<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[gelöst] node-red-node-serialport geht nicht Node.js v14.]]></title><description><![CDATA[<p dir="auto">Nach Update auf Node.js v14.19.0 wollte ich node-red-node-serialport über die NodeRed Instanz wieder einbinden.<br />
Das führt aber zu diesem Fehler:</p>
<pre><code>
2022-02-11 13:32:50.937 - error: node-red.2 (951) install: ["node-red-node-serialport"]
2022-02-11 13:32:51.516 - info: node-red.2 (951) Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
2022-02-11 13:32:59.638 - warn: node-red.2 (951) 11 Feb 13:32:59 - [warn] ------------------------------------------------------
2022-02-11 13:32:59.642 - warn: node-red.2 (951) 11 Feb 13:32:59 - [warn] [node-red-node-serialport/serialport] Error: The module '/opt/iobroker/iobroker-data/node-red/node_modules/@serialport/bindings/build/Release/bindings.node'
was compiled against a different Node.js version using
NODE_MODULE_VERSION 72. This version of Node.js requires
NODE_MODULE_VERSION 83. Please try re-compiling or re-installing
the module (for instance, using `npm rebuild` or `npm install`).
2022-02-11 13:32:59.649 - warn: node-red.2 (951) 11 Feb 13:32:59 - [warn] ------------------------------------------------------
2022-02-11 13:32:59.660 - warn: node-red.2 (951) 11 Feb 13:32:59 - [warn] Projects disabled : editorTheme.projects.enabled=false
11 Feb 13:32:59 - [info] Flows file : /opt/iobroker/iobroker-data/node-red/flows.json
</code></pre>
<p dir="auto">Wie kann man das beheben?</p>
]]></description><link>https://forum.iobroker.net/topic/52423/gelöst-node-red-node-serialport-geht-nicht-node-js-v14</link><generator>RSS for Node</generator><lastBuildDate>Sat, 23 May 2026 15:37:17 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/52423.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 11 Feb 2022 14:32:49 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to [gelöst] node-red-node-serialport geht nicht Node.js v14. on Fri, 11 Feb 2022 18:46:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a><br />
Danke für die Hinweise.<br />
Ich habe jetzt nochmal das Image vom Vormittag genommen und dann die paar Schritte durchgeführt.<br />
Wenn man weiß, was zu tun ist, ist es ja nicht viel Aufwand.</p>
<p dir="auto">Danke jedenfalls für deine Unterstützung. Jetzt ist mein System zumindest wieder aktuell.</p>
]]></description><link>https://forum.iobroker.net/post/760653</link><guid isPermaLink="true">https://forum.iobroker.net/post/760653</guid><dc:creator><![CDATA[Manuel001]]></dc:creator><pubDate>Fri, 11 Feb 2022 18:46:37 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst] node-red-node-serialport geht nicht Node.js v14. on Fri, 11 Feb 2022 19:26:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/manuel001" aria-label="Profile: manuel001">@<bdi>manuel001</bdi></a></p>
<p dir="auto">Irgendwie verfummelst du das System noch weiter...</p>
<pre><code>ls -la /usr/lib/node_modules/
</code></pre>
<p dir="auto">Und installier nochmal sauber nodejs@14.<br />
Lass künftig die Finger von</p>
<blockquote>
<p dir="auto">Run npm install -g npm to update!</p>
</blockquote>
<p dir="auto">Das ist ein schlechter Rat.</p>
]]></description><link>https://forum.iobroker.net/post/760601</link><guid isPermaLink="true">https://forum.iobroker.net/post/760601</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Fri, 11 Feb 2022 19:26:03 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst] node-red-node-serialport geht nicht Node.js v14. on Fri, 11 Feb 2022 16:46:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/manuel001" aria-label="Profile: manuel001">@<bdi>manuel001</bdi></a> sagte in <a href="/post/760578">node-red-node-serialport geht mit Node.js v14.19.0 nicht</a>:</p>
<blockquote>
<p dir="auto">Ja ich mache regelmäßig ein Image von der SD-Card. (das hat mich schon öfter gerettet)</p>
</blockquote>
<p dir="auto">Das ist gut aber lege dir auch Backups nur von ioBroker an. --&gt; BackitUp Adapter</p>
<p dir="auto">Schön wenn es wieder funktioniert und wenn du nicht weisst oder dir sicher bist wo ein Befehl ausgeführt werden muss/soll besser nochmal fragen.</p>
]]></description><link>https://forum.iobroker.net/post/760581</link><guid isPermaLink="true">https://forum.iobroker.net/post/760581</guid><dc:creator><![CDATA[wendy2702]]></dc:creator><pubDate>Fri, 11 Feb 2022 16:46:08 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst] node-red-node-serialport geht nicht Node.js v14. on Fri, 11 Feb 2022 16:43:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wendy2702" aria-label="Profile: wendy2702">@<bdi>wendy2702</bdi></a></p>
<blockquote>
<p dir="auto">sinn hätte es gemacht das rebuild im richtigen Verzeichnis auszuführen und zu lesen was in dem Fenster steht. Du willst bzw. wolltest bestimmt kein update auf NPM8.x machen.</p>
</blockquote>
<p dir="auto">Ich kenne mich da leider nicht aus und kann mir nur mit diesem Forum und Google weiterhelfen. Sorry</p>
<blockquote>
<p dir="auto">Hast du ein Backup von iobroker? Wenn nicht jetzt solltest du eines machen.</p>
</blockquote>
<blockquote>
<p dir="auto">Keine Ahnung ob deine NPM Installation jetzt schon schaden genommen hat.<br />
Vielleicht sicherheitshalber Anhand dieser Anleitung Prüfen</p>
</blockquote>
<p dir="auto">Offensichtlich habe ich nochmal Glück gehabt.</p>
<p dir="auto">Ich habe jetzt gesehen, dass man bei der letzten Version vom NodeRed Adapter in der Adapterkonfiguration wieder Paletten verwalten aktivieren kann. Über das habe ich dann node-red-node-serialport problemlos intallieren können.<br />
Aktuell scheint wieder alles zu funktionieren.<br />
Danke für die Unterstützung!</p>
]]></description><link>https://forum.iobroker.net/post/760578</link><guid isPermaLink="true">https://forum.iobroker.net/post/760578</guid><dc:creator><![CDATA[Manuel001]]></dc:creator><pubDate>Fri, 11 Feb 2022 16:43:47 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst] node-red-node-serialport geht nicht Node.js v14. on Fri, 11 Feb 2022 16:24:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/manuel001" aria-label="Profile: manuel001">@<bdi>manuel001</bdi></a> sinn hätte es gemacht das rebuild im richtigen Verzeichnis auszuführen und zu lesen was in dem Fenster steht. Du willst bzw. wolltest bestimmt kein update auf NPM8.x machen.</p>
<p dir="auto">Dann noch die berechtigungen zu ändern...ganz schlechte Idee.</p>
<p dir="auto">Keine Ahnung ob deine NPM Installation jetzt schon schaden genommen hat.</p>
<p dir="auto">Vielleicht sicherheitshalber Anhand dieser Anleitung Prüfen: <a href="https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian">https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian</a> bzw. einfach neu machen.</p>
<p dir="auto">Den rebuild mal in</p>
<pre><code>/opt/iobroker/
</code></pre>
<p dir="auto">Ausführen und am besten mit zweiter Session zeitgleich in das logfile schauen.</p>
]]></description><link>https://forum.iobroker.net/post/760564</link><guid isPermaLink="true">https://forum.iobroker.net/post/760564</guid><dc:creator><![CDATA[wendy2702]]></dc:creator><pubDate>Fri, 11 Feb 2022 16:24:37 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst] node-red-node-serialport geht nicht Node.js v14. on Fri, 11 Feb 2022 16:06:43 GMT]]></title><description><![CDATA[<p dir="auto">Mit</p>
<pre><code>sudo chown -R $USER /usr/lib/node_modules/
</code></pre>
<p dir="auto">kann man scheinbar mehr Berechtigungen vergeben.<br />
Dann sieht es so aus:</p>
<pre><code>pi@ioBrokerWallbox:~ $ npm rebuild
pi@ioBrokerWallbox:~ $ npm install -g npm
npm ERR! code EACCES
npm ERR! syscall unlink
npm ERR! path /usr/bin/npm
npm ERR! errno -13
npm ERR! Error: EACCES: permission denied, unlink '/usr/bin/npm'
npm ERR!  [OperationalError: EACCES: permission denied, unlink '/usr/bin/npm'] {
npm ERR!   cause: [Error: EACCES: permission denied, unlink '/usr/bin/npm'] {
npm ERR!     errno: -13,
npm ERR!     code: 'EACCES',
npm ERR!     syscall: 'unlink',
npm ERR!     path: '/usr/bin/npm'
npm ERR!   },
npm ERR! }
npm ERR!
npm ERR! The operation was rejected by your operating system.
npm ERR! It is likely you do not have the permissions to access this file as the current user
npm ERR!
npm ERR! If you believe this might be a permissions issue, please double-check the
npm ERR! permissions of the file and its containing directories, or try running
npm ERR! the command again as root/Administrator.
npm ERR!     /home/pi/.npm/_logs/2022-02-11T16_05_03_768Z-debug.log
</code></pre>
]]></description><link>https://forum.iobroker.net/post/760559</link><guid isPermaLink="true">https://forum.iobroker.net/post/760559</guid><dc:creator><![CDATA[Manuel001]]></dc:creator><pubDate>Fri, 11 Feb 2022 16:06:43 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst] node-red-node-serialport geht nicht Node.js v14. on Fri, 11 Feb 2022 15:58:02 GMT]]></title><description><![CDATA[<p dir="auto">Das führt du diesem Problem:</p>
<pre><code>
   │     New major version of npm available! 6.14.16 -&gt; 8.5.0      │
   │   Changelog: https://github.com/npm/cli/releases/tag/v8.5.0   │
   │               Run npm install -g npm to update!               │
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/abbrev
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/ansi-align
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/ansi-regex
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/aproba
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/are-we-there-yet/node_modules/string_decoder
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/asap
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/asn1
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/assert-plus
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/asynckit
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/aws-sign2
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/aws4
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/balanced-match
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/bluebird
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/buffer-from
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/builtins
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/byline
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/byte-size
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/call-limit
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/camelcase
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/capture-stack-trace
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/caseless
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/chownr
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/ci-info
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/cli-boxes
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/cliui/node_modules/ansi-regex
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/cliui/node_modules/is-fullwidth-code-point
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/cliui/node_modules/strip-ansi
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/cliui/node_modules/string-width
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/clone
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/code-point-at
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/color-name
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/color-convert
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/ansi-styles
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/colors
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/concat-map
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/brace-expansion
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/concat-stream/node_modules/string_decoder
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/console-control-strings
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/copy-concurrently/node_modules/aproba
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/copy-concurrently/node_modules/iferr
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/core-util-is
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/create-error-class
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/cross-spawn/node_modules/yallist
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/crypto-random-string
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/cyclist
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/dashdash
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/debug/node_modules/ms
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/debuglog
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/decamelize
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/decode-uri-component
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/deep-extend
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/defaults
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/delayed-stream
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/combined-stream
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/delegates
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/detect-indent
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/detect-newline
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/dotenv
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/duplexer3
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/duplexify/node_modules/string_decoder
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/editor
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/emoji-regex
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/end-of-stream
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/env-paths
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/err-code
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/es6-promise
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/es6-promisify
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/agent-base
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/escape-string-regexp
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/execa/node_modules/get-stream
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/extend
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/extsprintf
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/fast-json-stable-stringify
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/figgy-pudding
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/find-npm-prefix
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/flush-write-stream/node_modules/string_decoder
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/forever-agent
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/from2/node_modules/string_decoder
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/fs-minipass/node_modules/minipass
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/fs-write-stream-atomic/node_modules/iferr
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/fs-write-stream-atomic/node_modules/string_decoder
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/fs.realpath
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/function-bind
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/gauge/node_modules/aproba
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/gauge/node_modules/string-width
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/genfun
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/gentle-fs/node_modules/aproba
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/gentle-fs/node_modules/iferr
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/get-caller-file
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/getpass
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/global-dirs
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/got/node_modules/get-stream
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/graceful-fs
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/har-schema
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/har-validator/node_modules/fast-deep-equal
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/har-validator/node_modules/json-schema-traverse
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/has
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/has-flag
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/has-symbols
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/has-unicode
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/http-cache-semantics
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/http-proxy-agent
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/https-proxy-agent
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/iferr
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/import-lazy
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/imurmurhash
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/infer-owner
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/inherits
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/ini
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/ip
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/ip-regex
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/cidr-regex
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/is-callable
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/is-ci/node_modules/ci-info
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/is-date-object
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/is-npm
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/is-obj
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/dot-prop
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/is-redirect
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/is-regex
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/is-retry-allowed
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/is-stream
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/is-symbol
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/es-to-primitive
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/es-abstract
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/is-typedarray
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/isarray
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/isexe
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/isstream
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/jsbn
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/ecc-jsbn
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/json-parse-better-errors
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/json-schema
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/json-stringify-safe
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/jsonparse
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lazy-property
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/libnpmconfig/node_modules/p-try
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/libnpmconfig/node_modules/p-limit
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/libnpmconfig/node_modules/p-locate
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lock-verify
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lockfile
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lodash._baseindexof
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lodash._bindcallback
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lodash._cacheindexof
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lodash._createset
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lodash._getnative
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lodash._createcache
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lodash._root
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lodash._baseuniq
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lodash.clonedeep
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lodash.restparam
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lodash.union
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lodash.uniq
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lodash.without
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lowercase-keys
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/meant
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/mime-db
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/mime-types
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/form-data
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/minimatch
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/ignore-walk
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/minimist
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/minizlib/node_modules/minipass
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/mkdirp/node_modules/minimist
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/cmd-shim
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/move-concurrently/node_modules/aproba
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/ms
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/humanize-ms
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/agentkeepalive
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/mute-stream
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/node-fetch-npm
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npm-cache-filename
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npm-logical-tree
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npm-normalize-package-bin
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npm-bundled
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npm-registry-fetch/node_modules/safe-buffer
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/number-is-nan
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/is-fullwidth-code-point
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/oauth-sign
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/object-assign
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/object-keys
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/define-properties
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/object.getownpropertydescriptors
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/os-homedir
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/os-tmpdir
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/osenv
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/nopt
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/p-finally
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/pacote/node_modules/minipass
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/parallel-transform/node_modules/string_decoder
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/path-exists
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/libnpmconfig/node_modules/locate-path
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/libnpmconfig/node_modules/find-up
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/path-is-absolute
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/path-is-inside
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/fs-vacuum
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/is-path-inside
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/is-installed-globally
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/path-key
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npm-run-path
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/path-parse
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/normalize-package-data/node_modules/resolve
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/performance-now
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/pify
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/make-dir
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/prepend-http
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/process-nextick-args
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/are-we-there-yet/node_modules/readable-stream
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/concat-stream/node_modules/readable-stream
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/duplexify/node_modules/readable-stream
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/flush-write-stream/node_modules/readable-stream
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/from2/node_modules/readable-stream
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/fs-write-stream-atomic/node_modules/readable-stream
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/parallel-transform/node_modules/readable-stream
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/promise-inflight
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/promise-retry/node_modules/retry
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/proto-list
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/config-chain
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/protoduck
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/prr
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/errno
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/pseudomap
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/cross-spawn/node_modules/lru-cache
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/psl
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/pump
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/get-stream
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/pumpify/node_modules/pump
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/punycode
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/qs
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/qw
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/read
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/promzard
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/read-cmd-shim
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/require-directory
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/require-main-filename
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/resolve-from
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/retry
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/run-queue/node_modules/aproba
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/safe-buffer
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/safer-buffer
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/iconv-lite
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/encoding
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/semver-diff
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/set-blocking
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/sha
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/shebang-regex
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/shebang-command
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/signal-exit
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/slide
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/smart-buffer
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/socks
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/socks-proxy-agent/node_modules/agent-base
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/sorted-object
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/sorted-union-stream/node_modules/isarray
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/sorted-union-stream/node_modules/string_decoder
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/sorted-union-stream/node_modules/readable-stream
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/sorted-union-stream/node_modules/from2
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/spdx-exceptions
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/spdx-license-ids
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/spdx-expression-parse
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/spdx-correct
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/split-on-first
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/stream-iterate/node_modules/string_decoder
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/stream-iterate/node_modules/readable-stream
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/stream-shift
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/stream-each
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/strict-uri-encode
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/query-string
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/string_decoder/node_modules/safe-buffer
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/string-width/node_modules/ansi-regex
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/string-width/node_modules/is-fullwidth-code-point
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/string-width/node_modules/strip-ansi
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/stringify-package
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/strip-ansi
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/strip-eof
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/strip-json-comments
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/rc
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/registry-auth-token
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/registry-url
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/supports-color
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/chalk
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/tar/node_modules/safe-buffer
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/tar/node_modules/yallist
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/tar/node_modules/minipass
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/term-size
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/through
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/JSONStream
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/through2/node_modules/string_decoder
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/through2/node_modules/readable-stream
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/timed-out
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/tough-cookie
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/tunnel-agent
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/tweetnacl
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/bcrypt-pbkdf
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/sshpk
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/typedarray
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/uid-number
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/umask
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npm-lifecycle
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/unique-slug
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/unique-filename
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/unique-string
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/unpipe
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/unzip-response
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/uri-js/node_modules/punycode
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/har-validator/node_modules/ajv
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/url-parse-lax
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/package-json
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/latest-version
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/util-deprecate
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/readable-stream
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/util-extend
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/read-installed
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/util-promisify
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/read-package-tree
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/uuid
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/validate-npm-package-license
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/validate-npm-package-name
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/verror
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/jsprim
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/http-signature
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/request
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/wcwidth
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/which
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/which-module
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/wide-align/node_modules/string-width
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npmlog
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/widest-line
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/boxen
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/worker-farm
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/libcipm
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/wrap-ansi/node_modules/ansi-regex
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/wrap-ansi/node_modules/is-fullwidth-code-point
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/wrap-ansi/node_modules/strip-ansi
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/wrap-ansi/node_modules/string-width
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/wrappy
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/dezalgo
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/once
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/inflight
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npm-packlist
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/rimraf
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/readdir-scoped-modules
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/write-file-atomic
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/bin-links
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/xdg-basedir
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/configstore
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/update-notifier
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/xtend
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/mississippi
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/y18n
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/yallist
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lru-cache
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/hosted-git-info
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/read-package-json
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npm-install-checks
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npm-package-arg
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npm-pick-manifest
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/ssri
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/cacache
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/make-fetch-happen
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/node-gyp
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/yargs-parser/node_modules/camelcase
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/yargs/node_modules/ansi-regex
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/yargs/node_modules/is-fullwidth-code-point
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/yargs/node_modules/p-try
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/yargs/node_modules/p-limit
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/yargs/node_modules/p-locate
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/yargs/node_modules/locate-path
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/yargs/node_modules/find-up
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/yargs/node_modules/strip-ansi
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/yargs/node_modules/string-width
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/libnpx
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/ansicolors
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/ansistyles
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/archy
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/cli-columns
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/cli-table3
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/columnify
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/init-package-json
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/is-cidr
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/libnpmaccess
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/libnpmhook
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/libnpmorg
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/libnpmpublish
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/libnpmsearch
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/libnpmteam
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npm-audit-report
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npm-profile
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npm-user-validate
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/opener
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/qrcode-terminal
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/text-table
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/tiny-relative-date
npm ERR! syscall access
npm ERR! path /usr/lib/node_modules/npm/node_modules/abbrev
npm ERR! errno -13
npm ERR! Error: EACCES: permission denied, access '/usr/lib/node_modules/npm/node_modules/abbrev'
npm ERR!  [Error: EACCES: permission denied, access '/usr/lib/node_modules/npm/node_modules/abbrev'] {
npm ERR!   syscall: 'access',
npm ERR!   path: '/usr/lib/node_modules/npm/node_modules/abbrev'
npm ERR! }
npm ERR!
npm ERR!
npm ERR!     /home/pi/.npm/_logs/2022-02-11T15_56_54_055Z-debug.log
</code></pre>
<p dir="auto">Wie kann man das umgehen? Scheint ein Berechtigungsproblem zu sein.</p>
]]></description><link>https://forum.iobroker.net/post/760544</link><guid isPermaLink="true">https://forum.iobroker.net/post/760544</guid><dc:creator><![CDATA[Manuel001]]></dc:creator><pubDate>Fri, 11 Feb 2022 15:58:02 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst] node-red-node-serialport geht nicht Node.js v14. on Fri, 11 Feb 2022 15:16:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/manuel001" aria-label="Profile: manuel001">@<bdi>manuel001</bdi></a> sagte in <a href="/post/760514">node-red-node-serialport geht mit Node.js v14.19.0 nicht</a>:</p>
<blockquote>
<p dir="auto">Please try re-compiling or re-installing the module (for instance, using <code>npm rebuild</code> or <code>npm install</code>).</p>
</blockquote>
<p dir="auto">Mal probiert?</p>
]]></description><link>https://forum.iobroker.net/post/760538</link><guid isPermaLink="true">https://forum.iobroker.net/post/760538</guid><dc:creator><![CDATA[wendy2702]]></dc:creator><pubDate>Fri, 11 Feb 2022 15:16:10 GMT</pubDate></item></channel></rss>
