  4. node-red fenster nach update auf 2.4.0
    6.4k
85 Beiträge 5 Kommentatoren 4.6k Aufrufe 3 Beobachtet
    @fournierrf5
    Hier geht's auch mit ganz 'krummen' Beta-Versionen:
    echad@chet:/opt/iobroker $ iobroker add node-red
    NPM version: 8.1.0
    npm install iobroker.node-red@2.4.1 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
    host.chet install adapter node-red
    upload [14] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/words.js words.js application/javascript
    upload [13] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/node-red.png node-red.png image/png
    upload [12] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/index_m.html index_m.html text/html
    upload [11] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/index.html index.html text/html
    upload [10] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
    upload [9] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
    upload [8] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
    upload [7] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
    upload [6] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
    upload [5] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/it/translations.json i18n/it/translations.json application/json
    upload [4] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
    upload [3] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/es/translations.json i18n/es/translations.json application/json
    upload [2] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/en/translations.json i18n/en/translations.json application/json
    upload [1] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/de/translations.json i18n/de/translations.json application/json
    upload [0] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/bcrypt.min.js bcrypt.min.js application/javascript
    host.chet object system.adapter.node-red created/updated
    host.chet create instance node-red
    host.chet object node-red.0 created
    host.chet object system.adapter.node-red.0.logLevel created
    host.chet object system.adapter.node-red.0.sigKill created
    host.chet object system.adapter.node-red.0.eventLoopLag created
    host.chet object system.adapter.node-red.0.outputCount created
    host.chet object system.adapter.node-red.0.inputCount created
    host.chet object system.adapter.node-red.0.uptime created
    host.chet object system.adapter.node-red.0.memRss created
    host.chet object system.adapter.node-red.0.memHeapTotal created
    host.chet object system.adapter.node-red.0.memHeapUsed created
    host.chet object system.adapter.node-red.0.cputime created
    host.chet object system.adapter.node-red.0.cpu created
    host.chet object system.adapter.node-red.0.compactMode created
    host.chet object system.adapter.node-red.0.connected created
    host.chet object system.adapter.node-red.0.alive created
    host.chet object system.adapter.node-red.0 created
    Jan1
    #74
    @thomas-braun sagte in node-red fenster nach update auf 2.4.0:
    NPM version: 8.1.0
    Ich glaube er meint die NPM Version :)
    • J Jan1
      NPM version: 8.1.0
      mickymM Offline
      mickymM Offline
      mickym
      #75
      @jan1 Ach so - Danke :)
        @fournierrf5
        NPM version: 8.1.0
        #76
        @thomas-braun bei mir kommen immerhin die serialport Meldungen ;-)
        Ebenfalls aus dem Installationsfenster kopiert
        $ iobroker add node-red --host raspberrypi
        NPM version: 6.14.15
        npm install iobroker.node-red@2.4.0 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
        node-aead-crypto not needed on this system, since all ciphers are natively supported
        ../src/linux/BluetoothSerialPort.cc:18:14: error: variable or field ‘InitAll’ declared void
        void InitAll(Handle<Object> exports) { ^~~~~~../src/linux/BluetoothSerialPort.cc:18:14: error: ‘Handle’ was not declared in this scope
        ../src/linux/BluetoothSerialPort.cc:18:14: note: suggested alternative: ‘rand_r’
        void InitAll(Handle<Object> exports) { ^~~~~~ rand_r../src/linux/BluetoothSerialPort.cc:18:27: error: expected primary-expression before ‘>’ token void InitAll(Handle<Object> exports) { ^../src/linux/BluetoothSerialPort.cc:18:29: error: ‘exports’ was not declared in this scope void InitAll(Handle<Object> exports) { ^~~~~~~
        In file included from ../src/linux/BluetoothSerialPort.cc:12:../src/linux/BluetoothSerialPort.cc:23:34: error: ‘InitAll’ was not declared in this scope NODE_MODULE(BluetoothSerialPort, InitAll) ^~~~~~~
        /home/iobroker/.cache/node-gyp/12.22.7/include/node/node.h:736:36: note: in definition of macro ‘NODE_MODULE_X’ (node::addon_register_func) (regfunc), \ ^~~~~~~../src/linux/BluetoothSerialPort.cc:23:1: note: in expansion of macro ‘NODE_MODULE’ NODE_MODULE(BluetoothSerialPort, InitAll) ^~~~~~~~~~~
        make: *** [BluetoothSerialPort.target.mk:115: Release/obj.target/BluetoothSerialPort/src/linux/BluetoothSerialPort.o] Fehler 1
        gyp ERR! build error
        gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)gyp ERR! stack at ChildProcess.emit (events.js:314:20)gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:276:12)
        gyp ERR! System Linux 5.10.63-v7l+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "build"gyp ERR! cwd /opt/iobroker/node_modules/node-bluetoothgyp ERR! node -v v12.22.7
        gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
        In file included from ../src/bcrypt_node.cc:1:
        ../node_modules/nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:../node_modules/nan/nan.h:2232:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete) ^
        In file included from ../node_modules/nan/nan.h:53,
        from ../src/bcrypt_node.cc:1:../src/bcrypt_node.cc: At global scope:/home/iobroker/.cache/node-gyp/12.22.7/include/node/node.h:736:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type] (node::addon_register_func) (regfunc), \ ^/home/iobroker/.cache/node-gyp/12.22.7/include/node/node.h:770:3: note: in expansion of macro ‘NODE_MODULE_X’ NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage) ^~~~~~~~~~~~~../src/bcrypt_node.cc:378:1: note: in expansion of macro ‘NODE_MODULE’ NODE_MODULE(bcrypt_lib, init); ^~~~~~~~~~~
        ../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:../../nan/nan.h:2298:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete) ^
        In file included from ../../nan/nan.h:54,
        from ../src/bcrypt_node.cc:1:../src/bcrypt_node.cc: At global scope:/home/iobroker/.cache/node-gyp/12.22.7/include/node/node.h:736:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type] (node::addon_register_func) (regfunc), \ ^/home/iobroker/.cache/node-gyp/12.22.7/include/node/node.h:770:3: note: in expansion of macro ‘NODE_MODULE_X’ NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage) ^~~~~~~~~~~~~../src/bcrypt_node.cc:359:1: note: in expansion of macro ‘NODE_MODULE’ NODE_MODULE(bcrypt_lib, init); ^~~~~~~~~~~
        host.raspberrypi install adapter node-red
        host.raspberrypi object system.adapter.node-red created/updated
        host.raspberrypi create instance node-red
        host.raspberrypi object node-red.0 created
        host.raspberrypi object system.adapter.node-red.0.logLevel created
        host.raspberrypi object system.adapter.node-red.0.sigKill created
        host.raspberrypi object system.adapter.node-red.0.eventLoopLag created
        host.raspberrypi object system.adapter.node-red.0.outputCount created
        host.raspberrypi object system.adapter.node-red.0.inputCount created
        host.raspberrypi object system.adapter.node-red.0.uptime created
        host.raspberrypi object system.adapter.node-red.0.memRss created
        host.raspberrypi object system.adapter.node-red.0.memHeapTotal created
        host.raspberrypi object system.adapter.node-red.0.memHeapUsed created
        host.raspberrypi object system.adapter.node-red.0.cputime created
        host.raspberrypi object system.adapter.node-red.0.cpu created
        host.raspberrypi object system.adapter.node-red.0.compactMode created
        host.raspberrypi object system.adapter.node-red.0.connected created
        host.raspberrypi object system.adapter.node-red.0.alive created
        host.raspberrypi object system.adapter.node-red.0 created
        Process exited with code 0
        und dann auch die Meldung wie bei @fournierrf5
        Das passt dann auch!
        also fehlte bei @fournierrf5 doch eine ganze Menge
        Die Installation ist also nicht das Problem.
        Die ist vollständig installiert
        • mickymM mickym
          @thomas-braun Na nur weil ich mal eine Fehlerkorrektur mit eingebracht habe, muss man ja nicht gleich von ganz "krummen" Betaversionen sprechen. ;)
          @fournierrf5
          Und wenn es halt gar nicht mehr tut und Dein System sich nur noch merkwürdig verhält - dann mach halt via backitup Adapter ein Backup und mach ein neues OS Image mit bullseye und Node 14 - installiere iobroker neu - das funktioniert bei mir tadellos. Ich mach allerdings auch keine Spielereien mit Anmeldung etc - im internen Netz.
          #77
          @mickym sagte in node-red fenster nach update auf 2.4.0:
          Sorry, das meinte ich nicht. Damit war mein eigenes System gemeint, das im Moment mit nodeJS@17 und npm@8.1.0 läuft.
            #78
            @homoran sagte in node-red fenster nach update auf 2.4.0:
            Vielleicht mal node@14 probieren? Weiter raus würde ich aber nicht rudern.
              #79
              Das sollte nicht das Problem sein.
              ich tippe inzwischen wie @mickym darauf, dass etwas mit seinen Flows nicht stimmt.
              Da @fournierrf5 aber zum Glück alle Flows (einzeln???) gesichert hat, wäre es IMHO im Moment das sinnvollste den Rat von @mickym zu befolgen und alle zugehörigen Dateien zu löschen, dann den Adapter neu zu installieren und danach die Flows einzeln nacheinander zu importieren, bzw. externe nodes ebenfalls einzeln zu installieren.
              Sobald dann das Problem wieder auftritt weiß man ja an welchem Flow / node es lag.
              Thomas BraunT F 2 Antworten Letzte Antwort
                #80
                Da hab ich keine Ahnung von.
                  #81
                  ich auch nicht so wirklich, ist aber so wie wenn bei vis ein View, oder gar nur ein Widget, krumm ist, dann kann man gar nichts mehr aufrufen
                    mickymM Offline
                    mickymM Offline
                    mickym
                    #82
                    @homoran Auch wenn er die Flows nicht einzeln hat - Probleme machen ja dann oft auch die nachinstallierten NOdes.
                    Deshalb war mein Vorschlag - neben dem kompletten neu aufsetzen des Systems und zurückspielen eines Backups - den Adapter erst mal so zu installieren, dass man wenigstens wieder einen funktionierenden Adapter mit einem leeren Flow Fenster hat.
                    Dann kann man über Node-Red auch die letztes flows.json importieren.
                    Bei der Wiederinstallation hat man auch die neuesten Nodes. Das Problem was ich allerdings sehe, wenn man nicht den Palettenmanager im Node-Red nutzt (früher war das zwingend) - ab der Version 2 des Adapter kann man es über die Adapterkonfig machen. Dann hat man allerdings den Nachteil, dass man nicht sieht ob neue Versionen der Nodes exisitieren.
                    Und der apt-Manager erkennt keine Updates für Node-Red Nodes. Ich hab mal gerade bei mir geschaut und gesehen, dass wieder ein paar Updates verfügbar sind, die einem aber so im iobroker nicht angezeigt werden, da dieser die Nodes ja nicht kennt - keine Ahnung ob er die Updates kennt, wenn man nicht den Palettenmanager nutzt.
                    Deswegen sollte man da auch hin und wieder mal reinschauen, damit einem die Systemumgebung nicht wegläuft und man völlig veraltete Nodes verwendet.
                    @fournierrf5
                    Das wäre übrigens überhaupt eine Idee. Du sagst ja unter Node.js 10 funktioniert alles. Dann schau mal, im Palettenmanager ob Du Nodes updaten kannst bevor Du auf Node.js 12 oder 14 gehst.
                    Ich mache das gerade und im Palettenmanager halt dann auf
                    Zeige Protokoll klicken, dann siehst Du ob der npm richtig arbeitet:
                    2021-11-06T17:41:08.905Z Installieren : node-red-contrib-ui-time-scheduler 1.16.1
                    2021-11-06T17:41:08.720Z npm install --no-audit --no-update-notifier --no-fund --save --save-prefix=~ --production node-red-contrib-ui-time-scheduler@1.16.1
                    2021-11-06T17:41:21.407Z [err] npm
                    2021-11-06T17:41:21.407Z [err]  WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.13 (node_modules/fsevents):
                    2021-11-06T17:41:21.407Z [err] npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.13: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                    2021-11-06T17:41:21.408Z [err]
                    2021-11-06T17:41:21.410Z [out] + node-red-contrib-ui-time-scheduler@1.16.1
                    2021-11-06T17:41:21.410Z [out] updated 1 package in 10.665s
                    2021-11-06T17:41:21.443Z rc=0
                    2021-11-06T17:41:45.659Z Installieren : node-red-contrib-buffer-parser 3.1.7
                    2021-11-06T17:41:45.403Z npm install --no-audit --no-update-notifier --no-fund --save --save-prefix=~ --production node-red-contrib-buffer-parser@3.1.7
                    2021-11-06T17:41:56.922Z [err] npm
                    2021-11-06T17:41:56.923Z [err]  WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.13 (node_modules/fsevents):
                    2021-11-06T17:41:56.923Z [err] npm
                    2021-11-06T17:41:56.923Z [err] WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.13: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                    2021-11-06T17:41:56.924Z [err]
                    2021-11-06T17:41:56.926Z [out] + node-red-contrib-buffer-parser@3.1.7
                    2021-11-06T17:41:56.926Z [out] updated 1 package in 9.965s
                    2021-11-06T17:41:56.961Z rc=0
                    2021-11-06T17:42:17.690Z Installieren : node-red-contrib-homekit-bridged 1.4.3
                    2021-11-06T17:42:17.428Z npm install --no-audit --no-update-notifier --no-fund --save --save-prefix=~ --production node-red-contrib-homekit-bridged@1.4.3
                    2021-11-06T17:42:43.436Z [err] npm
                    2021-11-06T17:42:43.436Z [err]  WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.13 (node_modules/fsevents):
                    2021-11-06T17:42:43.437Z [err] npm
                    2021-11-06T17:42:43.437Z [err] WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.13: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                    2021-11-06T17:42:43.438Z [err]
                    2021-11-06T17:42:43.440Z [out] + node-red-contrib-homekit-bridged@1.4.3
                    2021-11-06T17:42:43.440Z [out] added 7 packages from 3 contributors, updated 24 packages and moved 3 packages in 24.557s
                    2021-11-06T17:42:43.476Z rc=0
                    2021-11-06T17:43:39.503Z Installieren : node-red-contrib-light-scheduler 0.0.18
                    2021-11-06T17:43:39.231Z npm install --no-audit --no-update-notifier --no-fund --save --save-prefix=~ --production node-red-contrib-light-scheduler@0.0.18
                    2021-11-06T17:43:52.379Z [err] npm
                    2021-11-06T17:43:52.379Z [err]  WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.13 (node_modules/fsevents):
                    2021-11-06T17:43:52.379Z [err] WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.13: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                    2021-11-06T17:43:52.380Z [err]
                    2021-11-06T17:43:52.382Z [out] + node-red-contrib-light-scheduler@0.0.18
                    2021-11-06T17:43:52.382Z [out] removed 2 packages and updated 3 packages in 11.708s
                    2021-11-06T17:43:52.417Z rc=0
                    2021-11-06T17:44:33.101Z Installieren : node-red-dashboard 3.1.1
                    2021-11-06T17:44:32.826Z npm install --no-audit --no-update-notifier --no-fund --save --save-prefix=~ --production node-red-dashboard@3.1.1
                    2021-11-06T17:44:50.500Z [err] npm
                    2021-11-06T17:44:50.500Z [err]  WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.13 (node_modules/fsevents):
                    2021-11-06T17:44:50.500Z [err] WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.13: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                    2021-11-06T17:44:50.501Z [err]
                    2021-11-06T17:44:50.504Z [out] + node-red-dashboard@3.1.1
                    2021-11-06T17:44:50.504Z [out] added 6 packages from 8 contributors, removed 23 packages and updated 14 packages in 15.968s
                    2021-11-06T17:44:50.537Z rc=0
                    Wenn dann alles aktualisiert ist:
                    muss Du den Adapter eh einmal neu starten.
                    • mickymM mickym
                      @fournierrf5
                      #83
                      Ja, das ist klar. Das sind ja auch keine deb-Pakete direkt vom OS. Das wird dann offenbar über eine Entsprechung (paletten-Manager?) von node-red gemacht. nodeJS-Module kommen ja auch nicht über apt sondern über den npm (node package manager) rein.
                        fournierrf5
                        #84
                        Das Problem existiert bereits ohne flows, sobald der adapter installiert wird.
                        node.js 14.xx hat selben erfolg gebraucht.
                        Zuletzt hat sich nodered nicht mal mehr deinstallieren lassen, jetzt das ist das backup image neu geflasht und alles läuft wieder wie zu beginn
                        • mickymM mickym
                          @fournierrf5
                          fournierrf5
                          #85
                          @mickym
                          ich benutze ausschliesslich den palettenmanager. es ist und war auch alles aktuell!
