  4. broker mit und ohne Fehlermeldung nicht erreichbar
    6.3k
connectdatabaseweb
49 Beiträge 3 Kommentatoren 5.8k Aufrufe 2 Beobachtet
  • Philipp DornP Philipp Dorn
    Das wird jetzt etwas mehr 😆
    pi@homeserver:~ $ iobroker upgrade
    Required dependency "web" not found on this host.
    This upgrade of "radar2" will at least introduce the following changes:
    -> 2.0.3:
    Fix for setStates
    -> 2.0.2:
    Fix for js-controller 3.3
    -> 2.0.1:
    defaults for new adapter installation updated!
    -> 2.0.0:
    Rewritten adapter with bug fixes and updated to node 10.x+ included fj-adapter-core awhich should work on js-controller 2.x and 3.x.
    -> 1.2.5:
    updated adapter to use new myAdapter awhich should work on js-controller 2.x and 3.x.
    -> 1.2.0:
    Added possibility to use hcitool only on linux to avoice noble on unsupported nodejs platforms.
    BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
    Would you like to upgrade radar2 from @1.0.9 to @2.0.3 now? [(y)es, (n)o]: y
    Update radar2 from @1.0.9 to @2.0.3
    NPM version: 6.14.15
    npm install iobroker.radar2@2.0.3 --loglevel error --prefix "/opt/iobroker" (System call)
    ../src/node_usb.cc: In function ‘Napi::Value SetDebugLevel(const Napi::CallbackInfo&)’:
    ../src/node_usb.cc:118:71: warning: ‘void libusb_set_debug(libusb_context*, int)’ is deprecated: Use libusb_set_option instead [-Wdeprecated-declarations]
      libusb_set_debug(usb_context, info[0].As<Napi::Number>().Int32Value());
    In file included from ../src/node_usb.h:11,
                     from ../src/node_usb.cc:1:
    ../libusb/libusb/libusb.h:1325:18: note: declared here
     void LIBUSB_CALL libusb_set_debug(libusb_context *ctx, int level);
    upload [8] radar2.admin /opt/iobroker/node_modules/iobroker.radar2/admin/words.json words.json application/json
    upload [7] radar2.admin /opt/iobroker/node_modules/iobroker.radar2/admin/words.js words.js application/javascript
    upload [6] radar2.admin /opt/iobroker/node_modules/iobroker.radar2/admin/vendors.json vendors.json application/json
    upload [5] radar2.admin /opt/iobroker/node_modules/iobroker.radar2/admin/tools.js tools.js application/javascript
    upload [4] radar2.admin /opt/iobroker/node_modules/iobroker.radar2/admin/radar2.png radar2.png image/png
    upload [3] radar2.admin /opt/iobroker/node_modules/iobroker.radar2/admin/node_ble_test.js node_ble_test.js application/javascript
    upload [2] radar2.admin /opt/iobroker/node_modules/iobroker.radar2/admin/network_test.js network_test.js application/javascript
    upload [1] radar2.admin /opt/iobroker/node_modules/iobroker.radar2/admin/index_m.html index_m.html text/html
    upload [0] radar2.admin /opt/iobroker/node_modules/iobroker.radar2/admin/index.html index.html text/html
    Adapter "radar2" updated
    This upgrade of "discovery" will introduce the following changes:
    -> 2.7.3:
    updated kecontact detection
    -> 2.7.2:
    support KeBa KeContact P30
    -> 2.7.1:
    Support KeBa KeContact P30
    Would you like to upgrade discovery from @2.7.0 to @2.7.3 now? [(y)es, (n)o]: y
    Update discovery from @2.7.0 to @2.7.3
    npm install iobroker.discovery@2.7.3 --loglevel error --prefix "/opt/iobroker" (System call)
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:78:69: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen);
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:135:71: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate);
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:175:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose);
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:215:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush);
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:271:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet);
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:316:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet);
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:366:76: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate);
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:412:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain);
    ../src/serialport.cpp: At global scope:
    ../src/serialport.cpp:433:28: warning: unnecessary parentheses in declaration of ‘ToParityEnum’ [-Wparentheses]
     SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local<v8::String>& v8str)) {
    ../src/serialport.cpp:452:30: warning: unnecessary parentheses in declaration of ‘ToStopBitEnum’ [-Wparentheses]
     SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) {
    In file included from ../../../nan/nan.h:58,
                     from ../src/./serialport.h:13,
                     from ../src/serialport.cpp:1:
    /home/iobroker/.cache/node-gyp/14.18.2/include/node/node.h:787:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
           (node::addon_register_func) (regfunc),                          \
    /home/iobroker/.cache/node-gyp/14.18.2/include/node/node.h:821:3: note: in expansion of macro ‘NODE_MODULE_X’
       NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
    ../src/serialport.cpp:486:1: note: in expansion of macro ‘NODE_MODULE’
     NODE_MODULE(serialport, init);
    ../src/serialport_unix.cpp: In function ‘int setup(int, OpenBaton*)’:
    ../src/serialport_unix.cpp:179:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1005 [-Wformat-truncation=]
         snprintf(data->errorString, sizeof(data->errorString), "Error %s Cannot open %s", strerror(errno), data->path);
    ../src/serialport_unix.cpp:179:13: note: ‘snprintf’ output 20 or more bytes (assuming 1043) into a destination of size 1024
    ../src/serialport_unix.cpp: In function ‘void EIO_Open(uv_work_t*)’:
    ../src/serialport_unix.cpp:89:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1003 [-Wformat-truncation=]
         snprintf(data->errorString, sizeof(data->errorString), "Error: %s, cannot open %s", strerror(errno), data->path);
    ../src/serialport_unix.cpp:89:13: note: ‘snprintf’ output 22 or more bytes (assuming 1045) into a destination of size 1024
    upload [16] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/words.js words.js application/javascript
    upload [15] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/translateTools.js translateTools.js application/javascript
    upload [14] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings_m.html settings_m.html text/html
    upload [13] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings.html settings.html text/html
    upload [12] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index_m.html index_m.html text/html
    upload [11] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index.html index.html text/html
    upload [10] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
    upload [9] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
    upload [8] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
    upload [7] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
    upload [6] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
    upload [5] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/i18n/it/translations.json i18n/it/translations.json application/json
    upload [4] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
    upload [3] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/i18n/es/translations.json i18n/es/translations.json application/json
    upload [2] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/i18n/en/translations.json i18n/en/translations.json application/json
    upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/i18n/de/translations.json i18n/de/translations.json application/json
    upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/discovery.png discovery.png image/png
    Adapter "discovery" updated
    This upgrade of "admin" will introduce the following changes:
    -> 5.2.3:
    Fixed error in `AutocompleteSendTo`
    Fixed error in charts
    -> 5.2.2:
    Changed the minimal required js-controller version to 3.3.22
    Used web-socket library 8 (no node 10 support anymore)
    -> 5.2.1:
    Allow in expert mode the creation of states and channels in mqtt branch
    -> 5.2.0:
    Fix crash cases reported via sentry
    Added support for multi-repositories
    -> 5.1.29:
    -> 5.1.28:
    Fixed discovery function
    Fixed some GUI bugs
    Would you like to upgrade admin from @5.1.25 to @5.2.3 now? [(y)es, (n)o]: y
    Update admin from @5.1.25 to @5.2.3
    host.homeserver Adapter "system.adapter.admin.0" is stopped.
    npm install iobroker.admin@5.2.3 --loglevel error --prefix "/opt/iobroker" (System call)
    upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/words.js words.js application/javascript
    Update "system.adapter.admin.0"
    upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json jsonConfig.json application/json
    upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index_m.html index_m.html text/html
    upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index.html index.html text/html
    upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
    upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
    upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
    upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
    upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
    upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json i18n/it/translations.json application/json
    upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
    upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json i18n/es/translations.json application/json
    upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json i18n/en/translations.json application/json
    upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json i18n/de/translations.json application/json
    upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
    Adapter "admin" updated
    host.homeserver Adapter "system.adapter.admin.0" is started
    This upgrade of "javascript" will introduce the following changes:
    -> 5.2.13:
    Fixed the loading of Node.js typings
    -> 5.2.12:
    Fixed the font in the editor
    -> 5.2.10:
    Parse variables to floats for mathematical operations
    Names with the dot at the end are not allowed anymore
    The blockly sounds are disabled
    -> 5.2.9:
    Make sure day of weeks is an array (Sentry IOBROKER-JAVASCRIPT-7Y)
    Report to sentry is disabled in GUI if sentry is deactivated
    Fixed many GitHub issues
    Would you like to upgrade javascript from @5.2.8 to @5.2.13 now? [(y)es, (n)o]: y
    Update javascript from @5.2.8 to @5.2.13
    npm install iobroker.javascript@5.2.13 --loglevel error --prefix "/opt/iobroker" (System call)
    upload [100] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/typescript/tsWorker.js vs/language/typescript/tsWorker.js application/javascript
    upload [90] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.js vs/editor/editor.main.nls.js application/javascript
    upload [80] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/basic-languages/javascript/javascript.js vs/basic-languages/javascript/javascript.js application/javascript
    upload [70] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/main.fc5df117.chunk.js static/js/main.fc5df117.chunk.js application/javascript
    upload [60] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/index_m.html index_m.html text/html
    upload [50] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/msg/de.js google-blockly/own/msg/de.js application/javascript
    upload [40] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/blocks_sendto.js google-blockly/own/blocks_sendto.js application/javascript
    upload [30] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/msg/js/it.js google-blockly/msg/js/it.js application/javascript
    upload [20] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/handopen.cur google-blockly/media/handopen.cur null
    upload [19] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/handdelete.cur google-blockly/media/handdelete.cur null
    upload [18] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/handclosed.cur google-blockly/media/handclosed.cur null
    upload [17] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/dropdown-arrow.svg google-blockly/media/dropdown-arrow.svg image/svg+xml
    upload [16] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/disconnect.wav google-blockly/media/disconnect.wav audio/wav
    upload [15] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/disconnect.ogg google-blockly/media/disconnect.ogg audio/ogg
    upload [14] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/disconnect.mp3 google-blockly/media/disconnect.mp3 audio/mpeg
    upload [13] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/delete.wav google-blockly/media/delete.wav audio/wav
    upload [12] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/delete.ogg google-blockly/media/delete.ogg audio/ogg
    upload [11] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/delete.mp3 google-blockly/media/delete.mp3 audio/mpeg
    upload [10] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/click.wav google-blockly/media/click.wav audio/wav
    upload [9] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/click.ogg google-blockly/media/click.ogg audio/ogg
    upload [8] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/click.mp3 google-blockly/media/click.mp3 audio/mpeg
    upload [7] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/1x1.gif google-blockly/media/1x1.gif image/gif
    upload [6] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/javascript_compressed.js google-blockly/javascript_compressed.js application/javascript
    upload [5] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/blocks_compressed.js google-blockly/blocks_compressed.js application/javascript
    upload [4] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/blockly_compressed.js google-blockly/blockly_compressed.js application/javascript
    upload [3] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/LICENSE google-blockly/LICENSE null
    upload [2] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
    upload [1] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/asset-manifest.json asset-manifest.json application/json
    upload [0] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/adminWords.js adminWords.js application/javascript
    Adapter "javascript" updated
    This upgrade of "history" will introduce the following changes:
    -> 1.9.14:
    Prevent crash cases reported by Sentry
    Would you like to upgrade history from @1.9.13 to @1.9.14 now? [(y)es, (n)o]: y
    Update history from @1.9.13 to @1.9.14
    npm install iobroker.history@1.9.14 --loglevel error --prefix "/opt/iobroker" (System call)
    upload [17] history.admin /opt/iobroker/node_modules/iobroker.history/admin/words.js words.js application/javascript
    upload [16] history.admin /opt/iobroker/node_modules/iobroker.history/admin/jsonCustom.json jsonCustom.json application/json
    upload [15] history.admin /opt/iobroker/node_modules/iobroker.history/admin/jsonConfig.json jsonConfig.json application/json
    upload [14] history.admin /opt/iobroker/node_modules/iobroker.history/admin/index_m.html index_m.html text/html
    upload [13] history.admin /opt/iobroker/node_modules/iobroker.history/admin/index.html index.html text/html
    upload [12] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
    upload [11] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
    upload [10] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
    upload [9] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
    upload [8] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
    upload [7] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/it/translations.json i18n/it/translations.json application/json
    upload [6] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
    upload [5] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/es/translations.json i18n/es/translations.json application/json
    upload [4] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/en/translations.json i18n/en/translations.json application/json
    upload [3] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/de/translations.json i18n/de/translations.json application/json
    upload [2] history.admin /opt/iobroker/node_modules/iobroker.history/admin/history.png history.png image/png
    upload [1] history.admin /opt/iobroker/node_modules/iobroker.history/admin/custom_m.html custom_m.html text/html
    upload [0] history.admin /opt/iobroker/node_modules/iobroker.history/admin/custom.html custom.html text/html
    Adapter "history" updated
    Scheinen auch einige Fehler zu schmeißen beim Upgrade. Aber das hatte ich auch schon seit längerem...
    pi@homeserver:~ $ iobroker upload all
    Soll ich eigenltich zwischendrin mal neustarten oder ähnliches? Habe jetzt wirklich nur eure Schritte gemacht.....
    @philipp-dorn
    Wenn das jetzt alles durch ist:
    iobroker list adapters
    iobroker list instances
    Philipp DornP 1 Antwort Letzte Antwort
      @philipp-dorn
      Philipp DornP Offline
      Philipp Dorn
      @thomas-braun Spannend, die geupdateten Adapter tauchen wieder auf:
      pi@homeserver:~ $ iobroker list adapters
      system.adapter.admin                   : admin          - v5.2.3
      system.adapter.discovery               : discovery      - v2.7.3
      system.adapter.history                 : history        - v1.9.14
      system.adapter.javascript              : javascript     - v5.2.13
      system.adapter.radar2                  : radar2         - v2.0.3
      pi@homeserver:~ $ iobroker list instances
      + system.adapter.admin.0                  : admin                 : homeserver                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + instance is alive
      Und ich komme zwar nicht auf die secured Weboberfläche, aber mit "http://" komme ich nun auf den iorboker Wilkommensbildschirm für die erste Konfiguration.....ich weiß nicht, ob das so sein soll.
        + instance is alive
        @philipp-dorn
        Ich vermute, da ist die alte Installation auf einem anderen host(name) gelaufen.
        iobroker stop
        iobroker host this
        iobroker start
          @philipp-dorn
          iobroker stop
          iobroker host this
          iobroker start
          Philipp Dorn
          schrieb am zuletzt editiert von Philipp Dorn
          pi@homeserver:~ $ iobroker stop
          pi@homeserver:~ $ iobroker host this
          A host with the name "homeserver" already exists!
          pi@homeserver:~ $ iobroker start
          + instance is alive
          pi@homeserver:~ $
          Mir fällt gerade auf, ich könnte ja mal den Fehler im Browser anzeigen:
            + instance is alive
            pi@homeserver:~ $
            @philipp-dorn
            Von SSL hab ich keine Ahnung. Meine Installation kommt ohne aus.
              @philipp-dorn
              Philipp Dorn
              @Thomas-Braun Das ist schade....dann wird wohl nur das Backup helfen, oder hat @Homoran noch eine Idee?
                @philipp-dorn sagte in broker mit und ohne Fehlermeldung nicht erreichbar:
                was das SSL angeht überhaupt nicht - damit kenne ich mich gar nicht aus.
                Für die anderen Punkte könnte man vielleicht nochmal das mini HowTo durchjagen, wenn es dazu nicht schon zu spät ist, da jede Änderung einen älteren Eintrag rauswirft und irgendwann keine heilen Zustände mehr existieren.
                Alles im Allem wäre jetzt wohl die Zeit für ein Restore (auf einem aktuellen System)
                Dabei aber jetzt unbedingt auf den Hostnamen achten
                Der sollte identisch mit dem im Backup sein
                  Philipp Dorn
                  @homoran Okay, mache ich, Hostname ist seit Monaten, wenn nicht sogar Jahren nicht geändert.
                  Danke für Eure Hilfe!
                    Philipp Dorn
                    Backup restored, funzt wieder alles. Auf ein neues 😆
                      Philipp Dorn
                      OOOOOOKAY?!?!?
                      Jetzt bin ich verwirrt. Ich habe ja wie bereits erwähnt das Backup restored, und auch extra nicht das letzte von vor einem Monat genommen sondern ein etwas älteres, von dem ich weiß, dass es ohne Probleme lief.
                      Gestern Abend ist nun der gleiche Error wieder passiert, iobroker ist nicht mehr erreichbar. Ich habe nach dem Restore wohlgemerkt NICHTS an iobroker gemacht....
                      Parallel dazu läuft auf dem gleichen Raspberry mein Unify Server ohne Probleme, nur iobroker ist wieder nicht erreichbar.
                      Bevor ich jetzt die Standardanleitung wieder durchgehe nun vorher die Frage - irgendwelche Anregungen für das Vorgehen? Oder soll ich das oben beschriebene einfach nochmal exakt so durchführen? Ich würde jetzt als erstes nochmal "iobroker fix" probieren, auch wenn ich nicht glaube, dass es das Problem löst. Spannend wäre jetzt ja mal, die Quelle des Fehlers zu finden....
                        OOOOOOKAY?!?!?
                        @philipp-dorn
                        |Arbeitsspeicher:| 1GB |
                        Unify-Server
                        Und da quetscht du auch noch neben den iobroker noch weiteren Kram? Das ist ohnehin schon knapp bemessen mit dem einen GB.
                          @philipp-dorn
                          Unify-Server
                          Philipp Dorn
                          @thomas-braun Ja, grundsätzlich richtig, allerdings in der RAM übersicht war es nie so, dass ich da in einen kritischen Bereich kam....
                          Hat ja auch wirklich mittlerweile Jahre funktioniert....
                          pi@homeserver:~ $ free
                          Mem:         996100      620888      100256        1740      274956      345296
                          Swap:       1023996      209664      814332
                            @philipp-dorn
                            Der Speicherbedarf ist in den letzten Versionen des iobrokers aber auch gestiegen. Was 'vor Jahren' ging muss heute nicht unbedingt noch passen.
                            Ich vermute, dass der Kiste der Spielraum ausgeht. Vielleicht beim nächtlichen Backup.
                              @philipp-dorn
                              free -ht --mega
                              Kann Mensch besser lesen.
                                @philipp-dorn
                                Philipp Dorn
                                @thomas-braun Backup mache ich manuell, also beim Backup kanns nicht sein...
                                Also empfiehlst du nen Raspi4? Ich habe eh schon seit längerem Überlegt ein kubernetes Cluster aus zwei Raspis 4 zu erstellen und alles dadrin zu hosten. Von der Leistung her, müsste der Raspi 4 das ja locker schaffen.
                                pi@homeserver:~ $ free -ht --mega
                                Mem:           972M        329M        535M        0.0K        107M        596M
                                Swap:          999M        331M        668M
                                Total:         2.0G        661M        1.2G
                                  @philipp-dorn
                                  Ich empfehle mehr RAM als 1GB. Ob das jetzt ein Raspberry ist oder was anderes ist egal.
                                  Edith: Dein Swap ist komisch...
                                  Philipp DornP 2 Antworten Letzte Antwort
                                    @philipp-dorn
                                    Philipp Dorn
                                    @thomas-braun Pro Node oder pro Cluster? Ich könnte natürlich (aufgrund der aktuell nicht bekommbaren Raspis 4 einen zweiten 3er als Node hinzufügen. Dann wäre es mehr Ram. Zukunfsträchtig ist es aber nicht auch nicht sehr lange.
                                      @philipp-dorn
                                      Philipp Dorn
                                      @thomas-braun said in broker mit und ohne Fehlermeldung nicht erreichbar:
                                      Definiere komisch? 😬
                                        @philipp-dorn
                                        Komisch groß, komisch zu voll.
                                        Du hast ein Problem mit zu wenig RAM.
                                        Mein System:
                                        echad@chet:~ $ free -ht --mega
                                        Mem:            7.8G        2.1G        2.6G        0.0K        3.2G        5.6G
                                        Swap:            99M          0B         99M
                                        Total:          7.9G        2.1G        2.7G
                                          @philipp-dorn
                                          Mein System:
                                          Swap:            99M          0B         99M
                                          Philipp Dorn
                                          @thomas-braun Okay, das stimmt scheinbar. Aber ist nicht genau dafür eigentlich der Swap da, damit eben mein System nicht abschmiert?
                                          Ich schaue mich nach einem Raspi 4 um, lege ein Kubernetes-Cluster an und werde da Unify und iobroker als Container laufen lassen. Gibts Erfahrungen mit iobroker als Container?
