  4. Backitup Fehlermeldung
    1.9k
14 Beiträge 3 Kommentatoren 1.1k Aufrufe 2 Beobachtet
  • eule66E Offline
    eule66E Offline
    eule66
    Hallo Zusammen
    habe beim Backup auf mein NAS folgende Fehlermeldung und es wir kein Backup angelegt bzw. es wird angelegt mit 0kb.
    Started iobroker ...
    [DEBUG] [mount] - noserverino option: false
    [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=iobroker_backup,password=****,rw,file_mode=0777,dir_mode=0777,vers=1.0 //192.168.178.52/Daten/iobroker_backup/ /opt/iobroker/backups"
    [DEBUG] [mount] - mount successfully completed
    [DEBUG] [mount] - done
    [DEBUG] [iobroker] - host.rock64 7588 states saved
    [DEBUG] [iobroker] - host.rock64 8348 objects saved
    [ERROR] [iobroker] - host.rock64 Cannot pack directory /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup: Error: EACCES: permission denied, open '/opt/iobroker/backups/iobroker_2021_12_30-14_18_57_backupiobroker.tar.gz'
    [DEBUG] [iobroker] - done
    [DEBUG] [mysql] - MySql-Backup started ...
    [ERROR] [mysql] - [IGNORED] Error: Command failed: mysqldump  -u iobroker -p**** iobroker -h localhost -P 3306 > /opt/iobroker/backups/mysql_2021_12_30-14_19_08_backupiobroker.sql
    /bin/sh: 1: cannot create /opt/iobroker/backups/mysql_2021_12_30-14_19_08_backupiobroker.sql: Permission denied
    [DEBUG] [historyDB] - compress from historyDB started ...
    [ERROR] [historyDB] - [IGNORED] Backitup cannot found source "undefined" for compress!
    [DEBUG] [jarvis] - found Jarvis Instance: 0
    [DEBUG] [jarvis] - start Jarvis Backup for Instance 0...
    [ERROR] [jarvis] - [IGNORED] Error: EACCES: permission denied, open '/opt/iobroker/backups/jarvis.0_2021_12_30-14_19_09_backupiobroker.tar.gz'
    [DEBUG] [cifs] - done
    [ERROR] [clean] - Backup files not deleted from /opt/iobroker/backups because some errors.
    [DEBUG] [clean] - done
    [DEBUG] [telegram] - done
    [DEBUG] [historyHTML] - new history html values created
    [DEBUG] [historyHTML] - done
    [DEBUG] [historyJSON] - new history json values created
    [DEBUG] [historyJSON] - done
    [DEBUG] [umount] - mount activ, umount is started ...
    [DEBUG] [umount] - umount successfully completed
    [DEBUG] [umount] - done
    [EXIT] 9
    Folgende Meldung wenn ich das Backup unter Windows öffnen möchte.
    Danke für eure Rückmeldung
    SegwayS 1 Antwort Letzte Antwort
    • eule66E eule66
      Hallo Zusammen
      [EXIT] 9
      SegwayS Offline
      SegwayS Offline
      Segway
      @eule66
      Steht ja da --> Permission denied !
      Der User mit dem du das backup dort ablegen möchtest hat keine rechte dazu !
      Gruß Dirk
      eule66E 1 Antwort Letzte Antwort
      • SegwayS Segway
        @eule66
        eule66E Offline
        eule66E Offline
        eule66
        schrieb am zuletzt editiert von eule66
        @segway lt. Anleitung im Backitup Adapter soll das helfen
        klick mich Punkt 6.
        iobroker stop
        iobroker fix
        sudo reboot
        hab es gemacht bekomme aber die gleich Fehlermeldung
        Was kann ich noch tun?
        • eule66E eule66
          klick mich Punkt 6.
          iobroker stop
          iobroker fix
          sudo reboot
          SegwayS Offline
          SegwayS Offline
          Segway
          @eule66
          Du musst auch auf dem NAS oder wo das ist ebenso die Berechtigung setzen und den User einrichten !
          Gruß Dirk
          • SegwayS Segway
            @eule66
            eule66E Offline
            eule66E Offline
            eule66
            @segway das hatte ich schon alles seit März am laufen. Die Backups wurden erstellt und alles war gut. Den User und die Freigaben für den Ordner liegen vor. Habe iobroker komplett neu installiert und nun geht's nicht mehr.
            • eule66E eule66
              eule66E Offline
              eule66E Offline
              eule66
              @eule66 hat jemand eine Idee wie ich rausfinden kann an was es liegt?
              • eule66E eule66
                @eule66
                vers=1.0 ist höchstwahrscheinlich zu niedrig. Spricht dein NAS nicht was aktuelleres?
                cifs-utils nachinstalliert?
                apt policy cifs-utils
                eule66E 2 Antworten Letzte Antwort
                  @eule66
                  eule66E Offline
                  eule66E Offline
                  eule66
                  @thomas-braun das weiß ich nicht, hab openmediavault am laufen müsste es ausprobieren
                  • eule66E eule66
                    @eule66
                    Das ist der smb-Server von debian dann.
                    https://openmediavault.readthedocs.io/en/5.x/administration/services/samba.html
                      @eule66
                      eule66E Offline
                      eule66E Offline
                      eule66
                      @thomas-braun die cifs-utils
                      sind aktuell
                      • eule66E eule66
                        sind aktuell
                        @eule66
                        Bitte Ausgaben posten.
                        Hast du jetzt die smb-Version hochgedreht? v1.0 spricht hoffentlich niemand mehr.
                          @eule66
                          eule66E Offline
                          eule66E Offline
                          eule66
                          @thomas-braun hab es auf 3.0 gestellt und siehe da es geht.
                          Danke für eure Hilfe :-)
                          • eule66E eule66
                            @eule66
                            Versuch mal 3.1.1.
                            Das ist soweit ich weiß der letzte Stand.
                              @eule66
                              Versuch mal 3.1.1.
                              eule66E Offline
                              eule66E Offline
                              eule66
                              @thomas-braun 3.1.1 läuft auch super
                              Danke 👍
