    6.5k
  • S SchuetzeSchulz
    @mcu
    Variante 1 hat nicht funktioniert, Variante 2 leider auch nicht. Bei Variante 2 kommt folgender Fehler in der Browser-Konsole:
    test.html:8 Uncaught TypeError: Cannot read properties of null (reading 'addEventListener')
        at test.html:8
    M Online
    M Online
    MCU
    #5736
    @schuetzeschulz
    Next one:
    <!DOCTYPE HTML>
    <html>
    <head>
        <title> </title>
        <style> #container {text-align: center; height: 100%;} .button { color: #333; background-color: #fff; border-color: #ccc;  font-size: 14px; font-weight: 400; border: 1px solid black; border-radius: 4px;  cursor: pointer;  line-height: 1.42857143; text-align: center; white-space: nowrap; vertical-align: middle; padding: 6px 12px;}
        </style>
        <script>
    	setTimeout(function(){
    	        var button = document.querySelector('#container .button');
            	button.addEventListener('click', fullscreen);
            	document.addEventListener('webkitfullscreenchange', fullscreenChange);
            	document.addEventListener('mozfullscreenchange', fullscreenChange);
            	document.addEventListener('fullscreenchange', fullscreenChange);
            	document.addEventListener('MSFullscreenChange', fullscreenChange);
    	},1000);
            function fullscreen() {
                // check if fullscreen mode is available
                if (document.fullscreenEnabled ||
                    document.webkitFullscreenEnabled ||
                    document.mozFullScreenEnabled ||
                    document.msFullscreenEnabled) {
                    // which element will be fullscreen
                    var iframe = document.querySelector('#container iframe');
                    // Do fullscreen
                    if (iframe.requestFullscreen) {
                        iframe.requestFullscreen();
                    } else if (iframe.webkitRequestFullscreen) {
                        iframe.webkitRequestFullscreen();
                    } else if (iframe.mozRequestFullScreen) {
                        iframe.mozRequestFullScreen();
                    } else if (iframe.msRequestFullscreen) {
                        iframe.msRequestFullscreen();
                else {
                    document.querySelector('.error').innerHTML = 'Your browser is not supported';
            function fullscreenChange() {
                    document.webkitIsFullScreen ||
                    document.mozFullScreen ||
                    document.msFullscreenElement) {
                        console.log('enter fullscreen');
                else {
                    console.log('exit fullscreen');
                // force to reload iframe once to prevent the iframe source didn't care about trying to resize the window
                // comment this line and you will see
                var iframe = document.querySelector('iframe');
                iframe.src = iframe.src;
            function onKlick(elem) { elem.requestFullscreen(); }
        </script>
    </head>
    <body style="text-align: center;" id="video1body">
        <div id="container">
            <iFrame width="320px" height="150px" src="URL" onclick="onKlick(this);" frameborder="2"
                allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture"
                allowfullscreen webkitallowfullscreen mozallowfullscreen oallowfullscreen msallowfullscreen>
            </iFrame>
            <div>
                <button class="button">FullScreen</button>
            </div>
            <div class="error"></div>
        </div>
    </body>
    </html>
    • S SchuetzeSchulz
      @mcu
          at test.html:8
      Johannes BauerstatterJ Offline
      #5737
      Ich glaub ich bin zu dämlich.
      Hab das Script laufen lassen und die IP´s eingetragen:
      In Jarvis folgendes:
      Geräte:
      Widget:
      Was mach ich falsch?
      • Johannes BauerstatterJ Johannes Bauerstatter
        Geräte:
        Widget:
        M Online
        M Online
        MCU
        #5738
        @johannes-bauerstatter Wie lautet denn der Link zur Kamera?
        In die Server-Ip kommt nur die IP 192.168.188.205, aber nur dann, wenn man die vis.0 in objData hat. Dann würde automatisch der Link erstellt mit http://SERVER-IP:8082/ + objData.
        Johannes BauerstatterJ 1 Antwort Letzte Antwort
        • M MCU
          #5739
          @mcu Ja genau. Wenn ich das in den Browser eingebe, läuft der Stream.
            M Online
            M Online
            MCU
            #5740
            @johannes-bauerstatter Stell mal bitte die objHTML rein.
            Du musst schon einmal makeHTML auf true setzen, damit eine objHTML erstellt wird.
            Und in jarvis müsste man auch die objHTML nutzen und nicht die objDataID.
            • M MCU
              schrieb am zuletzt editiert von Johannes Bauerstatter
              #5741
              @mcu Muss das Script immer laufen oder nur 1x malig? Hab den Datenpunkt auf true gestellt und auch das Script wieder gestartet. Keine Änderung:
                "common": {
                  "read": true,
                  "write": true,
                  "name": "HTML zum Objekt",
                  "type": "string",
                  "role": "text",
                  "def": ""
                "native": {},
                "type": "state",
                "from": "system.adapter.javascript.0",
                "user": "system.user.admin",
                "ts": 1636524251378,
                "_id": "0_userdata.0.jarvis.stream.objHTML",
                "acl": {
                  "object": 1636,
                  "state": 1636,
                  "owner": "system.user.admin",
                  "common": {
                    "read": true,
                    "write": true,
                    "type": "string",
                    "role": "text",
                    "def": ""
                  "native": {},
                  "type": "state",
                  "acl": {
                    "object": 1636,
                    "state": 1636,
                M Online
                M Online
                MCU
                #5742
                Das Script nutzt man um die objHTML zu erstellen.
                Das Programm muss laufen, bevor man den Schalter auf true setzt. Du musst jetzt einmal wieder auf false setzen und dann auf true.
                Benötigt man nur einmalig, ausser man hat verändernde Inhalte, dann müsste das Programm sowieso angepasst werden.
                • M MCU
                  #5743
                  @mcu Danke. Funktioniert jetzt
                    M Online
                    M Online
                    MCU
                    #5744
                    Hält der Videostream dann nach 100 Sekunden an?
                    • M MCU
                      @schuetzeschulz
                      Next one:
                      <!DOCTYPE HTML>
                      <html>
                      <head>
                          <title> </title>
                          </style>
                          <script>
                      	},1000);
                                      // Do fullscreen
                                  else {
                                  else {
                          </script>
                      </head>
                              </iFrame>
                              <div>
                              </div>
                          </div>
                      </body>
                      </html>
                      SchuetzeSchulz
                      #5745
                      @mcu sagte in jarvis v2.2.0 - just another remarkable vis:
                      <!DOCTYPE HTML> <html> <head> <title> </title> <style> #container {text-align: center; height: 100%;} .button { color: #333; background-color: #fff; border-color: #ccc; font-size: 14px; font-weight: 400; border: 1px solid black; border-radius: 4px; cursor: pointer; line-height: 1.42857143; text-align: center; white-space: nowrap; vertical-align: middle; padding: 6px 12px;} </style> <script> setTimeout(function(){ var button = document.querySelector('#container .button'); button.addEventListener('click', fullscreen); document.addEventListener('webkitfullscreenchange', fullscreenChange); document.addEventListener('mozfullscreenchange', fullscreenChange); document.addEventListener('fullscreenchange', fullscreenChange); document.addEventListener('MSFullscreenChange', fullscreenChange); },1000); function fullscreen() { // check if fullscreen mode is available if (document.fullscreenEnabled || document.webkitFullscreenEnabled || document.mozFullScreenEnabled || document.msFullscreenEnabled) { // which element will be fullscreen var iframe = document.querySelector('#container iframe'); // Do fullscreen if (iframe.requestFullscreen) { iframe.requestFullscreen(); } else if (iframe.webkitRequestFullscreen) { iframe.webkitRequestFullscreen(); } else if (iframe.mozRequestFullScreen) { iframe.mozRequestFullScreen(); } else if (iframe.msRequestFullscreen) { iframe.msRequestFullscreen(); } } else { document.querySelector('.error').innerHTML = 'Your browser is not supported'; } } function fullscreenChange() { if (document.fullscreenEnabled || document.webkitIsFullScreen || document.mozFullScreen || document.msFullscreenElement) { console.log('enter fullscreen'); } else { console.log('exit fullscreen'); } // force to reload iframe once to prevent the iframe source didn't care about trying to resize the window // comment this line and you will see var iframe = document.querySelector('iframe'); iframe.src = iframe.src; } function onKlick(elem) { elem.requestFullscreen(); } </script> </head> <body style="text-align: center;" id="video1body"> <div id="container"> <iFrame width="320px" height="150px" src="URL" onclick="onKlick(this);" frameborder="2" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture" allowfullscreen webkitallowfullscreen mozallowfullscreen oallowfullscreen msallowfullscreen> </iFrame> <div> <button class="button">FullScreen</button> </div> <div class="error"></div> </div> </body> </html>
                      Damit funktioniert das mit dem Button. Also klicke ich auf den Button kommt Vollbild.
                      • S SchuetzeSchulz
                        M Online
                        M Online
                        MCU
                        #5746
                        @schuetzeschulz Zufrieden, oder muss ich noch weiterschauen?
                        • M MCU
                          SchuetzeSchulz
                          #5747
                          @mcu Naja, ich würde es "besser" finden, wenn das Vollbild kommt wenn ich auf das Kamerabild drücke/klicke. Also quasi ohne den Button...
                          • S SchuetzeSchulz
                            M Online
                            M Online
                            MCU
                            #5748
                            @schuetzeschulz Dafür habe ich keinen Ansatz mehr. Das scheint an der Software für die Anzeige der Kamera zu liegen. Welche Kamera ist das?
                            • M MCU
                              #5749
                              @mcu Ja, funktioniert auch. War gewollt zum Testen.
                              • M MCU
                                SchuetzeSchulz
                                #5750
                                @mcu Habe 3 Wansview W3 Kameras im Einsatz.
                                • R Offline
                                  RkcCorian
                                  #5751
                                  Kenn jemand die CSS um die "Headings" (Überschriften) der Widgets anzupassen? Also Symbolgröße, Transparenz, sowie Schriftgröße? Vielen Dank!
                                  • R RkcCorian
                                    M Online
                                    M Online
                                    MCU
                                    #5752
                                    @rkccorian
                                    https://mcuiobroker.gitbook.io/jarvis-infos/jarvis/besonderheiten-v3/styles/statelist-1/.q-item__section--main
                                    R 1 Antwort Letzte Antwort
                                    • M MCU
                                      @rkccorian
                                      RkcCorian
                                      #5753
                                      @mcu Für .q-item__section--main .q-item__label.text-h6 gibt es (noch) kein jarvis-wasAuchImmerEigenesCss?!
                                      • R RkcCorian
                                        M Online
                                        M Online
                                        MCU
                                        #5754
                                        @rkccorian Nein. Es gibt jarvis-header, hat aber die Überschrift nicht mit drin? Bin mir grade nicht sicher.
                                        .jarvis-widget-header
                                          sicadrip
                                          #5755
                                          @Zefau
                                          Ich vermisse in der aktuellen alpha.125 beim DateTime Modul die Einstellung "Style des Textes (JSON Format)". Kommt das wieder dazu?
                                          v3.0.0-alpha.125
                                          v2.3.3
