  4. [gelöst] Error Meldung (ENOENT/ENOTDIR) Backitup
20 Beiträge 2 Kommentatoren 1.3k Aufrufe 2 Beobachtet
  • Claus1985 0C Offline
    Claus1985 0
    schrieb am zuletzt editiert von Claus1985 0
    Hallo Zusammen,
    bisher funktionierte Backitup bei mir gut, allerdings habe ich gerade festgestellt, dass es gar keine Backups anlegt sondern
    per Fehler endet:
    Started iobroker ...
    [DEBUG] [mount] - noserverino option: false
    [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=ioBroker_Backup,password=****,rw,file_mode=0777,dir_mode=0777,vers=1.0
    [DEBUG] [mount] - mount successfully completed
    [DEBUG] [mount] - done
    [DEBUG] [iobroker] - host.Schaltzentrale2 5449 states saved
    [DEBUG] [iobroker] - host.Schaltzentrale2 7413 objects saved
    [ERROR] [iobroker] - host.Schaltzentrale2 Cannot pack directory /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup: Error: ENOTDIR: not a directory, open '/opt/iobroker/backups/iobroker_2022_01_07-14_04_28_backupiobroker.tar.gz'
    [DEBUG] [iobroker] - done
    [DEBUG] [redis] - Start Redis Backup ...
    [DEBUG] [redis] - redis tmp directory "/opt/iobroker/backups/redistmp" cannot created
    [DEBUG] [redis] - detected redis file: dump.rdb | file type: rdb
    [ERROR] [redis] - Error: ENOENT: no such file or directory, open '/opt/iobroker/backups/redistmp/dump.rdb'
    [ERROR] [redis] - [IGNORED] Error: ENOENT: no such file or directory, open '/opt/iobroker/backups/redistmp/dump.rdb'
    [DEBUG] [zigbee] - found zigbee database: zigbee.0
    [DEBUG] [zigbee] - done
    [ERROR] [zigbee] - [IGNORED] Error: ENOTDIR: not a directory, open '/opt/iobroker/backups/zigbee.0_2022_01_07-14_04_36_backupiobroker.tar.gz'
    [DEBUG] [javascripts] - Javascript tmp directory "/opt/iobroker/backups/tmpScripts" cannot created ... Error: ENOTDIR: not a directory, mkdir '/opt/iobroker/backups/tmpScripts'
    [ERROR] [javascripts] - script.json cannot be written: Error: ENOENT: no such file or directory, open '/opt/iobroker/backups/tmpScripts/script.json'
    [DEBUG] [javascripts] - found Script: Harmony_Hub
    [DEBUG] [javascripts] - found Script: Heizung_mit_PV_steuern
    [DEBUG] [javascripts] - found Script: Indego
    [DEBUG] [javascripts] - javascript Backup not created
    [DEBUG] [javascripts] - done
    [DEBUG] [cifs] - done
    [ERROR] [clean] - Backup files not deleted from /opt/iobroker/backups because some errors.
    [DEBUG] [clean] - done
    [DEBUG] [historyHTML] - new history html values created
    [DEBUG] [historyHTML] - done
    [DEBUG] [historyJSON] - new history json values created
    [DEBUG] [historyJSON] - done
    [DEBUG] [umount] - mount activ, umount is started ...
    [EXIT] 9
    [DEBUG] [umount] - umount successfully completed
    [DEBUG] [umount] - done
    [EXIT] 9
    Kann mir hier jemand weiterhelfen? Mir scheint es ein lokales Problem auf dem Raspberry zu sein, denn
    alle backups zeigen als Error cannot be written: Error: ENOENT: no such file or directory bzw. als Error: ENOTDIR: not a directory an.
    Wie kann ich das beheben?
    Danke und Gruß,
    Claus
    • Claus1985 0C Claus1985 0
      Hallo Zusammen,
      per Fehler endet:
      [EXIT] 9
      [EXIT] 9
      Danke und Gruß,
      Claus
      @claus1985-0
      Mehr Info wird benötigt. SMB v1.0 ist aber höchstwahrscheinlich falsch.
      Claus1985 0C 1 Antwort Letzte Antwort
        @claus1985-0
        Claus1985 0
        @thomas-braun Hatte das auf der Fritzbox auf 1.0 gestellt da die neueren Versionen nicht funktioniert haben.
        Nachdem er allerdings mount = successfull anzeigt dachte ich, es liegt ggf. an der SD-Card im Pi und der lokalen Struktur?
          @claus1985-0 sagte in Error Meldung (ENOENT/ENOTDIR) beim Ausführen von Backitup:
          Welche Firmware? Gerade die Fritzboxen brauchen SMB 3.1.1 sowie die noserverino-Option. Zumindest in aktuellen Versionen.
            Claus1985 0
            @thomas-braun Hab die FB 7590 mit Fritz OS 7.29.
            Wenn ich umstelle auf 3.1.1 und noserverino läuft das Backup gar nicht mehr durch (Verbindungstyp ist CIFS):
            [DEBUG] [mount] - noserverino option: true
            [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=ioBroker_Backup,password=****,noserverino,rw,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.166.122/FRITZ-Zentral/PatriotMemory-01/ /opt/iobroker/backups"
            [DEBUG] [iobroker] - host.Schaltzentrale2 5465 states saved
            [DEBUG] [iobroker] - host.Schaltzentrale2 7486 objects saved
            [ERROR] [iobroker] - host.Schaltzentrale2 Cannot pack directory /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup: Error: ENOENT: no such file or directory, open '/opt/iobroker/backups/iobroker_2022_01_07-20_28_09_backupiobroker.tar.gz'
            Das Fehlerbild hatte ich schonmal und mit SMB 1.0 lief es auch mal erfolgreich durch.
            Seit 31.12.2021 um 02:40 Uhr nachts läuft das Backup nicht mehr durch.
            Meine Vermutung, dass es am lokalen Speicher hängt basiert auf dieser Meldung:
              @claus1985-0
              Die Optionen mit noserverino und smb 3.1.1 sind richtig, die fahre ich hier auch auf FritzOS 7.29.
              Ist /opt/iobroker/backups leer?
              ls -la /opt/iobroker/backups
                @claus1985-0
                Claus1985 0
                @thomas-braun Verzeichnis ist nicht leer, da sind die letzten Backups drin die noch funktioniert haben:
                  @claus1985-0 Dann räum die da mal raus. Ein Mountpunkt ist ein leeres Verzeichnis.
                  Und bitte keine Screenshots von Text. Als Text in CodeTags eingebettet ins Forum kopieren. Danke.
                    Claus1985 0
                    @thomas-braun ich glaube langsam nähern wir uns dem Problem.. Ich kann die Dateien nicht löschen.
                    Fehlermeldung:
                    sudo rm iobroker_2021_12_31-02_40_20_backupiobroker.tar.gz
                    rm: das Entfernen von 'iobroker_2021_12_31-02_40_20_backupiobroker.tar.gz' ist nicht möglich: Datei oder Verzeichnis nicht gefunden
                    Die gleiche Meldung erhalte ich wenn ich über Filezilla die Daten runterladen oder löschen möchte.
                      Fehlermeldung:
                      @claus1985-0
                      sudo -rf /opt/iobroker/backups/*
                      Die Freigabe darf dabei nicht gemountet sein!
                        @claus1985-0
                        Claus1985 0
                        Damit bekomme ich eine Fehlermeldung:
                        sudo: /opt/iobroker/backups/FRITZ: Befehl nicht gefunden
                          @claus1985-0
                          Bitte komplette Ein- und Ausgabe der Konsole zeigen.
                            @claus1985-0
                            Claus1985 0
                            pius@Zentrale2:~ $ ls -la /opt/iobroker/backups
                            insgesamt 7916
                            drwxrwxrwx  2 root     root           0 Jan  7 20:34 .
                            drwxrwxr-x+ 6 iobroker iobroker    4096 Jan  7 19:36 ..
                            drwxrwxrwx  2 root     root           0 Apr  8  2021 FRITZ
                            -rwxrwxrwx  1 root     root     6044763 Dez 31 02:40 iobroker_2021_12_31-02_40_20_backupiobroker.tar.gz
                            -rwxrwxrwx  1 root     root       63918 Dez 31 02:40 javascripts_2021_12_31-02_40_35_backupiobroker.tar.gz
                            drwxrwxrwx  2 root     root           0 Apr  8  2021 lost+found
                            -rwxrwxrwx  1 root     root      304080 Dez 31 02:40 redis_2021_12_31-02_40_33_backupiobroker.tar.gz
                            -rwxrwxrwx  1 root     root     1680730 Dez 31 02:40 zigbee.0_2021_12_31-02_40_34_backupiobroker.tar.gz
                            pius@Zentrale2:~ $ sudo -rf /opt/iobroker/backups/*
                              insgesamt 7916
                              @claus1985-0
                              Merkwürdig...
                              sudo rm -rf /opt/iobroker/backups/FRITZ
                                @claus1985-0
                                Merkwürdig...
                                Claus1985 0
                                @thomas-braun Das hat er ausgeführt, passiert ist allerdings nichts:
                                insgesamt 7916
                                  insgesamt 7916
                                  @claus1985-0
                                  Und was ist das für ein komischer lost+found Ordner? Das ist eigentlich ein Hinweis auf ein angeschossenes Dateisystem. Hier wohl das Speichermedium an der FritzBox. Sonst wird nämlich so ein Ordner nicht angelegt. Ist immer ein Hilferuf, wenn der im root eines Dateisystems auftaucht.
                                    @claus1985-0
                                    Claus1985 0
                                    @thomas-braun Habs unmounten können, lag daran, dass ich den Filezille noch offen hatte 🙄
                                    Ja genau, das Backup wird auf dem USB-Stick auf der FB gespeichert. Habe das nun mal umgeändert auf den Speicher der FB direkt und siehe da, es läuft mit den von Dir genannten Einstellungen durch..
                                    Danke Dir! :-)
                                    Hatte das ursprünglich auf den USB-Stick gepackt um den Flash Speicher der Fritzbox zu schonen..
                                      Danke Dir! :-)
                                      @claus1985-0
                                      Von Filezilla war aber nie die Rede...
                                      Schau dir den USB-Stick an, könnte sein das der 'nen Schuss hat.
                                      Das Verzeichnis /opt/iobroker/backups ist jetzt leer?
                                      Wenn da kein mount drauf ist...
                                        @claus1985-0
                                        Claus1985 0
                                        @thomas-braun nein ist nicht leer, funktioniert aber trotzdem. :-)
                                        Ich schätze der Stick passt einfach nicht da überdimensioniert (256gb / USB3.0)..
                                          @claus1985-0 sagte in [gelöst] Error Meldung (ENOENT/ENOTDIR) Backitup:
                                          Aber nicht unbedingt dauerhaft.
                                          Ein Mountpunkt ist leer, wenn das Dateisystem nicht gerade gemountet ist. Alles andere kann für Probleme sorgen.
