  3. Cloud Dienste
  4. iot Adapter bleibt gelb, "undefined" Fehlermeldung im Log
    6.5k
23 Beiträge 4 Kommentatoren 1.9k Aufrufe 3 Beobachtet
  • F fraso
    Update durch.
    Habe den iot.0 gelöscht, neu installiert. Dann eben den "Verbindungszertifikat" Button geklickt. Keine Änderung. Er bleibt gelb.
    Fehlermeldungen im Log:
    2022-02-04 17:36:15.881 - info: host.NUCioBroker "system.adapter.iot.0" enabled
    2022-02-04 17:36:15.927 - info: host.NUCioBroker instance system.adapter.iot.0 started with pid 11530
    2022-02-04 17:36:17.151 - info: iot.0 (11530) starting. Version 1.9.3 in /opt/iobroker/node_modules/iobroker.iot, node: v14.19.0, js-controller: 3.3.22
    2022-02-04 17:36:17.184 - info: iot.0 (11530) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
    2022-02-04 17:36:17.662 - error: iot.0 (11530) Error in main: TypeError: Cannot read property 'certificates' of undefined
    2022-02-04 17:36:20.005 - info: javascript.0 (8923) script.js.E6-HAUS.SICHERHEIT.CAM_AUTOSEND: /var/lib/motioneye/Camera6/2022-02-04/17-23.mp4
    2022-02-04 17:36:26.774 - info: host.NUCioBroker stopInstance system.adapter.iot.0 (force=false, process=true)
    2022-02-04 17:36:26.777 - info: host.NUCioBroker stopInstance system.adapter.iot.0 send kill signal
    2022-02-04 17:36:26.777 - info: iot.0 (11530) Got terminate signal TERMINATE_YOURSELF
    2022-02-04 17:36:26.778 - info: iot.0 (11530) terminating
    2022-02-04 17:36:26.779 - info: iot.0 (11530) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2022-02-04 17:36:27.339 - info: host.NUCioBroker instance system.adapter.iot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2022-02-04 17:36:29.826 - info: host.NUCioBroker instance system.adapter.iot.0 started with pid 11657
    2022-02-04 17:36:30.003 - info: javascript.0 (8923) script.js.E6-HAUS.SICHERHEIT.CAM_AUTOSEND: /var/lib/motioneye/Camera6/2022-02-04/17-23.mp4
    2022-02-04 17:36:30.848 - info: iot.0 (11657) starting. Version 1.9.3 in /opt/iobroker/node_modules/iobroker.iot, node: v14.19.0, js-controller: 3.3.22
    2022-02-04 17:36:30.870 - info: iot.0 (11657) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
    2022-02-04 17:36:31.322 - error: iot.0 (11657) Error in main: TypeError: Cannot read property 'certificates' of undefined
    Hier aktueller Stand:
    e6iob@NUCioBroker:~$ which nodejs node npm && nodejs -v && node -v && npm -v && apt policy nodejs
    /usr/bin/nodejs
    /usr/bin/node
    /usr/bin/npm
    v14.19.0
    v14.19.0
    6.14.16
    nodejs:
      Installiert:           14.19.0-deb-1nodesource1
      Installationskandidat: 14.19.0-deb-1nodesource1
      Versionstabelle:
     *** 14.19.0-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_14.x bullseye/main amd64 Packages
         12.22.5~dfsg-2~11u1 500
            500 http://deb.debian.org/debian bullseye/main amd64 Packages
            500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
    e6iob@NUCioBroker:~$ iobroker update
    Used repository: beta
    hash unchanged, use cached sources
    update done
    Adapter    "admin"         : 5.2.3    , installed 5.2.3
    Adapter    "alexa2"        : 3.12.0   , installed 3.12.0
    Adapter    "backitup"      : 2.2.4    , installed 2.2.4
    Adapter    "bydhvs"        : 1.3.0    , installed 1.3.0
    Adapter    "cloud"         : 4.1.0    , installed 4.1.0
    Adapter    "devices"       : 1.0.9    , installed 1.0.9
    Adapter    "discovery"     : 2.7.5    , installed 2.7.5
    Adapter    "fb-checkpresence": 1.1.13  , installed 1.1.13
    Adapter    "flot"          : 1.10.7   , installed 1.10.7
    Adapter    "fritzdect"     : 2.2.3    , installed 2.2.3
    Adapter    "habpanel"      : 0.4.3    , installed 0.4.3
    Adapter    "ham"           : 4.0.2    , installed 4.0.2
    Adapter    "history"       : 1.10.5   , installed 1.10.5
    Adapter    "hm-rega"       : 3.0.35   , installed 3.0.35
    Adapter    "hm-rpc"        : 1.15.2   , installed 1.15.2
    Adapter    "hs100"         : 2.0.7    , installed 2.0.7
    Adapter    "ical"          : 1.11.6   , installed 1.11.6
    Adapter    "icons-mfd-png" : 1.0.2    , installed 1.0.2
    Adapter    "influxdb"      : 2.4.0    , installed 2.4.0
    Adapter    "iot"           : 1.9.3    , installed 1.9.3
    Adapter    "javascript"    : 5.2.21   , installed 5.2.21
    Controller "js-controller" : 3.3.22   , installed 3.3.22
    Adapter    "mqtt"          : 2.4.1    , installed 2.4.1
    Adapter    "node-red"      : 2.4.1    , installed 2.4.1
    Adapter    "parser"        : 1.0.7    , installed 1.0.7
    Adapter    "ping"          : 1.5.2    , installed 1.5.2
    Adapter    "ring"          : 1.2.8    , installed 1.2.8
    Adapter    "shelly"        : 5.1.2    , installed 5.1.2
    Adapter    "simple-api"    : 2.6.2    , installed 2.6.2
    Adapter    "socketio"      : 4.1.0    , installed 4.1.0
    Adapter    "systeminfo"    : 0.3.1    , installed 0.3.1
    Adapter    "telegram"      : 1.11.1   , installed 1.11.1
    Adapter    "text2command"  : 2.1.1    , installed 2.1.1
    Adapter    "vis"           : 1.4.8    , installed 1.4.8
    Adapter    "vis-jqui-mfd"  : 1.0.12   , installed 1.0.12
    Adapter    "vis-weather"   : 2.5.5    , installed 2.5.5
    Adapter    "web"           : 4.1.1    , installed 4.1.1
    Adapter    "whatsapp-cmb"  : 0.1.6    , installed 0.1.6
    Adapter    "yeelight-2"    : 1.1.2    , installed 1.1.2
    Adapter    "zigbee"        : 1.6.14   , installed 1.6.14
    @fraso sagte in iot Adapter bleibt gelb, "undefined" Fehlermeldung im Log:
    Und in der stable hast du den Fehler nicht?
    Dann mach ein Issue auf.
    F 1 Antwort Letzte Antwort
      fraso
      Ich deinstalliert mal den iot.0 und installiere den stable bevor ich das mache.
      Macht das Sinn?
      • F fraso
        Macht das Sinn?
        Macht das Sinn?
        nur wenn du alles auf stable hast, was da einen Einfluss haben könnte
        • F fraso
          Macht das Sinn?
          Macht das Sinn?
          Um heraus zu finden ob der Fehler in der Beta-Version eingeführt wurde macht das schon Sinn.
            Macht das Sinn?
            fraso
            Ich habe 1.9.3 deinstalliert. Dann auf latest umgestellt. Dann versucht den Adapter neu zu installieren mit 1.8.??. Installiert wurde wieder der 1.9.3
            Wie geht das sonst richtig? Danke.
            • F fraso
              @fraso
              iobroker upgrade iot@1.8.24
              • F fraso
                Du weißt schon, dass latest der beta-Zweig ist?
                • F Offline
                  fraso
                  ja. jetzt 🤕
                  • F Offline
                    fraso
                    @fraso
                    Ist installiert.
                    Der Adapter ist grün.
                    Die iot.0.certs sind jetzt auch ausgefüllt.
                    Alexa Skill deaktiviert, neu aktiviert - Geräte suchen-> Geräte da.
                    • F fraso
                      @fraso
                      Ist installiert.
                      @fraso
                      Dann hast du beim Beta-Testing wohl einen Fehler entdeckt.
                      Mach ein Issue auf.
                        @fraso
                        Mach ein Issue auf.
                        fraso
                        Na dafür machen wir das doch. 😬
                        • F fraso
                          @fraso
                          Davon bin ich überzeugt.
                            @fraso
                            fraso
                            erledigt (mein erstes Issue).
                            Ich hoffe alles so wie es sein soll.
                            • F Offline
                              fraso
                              @fraso
                              Wie immer - den Beteiligten ganz ganz herzlichen Dank.
