  4. GELÖST Objects database error: connect ECONNREFUSED
    6.3k
13 Beiträge 4 Kommentatoren 10.0k Aufrufe 4 Beobachtet
  • Z zakuma
    pi@raspberrypi:~ $ iobroker status
    iobroker is not running on this host.
    Objects type: file
    States  type: file
    pi@raspberrypi:~ $ iobroker start
    Objects type: file
    States  type: file
    pi@raspberrypi:~ $
    Danke für die schnelle Meldung.
    Starten klappt nicht.
    @zakuma
    iobroker start admin
    Z 1 Antwort Letzte Antwort
      @zakuma
      Z Offline
      Z Offline
      zakuma
      pi@Pi4:~ $ iobroker start admin
      pi@Pi4:~ $ iobroker status
      Objects type: file
      States  type: file
      • Z zakuma
        Objects type: file
        States  type: file
        @zakuma
        Merkwürdig.
        Hau den
        iobroker fix
        mal über das System.
        Wenn das nicht funktioniert mal
        cd /opt/iobroker
        sudo -H -u iobroker npm install iobroker.js-controller
          @zakuma
          Merkwürdig.
          Hau den
          iobroker fix
          cd /opt/iobroker
          Z Offline
          Z Offline
          zakuma
          @thomas-braun said in Objects database error: connect ECONNREFUSED 127.0.0.1:9001:
          iobroker fix
          iobroker fix
          HALLELUJA!
          pi@Pi4:~ $ iobroker fix
          library: loaded
          Library version=2021-04-07
              Welcome to the ioBroker installation fixer!
              Script version: 2021-04-07
              You might need to enter your password a couple of times.
              Installing prerequisites (1/3)
          Get:1 file:/var/cache/openmediavault/archives  InRelease
          Ign:1 file:/var/cache/openmediavault/archives  InRelease
          Get:2 file:/var/cache/openmediavault/archives  Release
          Ign:2 file:/var/cache/openmediavault/archives  Release
          Get:3 file:/var/cache/openmediavault/archives  Packages
          Ign:3 file:/var/cache/openmediavault/archives  Packages
          Get:4 file:/var/cache/openmediavault/archives  Translation-en
          Ign:4 file:/var/cache/openmediavault/archives  Translation-en
          Hit:5 http://deb.debian.org/debian buster InRelease
          Hit:6 http://deb.debian.org/debian-security buster/updates InRelease
          Hit:7 http://deb.debian.org/debian buster-updates InRelease
          Ign:8 http://ftp.nl.debian.org/debian stretch InRelease
          Hit:9 http://httpredir.debian.org/debian buster-backports InRelease
          Hit:10 http://security.debian.org/debian-security buster/updates InRelease
          Hit:11 http://packages.openmediavault.org/public usul InRelease
          Hit:12 http://archive.raspberrypi.org/debian buster InRelease
          Hit:13 http://ftp.nl.debian.org/debian stretch Release
          Get:14 https://download.docker.com/linux/debian buster InRelease [44.4 kB]
          Ign:15 https://repo.mongodb.org/apt/ubuntu xenial/mongodb-org/3.6 InRelease
          Hit:16 https://deb.nodesource.com/node_12.x buster InRelease
          Hit:17 https://repo.mongodb.org/apt/ubuntu xenial/mongodb-org/3.6 Release
          Hit:18 https://openmediavault-plugin-developers.github.io/packages/debian usul InRelease
          Hit:19 https://openmediavault.github.io/packages usul InRelease
          Get:20 https://openmediavault-plugin-developers.github.io/packages/debian usul-extras InRelease [3918 B]
          Fetched 48.3 kB in 5s (9688 B/s)
          Reading package lists... Done
          Installed gcc-c++
              Checking ioBroker user and directory permissions (2/3)
              Checking autostart (3/3)
          Enabling autostart...
          Autostart enabled!
              Your installation was fixed successfully
              Run iobroker start to start ioBroker again!
          Objects type: file
          States  type: file
          • Z zakuma
            iobroker fix
            iobroker fix
            HALLELUJA!
            library: loaded
            Installed gcc-c++
            Autostart enabled!
            Objects type: file
            States  type: file
            @zakuma
            Du fährst da aber auch einen brandgefährlichen Mix aus Paketquellen, die nicht zusammenpassen!
            stretch, buster, xenial, backports usw.
            Da prognostiziere ich langanhaltenden Trouble. Dringendst aufräumen!
              @zakuma
              Z Offline
              Z Offline
              zakuma
              schrieb am zuletzt editiert von zakuma
              @thomas-braun Ja hab schon ein neues Problem mit einem Slave
              pi@Pi3:~ $ iobroker start
              pi@Pi3:~ $ iobroker status
              No connection to databases possible ...
              Soll ich dafür ein neuen Thread eröffnen?
              Wie was genau soll ich aufräumen?
              OMV wollte ich schon mit allem runter schmeißen, da ich es aktuell nicht Nutze. Leider hab ich kein Befehl hierzu gefunden.
              • Z zakuma
                @zakuma
                Bitte führe 2x
                sudo apt update
                durch, die Ausgabe des zweiten Laufs bitte hier posten.
                Zusammen mit der Ausgabe von
                lsb_release -a
                Wie ist es denn auf das System gekommen?
                • Z zakuma
                  Guten Tag,
                  gestern etwa gegen 23:30 Uhr (meine Frau hatte noch ein Alexa Befehl abgesetzt dieser ging durch) war von jetzt auf gleich mein IOBroker nicht mehr erreichbar und somit meine Alexa Befehle nicht mehr möglich.
                  Heute habe ich mich mal ran gesetzt und ich kann dieses einkreisen auf irgendwas mit dem Port 9001.
                  Nur habe ich schon länger nichts mehr verändert (außer mal Updates).
                  pi@Pi4:~ $ iobroker list instances
                    system.adapter.admin.0                  : admin                 : Pi4                                      -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                    system.adapter.alarm.0                  : alarm                 : Pi4                                      -  enabled
                    system.adapter.alexa2.0                 : alexa2                : Pi4                                      - disabled
                    system.adapter.backitup.0               : backitup              : Pi4                                      - disabled
                    system.adapter.history.0                : history               : Pi4                                      -  enabled
                    system.adapter.hm-rega.0                : hm-rega               : Pi4                                      -  enabled
                    system.adapter.hm-rpc.0                 : hm-rpc                : Pi4                                      -  enabled, port: 0
                    system.adapter.hm-rpc.1                 : hm-rpc                : Pi4                                      -  enabled, port: 0
                    system.adapter.info.0                   : info                  : Pi4                                      -  enabled
                    system.adapter.iot.0                    : iot                   : Pi4                                      -  enabled
                    system.adapter.iqontrol.0               : iqontrol              : Pi4                                      -  enabled
                    system.adapter.javascript.0             : javascript            : Pi4                                      -  enabled
                    system.adapter.mqtt.1                   : mqtt                  : Pi3                                      -  enabled, port: 1883, bind: 0.0.0.0
                    system.adapter.rpi2.0                   : rpi2                  : Pi4                                      -  enabled
                    system.adapter.shelly.0                 : shelly                : Pi4                                      -  enabled, port: 1882, bind: 192.168.27.44
                    system.adapter.simple-api.0             : simple-api            : Pi4                                      -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                    system.adapter.web.0                    : web                   : Pi4                                      -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                    system.adapter.zigbee.0                 : zigbee                : Pi3                                      -  enabled, port: /dev/ttyACM0
                  + instance is alive
                  So sieht das ganze aus. Die 127.0.0.1 war vorher die 0.0.0.0 (war Standard eingestellt) hat leider nichts gebracht dies zu verändern.
                  Ich habe sonst noch OMV installiert auf dem Pi.
                  Hoffentlich kann mir da jemand helfen, ich verzweifel.
                  exitus
                  @zakuma wie hast du das Problem gelöst habe das gleiche problem
                  • E exitus
                    @exitus
                    Vermutlich nicht. Oder fährst du da auch so'n wirren Gemischtwarenladen bei den Paketquellen?
                    Mach einen eigenen Thread auf.
                      @exitus
                      GlasfaserG Offline
                      GlasfaserG Offline
                      @thomas-braun sagte in GELÖST Objects database error: connect ECONNREFUSED:
                      Nee .... sollte hier weitermachen
                      https://forum.iobroker.net/topic/50075/hilfe-iobroker-startet-nicht
