  4. energymanager
    6.0k
energymanager
30 Beiträge 3 Kommentatoren 1.5k Aufrufe 2 Beobachtet
  • wendy2702W wendy2702
    @mcbirne Kommt nach dem error "null" nichts mehr?
    Wenn ja bitte komplett und nicht als Screenshot sondern als Text in Code Tags </> posten
    mcBirneM Offline
    mcBirneM Offline
    mcBirne
    @wendy2702
    nein, nach dem error kommt nichts mehr
    • mcBirneM mcBirne
      @wendy2702
      wendy2702W Online
      wendy2702W Online
      @mcbirne Kannst du die Instanz mal löschen, neu installieren und das log davon hier Posten ?
      mcBirneM 1 Antwort Letzte Antwort
        mcBirneM Offline
        mcBirneM Offline
        mcBirne
        @wendy2702
        dass ist der Log der Installation
        $ iobroker add energymanager auto --host buanet-iobroker1
        upload [2] energymanager.admin /opt/iobroker/node_modules/iobroker.energymanager/admin/words.js words.js application/javascript
        upload [1] energymanager.admin /opt/iobroker/node_modules/iobroker.energymanager/admin/index_m.html index_m.html text/html
        upload [0] energymanager.admin /opt/iobroker/node_modules/iobroker.energymanager/admin/energymanager.png energymanager.png image/png
        host.buanet-iobroker1 create instance energymanager
        host.buanet-iobroker1 object system.adapter.energymanager.0.logLevel created
        host.buanet-iobroker1 object system.adapter.energymanager.0.sigKill created
        host.buanet-iobroker1 object system.adapter.energymanager.0.eventLoopLag created
        host.buanet-iobroker1 object system.adapter.energymanager.0.outputCount created
        host.buanet-iobroker1 object system.adapter.energymanager.0.inputCount created
        host.buanet-iobroker1 object system.adapter.energymanager.0.uptime created
        host.buanet-iobroker1 object system.adapter.energymanager.0.memRss created
        host.buanet-iobroker1 object system.adapter.energymanager.0.memHeapTotal created
        host.buanet-iobroker1 object system.adapter.energymanager.0.memHeapUsed created
        host.buanet-iobroker1 object system.adapter.energymanager.0.cputime created
        host.buanet-iobroker1 object system.adapter.energymanager.0.cpu created
        host.buanet-iobroker1 object system.adapter.energymanager.0.compactMode created
        host.buanet-iobroker1 object system.adapter.energymanager.0.connected created
        host.buanet-iobroker1 object system.adapter.energymanager.0.alive created
        host.buanet-iobroker1 object system.adapter.energymanager.0 created
        Process exited with code 0
        MOD Edit: Log in Code Tags gesetzt
        • mcBirneM mcBirne
          @wendy2702
          wendy2702W Online
          wendy2702W Online
          @mcbirne Sieht sauber aus.
          Wenn du jetzt startest sieht das log genauso aus?
          Sehe ich das richtig das iob in einem Container läuft?
            mcBirneM Offline
            mcBirneM Offline
            mcBirne
            @wendy2702
            ja, wenn ich jetzt die IP adresse und das Passwort eingebe kommt die gleiche error Meldung.
            IOB läuft in einem Docker Container
            mcBirneM wendy2702W 2 Antworten Letzte Antwort
            • mcBirneM mcBirne
              @wendy2702
              mcBirneM Offline
              mcBirneM Offline
              mcBirne
              @mcbirne aktuell vermute ich, dass der Adapter nicht kompatibel ist, da ich vermutlich eine neue Solarwatt Version habe. Die Fehlermeldung kommt, wenn der Login versucht wird. Daher denke ich, dass der Login nicht klappt
              • mcBirneM mcBirne
                @wendy2702
                wendy2702W Online
                wendy2702W Online
                @mcbirne Ich denke da musst du bestimmt einen bestimmte(n) IP/Port freischalten damit der Adapter aus dem Container telefonieren darf.
                Was kommt wenn du im Browser diesen Link eingibts:
                http://"IP Adresse deines Gerätes"/rest/kiwigrid/wizard/devices
                  mcBirneM Offline
                  mcBirneM Offline
                  mcBirne
                  @wendy2702 said in energymanager:
                  es kommt die Meldung, dass die Seite nicht erreichbar ist
                  • mcBirneM mcBirne
                    wendy2702W Online
                    wendy2702W Online
                    @mcbirne Du hast aber deine IP Eingetragen, oder?
                      mcBirneM Offline
                      mcBirneM Offline
                      mcBirne
                      @wendy2702
                      {"error":{"message":"HTTP 404 Not Found","http-code":404,"exception":{"class":"javax.ws.rs.NotFoundException","message":"HTTP 404 Not Found","localized-message":"HTTP 404 Not Found"}}}
                      • mcBirneM mcBirne
                        @wendy2702
                        wendy2702W Online
                        wendy2702W Online
                        @mcbirne Hast du deine IP vom EnergyManager in den LINK eingetragen ???
                          mcBirneM Offline
                          mcBirneM Offline
                          mcBirne
                          @wendy2702 ja
                          HomoranH mcBirneM 2 Antworten Letzte Antwort
                          • mcBirneM mcBirne
                            @wendy2702 ja
                            @mcbirne und ohne Anführungszeichen?
                            • mcBirneM mcBirne
                              @wendy2702 ja
                              mcBirneM Offline
                              mcBirneM Offline
                              mcBirne
                              @mcbirne
                              wenn ich http://192.168.178.124/rest eingebe erhalte ich
                              {"version":"3","links":[{"type":"uuid","url":"http://192.168.178.124/rest/uuid"},{"type":"audio","url":"http://192.168.178.124/rest/audio"},{"type":"bindings","url":"http://192.168.178.124/rest/bindings"},{"type":"channel-types","url":"http://192.168.178.124/rest/channel-types"},{"type":"config-descriptions","url":"http://192.168.178.124/rest/config-descriptions"},{"type":"discovery","url":"http://192.168.178.124/rest/discovery"},{"type":"inbox","url":"http://192.168.178.124/rest/inbox"},{"type":"extensions","url":"http://192.168.178.124/rest/extensions"},{"type":"items","url":"http://192.168.178.124/rest/items"},{"type":"links","url":"http://192.168.178.124/rest/links"},{"type":"persistence","url":"http://192.168.178.124/rest/persistence"},{"type":"profile-types","url":"http://192.168.178.124/rest/profile-types"},{"type":"services","url":"http://192.168.178.124/rest/services"},{"type":"things","url":"http://192.168.178.124/rest/things"},{"type":"thing-types","url":"http://192.168.178.124/rest/thing-types"},{"type":"sitemaps","url":"http://192.168.178.124/rest/sitemaps"},{"type":"voice","url":"http://192.168.178.124/rest/voice"},{"type":"iconsets","url":"http://192.168.178.124/rest/iconsets"}]}
                                mcBirneM Offline
                                mcBirneM Offline
                                mcBirne
                                @homoran ja, ich habe http://192.168.178.124/rest/kiwigrid/wizard/devices eingegeben
                                • wendy2702W Online
                                  wendy2702W Online
                                  Kannst du die IP per Ping erreichen?
                                  Mal angenommen der Energy Manager hat eine Web Oberfläche, wie lautet der Link um diese zu erreichen?
                                    mcBirneM Offline
                                    mcBirneM Offline
                                    mcBirne
                                    @wendy2702 das ist die Weboberfläche http://192.168.178.124/dashboard
                                      mcBirneM Offline
                                      mcBirneM Offline
                                      mcBirne
                                      ich kann die IP auch mit dem Ping Adapter vom IObroker pingen
                                      • mcBirneM mcBirne
                                        @mcbirne sagte in energymanager:
                                        das passt ja zur Erreichbarkeit des dashboards.
                                        Dann hat dein Manager nicht den selben Pfad zur rest-Api oder der heisst anders.
                                        Gab es bei mir auch irgendwo
                                          mcBirneM Offline
                                          mcBirneM Offline
                                          mcBirne
                                          schade, dann habe ich wohl keine Möglichkeit an die Daten zu kommen
