  4. Nach Absturz keine Verbindung mehr REDIS PROBLEM [gelöst]
63 Beiträge 5 Kommentatoren 9.3k Aufrufe 3 Beobachtet
    @meicker
    Hast Du schon mal in den redis-server logfiles gesucht? Die liegen vermutlich in
    /var/log/redis
    meicker
    @meister-mopper
    da darf ich als 'user' nicht rein. Aber mit root ...
    4666:C 04 Dec 2021 15:00:18.887 # WARNING supervised by systemd - you MUST set appropriate values for TimeoutStartSec and TimeoutStopSec in your service unit.
    4666:C 04 Dec 2021 15:00:18.888 # oO0OoO0OoO0Oo Redis is starting oO0OoO0OoO0Oo
    4666:C 04 Dec 2021 15:00:18.888 # Redis version=6.0.15, bits=32, commit=00000000, modified=0, pid=4666, just started
    4666:C 04 Dec 2021 15:00:18.888 # Configuration loaded
    4666:M 04 Dec 2021 15:00:18.890 # Warning: 32 bit instance detected but no memory limit set. Setting 3 GB maxmemory limit with 'noeviction' policy now.
                    _._
               _.-``__ ''-._
          _.-``    `.  `_.  ''-._           Redis 6.0.15 (00000000/0) 32 bit
      .-`` .-```.  ```\/    _.,_ ''-._
     (    '      ,       .-`  | `,    )     Running in standalone mode
     |`-._`-...-` __...-.``-._|'` _.-'|     Port: 6379
     |    `-._   `._    /     _.-'    |     PID: 4666
      `-._    `-._  `-./  _.-'    _.-'
     |`-._`-._    `-.__.-'    _.-'_.-'|
     |    `-._`-._        _.-'_.-'    |           http://redis.io
      `-._    `-._`-.__.-'_.-'    _.-'
     |    `-._`-._        _.-'_.-'    |
          `-._    `-.__.-'    _.-'
              `-._        _.-'
                  `-.__.-'
    4666:M 04 Dec 2021 15:00:18.892 # Server initialized
    4666:M 04 Dec 2021 15:00:18.892 # WARNING overcommit_memory is set to 0! Background save may fail under low memory condition. To fix this issue add 'vm.overcommit_memory = 1' to /etc/sysctl.conf and then reboot or run the command 'sysctl vm.overcommit_memory=1' for this to take effect.
    4666:M 04 Dec 2021 15:00:18.892 # Wrong signature trying to load DB from file
    4666:M 04 Dec 2021 15:00:18.892 # Fatal error loading the DB: Invalid argument. Exiting.
    4681:C 04 Dec 2021 15:00:19.278 # WARNING supervised by systemd - you MUST set appropriate values for TimeoutStartSec and TimeoutStopSec in your service unit.
    4681:C 04 Dec 2021 15:00:19.278 # oO0OoO0OoO0Oo Redis is starting oO0OoO0OoO0Oo
    4681:C 04 Dec 2021 15:00:19.278 # Redis version=6.0.15, bits=32, commit=00000000, modified=0, pid=4681, just started
    4681:C 04 Dec 2021 15:00:19.278 # Configuration loaded
    4681:M 04 Dec 2021 15:00:19.281 # Warning: 32 bit instance detected but no memory limit set. Setting 3 GB maxmemory limit with 'noeviction' policy now.
    im zweiten Block Zeiole 2 und 3 kommt was ...
    Meister MopperM Thomas BraunT 2 Antworten Letzte Antwort
    • M meicker
      @meister-mopper
                      _._
                 _.-``__ ''-._
       |    `-._`-._        _.-'_.-'    |
            `-._    `-.__.-'    _.-'
                `-._        _.-'
                    `-.__.-'
      Meister MopperM Offline
      Meister Mopper
      @meicker
      Wie sieht denn Deine Arbeitsspeicherlandschaft aus? htop
      Und hast Du Redis Backup (Persistenz) konfiguriert?
      Proxmox und HA ...
      M 2 Antworten Letzte Antwort
        meicker
        Ich habe jetzt mal folgendes gemacht: setup custom - wieder auf File gesetzt. iobroker Status sieht dann gut aus und iobroker ist auch erreichbar.
        Dann habe ich noch ein Update gemacht was ebenfalls anstand: iob update / und upgrade self ... Dann neu gestartet.
        Dann habe ich versucht wieder redis einzuschalten für die states. Sieht zunächst auch gut aus aber wenn es daran geht sich mit der Datenbank zu verbinen schlägt das fehl ...
        marc@ioBroker:~$ iob stop
        marc@ioBroker:~$ iobroker setup custom
        Current configuration:
        - Objects database:
          - Type: file
          - Host/Unix Socket: 127.0.0.1
          - Port: 9001
        - States database:
          - Type: file
          - Port: 9000
        - Data Directory: ../../iobroker-data/
        Type of objects DB [(f)ile, (r)edis, ...], default [file]:
        Host / Unix Socket of objects DB(file), default[127.0.0.1]:
        Port of objects DB(file), default[9001]:
        Type of states DB [(f)file, (r)edis, ...], default [file]: r
        When States are stored in a Redis database please make sure to configure Redis
        persistence to make sure a Redis problem will not cause data loss!
        Host / Unix Socket of states DB (redis), default[127.0.0.1]:
        Port of states DB (redis), default[6379]:
        Data directory (file), default[../../iobroker-data/]:
        Host name of this machine [ioBroker]:
        This host appears to be a Master or a Single host system. Is this correct? [Y/n]: Y
        Do you want to migrate objects and states from "file/file" to "file/redis" [y/N]: y
        Connecting to previous DB "file"...
        Creating backup ...
        This can take some time ... please be patient!
        host.ioBroker 11855 states saved
        host.ioBroker 30778 objects saved
        Backup created: /opt/iobroker/backups/2021_12_04-17_39_34_backupiobroker-migration.tar.gz
        updating conf/iobroker.json
        Connecting to new DB "file" (can take up to 20s) ...
        No connection to states 127.0.0.1:6379[redis]
        New Database could not be connected. Please check your settings. No settings have been changed.
        restoring conf/iobroker.json
          @meicker
          meicker
          @meister-mopper sagte in Nach Absturz keine Verbindung mehr zum Admin REDIS PROBLEM:
            @meicker
            meicker
            ich denke nicht ... kommt mir unbekannt vor - wie prüfen oder machen ?
            • M meicker
              Meister Mopper
              @meicker
              Schau mal hier.
              Proxmox und HA ...
                meicker
                Eine Sicherung zurückspielen vom 3.12 oder 12.2 wo noch alles OK war wird wahrscheinlich nicht helfen weil ja die Verbindung zur DB nicht funktioniert. Die Daten als solches haben damit ja wahrscheinlich nichts zu tun.
                Mir ist aber bei upgrade self noch was aufgefallen, da kam eine Fehlermeldung:
                marc@ioBroker:~$ iob upgrade self
                Update js-controller from @3.3.19 to @3.3.21
                NPM version: 6.14.15
                npm install iobroker.js-controller@3.3.21 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
                Server Cannot move /opt/iobroker/iobroker-data/objects.json.new to /opt/iobroker/iobroker-data/objects.json: ENOENT: no such file or directory, stat '/opt/iobroker/iobroker-data/objects.json.new'. Try direct write as fallback
                • M meicker
                  Meister Mopper
                  @meicker
                  Die Fehlermeldung sagt mir nichts, aber hast Du denn überhaupt redis-backups?
                  Du musst ja die states/objects zurückspielen können, sonst sind sie perdu.
                  Proxmox und HA ...
                    @meicker
                    meicker
                    @meister-mopper
                    klar mache ich backups ... zurückspielen wäre kein Problem, aber da es ja scheinbar ein Paroblem mit der Datenbankverbindung gibt wird das wenig Sinn machen ... denke ich ...
                      meicker
                      oder ich lasse das mit redis einfach und bleibe bei file :-( Aber es muss doch eigentlich ne Lösung geben dafür ... redis-server deinstallieren und neu installierten ? Vielleicht ist beim Crash was kaputt gegangen.
                      • M meicker
                        @meister-mopper
                        Meister Mopper
                        schrieb am zuletzt editiert von Meister Mopper
                        @meicker sagte in Nach Absturz keine Verbindung mehr zum Admin REDIS PROBLEM:
                        Na dann, die Daten liegen in /var/lib/redis/dump.rdb, aber davon läuft der redis-server noch immer nicht.
                        Ich würde jetzt redis purgen und neu einrichten.
                        Proxmox und HA ...
                        • M meicker
                          @meister-mopper
                                          _._
                                     _.-``__ ''-._
                           |    `-._`-._        _.-'_.-'    |
                                `-._    `-.__.-'    _.-'
                                    `-._        _.-'
                                        `-.__.-'
                          Füge den User der Gruppe adm hinzu.
                            meicker
                            marc@ioBroker:~$ sudo usermod -aG adm marc
                            marc@ioBroker:~$ cd /var/log/redis
                            -bash: cd: /var/log/redis: Keine Berechtigung
                            • M meicker
                              @meicker
                              Die Gruppenrechte werden beim einloggen eingelesen. Also einmal ab- und wieder anmelden.
                                @meicker
                                meicker
                                @thomas-braun OK Danke :-)
                                  meicker
                                  @meister-mopper
                                  Ich habe alles von redis gelöscht und neu installiert. Jetzt verbindet er sich mit der Datenbank und ist gerade am arbeiten ... klappt also wieder - denke ich ...
                                  Vielen Dank für die Unterstützung !
                                  vg Marc
                                  Meister MopperM GlasfaserG 2 Antworten Letzte Antwort
                                  • M meicker
                                    @meister-mopper
                                    vg Marc
                                    Meister Mopper
                                    @meicker
                                    Schön 😊 , wenn es dann läuft editiere bitte diesen thread im ersten Beitrag auf [gelöst].
                                    Proxmox und HA ...
                                    • M meicker
                                      @meister-mopper
                                      vg Marc
                                      GlasfaserG Offline
                                      GlasfaserG Offline
                                      @meicker sagte in Nach Absturz keine Verbindung mehr REDIS PROBLEM [gelöst]:
                                      Also ...
                                      @thomas-braun sagte in Nach Absturz keine Verbindung mehr REDIS PROBLEM [gelöst]:
                                      Klar, wenn du da als root wie 'Elefant im Porzellanladen' durch das System stolperst und alles verbiegst...
                                      Meister MopperM M 2 Antworten Letzte Antwort
                                      • GlasfaserG Glasfaser
                                        Also ...
                                        Meister Mopper
                                        @glasfaser
                                        Nachtreten war früher 😖
                                        Proxmox und HA ...
                                          Also ...
                                          meicker
                                          @glasfaser
                                          sorry - das hatte mit root nix zu tun ... Da hast Du leider daneben getippt ... aber danke für den abschließenden Kommentar :-)
