparkler:
    Controller "js-controller" : 0.17.2   , installed 0.16.2 [Updateable] `
    ok, dann wollen wir mal:
    cd /opt/iobroker
    sudo iobroker stop
    sudo npm cache clean
    sudo npm install iobroker.js-controller --production
    sudo iobroker start
    … und hoffen
      southparkler
      root@raspberrypi:/opt/iobroker# sudo npm install iobroker.js-controller --production
      > unix-dgram@0.2.3 install /opt/iobroker/node_modules/iobroker.js-controller/node_modules/winston-syslog/node_modules/unix-dgram
      > node-gyp rebuild
      make: Entering directory '/opt/iobroker/node_modules/iobroker.js-controller/node_modules/winston-syslog/node_modules/unix-dgram/build'
        CXX(target) Release/obj.target/unix_dgram/src/unix_dgram.o
        SOLINK_MODULE(target) Release/obj.target/unix_dgram.node
        COPY Release/unix_dgram.node
      make: Leaving directory '/opt/iobroker/node_modules/iobroker.js-controller/node_modules/winston-syslog/node_modules/unix-dgram/build'
      > ursa@0.9.4 install /opt/iobroker/node_modules/iobroker.js-controller/node_modules/greenlock/node_modules/rsa-compat/node_modules/ursa
      > node-gyp rebuild
      make: Entering directory '/opt/iobroker/node_modules/iobroker.js-controller/node_modules/greenlock/node_modules/rsa-compat/node_modules/ursa/build'
        CXX(target) Release/obj.target/ursaNative/src/ursaNative.o
        SOLINK_MODULE(target) Release/obj.target/ursaNative.node
        COPY Release/ursaNative.node
      make: Leaving directory '/opt/iobroker/node_modules/iobroker.js-controller/node_modules/greenlock/node_modules/rsa-compat/node_modules/ursa/build'
      > iobroker.js-controller@0.17.2 install /opt/iobroker/node_modules/iobroker.js-controller
      > node iobroker.js setup first
      iobroker.js-controller@0.17.2 node_modules/iobroker.js-controller
      ├── safe-replace@1.0.2
      ├── le-sni-auto@2.1.0
      ├── le-challenge-fs@2.0.8
      ├── pyconf@1.1.2
      ├── semver@5.3.0
      ├── mime@1.3.4
      ├── winston-daily-rotate-file@1.4.6
      ├── daemonize2@0.4.2
      ├── ncp@2.0.0
      ├── node.extend@1.1.6 (is@3.2.1)
      ├── redis@2.7.1 (double-ended-queue@2.1.0-0, redis-commands@1.3.1, redis-parser@2.6.0)
      ├── node-schedule@1.2.1 (long-timeout@0.1.1, sorted-array-functions@1.0.0, cron-parser@1.1.0)
      ├── bluebird@3.5.0
      ├── mkdirp@0.5.1 (minimist@0.0.8)
      ├── winston@2.3.1 (cycle@1.0.3, stack-trace@0.0.9, isstream@0.1.2, eyes@0.1.8, async@1.0.0, colors@1.0.3)
      ├── socket.io@1.7.3 (object-assign@4.1.0, socket.io-adapter@0.5.0, has-binary@0.1.7, debug@2.3.3, socket.io-parser@2.3.1, engine.io@1.8.3)
      ├── socket.io-client@1.7.3 (to-array@0.1.4, component-emitter@1.2.1, indexof@0.0.1, object-component@0.0.3, component-bind@1.0.0, backo2@1.0.2, has-binary@0.1.7, debug@2.3.3, socket.io-parser@2.3.1, parseuri@0.0.5, engine.io-client@1.8.3)
      ├── winston-syslog@1.2.6 (cycle@1.0.3, glossy@0.1.7, unix-dgram@0.2.3)
      ├── prompt@1.0.0 (revalidator@0.1.8, pkginfo@0.4.0, colors@1.1.2, read@1.0.7, winston@2.1.1, utile@0.3.0)
      ├── yargs@6.6.0 (get-caller-file@1.0.2, decamelize@1.2.0, y18n@3.2.1, camelcase@3.0.0, which-module@1.0.0, set-blocking@2.0.0, yargs-parser@4.2.1, require-main-filename@1.0.1, require-directory@2.1.1, cliui@3.2.0, os-locale@1.4.0, string-width@1.0.2, read-pkg-up@1.0.1)
      ├── request@2.81.0 (aws-sign2@0.6.0, tunnel-agent@0.6.0, oauth-sign@0.8.2, forever-agent@0.6.1, is-typedarray@1.0.0, caseless@0.12.0, stringstream@0.0.5, safe-buffer@5.0.1, aws4@1.6.0, isstream@0.1.2, json-stringify-safe@5.0.1, extend@3.0.0, performance-now@0.2.0, uuid@3.0.1, qs@6.4.0, combined-stream@1.0.5, mime-types@2.1.15, tough-cookie@2.3.2, form-data@2.1.4, hawk@3.1.3, http-signature@1.1.1, har-validator@4.2.1)
      ├── tar.gz@1.0.5 (commander@2.9.0, bluebird@2.11.0, tar@2.2.1, fstream@1.0.11, mout@0.11.1)
      ├── greenlock@2.1.14 (le-store-certbot@2.0.5, homedir@0.6.0, asn1js@1.2.12, le-acme-core@2.0.9, pkijs@1.3.33, certpem@1.0.1, localhost.daplie.me-certificates@1.3.0, le-challenge-sni@2.0.1, rsa-compat@1.2.7)
      ├── jszip@3.1.3 (es6-promise@3.0.2, lie@3.1.1, pako@1.0.5, readable-stream@2.0.6, core-js@2.3.0)
      └── npm@2.15.12
      root@raspberrypi:/opt/iobroker# sudo iobroker start
      Starting iobroker controller daemon...
      iobroker controller daemon failed to start:  2
      Error: 2
      Jetzt kommt beim Starten "Error 2"
      iBroker läuft auf Raspi 3B über Gbit Lan
      Geräte:
      Licht: Hue Lampen mit Bridge, Osram Smart Plug, Tradfri Lampen über Hue, Yeelight Lampen
      Sensoren: Xiaomi Aqara Sensoren (Zigbee Stick)
      Heizung: Fritz!D…
        southparkler
        Nach reboot komm ich auf die Oberfläche von iobroker - aber keine Änderung.
        Geräte:
        Heizung: Fritz!D…
          letzte Idee:
          cd /opt/iobroker
          sudo iobroker stop admin
          sudo iobroker upload admin
          sudo iobroker start admin
          Und du hast wirklich den Ordner /opt/iobroker vollständig gelöscht gehabt?
            southparkler
            Das hatte ich in Putty eingegeben:
            rm -r /opt/iobroker
            Geräte:
            Heizung: Fritz!D…
              hast du es danach kontrolliert?
              läuft es nach dem upload?
              Welche Versionen von nodejs, npm und welches Betriebssystem hast du eigentlich?
              Sonst würde ich dir nur empfehlen eine neue Karte zu nehmen und neu installieren.
                southparkler
                Läuft nicht, alles unverändert.
                Nein, hab es nach dem Löschen nicht kontrolliert. Wusste nicht wie. Geb halt alles nach Anleitung in Putty ein.
                Hab alles inkl. Links von dieser Anleitung: http://www.iobroker.net/docu/?page_id=5106&lang=de
                Hab mich für diese jessie Version entschieden.
                RASPBIAN JESSIE WITH PIXEL
                Image with PIXEL desktop based on Debian Jessie
                Version:April 2017
                Release date:2017-04-10
                Kernel version:4.4
                Ansonsten Nagelneu: Raspi 3 + Samsung Evo+ 32GB
                Geräte:
                Heizung: Fritz!D…
                  @southparkler:
                  Release date:2017-04-10 `
                  Die kenne ich noch nicht. Ist ja flammneu. Ob es daran liegt ???
                  @southparkler:
                  Hab alles inkl. Links von dieser Anleitung: http://www.iobroker.net/docu/?page_id=5106&lang=de `
                  ist auch ok.
                  Ich weiß nur nicht ob und wenn ja welche node-version bereits in dem Raspbian enthalten ist.
                  Wenn du es nochmal neu versuchen willst, probiere es bitte mal mit Raspbian light, oder brauchst du einen Desktop?
                  Der frisst natürlich auch noch Ressourcen.
                  Ich habe wirklich keine Ahnung, außer, dass im Moment etwas mit dem Repo nicht stimmen könnte, weil Bluefox gerade dran arbeitet.
                  Dazu passt aber nicht dein Ergebnis bei iobroker update.
                  Sorry - bin im Moment rat- und hilflos
                    southparkler
                    Keine Ahnung woran es liegt. Probier es heute Nacht nochmal mit der Light und meld mich wieder.
                    Desktop brauch ich momentan nicht, hab gedacht lueber mal mit, man weiß ja nie ;)
                    Trotzdem schon mal vielen Dank.
                    Geräte:
                    Heizung: Fritz!D…
                      southparkler
                      So, ich bin zurück - leider mit dem selben Ergebnis.
                      Diesmal mit:
                      RASPBIAN JESSIE LITE
                      Minimal image based on Debian Jessie
                      Version:April 2017
                      Kernel version:4.4
                      root@raspberrypi:~# node -v
                      v4.8.2
                      root@raspberrypi:~# sudo mkdir /opt/iobroker
                      root@raspberrypi:~# sudo chmod 777 /opt/iobroker
                      root@raspberrypi:~# cd /opt/iobroker
                      root@raspberrypi:/opt/iobroker# sudo npm install iobroker --unsafe-perm
                      > iobroker@0.9.0 install /opt/iobroker/node_modules/iobroker
                      > node lib/setup.js
                      npm install iobroker.js-controller --production --prefix /opt/iobroker
                      npm install iobroker.admin --production --prefix /opt/iobroker
                      npm install iobroker.discovery --production --prefix /opt/iobroker
                      node-pre-gyp ERR! Tried to download(404): https://github.com/EmergingTechnologyAdvisors/node-serialport/releases/download/4.0.7/serialport-v4.0.7-node-v46-linux-arm.tar.gz
                      node-pre-gyp ERR! Pre-built binaries not found for serialport@4.0.7 and node@4.8.2 (node-v46 ABI) (falling back to source compile with node-gyp)
                      Write "./iobroker start" to start the ioBroker
                      : Datei oder Verzeichnis nicht gefunden
                      Auto-start was enabled. Write "update-rc.d -f iobroker.sh remove" to disable auto-start
                      iobroker is started. Go to "http://ip-addr:8081" to open the admin UI.
                      iobroker@0.9.0 node_modules/iobroker
                      └── yargs@7.1.0 (get-caller-file@1.0.2, decamelize@1.2.0, y18n@3.2.1, camelcase@3.0.0, which-module@1.0.0, set-blocking@2.0.0, yargs-parser@5.0.0, require-main-filename@1.0.1, require-directory@2.1.1, cliui@3.2.0, string-width@1.0.2, os-locale@1.4.0, read-pkg-up@1.0.1)
                      root@raspberrypi:/opt/iobroker# reboot
                      Geräte:
                      Heizung: Fritz!D…
                        Ich verstehe es nicht.
                        Die Installation läuft augenscheinlich problemlos durch, die Adapter waren zumindest in deiner letzten Installation komplett installiert. Allerdings wunderte mich, dass unmittelbar nach einer Neuinstallation der js-controller als updateable geführt wurde und nicht direkt die neueste Version installiert wurde.
                        Vielleicht fällt @Bluefox noch was ein.
                        Wenn nicht mache ich das morgen mal mit einem Pi 3 6nd der neuesten Version von Raspbian.
                          southparkler
                          @Homoran:
                          @southparkler:
                          cd /opt/iobroker
                          sudo iobroker stop
                          sudo iobroker start
                          … und hoffen
                          Rainer `
                          Das hab ich jetzt auch nochmals durch - hilft aber auch nicht weiter.
                          Hier mal der komplette Log nach dem root Zugang und sauberer Jessi light Installation bis jetzt, vielleicht mach ich ja doch irgendwo was falsch…
                          login as: root
                          root@192.168.2.164's password:
                          permitted by applicable law.
                          root@raspberrypi:~# sudo apt-get update && sudo apt-get upgrade
                          OK   http://archive.raspberrypi.org jessie InRelease
                          OK   http://mirrordirector.raspbian.org jessie InRelease
                          OK   http://archive.raspberrypi.org jessie/main armhf Packages
                          OK   http://mirrordirector.raspbian.org jessie/main armhf Packages
                          OK   http://mirrordirector.raspbian.org jessie/contrib armhf Packages
                          OK   http://archive.raspberrypi.org jessie/ui armhf Packages
                          OK   http://mirrordirector.raspbian.org jessie/non-free armhf Packages
                          OK   http://mirrordirector.raspbian.org jessie/rpi armhf Packages
                          Ign http://archive.raspberrypi.org jessie/main Translation-de_DE
                          Ign http://mirrordirector.raspbian.org jessie/contrib Translation-de_DE
                          Ign http://mirrordirector.raspbian.org jessie/contrib Translation-en
                          Ign http://mirrordirector.raspbian.org jessie/main Translation-de_DE
                          Ign http://archive.raspberrypi.org jessie/main Translation-en
                          Ign http://mirrordirector.raspbian.org jessie/main Translation-en
                          Ign http://archive.raspberrypi.org jessie/ui Translation-de_DE
                          Ign http://mirrordirector.raspbian.org jessie/non-free Translation-de_DE
                          Ign http://mirrordirector.raspbian.org jessie/non-free Translation-en
                          Ign http://archive.raspberrypi.org jessie/ui Translation-en
                          Ign http://mirrordirector.raspbian.org jessie/rpi Translation-de_DE
                          Ign http://mirrordirector.raspbian.org jessie/rpi Translation-en
                          Paketaktualisierung (Upgrade) wird berechnet... Fertig
                          0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                          root@raspberrypi:~# curl -sL https://deb.nodesource.com/setup_4.x | sudo -E bash -
                          ## Installing the NodeSource Node.js v4.x LTS Argon repo...
                          ## Populating apt-get cache...
                          + apt-get update
                          ## Confirming "jessie" is supported...
                          + curl -sLf -o /dev/null 'https://deb.nodesource.com/node_4.x/dists/jessie/Release'
                          ## Adding the NodeSource signing key to your keyring...
                          + curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | apt-key add -
                          OK
                          ## Creating apt sources list file for the NodeSource Node.js v4.x LTS Argon repo...
                          + echo 'deb https://deb.nodesource.com/node_4.x jessie main' > /etc/apt/sources.list.d/nodesource.list
                          + echo 'deb-src https://deb.nodesource.com/node_4.x jessie main' >> /etc/apt/sources.list.d/nodesource.list
                          ## Running `apt-get update` for you...
                          + apt-get update
                          Holen: 1 https://deb.nodesource.com jessie InRelease [4.634 B]
                          Holen: 2 https://deb.nodesource.com jessie/main Sources [763 B]
                          Holen: 3 https://deb.nodesource.com jessie/main armhf Packages [967 B]
                          Holen: 4 https://deb.nodesource.com jessie/main Translation-de_DE [162 B]
                          Holen: 5 https://deb.nodesource.com jessie/main Translation-de [162 B]
                          Holen: 6 https://deb.nodesource.com jessie/main Translation-en [162 B]
                          Holen: 7 https://deb.nodesource.com jessie/main Translation-de_DE [162 B]
                          Holen: 8 https://deb.nodesource.com jessie/main Translation-de [162 B]
                          Holen: 9 https://deb.nodesource.com jessie/main Translation-en [162 B]
                          Holen: 10 https://deb.nodesource.com jessie/main Translation-de_DE [162 B]
                          Holen: 11 https://deb.nodesource.com jessie/main Translation-de [162 B]
                          Holen: 12 https://deb.nodesource.com jessie/main Translation-en [162 B]
                          Holen: 13 https://deb.nodesource.com jessie/main Translation-de_DE [162 B]
                          Holen: 14 https://deb.nodesource.com jessie/main Translation-de [162 B]
                          Holen: 15 https://deb.nodesource.com jessie/main Translation-en [162 B]
                          Holen: 16 https://deb.nodesource.com jessie/main Translation-de_DE [162 B]
                          Ign https://deb.nodesource.com jessie/main Translation-de_DE
                          Holen: 17 https://deb.nodesource.com jessie/main Translation-de [162 B]
                          Holen: 18 https://deb.nodesource.com jessie/main Translation-en [162 B]
                          Ign https://deb.nodesource.com jessie/main Translation-en
                          Es wurden 6.364 B in 6 s geholt (955 B/s).
                          ## Run `apt-get install nodejs` (as root) to install Node.js v4.x LTS Argon and npm
                          root@raspberrypi:~# sudo apt-get insall -y build essential python nodejs
                          E: Befehlszeilenoption »y« [aus -y] ist nicht bekannt.
                          root@raspberrypi:~# sudo apt-get install -y build essential python nodejs
                          E: Paket build kann nicht gefunden werden.
                          E: Paket essential kann nicht gefunden werden.
                          root@raspberrypi:~# sudo apt-get install -y build-essential python nodejs
                          build-essential ist schon die neueste Version.
                          python ist schon die neueste Version.
                          Die folgenden zusätzlichen Pakete werden installiert:
                            rlwrap
                          Die folgenden NEUEN Pakete werden installiert:
                            nodejs rlwrap
                          0 aktualisiert, 2 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                          Es müssen 7.976 kB an Archiven heruntergeladen werden.
                          Nach dieser Operation werden 38,5 MB Plattenplatz zusätzlich benutzt.
                          Holen: 1 https://deb.nodesource.com/node_4.x/ jessie/main nodejs armhf 4.8.2-1nodesource1~jessie1 [7.906 kB]
                          Holen: 2 http://mirrordirector.raspbian.org/raspbian/ jessie/main rlwrap armhf 0.41-1 [70,3 kB]
                          Es wurden 7.976 kB in 2 s geholt (2.968 kB/s).
                          Vormals nicht ausgewähltes Paket rlwrap wird gewählt.
                          (Lese Datenbank ... 31821 Dateien und Verzeichnisse sind derzeit installiert.)
                          Vorbereitung zum Entpacken von .../rlwrap_0.41-1_armhf.deb ...
                          Entpacken von rlwrap (0.41-1) ...
                          Vormals nicht ausgewähltes Paket nodejs wird gewählt.
                          Vorbereitung zum Entpacken von .../nodejs_4.8.2-1nodesource1~jessie1_armhf.deb ...
                          Entpacken von nodejs (4.8.2-1nodesource1~jessie1) ...
                          Trigger für man-db (2.7.0.2-5) werden verarbeitet ...
                          rlwrap (0.41-1) wird eingerichtet ...
                          update-alternatives: /usr/bin/rlwrap wird verwendet, um /usr/bin/readline-editor (readline-editor) im automatischen Modus bereitzustellen
                          nodejs (4.8.2-1nodesource1~jessie1) wird eingerichtet ...
                          root@raspberrypi:~# reboot
                          Broadcast message from root@raspberrypi on pts/0 (So 2017-04-16 22:15:18 CEST):
                          The system is going down for reboot NOW!
                          root@raspberrypi:~#
                          login as: root
                          Last login: Sun Apr 16 22:02:33 2017 from lenovonotebok.fritz.box
                          v4.8.2
                          > node lib/setup.js
                          Broadcast message from root@raspberrypi on pts/0 (So 2017-04-16 22:23:09 CEST):
                          login as:
                          login as: root
                          Last login: Sun Apr 16 22:16:33 2017 from lenovonotebok.fritz.box
                          root@raspberrypi:~# ^C
                          root@raspberrypi:/opt/iobroker# sudo iobroker stop
                          Stopping iobroker controller daemon...
                          iobroker controller daemon stopped.
                          Exit code for "killall.sh": 0
                          root@raspberrypi:/opt/iobroker# sudo npm cache clean
                          > node-gyp rebuild
                          > node-gyp rebuild
                          ├── pyconf@1.1.2
                          ├── semver@5.3.0
                          ├── mime@1.3.4
                          ├── ncp@2.0.0
                          ├── bluebird@3.5.0
                          ├── winston@2.3.1 (cycle@1.0.3, stack-trace@0.0.9, eyes@0.1.8, isstream@0.1.2, async@1.0.0, colors@1.0.3)
                          ├── yargs@6.6.0 (get-caller-file@1.0.2, decamelize@1.2.0, y18n@3.2.1, camelcase@3.0.0, which-module@1.0.0, set-blocking@2.0.0, yargs-parser@4.2.1, require-main-filename@1.0.1, require-directory@2.1.1, os-locale@1.4.0, string-width@1.0.2, cliui@3.2.0, read-pkg-up@1.0.1)
                          ├── request@2.81.0 (aws-sign2@0.6.0, tunnel-agent@0.6.0, oauth-sign@0.8.2, forever-agent@0.6.1, caseless@0.12.0, is-typedarray@1.0.0, stringstream@0.0.5, safe-buffer@5.0.1, aws4@1.6.0, isstream@0.1.2, json-stringify-safe@5.0.1, extend@3.0.0, performance-now@0.2.0, uuid@3.0.1, qs@6.4.0, combined-stream@1.0.5, mime-types@2.1.15, tough-cookie@2.3.2, form-data@2.1.4, hawk@3.1.3, http-signature@1.1.1, har-validator@4.2.1)
                          └── npm@2.15.12
                          root@raspberrypi:/opt/iobroker# sudo iobroker start admin
                          Broadcast message from root@raspberrypi on pts/0 (So 2017-04-16 22:45:20 CEST):
                          login as: root
                          Last login: Sun Apr 16 22:25:53 2017 from lenovonotebok.fritz.box
                          root@raspberrypi:~#
                          Geräte:
                          Heizung: Fritz!D…
                            southparkler
                            …oder komm ich irgendwie Jessie Version unter der es bei dir läuft?
                            So der Akt ist die Installation ja auch nicht. Außerdem ist es Übung für mich ;)
                            Edit: Ein Error ist auch noch im Log: vis.0 2017-04-16 22:53:19.281 error No license found for vis. Please get one on https://iobroker.net !
                            Geräte:
                            Heizung: Fritz!D…
                              Du kannst ein fertiges raspbian image incl. Iobroker hier herunterladen, auch mit pixel ;)
                              http://www.iobroker.net/?page_id=2563&lang=de
                              Beim notwendigen update dann bitte zuerst per Konsole den controller updaten
                              Da du eh als root arbeitest:
                              cd /opt/iobroker
                              iobroker stop
                              iobroker update
                              iobroker upgrade self
                              iobroker start
                              Dann den admin und dann erst alle anderen Adapter per Konsole oder Webif updaten.
                                southparkler
                                Siehe da - schon sieht die Sache ganz anders aus :D
                                Vielen Dank.
                                Wie genau mach ich jetzt ein Update vom Admin und dem Rest per Console?
                                Edit: Der Admin ist aktuell - den Rest mach ich per Update Button.
                                Edit2: Eine wichtige Frage vielleicht noch. Wie mach ich jetzt am Besten eine komplette Sicherung - vielleicht auch automatisch in Intervallen (wenn das geht), am Besten auf mein NAS.
                                Geräte:
                                Heizung: Fritz!D…
                                • kmxakK Offline
                                  kmxakK Offline
                                  kmxak
                                  http://www.iobroker.net/docu/?page_id=3074&lang=de
                                  Gruß Alex
                                    Guten Morgen,
                                    @southparkler:
                                    Siehe da - schon sieht die Sache ganz anders aus `
                                    Jetzt macht mich das erst recht neugierig!
                                    Mal sehen, ob ich heute mal das neue raspbian teste.
                                      southparkler
                                      Kann ja fast nur an der neuen Version liegen :D
                                      Hab jetzt Gestern noch bissle rumprobiert. Echo zeigt die eingestellten Test eigentlich richtig an und gibt auch die Bestätigung mit "Ok" zurück - leider passiert nur nichts.
                                      Geräte:
                                      Heizung: Fritz!D…
                                        Meine Installation läuft gerade ;-)
                                        Hast du mit deiner "alten" = 2017-04-10 Version Fehler in der Browserkonsole (F12)?
                                          southparkler
                                          Nein, das ist aktuell mit der Neuen.
                                          Geräte:
                                          Heizung: Fritz!D…
