<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Warnmeldung nach Neuinstallation]]></title><description><![CDATA[<p dir="auto">Hallöchen,<br />
nach einer Neuinstallation bekomme ich folgende Warnmeldungen:</p>
<pre><code>javascript.0
2021-11-12 18:30:11.985	warn	Object of state "0_userdata.0.mdui.showIcal.log3.lastUpdate" is missing the required property "common.type"
javascript.0
2021-11-12 18:30:11.984	warn	Read-only state "0_userdata.0.mdui.showIcal.log3.count" has been written without ack-flag with value "8"
javascript.0
2021-11-12 18:30:11.984	warn	Object of state "0_userdata.0.mdui.showIcal.log3.list" is missing the required property "common.type"
javascript.0
2021-11-12 18:30:11.984	warn	Object of state "0_userdata.0.mdui.showIcal.log3.table" is missing the required property "common.type"
javascript.0
2021-11-12 18:30:11.983	warn	Object of state "0_userdata.0.mdui.showIcal.log2.lastUpdate" is missing the required property "common.type"
javascript.0
2021-11-12 18:30:11.983	warn	Read-only state "0_userdata.0.mdui.showIcal.log2.count" has been written without ack-flag with value "0"
javascript.0
2021-11-12 18:30:11.983	warn	Object of state "0_userdata.0.mdui.showIcal.log2.list" is missing the required property "common.type"
javascript.0
2021-11-12 18:30:11.983	warn	Object of state "0_userdata.0.mdui.showIcal.log2.table" is missing the required property "common.type"
javascript.0
2021-11-12 18:30:11.982	warn	Object of state "0_userdata.0.mdui.showIcal.log1.lastUpdate" is missing the required property "common.type"
javascript.0
2021-11-12 18:30:11.982	warn	Read-only state "0_userdata.0.mdui.showIcal.log1.count" has been written without ack-flag with value "8"
javascript.0
2021-11-12 18:30:11.982	warn	Object of state "0_userdata.0.mdui.showIcal.log1.list" is missing the required property "common.type"
javascript.0
2021-11-12 18:30:11.982	warn	Object of state "0_userdata.0.mdui.showIcal.log1.table" is missing the required property "common.type"
javascript.0
2021-11-12 18:30:11.982	warn	Object of state "0_userdata.0.mdui.showIcal.log0.lastUpdate" is missing the required property "common.type"
javascript.0
2021-11-12 18:30:11.981	warn	Read-only state "0_userdata.0.mdui.showIcal.log0.count" has been written without ack-flag with value "8"
javascript.0
2021-11-12 18:30:11.980	warn	Object of state "0_userdata.0.mdui.showIcal.log0.list" is missing the required property "common.type"
javascript.0
2021-11-12 18:30:11.979	warn	Object of state "0_userdata.0.mdui.showIcal.log0.table" is missing the required property "common.type"
</code></pre>
<p dir="auto">Kann jemand etwas damit anfangen?</p>
<p dir="auto">Gru?<br />
Holger</p>
]]></description><link>https://forum.iobroker.net/topic/49297/warnmeldung-nach-neuinstallation</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 01:17:45 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/49297.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 12 Nov 2021 17:45:27 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Warnmeldung nach Neuinstallation on Fri, 12 Nov 2021 18:12:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a></p>
<p dir="auto">ich denke ich habe es gefunden. Kommt wohl aus dem Skript Kalenderansicht. danke</p>
]]></description><link>https://forum.iobroker.net/post/702357</link><guid isPermaLink="true">https://forum.iobroker.net/post/702357</guid><dc:creator><![CDATA[Holger Etzel]]></dc:creator><pubDate>Fri, 12 Nov 2021 18:12:02 GMT</pubDate></item><item><title><![CDATA[Reply to Warnmeldung nach Neuinstallation on Fri, 12 Nov 2021 18:02:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/holger-etzel" aria-label="Profile: holger-etzel">@<bdi>holger-etzel</bdi></a></p>
<p dir="auto">Vermutlich aus der Ecke:</p>
<p dir="auto"><a href="https://forum.iobroker.net/topic/31635/vorlage-mdcss-v2-ical-kalendar-anzeigen">https://forum.iobroker.net/topic/31635/vorlage-mdcss-v2-ical-kalendar-anzeigen</a></p>
]]></description><link>https://forum.iobroker.net/post/702353</link><guid isPermaLink="true">https://forum.iobroker.net/post/702353</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Fri, 12 Nov 2021 18:02:00 GMT</pubDate></item><item><title><![CDATA[Reply to Warnmeldung nach Neuinstallation on Fri, 12 Nov 2021 18:00:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/holger-etzel" aria-label="Profile: Holger-Etzel">@<bdi>Holger-Etzel</bdi></a></p>
<p dir="auto">in der Script Suche , den Datenpunkt angeben , dann siehst du von welchen Script es kommt .</p>
<p dir="auto"><img src="/assets/uploads/files/1636740030955-0e3a0cdd-91c7-4569-862e-c0d0a8756fd7-grafik.png" alt="0e3a0cdd-91c7-4569-862e-c0d0a8756fd7-grafik.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.iobroker.net/post/702352</link><guid isPermaLink="true">https://forum.iobroker.net/post/702352</guid><dc:creator><![CDATA[Glasfaser]]></dc:creator><pubDate>Fri, 12 Nov 2021 18:00:36 GMT</pubDate></item><item><title><![CDATA[Reply to Warnmeldung nach Neuinstallation on Fri, 12 Nov 2021 17:58:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/holger-etzel" aria-label="Profile: holger-etzel">@<bdi>holger-etzel</bdi></a> sagte in <a href="/post/702350">Warnmeldung nach Neuinstallation</a>:</p>
<blockquote>
<p dir="auto">Könnte das Ical sein?</p>
</blockquote>
<p dir="auto">nein!</p>
<p dir="auto">die meldung kommt von deinen eigenen Scripten</p>
]]></description><link>https://forum.iobroker.net/post/702351</link><guid isPermaLink="true">https://forum.iobroker.net/post/702351</guid><dc:creator><![CDATA[Homoran]]></dc:creator><pubDate>Fri, 12 Nov 2021 17:58:00 GMT</pubDate></item><item><title><![CDATA[Reply to Warnmeldung nach Neuinstallation on Fri, 12 Nov 2021 17:57:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/meister-mopper" aria-label="Profile: meister-mopper">@<bdi>meister-mopper</bdi></a><br />
gute Frage. Kann ich nicht sagen.</p>
]]></description><link>https://forum.iobroker.net/post/702350</link><guid isPermaLink="true">https://forum.iobroker.net/post/702350</guid><dc:creator><![CDATA[Holger Etzel]]></dc:creator><pubDate>Fri, 12 Nov 2021 17:57:32 GMT</pubDate></item><item><title><![CDATA[Reply to Warnmeldung nach Neuinstallation on Fri, 12 Nov 2021 17:53:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/holger-etzel" aria-label="Profile: holger-etzel">@<bdi>holger-etzel</bdi></a><br />
Jetzt müsstest Du wissen, welches script diesen Datenpunkt erstellt hat, oder ob er überhaupt automatisch erstellt wird.</p>
]]></description><link>https://forum.iobroker.net/post/702348</link><guid isPermaLink="true">https://forum.iobroker.net/post/702348</guid><dc:creator><![CDATA[Meister Mopper]]></dc:creator><pubDate>Fri, 12 Nov 2021 17:53:52 GMT</pubDate></item></channel></rss>
