  4. iobroker cli kaputt
iobroker cli kaputt
clijs-controller
19 Beiträge 4 Kommentatoren 1.7k Aufrufe 2 Beobachtet
  • X Xyolyp
    @thomas-braun auch nach einem Versionswechsel nach deinem sehr umfangreichen Beitrag erhalte ich die gleiche Meldung:
    $ which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && sudo apt update && apt policy nodejs
    /usr/bin/nodejs
    /usr/local/bin/node
    /usr/bin/npm
    v12.22.7
    v12.10.0
    6.14.15
    Hit:1 http://security.debian.org/debian-security buster/updates InRelease
    Hit:2 http://phoscon.de/apt/deconz buster InRelease
    Hit:3 https://deb.nodesource.com/node_12.x buster InRelease
    Hit:4 https://download.docker.com/linux/debian buster InRelease
    Hit:5 http://deb.debian.org/debian buster InRelease
    Hit:6 http://deb.debian.org/debian buster-updates InRelease
    Reading package lists... Done
    Building dependency tree
    All packages are up to date.
    Hit:2 http://deb.debian.org/debian buster InRelease
    Hit:3 http://deb.debian.org/debian buster-updates InRelease
    Hit:4 http://phoscon.de/apt/deconz buster InRelease
    Hit:5 https://deb.nodesource.com/node_12.x buster InRelease
    Hit:6 https://download.docker.com/linux/debian buster InRelease
    nodejs:
      Installed: 12.22.7-deb-1nodesource1
      Candidate: 12.22.7-deb-1nodesource1
      Version table:
     *** 12.22.7-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_12.x buster/main amd64 Packages
         10.24.0~dfsg-1~deb10u1 500
            500 http://deb.debian.org/debian buster/main amd64 Packages
            500 http://security.debian.org/debian-security buster/updates/main amd64 Packages
    /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:37
            .scriptName(tools.appName)
    TypeError: require(...).scriptName is not a function
        at initYargs (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:37:10)
        at Object.module.exports.execute (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2902:20)
        at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js:1:24)
        at Module._compile (internal/modules/cjs/loader.js:936:30)
        at Object.Module._extensions..js (internal/modules/cjs/loader.js:947:10)
        at Module.load (internal/modules/cjs/loader.js:790:32)
        at Function.Module._load (internal/modules/cjs/loader.js:703:12)
        at Function.Module.runMain (internal/modules/cjs/loader.js:999:10)
        at internal/main/run_main_module.js:17:11
    Thomas BraunT Offline
    @xyolyp
    Ist ja auch noch krumm.
    X 1 Antwort Letzte Antwort
      @xyolyp
      X Offline
      X Offline
      Xyolyp
      schrieb am zuletzt editiert von Xyolyp
      @thomas-braun entschuldige mein Unwissen, aber erlaube bitte zwei Fragen:
      1. was ist krumm?
      2. wie ziehe ich es grade?
      • X Xyolyp
        1. was ist krumm?
        @xyolyp
        Falscher Pfad.
        Steht auch in der Anleitung drin, wie man das richtet.
        • X Xyolyp
          1. was ist krumm?
          HomoranH Offline
          HomoranH Offline
          @xyolyp sagte in iobroker cli kaputt:
          was ist krumm?
          du hast zwei verschiedene node.js Installationen parallel in zwei Verzeichnissen
            was ist krumm?
            X Offline
            X Offline
            Xyolyp
            @homoran @Thomas-Braun
            Soweit ich es jetzt deuten kann sollte alles in Ordnung sein, es sei denn ich übersehe wieder etwas. Leider scheitern weiterhin (nach einem Reboot) alle Befehle immernoch mit den gleichen Meldungen.
            /usr/bin/nodejs
            /usr/bin/node
            /usr/bin/npm
            v12.22.7
            v12.22.7
            6.14.15
            Hit:1 http://phoscon.de/apt/deconz buster InRelease
            Hit:2 https://deb.nodesource.com/node_12.x buster InRelease
            Hit:3 https://download.docker.com/linux/debian buster InRelease
            Hit:4 http://security.debian.org/debian-security buster/updates InRelease
            nodejs:
              Version table:
            • X Xyolyp
              /usr/bin/nodejs
              /usr/bin/node
              /usr/bin/npm
              v12.22.7
              v12.22.7
              6.14.15
              nodejs:
                Version table:
              @xyolyp
              Ja, jetzt ist zumindest nodeJS sauber.
              iobroker status
              iobroker update -i
                @xyolyp
                iobroker status
                iobroker update -i
                X Offline
                X Offline
                Xyolyp
                $ iob status
                    at Module._compile (internal/modules/cjs/loader.js:999:30)
                    at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
                    at Module.load (internal/modules/cjs/loader.js:863:32)
                    at Function.Module._load (internal/modules/cjs/loader.js:708:14)
                    at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:60:12)
                    at internal/main/run_main_module.js:17:47
                $ iob update -i
                • X Xyolyp
                  $ iob status
                  $ iob update -i
                  @xyolyp
                  iobroker stop
                  cd /opt/iobroker
                  sudo -H -u iobroker npm install iobroker.js-controller
                    @xyolyp
                    iobroker stop
                    cd /opt/iobroker
                    X Offline
                    X Offline
                    Xyolyp
                    $ sudo -H -u iobroker npm install ioboker.js-controller
                    npm ERR! code E404
                    npm ERR! 404 Not Found - GET https://registry.npmjs.org/ioboker.js-controller - Not found
                    npm ERR! 404
                    npm ERR! 404  'ioboker.js-controller@latest' is not in the npm registry.
                    npm ERR! 404 You should bug the author to publish it (or use the name yourself!)
                    npm ERR! 404
                    npm ERR! 404 Note that you can also install from a
                    npm ERR! 404 tarball, folder, http url, or git url.
                    npm ERR!     /home/iobroker/.npm/_logs/2021-11-17T22_53_25_614Z-debug.log
                    Thomas BraunT M 2 Antworten Letzte Antwort
                    • X Xyolyp
                      npm ERR! code E404
                      npm ERR! 404
                      npm ERR! 404
                      @xyolyp
                      Hm.
                      Netzwerk in Ordnung?
                      curl -sL https://iobroker.net/fix.sh | bash -
                      • X Xyolyp
                        npm ERR! code E404
                        npm ERR! 404
                        npm ERR! 404
                        M Online
                        M Online
                        mrjeschke
                        @xyolyp
                        Da fehlt ein r im iobroker
                        • M mrjeschke
                          @xyolyp
                          @maik-0
                          Oh, gut gesehen...
                          Die Befehle zu kopieren statt abzutippen ist auch keine doofe Idee .
                            @maik-0
                            Oh, gut gesehen...
                            X Offline
                            X Offline
                            Xyolyp
                            @thomas-braun @Maik-0 @Homoran danke euch drei, es sieht so aus als würde es wieder laufen.
                            Die Alternative wäre ein neues Setup als Docker-Container am Wochenende gewesen.
                            • X Xyolyp
                              @xyolyp
                              iobroker update -i
                              sagt jetzt?
