  4. Update auf admin 5.2.2
    6.3k
erroradminupdate
6 Beiträge 4 Kommentatoren 544 Aufrufe 3 Beobachtet
  • bahnuhrB Online
    bahnuhrB Online
    bahnuhr
    der Text passt nicht zusammen.
    Bitte ändern.
    Danke.
    • CinimodC Offline
      CinimodC Offline
      Cinimod
      @bahnuhr
      ist bereits geändert 😉
      • bahnuhrB bahnuhr
        Bitte ändern.
        mguenther
        ich häng mich dran. Habe erst den Host aktualisiert, dann den ADMIN. Lief durch - ich bekomme nur das jetzt im LOG:
        host.raspberrypi
        	2021-12-23 00:05:52.735	error	No adapter name is specified for readBaseSettings command from system.adapter.admin.0
        host.raspberrypi
        	2021-12-23 00:05:42.152	info	Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
        was tun?
        • M mguenther
          host.raspberrypi
          host.raspberrypi
          was tun?
          @mguenther
          iobroker status
          iobroker update -i
            @mguenther
            iobroker status
            iobroker update -i
            mguenther
            pi@raspberrypi:~ $ iobroker status
            Objects type: file
            States  type: file
            pi@raspberrypi:~ $ iobroker update -i
            Used repository: stable
            hash unchanged, use cached sources
            update done
            Adapter    "admin"         : 5.2.2    , installed 5.2.2
            Adapter    "alias-manager" : 1.2.4    , installed 1.2.4
            Adapter    "backitup"      : 2.2.2    , installed 2.2.2
            Adapter    "cloud"         : 4.1.0    , installed 4.1.0
            Adapter    "daswetter"     : 3.0.9    , installed 3.0.9
            Adapter    "deconz"        : 1.3.19   , installed 1.3.19
            Adapter    "denon"         : 1.11.2   , installed 1.11.2
            Adapter    "devices"       : 1.0.9    , installed 1.0.9
            Adapter    "discovery"     : 2.7.3    , installed 2.7.3
            Adapter    "dwd"           : 2.7.7    , installed 2.7.7
            Adapter    "echarts"       : 1.0.3    , installed 1.0.3
            Adapter    "ekey"          : 1.1.0    , installed 1.1.0
            Adapter    "feiertage"     : 1.0.23   , installed 1.0.23
            Adapter    "flot"          : 1.10.7   , installed 1.10.7
            Adapter    "fullybrowser"  : 2.0.10   , installed 2.0.10
            Adapter    "history"       : 1.9.14   , installed 1.9.14
            Adapter    "hm-rega"       : 3.0.33   , installed 3.0.33
            Adapter    "hm-rpc"        : 1.14.50  , installed 1.14.50
            Adapter    "ical"          : 1.11.4   , installed 1.11.4
            Adapter    "icons-addictive-flavour-png": 0.1.0   , installed 0.1.0
            Adapter    "icons-icons8"  : 0.0.1    , installed 0.0.1
            Adapter    "icons-material-png": 0.1.0   , installed 0.1.0
            Adapter    "icons-mfd-png" : 1.0.2    , installed 1.0.2
            Adapter    "icons-mfd-svg" : 1.0.2    , installed 1.0.2
            Adapter    "icons-open-icon-library-png": 0.1.2   , installed 0.1.2
            Adapter    "influxdb"      : 1.9.5    , installed 2.0.0
            Adapter    "info"          : 1.9.8    , installed 1.9.8
            Adapter    "iot"           : 1.8.24   , installed 1.8.24
            Adapter    "iqontrol"      : 1.8.2    , installed 1.8.2
            Adapter    "javascript"    : 5.2.13   , installed 5.2.13
            Controller "js-controller" : 3.3.22   , installed 3.3.22
            Adapter    "linux-control" : 1.1.3    , installed 1.1.3
            Adapter    "logparser"     : 1.1.0    , installed 1.1.0
            Adapter    "modbus"        : 3.4.14   , installed 3.4.14
            Adapter    "mqtt"          : 2.4.0    , installed 2.4.0
            Adapter    "nut"           : 1.5.0    , installed 1.5.0
            Adapter    "pi-hole"       : 1.3.2    , installed 1.3.2
            Adapter    "ping"          : 1.5.0    , installed 1.5.0
            Adapter    "pollenflug"    : 1.0.6    , installed 1.0.6
            Adapter    "rpi2"          : 1.3.1    , installed 1.3.1
            Adapter    "rssfeed"       : 1.0.0    , installed 1.0.0
            Adapter    "simple-api"    : 2.6.1    , installed 2.6.2
            Adapter    "socketio"      : 3.1.4    , installed 3.1.5
            Adapter    "sonoff"        : 2.4.5    , installed 2.4.5
            Adapter    "sql"           : 1.15.7   , installed 1.15.7
            Adapter    "tankerkoenig"  : 2.1.1    , installed 2.1.1
            Adapter    "trashschedule" : 1.2.0    , installed 1.2.0
            Adapter    "unifi"         : 0.5.10   , installed 0.5.10
            Adapter    "vis"           : 1.4.5    , installed 1.4.5
            Adapter    "vis-bars"      : 0.1.4    , installed 0.1.4
            Adapter    "vis-history"   : 1.0.0    , installed 1.0.0
            Adapter    "vis-hqwidgets" : 1.1.7    , installed 1.1.7
            Adapter    "vis-icontwo"   : 0.82.0   , installed 0.82.0
            Adapter    "vis-jqui-mfd"  : 1.0.12   , installed 1.0.12
            Adapter    "vis-justgage"  : 1.0.2    , installed 1.0.2
            Adapter    "vis-material-advanced": 1.7.2   , installed 1.7.2
            Adapter    "vis-metro"     : 1.1.2    , installed 1.1.2
            Adapter    "vis-players"   : 0.1.6    , installed 0.1.6
            Adapter    "vis-plumb"     : 1.0.2    , installed 1.0.2
            Adapter    "vis-timeandweather": 1.1.7   , installed 1.1.7
            Adapter    "vis-weather"   : 2.5.5    , installed 2.5.5
            Adapter    "vw-connect"    : 0.0.45   , installed 0.0.45
            Adapter    "weatherunderground": 3.3.1   , installed 3.3.1
            Adapter    "web"           : 3.4.9    , installed 3.4.9
            Adapter    "wled"          : 0.6.3    , installed 0.6.3
            Adapter    "zigbee"        : 1.6.6    , installed 1.6.6
            • M mguenther
              Objects type: file
              States  type: file
              update done
              @mguenther
              Fällt mir nichts zu ein.
