  4. smartmeter startet nach js update nicht
js controller updatesmartmeter
9 Beiträge 4 Kommentatoren 284 Aufrufe 4 Beobachtet
  • amg_666A Offline
    amg_666A Offline
    amg_666
    Hallo, ich habe heute den js controller auf die 3.3.21 upgedatet, danach kommt der smartmeter nicht mehr hoch:
    ost.iostrom
    	2021-11-29 09:09:16.774	error	instance system.adapter.smartmeter.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.iostrom
    	2021-11-29 09:09:16.773	error	Caught by controller[0]: }
    host.iostrom
    	2021-11-29 09:09:16.772	error	Caught by controller[0]: code: 'ERR_DLOPEN_FAILED'
    host.iostrom
    	2021-11-29 09:09:16.771	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:981:32) {
    host.iostrom
    	2021-11-29 09:09:16.771	error	Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1153:10)
    host.iostrom
    	2021-11-29 09:09:16.770	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1101:14)
    host.iostrom
    	2021-11-29 09:09:16.769	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.smartmeter/node_modules/@serialport/bindings/lib/linux.js:2:36)
    host.iostrom
    	2021-11-29 09:09:16.769	error	Caught by controller[0]: at bindings (/opt/iobroker/node_modules/iobroker.smartmeter/node_modules/bindings/bindings.js:112:48)
    host.iostrom
    	2021-11-29 09:09:16.768	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:102:18)
    host.iostrom
    	2021-11-29 09:09:16.768	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1005:19)
    host.iostrom
    	2021-11-29 09:09:16.767	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:822:12)
    host.iostrom
    	2021-11-29 09:09:16.766	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:981:32)
    host.iostrom
    	2021-11-29 09:09:16.766	error	Caught by controller[0]: at Object.Module._extensions..node (node:internal/modules/cjs/loader:1183:18)
    host.iostrom
    	2021-11-29 09:09:16.765	error	Caught by controller[0]: Error: /opt/iobroker/node_modules/iobroker.smartmeter/node_modules/@serialport/bindings/build/Release/bindings.node: file too short
    host.iostrom
    	2021-11-29 09:09:16.765	error	Caught by controller[0]: ^
    host.iostrom
    	2021-11-29 09:09:16.764	error	Caught by controller[0]: throw e;
    host.iostrom
    	2021-11-29 09:09:16.762	error	Caught by controller[0]: /opt/iobroker/node_modules/iobroker.smartmeter/node_modules/bindings/bindings.js:121
    host.iostrom
    	2021-11-29 09:09:12.780	info	instance system.adapter.smartmeter.0 started with pid 1488
    • amg_666A amg_666
      ost.iostrom
      host.iostrom
      host.iostrom
      host.iostrom
      host.iostrom
      host.iostrom
      host.iostrom
      host.iostrom
      host.iostrom
      host.iostrom
      host.iostrom
      host.iostrom
      host.iostrom
      host.iostrom
      host.iostrom
      host.iostrom
      host.iostrom
      host.iostrom
      GlasfaserG Offline
      GlasfaserG Offline
      @amg_666 sagte in smartmeter startet nach js update nicht:
      hier wäre der gleiche Fehler , aber mit Zigbee ,
      https://forum.iobroker.net/topic/44566/how-to-node-js-für-iobroker-richtig-updaten-2021-edition/133?_=1638191651915
      Eventuell hilft ein
      iobroker upload all
      Oder was hast du an Node/NPM
      • GlasfaserG Glasfaser
        Eventuell hilft ein
        iobroker upload all
        amg_666A Offline
        amg_666A Offline
        amg_666
        @glasfaser ich bin im beta-repository unterwegs...node.js 16.13.0 und NPM 8.1.0.
        Das Thema hat sich aber bei mir erledigt, ich hab in der Konsole manuell wieder die 3.3.20 installiert und dann erneut nochmal update/upgrade self durchgeführt, jetzt läufts. Ich hab im Log dann gesehen, dass der Adapter erst wieder auf Fehler lief und dann ein erneuter rebuild gemacht wurde, danach liefs
        • amg_666A amg_666
          das hat mit beta nichts zu tun
          nodejs und npm sind nicht ioBroker
          npm v8 funktioniert nicht mit ioBroker
          amg_666A Thomas BraunT 2 Antworten Letzte Antwort
            amg_666A Offline
            amg_666A Offline
            amg_666
            @homoran sagte in smartmeter startet nach js update nicht:
            Warum funktioniert das nicht? Mein iob läuft (??)
            • amg_666A amg_666
              Mein iob läuft (??)
              das (rote) würde ich unterschreiben
                Mein iob läuft (??)
                amg_666A Offline
                amg_666A Offline
                amg_666
                @homoran iob auf einem nuc mit debian10 container und einem slave (pi3).
                Hier laufen 45 Adapter und die Instanzen sind alle "grün". Keinerlei Probleme soweit.
                • amg_666A amg_666
                  irgendwann muss ioB ja auch mit npm v8 laufen.
                  Aber sicher, dass es bei Updates nicht zu Problemen kommt, bist du nicht
                    So generell würde ich das nicht sagen. Aber man muss sich bewusst sein, das man sich da auf 'unbekanntem Terrain' bewegt und es zu Komplikationen kommen kann.
