  4. Javascript Adapter rot
    5.5k
91 Beiträge 4 Kommentatoren 11.6k Aufrufe 3 Beobachtet
  • GlasfaserG Glasfaser
    @ChrisPrefect
    @glasfaser sagte in Javascript Adapter rot:
    @chrisprefect
    Zeige mal
    iobroker update -i
    @chrisprefect sagte in Javascript Adapter rot:
    @glasfaser OK ist umgestellt bei der Instanz:
    das ist immer noch die INFO
    ChrisPrefectC Offline
    ChrisPrefect
    @glasfaser Steht aber auf Debug bei der Instanz oder?
    Used repository: beta
    hash changed or no sources cached => force download of new sources
    update done
    Cannot read or parse /opt/iobroker/node_modules/iobroker.js-controller/lib/../node_modules/iobroker.javascript/io-package.json: /opt/iobroker/node_modules/iobroker.javascript/io-package.json: Unexpected end of JSON input
    Adapter    "admin"         : 5.2.3    , installed 5.2.3
    Adapter    "alexa2"        : 3.12.0   , installed 3.12.0
    Adapter    "backitup"      : 2.2.3    , installed 2.2.3
    Adapter    "cloud"         : 4.1.0    , installed 4.1.0
    Adapter    "deconz"        : 1.3.19   , installed 1.3.19
    Adapter    "discovery"     : 2.7.5    , installed 2.7.5
    Adapter    "email"         : 1.0.10   , installed 1.0.10
    Adapter    "find-my-iphone": 0.2.17   , installed 0.2.17
    Adapter    "flot"          : 1.10.7   , installed 1.10.7
    Adapter    "geofency"      : 1.0.3    , installed 1.0.3
    Adapter    "habpanel"      : 0.4.3    , installed 0.4.3
    Adapter    "history"       : 1.10.5   , installed 1.10.5
    Adapter    "icons-material-png": 0.1.0   , installed 0.1.0
    Adapter    "icons-material-svg": 0.1.0   , installed 0.1.0
    Adapter    "icons-ultimate-png": 1.0.1   , installed 1.0.1
    Adapter    "influxdb"      : 2.4.0    , installed 2.4.0
    Adapter    "info"          : 1.9.16   , installed 1.9.16
    Adapter    "iot"           : 1.8.25   , installed 1.8.25
    Adapter    "iqontrol"      : 1.11.0   , installed 1.11.0
    Adapter    "jarvis"        : 3.0.7    , installed 3.0.7
    Controller "js-controller" : 3.3.22   , installed 3.3.22
    Adapter    "lifx"          : 0.1.1    , installed 0.1.1
    Adapter    "linkeddevices" : 1.4.3    , installed 1.4.3
    Adapter    "material"      : 1.1.2    , installed 1.1.2
    Adapter    "mihome-vacuum" : 3.3.1    , installed 3.3.1
    Adapter    "mobile"        : 1.0.1    , installed 1.0.1
    Adapter    "modbus"        : 3.4.17   , installed 3.4.17
    Adapter    "mqtt"          : 2.4.1    , installed 2.4.1
    Adapter    "node-red"      : 2.4.1    , installed 2.4.1
    Adapter    "octoprint"     : 2.1.1    , installed 2.1.0 [Updateable]
    Adapter    "onvif"         : 0.4.4    , installed 0.4.4
    Adapter    "ping"          : 1.5.0    , installed 1.5.0
    Adapter    "proxy"         : 1.2.2    , installed 1.2.2
    Adapter    "rickshaw"      : 1.0.0    , installed 1.0.0
    Adapter    "rpi2"          : 1.3.1    , installed 1.3.1
    Adapter    "samsung"       : 0.2.9    , installed 0.2.9
    Adapter    "scenes"        : 2.3.8    , installed 2.3.8
    Adapter    "shelly"        : 5.0.0    , installed 5.0.0
    Adapter    "simple-api"    : 2.6.2    , installed 2.6.2
    Adapter    "smartcontrol"  : 1.2.1    , installed 1.2.1
    Adapter    "socketio"      : 3.1.5    , installed 3.1.5
    Adapter    "sonoff"        : 2.4.7    , installed 2.4.7
    Adapter    "statistics"    : 1.0.10   , installed 1.0.10
    Adapter    "stockmarket"   : 0.0.2    , installed 0.0.2
    Adapter    "sureflap"      : 1.0.9    , installed 1.0.9
    Adapter    "swiss-weather-api": 1.0.2   , installed 1.0.2
    Adapter    "telegram"      : 1.10.0   , installed 1.10.0
    Adapter    "tesla-motors"  : 1.0.7    , installed 1.0.7
    Adapter    "tileboard"     : 0.3.1    , installed 0.3.1
    Adapter    "tr-064"        : 4.2.15   , installed 4.2.15
    Adapter    "unifi"         : 0.5.10   , installed 0.5.10
    Adapter    "vis"           : 1.4.6    , installed 1.4.7
    Adapter    "vis-bars"      : 0.1.4    , installed 0.1.4
    Adapter    "vis-canvas-gauges": 0.1.5   , installed 0.1.5
    Adapter    "vis-colorpicker": 1.2.0   , installed 1.2.0
    Adapter    "vis-fancyswitch": 1.1.0   , installed 1.1.0
    Adapter    "vis-history"   : 1.0.0    , installed 1.0.0
    Adapter    "vis-hqwidgets" : 1.1.9    , installed 1.1.9
    Adapter    "vis-inventwo"  : 3.2.5    , installed 3.2.5
    Adapter    "vis-jqui-mfd"  : 1.0.12   , installed 1.0.12
    Adapter    "vis-justgage"  : 1.0.2    , installed 1.0.2
    Adapter    "vis-lcars"     : 1.0.4    , installed 1.0.4
    Adapter    "vis-map"       : 1.0.4    , installed 1.0.4
    Adapter    "vis-material"  : 0.1.3    , installed 0.1.3
    Adapter    "vis-materialdesign": 0.5.9   , installed 0.5.9
    Adapter    "vis-metro"     : 1.1.2    , installed 1.1.2
    Adapter    "vis-rgraph"    : 0.0.2    , installed 0.0.2
    Adapter    "vis-timeandweather": 1.1.7   , installed 1.1.7
    Adapter    "weatherunderground": 3.3.1   , installed 3.3.1
    Adapter    "web"           : 3.4.16   , installed 3.4.16
    Adapter    "windows-control": 0.1.5   , installed 0.1.5
    Adapter    "yahka"         : 0.13.1   , installed 0.13.1
    Adapter    "zigbee"        : 1.6.12   , installed 1.6.12
    • ChrisPrefectC ChrisPrefect
      update done
      GlasfaserG Offline
      GlasfaserG Offline
      @chrisprefect
      iobroker u all
      Dann mal deine VM neu starten
      ChrisPrefectC 1 Antwort Letzte Antwort
        @chrisprefect
        iobroker u all
        ChrisPrefect
        schrieb am zuletzt editiert von ChrisPrefect
        @glasfaser Das kam am ende nach iobroker u all
        upload [1] life360.admin /opt/iobroker/node_modules/iobroker.life360/admin/index_m.html index_m.html text/html
        upload [0] life360.admin /opt/iobroker/node_modules/iobroker.life360/admin/admin.d.ts admin.d.ts video/mp2t
        internal/modules/cjs/loader.js:1131
            throw err;
        SyntaxError: /opt/iobroker/node_modules/iobroker.javascript/io-package.json: Unexpected end of JSON input
            at parse (<anonymous>)
            at Object.Module._extensions..json (internal/modules/cjs/loader.js:1128:22)
            at Module.load (internal/modules/cjs/loader.js:950:32)
            at Function.Module._load (internal/modules/cjs/loader.js:790:12)
            at Module.require (internal/modules/cjs/loader.js:974:19)
            at require (internal/modules/cjs/helpers.js:93:18)
            at Upload.uploadAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpload.js:480:19)
            at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpload.js:245:26
            at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:2303:9)
            at processImmediate (internal/timers.js:466:21)
        Und der Javascript-Adapter ist noch immer rot nach dem Neustart. Und das Update sehe ich auch nicht.
              throw err;
          und was zeigt jetzt iob update -i?
          @Glasfaser
          eben stand der javascript-Adapter in der Liste gar nicht drin.
          ggf. Cache löschen und neu installeiren direkt mit @5.2.19
            @Glasfaser
            ChrisPrefect
            hash unchanged, use cached sources
            update done
            Adapter    "octoprint"     : 2.1.1    , installed 2.1.1
            Kann ich den Javascript-Adapter bedenkenlos entfernen? Gehen da keine Skripte verloren? Und nach dem Hinzufügen der neuen Instanz gehen auch alle Trigger und Zeitbasierten Skripte wieder?
            Wie lösche ich den Cache?
              update done
              nee, wahrscheinlich gar nicht
              oder siehst du ihn in der Liste?
                update done
                das war zwar an @Glasfaser gerichtet, kann aber wahrscheinlich nicht schaden.
                Allerdings kenne ich mich mit Containern gar nicht aus!
                sudo -u iobroker -H npm cache clean --force
                und dann nochmal iob update -i
                  ChrisPrefect
                  @homoran In der Liste ist er schon, da ist er ja auch rot. Aber das Löschen-Symbol ist durchgestrichen.
                    ChrisPrefect
                    @homoran Container? Ich habe keine Container-Installation. Das ist eine Virtualbox-VM mit debian.
                    Error: EACCES: permission denied, scandir '/root'
                      Sag mal - wofür lässt du dir über iob update -i eine Liste generieren, um dann einen Screenshot zu zeigen wenn ich auf deinen Konsolenoutput reagiere?
                      ChrisPrefectC 2 Antworten Letzte Antwort
                        ChrisPrefect
                        @homoran hä? Weil ich keine Ahnung habe! Sonst würde ich doch nicht um Hilfe bitten.
                          ChrisPrefect
                          @homoran Und warum ist er in der grafischen liste, nicht aber in der Liste auf der Konsole?
                            @chrisprefect
                            Das die Datei kaputt ist habt ihr aber schon gesehen?
                            Ich würde den js-controller und den Javascript nochmal drüberbügeln.
                            HomoranH ChrisPrefectC 2 Antworten Letzte Antwort
                              dann einfach zum mitschreiben:
                              siehst du in der Liste die du in der Konsole erhalten hast irgendwo den Eintrag Adapter "javascript"....?
                              Dein Admin nämlich auch nicht, deswegen ist da die Mülltonne auch nicht aktiv
                                @chrisprefect
                                @thomas-braun sagte in Javascript Adapter rot:
                                jepp.
                                deswegen den Cache löschen und dann mit der neuesten Version drüberbügeln.
                                Aber das Löschen des Caches scheint nicht zu gehen
                                aber ich hatte nicht realisiert, dass das im Verzeichnis des controllers ist
                                  @chrisprefect
                                  ChrisPrefect
                                  OK, und wie mache ich das?
                                    ChrisPrefect
                                    @homoran sagte in Javascript Adapter rot:
                                    Ich sehe die Instanz ja in der Admin-Oberfläche. Der Admin hat ja immerhin eine Versionsnummer und einen Speicherverbrauch der Instanz und ich kann das Debug-Level umstellen und die Instanz neu starten.
                                      @chrisprefect
                                      cd /opt/iobroker
                                      sudo -H -u iobroker npm install iobroker.js-controller
                                      Danach
                                      iobroker upgrade iobroker.javascript@latest
                                        @chrisprefect
                                        cd /opt/iobroker
                                        Danach
                                        ChrisPrefect
                                        Hat glaube ich nicht ganz geklappt:
                                        npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                                        > iobroker.js-controller@3.3.22 preinstall /opt/iobroker/node_modules/iobroker.js-controller
                                        > node lib/preinstallCheck.js
                                        NPM version: 6.14.15
                                        > iobroker.js-controller@3.3.22 install /opt/iobroker/node_modules/iobroker.js-controller
                                        > node iobroker.js setup first
                                        object _design/custom updated
                                        object _design/system updated
                                        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
                                        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                                        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@^1.0.7 (node_modules/iobroker.info/node_modules/osx-temperature-sensor):
                                        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                                        npm WARN bl@0.7.0 requires a peer of stream-browserify@* but none is installed. You must install peer dependencies yourself.
                                        + iobroker.js-controller@3.3.22
                                        updated 1 package in 39.486s
                                        152 packages are looking for funding
                                          run `npm fund` for details
                                        Uncaught Rejection: SyntaxError: /opt/iobroker/node_modules/iobroker.javascript/io-package.json: Unexpected end of JSON input
                                            at Upgrade.upgradeAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:368:27)
                                            at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:276:26
                                            at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2623:45)
                                          doch! sind nur optionale Abhängigkeiten
                                          solange sich ioBroker noch aus dem Cache bedient wird das auch so bleiben
