  4. Problem mit Backup Wiederherstellung auf dem Raspi
112 Beiträge 5 Kommentatoren 6.8k Aufrufe 4 Beobachtet
  • G guitardoc
    @homoran Ähhh - was ist das denn? Ich hab doch keine Ahnung...
    Ich hab das gemacht:
    pi@raspberrypi:~ $ which nodejs node npm && nodejs -v && node -v && npm -v && apt policy nodejs
    pi@raspberrypi:~ $ curl -sL https://deb.nodesource.com/setup_14.x | sudo -E bash
    ## Installing the NodeSource Node.js 14.x repo...
    ## Populating apt-get cache...
    + apt-get update
    OK:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    OK:2 http://archive.raspberrypi.org/debian bullseye InRelease
    OK:3 https://deb.nodesource.com/node_14.x bullseye InRelease
    ## Confirming "bullseye" is supported...
    + curl -sLf -o /dev/null 'https://deb.nodesource.com/node_14.x/dists/bullseye/Release'
    ## Adding the NodeSource signing key to your keyring...
    + curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | gpg --dearmor | tee /usr/share/keyrings/nodesource.gpg >/dev/null
    ## Creating apt sources list file for the NodeSource Node.js 14.x repo...
    + echo 'deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_14.x bullseye main' > /etc/apt/sources.list.d/nodesource.list
    + echo 'deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_14.x bullseye main' >> /etc/apt/sources.list.d/nodesource.list
    ## Running `apt-get update` for you...
    + apt-get update
    ## Run `sudo apt-get install -y nodejs` to install Node.js 14.x and npm
    ## You may also need development tools to build native addons:
         sudo apt-get install gcc g++ make
    ## To install the Yarn package manager, run:
         curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | gpg --dearmor | sudo tee /usr/share/keyrings/yarnkey.gpg >/dev/null
         echo "deb [signed-by=/usr/share/keyrings/yarnkey.gpg] https://dl.yarnpkg.com/debian stable main" | sudo tee /etc/apt/sources.list.d/yarn.list
         sudo apt-get update && sudo apt-get install yarn
    und danach den oben geschrieben Befehl.
    @guitardoc Nochmal
    which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && sudo apt update && apt policy nodejs
    G 1 Antwort Letzte Antwort
      @guitardoc Nochmal
      guitardoc
      schrieb am zuletzt editiert von guitardoc
      @thomas-braun said in Problem mit Backup Wiederherstellung auf dem Raspi:
      pi@raspberrypi:~ $ which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && sudo apt update && apt policy nodejs
      pi@raspberrypi:~ $
      • G guitardoc
        pi@raspberrypi:~ $
        @guitardoc
        sudo apt update
        apt policy nodejs
          @guitardoc
          sudo apt update
          apt policy nodejs
          guitardoc
          apt policy nodejs
          pi@raspberrypi:~ $ sudo apt update
          OK:2 https://deb.nodesource.com/node_14.x bullseye InRelease
          OK:3 http://archive.raspberrypi.org/debian bullseye InRelease
          Alle Pakete sind aktuell.
          pi@raspberrypi:~ $ apt policy nodejs
          nodejs:
            Installiert:           (keine)
            Installationskandidat: (keine)
            Versionstabelle:
               14.18.2-deb-1nodesource1 -1
                  500 https://deb.nodesource.com/node_14.x bullseye/main armhf Packages
               12.22.5~dfsg-2~11u1 -1
          pi@raspberrypi:~ $
          • G guitardoc
            apt policy nodejs
            nodejs:
              Versionstabelle:
            pi@raspberrypi:~ $
            @guitardoc
            sudo apt install nodejs
              @guitardoc
              guitardoc
              pi@raspberrypi:~ $ sudo apt install nodejs
              Paket nodejs ist nicht verfügbar, wird aber von einem anderen Paket
              referenziert. Das kann heißen, dass das Paket fehlt, dass es abgelöst
              wurde oder nur aus einer anderen Quelle verfügbar ist.
              Doch die folgenden Pakete ersetzen es:
                nodejs-doc
              E: Für Paket »nodejs« existiert kein Installationskandidat.
              pi@raspberrypi:~ $
              • G guitardoc
                  nodejs-doc
                pi@raspberrypi:~ $
                @guitardoc
                Komisch...
                sudo reboot
                G J 2 Antworten Letzte Antwort
                  @guitardoc
                  Komisch...
                  sudo reboot
                  guitardoc
                  Es ändert sich nichts:
                    nodejs-doc
                  pi@raspberrypi:~ $
                    @guitardoc
                    Komisch...
                    sudo reboot
                    Jan1
                    Legt die IObroker Installation nicht auch gleich das passende Repo an und macht den Rest eh automatisch richtig?
                    • J Jan1
                      @jan1 sagte in Problem mit Backup Wiederherstellung auf dem Raspi:
                      will er ja nicht.
                      Er hat da ein komisches Image mit einer fremden Installation drauf, die auf ein anderes repo zugreift
                      • G guitardoc
                          nodejs-doc
                        pi@raspberrypi:~ $
                        @guitardoc sagte in Problem mit Backup Wiederherstellung auf dem Raspi:
                        nodejs-doc
                        apt policy nodejs-doc
                          will er ja nicht.
                          Jan1
                          Die Repos oben sehen doch aber alle passend aus
                            nodejs-doc
                            guitardoc
                            pi@raspberrypi:~ $ apt policy nodejs-doc
                            nodejs-doc:
                              Installationskandidat: 12.22.5~dfsg-2~11u1
                              Versionstabelle:
                                 12.22.5~dfsg-2~11u1 500
                            pi@raspberrypi:~ $
                            • J Jan1
                              das ist ja das irritierende
                              @Thomas-Braun
                              gab es da nicht noch irgendeine Datei in der man etwas (Quellen) blocken konnte
                                @Thomas-Braun
                                @homoran sagte in Problem mit Backup Wiederherstellung auf dem Raspi:
                                Jein. Per 'pinning' kann man Präferenzen setzen, aber dann würde das Paket trotzdem bei
                                apt policy nodejs
                                auftauchen. Dann halt mit einem anderen Installationskandidaten. Aber so ganz ohne Vorschlag kenn ich das nicht.
                                G Meister MopperM 2 Antworten Letzte Antwort
                                  apt policy nodejs
                                  guitardoc
                                  Hmm, was mache ich denn nun? Ich muss mal für eine Stunde weg, daher bitte nicht wundern wenn nichts vin mir kommt - ichbrache aber dringend eure Hilfe, denn nun läuft ja gar nichts mehr ohne node...
                                    apt policy nodejs
                                    Meister MopperM Offline
                                    Meister Mopper
                                    #66
                                    @thomas-braun Ist das eigentlich beabsichtigt oder doppelt reinkopiert?
                                    Proxmox und HA ...
                                      #67
                                      @meister-mopper
                                      Das ist Absicht.
                                        @meister-mopper
                                        Das ist Absicht.
                                        guitardoc
                                        #68
                                        Hat zwischenzeitlich niemand eine Idee gehabt?
                                        • G guitardoc
                                          #69
                                          Plattmachen :-)
