  4. Zigbee Adapter mit Conbee 2 findet keine Geräte
    5.5k
zigbee adapterconbee 2tinkerboard s
19 Beiträge 7 Kommentatoren 1.2k Aufrufe 6 Beobachtet
  • haselchenH haselchen
    @perry-1
    Moin,
    wie sehen die Einstellungen im Zigbee Adapter aus?
    Perry 1
    @haselchen
    Auf der Geräteübersicht zeigt er auch korreckt alles zum Koordinator an:
    type:ConBee2/RaspBee2
    version:0-0.38.114.0.
    revision:0x26720700
    port:/dev/ttyACM0
    channel:11
    • P Perry 1
      @haselchen
      revision:0x26720700
      port:/dev/ttyACM0
      channel:11
      @perry-1
      Ein Neustart der Instanz sieht wie aus?
      Den Device Link würde ich schon mal auf
      /dev/serial/by-id/WASAUCHIMMERDABEIDIRSTEHT
      umstellen.
      P 1 Antwort Letzte Antwort
        @perry-1
        umstellen.
        Perry 1
        2021-12-19 12:50:00.432 - info: host.DietPi stopInstance system.adapter.zigbee.0 (force=false, process=true)
        2021-12-19 12:50:00.442 - info: host.DietPi stopInstance system.adapter.zigbee.0 send kill signal
        2021-12-19 12:50:00.442 - info: zigbee.0 (4568) Got terminate signal TERMINATE_YOURSELF
        2021-12-19 12:50:00.446 - info: zigbee.0 (4568) cleaned everything up...
        2021-12-19 12:50:00.452 - info: zigbee.0 (4568) Zigbee: disabling joining new devices.
        2021-12-19 12:50:00.721 - info: zigbee.0 (4568) terminating
        2021-12-19 12:50:00.725 - info: zigbee.0 (4568) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2021-12-19 12:50:01.343 - info: host.DietPi instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2021-12-19 12:50:03.481 - info: host.DietPi instance system.adapter.zigbee.0 started with pid 6998
        2021-12-19 12:50:06.665 - info: zigbee.0 (6998) starting. Version 1.6.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.8, js-controller: 3.3.21
        2021-12-19 12:50:06.781 - info: zigbee.0 (6998) Starting Zigbee npm ...
        2021-12-19 12:50:07.308 - info: zigbee.0 (6998) Installed Version: iobroker.zigbee@1.6.6
        2021-12-19 12:50:07.340 - info: zigbee.0 (6998) Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":114,"maintrel":0,"revision":"0x26720700"}}
        2021-12-19 12:50:07.361 - info: zigbee.0 (6998) Unable to disable LED, unsupported function.
        2021-12-19 12:50:07.450 - info: zigbee.0 (6998) --> transmitPower : normal
        2021-12-19 12:50:07.513 - info: zigbee.0 (6998) Unable to set transmit power, unsupported function.
        2021-12-19 12:50:07.516 - info: zigbee.0 (6998) Currently no devices.
        2021-12-19 12:50:07.517 - info: zigbee.0 (6998) Zigbee started
        Auch das umstellen auf
        /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2466843-if00
        bringt keinen unterschied. Ansonsten steht der Adapter die ganze Zeit auf Grün.
        • P Perry 1
          BananaJoeB Offline
          BananaJoeB Offline
          BananaJoe
          @perry-1 also, stelle mal die Zeit für das pairen von 60 auf 180 Sekunden.
          Leider hats du keine ZigBee Geräte dabei die ich kenne (Hui Lampen und Lidl BWM), aber bist du sicher das du diese richtig in den Pairing-Modus versetzt hast?
          Bei meinen Geräten war das was in der beiliegenden Anleitung Stand oft nicht zu gebrauchen sondern eine Recherche im Internet brachte das richtige zu Tage.
          Und mach mal ein
          cat /opt/iobroker/iobroker-data/zigbee_0/shepherd.db
          was da so drin steht. Dürfte ja eigentlich nur der ConBee drin stehen.
          Ich persönlich finde es ja richtig wenn man die Stable-Version verwendet. Aber der ZigBee Adapter ist inzwischen einige Versionen weiter (1.6.8) und ich persönlich würde den in der aktuellen Version einsetzen. Da müsste man aber vorher die anderen Abhängigkeiten prüfen (Admin-Version etc.)
          • BananaJoeB BananaJoe
            Und mach mal ein
            Perry 1
            @bananajoe Ich zweifel so langsam aber sicher auch schon an mir selber. Aber z.B. habe ich extra nen Aqara Temperatur ausgepackt der noch nie mit nem Netzwerk verbunden war. Also kann es auch daran nicht liegen dass meine Geräte nicht zurückgesetzt sind...
            Ich hab grade mal in meiner Bastelkiste nen alten Raspi 1 rausgekramt und werd es mal mit dem Probieren.
            • P Perry 1
              AsgothianA Offline
              AsgothianA Offline
              Asgothian
              @perry-1 sagte in Zigbee Adapter mit Conbee 2 findet keine Geräte:
              Ich lehne mich mal aus dem Fenster: Das wird auch nichts bringen.
              Ich vermute Dein Problem befindet sich auf der Funkseite:
              • wie ist das Tinkerboard mit dem Netz verbunden (LAN / WLan ?)
              • Ist Bluetooth am Tinkerboard aktiv ?
              • wie sind bei Dir die WLan Kanäle belegt (2.5 GHz Band) ?
              • betreibst Du den Stick direkt am Board oder mit einer Verlängerung ?
              • hast du die betroffenen Geräte korrekt in die Pairing-Modus versetzt ?
              A.
              • AsgothianA Asgothian
                A.
                Perry 1
                @asgothian
                Also der Raspi ist über folgende Verbindung mit dem Netz verbunden
                • FritzBox -> DLAN -> Switch -> LAN -> Raspi
                • Ja Bluetoth ist aktiv (war es vor dem Wechsel des Zigbee Sticks aber auch).
                • Die Kanäle sind nicht wirklich belegt. Hier aufm Dorf ist es nicht so tragisch 😁
                  (Aber auch hier gab es keinen unterschied beim Wechsel des Sticks)
                • Sowohl am Board als auch mit einer 1,5m USB 3 Verlängerung zeigt sich kein Unterschied
                • Ich denke schon 😌 . Grade bei den Temperatur Sensoren steht ja bloß ein Knopf zur verfügung... Die die bereits mit meinem vorherigen Netzwerk verbunden waren habe ich vor dem erneuten Pairing die Batterien für ne stunde entfernt und dann probiert.
                Das mit dem Raspi 1 habe ich gestern auch erst mal aufgegeben als aufgrund der alten arm version kein passendes NodeJS auf die schnelle verfügbar war.
                MfG
                Thomas BraunT AsgothianA 2 Antworten Letzte Antwort
                • P Perry 1
                  @asgothian
                  MfG
                  Da würde man was aus den 'unofficial builds' benötigen. In meinem nodeJS-HowTo (siehe Signatur) ist das als Sonderfall enthalten.
                  • P Perry 1
                    @asgothian
                    MfG
                    AsgothianA Offline
                    AsgothianA Offline
                    Asgothian
                    @perry-1
                    Das sieht allerdings gut aus. Zigbee 11 und WLan 1 liegen übereinander.
                    Was mir noch aufgefallen ist: Du hast die ExtPanID nicht angepasst. Da würde ich etwas anderes (nicht 16 D's eintragen) jede andere 16-stellige Hex zahl geht.
                    A.
                      @perry-1
                      A.
                      Perry 1
                      @asgothian In den Logs ist das richtig. Aber wie ich geschrieben habe bringt ein Test mit einer zufälligen HEX ID auch keinen unterschied.
                      Und selbst wenn WLAN und oder Bluetoth stören würde sollte das ja eigentlich nicht dafür sorgen dass ein Pairingversuch <1m vom Stick entfernt scheitert. Das würde man doch eigentlich in der Stabilität und Reichweite des Signals erkennen oder (besonders bin ich mir ziemlich sicher, dass sich der Kanal nicht geändert hat)?
                      @all auf jeden Fall vielen Dank für die Unterstützung ich bin wirklich über jeden Tipp dankbar.
                      • P Perry 1
                        Perry 1
                        schrieb am zuletzt editiert von Perry 1
                        @perry-1 Also ich bin bisher nur unwesentlich weiter gekommen.
                        Immerhin habe ich unter Windows rausbekommen, dass ich weder zu doof bin meine Geräte in den Pairing-Modus zu versetzen (was ich wirklich geglaubt habe) und dass der Stick funktioniert.
                        Mit DeCONZ unter Windows kann ich meine Sensoren alle ohne Probleme anlernen.
                        Nur am Raspi findet er partout keine Geräte. Sprich es kann ja nur noch am Raspi selber liegen wenn ich weder über den Zigbee Adapter noch über DECONZ eine verbindung bekomme.
                        • P Perry 1
                          BananaJoeB Offline
                          BananaJoeB Offline
                          BananaJoe
                          @perry-1 öhm, am Raspberry hast den Stick aber über eine Verlängerung dran (2m)? Am besten an einem USB2.0 Port (nicht blau)
                          USB3.0 Ports machen irgendetwas was ZigBee nicht mag. Also die laufen schon an 3.0 Ports, mögen die Nähe zu anderen aber nicht
                          • P Offline
                            Perry 1
                            @bananajoe Er hängt an einem der beiden USB 2.0 Ports über ein Amazon Basic USB 3.0, 1,5m Verlängerungskabel
                            Meine beiden USB3 Ports sind mit nem USB Stick zum Backup und der Boot SSD belegt.
                            • P Perry 1
                              AsgothianA Offline
                              AsgothianA Offline
                              Asgothian
                              An Dieser Stelle sollte das Problem sein. USB3 stört gerne auf 2.4 GHz, insbesondere bei schnellen Zugriffen (Boot-SSD). Zu Test solltest Du versuchen den Pi von SD-Card und ohne USB3 Backup Stick booten. Wenn es dann geht dann hast du Probleme mit den Störungen wegen des USB3, und kannst versuchen das durch Austausch der Kabel / Adapter zu lösen.
                              A.
