  4. js-controller 3.3 jetzt im Beta
    6.0k
791 Beiträge 75 Kommentatoren 285.7k Aufrufe 56 Beobachtet
  • D derrapf
    Jetzt hab ich mal nach Anleitung meinen Rock64 auch upgedatet und leider ging das bei mir voll in die Hose.
    Node ist bei mir v12.22.6
    Ich habe
    iobroker stop
    iobroker backup
    iobroker update
    iobroker upgrade self
    ausgeführt.
    Ausgabe:
    pi@rock64:/opt/iobroker$ iobroker upgrade self
    Update js-controller from @3.3.15 to @3.3.22
    NPM version: 6.14.15
    npm install iobroker.js-controller@3.3.22 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
    sharp: Installation error: Use with glibc 2.28 requires manual installation of libvips >= 8.10.6
    ../src/common.cc:24:10: fatal error: vips/vips8: Datei oder Verzeichnis nicht gefunden
     #include <vips/vips8>
    compilation terminated.
    make: *** [sharp.target.mk:139: Release/obj.target/sharp/src/common.o] Fehler 1
    gyp ERR! build error
    gyp ERR! stack Error: `make` failed with exit code: 2
    gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
    gyp ERR! stack     at ChildProcess.emit (events.js:314:20)
    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:276:12)
    gyp ERR! System Linux 5.10.63-rockchip64
    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    gyp ERR! cwd /opt/iobroker/node_modules/sharp
    gyp ERR! node -v v12.22.6
    gyp ERR! node-gyp -v v5.1.0
    gyp ERR! not ok
    In file included from ../../nan/nan.h:58,
                     from ../src/unix_dgram.cc:5:
    /home/iobroker/.cache/node-gyp/12.22.6/include/node/node.h:736:43: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
           (node::addon_register_func) (regfunc),                          \
    /home/iobroker/.cache/node-gyp/12.22.6/include/node/node.h:770:3: note: in expansion of macro ‘NODE_MODULE_X’
       NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
    ../src/unix_dgram.cc:404:1: note: in expansion of macro ‘NODE_MODULE’
     NODE_MODULE(unix_dgram, Initialize)
    Kann mir da jemand helfen?
    Gruss Ralf
    #728
    @derrapf
    Welches Release? Ist das noch Stretch oder noch älter?
      derrapf
      schrieb am zuletzt editiert von derrapf
      #729
      Hilf Dir das hier?
      pi@rock64:/opt/iobroker$ cat /etc/os-release
      PRETTY_NAME="Debian GNU/Linux 10 (buster)"
      NAME="Debian GNU/Linux"
      VERSION_ID="10"
      VERSION="10 (buster)"
      VERSION_CODENAME=buster
      ID=debian
      HOME_URL="https://www.debian.org/"
      SUPPORT_URL="https://www.debian.org/support"
      BUG_REPORT_URL="https://bugs.debian.org/"
      Ist jetzt mein System versaut, oder kann ich notfalls wieder auf den alten Stand?
      Gruss Ralf
      • D derrapf
        Hilf Dir das hier?
        VERSION_ID="10"
        ID=debian
        Gruss Ralf
        #730
        @derrapf
        apt policy libvips42 libvips-dev
        Wenn die fehlen, nachinstallieren.
          @derrapf
          derrapf
          #731
          Ok, hab ich ausgeführt:
          pi@rock64:/opt/iobroker$ apt policy libvips42 libvips-dev
          libvips42:
            Installiert:           (keine)
            Installationskandidat: 8.7.4-1+deb10u1
            Versionstabelle:
               8.7.4-1+deb10u1 500
                  500 http://deb.debian.org/debian buster/main arm64 Packages
          libvips-dev:
            Versionstabelle:
               8.7.4-1+deb10u1 500
          Ist das so ok?
          Oder muss ich jetzt sagen apt install libvips42 libvips-dev?
          Gruss Ralf
          Thomas BraunT D 3 Antworten Letzte Antwort
          • D derrapf
            libvips42:
              Versionstabelle:
                 8.7.4-1+deb10u1 500
            libvips-dev:
              Versionstabelle:
                 8.7.4-1+deb10u1 500
            Ist das so ok?
            Gruss Ralf
            #732
            @derrapf
            Genau das.
            sudo apt install libvips-dev libvips42
            • D derrapf
              libvips42:
                Versionstabelle:
                   8.7.4-1+deb10u1 500
              libvips-dev:
                Versionstabelle:
                   8.7.4-1+deb10u1 500
              Ist das so ok?
              Gruss Ralf
              #733
              @derrapf
              Oh, ich sehe gerade, die Versionen dürften zu alt sein.
              • D derrapf
                libvips42:
                  Versionstabelle:
                     8.7.4-1+deb10u1 500
                libvips-dev:
                  Versionstabelle:
                     8.7.4-1+deb10u1 500
                Ist das so ok?
                Gruss Ralf
                derrapf
                #734
                @derrapf Das scheint es gewesen zu sein
                Ich habe
                 apt-get install  libvips42 libvips-dev
                gemacht. Das lief ohne Fehler
                Danach habe ich noch mal den upgrade vom jscontroller gemacht und da kam nur die lapidare Meldung dass er uptodate wäre.
                Host    "rock64"         is up to date.
                War's das quasi jetzt? Weil die Fehler am Anfang sahen ja dramatisch aus. Und jetzt kommt nur "is up to date" ?
                Ich hätte jetzt erwartet dass die Installtionsrountinen nochmal ohne Fehler durchlaufen müssten...
                Gruss Ralf
                  @derrapf
                  derrapf
                  #735
                  Da haben wir gleichzeitig gepostet. Welche Versionen meinst Du?
                  Und was soll ich tun?
                  Gruss Ralf
                  • D derrapf
                    Gruss Ralf
                    #736
                    @derrapf
                    iobroker status
                    iobroker update -i
                      @derrapf
                      iobroker status
                      iobroker update -i
                      derrapf
                      #737
                      pi@rock64:/opt/iobroker$ iobroker status
                      iobroker is not running on this host.
                      Objects type: file
                      States  type: file
                      pi@rock64:/opt/iobroker$ iobroker update -i
                      Used repository: stable
                      hash unchanged, use cached sources
                      update done
                      Adapter    "admin"         : 5.2.3    , installed 5.2.3
                      Adapter    "alexa2"        : 3.11.2   , installed 3.11.2
                      Adapter    "backitup"      : 2.2.3    , installed 2.2.3
                      Adapter    "cloud"         : 4.1.0    , installed 4.1.0
                      Adapter    "daswetter"     : 3.0.9    , installed 3.0.9
                      Adapter    "discovery"     : 2.7.3    , installed 2.7.3
                      Adapter    "dwd"           : 2.7.7    , installed 2.7.7
                      Adapter    "flot"          : 1.10.7   , installed 1.10.7
                      Adapter    "fritzbox"      : 0.2.1    , installed 0.2.1
                      Adapter    "fritzdect"     : 2.2.3    , installed 2.1.15 [Updateable]
                      Adapter    "fullybrowser"  : 2.0.10   , installed 2.0.10
                      Adapter    "history"       : 1.9.14   , installed 1.9.14
                      Adapter    "hm-rega"       : 3.0.33   , installed 3.0.33
                      Adapter    "hm-rpc"        : 1.15.0   , installed 1.14.50 [Updateable]
                      Adapter    "hs100"         : 2.0.6    , installed 2.0.6
                      Adapter    "ical"          : 1.11.4   , installed 1.11.4
                      Adapter    "icons-addictive-flavour-png": 0.1.0   , installed 0.1.0
                      Adapter    "icons-fatcow-hosting": 0.1.0   , installed 0.1.0
                      Adapter    "icons-icons8"  : 0.0.1    , installed 0.0.1
                      Adapter    "icons-material-png": 0.1.0   , installed 0.1.1
                      Adapter    "icons-material-svg": 0.1.0   , installed 0.1.1
                      Adapter    "icons-mfd-svg" : 1.0.2    , installed 1.0.2
                      Adapter    "icons-open-icon-library-png": 0.1.2   , installed 0.1.2
                      Adapter    "icons-ultimate-png": 1.0.1   , installed 1.0.1
                      Adapter    "info"          : 1.9.8    , installed 1.9.8
                      Adapter    "iot"           : 1.8.24   , installed 1.8.24
                      Adapter    "jarvis"        : 3.0.11   , installed 2.2.1 [Updateable]
                      Adapter    "javascript"    : 5.2.13   , installed 5.2.13
                      Controller "js-controller" : 3.3.22   , installed 3.3.22
                      Adapter    "luftdaten"     : 2.1.3    , installed 1.0.3 [Updateable]
                      Adapter    "material"      : 1.0.4    , installed 1.0.4
                      Adapter    "melcloud"      : 1.1.4    , installed 1.1.4
                      Adapter    "mobile"        : 1.0.1    , installed 1.0.1
                      Adapter    "mqtt-client"   : 1.4.0    , installed 1.4.0
                      Adapter    "musiccast"     : 0.1.5    , installed 0.2.0
                      Adapter    "net-tools"     : 0.1.7    , installed 0.1.7
                      Adapter    "octoprint"     : 2.1.0    , installed 1.1.1 [Updateable]
                      Adapter    "owntracks"     : 1.0.0    , installed 1.0.0
                      Adapter    "parser"        : 1.0.7    , installed 1.0.7
                      Adapter    "ping"          : 1.5.0    , installed 1.5.0
                      Adapter    "places"        : 1.0.0    , installed 1.0.0
                      Adapter    "pushover"      : 2.0.5    , installed 2.0.5
                      Adapter    "rickshaw"      : 1.0.0    , installed 1.0.0
                      Adapter    "rpi2"          : 1.3.1    , installed 1.3.1
                      Adapter    "samsung"       : 0.2.9    , installed 0.2.9
                      Adapter    "sayit"         : 1.12.3   , installed 1.12.3
                      Adapter    "scenes"        : 2.3.8    , installed 2.3.8
                      Adapter    "shelly"        : 4.0.7    , installed 4.0.7
                      Adapter    "simple-api"    : 2.6.1    , installed 2.6.2
                      Adapter    "snmp"          : 0.5.0    , installed 0.5.0
                      Adapter    "socketio"      : 3.1.5    , installed 4.1.0
                      Adapter    "synology"      : 1.1.3    , installed 2.0.1
                      Adapter    "telegram"      : 1.10.0   , installed 1.10.0
                      Adapter    "text2command"  : 2.1.1    , installed 2.1.1
                      Adapter    "tr-064"        : 4.2.14   , installed 4.2.14
                      Adapter    "tvspielfilm"   : 2.0.4    , installed 2.0.4
                      Adapter    "vis"           : 1.4.5    , installed 1.4.5
                      Adapter    "vis-bars"      : 0.1.4    , installed 0.1.4
                      Adapter    "vis-canvas-gauges": 0.1.5   , installed 0.1.5
                      Adapter    "vis-colorpicker": 1.2.0   , installed 1.2.0
                      Adapter    "vis-fancyswitch": 1.1.0   , installed 1.1.0
                      Adapter    "vis-google-fonts": 0.1.0   , installed 0.1.0
                      Adapter    "vis-history"   : 1.0.0    , installed 1.0.0
                      Adapter    "vis-hqwidgets" : 1.1.7    , installed 1.1.7
                      Adapter    "vis-inventwo"  : 3.2.5    , installed 3.2.0 [Updateable]
                      Adapter    "vis-jqui-mfd"  : 1.0.12   , installed 1.0.12
                      Adapter    "vis-justgage"  : 1.0.2    , installed 1.0.2
                      Adapter    "vis-keyboard"  : 0.0.2    , installed 0.0.2
                      Adapter    "vis-lcars"     : 1.0.4    , installed 1.0.4
                      Adapter    "vis-map"       : 1.0.4    , installed 1.0.4
                      Adapter    "vis-material-advanced": 1.7.2   , installed 1.7.2
                      Adapter    "vis-metro"     : 1.1.2    , installed 1.1.2
                      Adapter    "vis-players"   : 0.1.6    , installed 0.1.6
                      Adapter    "vis-plumb"     : 1.0.2    , installed 1.0.2
                      Adapter    "vis-rgraph"    : 0.0.2    , installed 0.0.2
                      Adapter    "vis-timeandweather": 1.1.7   , installed 1.1.7
                      Adapter    "vw-connect"    : 0.0.48   , installed 0.0.45 [Updateable]
                      Adapter    "web"           : 3.4.16   , installed 3.4.16
                      Adapter    "yamaha"        : 0.4.0    , installed 0.4.0
                      wendy2702W Thomas BraunT 2 Antworten Letzte Antwort
                      • D derrapf
                        Objects type: file
                        States  type: file
                        update done
                        wendy2702W Offline
                        wendy2702W Offline
                        #738
                        @derrapf
                        iob start
                        • D derrapf
                          Objects type: file
                          States  type: file
                          update done
                          #739
                          @derrapf
                          Dann bringe den Rest jetzt auch auf Stand.
                            @derrapf
                            derrapf
                            #740
                            @thomas-braun Danke. Bis jetzt sieht es super aus!
                            Was war dieses libvips42 libvips-dev eigentlich? Wozu wird das benötigt?
                            Gruss Ralf
                            Thomas BraunT D 2 Antworten Letzte Antwort
                            • D derrapf
                              Gruss Ralf
                              #741
                              @derrapf
                              Wird benötigt um Bilder zu bearbeiten.
                              • D derrapf
                                Gruss Ralf
                                derrapf
                                #742
                                Doch nicht ganz
                                Der Octoprint Adapter will grad nicht
                                $ iobroker upgrade octoprint@2.1.0
                                Unable to enable Expiry Keyspace events from Redis Server: Connection is closed.
                                No connection to databases possible ...
                                ERROR: Process exited with code 22
                                Gruss Ralf
                                • D derrapf
                                  Doch nicht ganz
                                  Gruss Ralf
                                  #743
                                  @derrapf sagte in js-controller 3.3 jetzt im Beta:
                                  Redis Server
                                  Oben war von file/File die Rede. Oder spricht der Octopus mit Redis? Keine Ahnung, mag keine Meerestiere.
                                  D apollon77A 2 Antworten Letzte Antwort
                                    Redis Server
                                    derrapf
                                    #744
                                    Wenn ich das wüsste. Explizit gesagt hab ich ihm das nicht. Also nicht absichtlich.
                                    Du könntest aber mit der Version recht haben. Zwei Adapter haben gemeldet
                                    Sind aber trotzdem duchgelaufen.
                                    Kann man das ignorieren?
                                    Gruss Ralf
                                    D Thomas BraunT 2 Antworten Letzte Antwort
                                    • D derrapf
                                      Gruss Ralf
                                      derrapf
                                      #745
                                      @derrapf Ich habe den Octoprint nochmal upgedatet und nun ist er durchgelaufen. Konisch.
                                      Auf jeden Fall sind jetzt alle Adapter uptodate. Ob sie fehlerfrei laufen werde ich dann sehen.
                                      Danke nochmal
                                      Gruss Ralf
                                      • D derrapf
                                        Gruss Ralf
                                        #746
                                        @derrapf
                                        Jein. Da dürften jetzt Adapter, die Bilder bearbeiten (z.B. die Staubsauger-Adapter brauchen das oft um die Karten zu bearbeiten) nicht funktionieren.
                                          @derrapf
                                          derrapf
                                          #747
                                          Ah ok. Die hab ich leider nicht. Für den Dream-E scheint es noch keinen Adapter zu geben. Das einzige was ich habe das in irgend einer Form graphisch ist, ist VIS und den Flot Adapter. Mehr fällt mir da grad nicht ein.
                                          Und die Libs kann ich unter Buster nicht updaten? Müsste ich ein dist upgrade machen, oder wie das heisst? Wenn ja ist das problemlos möglich?
                                          Gruss Ralf
