<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[smartmeter startet nach js update nicht]]></title><description><![CDATA[<p dir="auto">Hallo, ich habe heute den js controller auf die 3.3.21 upgedatet, danach kommt der smartmeter nicht mehr hoch:</p>
<pre><code>ost.iostrom
	2021-11-29 09:09:16.774	error	instance system.adapter.smartmeter.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
host.iostrom
	2021-11-29 09:09:16.773	error	Caught by controller[0]: }
host.iostrom
	2021-11-29 09:09:16.772	error	Caught by controller[0]: code: 'ERR_DLOPEN_FAILED'
host.iostrom
	2021-11-29 09:09:16.771	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:981:32) {
host.iostrom
	2021-11-29 09:09:16.771	error	Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1153:10)
host.iostrom
	2021-11-29 09:09:16.770	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1101:14)
host.iostrom
	2021-11-29 09:09:16.769	error	Caught by controller[0]: at Object.&lt;anonymous&gt; (/opt/iobroker/node_modules/iobroker.smartmeter/node_modules/@serialport/bindings/lib/linux.js:2:36)
host.iostrom
	2021-11-29 09:09:16.769	error	Caught by controller[0]: at bindings (/opt/iobroker/node_modules/iobroker.smartmeter/node_modules/bindings/bindings.js:112:48)
host.iostrom
	2021-11-29 09:09:16.768	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:102:18)
host.iostrom
	2021-11-29 09:09:16.768	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1005:19)
host.iostrom
	2021-11-29 09:09:16.767	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:822:12)
host.iostrom
	2021-11-29 09:09:16.766	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:981:32)
host.iostrom
	2021-11-29 09:09:16.766	error	Caught by controller[0]: at Object.Module._extensions..node (node:internal/modules/cjs/loader:1183:18)
host.iostrom
	2021-11-29 09:09:16.765	error	Caught by controller[0]: Error: /opt/iobroker/node_modules/iobroker.smartmeter/node_modules/@serialport/bindings/build/Release/bindings.node: file too short
host.iostrom
	2021-11-29 09:09:16.765	error	Caught by controller[0]: ^
host.iostrom
	2021-11-29 09:09:16.764	error	Caught by controller[0]: throw e;
host.iostrom
	2021-11-29 09:09:16.762	error	Caught by controller[0]: /opt/iobroker/node_modules/iobroker.smartmeter/node_modules/bindings/bindings.js:121
host.iostrom
	2021-11-29 09:09:12.780	info	instance system.adapter.smartmeter.0 started with pid 1488
</code></pre>
]]></description><link>https://forum.iobroker.net/topic/49826/smartmeter-startet-nach-js-update-nicht</link><generator>RSS for Node</generator><lastBuildDate>Wed, 27 May 2026 11:12:00 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/49826.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 29 Nov 2021 08:10:28 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to smartmeter startet nach js update nicht on Mon, 29 Nov 2021 16:40:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/homoran" aria-label="Profile: homoran">@<bdi>homoran</bdi></a> sagte in <a href="/post/712152">smartmeter startet nach js update nicht</a>:</p>
<blockquote>
<p dir="auto">npm v8 funktioniert nicht mit ioBroker</p>
</blockquote>
<p dir="auto">So generell würde ich das nicht sagen. Aber man muss sich bewusst sein, das man sich da auf 'unbekanntem Terrain' bewegt und es zu Komplikationen kommen kann.</p>
]]></description><link>https://forum.iobroker.net/post/712189</link><guid isPermaLink="true">https://forum.iobroker.net/post/712189</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Mon, 29 Nov 2021 16:40:18 GMT</pubDate></item><item><title><![CDATA[Reply to smartmeter startet nach js update nicht on Mon, 29 Nov 2021 15:52:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/amg_666" aria-label="Profile: amg_666">@<bdi>amg_666</bdi></a> sagte in <a href="/post/712158">smartmeter startet nach js update nicht</a>:</p>
<blockquote>
<p dir="auto">Hier laufen 45 Adapter und die Instanzen sind alle "grün". Keinerlei Probleme soweit.</p>
</blockquote>
<p dir="auto">irgendwann muss ioB ja auch mit npm v8 laufen.<br />
Aber sicher, dass es bei Updates nicht zu Problemen kommt, bist du nicht</p>
]]></description><link>https://forum.iobroker.net/post/712164</link><guid isPermaLink="true">https://forum.iobroker.net/post/712164</guid><dc:creator><![CDATA[Homoran]]></dc:creator><pubDate>Mon, 29 Nov 2021 15:52:58 GMT</pubDate></item><item><title><![CDATA[Reply to smartmeter startet nach js update nicht on Mon, 29 Nov 2021 15:40:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/homoran" aria-label="Profile: homoran">@<bdi>homoran</bdi></a> iob auf einem nuc mit debian10 container und einem slave (pi3).<br />
]]></description><link>https://forum.iobroker.net/post/712158</link><guid isPermaLink="true">https://forum.iobroker.net/post/712158</guid><dc:creator><![CDATA[amg_666]]></dc:creator><pubDate>Mon, 29 Nov 2021 15:40:13 GMT</pubDate></item><item><title><![CDATA[Reply to smartmeter startet nach js update nicht on Mon, 29 Nov 2021 15:34:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/amg_666" aria-label="Profile: amg_666">@<bdi>amg_666</bdi></a> sagte in <a href="/post/712154">smartmeter startet nach js update nicht</a>:</p>
<blockquote>
<p dir="auto">Mein iob läuft (<span style="color:#ff0000"><strong>??</strong></span>)</p>
</blockquote>
<p dir="auto">das (rote) würde ich unterschreiben</p>
]]></description><link>https://forum.iobroker.net/post/712156</link><guid isPermaLink="true">https://forum.iobroker.net/post/712156</guid><dc:creator><![CDATA[Homoran]]></dc:creator><pubDate>Mon, 29 Nov 2021 15:34:19 GMT</pubDate></item><item><title><![CDATA[Reply to smartmeter startet nach js update nicht on Mon, 29 Nov 2021 15:33:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/homoran" aria-label="Profile: homoran">@<bdi>homoran</bdi></a> sagte in <a href="/post/712152">smartmeter startet nach js update nicht</a>:</p>
<blockquote>
</blockquote>
<p dir="auto">Warum funktioniert das nicht? Mein iob läuft (??)<br />
<img src="/assets/uploads/files/1638199934519-fce27320-73a1-476b-978d-fd3f52cc8974-grafik.png" alt="fce27320-73a1-476b-978d-fd3f52cc8974-grafik.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.iobroker.net/post/712154</link><guid isPermaLink="true">https://forum.iobroker.net/post/712154</guid><dc:creator><![CDATA[amg_666]]></dc:creator><pubDate>Mon, 29 Nov 2021 15:33:19 GMT</pubDate></item><item><title><![CDATA[Reply to smartmeter startet nach js update nicht on Mon, 29 Nov 2021 15:27:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/amg_666" aria-label="Profile: amg_666">@<bdi>amg_666</bdi></a> sagte in <a href="/post/712143">smartmeter startet nach js update nicht</a>:</p>
<blockquote>
<p dir="auto">ch bin im beta-repository unterwegs...node.js 16.13.0 und NPM 8.1.0.</p>
</blockquote>
<p dir="auto">das hat mit beta nichts zu tun</p>
<p dir="auto">nodejs und npm sind nicht ioBroker</p>
]]></description><link>https://forum.iobroker.net/post/712152</link><guid isPermaLink="true">https://forum.iobroker.net/post/712152</guid><dc:creator><![CDATA[Homoran]]></dc:creator><pubDate>Mon, 29 Nov 2021 15:27:48 GMT</pubDate></item><item><title><![CDATA[Reply to smartmeter startet nach js update nicht on Mon, 29 Nov 2021 15:11:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/glasfaser" aria-label="Profile: glasfaser">@<bdi>glasfaser</bdi></a> ich bin im beta-repository unterwegs...node.js 16.13.0 und NPM 8.1.0.<br />
Das Thema hat sich aber bei mir erledigt, ich hab in der Konsole manuell wieder die 3.3.20 installiert und dann erneut nochmal update/upgrade self durchgeführt, jetzt läufts. Ich hab im Log dann gesehen, dass der Adapter erst wieder auf Fehler lief und dann ein erneuter rebuild gemacht wurde, danach liefs</p>
]]></description><link>https://forum.iobroker.net/post/712143</link><guid isPermaLink="true">https://forum.iobroker.net/post/712143</guid><dc:creator><![CDATA[amg_666]]></dc:creator><pubDate>Mon, 29 Nov 2021 15:11:31 GMT</pubDate></item><item><title><![CDATA[Reply to smartmeter startet nach js update nicht on Mon, 29 Nov 2021 13:48:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/amg_666" aria-label="Profile: amg_666">@<bdi>amg_666</bdi></a> sagte in <a href="/post/711971">smartmeter startet nach js update nicht</a>:</p>
<blockquote>
<p dir="auto">2021-11-29 09:09:16.772	error	Caught by controller[0]: code: 'ERR_DLOPEN_FAILED'</p>
</blockquote>
<p dir="auto">hier wäre der gleiche Fehler  , aber mit Zigbee ,</p>
<p dir="auto"><a href="https://forum.iobroker.net/topic/44566/how-to-node-js-f%C3%BCr-iobroker-richtig-updaten-2021-edition/133?_=1638191651915">https://forum.iobroker.net/topic/44566/how-to-node-js-für-iobroker-richtig-updaten-2021-edition/133?_=1638191651915</a></p>
<p dir="auto">Eventuell hilft ein</p>
<pre><code>iobroker upload all
</code></pre>
<p dir="auto">Oder was hast du an Node/NPM</p>
]]></description><link>https://forum.iobroker.net/post/712097</link><guid isPermaLink="true">https://forum.iobroker.net/post/712097</guid><dc:creator><![CDATA[Glasfaser]]></dc:creator><pubDate>Mon, 29 Nov 2021 13:48:08 GMT</pubDate></item></channel></rss>
