  4. go-e Adapter
go-e Adapter
1.0k Beiträge 83 Kommentatoren 466.4k Aufrufe 33 Beobachtet
    @wildbill
    Hab die 051.4 und mal auf debug gestellt, das wiederholt sich dauernd...:
    2021-09-28 22:17:26.593  - debug: go-e.0 (101837) state go-e.0.ampere changed: 16 (ack = true) namespace: go-e.0
    2021-09-28 22:17:26.596  - debug: go-e.0 (101837) state go-e.0.amperePV changed: 0 (ack = true) namespace: go-e.0
    2021-09-28 22:17:26.599  - debug: go-e.0 (101837) state go-e.0.access_state changed: 1 (ack = true) namespace: go-e.0
    2021-09-28 22:17:26.601  - debug: go-e.0 (101837) state go-e.0.allow_charging changed: 0 (ack = true) namespace: go-e.0
    2021-09-28 22:17:26.603  - debug: go-e.0 (101837) state go-e.0.stop_state changed: 0 (ack = true) namespace: go-e.0
    2021-09-28 22:17:26.649  - debug: go-e.0 (101837) state go-e.0.max_load changed: 50 (ack = true) namespace: go-e.0
    2021-09-28 22:17:26.667  - debug: go-e.0 (101837) state go-e.0.settings.ampere_level1 changed: 6 (ack = true) namespace: go-e.0
    2021-09-28 22:17:26.669  - debug: go-e.0 (101837) state go-e.0.settings.ampere_level2 changed: 10 (ack = true) namespace: go-e.0
    2021-09-28 22:17:26.671  - debug: go-e.0 (101837) state go-e.0.settings.ampere_level3 changed: 12 (ack = true) namespace: go-e.0
    2021-09-28 22:17:26.673  - debug: go-e.0 (101837) state go-e.0.settings.ampere_level4 changed: 14 (ack = true) namespace: go-e.0
    2021-09-28 22:17:26.674  - debug: go-e.0 (101837) state go-e.0.settings.ampere_level5 changed: 16 (ack = true) namespace: go-e.0
    2021-09-28 22:17:26.677  - debug: go-e.0 (101837) state go-e.0.settings.color.idle changed: #ff (ack = true) namespace: go-e.0
    2021-09-28 22:17:26.678  - debug: go-e.0 (101837) state go-e.0.settings.color.charging changed: #ffff (ack = true) namespace: go-e.0
    2021-09-28 22:17:26.680  - debug: go-e.0 (101837) state go-e.0.settings.color.finish changed: #ff00 (ack = true) namespace: go-e.0
    2021-09-28 22:17:26.747  - info: go-e.0 (101837) State value to set for "go-e.0.temperatures.tempereatureArray" has to be stringified but received type "object"
    2021-09-28 22:17:26.748  - debug: go-e.0 (101837) Cant write temp single temps. Expected 3 elements got ["18.125","22.875"]
    2021-09-28 22:17:26.761  - debug: go-e.0 (101837) state go-e.0.unlock_state changed: 0 (ack = true) namespace: go-e.0
    2021-09-28 22:17:56.437  - debug: go-e.0 (101837) Starte Abfrage an: http://192.168.0.124/status
    2021-09-28 22:17:56.663  - debug: go-e.0 (101837) Response: 200 - OK with data as object
    2021-09-28 22:17:56.663  - debug: go-e.0 (101837) {"version":"B","tme":"2809212217","rbc":"10","rbt":"20814595","car":"1","amx":"0","amp":"16","err":"0","ast":"1","alw":"0","stp":"0","cbl":"0","pha":"56","fsp":"0","tma":[18.125,22.875],"dws":"2457353","dwo":"500","adi":"1","uby":"0","eto":"148","wst":"3","fwv":"051.4","nrg":[234,235,234,0,0,0,0,0,0,0,0,0,0,0,0,0],"sse":"059285","wss":"MITS","wke":"********","wen":"1","cdi":"0","tof":"101","tds":"1","lbr":"149","aho":"0","afi":"6","azo":"1","ama":"16","al1":"6","al2":"10","al3":"12","al4":"14","al5":"16","cid":"255","cch":"65535","cfi":"65280","lse":"1","ust":"0","wak":"********","r1x":"2","dto":"0","nmo":"0","sch":"AAAAAAAAAAAAAAAA","sdp":"0","eca":"0","ecr":"0","ecd":"0","ec4":"0","ec5":"0","ec6":"0","ec7":"0","ec8":"0","ec9":"0","ec1":"0","rca":"1","rcr":"1","rcd":"","rc4":"","rc5":"","rc6":"","rc7":"","rc8":"","rc9":"","rc1":"","rna":"ChipGoE","rnm":"BlueChip","rne":"User 3","rn4":"User 4","rn5":"User 5","rn6":"User 6","rn7":"User 7","rn8":"User 8","rn9":"User 9","rn1":"User 10","loe":0,"lot":32,"lom":6,"lop":50,"log":"","lof":0,"loa":0,"lch":259}
    W Online
    W Online
    Wildbill
    #357
    @ilovegym sagte in Go e-charger:
    Die zwei Zeilen zeigen, dass nicht alles passt bzw. die Daten von Deiner Box wohl nicht so kommen, wie der Adapter sie erwartet. Für Meldung 1 gibt es bereits ein Issue bei Github. Meldung 2 erscheint mir wirklich so, als ob Deine Box da nicht mehr alles so ausgibt, wie es der Adapter erwartet. Es werden wohl 3 Temperaturwerte erwartet, Deine Box gibt aber nur zwei aus. Da kann ich Dir leider auch nicht weiter helfen, da musst Du evtl. selbst ein Issue aufmachen.
    Gruss, Jürgen
    • W Wildbill
      Gruss, Jürgen
      #358
      @wildbill Danke, hab ich mir gedacht...
      Issue ist erledigt:
      https://github.com/MK-2001/ioBroker.go-e/issues/90
      • W Wildbill
        @ilovegym Bei mir kommen sowohl die vier einzelnen, als auch der Array an. Welche Version hat Deine Box? Vielleicht ist bei der aktuellen V3 ja etwas anders aufgebaut.
        Gruß, Jürgen
        lobomauL Offline
        lobomauL Offline
        lobomau
        schrieb am zuletzt editiert von lobomau
        #359
        @wildbill @ilovegym
        Bei der WB Version mit firmware 0.40 habe ich die Temperatur unter "go-e.0.temperatures.maintempereature".
        Bei der neuen WB mit Firmware 051.4 habe ich eine Temperatur unter "go-e.1.temperatures.tempereatureArray" wie auch ilovegym.
        @Wildbill benutzt du ein widget zur Darstellung dieses arrays? Bei mir wird in VIS der Wert korrekt angezeigt, wenn ich unter edit bin, aber in der VIS erscheint dann kein Wert.
        FW 040.0:
        FW 051.4
        Im Widget fehlt mir die Temp-anzeige der neuen WB:
        Edit: die Adapter laufen bei mir beim log als "warn", damit diese Info Meldung nicht ständig erscheint.
        Host: NUC8i3 mit Proxmox:
        • Slave: Pi4
        W HomoranH 2 Antworten Letzte Antwort
        • lobomauL lobomau
          @wildbill @ilovegym
          FW 040.0:
          FW 051.4
          W Online
          W Online
          Wildbill
          #360
          @lobomau Nein, ich verwende da nichts in der VIS, wüsste aber auch nicht, welches Widget einen Array direkt anzeigen/auflösen könnte. Vermutlich musst Du den selbst erst in einzelne Datenpunkte aufdröseln?!
          Meine FW ist im Übrigen 041.0, das ist aber die aktuellste, die mir für meine Box (V2 laut App) angeboten wird. Wird wohl dann mit unterschiedlichen Box- und FW-Versionen zusammenhängen, die der Adapter nicht nicht alle korrekt kennt und handlen kann..
          Gruss, Jürgen
          • lobomauL lobomau
            @wildbill @ilovegym
            FW 040.0:
            FW 051.4
            #361
            @lobomau sagte in Go e-charger:
            @Wildbill
            @ilovegym
            ich habe auch nur einen Wert für die Temperaturen. Ich arbeite auch mit der 0.40
            • W Wildbill
              Gruss, Jürgen
              lobomauL Offline
              lobomauL Offline
              lobomau
              #362
              @wildbill ah..sehe grad, dass 0.41 angeboten wird. Lade ich mal. Wobei nur von Stabilität und Fehlerverbesserungen die Rede ist, ich habe aber keine Probleme.
              Edit.: Update ging fix. Sehe erstmal keinen Unterschied. Wird schon laufen ;-)
              • Slave: Pi4
              W 1 Antwort Letzte Antwort
              • lobomauL lobomau
                W Online
                W Online
                Wildbill
                #363
                @lobomau Das Update auf die 41 wurde bei mir anscheinend irgendwann automatisch installiert. Ich hatte ursprünglich die 33 auf der Box und wollte nie updaten, da der Elektriker mir davon abriet, da die Nachfolgeversion (keine Ahnung welche das war) wohl öfter Probleme machen würde bei Boxen die er kennt.
                Ob das Update dann mit einem Update der App oder beim wechseln von Android zu Iphone passiert ist, kann ich nicht sagen, aber sie läuft.
                Mir fällt aber eben auf, dass bei mir in iobroker auch nur noch die Datenpunkte maintemperature und temperatureArray aktualisiert werden. Temperature1-4 haben sich seit 28.08. nicht mehr geändert. Fiel mir nur nur auf, weil ich da normal nicht schaue. Aber dann scheint es eindeutig mit irgendeiner Fw geändert worden zu sein.
                Gruß, Jürgen
                • FreunderNachtF Offline
                  FreunderNacht
                  schrieb am zuletzt editiert von FreunderNacht
                  #364
                  bei uns sollen insgesamt 3 Wallboxen installiert werden.
                  Ich hatte da an 2 11KW Go e Charger und eine 22 kW Keba p30 x gedacht (die P30, da ich gerne eine 22kw Ladestation haben wollte, die allerdings wegen der Förderung gedrosselt werden kann (geht ja leider bei der 22KW vom Go e nicht)).
                  Kann ich beide Wallboxen von Go e mit dem Adapter verwalten ?
                  Brauch ich dafür 2 Instanzen?
                  Gruß Freund der Nacht
                  Intel NUC mit Proxmox
                  IO Broker (Homematic IP / CCU3 / Shelly / Tasmota / Zigbee)
                  Influx DB
                  Grafana
                  PiHole
                  PiVPN
                  JLegJ 1 Antwort Letzte Antwort
                  • FreunderNachtF FreunderNacht
                    JLegJ Offline
                    JLegJ Offline
                    JLeg
                    #365
                    @freundernacht sagte in Go e-charger:
                    welche Förderung? 😬
                    FreunderNachtF 1 Antwort Letzte Antwort
                    • JLegJ JLeg
                      welche Förderung? 😬
                      FreunderNacht
                      #366
                      @jleg
                      Die Förderung von der KFW.
                      Ich hatte Glück und hab alle 3 noch genehmigt bekommen.
                      Mittlerweile ist der Fördertopf allerdings (mal wieder) leer.
                      https://www.kfw.de/inlandsfoerderung/Privatpersonen/Bestehende-Immobilie/Förderprodukte/Ladestationen-für-Elektroautos-Wohngebäude-(440)/
                      Influx DB
                      Grafana
                      PiHole
                      PiVPN
                      • ? Offline
                        #367
                        @wildbill ich hab inzwischen die 51.8 drauf und die laeuft super.
                        Ja, der Fehler mit den Temp. ist bekannt aber der Developer des Adapter hat wohl keine Zeit.. :-(
                          @jleg
                          #368
                          @freundernacht pro Wallbox eine Instanz, sonst gehts wohl nicht. Sind die Keba mit der Go-e baugleich und laufen mit dem gleichen Adapter??
                            FreunderNacht
                            #369
                            @ilovegym
                            Hallo Bernd,
                            die Keba hat einen eigenen Adapter.
                            Allerdings kann hier, laut Forum, nur 1 Wallbox verwaltet werden, egal mit wie viel Instanzen.
                            Ich würde mir lieber 3 22 KW Wallboxen von Go e holen, das fällt aber leider aufgrund der Förderung weg, da sich die von Go e nicht drosseln lassen.
                            Aber die Verwaltung von mehreren Wallboxen ist ein massiver Vorteil bei Go e.
                            Influx DB
                            Grafana
                            PiHole
                            PiVPN
                              @ilovegym
                              Hallo Bernd,
                              lobomauL Offline
                              lobomauL Offline
                              lobomau
                              #370
                              @freundernacht ich habe zwei Goe-charger installiert und über ioBroker eingebunden. Funktioniert wunderbar mit zwei Instanzen.
                              Ich habe:
                              • goe-charger 22kW V2
                              • goe-charger 11KW V3
                              Dabei funktioniert nicht das hauseigene Lastmanagement, weil V2 und V3 nicht zusammen funktionieren. Aber den Fall werden die meisten wohl nicht haben.
                              Das Lastmanagement mache ich über ioBroker realisiert und es funktioniert hervorragend. Die beiden Wallboxen sind nämlich am selben Anschluss über 16A abgesichert. Über ioBroker stelle ich sicher, dass nicht mehr als 20A pro Phase anstehen können.
                              • Slave: Pi4
                              JLegJ FreunderNachtF 2 Antworten Letzte Antwort
                              • lobomauL lobomau
                                Ich habe:
                                JLegJ Offline
                                JLegJ Offline
                                JLeg
                                #371
                                Oops, gut zu wissen - die 2. steht bei mir demnächst an - muss ich dann wohl auch per Script regeln...
                                leider doch; hatte damals vermutlich eine der letzten V2 Go-e erwischt... :-/
                                • lobomauL lobomau
                                  Ich habe:
                                  FreunderNacht
                                  #372
                                  @lobomau
                                  Vielen Dank für die Rückmeldung, bei mir werden es dann wahrscheinlich doch 3 go eCharger
                                  Wallboxen und somit 3 Instanzen werden.
                                  Die Verwaltung über den IO Broker scheint mit dem go eCharger doch wesentlich einfacher als mit der Keba zu sein.
                                  Wird für den Adapter eigentlich die Cloud benötigt, oder arbeitet er komplett ohne die Cloud?
                                  MfG
                                  Freund der Nacht
                                  Influx DB
                                  Grafana
                                  PiHole
                                  PiVPN
                                    @lobomau
                                    MfG
                                    Freund der Nacht
                                    #373
                                    Nein!
                                    Könnte aber, wenn man unbedingt wollte
                                    • JLegJ Offline
                                      JLegJ Offline
                                      JLeg
                                      #374
                                      @homoran sagte in Go e-charger:
                                      Nein!
                                      genau - und beides läuft problemlos parallel, iobroker greift über die lokale IP zu, und wenn man unterwegs mal nachschauen möchte, kann man die App über die Cloud nutzen…
                                      • JLegJ JLeg
                                        lobomauL Offline
                                        lobomauL Offline
                                        lobomau
                                        #375
                                        @jleg vielleicht kommt ja mal ein Update dazu!? Ist hier Stand August 2021:
                                        • Slave: Pi4
                                        • lobomauL lobomau
                                          JLegJ Offline
                                          JLegJ Offline
                                          JLeg
                                          #376
                                          ok, das "noch" gibt Hoffnung 😊 - dürfte letztlich ja eigentlich eine reine Softwarefrage sein, denke ich. Bin mit dem go-e-charger aber so zufrieden (auch was den Support betrifft), dass ich mir in jedem Fall eine weitere Box holen werde...
