  4. energymanager
    6.0k
energymanager
30 Beiträge 3 Kommentatoren 1.5k Aufrufe 2 Beobachtet
  • wendy2702W wendy2702
    @mcbirne Kannst du die Instanz mal löschen, neu installieren und das log davon hier Posten ?
    mcBirneM Offline
    mcBirneM Offline
    mcBirne
    @wendy2702
    dass ist der Log der Installation
    $ iobroker add energymanager auto --host buanet-iobroker1
    upload [2] energymanager.admin /opt/iobroker/node_modules/iobroker.energymanager/admin/words.js words.js application/javascript
    upload [1] energymanager.admin /opt/iobroker/node_modules/iobroker.energymanager/admin/index_m.html index_m.html text/html
    upload [0] energymanager.admin /opt/iobroker/node_modules/iobroker.energymanager/admin/energymanager.png energymanager.png image/png
    host.buanet-iobroker1 create instance energymanager
    host.buanet-iobroker1 object system.adapter.energymanager.0.logLevel created
    host.buanet-iobroker1 object system.adapter.energymanager.0.sigKill created
    host.buanet-iobroker1 object system.adapter.energymanager.0.eventLoopLag created
    host.buanet-iobroker1 object system.adapter.energymanager.0.outputCount created
    host.buanet-iobroker1 object system.adapter.energymanager.0.inputCount created
    host.buanet-iobroker1 object system.adapter.energymanager.0.uptime created
    host.buanet-iobroker1 object system.adapter.energymanager.0.memRss created
    host.buanet-iobroker1 object system.adapter.energymanager.0.memHeapTotal created
    host.buanet-iobroker1 object system.adapter.energymanager.0.memHeapUsed created
    host.buanet-iobroker1 object system.adapter.energymanager.0.cputime created
    host.buanet-iobroker1 object system.adapter.energymanager.0.cpu created
    host.buanet-iobroker1 object system.adapter.energymanager.0.compactMode created
    host.buanet-iobroker1 object system.adapter.energymanager.0.connected created
    host.buanet-iobroker1 object system.adapter.energymanager.0.alive created
    host.buanet-iobroker1 object system.adapter.energymanager.0 created
    Process exited with code 0
    MOD Edit: Log in Code Tags gesetzt
    • mcBirneM mcBirne
      @wendy2702
      wendy2702W Online
      wendy2702W Online
      @mcbirne Sieht sauber aus.
      Wenn du jetzt startest sieht das log genauso aus?
      Sehe ich das richtig das iob in einem Container läuft?
      mcBirneM 1 Antwort Letzte Antwort
        mcBirneM Offline
        mcBirneM Offline
        mcBirne
        @wendy2702
        ja, wenn ich jetzt die IP adresse und das Passwort eingebe kommt die gleiche error Meldung.
        IOB läuft in einem Docker Container
        mcBirneM wendy2702W 2 Antworten Letzte Antwort
        • mcBirneM mcBirne
          @wendy2702
          mcBirneM Offline
          mcBirneM Offline
          mcBirne
          @mcbirne aktuell vermute ich, dass der Adapter nicht kompatibel ist, da ich vermutlich eine neue Solarwatt Version habe. Die Fehlermeldung kommt, wenn der Login versucht wird. Daher denke ich, dass der Login nicht klappt
          • mcBirneM mcBirne
            @wendy2702
            wendy2702W Online
            wendy2702W Online
            @mcbirne Ich denke da musst du bestimmt einen bestimmte(n) IP/Port freischalten damit der Adapter aus dem Container telefonieren darf.
            Was kommt wenn du im Browser diesen Link eingibts:
            http://"IP Adresse deines Gerätes"/rest/kiwigrid/wizard/devices
              mcBirneM Offline
              mcBirneM Offline
              mcBirne
              @wendy2702 said in energymanager:
              es kommt die Meldung, dass die Seite nicht erreichbar ist
              • mcBirneM mcBirne
                wendy2702W Online
                wendy2702W Online
                @mcbirne Du hast aber deine IP Eingetragen, oder?
                  mcBirneM Offline
                  mcBirneM Offline
                  mcBirne
                  @wendy2702
                  {"error":{"message":"HTTP 404 Not Found","http-code":404,"exception":{"class":"javax.ws.rs.NotFoundException","message":"HTTP 404 Not Found","localized-message":"HTTP 404 Not Found"}}}
                  • mcBirneM mcBirne
                    @wendy2702
                    wendy2702W Online
                    wendy2702W Online
                    @mcbirne Hast du deine IP vom EnergyManager in den LINK eingetragen ???
                      mcBirneM Offline
                      mcBirneM Offline
                      mcBirne
                      @wendy2702 ja
                      HomoranH mcBirneM 2 Antworten Letzte Antwort
                      • mcBirneM mcBirne
                        @wendy2702 ja
                        @mcbirne und ohne Anführungszeichen?
                        • mcBirneM mcBirne
                          @wendy2702 ja
                          mcBirneM Offline
                          mcBirneM Offline
                          mcBirne
                          @mcbirne
                          wenn ich http://192.168.178.124/rest eingebe erhalte ich
                          {"version":"3","links":[{"type":"uuid","url":"http://192.168.178.124/rest/uuid"},{"type":"audio","url":"http://192.168.178.124/rest/audio"},{"type":"bindings","url":"http://192.168.178.124/rest/bindings"},{"type":"channel-types","url":"http://192.168.178.124/rest/channel-types"},{"type":"config-descriptions","url":"http://192.168.178.124/rest/config-descriptions"},{"type":"discovery","url":"http://192.168.178.124/rest/discovery"},{"type":"inbox","url":"http://192.168.178.124/rest/inbox"},{"type":"extensions","url":"http://192.168.178.124/rest/extensions"},{"type":"items","url":"http://192.168.178.124/rest/items"},{"type":"links","url":"http://192.168.178.124/rest/links"},{"type":"persistence","url":"http://192.168.178.124/rest/persistence"},{"type":"profile-types","url":"http://192.168.178.124/rest/profile-types"},{"type":"services","url":"http://192.168.178.124/rest/services"},{"type":"things","url":"http://192.168.178.124/rest/things"},{"type":"thing-types","url":"http://192.168.178.124/rest/thing-types"},{"type":"sitemaps","url":"http://192.168.178.124/rest/sitemaps"},{"type":"voice","url":"http://192.168.178.124/rest/voice"},{"type":"iconsets","url":"http://192.168.178.124/rest/iconsets"}]}
                            mcBirneM Offline
                            mcBirneM Offline
                            mcBirne
                            @homoran ja, ich habe http://192.168.178.124/rest/kiwigrid/wizard/devices eingegeben
                            • wendy2702W Online
                              wendy2702W Online
                              Kannst du die IP per Ping erreichen?
                              Mal angenommen der Energy Manager hat eine Web Oberfläche, wie lautet der Link um diese zu erreichen?
                                mcBirneM Offline
                                mcBirneM Offline
                                mcBirne
                                @wendy2702 das ist die Weboberfläche http://192.168.178.124/dashboard
                                  mcBirneM Offline
                                  mcBirneM Offline
                                  mcBirne
                                  ich kann die IP auch mit dem Ping Adapter vom IObroker pingen
                                  • mcBirneM mcBirne
                                    @mcbirne sagte in energymanager:
                                    das passt ja zur Erreichbarkeit des dashboards.
                                    Dann hat dein Manager nicht den selben Pfad zur rest-Api oder der heisst anders.
                                    Gab es bei mir auch irgendwo
                                      mcBirneM Offline
                                      mcBirneM Offline
                                      mcBirne
                                      schade, dann habe ich wohl keine Möglichkeit an die Daten zu kommen
                                      • mcBirneM mcBirne
                                        @mcbirne
                                        wendy2702W Online
                                        wendy2702W Online
                                        @mcbirne
                                        Klick dich doch mal durch die einzelnen Verzeichnisse ob da was brauchbares drin ist.
                                        • mcBirneM Offline
                                          mcBirneM Offline
                                          mcBirne
                                          @wendy2702
                                          Leider ist dort nirgends eine Liste mit Werten oder so.
