  4. [gelöst] node-red-node-serialport geht nicht Node.js v14.
    6.1k
9 Beiträge 3 Kommentatoren 706 Aufrufe 3 Beobachtet
    Manuel001
    schrieb am zuletzt editiert von Manuel001
    Nach Update auf Node.js v14.19.0 wollte ich node-red-node-serialport über die NodeRed Instanz wieder einbinden.
    Das führt aber zu diesem Fehler:
    2022-02-11 13:32:50.937 - error: node-red.2 (951) install: ["node-red-node-serialport"]
    2022-02-11 13:32:51.516 - info: node-red.2 (951) Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2022-02-11 13:32:59.638 - warn: node-red.2 (951) 11 Feb 13:32:59 - [warn] ------------------------------------------------------
    2022-02-11 13:32:59.642 - warn: node-red.2 (951) 11 Feb 13:32:59 - [warn] [node-red-node-serialport/serialport] Error: The module '/opt/iobroker/iobroker-data/node-red/node_modules/@serialport/bindings/build/Release/bindings.node'
    was compiled against a different Node.js version using
    NODE_MODULE_VERSION 72. This version of Node.js requires
    NODE_MODULE_VERSION 83. Please try re-compiling or re-installing
    the module (for instance, using `npm rebuild` or `npm install`).
    2022-02-11 13:32:59.649 - warn: node-red.2 (951) 11 Feb 13:32:59 - [warn] ------------------------------------------------------
    2022-02-11 13:32:59.660 - warn: node-red.2 (951) 11 Feb 13:32:59 - [warn] Projects disabled : editorTheme.projects.enabled=false
    11 Feb 13:32:59 - [info] Flows file : /opt/iobroker/iobroker-data/node-red/flows.json
    Wie kann man das beheben?
    • M Manuel001
      wendy2702W Offline
      wendy2702W Offline
      @manuel001 sagte in node-red-node-serialport geht mit Node.js v14.19.0 nicht:
      Please try re-compiling or re-installing the module (for instance, using npm rebuild or npm install).
      Mal probiert?
      • wendy2702W wendy2702
        Mal probiert?
        Manuel001
        Das führt du diesem Problem:
        pi@ioBrokerWallbox:~ $ npm rebuild
           │     New major version of npm available! 6.14.16 -> 8.5.0      │
           │   Changelog: https://github.com/npm/cli/releases/tag/v8.5.0   │
           │               Run npm install -g npm to update!               │
        pi@ioBrokerWallbox:~ $ npm install -g npm
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/abbrev
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/ansi-align
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/ansi-regex
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/aproba
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/are-we-there-yet/node_modules/string_decoder
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/asap
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/asn1
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/assert-plus
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/asynckit
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/aws-sign2
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/aws4
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/balanced-match
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/bluebird
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/buffer-from
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/builtins
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/byline
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/byte-size
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/call-limit
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/camelcase
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/capture-stack-trace
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/caseless
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/chownr
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/ci-info
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/cli-boxes
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/cliui/node_modules/ansi-regex
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/cliui/node_modules/is-fullwidth-code-point
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/cliui/node_modules/strip-ansi
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/cliui/node_modules/string-width
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/clone
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/code-point-at
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/color-name
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/color-convert
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/ansi-styles
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/colors
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/concat-map
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/brace-expansion
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/concat-stream/node_modules/string_decoder
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/console-control-strings
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/copy-concurrently/node_modules/aproba
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/copy-concurrently/node_modules/iferr
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/core-util-is
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/create-error-class
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/cross-spawn/node_modules/yallist
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/crypto-random-string
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/cyclist
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/dashdash
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/debug/node_modules/ms
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/debuglog
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/decamelize
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/decode-uri-component
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/deep-extend
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/defaults
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/delayed-stream
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/combined-stream
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/delegates
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/detect-indent
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/detect-newline
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/dotenv
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/duplexer3
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/duplexify/node_modules/string_decoder
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/editor
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/emoji-regex
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/end-of-stream
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/env-paths
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/err-code
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/es6-promise
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/es6-promisify
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/agent-base
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/escape-string-regexp
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/execa/node_modules/get-stream
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/extend
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/extsprintf
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/fast-json-stable-stringify
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/figgy-pudding
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/find-npm-prefix
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/flush-write-stream/node_modules/string_decoder
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/forever-agent
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/from2/node_modules/string_decoder
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/fs-minipass/node_modules/minipass
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/fs-write-stream-atomic/node_modules/iferr
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/fs-write-stream-atomic/node_modules/string_decoder
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/fs.realpath
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/function-bind
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/gauge/node_modules/aproba
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/gauge/node_modules/string-width
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/genfun
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/gentle-fs/node_modules/aproba
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/gentle-fs/node_modules/iferr
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/get-caller-file
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/getpass
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/global-dirs
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/got/node_modules/get-stream
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/graceful-fs
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/har-schema
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/har-validator/node_modules/fast-deep-equal
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/har-validator/node_modules/json-schema-traverse
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/has
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/has-flag
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/has-symbols
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/has-unicode
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/http-cache-semantics
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/http-proxy-agent
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/https-proxy-agent
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/iferr
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/import-lazy
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/imurmurhash
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/infer-owner
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/inherits
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/ini
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/ip
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/ip-regex
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/cidr-regex
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/is-callable
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/is-ci/node_modules/ci-info
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/is-date-object
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/is-npm
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/is-obj
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/dot-prop
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/is-redirect
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/is-regex
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/is-retry-allowed
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/is-stream
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/is-symbol
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/es-to-primitive
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/es-abstract
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/is-typedarray
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/isarray
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/isexe
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/isstream
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/jsbn
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/ecc-jsbn
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/json-parse-better-errors
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/json-schema
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/json-stringify-safe
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/jsonparse
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lazy-property
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/libnpmconfig/node_modules/p-try
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/libnpmconfig/node_modules/p-limit
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/libnpmconfig/node_modules/p-locate
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lock-verify
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lockfile
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lodash._baseindexof
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lodash._bindcallback
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lodash._cacheindexof
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lodash._createset
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lodash._getnative
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lodash._createcache
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lodash._root
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lodash._baseuniq
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lodash.clonedeep
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lodash.restparam
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lodash.union
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lodash.uniq
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lodash.without
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lowercase-keys
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/meant
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/mime-db
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/mime-types
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/form-data
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/minimatch
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/ignore-walk
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/minimist
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/minizlib/node_modules/minipass
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/mkdirp/node_modules/minimist
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/cmd-shim
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/move-concurrently/node_modules/aproba
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/ms
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/humanize-ms
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/agentkeepalive
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/mute-stream
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/node-fetch-npm
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npm-cache-filename
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npm-logical-tree
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npm-normalize-package-bin
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npm-bundled
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npm-registry-fetch/node_modules/safe-buffer
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/number-is-nan
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/is-fullwidth-code-point
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/oauth-sign
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/object-assign
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/object-keys
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/define-properties
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/object.getownpropertydescriptors
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/os-homedir
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/os-tmpdir
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/osenv
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/nopt
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/p-finally
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/pacote/node_modules/minipass
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/parallel-transform/node_modules/string_decoder
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/path-exists
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/libnpmconfig/node_modules/locate-path
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/libnpmconfig/node_modules/find-up
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/path-is-absolute
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/path-is-inside
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/fs-vacuum
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/is-path-inside
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/is-installed-globally
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/path-key
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npm-run-path
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/path-parse
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/normalize-package-data/node_modules/resolve
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/performance-now
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/pify
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/make-dir
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/prepend-http
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/process-nextick-args
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/are-we-there-yet/node_modules/readable-stream
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/concat-stream/node_modules/readable-stream
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/duplexify/node_modules/readable-stream
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/flush-write-stream/node_modules/readable-stream
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/from2/node_modules/readable-stream
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/fs-write-stream-atomic/node_modules/readable-stream
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/parallel-transform/node_modules/readable-stream
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/promise-inflight
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/promise-retry/node_modules/retry
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/proto-list
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/config-chain
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/protoduck
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/prr
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/errno
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/pseudomap
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/cross-spawn/node_modules/lru-cache
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/psl
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/pump
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/get-stream
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/pumpify/node_modules/pump
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/punycode
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/qs
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/qw
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/read
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/promzard
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/read-cmd-shim
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/require-directory
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/require-main-filename
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/resolve-from
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/retry
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/run-queue/node_modules/aproba
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/safe-buffer
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/safer-buffer
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/iconv-lite
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/encoding
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/semver-diff
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/set-blocking
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/sha
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/shebang-regex
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/shebang-command
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/signal-exit
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/slide
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/smart-buffer
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/socks
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/socks-proxy-agent/node_modules/agent-base
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/sorted-object
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/sorted-union-stream/node_modules/isarray
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/sorted-union-stream/node_modules/string_decoder
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/sorted-union-stream/node_modules/readable-stream
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/sorted-union-stream/node_modules/from2
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/spdx-exceptions
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/spdx-license-ids
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/spdx-expression-parse
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/spdx-correct
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/split-on-first
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/stream-iterate/node_modules/string_decoder
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/stream-iterate/node_modules/readable-stream
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/stream-shift
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/stream-each
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/strict-uri-encode
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/query-string
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/string_decoder/node_modules/safe-buffer
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/string-width/node_modules/ansi-regex
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/string-width/node_modules/is-fullwidth-code-point
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/string-width/node_modules/strip-ansi
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/stringify-package
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/strip-ansi
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/strip-eof
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/strip-json-comments
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/rc
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/registry-auth-token
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/registry-url
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/supports-color
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/chalk
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/tar/node_modules/safe-buffer
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/tar/node_modules/yallist
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/tar/node_modules/minipass
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/term-size
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/through
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/JSONStream
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/through2/node_modules/string_decoder
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/through2/node_modules/readable-stream
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/timed-out
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/tough-cookie
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/tunnel-agent
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/tweetnacl
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/bcrypt-pbkdf
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/sshpk
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/typedarray
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/uid-number
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/umask
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npm-lifecycle
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/unique-slug
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/unique-filename
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/unique-string
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/unpipe
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/unzip-response
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/uri-js/node_modules/punycode
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/har-validator/node_modules/ajv
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/url-parse-lax
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/package-json
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/latest-version
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/util-deprecate
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/readable-stream
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/util-extend
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/read-installed
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/util-promisify
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/read-package-tree
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/uuid
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/validate-npm-package-license
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/validate-npm-package-name
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/verror
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/jsprim
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/http-signature
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/request
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/wcwidth
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/which
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/which-module
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/wide-align/node_modules/string-width
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npmlog
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/widest-line
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/boxen
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/worker-farm
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/libcipm
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/wrap-ansi/node_modules/ansi-regex
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/wrap-ansi/node_modules/is-fullwidth-code-point
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/wrap-ansi/node_modules/strip-ansi
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/wrap-ansi/node_modules/string-width
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/wrappy
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/dezalgo
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/once
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/inflight
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npm-packlist
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/rimraf
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/readdir-scoped-modules
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/write-file-atomic
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/bin-links
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/xdg-basedir
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/configstore
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/update-notifier
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/xtend
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/mississippi
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/y18n
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/yallist
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lru-cache
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/hosted-git-info
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/read-package-json
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npm-install-checks
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npm-package-arg
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npm-pick-manifest
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/ssri
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/cacache
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/make-fetch-happen
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/node-gyp
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/yargs-parser/node_modules/camelcase
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/yargs/node_modules/ansi-regex
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/yargs/node_modules/is-fullwidth-code-point
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/yargs/node_modules/p-try
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/yargs/node_modules/p-limit
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/yargs/node_modules/p-locate
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/yargs/node_modules/locate-path
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/yargs/node_modules/find-up
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/yargs/node_modules/strip-ansi
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/yargs/node_modules/string-width
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/libnpx
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/ansicolors
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/ansistyles
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/archy
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/cli-columns
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/cli-table3
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/columnify
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/init-package-json
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/is-cidr
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/libnpmaccess
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/libnpmhook
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/libnpmorg
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/libnpmpublish
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/libnpmsearch
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/libnpmteam
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npm-audit-report
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npm-profile
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npm-user-validate
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/opener
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/qrcode-terminal
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/text-table
        npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/tiny-relative-date
        npm ERR! code EACCES
        npm ERR! syscall access
        npm ERR! path /usr/lib/node_modules/npm/node_modules/abbrev
        npm ERR! errno -13
        npm ERR! Error: EACCES: permission denied, access '/usr/lib/node_modules/npm/node_modules/abbrev'
        npm ERR!  [Error: EACCES: permission denied, access '/usr/lib/node_modules/npm/node_modules/abbrev'] {
        npm ERR!   errno: -13,
        npm ERR!   code: 'EACCES',
        npm ERR!   syscall: 'access',
        npm ERR!   path: '/usr/lib/node_modules/npm/node_modules/abbrev'
        npm ERR! }
        npm ERR!
        npm ERR! The operation was rejected by your operating system.
        npm ERR! It is likely you do not have the permissions to access this file as the current user
        npm ERR!
        npm ERR! If you believe this might be a permissions issue, please double-check the
        npm ERR! permissions of the file and its containing directories, or try running
        npm ERR! the command again as root/Administrator.
        npm ERR!     /home/pi/.npm/_logs/2022-02-11T15_56_54_055Z-debug.log
        Wie kann man das umgehen? Scheint ein Berechtigungsproblem zu sein.
        • M Manuel001
          npm ERR! errno -13
          npm ERR! }
          npm ERR!
          npm ERR!
          Manuel001
          Mit
          sudo chown -R $USER /usr/lib/node_modules/
          kann man scheinbar mehr Berechtigungen vergeben.
          Dann sieht es so aus:
          npm ERR! syscall unlink
          npm ERR! path /usr/bin/npm
          npm ERR! errno -13
          npm ERR! Error: EACCES: permission denied, unlink '/usr/bin/npm'
          npm ERR!  [OperationalError: EACCES: permission denied, unlink '/usr/bin/npm'] {
          npm ERR!   cause: [Error: EACCES: permission denied, unlink '/usr/bin/npm'] {
          npm ERR!     syscall: 'unlink',
          npm ERR!     path: '/usr/bin/npm'
          npm ERR!   },
          npm ERR! }
          npm ERR!
          npm ERR!
          npm ERR!     /home/pi/.npm/_logs/2022-02-11T16_05_03_768Z-debug.log
          • M Manuel001
            Mit
            npm ERR! errno -13
            npm ERR!   },
            npm ERR! }
            npm ERR!
            npm ERR!
            wendy2702W Offline
            wendy2702W Offline
            @manuel001 sinn hätte es gemacht das rebuild im richtigen Verzeichnis auszuführen und zu lesen was in dem Fenster steht. Du willst bzw. wolltest bestimmt kein update auf NPM8.x machen.
            Dann noch die berechtigungen zu ändern...ganz schlechte Idee.
            Hast du ein Backup von iobroker? Wenn nicht jetzt solltest du eines machen.
            Keine Ahnung ob deine NPM Installation jetzt schon schaden genommen hat.
            Vielleicht sicherheitshalber Anhand dieser Anleitung Prüfen: https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian bzw. einfach neu machen.
            Den rebuild mal in
            /opt/iobroker/
            Ausführen und am besten mit zweiter Session zeitgleich in das logfile schauen.
              Den rebuild mal in
              /opt/iobroker/
              Manuel001
              @wendy2702
              Ich kenne mich da leider nicht aus und kann mir nur mit diesem Forum und Google weiterhelfen. Sorry
              Ja ich mache regelmäßig ein Image von der SD-Card. (das hat mich schon öfter gerettet)
              Offensichtlich habe ich nochmal Glück gehabt.
              Ich habe jetzt gesehen, dass man bei der letzten Version vom NodeRed Adapter in der Adapterkonfiguration wieder Paletten verwalten aktivieren kann. Über das habe ich dann node-red-node-serialport problemlos intallieren können.
              Aktuell scheint wieder alles zu funktionieren.
              Danke für die Unterstützung!
              wendy2702W Thomas BraunT 2 Antworten Letzte Antwort
              • M Manuel001
                @wendy2702
                wendy2702W Offline
                wendy2702W Offline
                Das ist gut aber lege dir auch Backups nur von ioBroker an. --> BackitUp Adapter
                Schön wenn es wieder funktioniert und wenn du nicht weisst oder dir sicher bist wo ein Befehl ausgeführt werden muss/soll besser nochmal fragen.
                • M Manuel001
                  @wendy2702
                  @manuel001
                  Irgendwie verfummelst du das System noch weiter...
                  ls -la /usr/lib/node_modules/
                  Und installier nochmal sauber nodejs@14.
                  Lass künftig die Finger von
                  Das ist ein schlechter Rat.
                    @manuel001
                    Manuel001
                    Danke für die Hinweise.
                    Ich habe jetzt nochmal das Image vom Vormittag genommen und dann die paar Schritte durchgeführt.
                    Wenn man weiß, was zu tun ist, ist es ja nicht viel Aufwand.
                    Danke jedenfalls für deine Unterstützung. Jetzt ist mein System zumindest wieder aktuell.
