  4. Ich brauche Hilfe für den Umzug des iOBroker auf einen NUC
windows backup restore linux
92 Beiträge 7 Kommentatoren 8.2k Aufrufe 6 Beobachtet
  • P peterredl
    @homoran soll ich den iobroker stoppen (sorry)?
    peter@q4os-desktop:~$ iobroker host this
    Cannot execute changes on running system. Stop iobroker first.
    #83
    @peterredl sagte in Ich brauche Hilfe für den Umzug des iOBroker auf einen NUC:
    wenn dein DESKTOP das möchte, natürlich (sorry, hatte ich nicht auf dem Schirm)
    P 1 Antwort Letzte Antwort
      P Online
      P Online
      peterredl
      #84
      peter@q4os-desktop:~$ iobroker stop
      Host "SmartHome(SmartHome)" successfully renamed to "q4os-desktop".
      The host for instance "system.adapter.admin.0" was changed from "q4os-desktop" t
      o "q4os-desktop".
      The host for instance "system.adapter.alexa2.0" was changed from "q4os-desktop"
      to "q4os-desktop".
      The host for instance "system.adapter.backitup.0" was changed from "q4os-desktop
      " to "q4os-desktop".
      The host for instance "system.adapter.broadlink2.0" was changed from "q4os-deskt
      op" to "q4os-desktop".
      The host for instance "system.adapter.cloud.0" was changed from "q4os-desktop" t
      o "q4os-desktop".
      The host for instance "system.adapter.daswetter.0" was changed from "q4os-deskto
      The host for instance "system.adapter.discovery.0" was changed from "q4os-deskto
      The host for instance "system.adapter.fb-checkpresence.0" was changed from "q4os
      -desktop" to "q4os-desktop".
      The host for instance "system.adapter.fronius.0" was changed from "q4os-desktop"
       to "q4os-desktop".
      The host for instance "system.adapter.go-e.0" was changed from "q4os-desktop" to
       "q4os-desktop".
      The host for instance "system.adapter.ham.0" was changed from "q4os-desktop" to
      "q4os-desktop".
      The host for instance "system.adapter.history.0" was changed from "q4os-desktop"
       to "q4os-desktop".
      The host for instance "system.adapter.hmip.0" was changed from "q4os-desktop" to
       "q4os-desktop".
      The host for instance "system.adapter.hs100.0" was changed from "q4os-desktop" t
      o "q4os-desktop".
      The host for instance "system.adapter.info.0" was changed from "q4os-desktop" to
       "q4os-desktop".
      The host for instance "system.adapter.iot.0" was changed from "q4os-desktop" to
      "q4os-desktop".
      The host for instance "system.adapter.javascript.0" was changed from "q4os-deskt
      The host for instance "system.adapter.mercedesme.0" was changed from "q4os-deskt
      The host for instance "system.adapter.mihome.0" was changed from "q4os-desktop"
      to "q4os-desktop".
      The host for instance "system.adapter.netatmo-crawler.0" was changed from "q4os-
      The host for instance "system.adapter.netatmo.0" was changed from "q4os-desktop"
       to "q4os-desktop".
      The host for instance "system.adapter.shelly.0" was changed from "q4os-desktop"
      to "q4os-desktop".
      The host for instance "system.adapter.sonoff.0" was changed from "q4os-desktop"        to "q4os-desktop".
      The host for instance "system.adapter.surepetcareio.0" was changed from "q4os-de        sktop" to "q4os-desktop".
      The host for instance "system.adapter.telegram.0" was changed from "q4os-desktop        " to "q4os-desktop".
      The host for instance "system.adapter.tuya.0" was changed from "q4os-desktop" to        "q4os-desktop".
      The host for instance "system.adapter.vis-hqwidgets.0" was changed from "q4os-de        sktop" to "q4os-desktop".
      The host for instance "system.adapter.vis-jqui-mfd.0" was changed from "q4os-des        ktop" to "q4os-desktop".
      The host for instance "system.adapter.vis-timeandweather.0" was changed from "q4        os-desktop" to "q4os-desktop".
      The host for instance "system.adapter.vis-weather.0" was changed from "q4os-desk        top" to "q4os-desktop".
      The host for instance "system.adapter.vis.0" was changed from "q4os-desktop" to        "q4os-desktop".
      The host for instance "system.adapter.web.0" was changed from "q4os-desktop" to        "q4os-desktop".
      The host for instance "system.adapter.zigbee.0" was changed from "q4os-desktop"        to "q4os-desktop".
      • P peterredl
        o "q4os-desktop".
        to "q4os-desktop".
        o "q4os-desktop".
         to "q4os-desktop".
         "q4os-desktop".
        "q4os-desktop".
         to "q4os-desktop".
         "q4os-desktop".
        o "q4os-desktop".
         "q4os-desktop".
        "q4os-desktop".
        to "q4os-desktop".
         to "q4os-desktop".
        to "q4os-desktop".
        #85
        @peterredl iobroker start
        und Meldung machen
        P 2 Antworten Letzte Antwort
          und Meldung machen
          P Online
          P Online
          peterredl
          #86
          Jetzt gehts. Super. Danke vielmals. Kann ich die einen Kaffe spendieren?
            und Meldung machen
            P Online
            P Online
            peterredl
            schrieb am zuletzt editiert von peterredl
            #87
            kannst du mir vielleicht noch beim Zigbee-Adapter weiterhelfen?
            Ich kenn mich nur im Windows aus und Linux ist ein spanisches Dorf für mich.
            ich bin übrigens 72, habe aber vor 50 Jahren in Assembler eine Menge Programme geschrieben....
            HomoranH J 2 Antworten Letzte Antwort
            • P peterredl
              #88
              Nee, ich habe keine Bienen.
              Aber vielleicht @Thomas-Braun
              • P peterredl
                Jan1
                #89
                @peterredl
                Ist recht einfach. In der Konsole den Befehl rein:
                ls /dev/serial/by-id/
                was da bei raus kommt danach als Port eintragen:
                /dev/serial/by-id/....
                  #90
                  @homoran @peterredl
                  Hab ich. Aber bitte in einem eigenen Thread.
                    auch eine LINUX mit graphischer Oberfläche und einen Browser installiert.
                    das war aber nicht abgesprochen :-(
                    ein Server braucht das nicht
                    mach mal iobroker host this
                    #91
                    @homoran sagte in Ich brauche Hilfe für den Umzug des iOBroker auf einen NUC:
                    da müsste mal @simatec was zu sagen, wie bei backitup und restore mit Änderung des Hostnamens umzugehen ist
                    • J Jan1
                      @peterredl
                      P Online
                      P Online
                      peterredl
                      #92
                      @jan1 Danke. Hat funktioniert. 😊
