  4. Kann keine Adapter mehr aktualisieren.
    1.0k
    6.1k
16 Beiträge 3 Kommentatoren 1.5k Aufrufe 2 Beobachtet
  • GlasfaserG Glasfaser
    @friemelkarl
    Zeige mal was du hast :
    iobroker update -i
    iobroker list instances
    iobroker status
    iobroker version
    which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && sudo apt update && apt policy nodejs
    Ausgabe in Code-Tags </> setzen , komplett mit ein und Ausgabe
    friemelkarl
    @glasfaser
    root@Iobrokercontainer:~# iobroker update -i
    Used repository: stable
    hash unchanged, use cached sources
    update done
    Adapter    "admin"         : 5.2.3    , installed 5.2.3
    Adapter    "alexa2"        : 3.11.2   , installed 3.11.2
    Adapter    "daswetter"     : 3.0.9    , installed 3.0.9
    Adapter    "deconz"        : 1.3.19   , installed 1.3.19
    Adapter    "discovery"     : 2.7.3    , installed 2.7.3
    Adapter    "dwd"           : 2.7.7    , installed 2.7.7
    Adapter    "fb-checkpresence": 1.1.12  , installed 1.1.11 [Updateable]
    Adapter    "habpanel"      : 0.4.3    , installed 0.4.3
    Adapter    "ical"          : 1.11.4   , installed 1.11.4
    Adapter    "icons-addictive-flavour-png": 0.1.0   , installed 0.1.0
    Adapter    "icons-icons8"  : 0.0.1    , installed 0.0.1
    Adapter    "icons-material-png": 0.1.0   , installed 0.1.0
    Adapter    "icons-material-svg": 0.1.0   , installed 0.1.0
    Adapter    "icons-mfd-png" : 1.0.2    , installed 1.0.2
    Adapter    "icons-mfd-svg" : 1.0.2    , installed 1.0.2
    Adapter    "icons-open-icon-library-png": 0.1.2   , installed 0.1.2
    Adapter    "icons-ultimate-png": 1.0.1   , installed 1.0.1
    Adapter    "influxdb"      : 1.9.5    , installed 2.4.0
    Adapter    "info"          : 1.9.8    , installed 1.9.8
    Adapter    "javascript"    : 5.2.13   , installed 5.2.13
    Controller "js-controller" : 3.3.22   , installed 3.3.22
    Adapter    "lovelace"      : 2.0.6    , installed 2.0.6
    Adapter    "loxone"        : 3.0.0    , installed 2.2.3 [Updateable]
    Adapter    "mobile"        : 1.0.1    , installed 1.0.1
    Adapter    "moma"          : 1.2.9    , installed 1.2.9
    Adapter    "mqtt"          : 2.4.0    , installed 2.4.0
    Adapter    "mqtt-client"   : 1.4.0    , installed 1.4.0
    Adapter    "net-tools"     : 0.1.7    , installed 0.1.7
    Adapter    "node-red"      : 2.4.1    , installed 2.4.1
    Adapter    "openweathermap": 0.1.0    , installed 0.1.0
    Adapter    "proxmox"       : 1.3.4    , installed 1.3.4
    Adapter    "proxy"         : 1.2.2    , installed 1.2.2
    Adapter    "simple-api"    : 2.6.1    , installed 2.6.1
    Adapter    "smartmeter"    : 3.2.1    , installed 3.2.1
    Adapter    "socketio"      : 3.1.4    , installed 3.1.4
    Adapter    "sonoff"        : 2.4.5    , installed 2.4.5
    Adapter    "sonos"         : 2.1.1    , installed 2.1.1
    Adapter    "sql"           : 1.15.7   , installed 1.15.7
    Adapter    "statistics"    : 1.0.9    , installed 1.0.9
    Adapter    "telegram"      : 1.10.0   , installed 1.10.0
    Adapter    "tr-064"        : 4.2.14   , installed 4.2.14
    Adapter    "upnp"          : 1.0.19   , installed 1.0.19
    Adapter    "vis"           : 1.4.5    , installed 1.4.5
    Adapter    "vis-bars"      : 0.1.4    , installed 0.1.4
    Adapter    "vis-canvas-gauges": 0.1.5   , installed 0.1.5
    Adapter    "vis-fancyswitch": 1.1.0   , installed 1.1.0
    Adapter    "vis-google-fonts": 0.1.0   , installed 0.1.0
    Adapter    "vis-history"   : 1.0.0    , installed 1.0.0
    Adapter    "vis-hqwidgets" : 1.1.7    , installed 1.1.7
    Adapter    "vis-inventwo"  : 3.2.5    , installed 3.2.0 [Updateable]
    Adapter    "vis-jqui-mfd"  : 1.0.12   , installed 1.0.12
    Adapter    "vis-justgage"  : 1.0.2    , installed 1.0.2
    Adapter    "vis-keyboard"  : 0.0.2    , installed 0.0.2
    Adapter    "vis-map"       : 1.0.4    , installed 1.0.4
    Adapter    "vis-material-advanced": 1.7.2   , installed 1.7.2
    Adapter    "vis-metro"     : 1.1.2    , installed 1.1.2
    Adapter    "vis-players"   : 0.1.6    , installed 0.1.6
    Adapter    "vis-plumb"     : 1.0.2    , installed 1.0.2
    Adapter    "vis-rgraph"    : 0.0.2    , installed 0.0.2
    Adapter    "vis-weather"   : 2.5.5    , installed 2.5.5
    Adapter    "web"           : 3.4.9    , installed 3.4.9
    Adapter    "worx"          : 1.5.5    , installed 1.5.5
      @friemelkarl
      iobroker update -i
      iobroker status
      iobroker version
      friemelkarl
      @glasfaser sagte in Kann keine Adapter mehr aktualisieren.:
      root@Iobrokercontainer:~# iobroker list instances
      + system.adapter.admin.0                  : admin                 : Iobrokercontainer                        -  enabled, port: 8081, bind: 192.168.0.143, run as: admin
      + system.adapter.alexa2.0                 : alexa2                : Iobrokercontainer                        -  enabled
        system.adapter.daswetter.0              : daswetter             : Iobrokercontainer                        -  enabled
      + system.adapter.discovery.0              : discovery             : Iobrokercontainer                        -  enabled
        system.adapter.dwd.0                    : dwd                   : Iobrokercontainer                        -  enabled
      + system.adapter.fb-checkpresence.0       : fb-checkpresence      : Iobrokercontainer                        -  enabled
        system.adapter.ical.0                   : ical                  : Iobrokercontainer                        -  enabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : Iobrokercontainer                        -  enabled
        system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : Iobrokercontainer                        -  enabled
      + system.adapter.influxdb.2               : influxdb              : Iobrokercontainer                        -  enabled, port: 8086
      + system.adapter.influxdb.3               : influxdb              : Iobrokercontainer                        -  enabled, port: 8086
      + system.adapter.info.0                   : info                  : Iobrokercontainer                        -  enabled
      + system.adapter.javascript.0             : javascript            : Iobrokercontainer                        -  enabled
      + system.adapter.loxone.0                 : loxone                : Iobrokercontainer                        -  enabled, port: 80
        system.adapter.mobile.0                 : mobile                : Iobrokercontainer                        - disabled
      + system.adapter.mqtt-client.0            : mqtt-client           : Iobrokercontainer                        -  enabled, port: 1883
      + system.adapter.net-tools.0              : net-tools             : Iobrokercontainer                        -  enabled
      + system.adapter.node-red.0               : node-red              : Iobrokercontainer                        -  enabled, port: 1880, bind: 192.168.0.143
        system.adapter.openweathermap.0         : openweathermap        : Iobrokercontainer                        -  enabled
      + system.adapter.proxmox.0                : proxmox               : Iobrokercontainer                        -  enabled, port: 8006
      + system.adapter.smartmeter.1             : smartmeter            : iobrokerVM                               -  enabled
      + system.adapter.smartmeter.2             : smartmeter            : iobrokerVM                               -  enabled
      + system.adapter.socketio.0               : socketio              : Iobrokercontainer                        -  enabled, port: 8084, bind: 192.168.0.143, run as: admin
      + system.adapter.sonoff.0                 : sonoff                : Iobrokercontainer                        -  enabled, port: 1883, bind: 192.168.0.143
      + system.adapter.sonos.0                  : sonos                 : Iobrokercontainer                        -  enabled
      + system.adapter.statistics.0             : statistics            : Iobrokercontainer                        -  enabled
      + system.adapter.telegram.0               : telegram              : Iobrokercontainer                        -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.tr-064.0                 : tr-064                : Iobrokercontainer                        -  enabled
      + system.adapter.upnp.0                   : upnp                  : Iobrokercontainer                        -  enabled
        system.adapter.vis-bars.0               : vis-bars              : Iobrokercontainer                        -  enabled
        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : Iobrokercontainer                        -  enabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : Iobrokercontainer                        -  enabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : Iobrokercontainer                        -  enabled
        system.adapter.vis-keyboard.0           : vis-keyboard          : Iobrokercontainer                        -  enabled
        system.adapter.vis-map.0                : vis-map               : Iobrokercontainer                        -  enabled
        system.adapter.vis-material-advanced.0  : vis-material-advanced : Iobrokercontainer                        -  enabled
        system.adapter.vis-metro.0              : vis-metro             : Iobrokercontainer                        -  enabled
        system.adapter.vis-players.0            : vis-players           : Iobrokercontainer                        -  enabled
        system.adapter.vis-plumb.0              : vis-plumb             : Iobrokercontainer                        -  enabled
        system.adapter.vis-rgraph.0             : vis-rgraph            : Iobrokercontainer                        -  enabled
        system.adapter.vis-weather.0            : vis-weather           : Iobrokercontainer                        -  enabled
        system.adapter.vis.0                    : vis                   : Iobrokercontainer                        -  enabled
      + system.adapter.web-speedy.0             : web-speedy            : Iobrokercontainer                        -  enabled
      + system.adapter.web.0                    : web                   : Iobrokercontainer                        -  enabled, port: 8082, bind: 192.168.0.143, run as: admin
        system.adapter.worx.0                   : worx                  : Iobrokercontainer                        - disabled
      + instance is alive
      • F friemelkarl
        @glasfaser
        update done
        GlasfaserG Offline
        GlasfaserG Offline
        @friemelkarl sagte in Kann keine Adapter mehr aktualisieren.:
        root
        nicht als root
        und wo ist der Rest
        F GlasfaserG 2 Antworten Letzte Antwort
          root
          nicht als root
          und wo ist der Rest
          friemelkarl
          @Glasfaser
          root@Iobrokercontainer:~# iobroker status
          Objects type: file
          States  type: file
            @friemelkarl
            iobroker update -i
            iobroker status
            iobroker version
            friemelkarl
            iobroker version
            root@Iobrokercontainer:~# iobroker version
            3.3.22
              @friemelkarl
              iobroker update -i
              iobroker status
              iobroker version
              friemelkarl
              @glasfaser
              root@Iobrokercontainer:~# sudo ln -s /usr/bin/node /usr/bin/nodejs
              ln: failed to create symbolic link '/usr/bin/nodejs': File exists
                @friemelkarl
                iobroker update -i
                iobroker status
                iobroker version
                friemelkarl
                @glasfaser
                root@Iobrokercontainer:~# which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && sudo apt update && apt policy nodejs
                /usr/bin/nodejs
                /usr/bin/node
                /usr/bin/npm
                v14.16.1
                v14.16.1
                6.14.12
                Hit http://security.debian.org jessie/updates InRelease
                Ign http://ftp.debian.org jessie InRelease
                Hit http://ftp.debian.org jessie-updates InRelease
                Hit http://ftp.debian.org jessie Release.gpg
                Hit http://security.debian.org jessie/updates/main amd64 Packages
                Hit http://security.debian.org jessie/updates/contrib amd64 Packages
                Hit http://ftp.debian.org jessie-updates/main amd64 Packages
                Hit http://security.debian.org jessie/updates/contrib Translation-en
                Hit http://ftp.debian.org jessie-updates/contrib amd64 Packages
                Hit http://security.debian.org jessie/updates/main Translation-en
                Hit http://ftp.debian.org jessie-updates/contrib Translation-en
                Hit https://deb.nodesource.com jessie InRelease
                Hit http://ftp.debian.org jessie-updates/main Translation-en
                Hit https://deb.nodesource.com jessie/main Sources
                Hit https://deb.nodesource.com jessie/main amd64 Packages
                Get:1 https://deb.nodesource.com jessie/main Translation-en [162 B]
                Get:2 https://deb.nodesource.com jessie/main Translation-en [162 B]
                Get:3 https://deb.nodesource.com jessie/main Translation-en [162 B]
                Get:4 https://deb.nodesource.com jessie/main Translation-en [162 B]
                Get:5 https://deb.nodesource.com jessie/main Translation-en [162 B]
                Ign https://deb.nodesource.com jessie/main Translation-en
                Hit http://ftp.debian.org jessie/main amd64 Packages
                Hit http://ftp.debian.org jessie/contrib amd64 Packages
                Hit http://ftp.debian.org jessie/contrib Translation-en
                Hit http://ftp.debian.org jessie/main Translation-en
                Reading package lists... Done
                Building dependency tree
                All packages are up to date.
                E: Invalid operation policy
                  root
                  nicht als root
                  und wo ist der Rest
                  GlasfaserG Offline
                  GlasfaserG Offline
                  @friemelkarl
                  Noch mal .....
                  nicht als root ... melde dich als User an.
                  F 1 Antwort Letzte Antwort
                  • F friemelkarl
                    @glasfaser
                    /usr/bin/nodejs
                    /usr/bin/node
                    /usr/bin/npm
                    v14.16.1
                    v14.16.1
                    6.14.12
                    jessie
                    Ist schon zwei mal tot. Bring dein System auf was lebendiges.
                      @friemelkarl
                      Noch mal .....
                      friemelkarl
                      @glasfaser
                      andy@Iobrokercontainer:~$ iobroker update -i
                      update done
                      andy@Iobrokercontainer:~$ iobroker list instances
                      + instance is alive
                      andy@Iobrokercontainer:~$ iobroker status
                      Objects type: file
                      States  type: file
                      andy@Iobrokercontainer:~$ iobroker version
                      3.3.22
                      andy@Iobrokercontainer:~$ sudo ln -s /usr/bin/node /usr/bin/nodejs
                      [sudo] password for andy:
                      Sorry, user andy is not allowed to execute '/bin/ln -s /usr/bin/node /usr/bin/nodejs' as root on Iobrokercontainer.192.168.0.1.
                      andy@Iobrokercontainer:~$ which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && sudo apt update && apt policy nodejs
                      /usr/bin/nodejs
                      /usr/bin/node
                      /usr/bin/npm
                      v14.16.1
                      v14.16.1
                      6.14.12
                      Sorry, user andy is not allowed to execute '/usr/bin/apt update' as root on Iobrokercontainer.192.168.0.1.
                      • F friemelkarl
                        @glasfaser
                        update done
                        + instance is alive
                        Objects type: file
                        States  type: file
                        3.3.22
                        /usr/bin/nodejs
                        /usr/bin/node
                        /usr/bin/npm
                        v14.16.1
                        v14.16.1
                        6.14.12
                        @friemelkarl
                        Jessie
                        Timeframe
                        Jessie LTS is supported from 17th June 2018 to June 30, 2020.
                        https://wiki.debian.org/LTS/Jessie#Timeframe
                          @friemelkarl
                          Jessie
                          Timeframe
                          friemelkarl
                          Dann werde ich da mal updaten müssen! 😬
                          • F friemelkarl
                            @friemelkarl
                            Und richte dir gleich einen Standarduser gescheit ein. Als root wird nicht rumgehampelt.
                              @friemelkarl
                              friemelkarl
                              Wird gemacht!
                              Danke für die Hilfe!
