  4. Adapter für Buderus KM200 (und eventuell auch anderen KMxxx)
    6.7k
686 Beiträge 99 Kommentatoren 289.1k Aufrufe 56 Beobachtet
  • M mwolle
    @zgadgeter was sagt denn das Protokoll beim Adapterstart?
    Z Offline
    Z Offline
    zgadgeter
    schrieb am zuletzt editiert von zgadgeter
    #545
    @mwolle said in Adapter für Buderus KM200 (und eventuell auch anderen KMxxx):
    Ich werde daraus nicht schlau leider.
    km200.0
    2021-12-20 21:10:49.878	info	Adapter km200 initialization finished with 0 states.
    km200.0
    2021-12-20 21:10:49.868	info	Slow Interval=6 hours, Slow-List:
    km200.0
    2021-12-20 21:10:49.867	info	Fast Interval=2 min, Fast-List:
    km200.0
    2021-12-20 21:10:49.867	info	Interval=15 min, Norm-list:
    km200.0
    2021-12-20 21:10:49.867	info	KM200 found 0 states, get their values now.
    km200.0
    2021-12-20 21:10:49.866	info	Services found: 41
    km200.0
    2021-12-20 21:10:49.866	warn	Did not get any Services from KLM200!: {}
    km200.0
    2021-12-20 21:10:48.783	info	km200.0 address: http://192.168.178.103
    km200.0
    2021-12-20 21:10:48.782	info	km200 initialization started...
    km200.0
    2021-12-20 21:10:48.736	info	starting. Version 2.0.3 in /opt/iobroker/node_modules/iobroker.km200, node: v12.22.8, js-controller: 3.3.22
    host.IOBDebian104
    2021-12-20 21:10:48.247	info	instance system.adapter.km200.0 started with pid 22015
    host.IOBDebian104
    2021-12-20 21:10:48.231	debug	startInstance km200.0 loglevel=info, compact=false
    host.IOBDebian104
    2021-12-20 21:10:48.231	debug	added notifications configuration of system.adapter.km200.0
    host.IOBDebian104
    2021-12-20 21:10:47.388	debug	Incoming Host message getLogs
    host.IOBDebian104
    2021-12-20 21:10:47.377	debug	Incoming Host message getLogFiles
    host.IOBDebian104
    host.IOBDebian104
    host.IOBDebian104
    2021-12-20 21:10:45.729	info	instance system.adapter.km200.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    host.IOBDebian104
    2021-12-20 21:10:45.225	info	stopInstance system.adapter.km200.0 send kill signal
    km200.0
    2021-12-20 21:10:45.169	warn	Adapter will exit in latest 1 sec with code false!
    km200.0
    2021-12-20 21:10:45.169	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    km200.0
    2021-12-20 21:10:45.168	info	terminating
    km200.0
    2021-12-20 21:10:45.168	info	Adapter disconnected and stopped with dostop(false) and callback(true)
    km200.0
    2021-12-20 21:10:45.167	info	Got terminate signal TERMINATE_YOURSELF
    • Z zgadgeter
      km200.0
      km200.0
      km200.0
      km200.0
      km200.0
      km200.0
      km200.0
      km200.0
      km200.0
      km200.0
      host.IOBDebian104
      host.IOBDebian104
      host.IOBDebian104
      host.IOBDebian104
      host.IOBDebian104
      host.IOBDebian104
      host.IOBDebian104
      host.IOBDebian104
      host.IOBDebian104
      km200.0
      km200.0
      km200.0
      km200.0
      km200.0
      mwolle
      schrieb am zuletzt editiert von mwolle
      #546
      @zgadgeter der findet das Gateway so scheinbar nicht. Guck mal in deinem Router wie der sich bei dir anmeldet. Dazu muss dann eigentlich noch der DNS Suffix. (Bei mir heißt das Gerät JunkersMBLAN + Suffix fritz.box)
      G 1 Antwort Letzte Antwort
      • M mwolle
        gjo
        schrieb am zuletzt editiert von gjo
        #547
        funktioniert der Adapter auch mit einer KM 200 V2 Box? Habe mir so eine zugelegt und verzweifle zwar noch an der IBN in der APP - wird immer nur "hier ist etwas schiefgelaufen ... versuchen ... bla bla bla" angezeigt aber das Ziel ist natürlich die Datenpunkte im iobroker zu haben.
        • G gjo
          tp1de
          schrieb am zuletzt editiert von tp1de
          #548
          @gjo Ja der Adapter unterstützt km200 / IP-Inside.
          Du musst Dir allerdings erst die Zugangsdaten mit der Buderus MyDevice App erzeugen (Benutzername und Passwort). Dieses PW ist dann das "private Passwort". Auf dem Kessel bzw. Gateway steht dann das Gateway-PW in der Form xxxx-xxxx-xxxx-xxxx.
          Für den KM200 Adapter werden dann beide Passwörter benötigt.
          • M mwolle
            @frankjoke : lang ist es jetzt schon her, aber wie wird denn nun ein MB LANi eingerichtet?
            Mit den Daten:
            funktioniert es nicht. Muss man den Link zwingend auf Buderus abändern? Ich habe das ohne Bindestriche, mit Bindestriche versucht. Kein Erfolg. oder liegt es am DNS Suffix der Telekombox? Vlt hat jemand das gleiche Setup und kann mir sagen, was man tun muss?
            Ich habe ein drittes Gerät angeschlossen, am Namen TK-850XXX liegt es nicht, es muss der DNS Suffix sein. Obwohl er es laut ipconfig ist. Vlt hat noch jemand das an einem Speedport hängen?
            mwolle
            #549
            @mwolle hierzu kann keiner eine Info geben? Scheint das nur mit dem DNS Suffix fritz.box zu laufen? Der Adapter scheint auch nicht weiterentwickelt zu werden?
            G T 2 Antworten Letzte Antwort
            • M mwolle
              gjo
              #550
              @mwolle
              Hi, ich habe bei mir die echte IP Adresse der KM-Box angegeben … also kein fritz.Box. Und das funktioniert bestens.
              In der fritzbox habe ich nur dafür gesorgt, dass eine feste IP zugeordnet wird.
              • M mwolle
                tp1de
                #551
                @mwolle Ja genau einfach Ip-Adresse 192.168.178.xxx
                M 2 Antworten Letzte Antwort
                • T tp1de
                  mwolle
                  #552
                  @tp1de ja alles klar, probiere ich nachher mal aus und melde mich noch mal ob das mit der reinen IP Adresse ging
                  • M mwolle
                    tp1de
                    #553
                    @mwolle sagte in Adapter für Buderus KM200 (und eventuell auch anderen KMxxx):
                    Ja sicher benutze ich seit Jahren. Stimmen die Anmeldedaten?
                    • T tp1de
                      gjo
                      #554
                      @tp1de
                      Das müsste doch über die app rauszufinden sein. Sprich die Anmeldedaten / Passwort in der app und Adapter vergleichen …
                      • G gjo
                        @tp1de
                        tp1de
                        #555
                        @gjo sagte in Adapter für Buderus KM200 (und eventuell auch anderen KMxxx):
                        Nee falsch ! (s.o.)
                        • T tp1de
                          Nee falsch ! (s.o.)
                          gjo
                          #556
                          @tp1de
                          ich meinte, dass wenn er mit der APP Zugriff auf das KM200 hat mit den gleichen Daten (privates Passwort und Gateway Passwort) und der echten IP-Adresse auch via Adapter Zugriff haben sollte.
                          Bzgl. Gateway-Passwort und privates Passwort habe ich noch eine Seite zur Stellung ohne APP gefunden: https://ssl-account.com/km200.andreashahn.info/ Diese Info ist als ungetestet einzustufen.
                          • G gjo
                            @tp1de
                            gjo
                            #557
                            mir fehlt der Datenpunkt "km200.0.system.sensors.temperatures.return". Hat jemand eine Idee was ich machen muss damit der aufgelistet wird?
                            • G gjo
                              tp1de
                              #558
                              @gjo Buderus hat die Rücklauftemperatur mit dem letzten Firmware-Update im September entfernt !!!
                              Habe mich beschwert, aber ohne Erfolg.
                              Bosch / Buderus möchte den Direkt-Zugriff unterbinden und arbeitet an einer WEB-API Version mit sehr vereinfachten Datenpunkten / Funktionen.
                              • T tp1de
                                mwolle
                                #559
                                @tp1de das kann ich so nicht bestätigen, habe hier einerseits eine Buderus Logamax im Einsatz, sowie eine Junkers, bei beiden habe ich den Rücklauf dabei. Ggf. aber mal das Gateway neustarten.
                                Ansonsten klingt das ja schon ein wenig wie nach Viessmann, wer richtig damit was tun will, soll gefälligst die API bezahlen ;)
                                • M mwolle
                                  tp1de
                                  #560
                                  @mwolle vielleicht war es auch das Update was etwas zerschossen hat. Alles zu resetten habe ich keine Lust. Ich habe seit längerem parallel das ems-esp Gateway installiert. Das liefert auch noch viele zusätzliche Werte / Parameter die im Buderus-Gateway nicht abgebildet werden ....
                                  • T tp1de
                                    mwolle
                                    #561
                                    @tp1de said in Adapter für Buderus KM200 (und eventuell auch anderen KMxxx):
                                    funktioniert dennoch nicht, Gateway ist korrekt, PW aus der App eingetragen. Klappt nicht ;( Ich bekomme immer das:
                                    • M mwolle
                                      tp1de
                                      #562
                                      @mwolle dann sind die Passwörter falsch. Funktioniert die myDevice App?
                                      • T tp1de
                                        mwolle
                                        #563
                                        @tp1de ja die App geht darüber, dort wurde das Passwort nochmal neu gesetzt
                                        • M mwolle
                                          tp1de
                                          #564
                                          was bedeutet das ?????? Kannst Du mit App deine Anlage sehen und steuern?
