  4. Probleme mit Zigbee und CC26X2R1
140 Beiträge 13 Kommentatoren 21.1k Aufrufe 14 Beobachtet
  • schmitzkatzeS schmitzkatze
    @thomas-braun ```läuft einfach nicht! Habe jetzt die CC26... an einen anderen USB gehängt vorher den NUC runtergefahren dann den USB in den Einstellungen ausgewählt >reboot, aber nix ! ich habe mal den Log angehängt evtl. sehen die Experten was da fehlt.
    host.debianIObroker
    2021-11-26 17:02:07.440	info	Restart adapter system.adapter.zigbee.0 because enabled
    host.debianIObroker
    2021-11-26 17:02:07.438	error	instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.debianIObroker
    2021-11-26 17:02:07.438	error	Caught by controller[0]: }
    host.debianIObroker
    2021-11-26 17:02:07.438	error	Caught by controller[0]: ]
    host.debianIObroker
    2021-11-26 17:02:07.437	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.zigbee/main.js'
    host.debianIObroker
    2021-11-26 17:02:07.437	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.zigbee/lib/seriallist.js',
    host.debianIObroker
    2021-11-26 17:02:07.437	error	Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/serialPortUtils.js',
    host.debianIObroker
    2021-11-26 17:02:07.437	error	Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman/dist/utils/index.js',
    host.debianIObroker
    2021-11-26 17:02:07.436	error	Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman/dist/utils/backup.js',
    host.debianIObroker
    2021-11-26 17:02:07.436	error	Caught by controller[0]: requireStack: [
    host.debianIObroker
    2021-11-26 17:02:07.436	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
    host.debianIObroker
    2021-11-26 17:02:07.436	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:974:19) {
    host.debianIObroker
    2021-11-26 17:02:07.435	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12)
    host.debianIObroker
    2021-11-26 17:02:07.435	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
    host.debianIObroker
    2021-11-26 17:02:07.435	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
    host.debianIObroker
    2021-11-26 17:02:07.435	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
    host.debianIObroker
    2021-11-26 17:02:07.434	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/utils/backup.js:34:14)
    host.debianIObroker
    2021-11-26 17:02:07.434	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:93:18)
    host.debianIObroker
    2021-11-26 17:02:07.434	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:974:19)
    host.debianIObroker
    2021-11-26 17:02:07.434	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:746:27)
    host.debianIObroker
    2021-11-26 17:02:07.433	error	Caught by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:902:15)
    host.debianIObroker
    2021-11-26 17:02:07.433	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.zigbee/main.js
    host.debianIObroker
    2021-11-26 17:02:07.433	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.zigbee/lib/seriallist.js
    host.debianIObroker
    2021-11-26 17:02:07.433	error	Caught by controller[0]: - /opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/serialPortUtils.js
    host.debianIObroker
    2021-11-26 17:02:07.433	error	Caught by controller[0]: - /opt/iobroker/node_modules/zigbee-herdsman/dist/utils/index.js
    host.debianIObroker
    2021-11-26 17:02:07.432	error	Caught by controller[0]: - /opt/iobroker/node_modules/zigbee-herdsman/dist/utils/backup.js
    host.debianIObroker
    2021-11-26 17:02:07.432	error	Caught by controller[0]: Require stack:
    host.debianIObroker
    2021-11-26 17:02:07.432	error	Caught by controller[0]: Error: Cannot find module 'mz'
    host.debianIObroker
    2021-11-26 17:02:07.432	error	Caught by controller[0]: ^
    host.debianIObroker
    2021-11-26 17:02:07.431	error	Caught by controller[0]: throw err;
    host.debianIObroker
    2021-11-26 17:02:07.431	error	Caught by controller[0]: internal/modules/cjs/loader.js:905
    host.debianIObroker
    2021-11-26 17:02:06.820	info	instance system.adapter.zigbee.0 started with pid 940
    host.debianIObroker
    2021-11-26 17:02:06.420	info	Restart adapter system.adapter.zigbee.0 because enabled
    #83
    @schmitzkatze
    cd /opt/iobroker/
    npm list mz
    schmitzkatzeS 1 Antwort Letzte Antwort
      @opossum said in Probleme mit Zigbee und CC26X2R1:
      Hallo, @schmitzkatze,
      ich könnte Dir anbieten, eine komplette Installation auf Proxmox unter Debian 11 remote zu unterstützen. Wenn Du magst, könnten wir uns über AnyDesk (Teamviewer geht bei mir leider nicht) "treffen" und wir machen im Proxmox eine komplette Neuinstallation einer VM und dann in dieser VM iobroker. Wenn Du die Hilfe möchtest, schaue in den Chat, ich habe Dir dort meine Telefonnummer geschickt. Wir brauchen schätzungsweise eine halbe bis maximal eine Stunde.
      das ist super nett von Dir, die VM läuft ja. Ich habe letztes Jahr das gleiche Problem über Tage gehabt, und die Maschine runter und rauf gefahren, USB geändert usw. dann auf mal lief es 🤷‍♂️ deshalb denke ich nicht das es an der VM liegt.
      Aber vielleicht komme ich darauf zurück! 👍
      opossumO Offline
      opossumO Offline
      opossum
      schrieb am zuletzt editiert von opossum
      #84
      dann versuche doch einfach, mal vorn vorn zu beginnen. Ist die bessere Alternative. ZigBee ist vielleicht nicht Dein letztes Problem. Erst einmal alles sauber installieren und dann das Problem ZigBee angehen. Aber das ist Deine Entscheidung. Ich kanns nur anbieten. Danke Dir. Klinke mich dann mal aus, sorry für die Störung.
      https://www.schlepper-petersdorf.de
        @schmitzkatze
        cd /opt/iobroker/
        npm list mz
        schmitzkatzeS Offline
        schmitzkatze
        #85
        @thomas-braun ```
        michael@debianIObroker:/opt/iobroker$ npm list mz
        [sudo] Passwort für michael:
        npm WARN read-shrinkwrap This version of npm is compatible with lockfileVersion@1, but package-lock.json was generated for lockfileVersion@2. I'll try to do my best with it!
        iobroker.inst@3.0.0 /opt/iobroker
        └─┬ UNMET DEPENDENCY iobroker.zigbee@1.5.6
          └─┬ UNMET DEPENDENCY zigbee-herdsman@0.13.110
            └── UNMET DEPENDENCY mz@^2.7.0
        npm ERR! missing: iobroker.zigbee@1.5.6, required by iobroker.inst@3.0.0
        npm ERR! missing: zigbee-herdsman@0.13.110, required by iobroker.zigbee@1.5.6
        npm ERR! missing: mz@^2.7.0, required by zigbee-herdsman@0.13.110
          @thomas-braun ```
          #86
          @schmitzkatze
          Da ist der Adapter nicht richtig installiert.
          npm list
          sagt?
            @schmitzkatze
            npm list
            sagt?
            schmitzkatze
            #87
            @thomas-braun heißt ? deinstallieren ; Neustarten ; installieren und dann nochmal prüfen ?
              #88
              @schmitzkatze
              Zeig mal die Ausgabe von
              npm list
                @schmitzkatze
                npm list
                schmitzkatze
                schrieb am zuletzt editiert von schmitzkatze
                #89
                @thomas-braun ``` ich hoffe das ich das jetzt richtig gemacht habe 🥶 und das ist noch nicht alles !!
                ├─┬ UNMET DEPENDENCY iobroker.admin@5.1.25
                │ ├─┬ UNMET DEPENDENCY @iobroker/adapter-core@2.5.1
                │ │ └─┬ UNMET DEPENDENCY @types/iobroker@3.3.4
                │ │   └── UNMET DEPENDENCY @types/node@14.14.37
                │ ├─┬ UNMET DEPENDENCY body-parser@1.19.0
                │ │ ├── UNMET DEPENDENCY bytes@3.1.0
                │ │ ├── UNMET DEPENDENCY content-type@1.0.4
                │ │ ├─┬ UNMET DEPENDENCY debug@2.6.9
                │ │ │ └── UNMET DEPENDENCY ms@2.0.0
                │ │ ├── UNMET DEPENDENCY depd@1.1.2
                │ │ ├─┬ UNMET DEPENDENCY http-errors@1.7.2
                │ │ │ ├── UNMET DEPENDENCY depd@1.1.2
                │ │ │ ├── UNMET DEPENDENCY inherits@2.0.3
                │ │ │ ├── UNMET DEPENDENCY setprototypeof@1.1.1
                │ │ │ ├── UNMET DEPENDENCY statuses@1.5.0
                │ │ │ └── UNMET DEPENDENCY toidentifier@1.0.0
                │ │ ├─┬ UNMET DEPENDENCY iconv-lite@0.4.24
                │ │ │ └── UNMET DEPENDENCY safer-buffer@2.1.2
                │ │ ├─┬ UNMET DEPENDENCY on-finished@2.3.0
                │ │ │ └── UNMET DEPENDENCY ee-first@1.1.1
                │ │ ├── UNMET DEPENDENCY qs@6.7.0
                │ │ ├─┬ UNMET DEPENDENCY raw-body@2.4.0
                │ │ │ ├── UNMET DEPENDENCY bytes@3.1.0
                │ │ │ ├── UNMET DEPENDENCY http-errors@1.7.2
                │ │ │ ├── UNMET DEPENDENCY iconv-lite@0.4.24
                │ │ │ └── UNMET DEPENDENCY unpipe@1.0.0
                │ │ └─┬ UNMET DEPENDENCY type-is@1.6.18
                │ │   ├── UNMET DEPENDENCY media-typer@0.3.0
                │ │   └── UNMET DEPENDENCY mime-types@2.1.29
                │ ├── UNMET DEPENDENCY connect-flash@0.1.1
                │ ├─┬ UNMET DEPENDENCY cookie-parser@1.4.5
                │ │ ├── UNMET DEPENDENCY cookie@0.4.0
                │ │ └── UNMET DEPENDENCY cookie-signature@1.0.6
                │ ├─┬ UNMET DEPENDENCY express@4.17.1
                │ │ ├─┬ UNMET DEPENDENCY accepts@1.3.7
                │ │ │ ├── UNMET DEPENDENCY mime-types@2.1.29
                │ │ │ └── UNMET DEPENDENCY negotiator@0.6.2
                │ │ ├── UNMET DEPENDENCY array-flatten@1.1.1
                │ │ ├── UNMET DEPENDENCY body-parser@1.19.0
                │ │ ├─┬ UNMET DEPENDENCY content-disposition@0.5.3
                │ │ │ └── UNMET DEPENDENCY safe-buffer@5.1.2
                │ │ ├── UNMET DEPENDENCY cookie-signature@1.0.6
                │ │ ├── UNMET DEPENDENCY debug@2.6.9
                │ │ ├── UNMET DEPENDENCY encodeurl@1.0.2
                │ │ ├── UNMET DEPENDENCY escape-html@1.0.3
                │ │ ├── UNMET DEPENDENCY etag@1.8.1
                │ │ ├─┬ UNMET DEPENDENCY finalhandler@1.1.2
                │ │ │ ├── UNMET DEPENDENCY debug@2.6.9
                │ │ │ ├── UNMET DEPENDENCY encodeurl@1.0.2
                │ │ │ ├── UNMET DEPENDENCY escape-html@1.0.3
                │ │ │ ├── UNMET DEPENDENCY on-finished@2.3.0
                │ │ │ ├── UNMET DEPENDENCY parseurl@1.3.3
                │ │ ├── UNMET DEPENDENCY fresh@0.5.2
                │ │ ├── UNMET DEPENDENCY merge-descriptors@1.0.1
                │ │ ├── UNMET DEPENDENCY methods@1.1.2
                │ │ ├── UNMET DEPENDENCY path-to-regexp@0.1.7
                │ │ ├─┬ UNMET DEPENDENCY proxy-addr@2.0.6
                │ │ │ ├── UNMET DEPENDENCY forwarded@0.1.2
                │ │ │ └── UNMET DEPENDENCY ipaddr.js@1.9.1
                │ │ ├── UNMET DEPENDENCY range-parser@1.2.1
                │ │ ├── UNMET DEPENDENCY safe-buffer@5.1.2
                │ │ ├─┬ UNMET DEPENDENCY send@0.17.1
                │ │ │ ├── UNMET DEPENDENCY destroy@1.0.4
                │ │ │ ├── UNMET DEPENDENCY etag@1.8.1
                │ │ │ ├── UNMET DEPENDENCY fresh@0.5.2
                │ │ │ ├── UNMET DEPENDENCY mime@1.6.0
                │ │ │ ├── UNMET DEPENDENCY ms@2.1.1
                │ │ │ ├── UNMET DEPENDENCY range-parser@1.2.1
                │ │ │ └── UNMET DEPENDENCY statuses@1.5.0
                │ │ ├─┬ UNMET DEPENDENCY serve-static@1.14.1
                │ │ │ └── UNMET DEPENDENCY send@0.17.1
                │ │ ├── UNMET DEPENDENCY type-is@1.6.18
                │ │ ├── UNMET DEPENDENCY utils-merge@1.0.1
                │ │ └── UNMET DEPENDENCY vary@1.1.2
                │ ├─┬ UNMET DEPENDENCY express-fileupload@1.2.1
                │ │ └─┬ UNMET DEPENDENCY busboy@0.3.1
                │ │   └─┬ UNMET DEPENDENCY dicer@0.3.0
                │ │     └── UNMET DEPENDENCY streamsearch@0.1.2
                │ ├─┬ UNMET DEPENDENCY express-session@1.17.1
                │ │ ├── UNMET DEPENDENCY depd@2.0.0
                │ │ ├── UNMET DEPENDENCY on-headers@1.0.2
                │ │ ├── UNMET DEPENDENCY safe-buffer@5.2.0
                │ │ └─┬ UNMET DEPENDENCY uid-safe@2.1.5
                │ │   └── UNMET DEPENDENCY random-bytes@1.0.0
                │ ├─┬ UNMET DEPENDENCY passport@0.4.1
                │ │ ├── UNMET DEPENDENCY passport-strategy@1.0.0
                │ │ └── UNMET DEPENDENCY pause@0.0.1
                │ ├─┬ UNMET DEPENDENCY passport-local@1.0.0
                │ │ └── UNMET DEPENDENCY passport-strategy@1.0.0
                │ ├─┬ UNMET DEPENDENCY passport.socketio@3.7.0
                │ │ └── UNMET DEPENDENCY xtend@4.0.2
                │ ├─┬ UNMET DEPENDENCY request@2.88.2
                │ │ ├── UNMET DEPENDENCY aws-sign2@0.7.0
                │ │ ├── UNMET DEPENDENCY aws4@1.11.0
                │ │ ├── UNMET DEPENDENCY caseless@0.12.0
                │ │ ├─┬ UNMET DEPENDENCY combined-stream@1.0.8
                │ │ │ └── UNMET DEPENDENCY delayed-stream@1.0.0
                │ │ ├── UNMET DEPENDENCY extend@3.0.2
                │ │ ├── UNMET DEPENDENCY forever-agent@0.6.1
                │ │ ├─┬ UNMET DEPENDENCY form-data@2.3.3
                │ │ │ ├── UNMET DEPENDENCY asynckit@0.4.0
                │ │ │ ├── UNMET DEPENDENCY combined-stream@1.0.8
                │ │ │ └── UNMET DEPENDENCY mime-types@2.1.29
                │ │ ├─┬ UNMET DEPENDENCY har-validator@5.1.5
                │ │ │ ├─┬ UNMET DEPENDENCY ajv@6.12.6
                │ │ │ │ ├── UNMET DEPENDENCY fast-deep-equal@3.1.3
                │ │ │ │ ├── UNMET DEPENDENCY fast-json-stable-stringify@2.1.0
                │ │ │ │ ├── UNMET DEPENDENCY json-schema-traverse@0.4.1
                │ │ │ │ └─┬ UNMET DEPENDENCY uri-js@4.4.1
                │ │ │ │   └── UNMET DEPENDENCY punycode@2.1.1
                │ │ │ └── UNMET DEPENDENCY har-schema@2.0.0
                │ │ ├─┬ UNMET DEPENDENCY http-signature@1.2.0
                │ │ │ ├── UNMET DEPENDENCY assert-plus@1.0.0
                │ │ │ ├─┬ UNMET DEPENDENCY jsprim@1.4.1
                │ │ │ │ ├── UNMET DEPENDENCY assert-plus@1.0.0
                │ │ │ │ ├── UNMET DEPENDENCY extsprintf@1.3.0
                │ │ │ │ ├── UNMET DEPENDENCY json-schema@0.2.3
                │ │ │ │ └─┬ UNMET DEPENDENCY verror@1.10.0
                │ │ │ │   ├── UNMET DEPENDENCY core-util-is@1.0.2
                │ │ │ │   └── UNMET DEPENDENCY extsprintf@1.3.0
                │ │ │ └─┬ UNMET DEPENDENCY sshpk@1.16.1
                │ │ │   ├─┬ UNMET DEPENDENCY asn1@0.2.4
                │ │ │   │ └── UNMET DEPENDENCY safer-buffer@2.1.2
                │ │ │   ├─┬ UNMET DEPENDENCY bcrypt-pbkdf@1.0.2
                │ │ │   │ └── UNMET DEPENDENCY tweetnacl@0.14.5
                │ │ │   ├─┬ UNMET DEPENDENCY dashdash@1.14.1
                │ │ │   │ └── UNMET DEPENDENCY assert-plus@1.0.0
                │ │ │   ├─┬ UNMET DEPENDENCY ecc-jsbn@0.1.2
                │ │ │   │ ├── UNMET DEPENDENCY jsbn@0.1.1
                │ │ │   ├─┬ UNMET DEPENDENCY getpass@0.1.7
                │ │ │   ├── UNMET DEPENDENCY safer-buffer@2.1.2
                │ │ ├── UNMET DEPENDENCY is-typedarray@1.0.0
                │ │ ├── UNMET DEPENDENCY isstream@0.1.2
                │ │ ├── UNMET DEPENDENCY json-stringify-safe@5.0.1
                │ │ ├─┬ UNMET DEPENDENCY mime-types@2.1.29
                │ │ │ └── UNMET DEPENDENCY mime-db@1.46.0
                │ │ ├── UNMET DEPENDENCY oauth-sign@0.9.0
                │ │ ├── UNMET DEPENDENCY performance-now@2.1.0
                │ │ ├── UNMET DEPENDENCY qs@6.5.2
                │ │ ├─┬ UNMET DEPENDENCY tough-cookie@2.5.0
                │ │ │ ├── UNMET DEPENDENCY psl@1.8.0
                │ │ ├─┬ UNMET DEPENDENCY tunnel-agent@0.6.0
                │ │ └── UNMET DEPENDENCY uuid@3.4.0
                │ ├─┬ UNMET DEPENDENCY semver@7.3.5
                │ │ └─┬ UNMET DEPENDENCY lru-cache@6.0.0
                │ │   └── UNMET DEPENDENCY yallist@4.0.0
                │ └── UNMET DEPENDENCY ws@7.5.5
                ├─┬ UNMET DEPENDENCY iobroker.backitup@2.2.2
                │ ├─┬ UNMET DEPENDENCY @googleapis/drive@0.3.1
                │ │ └─┬ UNMET DEPENDENCY googleapis-common@5.0.5
                │ │   ├── UNMET DEPENDENCY gaxios@4.3.2
                │ │   ├── UNMET DEPENDENCY google-auth-library@7.10.2
                │ │   ├── UNMET DEPENDENCY url-template@2.0.8
                │ │   └── UNMET DEPENDENCY uuid@8.3.2
                │ ├── UNMET DEPENDENCY @iobroker/adapter-core@2.5.1
                │ ├─┬ UNMET DEPENDENCY axios@0.24.0
                │ │ └── UNMET DEPENDENCY follow-redirects@1.14.5
                │ ├─┬ UNMET DEPENDENCY dropbox-v2-api@2.4.52
                │ │ └── UNMET DEPENDENCY request@2.88.2
                │ ├── UNMET DEPENDENCY express@4.17.1
                │ ├─┬ UNMET DEPENDENCY fs-extra@10.0.0
                │ │ ├── UNMET DEPENDENCY graceful-fs@4.2.6
                │ │ ├─┬ UNMET DEPENDENCY jsonfile@6.1.0
                │ │ │ ├── UNMET DEPENDENCY graceful-fs@4.2.6
                │ │ │ └── UNMET DEPENDENCY universalify@2.0.0
                │ ├─┬ UNMET DEPENDENCY ftp@0.3.10
                │ │ ├─┬ UNMET DEPENDENCY readable-stream@1.1.14
                │ │ │ ├── UNMET DEPENDENCY isarray@0.0.1
                │ │ │ └── UNMET DEPENDENCY string_decoder@0.10.31
                │ │ └── UNMET DEPENDENCY xregexp@2.0.0
                │ ├─┬ UNMET DEPENDENCY google-auth-library@7.10.2
                │ │ ├── UNMET DEPENDENCY arrify@2.0.1
                │ │ ├── UNMET DEPENDENCY base64-js@1.5.1
                │ │ ├─┬ UNMET DEPENDENCY ecdsa-sig-formatter@1.0.11
                │ │ ├── UNMET DEPENDENCY fast-text-encoding@1.0.3
                │ │ ├─┬ UNMET DEPENDENCY gaxios@4.3.2
                │ │ │ ├─┬ UNMET DEPENDENCY abort-controller@3.0.0
                │ │ │ │ └── UNMET DEPENDENCY event-target-shim@5.0.1
                │ │ │ ├── UNMET DEPENDENCY extend@3.0.2
                │ │ │ ├── UNMET DEPENDENCY https-proxy-agent@5.0.0
                │ │ │ ├── UNMET DEPENDENCY is-stream@2.0.0
                │ │ │ └─┬ UNMET DEPENDENCY node-fetch@2.6.6
                │ │ │   └─┬ UNMET DEPENDENCY whatwg-url@5.0.0
                │ │ │     ├── UNMET DEPENDENCY tr46@0.0.3
                │ │ │     └── UNMET DEPENDENCY webidl-conversions@3.0.1
                │ │ ├─┬ UNMET DEPENDENCY gcp-metadata@4.3.1
                │ │ │ ├── UNMET DEPENDENCY gaxios@4.3.2
                │ │ │ └─┬ UNMET DEPENDENCY json-bigint@1.0.0
                │ │ │   └── UNMET DEPENDENCY bignumber.js@9.0.1
                │ │ ├─┬ UNMET DEPENDENCY gtoken@5.3.1
                │ │ │ ├─┬ UNMET DEPENDENCY google-p12-pem@3.1.2
                │ │ │ │ └── UNMET DEPENDENCY node-forge@0.10.0
                │ │ │ └─┬ UNMET DEPENDENCY jws@4.0.0
                │ │ │   ├─┬ UNMET DEPENDENCY jwa@2.0.0
                │ │ │   │ ├── UNMET DEPENDENCY buffer-equal-constant-time@1.0.1
                │ │ │   │ ├── UNMET DEPENDENCY ecdsa-sig-formatter@1.0.11
                │ │ │   │ └── UNMET DEPENDENCY safe-buffer@5.1.2
                │ │ ├─┬ UNMET DEPENDENCY jws@4.0.0
                │ │ └── UNMET DEPENDENCY lru-cache@6.0.0
                │ ├─┬ UNMET DEPENDENCY node-schedule@2.0.0
                │ │ ├─┬ UNMET DEPENDENCY cron-parser@3.5.0
                │ │ │ ├─┬ UNMET DEPENDENCY is-nan@1.3.2
                │ │ │ │ ├─┬ UNMET DEPENDENCY call-bind@1.0.2
                │ │ │ │ │ ├── UNMET DEPENDENCY function-bind@1.1.1
                │ │ │ │ │ └─┬ UNMET DEPENDENCY get-intrinsic@1.1.1
                │ │ │ │ │   ├── UNMET DEPENDENCY has@1.0.3
                │ │ │ │ │   └── UNMET DEPENDENCY has-symbols@1.0.2
                │ │ │ │ └─┬ UNMET DEPENDENCY define-properties@1.1.3
                │ │ │ │   └── UNMET DEPENDENCY object-keys@1.1.1
                │ │ │ └── UNMET DEPENDENCY luxon@1.26.0
                │ │ ├── UNMET DEPENDENCY long-timeout@0.1.1
                │ │ └── UNMET DEPENDENCY sorted-array-functions@1.3.0
                │ ├── UNMET DEPENDENCY node-wol@0.1.1
                │ ├── UNMET DEPENDENCY request@2.88.2
                │ ├─┬ UNMET DEPENDENCY tar-fs@2.1.1
                │ │ ├── UNMET DEPENDENCY chownr@1.1.4
                │ │ ├── UNMET DEPENDENCY mkdirp-classic@0.5.3
                │ │ ├─┬ UNMET DEPENDENCY pump@3.0.0
                │ │ │ ├─┬ UNMET DEPENDENCY end-of-stream@1.4.4
                │ │ │ │ └── UNMET DEPENDENCY once@1.4.0
                │ │ │ └─┬ UNMET DEPENDENCY once@1.4.0
                │ │ │   └── UNMET DEPENDENCY wrappy@1.0.2
                │ │ └─┬ UNMET DEPENDENCY tar-stream@2.2.0
                │ │   ├─┬ UNMET DEPENDENCY bl@4.1.0
                │ │   │ ├─┬ UNMET DEPENDENCY buffer@5.7.1
                │ │   │ │ ├── UNMET DEPENDENCY base64-js@1.5.1
                │ │   │ │ └── UNMET DEPENDENCY ieee754@1.2.1
                │ │   │ ├── UNMET DEPENDENCY inherits@2.0.4
                │ │   │ └─┬ UNMET DEPENDENCY readable-stream@3.6.0
                │ │   │   ├── UNMET DEPENDENCY string_decoder@1.1.1
                │ │   │   └── UNMET DEPENDENCY util-deprecate@1.0.2
                │ │   ├── UNMET DEPENDENCY end-of-stream@1.4.4
                │ │   ├── UNMET DEPENDENCY fs-constants@1.0.0
                │ └─┬ UNMET DEPENDENCY webdav@4.7.0
                │   ├── UNMET DEPENDENCY axios@0.21.1
                │   ├── UNMET DEPENDENCY base-64@1.0.0
                │   ├─┬ UNMET DEPENDENCY fast-xml-parser@3.21.1
                │   │ └── UNMET DEPENDENCY strnum@1.0.4
                │   ├── UNMET DEPENDENCY he@1.2.0
                │   ├── UNMET DEPENDENCY hot-patcher@0.5.0
                │   ├── UNMET DEPENDENCY layerr@0.1.2
                │   ├─┬ UNMET DEPENDENCY md5@2.3.0
                │   │ ├── UNMET DEPENDENCY charenc@0.0.2
                │   │ ├── UNMET DEPENDENCY crypt@0.0.2
                │   │ └── UNMET DEPENDENCY is-buffer@1.1.6
                │   ├─┬ UNMET DEPENDENCY minimatch@3.0.4
                │   │ └─┬ UNMET DEPENDENCY brace-expansion@1.1.11
                │   │   ├── UNMET DEPENDENCY balanced-match@1.0.0
                │   │   └── UNMET DEPENDENCY concat-map@0.0.1
                │   ├── UNMET DEPENDENCY nested-property@4.0.0
                │   ├── UNMET DEPENDENCY path-posix@1.0.0
                │   ├── UNMET DEPENDENCY url-join@4.0.1
                │   └─┬ UNMET DEPENDENCY url-parse@1.5.3
                │     ├── UNMET DEPENDENCY querystringify@2.2.0
                │     └── UNMET DEPENDENCY requires-port@1.0.0
                ├─┬ UNMET DEPENDENCY iobroker.discovery@2.7.3
                │ ├─┬ UNMET OPTIONAL DEPENDENCY mdns-discovery@0.2.6
                │ │ ├─┬ UNMET OPTIONAL DEPENDENCY debug@2.2.0
                │ │ │ └── UNMET OPTIONAL DEPENDENCY ms@0.7.1
                │ │ ├── UNMET OPTIONAL DEPENDENCY dgram@1.0.1
                │ │ └─┬ UNMET OPTIONAL DEPENDENCY dns-packet@1.3.1
                │ │   ├── UNMET DEPENDENCY ip@1.1.5
                │ ├── UNMET DEPENDENCY netmask@2.0.2
                │ ├── UNMET DEPENDENCY node-mndp@0.0.3
                │ ├─┬ UNMET DEPENDENCY node-ssdp@4.0.1
                │ │ ├─┬ UNMET DEPENDENCY async@2.6.3
                │ │ │ └── UNMET DEPENDENCY lodash@4.17.21
                │ │ ├── UNMET DEPENDENCY bluebird@3.7.2
                │ │ ├─┬ UNMET DEPENDENCY debug@3.2.7
                │ │ │ └── UNMET DEPENDENCY ms@2.1.3
                │ │ └── UNMET DEPENDENCY ip@1.1.5
                │ └─┬ UNMET DEPENDENCY serialport@9.2.7
                │   ├─┬ UNMET DEPENDENCY @serialport/binding-mock@9.2.4
                │   │ ├─┬ UNMET DEPENDENCY @serialport/binding-abstract@9.2.3
                │   │ │ └─┬ UNMET DEPENDENCY debug@4.3.2
                │   │ │   └── UNMET DEPENDENCY ms@2.1.2
                │   ├─┬ UNMET DEPENDENCY @serialport/bindings@9.2.7
                │   │ ├── UNMET DEPENDENCY @serialport/binding-abstract@9.2.3
                │   │ ├── UNMET DEPENDENCY @serialport/parser-readline@9.2.4
                │   │ ├─┬ UNMET DEPENDENCY bindings@1.5.0
                │   │ │ └── UNMET DEPENDENCY file-uri-to-path@1.0.0
                │   │ ├─┬ UNMET DEPENDENCY debug@4.3.2
                │   │ ├── UNMET DEPENDENCY nan@2.15.0
                │   │ └─┬ UNMET DEPENDENCY prebuild-install@6.1.4
                │   │   ├── UNMET DEPENDENCY detect-libc@1.0.3
                │   │   ├── UNMET DEPENDENCY expand-template@2.0.3
                │   │   ├── UNMET DEPENDENCY github-from-package@0.0.0
                │   │   ├── UNMET DEPENDENCY minimist@1.2.5
                │   │   ├── UNMET DEPENDENCY napi-build-utils@1.0.2
                │   │   ├─┬ UNMET DEPENDENCY node-abi@2.30.1
                │   │   │ └── UNMET DEPENDENCY semver@5.7.1
                │   │   ├─┬ UNMET DEPENDENCY npmlog@4.1.2
                │   │   │ ├─┬ UNMET DEPENDENCY are-we-there-yet@1.1.7
                │   │   │ │ ├── UNMET DEPENDENCY delegates@1.0.0
                │   │   │ │ └── UNMET DEPENDENCY readable-stream@2.3.7
                │   │   │ ├── UNMET DEPENDENCY console-control-strings@1.1.0
                │   │   │ ├─┬ UNMET DEPENDENCY gauge@2.7.4
                │   │   │ │ ├── UNMET DEPENDENCY aproba@1.2.0
                │   │   │ │ ├── UNMET DEPENDENCY console-control-strings@1.1.0
                │   │   │ │ ├── UNMET DEPENDENCY has-unicode@2.0.1
                │   │   │ │ ├── UNMET DEPENDENCY object-assign@4.1.1
                │   │   │ │ ├── UNMET DEPENDENCY signal-exit@3.0.6
                │   │   │ │ ├─┬ UNMET DEPENDENCY string-width@1.0.2
                │   │   │ │ │ ├── UNMET DEPENDENCY code-point-at@1.1.0
                │   │   │ │ │ ├─┬ UNMET DEPENDENCY is-fullwidth-code-point@1.0.0
                │   │   │ │ │ │ └── UNMET DEPENDENCY number-is-nan@1.0.1
                │   │   │ │ │ └── UNMET DEPENDENCY strip-ansi@3.0.1
                │   │   │ │ ├─┬ UNMET DEPENDENCY strip-ansi@3.0.1
                │   │   │ │ │ └── UNMET DEPENDENCY ansi-regex@2.1.1
                │   │   │ │ └─┬ UNMET DEPENDENCY wide-align@1.1.5
                │   │   │ │   └── UNMET DEPENDENCY string-width@1.0.2
                │   │   │ └── UNMET DEPENDENCY set-blocking@2.0.0
                │   │   ├── UNMET DEPENDENCY pump@3.0.0
                │   │   ├─┬ UNMET DEPENDENCY rc@1.2.8
                │   │   │ ├── UNMET DEPENDENCY deep-extend@0.6.0
                │   │   │ ├── UNMET DEPENDENCY ini@1.3.8
                │   │   │ ├── UNMET DEPENDENCY minimist@1.2.5
                │   │   │ └── UNMET DEPENDENCY strip-json-comments@2.0.1
                │   │   ├─┬ UNMET DEPENDENCY simple-get@3.1.0
                │   │   │ ├─┬ UNMET DEPENDENCY decompress-response@4.2.1
                │   │   │ │ └── UNMET DEPENDENCY mimic-response@2.1.0
                │   │   │ ├── UNMET DEPENDENCY once@1.4.0
                │   │   │ └── UNMET DEPENDENCY simple-concat@1.0.1
                │   │   ├── UNMET DEPENDENCY tar-fs@2.1.1
                │   │   └── UNMET DEPENDENCY tunnel-agent@0.6.0
                │   ├── UNMET DEPENDENCY @serialport/parser-byte-length@9.2.4
                │   ├── UNMET DEPENDENCY @serialport/parser-cctalk@9.2.4
                │   ├── UNMET DEPENDENCY @serialport/parser-delimiter@9.2.4
                │   ├── UNMET DEPENDENCY @serialport/parser-inter-byte-timeout@9.2.4
                │   ├─┬ UNMET DEPENDENCY @serialport/parser-readline@9.2.4
                │   │ └── UNMET DEPENDENCY @serialport/parser-delimiter@9.2.4
                │   ├── UNMET DEPENDENCY @serialport/parser-ready@9.2.4
                │   ├── UNMET DEPENDENCY @serialport/parser-regex@9.2.4
                │   ├─┬ UNMET DEPENDENCY @serialport/stream@9.2.4
                ├─┬ UNMET DEPENDENCY iobroker.hm-rega@3.0.32
                │ ├─┬ UNMET DEPENDENCY iconv-lite@0.6.3
                │ └─┬ UNMET DEPENDENCY xml2js@0.4.23
                │   ├── UNMET DEPENDENCY sax@1.2.4
                │   └── UNMET DEPENDENCY xmlbuilder@11.0.1
                ├─┬ UNMET DEPENDENCY iobroker.hm-rpc@1.14.45
                │ ├─┬ UNMET DEPENDENCY binrpc@3.3.1
                │ │ ├─┬ UNMET DEPENDENCY binary@0.3.0
                │ │ │ ├── UNMET DEPENDENCY buffers@0.1.1
                │ │ │ └─┬ UNMET DEPENDENCY chainsaw@0.1.0
                │ │ │   └── UNMET DEPENDENCY traverse@0.3.9
                │ │ └── UNMET DEPENDENCY put@0.0.6
                │ └─┬ UNMET DEPENDENCY homematic-xmlrpc@1.0.2
                │   ├── UNMET DEPENDENCY sax@0.4.3
                │   └── UNMET DEPENDENCY xmlbuilder@https://github.com/hobbyquaker/xmlbuilder-js/tarball/29fe5030dc6852007dc8d1bfd5109d75f8da58d5
                ├─┬ UNMET DEPENDENCY iobroker.info@1.9.8
                │ ├─┬ UNMET DEPENDENCY axios@0.21.1
                │ ├── UNMET DEPENDENCY jshashes@1.0.8
                │ ├── UNMET OPTIONAL DEPENDENCY osx-temperature-sensor@1.0.7
                │ ├── UNMET DEPENDENCY semver@7.3.5
                │ └── UNMET DEPENDENCY systeminformation@5.9.15
                ├─┬ UNMET DEPENDENCY iobroker.javascript@5.2.13
                │ ├── UNMET DEPENDENCY @types/node@12.20.37
                │ ├─┬ UNMET DEPENDENCY @types/request@2.48.7
                │ │ ├── UNMET DEPENDENCY @types/caseless@0.12.2
                │ │ ├── UNMET DEPENDENCY @types/node@14.14.37
                │ │ ├── UNMET DEPENDENCY @types/tough-cookie@4.0.1
                │ │ └─┬ UNMET DEPENDENCY form-data@2.5.1
                │ ├── UNMET DEPENDENCY coffee-compiler@0.3.2
                │ ├── UNMET DEPENDENCY coffee-script@1.12.7
                │ ├── UNMET DEPENDENCY jsonata@1.8.5
                │ ├── UNMET DEPENDENCY node-inspect@2.0.0
                │ ├── UNMET DEPENDENCY node-schedule@2.0.0
                │ ├── UNMET DEPENDENCY suncalc2@1.8.1
                │ ├── UNMET DEPENDENCY typescript@4.5.2
                │ ├─┬ UNMET DEPENDENCY virtual-tsc@0.6.1
                │ │ ├── UNMET DEPENDENCY colors@1.4.0
                │ │ └─┬ UNMET DEPENDENCY debug@3.2.7
                │ ├── UNMET OPTIONAL DEPENDENCY vm2@3.9.5
                │ └─┬ UNMET DEPENDENCY wake_on_lan@1.0.0
                │   └── UNMET DEPENDENCY minimist@1.2.5
                ├─┬ UNMET DEPENDENCY iobroker.js-controller@3.3.20
                │ ├─┬ UNMET DEPENDENCY @alcalzone/esbuild-register@2.5.1-1
                │ │ ├── UNMET DEPENDENCY esbuild@0.11.23
                │ │ └── UNMET DEPENDENCY jsonc-parser@3.0.0
                │ ├─┬ UNMET DEPENDENCY @iobroker/db-objects-file@1.2.7
                │ │ ├─┬ UNMET DEPENDENCY @iobroker/db-base@1.2.4
                │ │ │ ├── UNMET DEPENDENCY deep-clone@3.0.3
                │ │ │ ├── UNMET DEPENDENCY fs-extra@9.1.0
                │ │ │ ├── UNMET DEPENDENCY node.extend@2.0.2
                │ │ │ └── UNMET DEPENDENCY respjs@4.2.0
                │ │ ├── UNMET DEPENDENCY @iobroker/db-objects-redis@1.2.7
                │ │ └── UNMET DEPENDENCY node.extend@2.0.2
                │ ├─┬ UNMET DEPENDENCY @iobroker/db-objects-jsonl@1.2.7
                │ │ ├─┬ UNMET DEPENDENCY @alcalzone/jsonl-db@1.3.0
                │ │ │ ├─┬ UNMET DEPENDENCY alcalzone-shared@3.0.4
                │ │ │ │ └─┬ UNMET DEPENDENCY debug@4.3.2
                │ │ │ │   └── UNMET DEPENDENCY ms@2.1.2
                │ │ │ └─┬ UNMET DEPENDENCY proper-lockfile@4.1.2
                │ │ │   ├── UNMET DEPENDENCY retry@0.12.0
                │ │ │   └── UNMET DEPENDENCY signal-exit@3.0.6
                │ │ ├── UNMET DEPENDENCY @iobroker/db-base@1.2.4
                │ │ ├── UNMET DEPENDENCY @iobroker/db-objects-file@1.2.7
                │ ├─┬ UNMET DEPENDENCY @iobroker/db-objects-redis@1.2.7
                │ │ ├─┬ UNMET DEPENDENCY ioredis@4.28.0
                │ │ │ ├── UNMET DEPENDENCY cluster-key-slot@1.1.0
                │ │ │ ├─┬ UNMET DEPENDENCY debug@4.3.2
                │ │ │ ├── UNMET DEPENDENCY denque@1.5.1
                │ │ │ ├── UNMET DEPENDENCY lodash.defaults@4.2.0
                │ │ │ ├── UNMET DEPENDENCY lodash.flatten@4.4.0
                │ │ │ ├── UNMET DEPENDENCY lodash.isarguments@3.1.0
                │ │ │ ├── UNMET DEPENDENCY p-map@2.1.0
                │ │ │ ├── UNMET DEPENDENCY redis-commands@1.7.0
                │ │ │ ├── UNMET DEPENDENCY redis-errors@1.2.0
                │ │ │ ├─┬ UNMET DEPENDENCY redis-parser@3.0.0
                │ │ │ │ └── UNMET DEPENDENCY redis-errors@1.2.0
                │ │ │ └── UNMET DEPENDENCY standard-as-callback@2.1.0
                │ ├─┬ UNMET DEPENDENCY @iobroker/db-states-file@1.2.7
                │ │ └── UNMET DEPENDENCY @iobroker/db-states-redis@1.2.7
                │ ├─┬ UNMET DEPENDENCY @iobroker/db-states-jsonl@1.2.7
                │ │ ├── UNMET DEPENDENCY @alcalzone/jsonl-db@1.3.0
                │ │ ├── UNMET DEPENDENCY @iobroker/db-states-file@1.2.7
                │ ├─┬ UNMET DEPENDENCY @iobroker/db-states-redis@1.2.7
                │ │ └── UNMET DEPENDENCY ioredis@4.28.0
                │ ├── UNMET DEPENDENCY @iobroker/plugin-base@1.2.1
                │ ├─┬ UNMET DEPENDENCY @iobroker/plugin-sentry@1.1.10
                │ │ ├── UNMET DEPENDENCY @iobroker/plugin-base@1.2.1
                │ │ ├─┬ UNMET DEPENDENCY @sentry/integrations@6.2.4
                │ │ │ ├── UNMET DEPENDENCY @sentry/types@6.2.4
                │ │ │ ├─┬ UNMET DEPENDENCY @sentry/utils@6.2.4
                │ │ │ │ ├── UNMET DEPENDENCY @sentry/types@6.2.4
                │ │ │ │ └── UNMET DEPENDENCY tslib@1.14.1
                │ │ │ ├─┬ UNMET DEPENDENCY localforage@1.9.0
                │ │ │ │ └─┬ UNMET DEPENDENCY lie@3.1.1
                │ │ │ │   └── UNMET DEPENDENCY immediate@3.0.6
                │ │ ├─┬ UNMET DEPENDENCY @sentry/node@6.2.4
                │ │ │ ├─┬ UNMET DEPENDENCY @sentry/core@6.2.4
                │ │ │ │ ├── UNMET DEPENDENCY @sentry/hub@6.2.4
                │ │ │ │ ├─┬ UNMET DEPENDENCY @sentry/minimal@6.2.4
                │ │ │ │ │ ├── UNMET DEPENDENCY @sentry/hub@6.2.4
                │ │ │ │ │ ├── UNMET DEPENDENCY @sentry/types@6.2.4
                │ │ │ │ │ └── UNMET DEPENDENCY tslib@1.14.1
                │ │ │ │ ├── UNMET DEPENDENCY @sentry/utils@6.2.4
                │ │ │ ├─┬ UNMET DEPENDENCY @sentry/hub@6.2.4
                │ │ │ ├─┬ UNMET DEPENDENCY @sentry/tracing@6.2.4
                │ │ │ │ ├── UNMET DEPENDENCY @sentry/minimal@6.2.4
                │ │ │ ├── UNMET DEPENDENCY cookie@0.4.1
                │ │ │ ├── UNMET DEPENDENCY lru_map@0.3.3
                │ │ └─┬ UNMET DEPENDENCY source-map-support@0.5.19
                │ │   ├── UNMET DEPENDENCY buffer-from@1.1.1
                │ │   └── UNMET DEPENDENCY source-map@0.6.1
                │ ├─┬ UNMET DEPENDENCY chokidar@3.5.1
                │ │ ├─┬ UNMET DEPENDENCY anymatch@3.1.1
                │ │ │ ├── UNMET DEPENDENCY normalize-path@3.0.0
                │ │ │ └── UNMET DEPENDENCY picomatch@2.2.2
                │ │ ├─┬ UNMET DEPENDENCY braces@3.0.2
                │ │ │ └─┬ UNMET DEPENDENCY fill-range@7.0.1
                │ │ │   └─┬ UNMET DEPENDENCY to-regex-range@5.0.1
                │ │ │     └── UNMET DEPENDENCY is-number@7.0.0
                │ │ ├── UNMET OPTIONAL DEPENDENCY fsevents@2.3.2
                │ │ ├─┬ UNMET DEPENDENCY glob-parent@5.1.2
                │ │ │ └── UNMET DEPENDENCY is-glob@4.0.1
                │ │ ├─┬ UNMET DEPENDENCY is-binary-path@2.1.0
                │ │ │ └── UNMET DEPENDENCY binary-extensions@2.2.0
                │ │ ├─┬ UNMET DEPENDENCY is-glob@4.0.1
                │ │ │ └── UNMET DEPENDENCY is-extglob@2.1.1
                │ │ └─┬ UNMET DEPENDENCY readdirp@3.5.0
                │ ├── UNMET DEPENDENCY ci-info@3.2.0
                │ ├── UNMET DEPENDENCY daemonize2@0.4.2
                │ ├─┬ UNMET DEPENDENCY debug@4.3.1
                │ ├─┬ UNMET DEPENDENCY decache@4.6.0
                │ │ └── UNMET DEPENDENCY callsite@1.0.0
                │ ├─┬ UNMET OPTIONAL DEPENDENCY diskusage@1.1.3
                │ │ ├── UNMET OPTIONAL DEPENDENCY es6-promise@4.2.8
                │ │ └── UNMET DEPENDENCY nan@2.15.0
                │ ├─┬ UNMET DEPENDENCY event-stream@4.0.1
                │ │ ├── UNMET DEPENDENCY duplexer@0.1.2
                │ │ ├── UNMET DEPENDENCY from@0.1.7
                │ │ ├── UNMET DEPENDENCY map-stream@0.0.7
                │ │ ├─┬ UNMET DEPENDENCY pause-stream@0.0.11
                │ │ │ └── UNMET DEPENDENCY through@2.3.8
                │ │ ├─┬ UNMET DEPENDENCY split@1.0.1
                │ │ ├─┬ UNMET DEPENDENCY stream-combiner@0.2.2
                │ │ │ ├── UNMET DEPENDENCY duplexer@0.1.2
                │ ├─┬ UNMET DEPENDENCY fs-extra@9.1.0
                │ │ ├── UNMET DEPENDENCY at-least-node@1.0.0
                │ │ ├── UNMET DEPENDENCY jsonfile@6.1.0
                │ ├─┬ UNMET OPTIONAL DEPENDENCY greenlock@4.0.4
                │ │ ├─┬ UNMET OPTIONAL DEPENDENCY @greenlock/manager@3.1.0
                │ │ │ └─┬ UNMET OPTIONAL DEPENDENCY greenlock-manager-fs@3.1.1
                │ │ │   ├── UNMET OPTIONAL DEPENDENCY @root/mkdirp@1.0.0
                │ │ │   └── UNMET OPTIONAL DEPENDENCY safe-replace@1.1.0
                │ │ ├─┬ UNMET OPTIONAL DEPENDENCY @root/acme@3.1.0
                │ │ │ ├── UNMET OPTIONAL DEPENDENCY @root/csr@0.8.1
                │ │ │ ├── UNMET OPTIONAL DEPENDENCY @root/encoding@1.0.1
                │ │ │ ├─┬ UNMET OPTIONAL DEPENDENCY @root/keypairs@0.10.1
                │ │ │ │ ├── UNMET OPTIONAL DEPENDENCY @root/encoding@1.0.1
                │ │ │ │ ├── UNMET OPTIONAL DEPENDENCY @root/pem@1.0.4
                │ │ │ │ └── UNMET OPTIONAL DEPENDENCY @root/x509@0.7.2
                │ │ │ ├── UNMET OPTIONAL DEPENDENCY @root/request@1.7.0
                │ │ │ └─┬ UNMET OPTIONAL DEPENDENCY @root/x509@0.7.2
                │ │ │   ├── UNMET OPTIONAL DEPENDENCY @root/asn1@1.0.0
                │ │ │   └── UNMET OPTIONAL DEPENDENCY @root/encoding@1.0.1
                │ │ ├─┬ UNMET OPTIONAL DEPENDENCY @root/csr@0.8.1
                │ │ │ ├─┬ UNMET OPTIONAL DEPENDENCY @root/asn1@1.0.0
                │ │ │ │ └── UNMET OPTIONAL DEPENDENCY @root/encoding@1.0.1
                │ │ ├─┬ UNMET OPTIONAL DEPENDENCY @root/greenlock@4.0.5
                │ │ │ ├── UNMET OPTIONAL DEPENDENCY @greenlock/manager@3.1.0
                │ │ │ ├── UNMET OPTIONAL DEPENDENCY @root/acme@3.1.0
                │ │ │ ├── UNMET OPTIONAL DEPENDENCY acme-http-01-standalone@3.0.5
                │ │ │ ├── UNMET OPTIONAL DEPENDENCY cert-info@1.5.1
                │ │ │ ├── UNMET OPTIONAL DEPENDENCY greenlock-store-fs@3.2.2
                │ │ ├─┬ UNMET OPTIONAL DEPENDENCY @root/keypairs@0.9.0
                │ │ ├─┬ UNMET OPTIONAL DEPENDENCY greenlock-store-fs@3.2.2
                │ ├─┬ UNMET OPTIONAL DEPENDENCY greenlock-express@4.0.3
                │ │ ├── UNMET OPTIONAL DEPENDENCY @root/greenlock@4.0.5
                │ │ ├─┬ UNMET OPTIONAL DEPENDENCY @root/greenlock-express@4.0.4
                │ │ │ ├── UNMET OPTIONAL DEPENDENCY @root/greenlock@4.0.5
                │ │ │ └── UNMET OPTIONAL DEPENDENCY redirect-https@1.3.1
                │ │ └─┬ UNMET OPTIONAL DEPENDENCY redirect-https@1.3.1
                │ │   └── UNMET DEPENDENCY escape-html@1.0.3
                │ ├─┬ UNMET DEPENDENCY jsonwebtoken@8.5.1
                │ │ ├─┬ UNMET DEPENDENCY jws@3.2.2
                │ │ │ ├─┬ UNMET DEPENDENCY jwa@1.4.1
                │ │ ├── UNMET DEPENDENCY lodash.includes@4.3.0
                │ │ ├── UNMET DEPENDENCY lodash.isboolean@3.0.3
                │ │ ├── UNMET DEPENDENCY lodash.isinteger@4.0.4
                │ │ ├── UNMET DEPENDENCY lodash.isnumber@3.0.3
                │ │ ├── UNMET DEPENDENCY lodash.isplainobject@4.0.6
                │ │ ├── UNMET DEPENDENCY lodash.isstring@4.0.1
                │ │ ├── UNMET DEPENDENCY lodash.once@4.1.1
                │ │ ├── UNMET DEPENDENCY ms@2.1.3
                │ ├─┬ UNMET DEPENDENCY jszip@3.6.0
                │ │ ├─┬ UNMET DEPENDENCY lie@3.3.0
                │ │ ├── UNMET DEPENDENCY pako@1.0.11
                │ │ ├─┬ UNMET DEPENDENCY readable-stream@2.3.7
                │ │ │ ├── UNMET DEPENDENCY isarray@1.0.0
                │ │ │ ├── UNMET DEPENDENCY process-nextick-args@2.0.1
                │ │ │ ├── UNMET DEPENDENCY safe-buffer@5.1.2
                │ │ │ ├─┬ UNMET DEPENDENCY string_decoder@1.1.1
                │ │ └── UNMET DEPENDENCY set-immediate-shim@1.0.1
                │ ├─┬ UNMET OPTIONAL DEPENDENCY le-acme-core@2.1.4
                │ │ ├── UNMET DEPENDENCY request@2.88.2
                │ │ └─┬ UNMET OPTIONAL DEPENDENCY rsa-compat@1.9.4
                │ │   ├─┬ UNMET OPTIONAL DEPENDENCY keypairs@1.2.14
                │ │   │ ├── UNMET OPTIONAL DEPENDENCY eckles@1.4.1
                │ │   │ └── UNMET OPTIONAL DEPENDENCY rasha@1.2.5
                │ │   ├── UNMET OPTIONAL DEPENDENCY node-forge@0.7.6
                │ │   └─┬ UNMET OPTIONAL DEPENDENCY ursa-optional@0.9.10
                │ │     ├── UNMET DEPENDENCY bindings@1.5.0
                │ ├─┬ UNMET OPTIONAL DEPENDENCY le-challenge-fs@2.0.9
                │ │ └── UNMET OPTIONAL DEPENDENCY @root/mkdirp@1.0.0
                │ ├── UNMET OPTIONAL DEPENDENCY le-sni-auto@2.1.9
                │ ├─┬ UNMET DEPENDENCY loadavg-windows@1.1.1
                │ │ └── UNMET DEPENDENCY weak-daemon@1.0.3
                │ ├── UNMET DEPENDENCY mime@2.5.2
                │ ├── UNMET DEPENDENCY ncp@2.0.0
                │ ├── UNMET DEPENDENCY node-forge@0.10.0
                │ ├─┬ UNMET DEPENDENCY node.extend@2.0.2
                │ │ ├─┬ UNMET DEPENDENCY has@1.0.3
                │ │ │ └── UNMET DEPENDENCY function-bind@1.1.1
                │ │ └── UNMET DEPENDENCY is@3.3.0
                │ ├─┬ UNMET DEPENDENCY pidusage@2.0.21
                │ │ └── UNMET DEPENDENCY safe-buffer@5.2.1
                │ ├── UNMET DEPENDENCY promisify-child-process@4.1.1
                │ ├─┬ UNMET DEPENDENCY prompt@1.1.0
                │ │ ├─┬ UNMET DEPENDENCY read@1.0.7
                │ │ │ └── UNMET DEPENDENCY mute-stream@0.0.8
                │ │ ├── UNMET DEPENDENCY revalidator@0.1.8
                │ │ ├─┬ UNMET DEPENDENCY utile@0.3.0
                │ │ │ ├── UNMET DEPENDENCY async@0.9.2
                │ │ │ ├── UNMET DEPENDENCY deep-equal@0.2.2
                │ │ │ ├── UNMET DEPENDENCY i@0.3.6
                │ │ │ ├─┬ UNMET DEPENDENCY mkdirp@0.5.5
                │ │ │ │ └── UNMET DEPENDENCY minimist@1.2.5
                │ │ │ ├── UNMET DEPENDENCY ncp@1.0.1
                │ │ │ └─┬ UNMET DEPENDENCY rimraf@2.7.1
                │ │ │   └─┬ UNMET DEPENDENCY glob@7.1.6
                │ │ │     ├── UNMET DEPENDENCY fs.realpath@1.0.0
                │ │ │     ├─┬ UNMET DEPENDENCY inflight@1.0.6
                │ │ │     │ ├── UNMET DEPENDENCY once@1.4.0
                │ │ │     │ └── UNMET DEPENDENCY wrappy@1.0.2
                │ │ │     ├── UNMET DEPENDENCY minimatch@3.0.4
                │ │ │     └── UNMET DEPENDENCY path-is-absolute@1.0.1
                │ │ └─┬ UNMET DEPENDENCY winston@2.4.5
                │ │   ├── UNMET DEPENDENCY async@1.0.0
                │ │   ├── UNMET DEPENDENCY colors@1.0.3
                │ │   ├── UNMET DEPENDENCY cycle@1.0.3
                │ │   ├── UNMET DEPENDENCY eyes@0.1.8
                │ │   └── UNMET DEPENDENCY stack-trace@0.0.10
                │ ├── UNMET DEPENDENCY readline-sync@1.4.10
                │ ├─┬ UNMET DEPENDENCY tar@6.1.0
                │ │ ├── UNMET DEPENDENCY chownr@2.0.0
                │ │ ├─┬ UNMET DEPENDENCY fs-minipass@2.1.0
                │ │ │ └── UNMET DEPENDENCY minipass@3.1.3
                │ │ ├─┬ UNMET DEPENDENCY minipass@3.1.3
                │ │ │ └── UNMET DEPENDENCY yallist@4.0.0
                │ │ ├─┬ UNMET DEPENDENCY minizlib@2.1.2
                │ │ │ ├── UNMET DEPENDENCY minipass@3.1.3
                │ │ ├── UNMET DEPENDENCY mkdirp@1.0.4
                │ ├─┬ UNMET DEPENDENCY winston@3.3.3
                │ │ ├─┬ UNMET DEPENDENCY @dabh/diagnostics@2.0.2
                │ │ │ ├─┬ UNMET DEPENDENCY colorspace@1.1.2
                │ │ │ │ ├─┬ UNMET DEPENDENCY color@3.0.0
                │ │ │ │ │ ├─┬ UNMET DEPENDENCY color-convert@1.9.3
                │ │ │ │ │ │ └── UNMET DEPENDENCY color-name@1.1.3
                │ │ │ │ │ └─┬ UNMET DEPENDENCY color-string@1.5.5
                │ │ │ │ │   ├── UNMET DEPENDENCY color-name@1.1.3
                │ │ │ │ │   └─┬ UNMET DEPENDENCY simple-swizzle@0.2.2
                │ │ │ │ │     └── UNMET DEPENDENCY is-arrayish@0.3.2
                │ │ │ │ └── UNMET DEPENDENCY text-hex@1.0.0
                │ │ │ ├── UNMET DEPENDENCY enabled@2.0.0
                │ │ │ └── UNMET DEPENDENCY kuler@2.0.0
                │ │ ├── UNMET DEPENDENCY async@3.2.0
                │ │ ├─┬ UNMET DEPENDENCY logform@2.2.0
                │ │ │ ├── UNMET DEPENDENCY colors@1.4.0
                │ │ │ ├── UNMET DEPENDENCY fast-safe-stringify@2.0.7
                │ │ │ ├── UNMET DEPENDENCY fecha@4.2.0
                │ │ │ ├── UNMET DEPENDENCY ms@2.1.3
                │ │ │ └── UNMET DEPENDENCY triple-beam@1.3.0
                │ │ ├─┬ UNMET DEPENDENCY one-time@1.0.0
                │ │ │ └── UNMET DEPENDENCY fn.name@1.1.0
                │ │ ├─┬ UNMET DEPENDENCY readable-stream@3.6.0
                │ │ ├── UNMET DEPENDENCY stack-trace@0.0.10
                │ │ ├── UNMET DEPENDENCY triple-beam@1.3.0
                │ │ └─┬ UNMET DEPENDENCY winston-transport@4.4.0
                │ │   ├── UNMET DEPENDENCY readable-stream@2.3.7
                │ ├─┬ UNMET DEPENDENCY winston-daily-rotate-file@4.5.5
                │ │ ├─┬ UNMET DEPENDENCY file-stream-rotator@0.5.7
                │ │ │ └── UNMET DEPENDENCY moment@2.29.1
                │ │ ├── UNMET DEPENDENCY object-hash@2.2.0
                │ │ └── UNMET DEPENDENCY winston-transport@4.4.0
                │ ├─┬ UNMET OPTIONAL DEPENDENCY winston-seq-updated@1.0.4
                │ │ ├── UNMET OPTIONAL DEPENDENCY seq-logging@0.4.6
                │ ├─┬ UNMET OPTIONAL DEPENDENCY winston-syslog@2.4.4
                │ │ ├── UNMET OPTIONAL DEPENDENCY glossy@0.1.7
                │ │ └─┬ UNMET OPTIONAL DEPENDENCY unix-dgram@2.0.3
                │ └─┬ UNMET DEPENDENCY yargs@16.2.0
                │   ├─┬ UNMET DEPENDENCY cliui@7.0.4
                │   │ ├─┬ UNMET DEPENDENCY string-width@4.2.2
                │   │ │ ├── UNMET DEPENDENCY emoji-regex@8.0.0
                │   │ │ ├── UNMET DEPENDENCY is-fullwidth-code-point@3.0.0
                │   │ │ └── UNMET DEPENDENCY strip-ansi@6.0.0
                │   │ ├─┬ UNMET DEPENDENCY strip-ansi@6.0.0
                │   │ │ └── UNMET DEPENDENCY ansi-regex@5.0.0
                │   │ └─┬ UNMET DEPENDENCY wrap-ansi@7.0.0
                │   │   ├─┬ UNMET DEPENDENCY ansi-styles@4.3.0
                │   │   │ └─┬ UNMET DEPENDENCY color-convert@2.0.1
                │   │   │   └── UNMET DEPENDENCY color-name@1.1.4
                │   │   └─┬ UNMET DEPENDENCY strip-ansi@6.0.0
                │   ├── UNMET DEPENDENCY escalade@3.1.1
                │   ├── UNMET DEPENDENCY get-caller-file@2.0.5
                │   ├── UNMET DEPENDENCY require-directory@2.1.1
                │   ├── UNMET DEPENDENCY y18n@5.0.5
                │   └── UNMET DEPENDENCY yargs-parser@20.2.7
                ├─┬ UNMET DEPENDENCY iobroker.sunnyportal@git+ssh://git@github.com/marvincaspar/ioBroker.sunnyportal.git#0eeecbfa57a6366daf4f6070e7ab27885af3c3c8
                │ ├── UNMET DEPENDENCY flow@0.2.3
                │ └─┬ UNMET DEPENDENCY request-promise-native@1.0.9
                │   ├─┬ UNMET DEPENDENCY request-promise-core@1.1.4
                │   ├── UNMET DEPENDENCY stealthy-require@1.1.1
                │   └── UNMET DEPENDENCY tough-cookie@2.5.0
                  ├── UNMET DEPENDENCY tar@6.1.0
                  ├─┬ UNMET DEPENDENCY zigbee-herdsman@0.13.110
                  │ ├── UNMET DEPENDENCY @serialport/bindings@9.0.4
                  │ ├── UNMET DEPENDENCY debounce@^1.2.0
                  │ ├── UNMET DEPENDENCY debug@^4.3.1
                  │ ├── UNMET DEPENDENCY mixin-deep@^2.0.1
                  │ ├── UNMET DEPENDENCY mz@^2.7.0
                  │ ├── UNMET DEPENDENCY serialport@9.0.6
                  │ └── UNMET DEPENDENCY slip@^1.0.2
                  └─┬ UNMET DEPENDENCY zigbee-herdsman-converters@14.0.162
                    ├── UNMET DEPENDENCY buffer-crc32@^0.2.13
                    ├─┬ UNMET DEPENDENCY https-proxy-agent@5.0.0
                    │ ├─┬ UNMET DEPENDENCY agent-base@6.0.2
                    │ │ └─┬ UNMET DEPENDENCY debug@4.3.1
                    ├── UNMET DEPENDENCY tar-stream@2.2.0
                    └── UNMET DEPENDENCY zigbee-herdsman@0.13.110
                npm ERR! missing: iobroker.admin@5.1.25, required by iobroker.inst@3.0.0
                npm ERR! missing: iobroker.backitup@2.2.2, required by iobroker.inst@3.0.0
                npm ERR! missing: iobroker.discovery@2.7.3, required by iobroker.inst@3.0.0
                npm ERR! missing: iobroker.hm-rega@3.0.32, required by iobroker.inst@3.0.0
                npm ERR! missing: iobroker.hm-rpc@1.14.45, required by iobroker.inst@3.0.0
                npm ERR! missing: iobroker.info@1.9.8, required by iobroker.inst@3.0.0
                npm ERR! missing: iobroker.javascript@5.2.13, required by iobroker.inst@3.0.0
                npm ERR! missing: iobroker.js-controller@3.3.20, required by iobroker.inst@3.0.0
                npm ERR! missing: iobroker.sunnyportal@github:marvincaspar/ioBroker.sunnyportal#master, required by iobroker.inst@3.0.0
                npm ERR! missing: @iobroker/adapter-core@2.5.1, required by iobroker.admin@5.1.25
                npm ERR! missing: body-parser@1.19.0, required by iobroker.admin@5.1.25
                npm ERR! missing: connect-flash@0.1.1, required by iobroker.admin@5.1.25
                npm ERR! missing: cookie-parser@1.4.5, required by iobroker.admin@5.1.25
                npm ERR! missing: express@4.17.1, required by iobroker.admin@5.1.25
                npm ERR! missing: express-fileupload@1.2.1, required by iobroker.admin@5.1.25
                npm ERR! missing: express-session@1.17.1, required by iobroker.admin@5.1.25
                npm ERR! missing: passport@0.4.1, required by iobroker.admin@5.1.25
                npm ERR! missing: passport-local@1.0.0, required by iobroker.admin@5.1.25
                npm ERR! missing: passport.socketio@3.7.0, required by iobroker.admin@5.1.25
                npm ERR! missing: request@2.88.2, required by iobroker.admin@5.1.25
                npm ERR! missing: semver@7.3.5, required by iobroker.admin@5.1.25
                npm ERR! missing: ws@7.5.5, required by iobroker.admin@5.1.25
                npm ERR! missing: @types/iobroker@3.3.4, required by @iobroker/adapter-core@2.5.1
                npm ERR! missing: @types/node@14.14.37, required by @types/iobroker@3.3.4
                npm ERR! missing: bytes@3.1.0, required by body-parser@1.19.0
                npm ERR! missing: content-type@1.0.4, required by body-parser@1.19.0
                npm ERR! missing: debug@2.6.9, required by body-parser@1.19.0
                npm ERR! missing: depd@1.1.2, required by body-parser@1.19.0
                npm ERR! missing: http-errors@1.7.2, required by body-parser@1.19.0
                npm ERR! missing: iconv-lite@0.4.24, required by body-parser@1.19.0
                npm ERR! missing: on-finished@2.3.0, required by body-parser@1.19.0
                npm ERR! missing: qs@6.7.0, required by body-parser@1.19.0
                npm ERR! missing: raw-body@2.4.0, required by body-parser@1.19.0
                npm ERR! missing: type-is@1.6.18, required by body-parser@1.19.0
                npm ERR! missing: ms@2.0.0, required by debug@2.6.9
                npm ERR! missing: depd@1.1.2, required by http-errors@1.7.2
                npm ERR! missing: inherits@2.0.3, required by http-errors@1.7.2
                npm ERR! missing: setprototypeof@1.1.1, required by http-errors@1.7.2
                npm ERR! missing: statuses@1.5.0, required by http-errors@1.7.2
                npm ERR! missing: toidentifier@1.0.0, required by http-errors@1.7.2
                npm ERR! missing: safer-buffer@2.1.2, required by iconv-lite@0.4.24
                npm ERR! missing: ee-first@1.1.1, required by on-finished@2.3.0
                npm ERR! missing: bytes@3.1.0, required by raw-body@2.4.0
                npm ERR! missing: http-errors@1.7.2, required by raw-body@2.4.0
                npm ERR! missing: iconv-lite@0.4.24, required by raw-body@2.4.0
                npm ERR! missing: unpipe@1.0.0, required by raw-body@2.4.0
                npm ERR! missing: media-typer@0.3.0, required by type-is@1.6.18
                npm ERR! missing: mime-types@2.1.29, required by type-is@1.6.18
                npm ERR! missing: cookie@0.4.0, required by cookie-parser@1.4.5
                npm ERR! missing: cookie-signature@1.0.6, required by cookie-parser@1.4.5
                npm ERR! missing: accepts@1.3.7, required by express@4.17.1
                npm ERR! missing: array-flatten@1.1.1, required by express@4.17.1
                npm ERR! missing: body-parser@1.19.0, required by express@4.17.1
                npm ERR! missing: content-disposition@0.5.3, required by express@4.17.1
                npm ERR! missing: content-type@1.0.4, required by express@4.17.1
                npm ERR! missing: cookie@0.4.0, required by express@4.17.1
                npm ERR! missing: cookie-signature@1.0.6, required by express@4.17.1
                npm ERR! missing: debug@2.6.9, required by express@4.17.1
                npm ERR! missing: depd@1.1.2, required by express@4.17.1
                npm ERR! missing: encodeurl@1.0.2, required by express@4.17.1
                npm ERR! missing: escape-html@1.0.3, required by express@4.17.1
                npm ERR! missing: etag@1.8.1, required by express@4.17.1
                npm ERR! missing: finalhandler@1.1.2, required by express@4.17.1
                npm ERR! missing: fresh@0.5.2, required by express@4.17.1
                npm ERR! missing: merge-descriptors@1.0.1, required by express@4.17.1
                npm ERR! missing: methods@1.1.2, required by express@4.17.1
                npm ERR! missing: on-finished@2.3.0, required by express@4.17.1
                npm ERR! missing: parseurl@1.3.3, required by express@4.17.1
                npm ERR! missing: path-to-regexp@0.1.7, required by express@4.17.1
                npm ERR! missing: proxy-addr@2.0.6, required by express@4.17.1
                npm ERR! missing: qs@6.7.0, required by express@4.17.1
                npm ERR! missing: range-parser@1.2.1, required by express@4.17.1
                npm ERR! missing: safe-buffer@5.1.2, required by express@4.17.1
                npm ERR! missing: send@0.17.1, required by express@4.17.1
                npm ERR! missing: serve-static@1.14.1, required by express@4.17.1
                npm ERR! missing: setprototypeof@1.1.1, required by express@4.17.1
                npm ERR! missing: statuses@1.5.0, required by express@4.17.1
                npm ERR! missing: type-is@1.6.18, required by express@4.17.1
                npm ERR! missing: utils-merge@1.0.1, required by express@4.17.1
                npm ERR! missing: vary@1.1.2, required by express@4.17.1
                npm ERR! missing: mime-types@2.1.29, required by accepts@1.3.7
                npm ERR! missing: negotiator@0.6.2, required by accepts@1.3.7
                npm ERR! missing: safe-buffer@5.1.2, required by content-disposition@0.5.3
                npm ERR! missing: debug@2.6.9, required by finalhandler@1.1.2
                npm ERR! missing: encodeurl@1.0.2, required by finalhandler@1.1.2
                npm ERR! missing: escape-html@1.0.3, required by finalhandler@1.1.2
                npm ERR! missing: on-finished@2.3.0, required by finalhandler@1.1.2
                npm ERR! missing: parseurl@1.3.3, required by finalhandler@1.1.2
                npm ERR! missing: statuses@1.5.0, required by finalhandler@1.1.2
                npm ERR! missing: unpipe@1.0.0, required by finalhandler@1.1.2
                npm ERR! missing: forwarded@0.1.2, required by proxy-addr@2.0.6
                npm ERR! missing: ipaddr.js@1.9.1, required by proxy-addr@2.0.6
                npm ERR! missing: debug@2.6.9, required by send@0.17.1
                npm ERR! missing: depd@1.1.2, required by send@0.17.1
                npm ERR! missing: destroy@1.0.4, required by send@0.17.1
                npm ERR! missing: encodeurl@1.0.2, required by send@0.17.1
                npm ERR! missing: escape-html@1.0.3, required by send@0.17.1
                npm ERR! missing: etag@1.8.1, required by send@0.17.1
                npm ERR! missing: fresh@0.5.2, required by send@0.17.1
                npm ERR! missing: http-errors@1.7.2, required by send@0.17.1
                npm ERR! missing: on-finished@2.3.0, required by send@0.17.1
                npm ERR! missing: range-parser@1.2.1, required by send@0.17.1
                npm ERR! missing: mime@1.6.0, required by send@0.17.1
                npm ERR! missing: ms@2.1.1, required by send@0.17.1
                npm ERR! missing: statuses@1.5.0, required by send@0.17.1
                npm ERR! missing: encodeurl@1.0.2, required by serve-static@1.14.1
                npm ERR! missing: escape-html@1.0.3, required by serve-static@1.14.1
                npm ERR! missing: parseurl@1.3.3, required by serve-static@1.14.1
                npm ERR! missing: send@0.17.1, required by serve-static@1.14.1
                npm ERR! missing: busboy@0.3.1, required by express-fileupload@1.2.1
                npm ERR! missing: dicer@0.3.0, required by busboy@0.3.1
                npm ERR! missing: streamsearch@0.1.2, required by dicer@0.3.0
                npm ERR! missing: cookie@0.4.0, required by express-session@1.17.1
                npm ERR! missing: cookie-signature@1.0.6, required by express-session@1.17.1
                npm ERR! missing: debug@2.6.9, required by express-session@1.17.1
                npm ERR! missing: depd@2.0.0, required by express-session@1.17.1
                npm ERR! missing: safe-buffer@5.2.0, required by express-session@1.17.1
                npm ERR! missing: on-headers@1.0.2, required by express-session@1.17.1
                npm ERR! missing: parseurl@1.3.3, required by express-session@1.17.1
                npm ERR! missing: uid-safe@2.1.5, required by express-session@1.17.1
                npm ERR! missing: random-bytes@1.0.0, required by uid-safe@2.1.5
                npm ERR! missing: passport-strategy@1.0.0, required by passport@0.4.1
                npm ERR! missing: pause@0.0.1, required by passport@0.4.1
                npm ERR! missing: passport-strategy@1.0.0, required by passport-local@1.0.0
                npm ERR! missing: xtend@4.0.2, required by passport.socketio@3.7.0
                npm ERR! missing: aws-sign2@0.7.0, required by request@2.88.2
                npm ERR! missing: aws4@1.11.0, required by request@2.88.2
                npm ERR! missing: caseless@0.12.0, required by request@2.88.2
                npm ERR! missing: combined-stream@1.0.8, required by request@2.88.2
                npm ERR! missing: extend@3.0.2, required by request@2.88.2
                npm ERR! missing: forever-agent@0.6.1, required by request@2.88.2
                npm ERR! missing: form-data@2.3.3, required by request@2.88.2
                npm ERR! missing: har-validator@5.1.5, required by request@2.88.2
                npm ERR! missing: http-signature@1.2.0, required by request@2.88.2
                npm ERR! missing: is-typedarray@1.0.0, required by request@2.88.2
                npm ERR! missing: isstream@0.1.2, required by request@2.88.2
                npm ERR! missing: json-stringify-safe@5.0.1, required by request@2.88.2
                npm ERR! missing: mime-types@2.1.29, required by request@2.88.2
                npm ERR! missing: oauth-sign@0.9.0, required by request@2.88.2
                npm ERR! missing: performance-now@2.1.0, required by request@2.88.2
                npm ERR! missing: qs@6.5.2, required by request@2.88.2
                npm ERR! missing: safe-buffer@5.1.2, required by request@2.88.2
                npm ERR! missing: tough-cookie@2.5.0, required by request@2.88.2
                npm ERR! missing: tunnel-agent@0.6.0, required by request@2.88.2
                npm ERR! missing: uuid@3.4.0, required by request@2.88.2
                npm ERR! missing: delayed-stream@1.0.0, required by combined-stream@1.0.8
                npm ERR! missing: asynckit@0.4.0, required by form-data@2.3.3
                npm ERR! missing: combined-stream@1.0.8, required by form-data@2.3.3
                npm ERR! missing: mime-types@2.1.29, required by form-data@2.3.3
                npm ERR! missing: ajv@6.12.6, required by har-validator@5.1.5
                npm ERR! missing: har-schema@2.0.0, required by har-validator@5.1.5
                npm ERR! missing: fast-deep-equal@3.1.3, required by ajv@6.12.6
                npm ERR! missing: fast-json-stable-stringify@2.1.0, required by ajv@6.12.6
                npm ERR! missing: json-schema-traverse@0.4.1, required by ajv@6.12.6
                npm ERR! missing: uri-js@4.4.1, required by ajv@6.12.6
                npm ERR! missing: punycode@2.1.1, required by uri-js@4.4.1
                npm ERR! missing: assert-plus@1.0.0, required by http-signature@1.2.0
                npm ERR! missing: jsprim@1.4.1, required by http-signature@1.2.0
                npm ERR! missing: sshpk@1.16.1, required by http-signature@1.2.0
                npm ERR! missing: assert-plus@1.0.0, required by jsprim@1.4.1
                npm ERR! missing: extsprintf@1.3.0, required by jsprim@1.4.1
                npm ERR! missing: json-schema@0.2.3, required by jsprim@1.4.1
                npm ERR! missing: verror@1.10.0, required by jsprim@1.4.1
                npm ERR! missing: assert-plus@1.0.0, required by verror@1.10.0
                npm ERR! missing: core-util-is@1.0.2, required by verror@1.10.0
                npm ERR! missing: extsprintf@1.3.0, required by verror@1.10.0
                npm ERR! missing: asn1@0.2.4, required by sshpk@1.16.1
                npm ERR! missing: assert-plus@1.0.0, required by sshpk@1.16.1
                npm ERR! missing: bcrypt-pbkdf@1.0.2, required by sshpk@1.16.1
                npm ERR! missing: dashdash@1.14.1, required by sshpk@1.16.1
                npm ERR! missing: ecc-jsbn@0.1.2, required by sshpk@1.16.1
                npm ERR! missing: getpass@0.1.7, required by sshpk@1.16.1
                npm ERR! missing: jsbn@0.1.1, required by sshpk@1.16.1
                npm ERR! missing: safer-buffer@2.1.2, required by sshpk@1.16.1
                npm ERR! missing: tweetnacl@0.14.5, required by sshpk@1.16.1
                npm ERR! missing: safer-buffer@2.1.2, required by asn1@0.2.4
                npm ERR! missing: tweetnacl@0.14.5, required by bcrypt-pbkdf@1.0.2
                npm ERR! missing: assert-plus@1.0.0, required by dashdash@1.14.1
                npm ERR! missing: jsbn@0.1.1, required by ecc-jsbn@0.1.2
                npm ERR! missing: safer-buffer@2.1.2, required by ecc-jsbn@0.1.2
                npm ERR! missing: assert-plus@1.0.0, required by getpass@0.1.7
                  #90
                  @schmitzkatze
                  Da ist ja alles krumm...
                  Ich würde das wohl neuinstallieren und mein Backup einspielen.
                  schmitzkatzeS 2 Antworten Letzte Antwort
                    @schmitzkatze
                    schmitzkatze
                    #91
                    @thomas-braun 👍😇
                      @thomas-braun 👍😇
                      #92
                      @schmitzkatze
                      Was passiert denn bei einem
                      iobroker update -i
                        @schmitzkatze
                        schmitzkatze
                        #93
                        @thomas-braun heißt den ioBroker komplett in einer neuen VM wie es "opossum" vorgeschlagenhat?
                          @schmitzkatze
                          iobroker update -i
                          schmitzkatze
                          #94
                          @thomas-braun said in Probleme mit Zigbee und CC26X2R1:
                          update -i
                          michael@debianIObroker:/opt/iobroker$ update -i
                          -bash: update: Kommando nicht gefunden.
                            update -i
                            #95
                            @schmitzkatze
                            iobroker update -i
                              @schmitzkatze
                              iobroker update -i
                              schmitzkatze
                              #96
                              @thomas-braun .....bin gerade dabei eine neue VM zu erstellen und habe mich genau an die Anweisung
                              (https://technikkram.net/blog/2020/02/15/projekt-teil-08-iobroker-auf-intel-nuc-als-vm-installieren-all-in-one-mit-raspberrymatic/)
                              gehalten, nun hängt die Installation bei der Installation von
                              8. … und zu guter Letzt npm installieren: npm install -g npm 🤷‍♂️ hast Du eine Idee? den Punkt überspringen und ioBroker installieren geht dann auch nicht ```
                              root@debianIoBrokerNEU:/# npm install -g npm
                              bash: npm: Kommando nicht gefunden.
                                #97
                                @schmitzkatze
                                npm wird nicht so installiert. Ist das in der Anleitung drin? Dann ist auch die mal wieder Quatsch.
                                npm ist Bestandteil vom Paket nodejs.
                                Aber auch das installiert man nicht selber, das macht der Installer des ioBrokers gleich richtig mit.
                                Und du bist auch root. Das sollst du doch nicht!
                                [Edit:] Gerade mal genauer geschaut, in der Anleitung steht leider noch mehr Blödsinn drin.
                                Dem root wird kein Passwort gegeben, dann wird das System automatisch mit sudo aufgesetzt.
                                  @schmitzkatze
                                  schmitzkatze
                                  #98
                                  @thomas-braun Guten Morgen 🤗
                                  das ist aber wirklich sehr blöd !🤢
                                  Wenn ich dieser Anleitung nicht vertrauen kann.
                                  Wenn ich mich Anmelde wie beschrieben, kommt das dabei raus!
                                  Nach welcher Installation Anleitung kann man denn installieren?
                                  michael-----@Michaels-MacBook-Pro ~ % ssh michael@192.168.178.48
                                  michael@192.168.178.48's password:
                                  Linux debianIoBrokerNEU 5.10.0-9-amd64 #1 SMP Debian 5.10.70-1 (2021-09-30) x86_64
                                  permitted by applicable law.
                                  Last login: Fri Nov 26 22:32:18 2021 from 192.168.178.171
                                  michael@debianIoBrokerNEU:~$ su
                                  Passwort:
                                  root@debianIoBrokerNEU:/home/michael# cd /
                                    Passwort:
                                    #99
                                    @schmitzkatze
                                    Wo steht denn das man als erstes
                                    su
                                    eingeben soll und damit wieder zum root wird?
                                    root ist Tabu!
                                    Eigentlich ist das ganze auch viel weniger Aufwand als in diesem Machwerk. Im Debian-Installer einfach dem root KEIN Passwort geben. Und den ioBroker installiert man ganz einfach nur mit dem Installations-Einzeiler. Nix mit nodeJS oder gar npm von Hand machen.
                                      @schmitzkatze
                                      su
                                      root ist Tabu!
                                      schmitzkatze
                                      #100
                                      Wenn das da so steht macht man das auch oder? Wenn das falsch ist ist das sehr bitter!
                                      @schmitzkatze
                                      su
                                      root ist Tabu!
                                      nachdem das erledigt ist, das System mit dem folgenden Befehl neu booten: ***sudo reboot***
                                      Nachdem das System wieder oben ist, stellen wir über PUTTY eine SSH Verbindung her und melden uns mit der persönlichen Benutzerkennung und nicht mit
                                      ***„root“*** an. Wenn ihr angemeldet seid, gebt ihr ***„su“*** ein, um dann das Passwort des „Root-Benutzers“ einzugeben. Dann unbedingt noch ***„cd /“*** eingeben, um in das Stammverzeichnis zu wechseln.
                                        @schmitzkatze
                                        su
                                        root ist Tabu!
                                        #101
                                        @schmitzkatze
                                        Ich sag ja...
                                        Da steht leider so einiger Quark drin. Die 'Anleitung' kannst du vergessen.
                                          @schmitzkatze
                                          Ich sag ja...
                                          schmitzkatze
                                          #102
                                          @thomas-braun ja schade aber auch!
                                          Nach welcher kann ich denn gehen?
