  4. Frage zum BackItUp-Adapter: Fehler nach Update auf 2.2.2.
    5.5k
32 Beiträge 4 Kommentatoren 1.0k Aufrufe 4 Beobachtet
  • I invidianer
    Okay, habe wieder auf 2.2.2 upgedated und dann manuell die Sicherung angestoßen. Bei "Packed 0MB so far ..." bleibt er hängen:
    Started iobroker ...
    [DEBUG] [mount] - mount activ... umount is started before mount!!
    [DEBUG] [mount] - umount successfully completed
    [DEBUG] [mount] - noserverino option: false
    [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=ioBroker_backup,password=****,rw,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.2.1/fritzdg/ioBroker_backup /opt/iobroker/backups"
    [DEBUG] [mount] - mount successfully completed
    [DEBUG] [mount] - done
    [DEBUG] [iobroker] - host.raspberrypi 2468 states saved
    [DEBUG] [iobroker] - host.raspberrypi 2832 objects saved
    [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2021_11_18-08_32_28_backupiobroker.tar.gz
    [DEBUG] [iobroker] - done
    [DEBUG] [javascripts] - Try deleting the old javascript_tmp directory: "/opt/iobroker/backups/tmpScripts"
    [DEBUG] [javascripts] - old javascript_tmp directory "/opt/iobroker/backups/tmpScripts" successfully deleted
    [DEBUG] [javascripts] - Created javascript_tmp directory
    [DEBUG] [javascripts] - found Script: Telegram_-_Stehlampe
    [DEBUG] [javascripts] - found Script: Telegram_-_Licht_Heizungskeller
    [DEBUG] [javascripts] - found Script: Waschmaschine_Stromversorgung
    [DEBUG] [javascripts] - found Script: Telegram_-_Waschmaschine_Stromversorgung
    [DEBUG] [javascripts] - found Script: Telegram_-_Geschirrspülmaschine_fertig
    [DEBUG] [javascripts] - found Script: Hifi_ausschalten
    [DEBUG] [javascripts] - found Script: Telegram_-_Anruf
    [DEBUG] [javascripts] - found Script: Telegram_-_TV
    [DEBUG] [javascripts] - found Script: Telegram_-_Tauchpumpe
    [DEBUG] [javascripts] - found Script: Telegram_-_Heizung
    [DEBUG] [javascripts] - found Script: Telegram_-_Kühlschrank
    [DEBUG] [javascripts] - found Script: Kaffeemaschine_ausschalten
    [DEBUG] [javascripts] - found Script: Telegram_-_Waschmaschine_fertig
    [DEBUG] [javascripts] - Packed 0MB so far...
    Jan1
    @invidianer
    Macht er bei mir auch und der Ordner Scripte wird nicht angelegt.
    Allerdings klappt das wohl wenn er es nachts automatisch macht. Muss ich mal schauen, ob morgen alles wie gewünscht im Ordner liegt, wenn nicht, hast ein Bug gefunden ;)
    @Thomas-Braun
    so ist es, nur seit wann ist das und hats dazu ne Info gegeben?
      @invidianer
      Ist das eine Fritzbox, auf die da gesichert wird?
      Dann muss noserverino auf true gesetzt sein.
      I Offline
      I Offline
      invidianer
      @thomas-braun sagte in Frage zum BackItUp-Adapter: Fehler nach Update auf 2.2.2.:
      @invidianer
      Das war es!! Danke!! Jetzt funktioniert es! Diese Option "Mount mit Option noserverinfo" gab es bei 2.1.17 noch nicht, oder? Zumindest hatte ich da nichts aktiviert und es ging ja.
      J Thomas BraunT 2 Antworten Letzte Antwort
      • I invidianer
        @invidianer
        Jan1
        @invidianer
        Scheint so, da ich das ebenfalls so hatte und mir die Info zu dieser Option auch gefehlt hat.
        I 1 Antwort Letzte Antwort
        • J Jan1
          @invidianer
          I Offline
          I Offline
          invidianer
          @jan1 sagte in Frage zum BackItUp-Adapter: Fehler nach Update auf 2.2.2.:
          @invidianer
          Danke für Bestätigung!
          • I invidianer
            @invidianer
            @invidianer @Jan1
            Die Option gibt es seit dem Update des samba-Servers in der FritzBox.
            Ist glaube ich mit FritzOS 7.2x eingeführt worden.
            Steht in der ReadMe zum Backitup-Adapter aber auch drin:
            Wenn eine Fritzbox als NAS mit einer Firmware >= 7.21 verwendet wird, sollten in Backitup die SMB-Einstellungen auf "3.1.1" eingestellt und die Option "noserverino" aktiviert werden.
              @invidianer @Jan1
              I Offline
              I Offline
              invidianer
              Hmm, komisch. Gestern (vor Update auf 2.2.2) hatte es noch funktioniert.
              Wenn die Option bei 2.1.17 schon vorhanden war, ging es entweder auch mit nicht aktivierter oder sie war aktiviert und ist beim Update auf 2.2.2 rausgeflogen.
              • I invidianer
                @invidianer sagte in Frage zum BackItUp-Adapter: Fehler nach Update auf 2.2.2.:
                Es ging, aber nicht korrekt.
                  I Offline
                  I Offline
                  invidianer
                  Eine Fehlermeldung kam allerdings nie (es gab nur "positiv"-Meldungen per Telegram).
                  • I invidianer
                    @invidianer
                    Ich meine, da müsste auch im Log irgendwas gestanden haben.
                    Ich hab das 'damals' mit @simatec jedenfalls ausbaldowert, kann mich aber nicht mehr erinnern was die Meldungen waren.
                      @invidianer
                      I Offline
                      I Offline
                      invidianer
                      Nochmal zu dem "Log": Es gibt doch nur das eine, welches im ioBroker-Frontend unter "Protokolle" einzusehen ist, oder?
                      • I invidianer
                        @invidianer
                        Ja, das meine ich.
                        Wobei das besser in der Konsole angeschaut wird, die Darstellung unter 'Protokolle' ist suboptimal.
                        I J 2 Antworten Letzte Antwort
                          @invidianer
                          Ja, das meine ich.
                          I Offline
                          I Offline
                          invidianer
                          Ok, danke!
                          Darin stehen jedoch für die Sicherungen unter 2.1.17 tatsächlich keine Fehler. Diese wären mir sonst definitiv aufgefallen und zusätzlich kommt jede Nacht um 2:00 Uhr die Telegram-Meldung, daß die Sicherung erfolgreich war.
                            @invidianer
                            Ja, das meine ich.
                            Jan1
                            Mir ist es auch nur aufgefallen, weil ich eben mal ein Backup manuell gestartet hatte und dann einfach das Fenster nicht schließt, allerdings auch keine Fehlermeldung erscheint. Die Backups wurden aber schön auf der Fritz angelegt, somit ist das etwas verwirrend.
                            OK, wenn es in der readme drin steht, könnte man das dort nachlesen, nur wenn ich vermeintlich kein Problem habe, lese ich die nicht aus reiner Neugier oder Langeweile ;)
                            Aber auch egal, Problem erkannt und gelöst :)
                            Thomas BraunT I 2 Antworten Letzte Antwort
                            • J Jan1
                              @jan1 @invidianer
                              Kann auch sein, dass es Meldungen seitens eines parallelen Backups auf Google Drive gab. Das greift ja auch auf das gemountete smb/cifs-Share zu.
                              Ich weiß es aber nicht mehr.
                              • J Jan1
                                I Offline
                                I Offline
                                invidianer
                                Ich habe es gemerkt, weil keine Telegram-Meldung zur Sicherung kam. Warum dies so war, weiß ich bisher nicht, aber da nun alles wieder funktioniert …
                                • I invidianer
                                  simatecS Offline
                                  simatecS Offline
                                  simatec
                                  @invidianer @Jan1 @Thomas-Braun
                                  Für die Fritzbox mit aktueller Firmware ist definitiv die noserverino Option erforderlich. Andernfalls kann der tmp Ordner für einzelne Backuptypen nicht ordnungsgemäß angelegt werden.
                                  Dies ist auch mit 2.1.17 bereits so gewesen.
                                  Allerdings wurden durch Umstellungen in der Javascriptsicherung hier noch ein paar mehr Logs eingebaut.
                                  Ich gehe davon aus, dass in Version 2.1.17 hier ebenfalls ein Fehler auftrat, aber dieser nicht sauber gemeldet wurde.
                                  • Besuche meine Github Seite
                                  • HowTo Restore ioBroker
                                  • simatecS simatec
                                    Jan1
                                    @simatec
                                    Das ist gut möglich, da ich im Backup Ordner vorhin zwei Ordner drin hatte, die mir neu waren. Da ich die gelöscht habe ohne weiter drüber nachzudenken (es waren auch noch recht alte Backups da, die eigentlich auch hätten weg sein sollen), kann ich die nur aus dem Gedächtnis brennen.
                                    Müsste ein Script und ein temp.Script Ordner gewesen sein ;)
                                    Die sind nur nach dem gesetzten Haken und erneut ausgeführten Backup mit dem Adapter nicht mehr vorhanden.
                                    So sieht das nun wieder aus und so kenne ich das auch:
                                    • J Jan1
                                      @simatec
                                      simatecS Offline
                                      simatecS Offline
                                      simatec
                                      @jan1 Das ist auch gut so ... das sind nur tempsdirs ... Nach dem packen der Backupdateien löscht Backitup die tmps
                                      • simatecS simatec
                                        Jan1
                                        @simatec
                                        Richtig und genau die bleiben stehen, wenn der Haken nicht gesetzt ist und somit löscht er auch keine alten Backups. Ob das nach den letzten Updates des Host und JS nun deutlichere Logfiles ausgeworfen hätte, müsste ich erst mal testen, in dem ich dem Haken wieder raus nehme ;)
                                        • J Jan1
                                          @simatec
                                          I Offline
                                          I Offline
                                          invidianer
                                          @jan1
                                          So war es bei mir auch. Haken nicht gesetzt, Ordner „tmpScripts“ noch vorhanden und Backup hängengeblieben bei Meldung „0MB packed …“.
                                          Haken gesetzt, Ordner tmpScripts weg.
