  4. Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T
    6.7k
17trackamazonbriefedhldpdglsups
1.6k Beiträge 129 Kommentatoren 729.1k Aufrufe 117 Beobachtet
  • T tombox
    @chaot Wäre nur gut zu wissen ob variante 2 auch reichen würde
    ChaotC Offline
    ChaotC Offline
    Chaot
    #209
    @tombox Kannst damit was anfangen:
    haus@ioBroker:~$ sudo apt-get install libnss3 libatk1.0-0 libatk-bridge2.0-0 libcups2 libdrm-dev libxkbcommon-dev libxcomposite1 libxdamage1 libxfixes3 libxrandr2 libgbm-dev
    Reading package lists... Done
    Building dependency tree
    libatk1.0-0 is already the newest version (2.35.1-1ubuntu2).
    libxcomposite1 is already the newest version (1:0.4.5-1).
    libxdamage1 is already the newest version (1:1.1.5-2).
    libxfixes3 is already the newest version (1:5.0.3-2).
    libxrandr2 is already the newest version (2:1.5.2-0ubuntu1).
    libatk-bridge2.0-0 is already the newest version (2.34.2-0ubuntu2~20.04.1).
    libcups2 is already the newest version (2.3.1-9ubuntu1.1).
    libnss3 is already the newest version (2:3.49.1-1ubuntu1.6).
    The following additional packages will be installed:
      libgbm1 libwayland-server0
    The following NEW packages will be installed:
      libdrm-dev libgbm-dev libgbm1 libwayland-server0 libxkbcommon-dev
    0 upgraded, 5 newly installed, 0 to remove and 0 not upgraded.
    Need to get 246 kB of archives.
    After this operation, 1349 kB of additional disk space will be used.
    Do you want to continue? [Y/n] y
    Get:1 http://archive.ubuntu.com/ubuntu focal-updates/main amd64 libdrm-dev amd64 2.4.105-3~20.04.2 [131 kB]
    Get:2 http://archive.ubuntu.com/ubuntu focal/main amd64 libwayland-server0 amd64 1.18.0-1 [31.6 kB]
    Get:3 http://archive.ubuntu.com/ubuntu focal-updates/main amd64 libgbm1 amd64 21.0.3-0ubuntu0.3~20.04.5 [28.7 kB]
    Get:4 http://archive.ubuntu.com/ubuntu focal-updates/main amd64 libgbm-dev amd64 21.0.3-0ubuntu0.3~20.04.5 [9088 B]
    Get:5 http://archive.ubuntu.com/ubuntu focal/main amd64 libxkbcommon-dev amd64 0.10.0-1 [45.4 kB]
    Fetched 246 kB in 0s (823 kB/s)
    Selecting previously unselected package libdrm-dev:amd64.
    (Reading database ... 57296 files and directories currently installed.)
    Preparing to unpack .../libdrm-dev_2.4.105-3~20.04.2_amd64.deb ...
    Unpacking libdrm-dev:amd64 (2.4.105-3~20.04.2) ...
    Selecting previously unselected package libwayland-server0:amd64.
    Preparing to unpack .../libwayland-server0_1.18.0-1_amd64.deb ...
    Unpacking libwayland-server0:amd64 (1.18.0-1) ...
    Selecting previously unselected package libgbm1:amd64.
    Preparing to unpack .../libgbm1_21.0.3-0ubuntu0.3~20.04.5_amd64.deb ...
    Unpacking libgbm1:amd64 (21.0.3-0ubuntu0.3~20.04.5) ...
    Selecting previously unselected package libgbm-dev:amd64.
    Preparing to unpack .../libgbm-dev_21.0.3-0ubuntu0.3~20.04.5_amd64.deb ...
    Unpacking libgbm-dev:amd64 (21.0.3-0ubuntu0.3~20.04.5) ...
    Selecting previously unselected package libxkbcommon-dev:amd64.
    Preparing to unpack .../libxkbcommon-dev_0.10.0-1_amd64.deb ...
    Unpacking libxkbcommon-dev:amd64 (0.10.0-1) ...
    Setting up libwayland-server0:amd64 (1.18.0-1) ...
    Setting up libdrm-dev:amd64 (2.4.105-3~20.04.2) ...
    Setting up libgbm1:amd64 (21.0.3-0ubuntu0.3~20.04.5) ...
    Setting up libxkbcommon-dev:amd64 (0.10.0-1) ...
    Setting up libgbm-dev:amd64 (21.0.3-0ubuntu0.3~20.04.5) ...
    Processing triggers for man-db (2.9.1-1) ...
    Processing triggers for libc-bin (2.31-0ubuntu9.3) ...
    • T tombox
      @liv-in-sky die ohne status wäre noch gut zu wissen was da auf der lieferung verfolgen seite angezeigt wird.
      Tja es werden die ersten 10 auf der bestellseite genommen also archivieren würde auch nicht helfen
      liv-in-skyL Offline
      liv-in-skyL Offline
      #210
      @tombox die sind auch richtig - bis auf das 2 nicht als geliefert angezeigt werden
      • T tombox
        liv-in-skyL Offline
        liv-in-skyL Offline
        #211
        @tombox
        ps: cool , wie du das eingepflegt hast :-)
        • FlexerF Offline
          FlexerF Offline
          Flexer
          schrieb am zuletzt editiert von Flexer
          #212
          @tombox Alter Schwede! Variante 2 hat dann geklappt! Der Login dauert recht lange. Siehe Log. Er hat bis jetzt nur einen leeren Amazon Ordner erstellt obwohl Sendungen unterwegs sind.
          Unterm Strich ist alles besser.
          Ja, voll geil hier!
          • T tombox
            ChaotC Offline
            ChaotC Offline
            Chaot
            #213
            @tombox
            Ein Paket das aktuell in der Zustellung ist:
            Scheint so als würde Amazon das nur bedingt richtig wiedergeben.
            • T tombox
              liv-in-skyL Offline
              liv-in-skyL Offline
              #214
              @tombox das mit dem "unter all providers im json " kommt sicher noch :-)
              • FlexerF Flexer
                @tombox sagte in Test Adapter parcel Paketverfolgung DHL v0.0.1:
                sudo apt-get install libpango
                Da bekomme ich folgendes
                E: Unable to locate package libpango
                #215
                @flexer sagte in Test Adapter parcel Paketverfolgung DHL v0.0.1:
                Das Paket heißt (unter Debian Bullseye) auch libpango-1.0-0 oder (alte Bezeichnung) libpango1.0-0
                • FlexerF Flexer
                  tombox
                  #216
                  @flexer Ich habe den fehlerfall wie bei dir nochmal verbessert
                  • ChaotC Chaot
                    @tombox
                    tombox
                    #217
                    @chaot Der Adapter zeigt an was auf der Webseite zu sehen ist. Falls da andere Informationen stehen bescheid sagen
                    • T tombox
                      ChaotC Offline
                      ChaotC Offline
                      Chaot
                      #218
                      @tombox Auf der Webseite stand zu dem Zeitpunkt "Zustellung heute 14:00 - 17:00 Uhr"
                      Interessant - Paket ist geliefert und die Zeile ist leer.
                      • FlexerF Offline
                        FlexerF Offline
                        Flexer
                        #219
                        OK habe Amazon jetzt zum laufen bekommen aber nur mit dem Amz Konto meiner Frau. Warum auch immer. Werde heute Abend nochmal mein Konto testen. Sind das alle Daten die man bekommt oder ist da noch mehr?
                        Finde den Adapter super genial!
                        Ja, voll geil hier!
                        • FlexerF Offline
                          FlexerF Offline
                          Flexer
                          #220
                          So nach etwas testen konnte ich ein gutes Script für Telegram entwerfen.
                          Bitte testen und bei mir melden.
                          Die Funktion ob ein neues Paket erkannt wurde habe ich deaktiviert.
                          DHL_TelegramV0.7RC.txt
                          Ja, voll geil hier!
                          • Jabba_the_HuttJ Offline
                            Jabba_the_Hutt
                            #221
                            Bei mir mault er bei Amazon wegen der sandbox. Aber das hat mit Proxmox zu tun ;)
                            • BjoernFB Offline
                              BjoernFB Offline
                              BjoernF
                              #222
                              @tombox mir ist aufgefallen, dass in der "allproviderJSON" bei NAME ein mix aus Absender und Empfänger angezeigt wird.
                              Ich habe ausgehende als auch eingehende Sendungen. Wäre super wenn man beides in die JSON bekommen würde. Ggf. noch den Datenpunkt SENDUNGSRICHTUNG :-) dann könnte man so gar noch nach filtern.
                              BjoernFB 1 Antwort Letzte Antwort
                              • T tombox
                                Ich habe mal testweise Amazon Anbindung eingebaut
                                #223
                                @tombox Ich bekomme zu Amazon rein garnichts angezeigt in den Einstellungen. Nur zu DHL, DPD, 17track.
                                  tombox
                                  #224
                                  @thomas-braun Sollte eigentlich angezeigt werden wenn die aktuelle version installiert ist
                                  • T tombox
                                    #225
                                    @tombox
                                    Müsste aktuell sein. Hab es eben nochmal reingezogen:
                                    iobroker.parcel@0.0.1 (git+ssh://git@github.com/TA2k/ioBroker.parcel.git#e64cba6d4c582c91b9d59f1bb262adb58a18a0a5)
                                    Dafür muss ja wohl hoffentlich kein X-Server laufen? Sind mir schon 'verdächtig viele' Pakete mit x im Namen dabei.
                                      @tombox
                                      tombox
                                      #226
                                      @thomas-braun Nein nur die dependencies um ein chromium zum laufen zu bekommen geht leider nicht anders.
                                      letzter commit ist eigentlich dfc2068a8772a670fe6e53a2203a13765b34fe7f
                                      Jabba_the_HuttJ Thomas BraunT 2 Antworten Letzte Antwort
                                      • T tombox
                                        Jabba_the_Hutt
                                        #227
                                        @tombox
                                        chromium mit --no-sandbox wäre toll ;)
                                        Genau die Angst hatte ich auch bzgl. X-Server und so g
                                        • T tombox
                                          #228
                                          @tombox
                                          Hmm... Irgendwas stimmt doch bei mir dann nicht...
                                          2022-02-07 21:22:44.423  - info: host.chet iobroker install TA2k/ioBroker.parcel#dfc2068a8772a670fe6e53a2203a13765b34fe7f
                                          2022-02-07 21:22:45.293  - info: host.chet iobroker NPM version: 8.3.1
                                          2022-02-07 21:22:45.295  - info: host.chet iobroker Installing TA2k/ioBroker.parcel#dfc2068a8772a670fe6e53a2203a13765b34fe7f... (System call)
                                          Aber:
                                          npm ls bringt danach weiterhin:
                                          ├── iobroker.parcel@0.0.1 (git+ssh://git@github.com/TA2k/ioBroker.parcel.git#e64cba6d4c582c91b9d59f1bb262adb58a18a0a5)
