  3. Einsteigerfragen
  4. Problem Installation auf Raspi4
    5.7k
31 Beiträge 4 Kommentatoren 2.3k Aufrufe 3 Beobachtet
    @Thomas-Braun
    völlig egal mit welchem user (pi/moelli/root): es bleibt bei der Fehlermeldung der typmissmatch in der headerdatei.
    @wendy2702
    erstmal dankefür Deine Hilfe: netzwerkinterfaces für vpn
    $ cd /opt/iobroker
    $ npm install iobroker.js-controller@3.3.22
    > iobroker.js-controller@3.3.22 preinstall /opt/iobroker/node_modules/iobroker.js-controller
    > node lib/preinstallCheck.js
    NPM version: 6.14.16
    > unix-dgram@2.0.4 install /opt/iobroker/node_modules/unix-dgram
    > node-gyp rebuild
    make: Verzeichnis „/opt/iobroker/node_modules/unix-dgram/build“ wird betreten
      CXX(target) Release/obj.target/unix_dgram/src/unix_dgram.o
    In file included from ../../nan/nan.h:58,
                     from ../src/unix_dgram.cc:5:
    /home/moelli/.cache/node-gyp/14.19.0/include/node/node.h:793:43: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
           (node::addon_register_func) (regfunc),                          \
    /home/moelli/.cache/node-gyp/14.19.0/include/node/node.h:827:3: note: in expansion of macro ‘NODE_MODULE_X’
       NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
    ../src/unix_dgram.cc:404:1: note: in expansion of macro ‘NODE_MODULE’
     NODE_MODULE(unix_dgram, Initialize)
      SOLINK_MODULE(target) Release/obj.target/unix_dgram.node
      COPY Release/unix_dgram.node
    make: Verzeichnis „/opt/iobroker/node_modules/unix-dgram/build“ wird verlassen
    > ursa-optional@0.9.10 install /opt/iobroker/node_modules/ursa-optional
    > node rebuild.js
    ursaNative bindings compilation fail. This is not an issue. Modules that depend on it will use fallbacks.
    > diskusage@1.1.3 install /opt/iobroker/node_modules/diskusage
    > node-gyp rebuild
    make: Verzeichnis „/opt/iobroker/node_modules/diskusage/build“ wird betreten
      CXX(target) Release/obj.target/diskusage/src/main.o
                     from ../src/main.cpp:3:
    ../src/main.cpp:42:1: note: in expansion of macro ‘NODE_MODULE’
     NODE_MODULE(diskusage, Init)
      CXX(target) Release/obj.target/diskusage/src/diskusage_posix.o
      SOLINK_MODULE(target) Release/obj.target/diskusage.node
      COPY Release/diskusage.node
    make: Verzeichnis „/opt/iobroker/node_modules/diskusage/build“ wird verlassen
    > iobroker.js-controller@3.3.22 install /opt/iobroker/node_modules/iobroker.js-controller
    > node iobroker.js setup first
     Could not connect to objects database at 127.0.0.1:9001 (invalid protocol). Please make sure the configured IP and port points to a host running JS-Controller >= 2.0. and that the port is not occupied by other software!
    Server Cannot load /opt/iobroker/iobroker-data/objects.json: Database file /opt/iobroker/iobroker-data/objects.json does not exists.. We try last Backup!
    Server Cannot load /opt/iobroker/iobroker-data/objects.json.bak: Database file /opt/iobroker/iobroker-data/objects.json.bak does not exists.. Continue with empty dataset!
    Server If this is no Migration or initial start please restore the last backup from /opt/iobroker/iobroker-data/backup-objects
    No connection to databases possible ...
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm ERR! code ELIFECYCLE
    npm ERR! errno 22
    npm ERR! iobroker.js-controller@3.3.22 install: `node iobroker.js setup first`
    npm ERR! Exit status 22
    npm ERR!
    npm ERR! Failed at the iobroker.js-controller@3.3.22 install script.
    npm ERR!     /home/moelli/.npm/_logs/2022-02-15T22_56_22_260Z-debug.logcode_text
    der compiler motzt weiter über nan.h und node.h und erzeugt nicht js-controller. Insofern startet IOB auch nicht und es gibt keine Verbindung zu Port 9001.
    Für mich sieht das nach einer Incompatibiltät zw java und dden benutzten C-Biblotheken aus.
    Erst mal danke und gute nacht - gibt sonst auch noch Dinge die man um die Uhrzeit macht...
    @goofy1800 sagte in Problem Installation auf Raspi4:
    Lass ihn motzen. Das ist vollkommen normal.
    Nicht normal ist das Nichterreichen der Datenbank.
    Läuft da schon was anderes auf dem Port?
    • ? Offline
      die Idee nach der Portbelegung zu schauen, war nicht schlecht:
      Port 9001 Ausgabe von netstat:
      $ sudo netstat -tulpn |grep 9001
      [sudo] Passwort für ****:
      tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      426/node
      code_text
      pid 426 betrifft noch einen openhab Prozeß "frontail", eigentlich ist openhab deinstalliert:
         426 	frontail 	vor 2 Tagen 	node /usr/lib/node_modules/frontail/bin/frontail --disable-usage-stats --ui-high ...
            1180 	frontail 	vor 2 Tagen 	tail -n 200 -F /var/log/openhab/openhab.log /var/log/openhab/events.log
      werde demnächst weiter suchen, erstmal danke
      • ? Offline
        Abschalten von frontail und anschließender Aufruf des Installscriptes ergab dann folgendes:
        [20:44:16] root@openhabraspi4:/opt/iobroker# systemctl status iobroker
        ● iobroker.service - ioBroker Server
           Loaded: loaded (/lib/systemd/system/iobroker.service; enabled; vendor preset:
           Active: active (running) since Wed 2022-02-16 20:43:22 CET; 2min 11s ago
             Docs: http://iobroker.net
         Main PID: 14896 (iobroker.js-con)
            Tasks: 11 (limit: 4915)
           CGroup: /system.slice/iobroker.service
                   └─14896 iobroker.js-controller
        Feb 16 20:43:22 openhabraspi4 systemd[1]: Started ioBroker Server.
        lines 1-10/10 (END)
        code_text
        ich kann aber über den Port 8081 dann die web-Oberfläche nicht aufrufen, egal ob über die IP Adresse oder localhost:8081 -> Verbindung abgelehnt.
        die Kontrolle mit netstat zeigt keinen offenen Port unter 8081 an,
        9001 erscheint.
        code[20:30:58] root@openhabraspi4:/home/moelli# netstat -tulpn | grep 8081
        _text
        [20:46:08] root@openhabraspi4:/opt/iobroker# netstat -tulpn | grep 9001
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      14896/iobroker.js-c
        etwas ratlos
          lines 1-10/10 (END)
          code_text
          9001 erscheint.
          _text
          etwas ratlos
          etwas ratlos
          Immer noch root.
          • wendy2702W Offline
            wendy2702W Offline
            als USER:
            iob list instances
            • ? Offline
              ich habe alle Varianten durchgespielt: root, pi, sonst. user
              bei user kommt ungültige Gruppe user****:user****
                @goofy1800
                Du sollst halt nicht als root da rumhampeln.
                Das ist jetzt Rat genug an der Stelle.
                  @goofy1800
                  pi@openhabraspi4:/opt/iobroker $ curl -sLf https://iobroker.net/install.sh | bash -
                  library: loaded
                  Library version=2022-02-10
                     Welcome to the ioBroker installer!
                     Installer version: 2022-02-13
                     You might need to enter your password a couple of times.
                     Installing prerequisites (1/4)
                  OK:1 http://archive.raspberrypi.org/debian buster InRelease
                  OK:2 http://deb.debian.org/debian buster-backports InRelease
                  OK:3 http://raspbian.raspberrypi.org/raspbian buster InRelease
                  OK:4 https://packages.grafana.com/oss/deb stable InRelease
                  Ign:5 http://repos.azulsystems.com/debian stable InRelease
                  OK:6 http://repos.azulsystems.com/debian stable Release
                  OK:7 https://repos.influxdata.com/debian buster InRelease
                  Holen:8 https://repo.z-wave.me/z-way/raspbian buster InRelease [1.806 B]
                  OK:9 https://deb.nodesource.com/node_16.x buster InRelease
                  OK:10 https://repo.mosquitto.org/debian buster InRelease
                  OK:11 https://openhab.jfrog.io/artifactory/openhab-linuxpkg stable InRelease
                  Es wurden 1.806 B in 5 s geholt (390 B/s).
                  Changing npm registry to https://registry.npmjs.org
                  Installed gcc-c++
                     Creating ioBroker user and directory (2/4)
                  Directory /opt/iobroker created
                     Installing ioBroker (3/4)
                     Finalizing installation (4/4)
                  Enabling autostart...
                  Autostart enabled!
                     ioBroker was installed successfully
                     Open http://192.168.11.117 192.168.11.217 192.168.55.1 10.6.0.1:8081 in a browser and start configuring!
                  You need to re-login before doing anything else on the console!
                  ode_text
                  ich finde Ihren Ton (rumhampeln) nicht gerade angemessen, man wweiß ja nicht wen man auf der Gegenseite vor sich hat - ....
                  Thomas BraunT wendy2702W HomoranH 3 Antworten Letzte Antwort
                    library: loaded
                    Installed gcc-c++
                    Autostart enabled!
                    ode_text
                    Einen Goofy. Sehe ich.
                      library: loaded
                      Installed gcc-c++
                      Autostart enabled!
                      ode_text
                      wendy2702W Offline
                      wendy2702W Offline
                      Leute die versuchen einem zu helfen.
                      Laut fixer sollte IOB laufen.
                      Wie die IP Addressen zustande kommen erschliesst sich mir aktuell nicht da ich die Konfig vom PI nicht kenne, daher kann ich nicht sagen welche jetzt zu verwenden wäre.
                        library: loaded
                        Installed gcc-c++
                        Autostart enabled!
                        ode_text
                        HomoranH Offline
                        HomoranH Offline
                        Ein lockerer Ton darf doch erlaubt sein. Bei dir motzt der compiler ja auc
                        @Ein ehemaliger Benutzer sagte in Problem Installation auf Raspi4:
                        da ist jemand , dem man in entspannter Atmosphäre helfen will.
                          wendy2702W Offline
                          Oha....
                          da hat sich aber schnell wieder jemand von ioBroker verabschiedet.
