  4. Fehler bei Installation
    6.3k
23 Beiträge 3 Kommentatoren 2.4k Aufrufe 2 Beobachtet
    @xnetworker-x
    Dann
    sudo apt remove nodejs node-*
    sudo apt update
    sudo apt dist-upgrade
    sudo apt install nodejs
    sudo reboot
    Xnetworker XX Offline
    Xnetworker X
    pi@raspberrypi:~ $ sudo apt remove nodejs node-*
    Reading package lists... Done
    Note, selecting 'node-jsdom' instead of 'node-data-urls'
    Note, selecting 'node-jsdom' instead of 'node-decimal.js'
    Note, selecting 'node-jsdom' instead of 'node-domexception'
    Note, selecting 'node-jsdom' instead of 'node-html-encoding-sniffer'
    Package 'node-zeparser' is not installed, so not removed
    Package 'node-zipfile' is not installed, so not removed
    You might want to run 'apt --fix-broken install' to correct these.
    The following packages have unmet dependencies:
     libreoffice-help-common : Depends: libjs-normalize.css
    E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
    pi@raspberrypi:~ $ sudo apt dist-upgrade
     nodejs : Depends: libnode72 (= 12.22.5~dfsg-2~11u1) but it is not installed
    pi@raspberrypi:~ $ sudo apt install nodejs
    The following packages were automatically installed and are no longer required:
      gyp libc-ares2 libfuse2 libjs-highlight.js libjs-inherits libjs-is-typedarray libjs-psl libjs-typedarray-to-buffer
      libssl-dev libuv1-dev node-abbrev node-agent-base node-ajv node-ansi node-ansi-regex node-ansi-styles node-ansistyles
      node-aproba node-archy node-are-we-there-yet node-asap node-asn1 node-assert-plus node-asynckit node-aws-sign2 node-aws4
      node-balanced-match node-bcrypt-pbkdf node-brace-expansion node-builtins node-cacache node-caseless node-chalk node-chownr
      node-clone node-color-convert node-color-name node-colors node-columnify node-combined-stream node-concat-map
      node-console-control-strings node-copy-concurrently node-core-util-is node-dashdash node-debug node-defaults
      node-delayed-stream node-delegates node-depd node-ecc-jsbn node-encoding node-err-code node-escape-string-regexp
      node-extend node-extsprintf node-fast-deep-equal node-forever-agent node-form-data node-fs-write-stream-atomic
      node-fs.realpath node-function-bind node-gauge node-getpass node-glob node-graceful-fs node-har-schema node-har-validator
      node-has-flag node-has-unicode node-hosted-git-info node-http-signature node-https-proxy-agent node-iconv-lite node-iferr
      node-imurmurhash node-indent-string node-inflight node-inherits node-ini node-ip node-ip-regex node-is-typedarray
      node-isarray node-isexe node-isstream node-jsbn node-json-parse-better-errors node-json-schema node-json-schema-traverse
      node-json-stable-stringify node-json-stringify-safe node-jsonify node-jsonparse node-jsonstream node-jsprim node-leven
      node-lockfile node-lru-cache node-mime node-mime-types node-minimatch node-mkdirp node-move-concurrently node-ms
      node-mute-stream node-nopt node-normalize-package-data node-npm-bundled node-npm-package-arg node-npmlog node-number-is-nan
      node-oauth-sign node-object-assign node-once node-opener node-osenv node-p-map node-path-is-absolute node-performance-now
      node-process-nextick-args node-promise-inflight node-promise-retry node-promzard node-psl node-puka node-punycode node-qs
      node-read node-read-package-json node-readable-stream node-request node-resolve node-resolve-from node-retry node-rimraf
      node-run-queue node-safe-buffer node-semver node-set-blocking node-signal-exit node-slash node-spdx-correct
      node-spdx-exceptions node-spdx-expression-parse node-spdx-license-ids node-sshpk node-ssri node-string-decoder
      node-string-width node-strip-ansi node-supports-color node-tar node-text-table node-through node-tough-cookie
      node-tunnel-agent node-tweetnacl node-typedarray-to-buffer node-unique-filename node-universalify node-uri-js
      node-util-deprecate node-uuid node-validate-npm-package-license node-validate-npm-package-name node-verror node-wcwidth.js
      node-which node-wide-align node-wrappy node-write-file-atomic node-yallist nodejs-doc python-is-python2
    Use 'sudo apt autoremove' to remove them.
    The following packages will be upgraded:
      nodejs
    1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
    Need to get 0 B/22.9 MB of archives.
    After this operation, 115 MB of additional disk space will be used.
    Reading changelogs... Done
    (Reading database ... 166330 files and directories currently installed.)
    Preparing to unpack .../nodejs_14.18.1-deb-1nodesource1_armhf.deb ...
    Unpacking nodejs (14.18.1-deb-1nodesource1) over (12.22.5~dfsg-2~11u1) ...
    dpkg: error processing archive /var/cache/apt/archives/nodejs_14.18.1-deb-1nodesource1_armhf.deb (--unpack):
     trying to overwrite '/usr/share/doc/nodejs/api/embedding.json.gz', which is also in package nodejs-doc 12.22.5~dfsg-2~11u1
    dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
    Errors were encountered while processing:
    E: Sub-process /usr/bin/dpkg returned an error code (1)
    pi@raspberrypi:~ $ sudo reboot
    • Xnetworker XX Xnetworker X
        nodejs
      @xnetworker-x sagte in Fehler bei Installation:
      nodejs-doc
      sudo apt autoremove
      sudo apt remove nodejs-doc
      Und bitte das Raspberry OS NICHT in der Desktop-Variante verwenden.
      Am besten nochmal neuinstallieren, diesmal in der Lite-Version.
      Xnetworker XX 2 Antworten Letzte Antwort
        nodejs-doc
        sudo apt autoremove
        Xnetworker X
        Dann stehe ich vor dem Problem, wie ich von der SD-Karte auf die SSD die Daten kopiere. Dies habe ich über das Tool SD Copy durchgeführt. Habe dazu keine andere Anleitung gefunden. Nutze das Argon M.2 Gehäuse mit einer 500GB -SSD
          nodejs-doc
          sudo apt autoremove
          Xnetworker X
          @thomas-braun said in Fehler bei Installation:
          sudo apt autoremove
          pi@raspberrypi:~ $ sudo apt autoremove
          pi@raspberrypi:~ $ sudo apt remove nodejs-doc
           nodejs : Depends: libnode72 (= 12.22.5~dfsg-2~11u1) but it is not going to be installed
                    Recommends: nodejs-doc but it is not going to be installed
            @xnetworker-x
            Mach es mit dem Raspberry Pi Imager
            https://www.raspberrypi.com/software/
            Da kann man das 32bit Rasperry OS lite aussuchen, nicht das Recommended Desktop-Ding verwenden.
              @xnetworker-x
              Xnetworker X
              @thomas-braun Wie kopiere ich dann die SD-Karte auf die SSD?
                @xnetworker-x
                Xnetworker X
                @thomas-braun Den habe ich auch genutzt. Nur nicht die Lite-Version
                  Warum nicht?
                  Xnetworker XX 1 Antwort Letzte Antwort
                    Was hast du vor?
                    Installier es auf die SD-Karte und dann stellst du das von dort auf SSD-Betreib um. Gibt irgendwo Anleitungen dazu, wie das gemacht wird.
                    Ich betreibe meine Raspberrys nur mit SD-Karten.
                      Warum nicht?
                      Xnetworker X
                      Warum nicht?
                      Weil ich in der Desktop-Version das Klonetool genutzt habe.
                        Was hast du vor?
                        Xnetworker X
                        Was hast du vor?
                        Dazu müssen doch aber alle Daten von der SD auf die SSD kopiert werden. Habe leider noch keine funktionierende Anleitung gefunden.
                          Warum nicht?
                          Für einen Server wird kein Desktop installiert.
