  4. PiFace addon Installationsproblem
    6.3k
22 Beiträge 2 Kommentatoren 1.0k Aufrufe 2 Beobachtet
  • T TK 0
    Hallo ,
    ich wollte das PiFace addon installieren und es gelingt nicht.
    Was mache ich falsch, bzw. was muss ich anders machen?
    Hier die Fehlermeldung:
    ERROR: Process exited with code 25
    weniger
    mehr
    $ iobroker add piface --host raspib
    NPM version: 6.14.12
    npm install iobroker.piface@1.0.0 --loglevel error --prefix "/opt/iobroker" (System call)
    In file included from ../src/cpp/init.cc:2:
    ../src/cpp/NPIFaceDigital.h: In function 'void AsyncAfter(uv_work_t*, int)':../src/cpp/NPIFaceDigital.h:74:52: error: no matching function for call to 'v8::Function::Call(v8::Localv8::Primitive, const unsigned int&, v8::Localv8::Value [0])' info->callback->Call(Null(info->isolate),argc,argv); ^In file included from /home/iobroker/.cache/node-gyp/12.22.1/include/node/node.h:67, from ../src/cpp/init.cc:1:/home/iobroker/.cache/node-gyp/12.22.1/include/node/v8.h:4298:43: note: candidate: 'v8::MaybeLocalv8::Value v8::Function::Call(v8::Localv8::Context, v8::Localv8::Value, int, v8::Localv8::Value*)' V8_WARN_UNUSED_RESULT MaybeLocal<Value> Call(Local<Context> context, ^~~~/home/iobroker/.cache/node-gyp/12.22.1/include/node/v8.h:4298:43: note: candidate expects 4 arguments, 3 providedIn file included from ../src/cpp/init.cc:1:
    ../src/cpp/init.cc: At global scope:/home/iobroker/.cache/node-gyp/12.22.1/include/node/node.h:736:43: warning: cast between incompatible function types from 'void ()(v8::Localv8::Object)' to 'node::addon_register_func' {aka 'void ()(v8::Localv8::Object, v8::Localv8::Value, void*)'} [-Wcast-function-type] (node::addon_register_func) (regfunc), \ ^/home/iobroker/.cache/node-gyp/12.22.1/include/node/node.h:770:3: note: in expansion of macro 'NODE_MODULE_X' NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage) ^~~../src/cpp/init.cc:10:1: note: in expansion of macro 'NODE_MODULE' NODE_MODULE(pifacedigital, Initialize) ^
    In file included from ../src/cpp/init.cc:2:../src/cpp/NPIFaceDigital.h:61:13: warning: 'void AsyncAfter(uv_work_t*, int)' defined but not used [-Wunused-function] static void AsyncAfter(uv_work_t req, int status) ^~~~~~~~~~../src/cpp/NPIFaceDigital.h:34:13: warning: 'void WaitForAsync(uv_work_t)' defined but not used [-Wunused-function] static void WaitForAsync(uv_work_t *req) ^~~~~~~~~~~~
    make: *** [pifacedigital.target.mk:112: Release/obj.target/pifacedigital/src/cpp/init.o] Fehler 1
    gyp ERR! build error
    gyp ERR! stack Error: make failed with exit code: 2
    gyp ERR! stack at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)gyp ERR! stack at ChildProcess.emit (events.js:314:20)gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:276:12)gyp ERR! System Linux 4.19.66-v7+gyp ERR! command "/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/node-pifacedigitalgyp ERR! node -v v12.22.1gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
    npm ERR! code ELIFECYCLEnpm ERR! errno 1
    npm ERR! node-pifacedigital@0.1.7 install: node-gyp rebuildnpm ERR! Exit status 1npm ERR! npm ERR! Failed at the node-pifacedigital@0.1.7 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
    npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2021-12-12T14_27_52_246Z-debug.log
    host.raspib Cannot install iobroker.piface@1.0.0: 1
    @tk-0
    usr/local/bin/node
    deutet auf eine verfummelte Installation von nodeJS hin.
      @tk-0
      usr/local/bin/node
      TK 0
      Hallo Thomas,
      vielen Dank für die Hinweise und Links.
      Wie darin beschrieben habe ich die alten Verweise etc. entfernt und dann manuell die Version nodejs 14.18.2 und npm 6.14.15 installiert.
      Im Anschluß habe ich bei iobroker alles auf den neusten Stand gebracht. Ebenso bin ich mit den Dateien verfahren, welche man über GIT herunterladen und installieren soll.
      Nach einem Reboot des Raspi habe ich versucht piface zu installieren.
      Hier habe ich erneut eine Fehlermeldung erhalten:
      NPM version: 6.14.15npm install iobroker.piface@1.0.0 --loglevel error --prefix "/opt/iobroker" (System call)
      ../src/cpp/NPIFaceDigital.h: In function 'void AsyncAfter(uv_work_t*, int)':../src/cpp/NPIFaceDigital.h:74:52: error: no matching function for call to 'v8::Function::Call(v8::Localv8::Primitive, const unsigned int&, v8::Localv8::Value [0])' info->callback->Call(Null(info->isolate),argc,argv); ^In file included from /home/iobroker/.cache/node-gyp/14.18.2/include/node/node.h:67, from ../src/cpp/init.cc:1:/home/iobroker/.cache/node-gyp/14.18.2/include/node/v8.h:4468:43: note: candidate: 'v8::MaybeLocalv8::Value v8::Function::Call(v8::Localv8::Context, v8::Localv8::Value, int, v8::Localv8::Value)' V8_WARN_UNUSED_RESULT MaybeLocal<Value> Call(Local<Context> context, ^~~~/home/iobroker/.cache/node-gyp/14.18.2/include/node/v8.h:4468:43: note: candidate expects 4 arguments, 3 providedIn file included from ../src/cpp/init.cc:1:../src/cpp/init.cc: At global scope:/home/iobroker/.cache/node-gyp/14.18.2/include/node/node.h:787:43: warning: cast between incompatible function types from 'void ()(v8::Localv8::Object)' to 'node::addon_register_func' {aka 'void ()(v8::Localv8::Object, v8::Localv8::Value, void)'} [-Wcast-function-type] (node::addon_register_func) (regfunc), \ ^/home/iobroker/.cache/node-gyp/14.18.2/include/node/node.h:821:3: note: in expansion of macro 'NODE_MODULE_X' NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage) ^~~../src/cpp/init.cc:10:1: note: in expansion of macro 'NODE_MODULE' NODE_MODULE(pifacedigital, Initialize) ^
      gyp ERR! build error gyp ERR! stack Error: make failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)gyp ERR! stack at ChildProcess.emit (events.js:400:28)gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:282:12)gyp ERR! System Linux 4.19.66-v7+gyp ERR! command "/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/node-pifacedigitalgyp ERR! node -v v14.18.2gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
      npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2021-12-23T12_29_50_843Z-debug.log
      Kannst Du mir bitte nochmals weiterhelfen.
      Vielen Dank vorab und schöne Weihnachten.
      Thomas
      • T TK 0
        Hallo Thomas,
        Thomas
        @tk-0
        usr/local/bin/node
        Dein nodeJS ist noch krumm im System.
        Und bitte Texte aus der Konsole in CodeTags posten.
          @tk-0
          usr/local/bin/node
          TK 0
          Sorry, ich kenne mich mit Foren nicht so aus.
          Was sind CodeTags??
          Der Pfad "usr/local/bin/node" entstammt der Beschreibung SONDERFALL "alte Raspberry händisch pflegen"
          • T TK 0
            Was sind CodeTags??
            @tk-0
            CodeTags: Beim Antworten das </> anklicken, Steuerzeichen in einer neuen Zeile starten lassen, Text zwischen die Steuerzeichen kopieren.
            Sonderfall? Welche Hardware verwendest du?
              TK 0
              Danke für den Tipp mit den CodeTags. werde ich berücksichtigen.
              Ich verwende eine Raspberry B erstes Modell mit raspian buster.
              • T TK 0
                @tk-0
                Raspberry Pi 3B?
                Edit: 1B?
                  TK 0
                  Keine Ahnung, auf der Box steht nur Pi Modell B drauf.
                  Beim Login über die Konsole steht Linux raspib 4.19.66-v7+, etwas dahinter nach dem Datum und Uhrzeut armv7l
                  • T TK 0
                    @tk-0 sagte in PiFace addon Installationsproblem:
                    armv7l
                    Das ist aber dann kein Sonderfall. Die Sonderfälle sind für armv6l.
                    Aber wenn ich mir das so anschaue bzgl. piface, das wird ganz schwierig werden, vermute ich. Das ist ja alles 'ewig alt'. Keine Ahnung ob das noch unter aktuellen Versionen von python, nodeJS und dem OS ans laufen zu bekommen ist. Sind auf jedenfall große Klimmzüge erforderlich.
                      TK 0
                      ohhh Sorry, darauf hatte ich gar nicht geachtet. Hatte nur auf die Modellreihe B geachtet.
                      Dann gehe ich nochmals nach Deiner Anleitung für den Standardfall durch.
                      Vielen Dank nochmals und entschuldige meinen Fehler.
                      • T TK 0
                        @tk-0
                        Was sagt denn
                        cat /proc/cpuinfo
                        cat /proc/device-tree/model
                        Dann kannst du auch gleich mal die CodeTags versuchen.
                        T 2 Antworten Letzte Antwort
                          @tk-0
                          Was sagt denn
                          cat /proc/cpuinfo
                          TK 0
                          iobroker@raspib:~ $ cat /proc/cpuinfo
                          processor       : 0
                          model name      : ARMv7 Processor rev 4 (v7l)
                          BogoMIPS        : 38.40
                          Features        : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm crc32
                          CPU implementer : 0x41
                          CPU architecture: 7
                          CPU variant     : 0x0
                          CPU part        : 0xd03
                          CPU revision    : 4
                          processor       : 1
                          BogoMIPS        : 38.40
                          CPU architecture: 7
                          CPU variant     : 0x0
                          CPU part        : 0xd03
                          CPU revision    : 4
                          processor       : 2
                          BogoMIPS        : 38.40
                          CPU architecture: 7
                          CPU variant     : 0x0
                          CPU part        : 0xd03
                          CPU revision    : 4
                          processor       : 3
                          BogoMIPS        : 38.40
                          CPU architecture: 7
                          CPU variant     : 0x0
                          CPU part        : 0xd03
                          CPU revision    : 4
                          Hardware        : BCM2835
                          Revision        : a02082
                          Serial          : 00000000b4510762
                            @tk-0
                            Was sagt denn
                            cat /proc/cpuinfo
                            TK 0
                            iobroker@raspib:~ $ cat /proc/device-tree/model
                            Raspberry Pi 3 Model B Rev 1.2iobroker@raspib:~ $
                            • T TK 0
                              @tk-0
                              Also ein relativ aktueller Pi3B.
                              Da braucht es keine Sonderfall-Regelung.
                              Btw: Der user 'iobroker' ist mal schlecht gewählt, der gehört als Systemuser eigentlich zur ioBroker-Grundinstallation.
                                @tk-0
                                TK 0
                                Habe mich über ssh als iobroker angemeldet. Als normaler Benutzer gibt es auch noch pi.
                                Node habe ich nun über den normalen installiert und nach einem Neustart läuft IoBroker wieder.
                                iobroker@raspib:~ $ which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && sudo apt updaten && apt policy nodejs
                                /usr/bin/nodejs
                                /usr/bin/node
                                /usr/bin/npm
                                v14.18.2
                                v14.18.2
                                6.14.15
                                OK:1 http://archive.raspberrypi.org/debian stretch InRelease
                                OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                                OK:3 https://deb.nodesource.com/node_14.x buster InRelease
                                Abhngigkeitsbaum wird aufgebaut.
                                Aktualisierung fr 47 Pakete verfgbar. Fhren Sie apt list --upgradable aus, um sie anzuzeigen.
                                E: Ungltige Operation updaten
                                Wie von Dir vermutet geht die Installation von piface dennoch nicht.
                                ../src/cpp/NPIFaceDigital.h: In function 'void AsyncAfter(uv_work_t*, int)':../src/cpp/NPIFaceDigital.h:74:52: error: no matching function for call to 'v8::Function::Call(v8::Local<v8::Primitive>, const unsigned int&, v8::Local<v8::Value> [0])' info->callback->Call(Null(info->isolate),argc,argv); ^In file included from /home/iobroker/.cache/node-gyp/14.18.2/include/node/node.h:67, from ../src/cpp/init.cc:1:/home/iobroker/.cache/node-gyp/14.18.2/include/node/v8.h:4468:43: note: candidate: 'v8::MaybeLocal<v8::Value> v8::Function::Call(v8::Local<v8::Context>, v8::Local<v8::Value>, int, v8::Local<v8::Value>*)' V8_WARN_UNUSED_RESULT MaybeLocal<Value> Call(Local<Context> context, ^~~~/home/iobroker/.cache/node-gyp/14.18.2/include/node/v8.h:4468:43: note: candidate expects 4 arguments, 3 provided
                                In file included from ../src/cpp/init.cc:1:../src/cpp/init.cc: At global scope:/home/iobroker/.cache/node-gyp/14.18.2/include/node/node.h:787:43: warning: cast between incompatible function types from 'void (*)(v8::Local<v8::Object>)' to 'node::addon_register_func' {aka 'void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)'} [-Wcast-function-type] (node::addon_register_func) (regfunc), \ ^/home/iobroker/.cache/node-gyp/14.18.2/include/node/node.h:821:3: note: in expansion of macro 'NODE_MODULE_X' NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage) ^~~~~~~~~~~~~../src/cpp/init.cc:10:1: note: in expansion of macro 'NODE_MODULE' NODE_MODULE(pifacedigital, Initialize) ^~~~~~~~~~~
                                ../src/cpp/NPIFaceDigital.h:61:13: warning: 'void AsyncAfter(uv_work_t*, int)' defined but not used [-Wunused-function] static void AsyncAfter(uv_work_t *req, int status) ^~~~~~~~~~../src/cpp/NPIFaceDigital.h:34:13: warning: 'void WaitForAsync(uv_work_t*)' defined but not used [-Wunused-function] static void WaitForAsync(uv_work_t *req) ^~~~~~~~~~~~
                                gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)gyp ERR! stack at ChildProcess.emit (events.js:400:28)
                                gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:282:12)gyp ERR! System Linux 4.19.66-v7+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/node-pifacedigitalgyp ERR! node -v v14.18.2gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
                                npm ERR! errno 1
                                npm ERR! node-pifacedigital@0.1.7 install: `node-gyp rebuild`
                                npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2021-12-23T13_48_51_110Z-debug.log
                                Bedeutet das, dass die Software für diesen Adapter zu alt ist?
                                • T TK 0
                                  /usr/bin/nodejs
                                  /usr/bin/node
                                  /usr/bin/npm
                                  v14.18.2
                                  v14.18.2
                                  6.14.15
                                  npm ERR! errno 1
                                  Das ist falsch. Muss 'buster' statt 'stretch' lauten.
                                  • T TK 0
                                    /usr/bin/nodejs
                                    /usr/bin/node
                                    /usr/bin/npm
                                    v14.18.2
                                    v14.18.2
                                    6.14.15
                                    npm ERR! errno 1
                                    Möglich. Aber hast du auch die ganzen Voraussetzungen auf der Hardwareseite erfüllt? SPI aktiv im Raspberry? Wenn ich das richtig sehe ist das ganze ja etwas frickelig einzurichten, schon bevor da irgendwas node / ioBroker bezogenes überhaupt funktionieren würde.
                                      TK 0
                                      Das Ganze lief schon mal mit einer älteren iobroker Version. Frag bitte nicht welche das war.
                                      Ich habe damit S0 Schnittstellen von meinem Wasserzähler und dem PV Inverter mitgeloggt.
                                      Nach einem Update vor einigen Wochen/Monate ging es dann leider nicht mehr.
                                      • T TK 0
                                        @tk-0
                                        Bevor du da weiter machst dringend die Repos gerade ziehen. Das trägt nicht gerade zu einem stabilen System bei, wenn das alles nicht zueinander passt.
                                          @tk-0
                                          TK 0
                                          So, alle Repos gerade gezogen und das System aktualisiert neu gestartet und nochmals die Installation versucht.
                                          Leider geht die Installation von Piface immer noch nicht.
                                          Gibt es eine Möglichkeit, dass sich das mal jemand anschaut, der sich damit auskennt?
