  4. Warnmeldung nach Neuinstallation
    6.3k
7 Beiträge 5 Kommentatoren 673 Aufrufe 4 Beobachtet
  • Holger EtzelH Offline
    Holger Etzel
    Hallöchen,
    nach einer Neuinstallation bekomme ich folgende Warnmeldungen:
    javascript.0
    2021-11-12 18:30:11.985	warn	Object of state "0_userdata.0.mdui.showIcal.log3.lastUpdate" is missing the required property "common.type"
    javascript.0
    2021-11-12 18:30:11.984	warn	Read-only state "0_userdata.0.mdui.showIcal.log3.count" has been written without ack-flag with value "8"
    javascript.0
    2021-11-12 18:30:11.984	warn	Object of state "0_userdata.0.mdui.showIcal.log3.list" is missing the required property "common.type"
    javascript.0
    2021-11-12 18:30:11.984	warn	Object of state "0_userdata.0.mdui.showIcal.log3.table" is missing the required property "common.type"
    javascript.0
    2021-11-12 18:30:11.983	warn	Object of state "0_userdata.0.mdui.showIcal.log2.lastUpdate" is missing the required property "common.type"
    javascript.0
    2021-11-12 18:30:11.983	warn	Read-only state "0_userdata.0.mdui.showIcal.log2.count" has been written without ack-flag with value "0"
    javascript.0
    2021-11-12 18:30:11.983	warn	Object of state "0_userdata.0.mdui.showIcal.log2.list" is missing the required property "common.type"
    javascript.0
    2021-11-12 18:30:11.983	warn	Object of state "0_userdata.0.mdui.showIcal.log2.table" is missing the required property "common.type"
    javascript.0
    2021-11-12 18:30:11.982	warn	Object of state "0_userdata.0.mdui.showIcal.log1.lastUpdate" is missing the required property "common.type"
    javascript.0
    2021-11-12 18:30:11.982	warn	Read-only state "0_userdata.0.mdui.showIcal.log1.count" has been written without ack-flag with value "8"
    javascript.0
    2021-11-12 18:30:11.982	warn	Object of state "0_userdata.0.mdui.showIcal.log1.list" is missing the required property "common.type"
    javascript.0
    2021-11-12 18:30:11.982	warn	Object of state "0_userdata.0.mdui.showIcal.log1.table" is missing the required property "common.type"
    javascript.0
    2021-11-12 18:30:11.982	warn	Object of state "0_userdata.0.mdui.showIcal.log0.lastUpdate" is missing the required property "common.type"
    javascript.0
    2021-11-12 18:30:11.981	warn	Read-only state "0_userdata.0.mdui.showIcal.log0.count" has been written without ack-flag with value "8"
    javascript.0
    2021-11-12 18:30:11.980	warn	Object of state "0_userdata.0.mdui.showIcal.log0.list" is missing the required property "common.type"
    javascript.0
    2021-11-12 18:30:11.979	warn	Object of state "0_userdata.0.mdui.showIcal.log0.table" is missing the required property "common.type"
    Kann jemand etwas damit anfangen?
    Gru?
    Holger
    • Holger EtzelH Holger Etzel
      Hallöchen,
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      Gru?
      Holger
      Meister MopperM Offline
      Meister Mopper
      @holger-etzel
      Jetzt müsstest Du wissen, welches script diesen Datenpunkt erstellt hat, oder ob er überhaupt automatisch erstellt wird.
      Proxmox und HA ...
      Holger EtzelH 1 Antwort Letzte Antwort
        @holger-etzel
        Holger Etzel
        @meister-mopper
        gute Frage. Kann ich nicht sagen.
        Könnte das Ical sein?
          @meister-mopper
          @holger-etzel sagte in Warnmeldung nach Neuinstallation:
          nein!
          die meldung kommt von deinen eigenen Scripten
          • GlasfaserG Offline
            GlasfaserG Offline
            @Holger-Etzel
            in der Script Suche , den Datenpunkt angeben , dann siehst du von welchen Script es kommt .
            • Thomas BraunT Online
              @holger-etzel
              Vermutlich aus der Ecke:
              https://forum.iobroker.net/topic/31635/vorlage-mdcss-v2-ical-kalendar-anzeigen
                @holger-etzel
                Holger Etzel
                ich denke ich habe es gefunden. Kommt wohl aus dem Skript Kalenderansicht. danke
